[U-Boot] [PATCH 00/48] stm32mp1 patches for v2019.10
Second serie of patches for stm32mp1 support in U-Boot - sync device tree with kernel v5.3-rc2 - update configs - update board stm32mp1 - few ram and clk driver update
Christophe Kerello (1): mmc: stm32_sdmmc2: reload watchdog
Patrice Chotard (2): pinctrl: pinctrl_stm32: cosmetic: Reorder include files stm32mp1: configs: Set bootdelay to 1
Patrick Delaunay (45): stm32mp1: cosmetic: remove comment pinctrl: stmfx: update pinconf settings ARM: dts: stm32mp1: sync device tree with v5.3-rc2 ARM: dts: stm32mp1: DDR config v1.45 ARM: dts: stm32mp1: Add iwdg2 support for SPL ARM: dts: stm32mp1: Add PSCI node access before relocation ARM: dts: stm32mp1: add ldtc pre-reloc proper in SOC file ARM: dts: stm32mp1: add key support on DK1/DK2 ARM: dts: stm32mp1: add pull-up on serial rx of console connected to STLINK dt-bindings: clock: stm32mp1: support disabled fixed clock stpmic1: program pmic to keep only the debug unit on stm32mp1: configs: remove CONFIG_SYS_HZ stm32mp1: configs: activate CONFIG_SILENT_CONSOLE stm32mp1: configs: activate PRE_CONSOLE_BUFFER stm32mp1: configs: deactivate ARMV7_VIRT for basic boot stm32mp1: configs: select CONFIG_STM32_SERIAL stm32mp1: configs: Activate DISABLE_CONSOLE stm32mp1: configs: support MTDPARTS only if needed stm32mp1: configs: imply CONFIG_OF_LIBFDT_OVERLAY stm32mp1: configs: Deactivate SPI_FLASH_BAR stm32mp1: configs: add CONFIG_DM_VIDEO stm32mp1: configs: add BACKLIGHT_GPIO support stm32mp1: configs: add CONFIG_CMD_BMP stm32mp1: configs: add condition to activate WATCHDOG in SPL stm32mp1: configs: add altbootcmd stm32mp1: configs: add spi load support in spl stm32mp1: board: add environment variable for board id and board rev stm32mp1: board: enable v1v2_hdmi and v3v3_hdmi regulator on dk2 boot stm32mp1: board: support of error led on ed1/ev1 board stm32mp1: board: protect the led function calls stm32mp1: board: check the boot-source to disable bootdelay stm32mp1: board: Update the way vdd-supply is retrieved from DT stm32mp1: board: remove board_check_usb_power when ADC is not activated stm32mp1: board: cosmetic: cleanup file serial: stm32: add Framing error support serial: stm32: remove unused include stm32mp1: ram: cosmetic: remove unused prototype stm32mp1: ram: fix address issue in 2 tests stm32mp1: ram: update loop management in infinite test stm32mp1: ram: reload watchdog during ddr test stm32mp1: ram: add pattern parameter in infinite write test stm32mp1: Makefile cleanup stm32mp1: clk: remove debug traces stm32mp1: clk: use gd to store frequency information MAINTAINERS: update ARM STM STM32MP and STM32MP1 BOARD
MAINTAINERS | 19 +- arch/arm/Kconfig | 1 + arch/arm/dts/stm32mp15-ddr3-1x4Gb-1066-binG.dtsi | 4 +- arch/arm/dts/stm32mp15-ddr3-2x4Gb-1066-binG.dtsi | 5 +- arch/arm/dts/stm32mp157-pinctrl.dtsi | 234 +++++++++++++++++++---- arch/arm/dts/stm32mp157-u-boot.dtsi | 14 ++ arch/arm/dts/stm32mp157a-avenger96.dts | 44 +++-- arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi | 4 + arch/arm/dts/stm32mp157a-dk1.dts | 73 ++++++- arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi | 6 + arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi | 23 +-- arch/arm/dts/stm32mp157c-ed1.dts | 23 ++- arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 5 - arch/arm/dts/stm32mp157c-ev1.dts | 109 ++++++++++- arch/arm/dts/stm32mp157c.dtsi | 180 +++++++++++++++++ arch/arm/dts/stm32mp157xaa-pinctrl.dtsi | 90 +++++++++ arch/arm/dts/stm32mp157xab-pinctrl.dtsi | 62 ++++++ arch/arm/dts/stm32mp157xac-pinctrl.dtsi | 78 ++++++++ arch/arm/dts/stm32mp157xad-pinctrl.dtsi | 62 ++++++ arch/arm/mach-stm32mp/Kconfig | 14 +- arch/arm/mach-stm32mp/Makefile | 3 +- arch/arm/mach-stm32mp/include/mach/stm32.h | 1 + board/st/stm32mp1/Kconfig | 4 + board/st/stm32mp1/MAINTAINERS | 5 +- board/st/stm32mp1/spl.c | 14 ++ board/st/stm32mp1/stm32mp1.c | 162 ++++++++++++++-- configs/stm32mp15_basic_defconfig | 6 +- configs/stm32mp15_optee_defconfig | 5 +- configs/stm32mp15_trusted_defconfig | 5 +- doc/device-tree-bindings/clock/st,stm32mp1.txt | 4 +- drivers/clk/clk_stm32mp1.c | 37 ++-- drivers/mmc/stm32_sdmmc2.c | 3 + drivers/pinctrl/pinctrl-stmfx.c | 20 +- drivers/pinctrl/pinctrl_stm32.c | 4 +- drivers/ram/stm32mp1/stm32mp1_ddr.h | 4 - drivers/ram/stm32mp1/stm32mp1_tests.c | 97 ++++++---- drivers/serial/serial_stm32.c | 5 +- drivers/serial/serial_stm32.h | 2 + include/configs/stm32mp1.h | 17 +- include/dm/platform_data/serial_stm32.h | 15 -- include/power/stpmic1.h | 5 +- 41 files changed, 1250 insertions(+), 218 deletions(-) create mode 100644 arch/arm/dts/stm32mp157xaa-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32mp157xab-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32mp157xac-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32mp157xad-pinctrl.dtsi delete mode 100644 include/dm/platform_data/serial_stm32.h
Remove unnecessary comment.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
include/configs/stm32mp1.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 24f7b9d..1bed570 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -52,7 +52,6 @@
/* SPL support */ #ifdef CONFIG_SPL -/* BOOTROM load address */ /* SPL use DDR */ #define CONFIG_SPL_BSS_START_ADDR 0xC0200000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000
Signed-off-by: Patrice Chotard patrice.chotard@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
drivers/pinctrl/pinctrl_stm32.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index cdbe463..3a235ae 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -1,11 +1,11 @@ #include <common.h> #include <dm.h> -#include <dm/lists.h> -#include <dm/pinctrl.h> #include <hwspinlock.h> #include <asm/arch/gpio.h> #include <asm/gpio.h> #include <asm/io.h> +#include <dm/lists.h> +#include <dm/pinctrl.h>
DECLARE_GLOBAL_DATA_PTR;
Alignment with kernel driver.
According to the following tab (coming from STMFX datasheet), updates have to done in stmfx_pinctrl_conf_set function:
-"type" has to be set when "bias" is configured as "pull-up or pull-down" -PIN_CONFIG_DRIVE_PUSH_PULL should only be used when gpio is configured as output. There is so no need to check direction.
DIR | TYPE | PUPD | MFX GPIO configuration ----|------|------|--------------------------------------------------- 1 | 1 | 1 | OUTPUT open drain with internal pull-up resistor ----|------|------|--------------------------------------------------- 1 | 1 | 0 | OUTPUT open drain with internal pull-down resistor ----|------|------|--------------------------------------------------- 1 | 0 | 0/1 | OUTPUT push pull no pull ----|------|------|--------------------------------------------------- 0 | 1 | 1 | INPUT with internal pull-up resistor ----|------|------|--------------------------------------------------- 0 | 1 | 0 | INPUT with internal pull-down resistor ----|------|------|--------------------------------------------------- 0 | 0 | 1 | INPUT floating ----|------|------|--------------------------------------------------- 0 | 0 | 0 | analog (GPIO not used, default setting)
drivers/pinctrl/pinctrl-stmfx.c | 20 ++++++++++---------- 1 file changed, 10 insertions(+), 10 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-stmfx.c b/drivers/pinctrl/pinctrl-stmfx.c index 5431df9..0b5a043 100644 --- a/drivers/pinctrl/pinctrl-stmfx.c +++ b/drivers/pinctrl/pinctrl-stmfx.c @@ -231,23 +231,23 @@ static int stmfx_pinctrl_conf_set(struct udevice *dev, unsigned int pin, switch (param) { case PIN_CONFIG_BIAS_PULL_PIN_DEFAULT: case PIN_CONFIG_BIAS_DISABLE: + case PIN_CONFIG_DRIVE_PUSH_PULL: + ret = stmfx_pinctrl_set_type(dev, pin, 0); + break; case PIN_CONFIG_BIAS_PULL_DOWN: + ret = stmfx_pinctrl_set_type(dev, pin, 1); + if (ret) + return ret; ret = stmfx_pinctrl_set_pupd(dev, pin, 0); break; case PIN_CONFIG_BIAS_PULL_UP: + ret = stmfx_pinctrl_set_type(dev, pin, 1); + if (ret) + return ret; ret = stmfx_pinctrl_set_pupd(dev, pin, 1); break; case PIN_CONFIG_DRIVE_OPEN_DRAIN: - if (dir == GPIOF_OUTPUT) - ret = stmfx_pinctrl_set_type(dev, pin, 1); - else - ret = stmfx_pinctrl_set_type(dev, pin, 0); - break; - case PIN_CONFIG_DRIVE_PUSH_PULL: - if (dir == GPIOF_OUTPUT) - ret = stmfx_pinctrl_set_type(dev, pin, 0); - else - ret = stmfx_pinctrl_set_type(dev, pin, 1); + ret = stmfx_pinctrl_set_type(dev, pin, 1); break; case PIN_CONFIG_OUTPUT: ret = stmfx_gpio_direction_output(plat->gpio, pin, arg);
Synchronize device tree with v5.3-rc2 label and update the associated u-boot dtsi.
