[U-Boot] [PATCH v1 0/2] Replace serial setparity by setconfig
This series : _ replace setparity ops by more complete setconfig in serial uclass _ replace setparity by setconfig in STM32 serial driver
Patrice Chotard (1): serial: stm32: Replace setparity by setconfig
Patrick Delaunay (1): dm: serial: Replace setparity by setconfig
drivers/serial/serial-uclass.c | 14 ++++++++++++++ drivers/serial/serial_stm32.c | 21 +++++++++++++++------ include/serial.h | 42 +++++++++++++++++++++++++++++++++++++++--- 3 files changed, 68 insertions(+), 9 deletions(-)
Replace setparity by more generic setconfig ops to allow uart parity, bits word length and stop bits number change.
Adds SERIAL_GET_PARITY/BITS/STOP macros.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
drivers/serial/serial-uclass.c | 14 ++++++++++++++ include/serial.h | 42 +++++++++++++++++++++++++++++++++++++++--- 2 files changed, 53 insertions(+), 3 deletions(-)
diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index 321d23ee93bf..9f523751ce17 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -287,6 +287,18 @@ void serial_setbrg(void) ops->setbrg(gd->cur_serial_dev, gd->baudrate); }
+void serial_setconfig(u8 config) +{ + struct dm_serial_ops *ops; + + if (!gd->cur_serial_dev) + return; + + ops = serial_get_ops(gd->cur_serial_dev); + if (ops->setconfig) + ops->setconfig(gd->cur_serial_dev, config); +} + void serial_stdio_init(void) { } @@ -398,6 +410,8 @@ static int serial_post_probe(struct udevice *dev) ops->pending += gd->reloc_off; if (ops->clear) ops->clear += gd->reloc_off; + if (ops->setconfig) + ops->setconfig += gd->reloc_off; #if CONFIG_POST & CONFIG_SYS_POST_UART if (ops->loop) ops->loop += gd->reloc_off diff --git a/include/serial.h b/include/serial.h index b9ef6d91c9c5..61c1362e9e32 100644 --- a/include/serial.h +++ b/include/serial.h @@ -73,6 +73,39 @@ enum serial_par { SERIAL_PAR_EVEN };
+#define SERIAL_PAR_MASK 0x03 +#define SERIAL_PAR_SHIFT 0 +#define SERIAL_GET_PARITY(config) \ + ((config & SERIAL_PAR_MASK) >> SERIAL_PAR_SHIFT) + +enum serial_bits { + SERIAL_5_BITS, + SERIAL_6_BITS, + SERIAL_7_BITS, + SERIAL_8_BITS +}; + +#define SERIAL_BITS_MASK 0x0C +#define SERIAL_BITS_SHIFT 2 +#define SERIAL_GET_BITS(config) \ + ((config & SERIAL_BITS_MASK) >> SERIAL_BITS_SHIFT) + +enum serial_stop { + SERIAL_HALF_STOP, /* 0.5 stop bit */ + SERIAL_ONE_STOP, /* 1 stop bit */ + SERIAL_ONE_HALF_STOP, /* 1.5 stop bit */ + SERIAL_TWO_STOP /* 2 stop bit */ +}; + +#define SERIAL_STOP_MASK 0x30 +#define SERIAL_STOP_SHIFT 4 +#define SERIAL_GET_STOP(config) \ + ((config & SERIAL_STOP_MASK) >> SERIAL_STOP_SHIFT) + +#define SERIAL_DEFAULT_CONFIG SERIAL_PAR_NONE << SERIAL_PAR_SHIFT | \ + SERIAL_8_BITS << SERIAL_BITS_SHIFT | \ + SERIAL_ONE_STOP << SERIAL_STOP_SHIFT + /** * struct struct dm_serial_ops - Driver model serial operations * @@ -150,15 +183,18 @@ struct dm_serial_ops { int (*loop)(struct udevice *dev, int on); #endif /** - * setparity() - Set up the parity + * setconfig() - Set up the uart configuration + * (parity, 5/6/7/8 bits word length, stop bits) * - * Set up a new parity for this device. + * Set up a new config for this device. * * @dev: Device pointer * @parity: parity to use + * @bits: bits number to use + * @stop: stop bits number to use * @return 0 if OK, -ve on error */ - int (*setparity)(struct udevice *dev, enum serial_par parity); + int (*setconfig)(struct udevice *dev, u8 serial_config); };
Hi Patrice,
return;
if (ops->setconfig)
if (ops->setconfig)
+enum serial_bits {
SERIAL_5_BITS,
SERIAL_6_BITS,
SERIAL_7_BITS,
SERIAL_8_BITS
For consistency:
#define SERIAL_BITS_SHIFT 2 #define SERIAL_BITS_MASK (0x3 << SERIAL_BITS_SHIFT)
+enum serial_stop {
same here
- struct struct dm_serial_ops - Driver model serial operations
Please make this uint instead of u8. There is no point in using u8 since the compiler will use a register anyway. It can only make code size worse, if the compile add masking, etc.
