[PATCH V2] efi_loader: loosen buffer parameter check in efi_file_read_int
This is same issue as https://bugzilla.redhat.com/show_bug.cgi?id=1733817, but that fix was wrongly partial reverted.
When reading a directory, EFI_BUFFER_TOO_SMALL should be returned when the supplied buffer is too small, so a use-case is to call EFI_FILE_PROTOCOL.Read() with *buffer_size=0 and buffer=NULL to obtain the needed size before doing the actual read.
So remove the check only for directory reading, file reading already do the check by itself.
Fixes: db12f518edb0("efi_loader: implement non-blocking file services") Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Stefan Sørensen stefan.sorensen@spectralink.com Tested-by: Peter Robinson pbrobinson@gmail.com Signed-off-by: Peng Fan peng.fan@nxp.com ---
V2: Update commit log Per Heinrich's comments. Add T-b tag
lib/efi_loader/efi_file.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_file.c b/lib/efi_loader/efi_file.c index 204105e25a..6b3f5962be 100644 --- a/lib/efi_loader/efi_file.c +++ b/lib/efi_loader/efi_file.c @@ -554,7 +554,7 @@ static efi_status_t efi_file_read_int(struct efi_file_handle *this, efi_status_t ret = EFI_SUCCESS; u64 bs;
- if (!this || !buffer_size || !buffer) + if (!this || !buffer_size) return EFI_INVALID_PARAMETER;
bs = *buffer_size;
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
bs = *buffer_size;
st 28. 4. 2021 v 15:22 odesílatel Peng Fan (OSS) peng.fan@oss.nxp.com napsal:
if (!this || !buffer_size) return EFI_INVALID_PARAMETER; bs = *buffer_size;
-- 2.30.0
Tested-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
Michal Simek
Peng Fan (OSS)