arch/arm/dts/stm32mp157-pinctrl.dtsi | 234 ++++++++++++++++++++++++++----- arch/arm/dts/stm32mp157a-avenger96.dts | 39 +++--- arch/arm/dts/stm32mp157a-dk1.dts | 68 ++++++++- arch/arm/dts/stm32mp157c-ed1.dts | 18 ++- arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 5 - arch/arm/dts/stm32mp157c-ev1.dts | 109 +++++++++++++- arch/arm/dts/stm32mp157c.dtsi | 180 ++++++++++++++++++++++++ arch/arm/dts/stm32mp157xaa-pinctrl.dtsi | 90 ++++++++++++ arch/arm/dts/stm32mp157xab-pinctrl.dtsi | 62 ++++++++ arch/arm/dts/stm32mp157xac-pinctrl.dtsi | 78 +++++++++++ arch/arm/dts/stm32mp157xad-pinctrl.dtsi | 62 ++++++++ 11 files changed, 885 insertions(+), 60 deletions(-) create mode 100644 arch/arm/dts/stm32mp157xaa-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32mp157xab-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32mp157xac-pinctrl.dtsi create mode 100644 arch/arm/dts/stm32mp157xad-pinctrl.dtsi
diff --git a/arch/arm/dts/stm32mp157-pinctrl.dtsi b/arch/arm/dts/stm32mp157-pinctrl.dtsi index 9bae850..4367e8d 100644 --- a/arch/arm/dts/stm32mp157-pinctrl.dtsi +++ b/arch/arm/dts/stm32mp157-pinctrl.dtsi @@ -25,8 +25,7 @@ reg = <0x0 0x400>; clocks = <&rcc GPIOA>; st,bank-name = "GPIOA"; - ngpios = <16>; - gpio-ranges = <&pinctrl 0 0 16>; + status = "disabled"; };
gpiob: gpio@50003000 { @@ -37,8 +36,7 @@ reg = <0x1000 0x400>; clocks = <&rcc GPIOB>; st,bank-name = "GPIOB"; - ngpios = <16>; - gpio-ranges = <&pinctrl 0 16 16>; + status = "disabled"; };
gpioc: gpio@50004000 { @@ -49,8 +47,7 @@ reg = <0x2000 0x400>; clocks = <&rcc GPIOC>; st,bank-name = "GPIOC"; - ngpios = <16>; - gpio-ranges = <&pinctrl 0 32 16>; + status = "disabled"; };
gpiod: gpio@50005000 { @@ -61,8 +58,7 @@ reg = <0x3000 0x400>; clocks = <&rcc GPIOD>; st,bank-name = "GPIOD"; - ngpios = <16>; - gpio-ranges = <&pinctrl 0 48 16>; + status = "disabled"; };
gpioe: gpio@50006000 { @@ -73,8 +69,7 @@ reg = <0x4000 0x400>; clocks = <&rcc GPIOE>; st,bank-name = "GPIOE"; - ngpios = <16>; - gpio-ranges = <&pinctrl 0 64 16>; + status = "disabled"; };
gpiof: gpio@50007000 { @@ -85,8 +80,7 @@ reg = <0x5000 0x400>; clocks = <&rcc GPIOF>; st,bank-name = "GPIOF"; - ngpios = <16>; - gpio-ranges = <&pinctrl 0 80 16>; + status = "disabled"; };
gpiog: gpio@50008000 { @@ -97,8 +91,7 @@ reg = <0x6000 0x400>; clocks = <&rcc GPIOG>; st,bank-name = "GPIOG"; - ngpios = <16>; - gpio-ranges = <&pinctrl 0 96 16>; + status = "disabled"; };
gpioh: gpio@50009000 { @@ -109,8 +102,7 @@ reg = <0x7000 0x400>; clocks = <&rcc GPIOH>; st,bank-name = "GPIOH"; - ngpios = <16>; - gpio-ranges = <&pinctrl 0 112 16>; + status = "disabled"; };
gpioi: gpio@5000a000 { @@ -121,8 +113,7 @@ reg = <0x8000 0x400>; clocks = <&rcc GPIOI>; st,bank-name = "GPIOI"; - ngpios = <16>; - gpio-ranges = <&pinctrl 0 128 16>; + status = "disabled"; };
gpioj: gpio@5000b000 { @@ -133,8 +124,7 @@ reg = <0x9000 0x400>; clocks = <&rcc GPIOJ>; st,bank-name = "GPIOJ"; - ngpios = <16>; - gpio-ranges = <&pinctrl 0 144 16>; + status = "disabled"; };
gpiok: gpio@5000c000 { @@ -145,8 +135,7 @@ reg = <0xa000 0x400>; clocks = <&rcc GPIOK>; st,bank-name = "GPIOK"; - ngpios = <8>; - gpio-ranges = <&pinctrl 0 160 8>; + status = "disabled"; };
adc12_usb_pwr_pins_a: adc12-usb-pwr-pins-0 { @@ -186,6 +175,47 @@ }; };
+ dcmi_pins_a: dcmi-0 { + pins { + pinmux = <STM32_PINMUX('H', 8, AF13)>,/* DCMI_HSYNC */ + <STM32_PINMUX('B', 7, AF13)>,/* DCMI_VSYNC */ + <STM32_PINMUX('A', 6, AF13)>,/* DCMI_PIXCLK */ + <STM32_PINMUX('H', 9, AF13)>,/* DCMI_D0 */ + <STM32_PINMUX('H', 10, AF13)>,/* DCMI_D1 */ + <STM32_PINMUX('H', 11, AF13)>,/* DCMI_D2 */ + <STM32_PINMUX('H', 12, AF13)>,/* DCMI_D3 */ + <STM32_PINMUX('H', 14, AF13)>,/* DCMI_D4 */ + <STM32_PINMUX('I', 4, AF13)>,/* DCMI_D5 */ + <STM32_PINMUX('B', 8, AF13)>,/* DCMI_D6 */ + <STM32_PINMUX('E', 6, AF13)>,/* DCMI_D7 */ + <STM32_PINMUX('I', 1, AF13)>,/* DCMI_D8 */ + <STM32_PINMUX('H', 7, AF13)>,/* DCMI_D9 */ + <STM32_PINMUX('I', 3, AF13)>,/* DCMI_D10 */ + <STM32_PINMUX('H', 15, AF13)>;/* DCMI_D11 */ + bias-disable; + }; + }; + + dcmi_sleep_pins_a: dcmi-sleep-0 { + pins { + pinmux = <STM32_PINMUX('H', 8, ANALOG)>,/* DCMI_HSYNC */ + <STM32_PINMUX('B', 7, ANALOG)>,/* DCMI_VSYNC */ + <STM32_PINMUX('A', 6, ANALOG)>,/* DCMI_PIXCLK */ + <STM32_PINMUX('H', 9, ANALOG)>,/* DCMI_D0 */ + <STM32_PINMUX('H', 10, ANALOG)>,/* DCMI_D1 */ + <STM32_PINMUX('H', 11, ANALOG)>,/* DCMI_D2 */ + <STM32_PINMUX('H', 12, ANALOG)>,/* DCMI_D3 */ + <STM32_PINMUX('H', 14, ANALOG)>,/* DCMI_D4 */ + <STM32_PINMUX('I', 4, ANALOG)>,/* DCMI_D5 */ + <STM32_PINMUX('B', 8, ANALOG)>,/* DCMI_D6 */ + <STM32_PINMUX('E', 6, ANALOG)>,/* DCMI_D7 */ + <STM32_PINMUX('I', 1, ANALOG)>,/* DCMI_D8 */ + <STM32_PINMUX('H', 7, ANALOG)>,/* DCMI_D9 */ + <STM32_PINMUX('I', 3, ANALOG)>,/* DCMI_D10 */ + <STM32_PINMUX('H', 15, ANALOG)>;/* DCMI_D11 */ + }; + }; + ethernet0_rgmii_pins_a: rgmii-0 { pins1 { pinmux = <STM32_PINMUX('G', 5, AF11)>, /* ETH_RGMII_CLK125 */ @@ -308,6 +338,13 @@ }; };
+ i2c1_pins_sleep_b: i2c1-3 { + pins { + pinmux = <STM32_PINMUX('F', 14, ANALOG)>, /* I2C1_SCL */ + <STM32_PINMUX('F', 15, ANALOG)>; /* I2C1_SDA */ + }; + }; + i2c2_pins_a: i2c2-0 { pins { pinmux = <STM32_PINMUX('H', 4, AF4)>, /* I2C2_SCL */ @@ -325,16 +362,21 @@ }; };
- i2c2_pins_b: i2c2-2 { + i2c2_pins_b1: i2c2-2 { pins { - pinmux = <STM32_PINMUX('Z', 0, AF3)>, /* I2C2_SCL */ - <STM32_PINMUX('H', 5, AF4)>; /* I2C2_SDA */ + pinmux = <STM32_PINMUX('H', 5, AF4)>; /* I2C2_SDA */ bias-disable; drive-open-drain; slew-rate = <0>; }; };
+ i2c2_pins_sleep_b1: i2c2-3 { + pins { + pinmux = <STM32_PINMUX('H', 5, ANALOG)>; /* I2C2_SDA */ + }; + }; + i2c5_pins_a: i2c5-0 { pins { pinmux = <STM32_PINMUX('A', 11, AF4)>, /* I2C5_SCL */ @@ -353,6 +395,25 @@ }; };
+ i2s2_pins_a: i2s2-0 { + pins { + pinmux = <STM32_PINMUX('I', 3, AF5)>, /* I2S2_SDO */ + <STM32_PINMUX('B', 9, AF5)>, /* I2S2_WS */ + <STM32_PINMUX('A', 9, AF5)>; /* I2S2_CK */ + slew-rate = <1>; + drive-push-pull; + bias-disable; + }; + }; + + i2s2_pins_sleep_a: i2s2-1 { + pins { + pinmux = <STM32_PINMUX('I', 3, ANALOG)>, /* I2S2_SDO */ + <STM32_PINMUX('B', 9, ANALOG)>, /* I2S2_WS */ + <STM32_PINMUX('A', 9, ANALOG)>; /* I2S2_CK */ + }; + }; + ltdc_pins_a: ltdc-a-0 { pins { pinmux = <STM32_PINMUX('G', 7, AF14)>, /* LCD_CLK */ @@ -547,6 +608,12 @@ }; };
+ qspi_clk_sleep_pins_a: qspi-clk-sleep-0 { + pins { + pinmux = <STM32_PINMUX('F', 10, ANALOG)>; /* QSPI_CLK */ + }; + }; + qspi_bk1_pins_a: qspi-bk1-0 { pins1 { pinmux = <STM32_PINMUX('F', 8, AF10)>, /* QSPI_BK1_IO0 */ @@ -565,6 +632,16 @@ }; };
+ qspi_bk1_sleep_pins_a: qspi-bk1-sleep-0 { + pins { + pinmux = <STM32_PINMUX('F', 8, ANALOG)>, /* QSPI_BK1_IO0 */ + <STM32_PINMUX('F', 9, ANALOG)>, /* QSPI_BK1_IO1 */ + <STM32_PINMUX('F', 7, ANALOG)>, /* QSPI_BK1_IO2 */ + <STM32_PINMUX('F', 6, ANALOG)>, /* QSPI_BK1_IO3 */ + <STM32_PINMUX('B', 6, ANALOG)>; /* QSPI_BK1_NCS */ + }; + }; + qspi_bk2_pins_a: qspi-bk2-0 { pins1 { pinmux = <STM32_PINMUX('H', 2, AF9)>, /* QSPI_BK2_IO0 */ @@ -583,6 +660,89 @@ }; };
+ qspi_bk2_sleep_pins_a: qspi-bk2-sleep-0 { + pins { + pinmux = <STM32_PINMUX('H', 2, ANALOG)>, /* QSPI_BK2_IO0 */ + <STM32_PINMUX('H', 3, ANALOG)>, /* QSPI_BK2_IO1 */ + <STM32_PINMUX('G', 10, ANALOG)>, /* QSPI_BK2_IO2 */ + <STM32_PINMUX('G', 7, ANALOG)>, /* QSPI_BK2_IO3 */ + <STM32_PINMUX('C', 0, ANALOG)>; /* QSPI_BK2_NCS */ + }; + }; + + sai2a_pins_a: sai2a-0 { + pins { + pinmux = <STM32_PINMUX('I', 5, AF10)>, /* SAI2_SCK_A */ + <STM32_PINMUX('I', 6, AF10)>, /* SAI2_SD_A */ + <STM32_PINMUX('I', 7, AF10)>, /* SAI2_FS_A */ + <STM32_PINMUX('E', 0, AF10)>; /* SAI2_MCLK_A */ + slew-rate = <0>; + drive-push-pull; + bias-disable; + }; + }; + + sai2a_sleep_pins_a: sai2a-1 { + pins { + pinmux = <STM32_PINMUX('I', 5, ANALOG)>, /* SAI2_SCK_A */ + <STM32_PINMUX('I', 6, ANALOG)>, /* SAI2_SD_A */ + <STM32_PINMUX('I', 7, ANALOG)>, /* SAI2_FS_A */ + <STM32_PINMUX('E', 0, ANALOG)>; /* SAI2_MCLK_A */ + }; + }; + + sai2b_pins_a: sai2b-0 { + pins1 { + pinmux = <STM32_PINMUX('E', 12, AF10)>, /* SAI2_SCK_B */ + <STM32_PINMUX('E', 13, AF10)>, /* SAI2_FS_B */ + <STM32_PINMUX('E', 14, AF10)>; /* SAI2_MCLK_B */ + slew-rate = <0>; + drive-push-pull; + bias-disable; + }; + pins2 { + pinmux = <STM32_PINMUX('F', 11, AF10)>; /* SAI2_SD_B */ + bias-disable; + }; + }; + + sai2b_sleep_pins_a: sai2b-1 { + pins { + pinmux = <STM32_PINMUX('F', 11, ANALOG)>, /* SAI2_SD_B */ + <STM32_PINMUX('E', 12, ANALOG)>, /* SAI2_SCK_B */ + <STM32_PINMUX('E', 13, ANALOG)>, /* SAI2_FS_B */ + <STM32_PINMUX('E', 14, ANALOG)>; /* SAI2_MCLK_B */ + }; + }; + + sai2b_pins_b: sai2b-2 { + pins { + pinmux = <STM32_PINMUX('F', 11, AF10)>; /* SAI2_SD_B */ + bias-disable; + }; + }; + + sai2b_sleep_pins_b: sai2b-3 { + pins { + pinmux = <STM32_PINMUX('F', 11, ANALOG)>; /* SAI2_SD_B */ + }; + }; + + sai4a_pins_a: sai4a-0 { + pins { + pinmux = <STM32_PINMUX('B', 5, AF10)>; /* SAI4_SD_A */ + slew-rate = <0>; + drive-push-pull; + bias-disable; + }; + }; + + sai4a_sleep_pins_a: sai4a-1 { + pins { + pinmux = <STM32_PINMUX('B', 5, ANALOG)>; /* SAI4_SD_A */ + }; + }; + sdmmc1_b4_pins_a: sdmmc1-b4-0 { pins { pinmux = <STM32_PINMUX('C', 8, AF12)>, /* SDMMC1_D0 */ @@ -752,12 +912,6 @@ bias-disable; }; }; - - usbotg_hs_pins_a: usbotg_hs-0 { - pins { - pinmux = <STM32_PINMUX('A', 10, ANALOG)>; /* OTG_ID */ - }; - }; };
pinctrl_z: pin-controller-z@54004000 { @@ -779,8 +933,22 @@ clocks = <&rcc GPIOZ>; st,bank-name = "GPIOZ"; st,bank-ioport = <11>; - ngpios = <8>; - gpio-ranges = <&pinctrl_z 0 400 8>; + status = "disabled"; + }; + + i2c2_pins_b2: i2c2-0 { + pins { + pinmux = <STM32_PINMUX('Z', 0, AF3)>; /* I2C2_SCL */ + bias-disable; + drive-open-drain; + slew-rate = <0>; + }; + }; + + i2c2_pins_sleep_b2: i2c2-1 { + pins { + pinmux = <STM32_PINMUX('Z', 0, ANALOG)>; /* I2C2_SCL */ + }; };
i2c4_pins_a: i2c4-0 { diff --git a/arch/arm/dts/stm32mp157a-avenger96.dts b/arch/arm/dts/stm32mp157a-avenger96.dts index dd08597..ba86cf5 100644 --- a/arch/arm/dts/stm32mp157a-avenger96.dts +++ b/arch/arm/dts/stm32mp157a-avenger96.dts @@ -1,8 +1,5 @@ // SPDX-License-Identifier: (GPL-2.0 OR BSD-3-Clause) /* - * Copyright (C) STMicroelectronics 2019 - All Rights Reserved - * Author: Alexandre Torgue alexandre.torgue@st.com for STMicroelectronics. - * * Copyright (C) Linaro Ltd 2019 - All Rights Reserved * Author: Manivannan Sadhasivam manivannan.sadhasivam@linaro.org */ @@ -10,17 +7,19 @@ /dts-v1/;
#include "stm32mp157c.dtsi" -#include "stm32mp157-pinctrl.dtsi" +#include "stm32mp157xac-pinctrl.dtsi" #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/mfd/st,stpmic1.h>
/ { model = "Arrow Electronics STM32MP157A Avenger96 board"; - compatible = "st,stm32mp157a-avenger96", "st,stm32mp157"; + compatible = "arrow,stm32mp157a-avenger96", "st,stm32mp157";
aliases { ethernet0 = ðernet0; + mmc0 = &sdmmc1; serial0 = &uart4; + serial1 = &uart7; };
chosen { @@ -28,6 +27,7 @@ };
memory@c0000000 { + device_type = "memory"; reg = <0xc0000000 0x40000000>; };
@@ -109,7 +109,7 @@
&i2c2 { pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins_b>; + pinctrl-0 = <&i2c2_pins_b1 &i2c2_pins_b2>; i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; status = "okay"; @@ -151,10 +151,10 @@