1.9.1
Also you need a serial_setconfig() function call in the uclass so people can call it.
Perhaps that could have separate parameters for each setting, so that the caller does not have to make up a mask? I'm not sure if that is better or not.
Also we need to call this from sandbox code for testing purposes,
Hi Simon
On 07/31/2018 01:52 PM, Simon Glass wrote:
Hi Patrice,
return;
if (ops->setconfig)
- void serial_stdio_init(void) { }
if (ops->setconfig)
#if CONFIG_POST & CONFIG_SYS_POST_UART if (ops->loop) ops->loop += gd->reloc_offops->setconfig += gd->reloc_off;
+enum serial_bits {
SERIAL_5_BITS,
SERIAL_6_BITS,
SERIAL_7_BITS,
SERIAL_8_BITS
For consistency:
Ok
+enum serial_stop {
same here
ok
ok
1.9.1
I already add serial_setconfig() function call in serial-uclass at the beginning of this patch ;-)
Don't know what is better, currently only STM32 platforms will use it, internally we already use this API.
Ok i will add a test for this.
Thanks
Patrice
Hi Patrice,
On 31 July 2018 at 07:53, Patrice CHOTARD patrice.chotard@st.com wrote:
Hi Simon
Hi Patrice,
return;
if (ops->setconfig)
if (ops->setconfig)
+enum serial_bits {
SERIAL_5_BITS,
SERIAL_6_BITS,
SERIAL_7_BITS,
SERIAL_8_BITS
For consistency:
Ok
+enum serial_stop {
same here
ok
ok
1.9.1
OK good. Please change u8 there too :-)
OK well I think what you have will work. We can separate out the parameters later if we see a need.
Replace stm32_serial_setparity by stm32_serial_setconfig which allows to set serial bits number, parity and stop bits number. Only parity setting is implemented.
drivers/serial/serial_stm32.c | 21 +++++++++++++++------ 1 file changed, 15 insertions(+), 6 deletions(-)
diff --git a/drivers/serial/serial_stm32.c b/drivers/serial/serial_stm32.c index f26234549c3e..e6d383601c6c 100644 --- a/drivers/serial/serial_stm32.c +++ b/drivers/serial/serial_stm32.c @@ -47,20 +47,28 @@ static int stm32_serial_setbrg(struct udevice *dev, int baudrate) return 0; }
-static int stm32_serial_setparity(struct udevice *dev, enum serial_par parity) +static int stm32_serial_setconfig(struct udevice *dev, u8 serial_config) { struct stm32x7_serial_platdata *plat = dev_get_platdata(dev); bool stm32f4 = plat->uart_info->stm32f4; u8 uart_enable_bit = plat->uart_info->uart_enable_bit; u32 cr1 = plat->base + CR1_OFFSET(stm32f4); u32 config = 0; - - if (stm32f4) - return -EINVAL; /* not supported in driver*/ + u8 parity = SERIAL_GET_PARITY(serial_config); + u8 bits = SERIAL_GET_BITS(serial_config); + u8 stop = SERIAL_GET_STOP(serial_config); + + /* + * only parity config is implemented, check if other serial settings + * are the default one. + * (STM32F4 serial IP didn't support parity setting) + */ + if (bits != SERIAL_8_BITS || stop != SERIAL_ONE_STOP || stm32f4) + return -ENOTSUPP; /* not supported in driver*/
clrbits_le32(cr1, USART_CR1_RE | USART_CR1_TE | BIT(uart_enable_bit)); /* update usart configuration (uart need to be disable) - * PCE: parity check control + * PCE: parity check enable * PS : '0' : Even / '1' : Odd * M[1:0] = '00' : 8 Data bits * M[1:0] = '01' : 9 Data bits with parity @@ -77,6 +85,7 @@ static int stm32_serial_setparity(struct udevice *dev, enum serial_par parity) config = USART_CR1_PCE | USART_CR1_M0; break; } + clrsetbits_le32(cr1, USART_CR1_PCE | USART_CR1_PS | USART_CR1_M1 | USART_CR1_M0, @@ -210,7 +219,7 @@ static const struct dm_serial_ops stm32_serial_ops = { .pending = stm32_serial_pending, .getc = stm32_serial_getc, .setbrg = stm32_serial_setbrg, - .setparity = stm32_serial_setparity + .setconfig = stm32_serial_setconfig };
U_BOOT_DRIVER(serial_stm32) = {
Hi Patrice,
Looks OK, apart from changes requested in the first patch.
Patrice CHOTARD
Patrice Chotard
