[U-Boot] [PATCH v2 1/3] tpm: Add casts for proper compilation
When building for the Sandbox version, the casts in this change are necessary to avoid compilation issues.
Signed-off-by: Taylor Hutt thutt@chromium.org Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes in v2: None
drivers/tpm/generic_lpc_tpm.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/tpm/generic_lpc_tpm.c b/drivers/tpm/generic_lpc_tpm.c index 6c494eb..04ad418 100644 --- a/drivers/tpm/generic_lpc_tpm.c +++ b/drivers/tpm/generic_lpc_tpm.c @@ -135,7 +135,7 @@ static u8 tpm_read_byte(const u8 *ptr) { u8 ret = readb(ptr); debug(PREFIX "Read reg 0x%4.4x returns 0x%2.2x\n", - (u32)ptr - (u32)lpc_tpm_dev, ret); + (u32)(uintptr_t)ptr - (u32)(uintptr_t)lpc_tpm_dev, ret); return ret; }
@@ -143,21 +143,21 @@ static u32 tpm_read_word(const u32 *ptr) { u32 ret = readl(ptr); debug(PREFIX "Read reg 0x%4.4x returns 0x%8.8x\n", - (u32)ptr - (u32)lpc_tpm_dev, ret); + (u32)(uintptr_t)ptr - (u32)(uintptr_t)lpc_tpm_dev, ret); return ret; }
static void tpm_write_byte(u8 value, u8 *ptr) { debug(PREFIX "Write reg 0x%4.4x with 0x%2.2x\n", - (u32)ptr - (u32)lpc_tpm_dev, value); + (u32)(uintptr_t)ptr - (u32)(uintptr_t)lpc_tpm_dev, value); writeb(value, ptr); }
static void tpm_write_word(u32 value, u32 *ptr) { debug(PREFIX "Write reg 0x%4.4x with 0x%8.8x\n", - (u32)ptr - (u32)lpc_tpm_dev, value); + (u32)(uintptr_t)ptr - (u32)(uintptr_t)lpc_tpm_dev, value); writel(value, ptr); }
@@ -491,5 +491,5 @@ int tis_sendrecv(const u8 *sendbuf, size_t send_size, return TPM_DRIVER_ERR; }
- return tis_readresponse(recvbuf, recv_len); + return tis_readresponse(recvbuf, (u32 *)recv_len); }
Add a driver for the I2C TPM from Infineon.
Signed-off-by: Che-Liang Chiou clchiou@chromium.org Signed-off-by: Rong Chang rongchang@chromium.org Signed-off-by: Tom Wai-Hong Tam waihong@chromium.org Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Tidy up new checkpatch warnings - Use udelay() instead of usleep() - Use new form of i2c_get_bus_num_fdt()
Makefile | 2 +- drivers/tpm/Makefile | 4 + drivers/tpm/slb9635_i2c/compatibility.h | 51 +++ drivers/tpm/slb9635_i2c/tpm.c | 453 ++++++++++++++++++++++++++ drivers/tpm/slb9635_i2c/tpm.h | 161 +++++++++ drivers/tpm/slb9635_i2c/tpm_tis_i2c.c | 561 ++++++++++++++++++++++++++++++++ drivers/tpm/tis_i2c.c | 181 +++++++++++ include/fdtdec.h | 1 + lib/fdtdec.c | 1 + 9 files changed, 1414 insertions(+), 1 deletion(-) create mode 100644 drivers/tpm/slb9635_i2c/compatibility.h create mode 100644 drivers/tpm/slb9635_i2c/tpm.c create mode 100644 drivers/tpm/slb9635_i2c/tpm.h create mode 100644 drivers/tpm/slb9635_i2c/tpm_tis_i2c.c create mode 100644 drivers/tpm/tis_i2c.c
diff --git a/Makefile b/Makefile index db7561c..6547bc0 100644 --- a/Makefile +++ b/Makefile @@ -314,7 +314,7 @@ endif LIBS-y += drivers/rtc/librtc.o LIBS-y += drivers/serial/libserial.o LIBS-y += drivers/sound/libsound.o -LIBS-$(CONFIG_GENERIC_LPC_TPM) += drivers/tpm/libtpm.o +LIBS-y += drivers/tpm/libtpm.o LIBS-y += drivers/twserial/libtws.o LIBS-y += drivers/usb/eth/libusb_eth.o LIBS-y += drivers/usb/gadget/libusb_gadget.o diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index be11c8b..e8c159c 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -23,7 +23,11 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libtpm.o