vddcore: buck1 { regulator-name = "vddcore"; - regulator-min-microvolt = <800000>; + regulator-min-microvolt = <1200000>; regulator-max-microvolt = <1350000>; regulator-always-on; - regulator-initial-mode = <2>; + regulator-initial-mode = <0>; regulator-over-current-protection; };
@@ -163,17 +163,17 @@ regulator-min-microvolt = <1350000>; regulator-max-microvolt = <1350000>; regulator-always-on; - regulator-initial-mode = <2>; + regulator-initial-mode = <0>; regulator-over-current-protection; };
vdd: buck3 { regulator-name = "vdd"; - regulator-min-microvolt = <2500000>; - regulator-max-microvolt = <2500000>; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; regulator-always-on; st,mask_reset; - regulator-initial-mode = <8>; + regulator-initial-mode = <0>; regulator-over-current-protection; };
@@ -183,7 +183,7 @@ regulator-max-microvolt = <3300000>; regulator-always-on; regulator-over-current-protection; - regulator-initial-mode = <8>; + regulator-initial-mode = <0>; };
vdda: ldo1 { @@ -204,8 +204,8 @@
vtt_ddr: ldo3 { regulator-name = "vtt_ddr"; - regulator-min-microvolt = <0000000>; - regulator-max-microvolt = <1000000>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <750000>; regulator-always-on; regulator-over-current-protection; }; @@ -233,6 +233,7 @@ regulator-max-microvolt = <1800000>; interrupts = <IT_CURLIM_LDO6 0>; interrupt-parent = <&pmic>; + regulator-enable-ramp-delay = <300000>; };
vref_ddr: vref_ddr { @@ -294,8 +295,10 @@ };
&sdmmc1 { - pinctrl-names = "default"; + pinctrl-names = "default", "opendrain", "sleep"; pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_a>; + pinctrl-1 = <&sdmmc1_b4_od_pins_a>; + pinctrl-2 = <&sdmmc1_b4_sleep_pins_a>; broken-cd; st,sig-dir; st,neg-edge; @@ -325,12 +328,16 @@ };
&uart4 { + /* On Low speed expansion header */ + label = "LS-UART1"; pinctrl-names = "default"; pinctrl-0 = <&uart4_pins_b>; status = "okay"; };
&uart7 { + /* On Low speed expansion header */ + label = "LS-UART0"; pinctrl-names = "default"; pinctrl-0 = <&uart7_pins_a>; status = "okay"; diff --git a/arch/arm/dts/stm32mp157a-dk1.dts b/arch/arm/dts/stm32mp157a-dk1.dts index adb2464..1d5c1a6 100644 --- a/arch/arm/dts/stm32mp157a-dk1.dts +++ b/arch/arm/dts/stm32mp157a-dk1.dts @@ -7,7 +7,7 @@ /dts-v1/;
@@ -28,6 +28,17 @@ reg = <0xc0000000 0x20000000>; };
+ reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + gpu_reserved: gpu@d4000000 { + reg = <0xd4000000 0x4000000>; + no-map; + }; + }; + led { compatible = "gpio-leds"; blue { @@ -65,6 +76,47 @@ }; };
+&gpu { + contiguous-area = <&gpu_reserved>; + status = "okay"; +}; + +&i2c1 { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&i2c1_pins_a>; + pinctrl-1 = <&i2c1_pins_sleep_a>; + i2c-scl-rising-time-ns = <100>; + i2c-scl-falling-time-ns = <7>; + status = "okay"; + /delete-property/dmas; + /delete-property/dma-names; + + hdmi-transmitter@39 { + compatible = "sil,sii9022"; + reg = <0x39>; + iovcc-supply = <&v3v3_hdmi>; + cvcc12-supply = <&v1v2_hdmi>; + reset-gpios = <&gpioa 10 GPIO_ACTIVE_LOW>; + interrupts = <1 IRQ_TYPE_EDGE_FALLING>; + interrupt-parent = <&gpiog>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <<dc_pins_a>; + pinctrl-1 = <<dc_pins_sleep_a>; + status = "okay"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + sii9022_in: endpoint { + remote-endpoint = <<dc_ep0_out>; + }; + }; + }; + }; +};
&i2c4 { pinctrl-names = "default"; @@ -241,6 +293,20 @@ status = "okay"; };
+<dc { + status = "okay"; + + port { + #address-cells = <1>; + #size-cells = <0>; + + ltdc_ep0_out: endpoint@0 { + reg = <0>; + remote-endpoint = <&sii9022_in>; + }; + }; +}; + &pwr { pwr-supply = <&vdd>; }; diff --git a/arch/arm/dts/stm32mp157c-ed1.dts b/arch/arm/dts/stm32mp157c-ed1.dts index 11981d6..94ac025 100644 --- a/arch/arm/dts/stm32mp157c-ed1.dts +++ b/arch/arm/dts/stm32mp157c-ed1.dts @@ -6,7 +6,7 @@ /dts-v1/;
#include "stm32mp157c.dtsi" -#include "stm32mp157-pinctrl.dtsi" +#include "stm32mp157xaa-pinctrl.dtsi" #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/mfd/st,stpmic1.h>
@@ -23,6 +23,17 @@ reg = <0xC0000000 0x40000000>; };
+ reserved-memory { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + gpu_reserved: gpu@e8000000 { + reg = <0xe8000000 0x8000000>; + no-map; + }; + }; + aliases { serial0 = &uart4; }; @@ -45,6 +56,11 @@ status = "okay"; };
+&gpu { + contiguous-area = <&gpu_reserved>; + status = "okay"; +}; + &i2c4 { pinctrl-names = "default"; pinctrl-0 = <&i2c4_pins_a>; diff --git a/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi b/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi index b656eb1..ec60486 100644 --- a/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi @@ -17,14 +17,9 @@ };
&flash0 { - compatible = "jedec,spi-nor"; u-boot,dm-spl; };
-&flash1 { - compatible = "jedec,spi-nor"; -}; - &qspi { u-boot,dm-spl; }; diff --git a/arch/arm/dts/stm32mp157c-ev1.dts b/arch/arm/dts/stm32mp157c-ev1.dts index ca2a333..23de232 100644 --- a/arch/arm/dts/stm32mp157c-ev1.dts +++ b/arch/arm/dts/stm32mp157c-ev1.dts @@ -7,6 +7,7 @@
#include "stm32mp157c-ed1.dts" #include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h>
/ { model = "STMicroelectronics STM32MP157C eval daughter on eval mother"; @@ -21,6 +22,51 @@ ethernet0 = ðernet0; };
+ clocks { + clk_ext_camera: clk-ext-camera { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <24000000>; + }; + }; + + joystick { + compatible = "gpio-keys"; + #size-cells = <0>; + pinctrl-0 = <&joystick_pins>; + pinctrl-names = "default"; + button-0 { + label = "JoySel"; + linux,code = <KEY_ENTER>; + interrupt-parent = <&stmfx_pinctrl>; + interrupts = <0 IRQ_TYPE_EDGE_RISING>; + }; + button-1 { + label = "JoyDown"; + linux,code = <KEY_DOWN>; + interrupt-parent = <&stmfx_pinctrl>; + interrupts = <1 IRQ_TYPE_EDGE_RISING>; + }; + button-2 { + label = "JoyLeft"; + linux,code = <KEY_LEFT>; + interrupt-parent = <&stmfx_pinctrl>; + interrupts = <2 IRQ_TYPE_EDGE_RISING>; + }; + button-3 { + label = "JoyRight"; + linux,code = <KEY_RIGHT>; + interrupt-parent = <&stmfx_pinctrl>; + interrupts = <3 IRQ_TYPE_EDGE_RISING>; + }; + button-4 { + label = "JoyUp"; + linux,code = <KEY_UP>; + interrupt-parent = <&stmfx_pinctrl>; + interrupts = <4 IRQ_TYPE_EDGE_RISING>; + }; + }; + panel_backlight: panel-backlight { compatible = "gpio-backlight"; gpios = <&gpiod 13 GPIO_ACTIVE_LOW>; @@ -35,6 +81,23 @@ status = "okay"; };
+&dcmi { + status = "okay"; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&dcmi_pins_a>; + pinctrl-1 = <&dcmi_sleep_pins_a>; + + port { + dcmi_0: endpoint { + remote-endpoint = <&ov5640_0>; + bus-width = <8>; + hsync-active = <0>; + vsync-active = <0>; + pclk-sample = <1>; + }; + }; +}; + &dsi { #address-cells = <1>; #size-cells = <0>; @@ -64,6 +127,7 @@ reg = <0>; reset-gpios = <&gpiof 15 GPIO_ACTIVE_LOW>; backlight = <&panel_backlight>; + power-supply = <&v3v3>; status = "okay";
port { @@ -116,6 +180,31 @@ i2c-scl-falling-time-ns = <20>; status = "okay";
+ ov5640: camera@3c { + compatible = "ovti,ov5640"; + pinctrl-names = "default"; + pinctrl-0 = <&ov5640_pins>; + reg = <0x3c>; + clocks = <&clk_ext_camera>; + clock-names = "xclk"; + DOVDD-supply = <&v2v8>; + powerdown-gpios = <&stmfx_pinctrl 18 GPIO_ACTIVE_HIGH>; + reset-gpios = <&stmfx_pinctrl 19 GPIO_ACTIVE_LOW>; + rotation = <180>; + status = "okay"; + + port { + ov5640_0: endpoint { + remote-endpoint = <&dcmi_0>; + bus-width = <8>; + data-shift = <2>; /* lines 9:2 are used */ + hsync-active = <0>; + vsync-active = <0>; + pclk-sample = <1>; + }; + }; + }; + stmfx: stmfx@42 { compatible = "st,stmfx-0300"; reg = <0x42>; @@ -130,7 +219,18 @@ interrupt-controller; #interrupt-cells = <2>; gpio-ranges = <&stmfx_pinctrl 0 0 24>; - status = "disabled"; + + joystick_pins: joystick { + pins = "gpio0", "gpio1", "gpio2", "gpio3", "gpio4"; + drive-push-pull; + bias-pull-down; + }; + + ov5640_pins: camera { + pins = "agpio2", "agpio3"; /* stmfx pins 18 & 19 */ + drive-push-pull; + output-low; + }; }; }; }; @@ -165,14 +265,16 @@ };
&qspi { - pinctrl-names = "default"; + pinctrl-names = "default", "sleep"; pinctrl-0 = <&qspi_clk_pins_a &qspi_bk1_pins_a &qspi_bk2_pins_a>; + pinctrl-1 = <&qspi_clk_sleep_pins_a &qspi_bk1_sleep_pins_a &qspi_bk2_sleep_pins_a>; reg = <0x58003000 0x1000>, <0x70000000 0x4000000>; #address-cells = <1>; #size-cells = <0>; status = "okay";
flash0: mx66l51235l@0 { + compatible = "jedec,spi-nor"; reg = <0>; spi-rx-bus-width = <4>; spi-max-frequency = <108000000>; @@ -181,6 +283,7 @@ };
flash1: mx66l51235l@1 { + compatible = "jedec,spi-nor"; reg = <1>; spi-rx-bus-width = <4>; spi-max-frequency = <108000000>; @@ -245,8 +348,6 @@ };
&usbotg_hs { - pinctrl-names = "default"; - pinctrl-0 = <&usbotg_hs_pins_a>; dr_mode = "peripheral"; phys = <&usbphyc_port1 0>; phy-names = "usb2-phy"; diff --git a/arch/arm/dts/stm32mp157c.dtsi b/arch/arm/dts/stm32mp157c.dtsi index d15fba0..bcd8c1a 100644 --- a/arch/arm/dts/stm32mp157c.dtsi +++ b/arch/arm/dts/stm32mp157c.dtsi @@ -372,6 +372,17 @@ status = "disabled"; };
+ i2s2: audio-controller@4000b000 { + compatible = "st,stm32h7-i2s"; + #sound-dai-cells = <0>; + reg = <0x4000b000 0x400>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmamux1 39 0x400 0x01>, + <&dmamux1 40 0x400 0x01>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + spi3: spi@4000c000 { #address-cells = <1>; #size-cells = <0>; @@ -386,6 +397,17 @@ status = "disabled"; };
+ i2s3: audio-controller@4000c000 { + compatible = "st,stm32h7-i2s"; + #sound-dai-cells = <0>; + reg = <0x4000c000 0x400>; + interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmamux1 61 0x400 0x01>, + <&dmamux1 62 0x400 0x01>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + spdifrx: audio-controller@4000d000 { compatible = "st,stm32h7-spdifrx"; #sound-dai-cells = <0>; @@ -614,6 +636,17 @@ status = "disabled"; };
+ i2s1: audio-controller@44004000 { + compatible = "st,stm32h7-i2s"; + #sound-dai-cells = <0>; + reg = <0x44004000 0x400>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmamux1 37 0x400 0x01>, + <&dmamux1 38 0x400 0x01>; + dma-names = "rx", "tx"; + status = "disabled"; + }; + spi4: spi@44005000 { #address-cells = <1>; #size-cells = <0>; @@ -715,6 +748,100 @@ status = "disabled"; };
+ sai1: sai@4400a000 { + compatible = "st,stm32h7-sai"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x4400a000 0x400>; + reg = <0x4400a000 0x4>, <0x4400a3f0 0x10>; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + resets = <&rcc SAI1_R>; + status = "disabled"; + + sai1a: audio-controller@4400a004 { + #sound-dai-cells = <0>; + + compatible = "st,stm32-sai-sub-a"; + reg = <0x4 0x1c>; + clocks = <&rcc SAI1_K>; + clock-names = "sai_ck"; + dmas = <&dmamux1 87 0x400 0x01>; + status = "disabled"; + }; + + sai1b: audio-controller@4400a024 { + #sound-dai-cells = <0>; + compatible = "st,stm32-sai-sub-b"; + reg = <0x24 0x1c>; + clocks = <&rcc SAI1_K>; + clock-names = "sai_ck"; + dmas = <&dmamux1 88 0x400 0x01>; + status = "disabled"; + }; + }; + + sai2: sai@4400b000 { + compatible = "st,stm32h7-sai"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x4400b000 0x400>; + reg = <0x4400b000 0x4>, <0x4400b3f0 0x10>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; + resets = <&rcc SAI2_R>; + status = "disabled"; + + sai2a: audio-controller@4400b004 { + #sound-dai-cells = <0>; + compatible = "st,stm32-sai-sub-a"; + reg = <0x4 0x1c>; + clocks = <&rcc SAI2_K>; + clock-names = "sai_ck"; + dmas = <&dmamux1 89 0x400 0x01>; + status = "disabled"; + }; + + sai2b: audio-controller@4400b024 { + #sound-dai-cells = <0>; + compatible = "st,stm32-sai-sub-b"; + reg = <0x24 0x1c>; + clocks = <&rcc SAI2_K>; + clock-names = "sai_ck"; + dmas = <&dmamux1 90 0x400 0x01>; + status = "disabled"; + }; + }; + + sai3: sai@4400c000 { + compatible = "st,stm32h7-sai"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x4400c000 0x400>; + reg = <0x4400c000 0x4>, <0x4400c3f0 0x10>; + interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; + resets = <&rcc SAI3_R>; + status = "disabled"; + + sai3a: audio-controller@4400c004 { + #sound-dai-cells = <0>; + compatible = "st,stm32-sai-sub-a"; + reg = <0x04 0x1c>; + clocks = <&rcc SAI3_K>; + clock-names = "sai_ck"; + dmas = <&dmamux1 113 0x400 0x01>; + status = "disabled"; + }; + + sai3b: audio-controller@4400c024 { + #sound-dai-cells = <0>; + compatible = "st,stm32-sai-sub-b"; + reg = <0x24 0x1c>; + clocks = <&rcc SAI3_K>; + clock-names = "sai_ck"; + dmas = <&dmamux1 114 0x400 0x01>; + status = "disabled"; + }; + }; + dfsdm: dfsdm@4400d000 { compatible = "st,stm32mp1-dfsdm"; reg = <0x4400d000 0x800>; @@ -945,6 +1072,18 @@ status = "disabled"; };
+ dcmi: dcmi@4c006000 { + compatible = "st,stm32-dcmi"; + reg = <0x4c006000 0x400>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; + resets = <&rcc CAMITF_R>; + clocks = <&rcc DCMI>; + clock-names = "mclk"; + dmas = <&dmamux1 75 0x400 0x0d>; + dma-names = "tx"; + status = "disabled"; + }; + rcc: rcc@50000000 { compatible = "st,stm32mp1-rcc", "syscon"; reg = <0x50000000 0x1000>; @@ -1084,6 +1223,37 @@ status = "disabled"; };
+ sai4: sai@50027000 { + compatible = "st,stm32h7-sai"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x50027000 0x400>; + reg = <0x50027000 0x4>, <0x500273f0 0x10>; + interrupts = <GIC_SPI 146 IRQ_TYPE_LEVEL_HIGH>; + resets = <&rcc SAI4_R>; + status = "disabled"; + + sai4a: audio-controller@50027004 { + #sound-dai-cells = <0>; + compatible = "st,stm32-sai-sub-a"; + reg = <0x04 0x1c>; + clocks = <&rcc SAI4_K>; + clock-names = "sai_ck"; + dmas = <&dmamux1 99 0x400 0x01>; + status = "disabled"; + }; + + sai4b: audio-controller@50027024 { + #sound-dai-cells = <0>; + compatible = "st,stm32-sai-sub-b"; + reg = <0x24 0x1c>; + clocks = <&rcc SAI4_K>; + clock-names = "sai_ck"; + dmas = <&dmamux1 100 0x400 0x01>; + status = "disabled"; + }; + }; + dts: thermal@50028000 { compatible = "st,stm32-thermal"; reg = <0x50028000 0x100>; @@ -1242,6 +1412,16 @@ status = "disabled"; };
+ gpu: gpu@59000000 { + compatible = "vivante,gc"; + reg = <0x59000000 0x800>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&rcc GPU>, <&rcc GPU_K>; + clock-names = "bus" ,"core"; + resets = <&rcc GPU_R>; + status = "disabled"; + }; + dsi: dsi@5a000000 { compatible = "st,stm32-dsi"; reg = <0x5a000000 0x800>; diff --git a/arch/arm/dts/stm32mp157xaa-pinctrl.dtsi b/arch/arm/dts/stm32mp157xaa-pinctrl.dtsi new file mode 100644 index 0000000..875adf5 --- /dev/null +++ b/arch/arm/dts/stm32mp157xaa-pinctrl.dtsi @@ -0,0 +1,90 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2019 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@st.com + */ + +#include "stm32mp157-pinctrl.dtsi" +/ { + soc { + pinctrl: pin-controller@50002000 { + st,package = <STM32MP_PKG_AA>; + + gpioa: gpio@50002000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 0 16>; + }; + + gpiob: gpio@50003000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 16 16>; + }; + + gpioc: gpio@50004000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 32 16>; + }; + + gpiod: gpio@50005000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 48 16>; + }; + + gpioe: gpio@50006000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 64 16>; + }; + + gpiof: gpio@50007000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 80 16>; + }; + + gpiog: gpio@50008000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 96 16>; + }; + + gpioh: gpio@50009000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 112 16>; + }; + + gpioi: gpio@5000a000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 128 16>; + }; + + gpioj: gpio@5000b000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 144 16>; + }; + + gpiok: gpio@5000c000 { + status = "okay"; + ngpios = <8>; + gpio-ranges = <&pinctrl 0 160 8>; + }; + }; + + pinctrl_z: pin-controller-z@54004000 { + st,package = <STM32MP_PKG_AA>; + + gpioz: gpio@54004000 { + status = "okay"; + ngpios = <8>; + gpio-ranges = <&pinctrl_z 0 400 8>; + }; + }; + }; +}; diff --git a/arch/arm/dts/stm32mp157xab-pinctrl.dtsi b/arch/arm/dts/stm32mp157xab-pinctrl.dtsi new file mode 100644 index 0000000..961fa12 --- /dev/null +++ b/arch/arm/dts/stm32mp157xab-pinctrl.dtsi @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2019 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@st.com + */ + +#include "stm32mp157-pinctrl.dtsi" +/ { + soc { + pinctrl: pin-controller@50002000 { + st,package = <STM32MP_PKG_AB>; + + gpioa: gpio@50002000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 0 16>; + }; + + gpiob: gpio@50003000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 16 16>; + }; + + gpioc: gpio@50004000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 32 16>; + }; + + gpiod: gpio@50005000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 48 16>; + }; + + gpioe: gpio@50006000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 64 16>; + }; + + gpiof: gpio@50007000 { + status = "okay"; + ngpios = <6>; + gpio-ranges = <&pinctrl 6 86 6>; + }; + + gpiog: gpio@50008000 { + status = "okay"; + ngpios = <10>; + gpio-ranges = <&pinctrl 6 102 10>; + }; + + gpioh: gpio@50009000 { + status = "okay"; + ngpios = <2>; + gpio-ranges = <&pinctrl 0 112 2>; + }; + }; + }; +}; diff --git a/arch/arm/dts/stm32mp157xac-pinctrl.dtsi b/arch/arm/dts/stm32mp157xac-pinctrl.dtsi new file mode 100644 index 0000000..26600f1 --- /dev/null +++ b/arch/arm/dts/stm32mp157xac-pinctrl.dtsi @@ -0,0 +1,78 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2019 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@st.com + */ + +#include "stm32mp157-pinctrl.dtsi" +/ { + soc { + pinctrl: pin-controller@50002000 { + st,package = <STM32MP_PKG_AC>; + + gpioa: gpio@50002000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 0 16>; + }; + + gpiob: gpio@50003000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 16 16>; + }; + + gpioc: gpio@50004000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 32 16>; + }; + + gpiod: gpio@50005000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 48 16>; + }; + + gpioe: gpio@50006000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 64 16>; + }; + + gpiof: gpio@50007000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 80 16>; + }; + + gpiog: gpio@50008000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 96 16>; + }; + + gpioh: gpio@50009000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 112 16>; + }; + + gpioi: gpio@5000a000 { + status = "okay"; + ngpios = <12>; + gpio-ranges = <&pinctrl 0 128 12>; + }; + }; + + pinctrl_z: pin-controller-z@54004000 { + st,package = <STM32MP_PKG_AC>; + + gpioz: gpio@54004000 { + status = "okay"; + ngpios = <8>; + gpio-ranges = <&pinctrl_z 0 400 8>; + }; + }; + }; +}; diff --git a/arch/arm/dts/stm32mp157xad-pinctrl.dtsi b/arch/arm/dts/stm32mp157xad-pinctrl.dtsi new file mode 100644 index 0000000..910113f --- /dev/null +++ b/arch/arm/dts/stm32mp157xad-pinctrl.dtsi @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR BSD-3-Clause) +/* + * Copyright (C) STMicroelectronics 2019 - All Rights Reserved + * Author: Alexandre Torgue alexandre.torgue@st.com + */ + +#include "stm32mp157-pinctrl.dtsi" +/ { + soc { + pinctrl: pin-controller@50002000 { + st,package = <STM32MP_PKG_AD>; + + gpioa: gpio@50002000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 0 16>; + }; + + gpiob: gpio@50003000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 16 16>; + }; + + gpioc: gpio@50004000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 32 16>; + }; + + gpiod: gpio@50005000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 48 16>; + }; + + gpioe: gpio@50006000 { + status = "okay"; + ngpios = <16>; + gpio-ranges = <&pinctrl 0 64 16>; + }; + + gpiof: gpio@50007000 { + status = "okay"; + ngpios = <6>; + gpio-ranges = <&pinctrl 6 86 6>; + }; + + gpiog: gpio@50008000 { + status = "okay"; + ngpios = <10>; + gpio-ranges = <&pinctrl 6 102 10>; + }; + + gpioh: gpio@50009000 { + status = "okay"; + ngpios = <2>; + gpio-ranges = <&pinctrl 0 112 2>; + }; + }; + }; +};
Update DDR configuration with the latest update: - Change DQSGE to 1 for DDR3, to cure missing DQS preamble.
Signed-off-by: Nicolas Le Bayon nicolas.le.bayon@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
arch/arm/dts/stm32mp15-ddr3-1x4Gb-1066-binG.dtsi | 4 ++-- arch/arm/dts/stm32mp15-ddr3-2x4Gb-1066-binG.dtsi | 5 ++--- 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/arch/arm/dts/stm32mp15-ddr3-1x4Gb-1066-binG.dtsi b/arch/arm/dts/stm32mp15-ddr3-1x4Gb-1066-binG.dtsi index dc30360..11e8f2b 100644 --- a/arch/arm/dts/stm32mp15-ddr3-1x4Gb-1066-binG.dtsi +++ b/arch/arm/dts/stm32mp15-ddr3-1x4Gb-1066-binG.dtsi @@ -16,7 +16,7 @@ * address mapping : RBC * Tc > + 85C : N */ -#define DDR_MEM_NAME "DDR3-1066/888 bin G 1x4Gb 533MHz v1.44" +#define DDR_MEM_NAME "DDR3-1066/888 bin G 1x4Gb 533MHz v1.45" #define DDR_MEM_SPEED 533000 #define DDR_MEM_SIZE 0x20000000
@@ -89,7 +89,7 @@ #define DDR_PTR2 0x042DA068 #define DDR_ACIOCR 0x10400812 #define DDR_DXCCR 0x00000C40 -#define DDR_DSGCR 0xF200001F +#define DDR_DSGCR 0xF200011F #define DDR_DCR 0x0000000B #define DDR_DTPR0 0x38D488D0 #define DDR_DTPR1 0x098B00D8 diff --git a/arch/arm/dts/stm32mp15-ddr3-2x4Gb-1066-binG.dtsi b/arch/arm/dts/stm32mp15-ddr3-2x4Gb-1066-binG.dtsi index 8158a56..4b70b60 100644 --- a/arch/arm/dts/stm32mp15-ddr3-2x4Gb-1066-binG.dtsi +++ b/arch/arm/dts/stm32mp15-ddr3-2x4Gb-1066-binG.dtsi @@ -16,8 +16,7 @@ * address mapping : RBC * Tc > + 85C : N */ - -#define DDR_MEM_NAME "DDR3-1066/888 bin G 2x4Gb 533MHz v1.44" +#define DDR_MEM_NAME "DDR3-1066/888 bin G 2x4Gb 533MHz v1.45" #define DDR_MEM_SPEED 533000 #define DDR_MEM_SIZE 0x40000000
@@ -90,7 +89,7 @@ #define DDR_PTR2 0x042DA068 #define DDR_ACIOCR 0x10400812 #define DDR_DXCCR 0x00000C40 -#define DDR_DSGCR 0xF200001F +#define DDR_DSGCR 0xF200011F #define DDR_DCR 0x0000000B #define DDR_DTPR0 0x38D488D0 #define DDR_DTPR1 0x098B00D8
This patch adds independent watchdog support for stm32mp157c in SPL.
arch/arm/dts/stm32mp157-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/stm32mp157-u-boot.dtsi b/arch/arm/dts/stm32mp157-u-boot.dtsi index 8102ce2..ba13ebb 100644 --- a/arch/arm/dts/stm32mp157-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157-u-boot.dtsi @@ -106,6 +106,10 @@ u-boot,dm-pre-reloc; };
+&iwdg2 { + u-boot,dm-pre-reloc; +}; + &pinctrl { u-boot,dm-pre-reloc; };
Add node in DT and avoid error to search UCLASS_SYSRESET in board_f.c::print_resetinfo() and lost 1.6s in U-Boot for the trusted boot chain.