+$(shell mkdir -p $(obj)slb9635_i2c) + COBJS-$(CONFIG_GENERIC_LPC_TPM) = generic_lpc_tpm.o +COBJS-$(CONFIG_INFINEON_TPM_I2C) += tis_i2c.o slb9635_i2c/tpm.o +COBJS-$(CONFIG_INFINEON_TPM_I2C) += slb9635_i2c/tpm_tis_i2c.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/tpm/slb9635_i2c/compatibility.h b/drivers/tpm/slb9635_i2c/compatibility.h new file mode 100644 index 0000000..62dc9fa --- /dev/null +++ b/drivers/tpm/slb9635_i2c/compatibility.h @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2011 Infineon Technologies + * + * Authors: + * Peter Huewe huewe.external@infineon.com + * + * Version: 2.1.1 + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _COMPATIBILITY_H_ +#define _COMPATIBILITY_H_ + +/* all includes from U-Boot */ +#include <linux/types.h> +#include <linux/unaligned/be_byteshift.h> +#include <asm-generic/errno.h> +#include <compiler.h> +#include <common.h> + +/* extended error numbers from linux (see errno.h) */ +#define ECANCELED 125 /* Operation Canceled */ + +#define msleep(t) udelay((t)*1000) + +/* Timer frequency. Corresponds to msec timer resolution*/ +#define HZ 1000 + +#define dev_dbg(dev, format, arg...) debug(format, ##arg) +#define dev_err(dev, format, arg...) printf(format, ##arg) +#define dev_info(dev, format, arg...) debug(format, ##arg) +#define dbg_printf debug + +#endif diff --git a/drivers/tpm/slb9635_i2c/tpm.c b/drivers/tpm/slb9635_i2c/tpm.c new file mode 100644 index 0000000..496c48e --- /dev/null +++ b/drivers/tpm/slb9635_i2c/tpm.c @@ -0,0 +1,453 @@ +/* + * Copyright (C) 2011 Infineon Technologies + * + * Authors: + * Peter Huewe huewe.external@infineon.com + * + * Description: + * Device driver for TCG/TCPA TPM (trusted platform module). + * Specifications at www.trustedcomputinggroup.org + * + * It is based on the Linux kernel driver tpm.c from Leendert van + * Dorn, Dave Safford, Reiner Sailer, and Kyleen Hall. + * + * Version: 2.1.1 + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation, version 2 of the + * License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <malloc.h> +#include "tpm.h" + +/* global structure for tpm chip data */ +struct tpm_chip g_chip; + +enum tpm_duration { + TPM_SHORT = 0, + TPM_MEDIUM = 1, + TPM_LONG = 2, + TPM_UNDEFINED, +}; + +#define TPM_MAX_ORDINAL 243 +#define TPM_MAX_PROTECTED_ORDINAL 12 +#define TPM_PROTECTED_ORDINAL_MASK 0xFF + +/* + * Array with one entry per ordinal defining the maximum amount + * of time the chip could take to return the result. The ordinal + * designation of short, medium or long is defined in a table in + * TCG Specification TPM Main Part 2 TPM Structures Section 17. The + * values of the SHORT, MEDIUM, and LONG durations are retrieved + * from the chip during initialization with a call to tpm_get_timeouts. + */ +static const u8 tpm_protected_ordinal_duration[TPM_MAX_PROTECTED_ORDINAL] = { + TPM_UNDEFINED, /* 0 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 5 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 10 */ + TPM_SHORT, +}; + +static const u8 tpm_ordinal_duration[TPM_MAX_ORDINAL] = { + TPM_UNDEFINED, /* 0 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 5 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 10 */ + TPM_SHORT, + TPM_MEDIUM, + TPM_LONG, + TPM_LONG, + TPM_MEDIUM, /* 15 */ + TPM_SHORT, + TPM_SHORT, + TPM_MEDIUM, + TPM_LONG, + TPM_SHORT, /* 20 */ + TPM_SHORT, + TPM_MEDIUM, + TPM_MEDIUM, + TPM_MEDIUM, + TPM_SHORT, /* 25 */ + TPM_SHORT, + TPM_MEDIUM, + TPM_SHORT, + TPM_SHORT, + TPM_MEDIUM, /* 30 */ + TPM_LONG, + TPM_MEDIUM, + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, /* 35 */ + TPM_MEDIUM, + TPM_MEDIUM, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_MEDIUM, /* 40 */ + TPM_LONG, + TPM_MEDIUM, + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, /* 45 */ + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, + TPM_LONG, + TPM_MEDIUM, /* 50 */ + TPM_MEDIUM, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 55 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_MEDIUM, /* 60 */ + TPM_MEDIUM, + TPM_MEDIUM, + TPM_SHORT, + TPM_SHORT, + TPM_MEDIUM, /* 65 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 70 */ + TPM_SHORT, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 75 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_LONG, /* 80 */ + TPM_UNDEFINED, + TPM_MEDIUM, + TPM_LONG, + TPM_SHORT, + TPM_UNDEFINED, /* 85 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 90 */ + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, + TPM_UNDEFINED, /* 95 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_MEDIUM, /* 100 */ + TPM_SHORT, + TPM_SHORT, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 105 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 110 */ + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, /* 115 */ + TPM_SHORT, + TPM_SHORT, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_LONG, /* 120 */ + TPM_LONG, + TPM_MEDIUM, + TPM_UNDEFINED, + TPM_SHORT, + TPM_SHORT, /* 125 */ + TPM_SHORT, + TPM_LONG, + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, /* 130 */ + TPM_MEDIUM, + TPM_UNDEFINED, + TPM_SHORT, + TPM_MEDIUM, + TPM_UNDEFINED, /* 135 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 140 */ + TPM_SHORT, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 145 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 150 */ + TPM_MEDIUM, + TPM_MEDIUM, + TPM_SHORT, + TPM_SHORT, + TPM_UNDEFINED, /* 155 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 160 */ + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 165 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_LONG, /* 170 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 175 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_MEDIUM, /* 180 */ + TPM_SHORT, + TPM_MEDIUM, + TPM_MEDIUM, + TPM_MEDIUM, + TPM_MEDIUM, /* 185 */ + TPM_SHORT, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 190 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 195 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 200 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, + TPM_SHORT, /* 205 */ + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, + TPM_MEDIUM, /* 210 */ + TPM_UNDEFINED, + TPM_MEDIUM, + TPM_MEDIUM, + TPM_MEDIUM, + TPM_UNDEFINED, /* 215 */ + TPM_MEDIUM, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, + TPM_SHORT, /* 220 */ + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, + TPM_SHORT, + TPM_UNDEFINED, /* 225 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 230 */ + TPM_LONG, + TPM_MEDIUM, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, /* 235 */ + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_UNDEFINED, + TPM_SHORT, /* 240 */ + TPM_UNDEFINED, + TPM_MEDIUM, +}; + +/* + * Returns max number of milliseconds to wait + */ +unsigned long tpm_calc_ordinal_duration(struct tpm_chip *chip, u32 ordinal) +{ + int duration_idx = TPM_UNDEFINED; + int duration = 0; + + if (ordinal < TPM_MAX_ORDINAL) + duration_idx = tpm_ordinal_duration[ordinal]; + else if ((ordinal & TPM_PROTECTED_ORDINAL_MASK) < + TPM_MAX_PROTECTED_ORDINAL) + duration_idx = + tpm_protected_ordinal_duration[ordinal & + TPM_PROTECTED_ORDINAL_MASK]; + + if (duration_idx != TPM_UNDEFINED) + duration = chip->vendor.duration[duration_idx]; + if (duration <= 0) + return 2 * 60 * HZ; /*two minutes timeout*/ + else + return duration; +} + +#define TPM_CMD_COUNT_BYTE 2 +#define TPM_CMD_ORDINAL_BYTE 6 + +ssize_t tpm_transmit(const unsigned char *buf, size_t bufsiz) +{ + ssize_t rc; + u32 count, ordinal; + unsigned