arch/arm/dts/stm32mp157-u-boot.dtsi | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/arch/arm/dts/stm32mp157-u-boot.dtsi b/arch/arm/dts/stm32mp157-u-boot.dtsi index ba13ebb..1c4ad67 100644 --- a/arch/arm/dts/stm32mp157-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157-u-boot.dtsi @@ -25,6 +25,11 @@ u-boot,dm-pre-reloc; };
+ /* need PSCI for sysreset during board_f */ + psci { + u-boot,dm-pre-proper; + }; + reboot { u-boot,dm-pre-reloc; };
The pre-relocation probe is needed to reserve video frame buffer in video_reserve() for all the board; LDTC must be tagged prereloc in SOC U-Boot dtsi file.
diff --git a/arch/arm/dts/stm32mp157-u-boot.dtsi b/arch/arm/dts/stm32mp157-u-boot.dtsi index 1c4ad67..0d1d387 100644 --- a/arch/arm/dts/stm32mp157-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157-u-boot.dtsi @@ -115,6 +115,11 @@ u-boot,dm-pre-reloc; };
+/* pre-reloc probe = reserve video frame buffer in video_reserve() */ +<dc { + u-boot,dm-pre-proper; +}; + &pinctrl { u-boot,dm-pre-reloc; };
Allow to use PA13 and PA14 to force fastboot mode or STM32CubeProgrammer mode.
arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi b/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi index 36c852d..2a1cfd3 100644 --- a/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi @@ -17,6 +17,8 @@ u-boot,boot-led = "heartbeat"; u-boot,error-led = "error"; st,adc_usb_pd = <&adc1 18>, <&adc1 19>; + st,fastboot-gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; + st,stm32prog-gpios = <&gpioa 14 GPIO_ACTIVE_LOW>; }; led { red {
Avoid U-Boot auto-boot interruption for line break detection on console when the RX line connected to STLINK is floating (-IO error in getc cause by framing error and testc return 1) Same workaround is applied on all the STMicroelectonics board.
arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi | 2 ++ arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi b/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi index 2a1cfd3..dcaab3e 100644 --- a/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi @@ -189,6 +189,8 @@ }; pins2 { u-boot,dm-pre-reloc; + /* pull-up on rx to avoid floating level */ + bias-pull-up; }; };
diff --git a/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi b/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi index 200601e..21c89c1 100644 --- a/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi @@ -206,5 +206,7 @@ }; pins2 { u-boot,dm-pre-reloc; + /* pull-up on rx to avoid floating level */ + bias-pull-up; }; };
Add precision for disabled fixed clock in stm32mp1 binding.
doc/device-tree-bindings/clock/st,stm32mp1.txt | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/doc/device-tree-bindings/clock/st,stm32mp1.txt b/doc/device-tree-bindings/clock/st,stm32mp1.txt index 02e1460..ec1d703 100644 --- a/doc/device-tree-bindings/clock/st,stm32mp1.txt +++ b/doc/device-tree-bindings/clock/st,stm32mp1.txt @@ -164,8 +164,10 @@ used to define the state of associated ST32MP1 oscillators: - clk-csi
At boot the clock tree initialization will - - enable oscillators present in device tree + - enable oscillators present in device tree and not disabled + (node with status="disabled"), - disable HSI oscillator if the node is absent (always activated by bootrom) + and not disabled (node with status="disabled").
Optional properties :
Depending on backup register value, we maintain the debug unit powered-on for debugging purpose. Only BUCK1 is required for powering the debug unit, so revert the setting for all the other power lanes, except BUCK3 that has to be always on.
arch/arm/mach-stm32mp/include/mach/stm32.h | 1 + board/st/stm32mp1/spl.c | 14 ++++++++++++++ include/power/stpmic1.h | 5 +++-- 3 files changed, 18 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-stm32mp/include/mach/stm32.h b/arch/arm/mach-stm32mp/include/mach/stm32.h index 1d4b548..b3e9ccc 100644 --- a/arch/arm/mach-stm32mp/include/mach/stm32.h +++ b/arch/arm/mach-stm32mp/include/mach/stm32.h @@ -94,6 +94,7 @@ enum boot_device { #define TAMP_BOOT_DEVICE_MASK GENMASK(7, 4) #define TAMP_BOOT_INSTANCE_MASK GENMASK(3, 0) #define TAMP_BOOT_FORCED_MASK GENMASK(7, 0) +#define TAMP_BOOT_DEBUG_ON BIT(16)
enum forced_boot_mode { BOOT_NORMAL = 0x00, diff --git a/board/st/stm32mp1/spl.c b/board/st/stm32mp1/spl.c index e19be0f..e65ff28 100644 --- a/board/st/stm32mp1/spl.c +++ b/board/st/stm32mp1/spl.c @@ -27,5 +27,19 @@ void spl_board_init(void) STPMIC1_BUCKS_MRST_CR, STPMIC1_MRST_BUCK(STPMIC1_BUCK3), STPMIC1_MRST_BUCK(STPMIC1_BUCK3)); + + /* Check if debug is enabled to program PMIC according to the bit */ + if ((readl(TAMP_BOOT_CONTEXT) & TAMP_BOOT_DEBUG_ON) && !ret) { + printf("Keep debug unit ON\n"); + + pmic_clrsetbits(dev, STPMIC1_BUCKS_MRST_CR, + STPMIC1_MRST_BUCK_DEBUG, + STPMIC1_MRST_BUCK_DEBUG); + + if (STPMIC1_MRST_LDO_DEBUG) + pmic_clrsetbits(dev, STPMIC1_LDOS_MRST_CR, + STPMIC1_MRST_LDO_DEBUG, + STPMIC1_MRST_LDO_DEBUG); + } #endif } diff --git a/include/power/stpmic1.h b/include/power/stpmic1.h index 0e6721d..d90a1a9 100644 --- a/include/power/stpmic1.h +++ b/include/power/stpmic1.h @@ -22,11 +22,12 @@
/* BUCKS_MRST_CR */ #define STPMIC1_MRST_BUCK(buck) BIT(buck) -#define STPMIC1_MRST_BUCK_ALL GENMASK(3, 0) +#define STPMIC1_MRST_BUCK_DEBUG (STPMIC1_MRST_BUCK(STPMIC1_BUCK1) | \ + STPMIC1_MRST_BUCK(STPMIC1_BUCK3))
/* LDOS_MRST_CR */ #define STPMIC1_MRST_LDO(ldo) BIT(ldo) -#define STPMIC1_MRST_LDO_ALL GENMASK(6, 0) +#define STPMIC1_MRST_LDO_DEBUG 0
/* BUCKx_MAIN_CR (x=1...4) */ #define STPMIC1_BUCK_ENA BIT(0)
Use the default value from lib/Kconfig.
include/configs/stm32mp1.h | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 1bed570..033291e 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -10,11 +10,6 @@ #include <linux/sizes.h> #include <asm/arch/stm32.h>
-/* - * Number of clock ticks in 1 sec - */ -#define CONFIG_SYS_HZ 1000 - #ifndef CONFIG_STM32MP1_TRUSTED /* PSCI support */ #define CONFIG_ARMV7_PSCI_1_0
Allow to disable console with environment variable 'silent':
env set silent 1; env save
arch/arm/mach-stm32mp/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 9dc3c4d..e5f05af 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -47,6 +47,7 @@ config TARGET_STM32MP1 imply BOOTSTAGE imply CMD_BOOTCOUNT imply CMD_BOOTSTAGE + imply SILENT_CONSOLE imply SYSRESET_PSCI if STM32MP1_TRUSTED imply SYSRESET_SYSCON if !STM32MP1_TRUSTED help
Correctly handle silent=1 in the default environment.
arch/arm/mach-stm32mp/Kconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index e5f05af..7efe464 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -47,6 +47,7 @@ config TARGET_STM32MP1 imply BOOTSTAGE imply CMD_BOOTCOUNT imply CMD_BOOTSTAGE + imply PRE_CONSOLE_BUFFER imply SILENT_CONSOLE imply SYSRESET_PSCI if STM32MP1_TRUSTED imply SYSRESET_SYSCON if !STM32MP1_TRUSTED @@ -110,6 +111,13 @@ config CMD_STM32KEY fuse public key hash in corresponding fuse used to authenticate binary.
+ +config PRE_CON_BUF_ADDR + default 0xC02FF000 + +config PRE_CON_BUF_SZ + default 4096 + config BOOTSTAGE_STASH_ADDR default 0xC3000000
for the moment basic and trusted configuration must start CPU in Supervisor mode and not in Hypervisor
configs/stm32mp15_basic_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 27b8525..a4c2027 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_TARGET_STM32MP1=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y +# CONFIG_ARMV7_VIRT is not set CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_BOOTCOMMAND="run bootcmd_stm32mp"
Select the serial driver mandatory for the console.
arch/arm/mach-stm32mp/Kconfig | 1 + configs/stm32mp15_basic_defconfig | 1 - configs/stm32mp15_optee_defconfig | 1 - configs/stm32mp15_trusted_defconfig | 1 - 4 files changed, 1 insertion(+), 3 deletions(-)
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 7efe464..0de9b3e 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -42,6 +42,7 @@ config TARGET_STM32MP1 select PINCTRL_STM32 select STM32_RCC select STM32_RESET + select STM32_SERIAL select SYS_ARCH_TIMER imply BOOTCOUNT_LIMIT imply BOOTSTAGE diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index a4c2027..1edea79 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -106,7 +106,6 @@ CONFIG_REMOTEPROC_STM32_COPRO=y CONFIG_DM_RTC=y CONFIG_RTC_STM32=y CONFIG_SERIAL_RX_BUFFER=y -CONFIG_STM32_SERIAL=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig index 0565e5e..11f8359 100644 --- a/configs/stm32mp15_optee_defconfig +++ b/configs/stm32mp15_optee_defconfig @@ -92,7 +92,6 @@ CONFIG_REMOTEPROC_STM32_COPRO=y CONFIG_DM_RTC=y CONFIG_RTC_STM32=y CONFIG_SERIAL_RX_BUFFER=y -CONFIG_STM32_SERIAL=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 844cbcd..bc76c08 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -91,7 +91,6 @@ CONFIG_REMOTEPROC_STM32_COPRO=y CONFIG_DM_RTC=y CONFIG_RTC_STM32=y CONFIG_SERIAL_RX_BUFFER=y -CONFIG_STM32_SERIAL=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y
Activate DISABLE_CONSOLE needed for stm32prog support on uart.
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 0de9b3e..cee3ce1 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -48,6 +48,7 @@ config TARGET_STM32MP1 imply BOOTSTAGE imply CMD_BOOTCOUNT imply CMD_BOOTSTAGE + imply DISABLE_CONSOLE imply PRE_CONSOLE_BUFFER imply SILENT_CONSOLE imply SYSRESET_PSCI if STM32MP1_TRUSTED
MTD is only use if NAND or NOR driver is activated.
include/configs/stm32mp1.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 033291e..b2b8660 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -79,7 +79,9 @@ #endif
/* Dynamic MTD partition support */ +#if defined(CONFIG_STM32_QSPI) || defined(CONFIG_NAND_STM32_FMC2) #define CONFIG_SYS_MTDPARTS_RUNTIME +#endif
/*****************************************************************************/ #ifdef CONFIG_DISTRO_DEFAULTS
Add imply for FDT overlay that can be usefuill for kernel device tree management but it is not mandatory (can be removed to gain space)
arch/arm/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3f0e301..14108e6 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1545,6 +1545,7 @@ config ARCH_STM32MP imply SPL_SYSRESET imply CMD_DM imply CMD_POWEROFF + imply OF_LIBFDT_OVERLAY imply ENV_VARS_UBOOT_RUNTIME_CONFIG imply USE_PREBOOT help
Remove CONFIG_SPI_FLASH_BAR as the SPI NOR layer uses stateless 4 byte opcodes by default.
configs/stm32mp15_basic_defconfig | 1 - configs/stm32mp15_optee_defconfig | 1 - configs/stm32mp15_trusted_defconfig | 1 - 3 files changed, 3 deletions(-)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 1edea79..5a372e1 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -81,7 +81,6 @@ CONFIG_NAND=y CONFIG_NAND_STM32_FMC2=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig index 11f8359..a6c010e 100644 --- a/configs/stm32mp15_optee_defconfig +++ b/configs/stm32mp15_optee_defconfig @@ -69,7 +69,6 @@ CONFIG_NAND=y CONFIG_NAND_STM32_FMC2=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index bc76c08..de87834 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -68,7 +68,6 @@ CONFIG_NAND=y CONFIG_NAND_STM32_FMC2=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y
Activate command DM_VIDEO for LCD support
configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_optee_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + 3 files changed, 3 insertions(+)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 5a372e1..7e5ae45 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -119,4 +119,5 @@ CONFIG_USB_GADGET_MANUFACTURER="STMicroelectronics" CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_DM_VIDEO=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig index a6c010e..0860a26 100644 --- a/configs/stm32mp15_optee_defconfig +++ b/configs/stm32mp15_optee_defconfig @@ -105,4 +105,5 @@ CONFIG_USB_GADGET_MANUFACTURER="STMicroelectronics" CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_DM_VIDEO=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index de87834..5855c36 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -104,4 +104,5 @@ CONFIG_USB_GADGET_MANUFACTURER="STMicroelectronics" CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_DM_VIDEO=y CONFIG_FDT_FIXUP_PARTITIONS=y
Backlight of panel raydium RM68200 is controlled by a simple gpio, thus we activate the support for the needed driver.
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 7e5ae45..ca7e91c 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -120,4 +120,5 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig index 0860a26..f480c3d 100644 --- a/configs/stm32mp15_optee_defconfig +++ b/configs/stm32mp15_optee_defconfig @@ -106,4 +106,5 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 5855c36..585817e 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -105,4 +105,5 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y CONFIG_FDT_FIXUP_PARTITIONS=y
Activate command BMP for splash screen support
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index ca7e91c..740d482 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y diff --git a/configs/stm32mp15_optee_defconfig b/configs/stm32mp15_optee_defconfig index f480c3d..e5b9be7 100644 --- a/configs/stm32mp15_optee_defconfig +++ b/configs/stm32mp15_optee_defconfig @@ -27,6 +27,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 585817e..2d9be04 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y +CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y
Only activate WATCHDOG in SPL when CONFIG_WATCHDOG is activated in U-Boot.
arch/arm/mach-stm32mp/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index cee3ce1..187be17 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -17,7 +17,7 @@ config SPL select SPL_DM_RESET select SPL_SERIAL_SUPPORT select SPL_SYSCON - select SPL_WATCHDOG_SUPPORT + select SPL_WATCHDOG_SUPPORT if WATCHDOG imply BOOTSTAGE_STASH if SPL_BOOTSTAGE imply SPL_BOOTSTAGE if BOOTSTAGE imply SPL_DISPLAY_PRINT
Add altbootcmad as it is used for - bootcountlimit - in mach-stm32mp/cpu.c for BOOT_RECOVERY mode
include/configs/stm32mp1.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index b2b8660..ae05308 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -150,7 +150,8 @@ "ramdisk_addr_r=0xc4400000\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ - "env_default=1\0" \ + "altbootcmd=run bootcmd\0" \ + "env_default=1\0" \ "env_check=if test $env_default -eq 1;"\ " then env set env_default 0;env save;fi\0" \ STM32MP_BOOTCMD \
This allows to display splashcreen without waiting an extra delay of 2 seconds due to default value of bootdelay.
include/configs/stm32mp1.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index ae05308..92660fe 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -142,6 +142,7 @@ * and the ramdisk at the end. */ #define CONFIG_EXTRA_ENV_SETTINGS \ + "bootdelay=1\0" \ "kernel_addr_r=0xc2000000\0" \ "fdt_addr_r=0xc4000000\0" \ "scriptaddr=0xc4100000\0" \
Add the boot for NOR, SPL load U-Boot.img at offset CONFIG_SYS_SPI_U_BOOT_OFFS = 0x80000. It is the start address of mtd partition ssbl in nor.
Signed-off-by: Christophe Kerello christophe.kerello@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
arch/arm/mach-stm32mp/Kconfig | 1 + include/configs/stm32mp1.h | 5 +++++ 2 files changed, 6 insertions(+)
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 187be17..c9bc084 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -16,6 +16,7 @@ config SPL select SPL_REGMAP select SPL_DM_RESET select SPL_SERIAL_SUPPORT + select SPL_SPI_LOAD select SPL_SYSCON select SPL_WATCHDOG_SUPPORT if WATCHDOG imply BOOTSTAGE_STASH if SPL_BOOTSTAGE diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 92660fe..88f8254 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -70,6 +70,11 @@ #define CONFIG_SYS_NAND_ONFI_DETECTION #define CONFIG_SYS_MAX_NAND_DEVICE 1
+/* SPI FLASH support */ +#if defined(CONFIG_SPL_BUILD) +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x80000 +#endif + /* Ethernet need */ #ifdef CONFIG_DWC_ETH_QOS #define CONFIG_SYS_NONCACHED_MEMORY (1 * SZ_1M) /* 1M */
Add variable to identify board with HW id (read from OTP) and revision.
board/st/stm32mp1/stm32mp1.c | 19 +++++++++++++++++++ 1 file changed, 19 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index b99c6c0..ad3db31 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -538,6 +538,10 @@ int board_late_init(void) #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG const void *fdt_compat; int fdt_compat_len; + int ret; + u32 otp; + struct udevice *dev; + char buf[10];
fdt_compat = fdt_getprop(gd->fdt_blob, 0, "compatible", &fdt_compat_len); @@ -547,6 +551,21 @@ int board_late_init(void) else env_set("board_name", fdt_compat + 3); } + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(stm32mp_bsec), + &dev); + + if (!ret) + ret = misc_read(dev, STM32_BSEC_SHADOW(BSEC_OTP_BOARD), + &otp, sizeof(otp)); + if (!ret && otp) { + snprintf(buf, sizeof(buf), "0x%04x", otp >> 16); + env_set("board_id", buf); + + snprintf(buf, sizeof(buf), "0x%04x", + ((otp >> 8) & 0xF) - 1 + 0xA); + env_set("board_rev", buf); + } #endif
/* for DK1/DK2 boards */
As for Audio codec IC, HDMI IC is not "IO safe". HDMI regulators (v3v3 and v1v2) must be enabled to allow I2C1 bus usage. HDMI IC must be under reset during power up and keep HDMI and AUDIO devices in reset while they are not used in U-Boot to keep them in low power mode (each device can be kept in reset independently keeping their power supplies ON until kernel).
arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi | 6 +++ board/st/stm32mp1/Kconfig | 4 ++ board/st/stm32mp1/stm32mp1.c | 70 ++++++++++++++++++++++++++++++++ 3 files changed, 80 insertions(+)
diff --git a/arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi b/arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi index 06ef3a4..18ac1e3 100644 --- a/arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi @@ -4,3 +4,9 @@ */
#include "stm32mp157a-dk1-u-boot.dtsi" + +&i2c1 { + hdmi-transmitter@39 { + reset-gpios = <&gpioa 10 GPIO_ACTIVE_LOW>; + }; +}; diff --git a/board/st/stm32mp1/Kconfig b/board/st/stm32mp1/Kconfig index 87216c0..4fa2360 100644 --- a/board/st/stm32mp1/Kconfig +++ b/board/st/stm32mp1/Kconfig @@ -22,4 +22,8 @@ config CMD_STBOARD This compile the stboard command to read and write the board in the OTP.
+config TARGET_STM32MP157C_DK2 + bool "support of STMicroelectronics STM32MP157C-DK2 Discovery Board" + default y + endif diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index ad3db31..2837e9a 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -504,6 +504,73 @@ static void sysconf_init(void) #endif }
+#ifdef CONFIG_DM_REGULATOR +/* Fix to make I2C1 usable on DK2 for touchscreen usage in kernel */ +static int dk2_i2c1_fix(void) +{ + ofnode node; + struct gpio_desc hdmi, audio; + int ret = 0; + + node = ofnode_path("/soc/i2c@40012000/hdmi-transmitter@39"); + if (!ofnode_valid(node)) { + pr_debug("%s: no hdmi-transmitter@39 ?\n", __func__); + return -ENOENT; + } + + if (gpio_request_by_name_nodev(node, "reset-gpios", 0, + &hdmi, GPIOD_IS_OUT)) { + pr_debug("%s: could not find reset-gpios\n", + __func__); + return -ENOENT; + } + + node = ofnode_path("/soc/i2c@40012000/cs42l51@4a"); + if (!ofnode_valid(node)) { + pr_debug("%s: no cs42l51@4a ?\n", __func__); + return -ENOENT; + } + + if (gpio_request_by_name_nodev(node, "reset-gpios", 0, + &audio, GPIOD_IS_OUT)) { + pr_debug("%s: could not find reset-gpios\n", + __func__); + return -ENOENT; + } + + /* before power up, insure that HDMI and AUDIO IC is under reset */ + ret = dm_gpio_set_value(&hdmi, 1); + if (ret) { + pr_err("%s: can't set_value for hdmi_nrst gpio", __func__); + goto error; + } + ret = dm_gpio_set_value(&audio, 1); + if (ret) { + pr_err("%s: can't set_value for audio_nrst gpio", __func__); + goto error; + } + + /* power-up audio IC */ + regulator_autoset_by_name("v1v8_audio", NULL); + + /* power-up HDMI IC */ + regulator_autoset_by_name("v1v2_hdmi", NULL); + regulator_autoset_by_name("v3v3_hdmi", NULL); + +error: + return ret; +} + +static bool board_is_dk2(void) +{ + if (CONFIG_IS_ENABLED(TARGET_STM32MP157C_DK2) && + of_machine_is_compatible("st,stm32mp157c-dk2")) + return true; + + return false; +} +#endif + /* board dependent setup after realloc */ int board_init(void) { @@ -522,6 +589,9 @@ int board_init(void) board_key_check();
#ifdef CONFIG_DM_REGULATOR + if (board_is_dk2()) + dk2_i2c1_fix(); + regulators_enable_boot_on(_DEBUG); #endif
Create a function led_error_blink and add node in device tree.
arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi | 21 ++++---------- board/st/stm32mp1/stm32mp1.c | 48 ++++++++++++++++++++++---------- 2 files changed, 39 insertions(+), 30 deletions(-)
diff --git a/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi b/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi index 21c89c1..4953a0d 100644 --- a/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi @@ -15,31 +15,22 @@ };
config { + u-boot,boot-led = "heartbeat"; + u-boot,error-led = "error"; st,fastboot-gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; st,stm32prog-gpios = <&gpioa 14 GPIO_ACTIVE_LOW>; };
led { - compatible = "gpio-leds"; - red { - label = "stm32mp:red:status"; + label = "error"; gpios = <&gpioa 13 GPIO_ACTIVE_LOW>; default-state = "off"; + status = "okay"; }; - green { - label = "stm32mp:green:user"; - gpios = <&gpioa 14 GPIO_ACTIVE_LOW>; - default-state = "on"; - }; - orange { - label = "stm32mp:orange:status"; - gpios = <&gpioh 7 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; + blue { - label = "stm32mp:blue:user"; - gpios = <&gpiod 11 GPIO_ACTIVE_HIGH>; + default-state = "on"; }; }; }; diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 2837e9a..61a4253 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -20,6 +20,7 @@ #include <reset.h> #include <syscon.h> #include <usb.h> +#include <watchdog.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/stm32.h> @@ -231,6 +232,7 @@ int g_dnl_board_usb_cable_connected(void) } #endif /* CONFIG_USB_GADGET */
+#ifdef CONFIG_LED static int get_led(struct udevice **dev, char *led_string) { char *led_name; @@ -263,12 +265,41 @@ static int setup_led(enum led_state_t cmd) ret = led_set_state(dev, cmd); return ret; } +#endif + +static void __maybe_unused led_error_blink(u32 nb_blink) +{ +#ifdef CONFIG_LED + int ret; + struct udevice *led; + u32 i; +#endif + + if (!nb_blink) + return; + +#ifdef CONFIG_LED + ret = get_led(&led, "u-boot,error-led"); + if (!ret) { + /* make u-boot,error-led blinking */ + /* if U32_MAX and 125ms interval, for 17.02 years */ + for (i = 0; i < 2 * nb_blink; i++) { + led_set_state(led, LEDST_TOGGLE); + mdelay(125); + WATCHDOG_RESET(); + } + } +#endif + + /* infinite: the boot process must be stopped */ + if (nb_blink == U32_MAX) + hang(); +}
static int board_check_usb_power(void) { struct ofnode_phandle_args adc_args; struct udevice *adc; - struct udevice *led; ofnode node; unsigned int raw; int max_uV = 0; @@ -394,20 +425,7 @@ static int board_check_usb_power(void) pr_err("****************************************************\n\n"); }
- ret = get_led(&led, "u-boot,error-led"); - if (ret) { - /* in unattached case, the boot process must be stopped */ - if (nb_blink == U32_MAX) - hang(); - return ret; - } - - /* make u-boot,error-led blinking */ - for (i = 0; i < nb_blink * 2; i++) { - led_set_state(led, LEDST_TOGGLE); - mdelay(125); - } - led_set_state(led, LEDST_ON); + led_error_blink(nb_blink);
return 0; }
Avoid compilation issue when CONFIG_LED is not activated
board/st/stm32mp1/stm32mp1.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 61a4253..181409c 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -615,7 +615,7 @@ int board_init(void)
sysconf_init();
- if (IS_ENABLED(CONFIG_LED)) + if (CONFIG_IS_ENABLED(CONFIG_LED)) led_default_state();
return 0; @@ -664,7 +664,9 @@ int board_late_init(void)
void board_quiesce_devices(void) { +#ifdef CONFIG_LED setup_led(LEDST_OFF); +#endif }
/* board interface eth init */
Allows to avoid to wait 2 second in U-Boot before to start STM32CubeProgrammer command.
board/st/stm32mp1/stm32mp1.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 181409c..c61a562 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -623,6 +623,7 @@ int board_init(void)
int board_late_init(void) { + char *boot_device; #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG const void *fdt_compat; int fdt_compat_len; @@ -659,6 +660,11 @@ int board_late_init(void) /* for DK1/DK2 boards */ board_check_usb_power();
+ /* Check the boot-source to disable bootdelay */ + boot_device = env_get("boot_device"); + if (!strcmp(boot_device, "serial") || !strcmp(boot_device, "usb")) + env_set("bootdelay", "0"); + return 0; }
Due to kernel DT alignment, pwr-supply is renamed to vdd-supply and is a subnode of pwr-regulators.