long start, stop; + + struct tpm_chip *chip = &g_chip; + + /* switch endianess: big->little */ + count = get_unaligned_be32(buf + TPM_CMD_COUNT_BYTE); + ordinal = get_unaligned_be32(buf + TPM_CMD_ORDINAL_BYTE); + + if (count == 0) { + dev_err(chip->dev, "no data\n"); + return -ENODATA; + } + if (count > bufsiz) { + dev_err(chip->dev, + "invalid count value %x %zx\n", count, bufsiz); + return -E2BIG; + } + + rc = chip->vendor.send(chip, (u8 *)buf, count); + if (rc < 0) { + dev_err(chip->dev, "tpm_transmit: tpm_send: error %zd\n", rc); + goto out; + } + + if (chip->vendor.irq) + goto out_recv; + + start = get_timer(0); + stop = tpm_calc_ordinal_duration(chip, ordinal); + do { + dbg_printf("waiting for status...\n"); + u8 status = chip->vendor.status(chip); + if ((status & chip->vendor.req_complete_mask) == + chip->vendor.req_complete_val) { + dbg_printf("...got it;\n"); + goto out_recv; + } + + if ((status == chip->vendor.req_canceled)) { + dev_err(chip->dev, "Operation Canceled\n"); + rc = -ECANCELED; + goto out; + } + msleep(TPM_TIMEOUT); + } while (get_timer(start) < stop); + + chip->vendor.cancel(chip); + dev_err(chip->dev, "Operation Timed out\n"); + rc = -ETIME; + goto out; + +out_recv: + + dbg_printf("out_recv: reading response...\n"); + rc = chip->vendor.recv(chip, (u8 *)buf, TPM_BUFSIZE); + if (rc < 0) + dev_err(chip->dev, "tpm_transmit: tpm_recv: error %zd\n", rc); +out: + return rc; +} + +#define TPM_ERROR_SIZE 10 + +enum tpm_capabilities { + TPM_CAP_PROP = cpu_to_be32(5), +}; + +enum tpm_sub_capabilities { + TPM_CAP_PROP_TIS_TIMEOUT = cpu_to_be32(0x115), + TPM_CAP_PROP_TIS_DURATION = cpu_to_be32(0x120), +}; + +struct tpm_chip *tpm_register_hardware(const struct tpm_vendor_specific *entry) +{ + struct tpm_chip *chip; + + /* Driver specific per-device data */ + chip = &g_chip; + memcpy(&chip->vendor, entry, sizeof(struct tpm_vendor_specific)); + chip->is_open = 1; + + return chip; +} + +int tpm_open(uint32_t dev_addr) +{ + int rc; + if (g_chip.is_open) + return -EBUSY; + rc = tpm_vendor_init(dev_addr); + if (rc < 0) + g_chip.is_open = 0; + return rc; +} + +void tpm_close(void) +{ + if (g_chip.is_open) { + tpm_vendor_cleanup(&g_chip); + g_chip.is_open = 0; + } +} diff --git a/drivers/tpm/slb9635_i2c/tpm.h b/drivers/tpm/slb9635_i2c/tpm.h new file mode 100644 index 0000000..9ddee86 --- /dev/null +++ b/drivers/tpm/slb9635_i2c/tpm.h @@ -0,0 +1,161 @@ +/* + * Copyright (C) 2011 Infineon Technologies + * + * Authors: + * Peter Huewe huewe.external@infineon.com + * + * Version: 2.1.1 + * + * Description: + * Device driver for TCG/TCPA TPM (trusted platform module). + * Specifications at www.trustedcomputinggroup.org + * + * It is based on the Linux kernel driver tpm.c from Leendert van + * Dorn, Dave Safford, Reiner Sailer, and Kyleen Hall. + * + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation, version 2 of the + * License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef _TPM_H_ +#define _TPM_H_ + +#include <linux/compiler.h> + +#include "compatibility.h" + +enum tpm_timeout { + TPM_TIMEOUT = 5, /* msecs */ +}; + +/* Size of external transmit buffer (used in tpm_transmit)*/ +#define TPM_BUFSIZE 4096 + +/* Index of fields in TPM command buffer */ +#define TPM_CMD_SIZE_BYTE 2 +#define TPM_CMD_ORDINAL_BYTE 6 + +/* Index of Count field in TPM response buffer */ +#define TPM_RSP_SIZE_BYTE 2 +#define TPM_RSP_RC_BYTE 6 + +struct tpm_chip; + +struct tpm_vendor_specific { + const u8 req_complete_mask; + const u8 req_complete_val; + const u8 req_canceled; + int irq; + int (*recv) (struct tpm_chip *, u8 *, size_t); + int (*send) (struct tpm_chip *, u8 *, size_t); + void (*cancel) (struct tpm_chip *); + u8(*status) (struct tpm_chip *); + int locality; + unsigned long timeout_a, timeout_b, timeout_c, timeout_d; /* msec */ + unsigned long duration[3]; /* msec */ +}; + +struct tpm_chip { + int is_open; + struct tpm_vendor_specific vendor; +}; + +struct tpm_input_header { + __be16 tag; + __be32 length; + __be32 ordinal; +} __packed; + +struct tpm_output_header { + __be16 tag; + __be32 length; + __be32 return_code; +} __packed; + +struct timeout_t { + __be32 a; + __be32 b; + __be32 c; + __be32 d; +} __packed; + +struct duration_t { + __be32 tpm_short; + __be32 tpm_medium; + __be32 tpm_long; +} __packed; + +union cap_t { + struct timeout_t timeout; + struct duration_t duration; +}; + +struct tpm_getcap_params_in { + __be32 cap; + __be32 subcap_size; + __be32 subcap; +} __packed; + +struct tpm_getcap_params_out { + __be32 cap_size; + union cap_t cap; +} __packed; + +union tpm_cmd_header { + struct tpm_input_header in; + struct tpm_output_header out; +}; + +union tpm_cmd_params { + struct tpm_getcap_params_out getcap_out; + struct tpm_getcap_params_in getcap_in; +}; + +struct tpm_cmd_t { + union tpm_cmd_header header; + union tpm_cmd_params params; +} __packed; + + +/* ---------- Interface for TPM vendor ------------ */ + +extern struct tpm_chip *tpm_register_hardware( + const struct tpm_vendor_specific *); + +extern int tpm_vendor_init(uint32_t dev_addr); + +extern void tpm_vendor_cleanup(struct tpm_chip *chip); + +/* ---------- Interface for TDDL ------------------- */ + +/* + * if dev_addr != 0 - redefines TPM device address + * Returns < 0 on error, 0 on success. + */ +extern int tpm_open(uint32_t dev_addr); + +extern void tpm_close(void); + +/* + * Transmit bufsiz bytes out of buf to TPM and get results back in buf, too. + * Returns < 0 on error, 0 on success. + */ +extern ssize_t tpm_transmit(const unsigned char *buf, size_t bufsiz); + +#endif diff --git a/drivers/tpm/slb9635_i2c/tpm_tis_i2c.c b/drivers/tpm/slb9635_i2c/tpm_tis_i2c.c new file mode 100644 index 0000000..82a41bf --- /dev/null +++ b/drivers/tpm/slb9635_i2c/tpm_tis_i2c.c @@ -0,0 +1,561 @@ +/* + * Copyright (C) 2011 Infineon Technologies + * + * Authors: + * Peter Huewe huewe.external@infineon.com + * + * Description: + * Device driver for TCG/TCPA TPM (trusted platform module). + * Specifications at www.trustedcomputinggroup.org + * + * This device driver implements the TPM interface as defined in + * the TCG TPM Interface Spec version 1.2, revision 1.0 and the + * Infineon I2C Protocol Stack Specification v0.20. + * + * It is based on the Linux kernel driver tpm.c from Leendert van + * Dorn, Dave Safford, Reiner Sailer, and Kyleen Hall. + * + * Version: 2.1.1 + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation, version 2 of the + * License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <i2c.h> +#include <linux/types.h> + +#include "compatibility.h" +#include "tpm.h" + +/* max. buffer size supported by our tpm */ +#ifdef TPM_BUFSIZE +#undef TPM_BUFSIZE +#endif +#define TPM_BUFSIZE 1260 +/* Address of the TPM on the I2C bus */ +#define TPM_I2C_ADDR 0x20 +/* max. number of iterations after i2c NAK */ +#define MAX_COUNT 3 + +#define SLEEP_DURATION 60 /*in usec*/ + +/* max. number of iterations after i2c NAK for 'long' commands + * we need this especially for sending TPM_READY, since the cleanup after the + * transtion to the ready state may take some time, but it is unpredictable + * how long it will take. + */ +#define MAX_COUNT_LONG 50 + +#define SLEEP_DURATION_LONG 210 /* in usec */ + +/* expected value for DIDVID register */ +#define TPM_TIS_I2C_DID_VID 0x000b15d1L + +/* Structure to store I2C TPM specific stuff */ +struct tpm_inf_dev { + uint addr; + u8 buf[TPM_BUFSIZE + sizeof(u8)]; /* max. buffer size + addr */ +}; + +static struct tpm_inf_dev tpm_dev = { + .addr = TPM_I2C_ADDR +}; + +/* + * iic_tpm_read() - read from TPM register + * @addr: register address to read from + * @buffer: provided by caller + * @len: number of bytes to read + * + * Read len bytes from TPM register and put them into + * buffer (little-endian format, i.e. first byte is put into buffer[0]). + * + * NOTE: TPM is big-endian for multi-byte values. Multi-byte + * values have to be swapped. + * + * Return -EIO on error, 0 on success. + */ +int iic_tpm_read(u8 addr, u8 *buffer, size_t len) +{ + int rc; + int count; + uint myaddr = addr; + /* we have to use uint here, uchar hangs the board */ + + for (count = 0; count < MAX_COUNT; count++) { + rc = i2c_write(tpm_dev.addr, 0, 0, (uchar *)&myaddr, 1); + if (rc == 0) + break; /*success, break to skip sleep*/ + + udelay(SLEEP_DURATION); + } + + if (rc) + return -rc; + + /* After the TPM has successfully received the register address it needs + * some time, thus we're sleeping here again, before retrieving the data + */ + for (count = 0; count < MAX_COUNT; count++) { + udelay(SLEEP_DURATION); + rc = i2c_read(tpm_dev.addr, 0, 0, buffer, len); + if (rc == 0) + break; /*success, break to skip sleep*/ + } + + if (rc) + return -rc; + + return 0; +} + +static int iic_tpm_write_generic(u8 addr, u8 *buffer, size_t len, + unsigned int sleep_time, + u8 max_count) +{ + int rc = 0; + int count; + + /* prepare send buffer */ + tpm_dev.buf[0] = addr; + memcpy(&(tpm_dev.buf[1]), buffer, len); + + for (count = 0; count < max_count; count++) { + rc = i2c_write(tpm_dev.addr, 0, 0, tpm_dev.buf, len + 1); + if (rc == 0) + break; /*success, break to skip sleep*/ + + udelay(sleep_time); + } + + if (rc) + return -rc; + + return 0; +} + +/* + * iic_tpm_write() - write to TPM register + * @addr: register address to write to + * @buffer: containing data to be written + * @len: number of bytes to write + * + * Write len bytes from provided buffer to TPM register (little + * endian format, i.e. buffer[0] is written as first byte). + * + * NOTE: TPM is big-endian for multi-byte values. Multi-byte + * values have to be swapped. + * + * NOTE: use this function instead of the iic_tpm_write_generic function. + * + * Return -EIO on error, 0 on success + */ +static int iic_tpm_write(u8 addr, u8 *buffer, size_t len) +{ + return iic_tpm_write_generic(addr, buffer, len, SLEEP_DURATION, + MAX_COUNT); +} + +/* + * This function is needed especially for the cleanup situation after + * sending TPM_READY + * */ +static int iic_tpm_write_long(u8 addr, u8 *buffer, size_t len) +{ + return iic_tpm_write_generic(addr, buffer, len, SLEEP_DURATION_LONG, + MAX_COUNT_LONG); +} + +#define TPM_HEADER_SIZE 10 + +enum tis_access { + TPM_ACCESS_VALID = 0x80, + TPM_ACCESS_ACTIVE_LOCALITY = 0x20, + TPM_ACCESS_REQUEST_PENDING = 0x04, + TPM_ACCESS_REQUEST_USE = 0x02, +}; + +enum tis_status { + TPM_STS_VALID = 0x80, + TPM_STS_COMMAND_READY = 0x40, + TPM_STS_GO = 0x20, + TPM_STS_DATA_AVAIL = 0x10, + TPM_STS_DATA_EXPECT = 0x08, +}; + +enum tis_defaults { + TIS_SHORT_TIMEOUT = 750, /* ms */ + TIS_LONG_TIMEOUT = 2000, /* 2 sec */ +}; + +#define TPM_ACCESS(l) (0x0000 | ((l) << 4)) +#define TPM_STS(l) (0x0001 | ((l) << 4)) +#define TPM_DATA_FIFO(l) (0x0005 | ((l) << 4)) +#define TPM_DID_VID(l) (0x0006 | ((l) << 4)) + +static int check_locality(struct tpm_chip *chip, int