Signed-off-by: Patrice Chotard patrice.chotard@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
arch/arm/dts/stm32mp157a-avenger96.dts | 5 ++++- arch/arm/dts/stm32mp157a-dk1.dts | 5 ++++- arch/arm/dts/stm32mp157c-ed1.dts | 5 ++++- board/st/stm32mp1/stm32mp1.c | 8 +++++--- 4 files changed, 17 insertions(+), 6 deletions(-)
diff --git a/arch/arm/dts/stm32mp157a-avenger96.dts b/arch/arm/dts/stm32mp157a-avenger96.dts index ba86cf5..5b15a4a 100644 --- a/arch/arm/dts/stm32mp157a-avenger96.dts +++ b/arch/arm/dts/stm32mp157a-avenger96.dts @@ -283,7 +283,10 @@ };
&pwr { - pwr-supply = <&vdd>; + pwr-regulators { + vdd-supply = <&vdd>; + vdd_3v3_usbfs-supply = <&vdd_usb>; + }; };
&rng1 { diff --git a/arch/arm/dts/stm32mp157a-dk1.dts b/arch/arm/dts/stm32mp157a-dk1.dts index 1d5c1a6..ba612a5 100644 --- a/arch/arm/dts/stm32mp157a-dk1.dts +++ b/arch/arm/dts/stm32mp157a-dk1.dts @@ -308,7 +308,10 @@ };
&rng1 { diff --git a/arch/arm/dts/stm32mp157c-ed1.dts b/arch/arm/dts/stm32mp157c-ed1.dts index 94ac025..3e8b7b5 100644 --- a/arch/arm/dts/stm32mp157c-ed1.dts +++ b/arch/arm/dts/stm32mp157c-ed1.dts @@ -218,7 +218,10 @@ };
&rng1 { diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index c61a562..a96e675 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -471,7 +471,9 @@ static void sysconf_init(void) * => U-Boot set the register only if VDD < 2.7V (in DT) * but this value need to be consistent with board design */ - ret = syscon_get_by_driver_data(STM32MP_SYSCON_PWR, &pwr_dev); + ret = uclass_get_device_by_driver(UCLASS_PMIC, + DM_GET_DRIVER(stm32mp_pwr_pmic), + &pwr_dev); if (!ret) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_GET_DRIVER(stm32mp_bsec), @@ -485,8 +487,8 @@ static void sysconf_init(void) if (!ret) otp = otp & BIT(13);
- /* get VDD = pwr-supply */ - ret = device_get_supply_regulator(pwr_dev, "pwr-supply", + /* get VDD = vdd-supply */ + ret = device_get_supply_regulator(pwr_dev, "vdd-supply", &pwr_reg);
/* check if VDD is Low Voltage */
Avoid compilation issue when CONFIG_ADC is not activated
board/st/stm32mp1/stm32mp1.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index a96e675..a67e33e 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -296,6 +296,7 @@ static void __maybe_unused led_error_blink(u32 nb_blink) hang(); }
+#ifdef CONFIG_ADC static int board_check_usb_power(void) { struct ofnode_phandle_args adc_args; @@ -429,6 +430,7 @@ static int board_check_usb_power(void)
return 0; } +#endif /* CONFIG_ADC */
static void sysconf_init(void) { @@ -659,8 +661,10 @@ int board_late_init(void) } #endif
+#ifdef CONFIG_ADC /* for DK1/DK2 boards */ board_check_usb_power(); +#endif /* CONFIG_ADC */
/* Check the boot-source to disable bootdelay */ boot_device = env_get("boot_device");
- reorder include files - remove one comment
board/st/stm32mp1/stm32mp1.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index a67e33e..7085bd5 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -5,8 +5,8 @@ #include <common.h> #include <adc.h> #include <bootm.h> -#include <config.h> #include <clk.h> +#include <config.h> #include <dm.h> #include <environment.h> #include <g_dnl.h> @@ -682,7 +682,6 @@ void board_quiesce_devices(void) }
/* board interface eth init */ -/* this is a weak define that we are overriding */ int board_interface_eth_init(phy_interface_t interface_type, bool eth_clk_sel_reg, bool eth_ref_clk_sel_reg) {
This patch solves a watchdog reset issue during mmc erase command.
drivers/mmc/stm32_sdmmc2.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/mmc/stm32_sdmmc2.c b/drivers/mmc/stm32_sdmmc2.c index 867ed56..e7058cb 100644 --- a/drivers/mmc/stm32_sdmmc2.c +++ b/drivers/mmc/stm32_sdmmc2.c @@ -14,6 +14,7 @@ #include <asm/io.h> #include <asm/gpio.h> #include <linux/iopoll.h> +#include <watchdog.h>
struct stm32_sdmmc2_plat { struct mmc_config cfg; @@ -432,6 +433,8 @@ static int stm32_sdmmc2_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, u32 cmdat = data ? SDMMC_CMD_CMDTRANS : 0; int ret, retry = 3;
+ WATCHDOG_RESET(); + retry_cmd: ctx.data_length = 0; ctx.dpsm_abort = false;
Add management of Bit 1 of USART_ISR = FE: Framing error This bit is set by hardware when a de-synchronization, excessive noise or a break character is detected. It is cleared by software, writing 1 to the FECF bit in the USART_ICR register (for stm32 after f4).
drivers/serial/serial_stm32.c | 5 +++-- drivers/serial/serial_stm32.h | 2 ++ 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/drivers/serial/serial_stm32.c b/drivers/serial/serial_stm32.c index 3ab536a..00a8e72 100644 --- a/drivers/serial/serial_stm32.c +++ b/drivers/serial/serial_stm32.c @@ -106,10 +106,11 @@ static int stm32_serial_getc(struct udevice *dev) if ((isr & USART_ISR_RXNE) == 0) return -EAGAIN;
- if (isr & (USART_ISR_PE | USART_ISR_ORE)) { + if (isr & (USART_ISR_PE | USART_ISR_ORE | USART_ISR_FE)) { if (!stm32f4) setbits_le32(base + ICR_OFFSET, - USART_ICR_PCECF | USART_ICR_ORECF); + USART_ICR_PCECF | USART_ICR_ORECF | + USART_ICR_FECF); else readl(base + RDR_OFFSET(stm32f4)); return -EIO; diff --git a/drivers/serial/serial_stm32.h b/drivers/serial/serial_stm32.h index 5549f8c..7b0c531 100644 --- a/drivers/serial/serial_stm32.h +++ b/drivers/serial/serial_stm32.h @@ -67,6 +67,7 @@ struct stm32x7_serial_platdata { #define USART_ISR_TXE BIT(7) #define USART_ISR_RXNE BIT(5) #define USART_ISR_ORE BIT(3) +#define USART_ISR_FE BIT(1) #define USART_ISR_PE BIT(0)
#define USART_BRR_F_MASK GENMASK(7, 0) @@ -74,6 +75,7 @@ struct stm32x7_serial_platdata { #define USART_BRR_M_MASK GENMASK(15, 4)
#define USART_ICR_ORECF BIT(3) +#define USART_ICR_FECF BIT(1) #define USART_ICR_PCECF BIT(0)
#endif
The "serial_stm32.h" is only used by drivers/serial/serial_stm32.c and it is the file ./drivers/serial/serial_stm32.h
include/dm/platform_data/serial_stm32.h | 15 --------------- 1 file changed, 15 deletions(-) delete mode 100644 include/dm/platform_data/serial_stm32.h
diff --git a/include/dm/platform_data/serial_stm32.h b/include/dm/platform_data/serial_stm32.h deleted file mode 100644 index 85153df..0000000 --- a/include/dm/platform_data/serial_stm32.h +++ /dev/null @@ -1,15 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * (C) Copyright 2015 - * Kamil Lulko, kamil.lulko@gmail.com - */ - -#ifndef __SERIAL_STM32_H -#define __SERIAL_STM32_H - -/* Information about a serial port */ -struct stm32_serial_platdata { - struct stm32_usart *base; /* address of registers in physical memory */ -}; - -#endif /* __SERIAL_STM32_H */
drivers/ram/stm32mp1/stm32mp1_ddr.h | 4 ---- 1 file changed, 4 deletions(-)
diff --git a/drivers/ram/stm32mp1/stm32mp1_ddr.h b/drivers/ram/stm32mp1/stm32mp1_ddr.h index a8eed89..52b748f 100644 --- a/drivers/ram/stm32mp1/stm32mp1_ddr.h +++ b/drivers/ram/stm32mp1/stm32mp1_ddr.h @@ -197,10 +197,6 @@ void stm32mp1_edit_param(const struct stm32mp1_ddr_config *config, char *name, char *string);
-void stm32mp1_dump_info( - const struct ddr_info *priv, - const struct stm32mp1_ddr_config *config); - bool stm32mp1_ddr_interactive( void *priv, enum stm32mp1_ddr_interact_step step,
If user choose to test memory size is 1GByte (0x40000000), memory address would overflow in test "Random" and test "FrequencySelectivePattern". Thus the system would hangs up when running DDR test.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Bossen WU bossen.wu@st.com ---
drivers/ram/stm32mp1/stm32mp1_tests.c | 25 ++++++++++++++----------- 1 file changed, 14 insertions(+), 11 deletions(-)
diff --git a/drivers/ram/stm32mp1/stm32mp1_tests.c b/drivers/ram/stm32mp1/stm32mp1_tests.c index b6fb2a9..691c63c 100644 --- a/drivers/ram/stm32mp1/stm32mp1_tests.c +++ b/drivers/ram/stm32mp1/stm32mp1_tests.c @@ -578,27 +578,29 @@ static enum test_result test_random(struct stm32mp1_ddrctl *ctl, u32 error = 0; unsigned int seed;
- if (get_bufsize(string, argc, argv, 0, &bufsize, 4 * 1024)) + if (get_bufsize(string, argc, argv, 0, &bufsize, 8 * 1024)) return TEST_ERROR; if (get_nb_loop(string, argc, argv, 1, &nb_loop, 1)) return TEST_ERROR; if (get_addr(string, argc, argv, 2, &addr)) return TEST_ERROR;
- printf("running %d loops at 0x%x\n", nb_loop, addr); + bufsize /= 2; + printf("running %d loops copy from 0x%x to 0x%x (buffer size=0x%x)\n", + nb_loop, addr, addr + bufsize, bufsize); while (!error) { seed = rand(); - for (offset = addr; offset < addr + bufsize; offset += 4) - writel(rand(), offset); + for (offset = 0; offset < bufsize; offset += 4) + writel(rand(), addr + offset);
memcpy((void *)addr + bufsize, (void *)addr, bufsize);
srand(seed); - for (offset = addr; offset < addr + 2 * bufsize; offset += 4) { - if (offset == (addr + bufsize)) + for (offset = 0; offset < 2 * bufsize; offset += 4) { + if (offset == bufsize) srand(seed); value = rand(); - error = check_addr(offset, value); + error = check_addr(addr + offset, value); if (error) break; if (progress(offset)) @@ -607,6 +609,7 @@ static enum test_result test_random(struct stm32mp1_ddrctl *ctl, if (test_loop_end(&loop, nb_loop, 100)) break; } + putc('\n');
if (error) { sprintf(string, @@ -791,9 +794,9 @@ static enum test_result test_loop(const u32 *pattern, u32 *address, int i; int j; enum test_result res = TEST_PASSED; - u32 *offset, testsize, remaining; + u32 offset, testsize, remaining;
- offset = address; + offset = (u32)address; remaining = bufsize; while (remaining) { testsize = bufsize > 0x1000000 ? 0x1000000 : bufsize; @@ -809,7 +812,7 @@ static enum test_result test_loop(const u32 *pattern, u32 *address, __asm__("stmia r1!, {R3-R10}"); __asm__("stmia r1!, {R3-R10}"); __asm__("stmia r1!, {R3-R10}"); - __asm__("subs r2, r2, #8"); + __asm__("subs r2, r2, #128"); __asm__("bge loop2"); __asm__("pop {R0-R10}");
@@ -1388,7 +1391,7 @@ const struct test_desc test[] = { "Verifies r/w and memcopy(burst for pseudo random value.", 3 }, - {test_freq_pattern, "FrequencySelectivePattern ", "[size]", + {test_freq_pattern, "FrequencySelectivePattern", "[size]", "write & test patterns: Mostly Zero, Mostly One and F/n", 1 },
Reduce verbosity of the infinite tests to avoid CubeMX issue. test and display loop by 1024*1024 accesses: read or write.
drivers/ram/stm32mp1/stm32mp1_tests.c | 38 +++++++++++++++++++++++------------ 1 file changed, 25 insertions(+), 13 deletions(-)
diff --git a/drivers/ram/stm32mp1/stm32mp1_tests.c b/drivers/ram/stm32mp1/stm32mp1_tests.c index 691c63c..7356802 100644 --- a/drivers/ram/stm32mp1/stm32mp1_tests.c +++ b/drivers/ram/stm32mp1/stm32mp1_tests.c @@ -1241,6 +1241,7 @@ static enum test_result test_read(struct stm32mp1_ddrctl *ctl, u32 *addr; u32 data; u32 loop = 0; + int i, size = 1024 * 1024; bool random = false;
if (get_addr(string, argc, argv, 0, (u32 *)&addr)) @@ -1254,14 +1255,19 @@ static enum test_result test_read(struct stm32mp1_ddrctl *ctl, printf("running at 0x%08x\n", (u32)addr);
while (1) { - if (random) - addr = (u32 *)(STM32_DDR_BASE + - (rand() & (STM32_DDR_SIZE - 1) & ~0x3)); - data = readl(addr); - if (test_loop_end(&loop, 0, 1000)) + for (i = 0; i < size; i++) { + if (random) + addr = (u32 *)(STM32_DDR_BASE + + (rand() & (STM32_DDR_SIZE - 1) & ~0x3)); + data = readl(addr); + } + if (test_loop_end(&loop, 0, 1)) break; } - sprintf(string, "0x%x: %x", (u32)addr, data); + if (random) + sprintf(string, "%d loops random", loop); + else + sprintf(string, "%d loops at 0x%x: %x", loop, (u32)addr, data);
return TEST_PASSED; } @@ -1280,6 +1286,7 @@ static enum test_result test_write(struct stm32mp1_ddrctl *ctl, u32 *addr; u32 data = 0xA5A5AA55; u32 loop = 0; + int i, size = 1024 * 1024; bool random = false;
if (get_addr(string, argc, argv, 0, (u32 *)&addr)) @@ -1293,16 +1300,21 @@ static enum test_result test_write(struct stm32mp1_ddrctl *ctl, printf("running at 0x%08x\n", (u32)addr);
while (1) { - if (random) { - addr = (u32 *)(STM32_DDR_BASE + - (rand() & (STM32_DDR_SIZE - 1) & ~0x3)); - data = rand(); + for (i = 0; i < size; i++) { + if (random) { + addr = (u32 *)(STM32_DDR_BASE + + (rand() & (STM32_DDR_SIZE - 1) & ~0x3)); + data = rand(); + } + writel(data, addr); } - writel(data, addr); - if (test_loop_end(&loop, 0, 1000)) + if (test_loop_end(&loop, 0, 1)) break; } - sprintf(string, "0x%x: %x", (u32)addr, data); + if (random) + sprintf(string, "%d loops random", loop); + else + sprintf(string, "%d loops at 0x%x: %x", loop, (u32)addr, data);
Avoid watchdog during infinite DDR test.
drivers/ram/stm32mp1/stm32mp1_tests.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/ram/stm32mp1/stm32mp1_tests.c b/drivers/ram/stm32mp1/stm32mp1_tests.c index 7356802..f947b5d 100644 --- a/drivers/ram/stm32mp1/stm32mp1_tests.c +++ b/drivers/ram/stm32mp1/stm32mp1_tests.c @@ -4,6 +4,7 @@ */ #include <common.h> #include <console.h> +#include <watchdog.h> #include <asm/io.h> #include <linux/log2.h> #include "stm32mp1_tests.h" @@ -154,6 +155,8 @@ static int test_loop_end(u32 *loop, u32 nb_loop, u32 progress) return 1; } printf("loop #%d\n", *loop); + WATCHDOG_RESET(); + return 0; }
Add pattern for infinite test_read and test_write, that allow to change the pattern to test without recompilation; default pattern is 0xA5A5AA55.
drivers/ram/stm32mp1/stm32mp1_tests.c | 31 ++++++++++++++++++++----------- 1 file changed, 20 insertions(+), 11 deletions(-)
diff --git a/drivers/ram/stm32mp1/stm32mp1_tests.c b/drivers/ram/stm32mp1/stm32mp1_tests.c index f947b5d..581ee48 100644 --- a/drivers/ram/stm32mp1/stm32mp1_tests.c +++ b/drivers/ram/stm32mp1/stm32mp1_tests.c @@ -1250,13 +1250,18 @@ static enum test_result test_read(struct stm32mp1_ddrctl *ctl, if (get_addr(string, argc, argv, 0, (u32 *)&addr)) return TEST_ERROR;
+ if (get_pattern(string, argc, argv, 1, &data, 0xA5A5AA55)) + return TEST_ERROR; + if ((u32)addr == ADDR_INVALID) { - printf("random "); + printf("running random\n"); random = true; + } else { + printf("running at 0x%08x with pattern=0x%08x\n", + (u32)addr, data); + writel(data, addr); }
- printf("running at 0x%08x\n", (u32)addr); - while (1) { for (i = 0; i < size; i++) { if (random) @@ -1287,7 +1292,7 @@ static enum test_result test_write(struct stm32mp1_ddrctl *ctl, char *string, int argc, char *argv[]) { u32 *addr; - u32 data = 0xA5A5AA55; + u32 data; u32 loop = 0; int i, size = 1024 * 1024; bool random = false; @@ -1295,13 +1300,17 @@ static enum test_result test_write(struct stm32mp1_ddrctl *ctl, if (get_addr(string, argc, argv, 0, (u32 *)&addr)) return TEST_ERROR;
+ if (get_pattern(string, argc, argv, 1, &data, 0xA5A5AA55)) + return TEST_ERROR; + if ((u32)addr == ADDR_INVALID) { - printf("random "); + printf("running random\n"); random = true; + } else { + printf("running at 0x%08x with pattern 0x%08x\n", + (u32)addr, data); }
- printf("running at 0x%08x\n", (u32)addr); - while (1) { for (i = 0; i < size; i++) { if (random) { @@ -1435,10 +1444,10 @@ const struct test_desc test[] = { 3 }, /* need to the the 2 last one (infinite) : skipped for test all */ - {test_read, "infinite read", "[addr]", - "basic test : infinite read access", 1}, - {test_write, "infinite write", "[addr]", - "basic test : infinite write access", 1}, + {test_read, "infinite read", "[addr] [pattern]", + "basic test : infinite read access (random: addr=0xFFFFFFFF)", 2}, + {test_write, "infinite write", "[addr] [pattern]", + "basic test : infinite write access (random: addr=0xFFFFFFFF)", 2}, };
const int test_nb = ARRAY_SIZE(test);
Don't compile psci for SPL build.
arch/arm/mach-stm32mp/Makefile | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index 7745060..299f9a7 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -15,7 +15,8 @@ obj-$(CONFIG_CMD_STM32KEY) += cmd_stm32key.o ifndef CONFIG_STM32MP1_TRUSTED obj-$(CONFIG_SYSRESET) += cmd_poweroff.o endif -endif obj-$(CONFIG_ARMV7_PSCI) += psci.o +endif + obj-$(CONFIG_$(SPL_)DM_REGULATOR) += pwr_regulator.o obj-$(CONFIG_OF_SYSTEM_SETUP) += fdt.o
Remove many debug trace.
drivers/clk/clk_stm32mp1.c | 21 ++++----------------- 1 file changed, 4 insertions(+), 17 deletions(-)
diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index 5806d48..359c2b9 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -759,9 +759,6 @@ static ulong stm32mp1_clk_get_fixed(struct stm32mp1_clk_priv *priv, int idx) return 0; }
- debug("%s: clk id %d = %x : %ld kHz\n", __func__, idx, - (u32)priv->osc[idx], priv->osc[idx] / 1000); - return priv->osc[idx]; }
@@ -863,8 +860,6 @@ static ulong pll_get_fref_ck(struct stm32mp1_clk_priv *priv, src = selr & RCC_SELR_SRC_MASK;
refclk = stm32mp1_clk_get_fixed(priv, pll[pll_id].refclk[src]); - debug("PLL%d : selr=%x refclk = %d kHz\n", - pll_id, selr, (u32)(refclk / 1000));
return refclk; } @@ -889,9 +884,6 @@ static ulong pll_get_fvco(struct stm32mp1_clk_priv *priv, divm = (cfgr1 & (RCC_PLLNCFGR1_DIVM_MASK)) >> RCC_PLLNCFGR1_DIVM_SHIFT; divn = cfgr1 & RCC_PLLNCFGR1_DIVN_MASK;
- debug("PLL%d : cfgr1=%x fracr=%x DIVN=%d DIVM=%d\n", - pll_id, cfgr1, fracr, divn, divm); - refclk = pll_get_fref_ck(priv, pll_id);
/* with FRACV : @@ -908,7 +900,6 @@ static ulong pll_get_fvco(struct stm32mp1_clk_priv *priv, } else { fvco = (ulong)(refclk * (divn + 1) / (divm + 1)); } - debug("PLL%d : %s = %ld\n", pll_id, __func__, fvco);
return fvco; } @@ -921,17 +912,13 @@ static ulong stm32mp1_read_pll_freq(struct stm32mp1_clk_priv *priv, ulong dfout; u32 cfgr2;
- debug("%s(%d, %d)\n", __func__, pll_id, div_id); if (div_id >= _DIV_NB) return 0;
cfgr2 = readl(priv->base + pll[pll_id].pllxcfgr2); divy = (cfgr2 >> RCC_PLLNCFGR2_SHIFT(div_id)) & RCC_PLLNCFGR2_DIVX_MASK;
- debug("PLL%d : cfgr2=%x DIVY=%d\n", pll_id, cfgr2, divy); - dfout = pll_get_fvco(priv, pll_id) / (divy + 1); - debug(" => dfout = %d kHz\n", (u32)(dfout / 1000));
return dfout; } @@ -1574,9 +1561,6 @@ static void stgen_config(struct stm32mp1_clk_priv *priv)
/* need to update gd->arch.timer_rate_hz with new frequency */ timer_init(); - pr_debug("gd->arch.timer_rate_hz = %x\n", - (u32)gd->arch.timer_rate_hz); - pr_debug("Tick = %x\n", (u32)(get_ticks())); } }
@@ -1882,7 +1866,6 @@ static int pll_set_output_rate(struct udevice *dev, if (div > 128) div = 128;
- debug("fvco = %ld, clk_rate = %ld, div=%d\n", fvco, clk_rate, div); /* stop the requested output */ clrbits_le32(pllxcr, 0x1 << div_id << RCC_PLLNCR_DIVEN_SHIFT); /* change divider */ @@ -1915,6 +1898,9 @@ static ulong stm32mp1_clk_set_rate(struct clk *clk, unsigned long clk_rate) }
p = stm32mp1_clk_get_parent(priv, clk->id); +#ifdef DEBUG + debug("%s: parent = %d:%s\n", __func__, p, stm32mp1_clk_parent_name[p]); +#endif if (p < 0) return -EINVAL;
@@ -1932,6 +1918,7 @@ static ulong stm32mp1_clk_set_rate(struct clk *clk, unsigned long clk_rate) return result; } #endif + case _PLL4_Q: /* for LTDC_PX and DSI_PX case */ return pll_set_output_rate(clk->dev, _PLL4, _DIV_Q, clk_rate);
Use existing gd structure to store frequency information which can be used in drivers or arch without new request.
drivers/clk/clk_stm32mp1.c | 16 +++++++++------- 1 file changed, 9 insertions(+), 7 deletions(-)
diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index 359c2b9..e87307f 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -15,6 +15,8 @@ #include <dt-bindings/clock/stm32mp1-clks.h> #include <dt-bindings/clock/stm32mp1-clksrc.h>
+DECLARE_GLOBAL_DATA_PTR; + #ifndef CONFIG_STM32MP1_TRUSTED #if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) /* activate clock tree initialization in the driver */ @@ -2042,22 +2044,22 @@ static int stm32mp1_clk_probe(struct udevice *dev) stm32mp1_clk_dump(priv); #endif
+ gd->cpu_clk = stm32mp1_clk_get(priv, _CK_MPU); + gd->bus_clk = stm32mp1_clk_get(priv, _ACLK); + /* DDRPHYC father */ + gd->mem_clk = stm32mp1_clk_get(priv, _PLL2_R); #if defined(CONFIG_DISPLAY_CPUINFO) if (gd->flags & GD_FLG_RELOC) { char buf[32];
printf("Clocks:\n"); - printf("- MPU : %s MHz\n", - strmhz(buf, stm32mp1_clk_get(priv, _CK_MPU))); + printf("- MPU : %s MHz\n", strmhz(buf, gd->cpu_clk)); printf("- MCU : %s MHz\n", strmhz(buf, stm32mp1_clk_get(priv, _CK_MCU))); - printf("- AXI : %s MHz\n", - strmhz(buf, stm32mp1_clk_get(priv, _ACLK))); + printf("- AXI : %s MHz\n", strmhz(buf, gd->bus_clk)); printf("- PER : %s MHz\n", strmhz(buf, stm32mp1_clk_get(priv, _CK_PER))); - /* DDRPHYC father */ - printf("- DDR : %s MHz\n", - strmhz(buf, stm32mp1_clk_get(priv, _PLL2_R))); + printf("- DDR : %s MHz\n", strmhz(buf, gd->mem_clk)); } #endif /* CONFIG_DISPLAY_CPUINFO */ #endif
Add the missing driver and files for mach-stm32mp / stm32mp1 product.
MAINTAINERS | 19 +++++++++++++++++-- board/st/stm32mp1/MAINTAINERS | 5 +++-- 2 files changed, 20 insertions(+), 4 deletions(-)
diff --git a/MAINTAINERS b/MAINTAINERS index c28251e..8e2a999 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -298,14 +298,19 @@ ARM STM STM32MP M: Patrick Delaunay patrick.delaunay@st.com M: Patrice Chotard patrice.chotard@st.com L: uboot-stm32@st-md-mailman.stormreply.com (moderated for non-subscribers) -T: git https://gitlab.denx.de/u-boot/custodians/u-boot-stm +T: git https://gitlab.denx.de/u-boot/custodians/u-boot-stm.git S: Maintained F: arch/arm/mach-stm32mp/ +F: drivers/adc/stm32-adc* F: drivers/clk/clk_stm32mp1.c +F: drivers/gpio/stm32_gpio.c +F: drivers/hwspinlock/stm32_hwspinlock.c F: drivers/i2c/stm32f7_i2c.c F: drivers/mailbox/stm32-ipcc.c F: drivers/misc/stm32mp_fuse.c +F: drivers/misc/stm32_rcc.c F: drivers/mmc/stm32_sdmmc2.c +F: drivers/mtd/nand/raw/stm32_fmc2_nand.c F: drivers/phy/phy-stm32-usbphyc.c F: drivers/pinctrl/pinctrl_stm32.c F: drivers/power/pmic/stpmic1.c @@ -313,11 +318,21 @@ F: drivers/power/regulator/stm32-vrefbuf.c F: drivers/power/regulator/stpmic1.c F: drivers/ram/stm32mp1/ F: drivers/remoteproc/stm32_copro.c -F: drivers/misc/stm32_rcc.c F: drivers/reset/stm32-reset.c +F: drivers/rtc/stm32_rtc.c +F: drivers/serial/serial_stm32.* F: drivers/spi/stm32_qspi.c F: drivers/spi/stm32_spi.c +F: drivers/video/stm32/stm32_ltdc.c F: drivers/watchdog/stm32mp_wdt.c +F: include/dt-bindings/clock/stm32fx-clock.h +F: include/dt-bindings/clock/stm32mp1-clks.h +F: include/dt-bindings/clock/stm32mp1-clksrc.h +F: include/dt-bindings/pinctrl/stm32-pinfunc.h +F: include/dt-bindings/reset/stm32mp1-resets.h +F: include/stm32_rcc.h +F: tools/stm32image.c +
ARM STM STV0991 M: Vikas Manocha vikas.manocha@st.com diff --git a/board/st/stm32mp1/MAINTAINERS b/board/st/stm32mp1/MAINTAINERS index 3bf4c21..2930947 100644 --- a/board/st/stm32mp1/MAINTAINERS +++ b/board/st/stm32mp1/MAINTAINERS @@ -1,9 +1,10 @@ STM32MP1 BOARD M: Patrick Delaunay patrick.delaunay@st.com L: uboot-stm32@st-md-mailman.stormreply.com (moderated for non-subscribers) +T: git https://gitlab.denx.de/u-boot/custodians/u-boot-stm.git S: Maintained -F: arch/arm/dts/stm32mp157* -F: board/st/stm32mp1 +F: arch/arm/dts/stm32mp15* +F: board/st/stm32mp1/ F: configs/stm32mp15_basic_defconfig F: configs/stm32mp15_optee_defconfig F: configs/stm32mp15_trusted_defconfig
Patrick Delaunay