loc) +{ + u8 buf; + int rc; + + rc = iic_tpm_read(TPM_ACCESS(loc), &buf, 1); + if (rc < 0) + return rc; + + if ((buf & (TPM_ACCESS_ACTIVE_LOCALITY | TPM_ACCESS_VALID)) == + (TPM_ACCESS_ACTIVE_LOCALITY | TPM_ACCESS_VALID)) { + chip->vendor.locality = loc; + return loc; + } + + return -1; +} + +static void release_locality(struct tpm_chip *chip, int loc, int force) +{ + u8 buf; + if (iic_tpm_read(TPM_ACCESS(loc), &buf, 1) < 0) + return; + + if (force || (buf & (TPM_ACCESS_REQUEST_PENDING | TPM_ACCESS_VALID)) == + (TPM_ACCESS_REQUEST_PENDING | TPM_ACCESS_VALID)) { + buf = TPM_ACCESS_ACTIVE_LOCALITY; + iic_tpm_write(TPM_ACCESS(loc), &buf, 1); + } +} + +static int request_locality(struct tpm_chip *chip, int loc) +{ + unsigned long start, stop; + u8 buf = TPM_ACCESS_REQUEST_USE; + + if (check_locality(chip, loc) >= 0) + return loc; /* we already have the locality */ + + iic_tpm_write(TPM_ACCESS(loc), &buf, 1); + + /* wait for burstcount */ + start = get_timer(0); + stop = chip->vendor.timeout_a; + do { + if (check_locality(chip, loc) >= 0) + return loc; + msleep(TPM_TIMEOUT); + } while (get_timer(start) < stop); + + return -1; +} + +static u8 tpm_tis_i2c_status(struct tpm_chip *chip) +{ + /* NOTE: since i2c read may fail, return 0 in this case --> time-out */ + u8 buf; + if (iic_tpm_read(TPM_STS(chip->vendor.locality), &buf, 1) < 0) + return 0; + else + return buf; +} + +static void tpm_tis_i2c_ready(struct tpm_chip *chip) +{ + /* this causes the current command to be aborted */ + u8 buf = TPM_STS_COMMAND_READY; + iic_tpm_write_long(TPM_STS(chip->vendor.locality), &buf, 1); +} + +static ssize_t get_burstcount(struct tpm_chip *chip) +{ + unsigned long start, stop; + ssize_t burstcnt; + u8 buf[3]; + + /* wait for burstcount */ + /* which timeout value, spec has 2 answers (c & d) */ + start = get_timer(0); + stop = chip->vendor.timeout_d; + do { + /* Note: STS is little endian */ + if (iic_tpm_read(TPM_STS(chip->vendor.locality) + 1, buf, 3) + < 0) + burstcnt = 0; + else + burstcnt = (buf[2] << 16) + (buf[1] << 8) + buf[0]; + + if (burstcnt) + return burstcnt; + msleep(TPM_TIMEOUT); + } while (get_timer(start) < stop); + + return -EBUSY; +} + +static int wait_for_stat(struct tpm_chip *chip, u8 mask, unsigned long timeout, + int *status) +{ + unsigned long start, stop; + + /* check current status */ + *status = tpm_tis_i2c_status(chip); + if ((*status & mask) == mask) + return 0; + + start = get_timer(0); + stop = timeout; + do { + msleep(TPM_TIMEOUT); + *status = tpm_tis_i2c_status(chip); + if ((*status & mask) == mask) + return 0; + + } while (get_timer(start) < stop); + + return -ETIME; +} + +static int recv_data(struct tpm_chip *chip, u8 *buf, size_t count) +{ + size_t size = 0; + ssize_t burstcnt; + int rc; + + while (size < count) { + burstcnt = get_burstcount(chip); + + /* burstcount < 0 = tpm is busy */ + if (burstcnt < 0) + return burstcnt; + + /* limit received data to max. left */ + if (burstcnt > (count - size)) + burstcnt = count - size; + + rc = iic_tpm_read(TPM_DATA_FIFO(chip->vendor.locality), + &(buf[size]), + burstcnt); + if (rc == 0) + size += burstcnt; + } + + return size; +} + +static int tpm_tis_i2c_recv(struct tpm_chip *chip, u8 *buf, size_t count) +{ + int size = 0; + int expected, status; + + if (count < TPM_HEADER_SIZE) { + size = -EIO; + goto out; + } + + /* read first 10 bytes, including tag, paramsize, and result */ + size = recv_data(chip, buf, TPM_HEADER_SIZE); + if (size < TPM_HEADER_SIZE) { + dev_err(chip->dev, "Unable to read header\n"); + goto out; + } + + expected = get_unaligned_be32(buf + TPM_RSP_SIZE_BYTE); + if ((size_t)expected > count) { + size = -EIO; + goto out; + } + + size += recv_data(chip, &buf[TPM_HEADER_SIZE], + expected - TPM_HEADER_SIZE); + if (size < expected) { + dev_err(chip->dev, "Unable to read remainder of result\n"); + size = -ETIME; + goto out; + } + + wait_for_stat(chip, TPM_STS_VALID, chip->vendor.timeout_c, &status); + if (status & TPM_STS_DATA_AVAIL) { /* retry? */ + dev_err(chip->dev, "Error left over data\n"); + size = -EIO; + goto out; + } + +out: + tpm_tis_i2c_ready(chip); + /* The TPM needs some time to clean up here, + * so we sleep rather than keeping the bus busy + */ + udelay(2000); + release_locality(chip, chip->vendor.locality, 0); + + return size; +} + +static int tpm_tis_i2c_send(struct tpm_chip *chip, u8 *buf, size_t len) +{ + int rc, status; + ssize_t burstcnt; + size_t count = 0; + u8 sts = TPM_STS_GO; + + if (len > TPM_BUFSIZE) + return -E2BIG; /* command is too long for our tpm, sorry */ + + if (request_locality(chip, 0) < 0) + return -EBUSY; + + status = tpm_tis_i2c_status(chip); + if ((status & TPM_STS_COMMAND_READY) == 0) { + tpm_tis_i2c_ready(chip); + if (wait_for_stat + (chip, TPM_STS_COMMAND_READY, + chip->vendor.timeout_b, &status) < 0) { + rc = -ETIME; + goto out_err; + } + } + + while (count < len - 1) { + burstcnt = get_burstcount(chip); + + /* burstcount < 0 = tpm is busy */ + if (burstcnt < 0) + return burstcnt; + + if (burstcnt > (len-1-count)) + burstcnt = len-1-count; + +#ifdef CONFIG_TPM_I2C_BURST_LIMITATION + if (burstcnt > CONFIG_TPM_I2C_BURST_LIMITATION) + burstcnt = CONFIG_TPM_I2C_BURST_LIMITATION; +#endif /* CONFIG_TPM_I2C_BURST_LIMITATION */ + + rc = iic_tpm_write(TPM_DATA_FIFO(chip->vendor.locality), + &(buf[count]), burstcnt); + if (rc == 0) + count += burstcnt; + + wait_for_stat(chip, TPM_STS_VALID, + chip->vendor.timeout_c, &status); + + if ((status & TPM_STS_DATA_EXPECT) == 0) { + rc = -EIO; + goto out_err; + } + } + + /* write last byte */ + iic_tpm_write(TPM_DATA_FIFO(chip->vendor.locality), &(buf[count]), 1); + wait_for_stat(chip, TPM_STS_VALID, chip->vendor.timeout_c, &status); + if ((status & TPM_STS_DATA_EXPECT) != 0) { + rc = -EIO; + goto out_err; + } + + /* go and do it */ + iic_tpm_write(TPM_STS(chip->vendor.locality), &sts, 1); + + return len; +out_err: + tpm_tis_i2c_ready(chip); + /* The TPM needs some time to clean up here, + * so we sleep rather than keeping the bus busy + */ + udelay(2000); + release_locality(chip, chip->vendor.locality, 0); + + return rc; +} + +static struct tpm_vendor_specific tpm_tis_i2c = { + .status = tpm_tis_i2c_status, + .recv = tpm_tis_i2c_recv, + .send = tpm_tis_i2c_send, + .cancel = tpm_tis_i2c_ready, + .req_complete_mask = TPM_STS_DATA_AVAIL | TPM_STS_VALID, + .req_complete_val = TPM_STS_DATA_AVAIL | TPM_STS_VALID, + .req_canceled = TPM_STS_COMMAND_READY, +}; + +/* initialisation of i2c tpm */ + + +int tpm_vendor_init(uint32_t dev_addr) +{ + u32 vendor; + uint old_addr; + int rc = 0; + struct tpm_chip *chip; + + old_addr = tpm_dev.addr; + if (dev_addr != 0) + tpm_dev.addr = dev_addr; + + chip = tpm_register_hardware(&tpm_tis_i2c); + if (chip < 0) { + rc = -ENODEV; + goto out_err; + } + + /* Disable interrupts (not supported) */ + chip->vendor.irq = 0; + + /* Default timeouts */ + chip->vendor.timeout_a = TIS_SHORT_TIMEOUT; + chip->vendor.timeout_b = TIS_LONG_TIMEOUT; + chip->vendor.timeout_c = TIS_SHORT_TIMEOUT; + chip->vendor.timeout_d = TIS_SHORT_TIMEOUT; + + if (request_locality(chip, 0) != 0) { + rc = -ENODEV; + goto out_err; + } + + /* read four bytes from DID_VID register */ + if (iic_tpm_read(TPM_DID_VID(0), (uchar *)&vendor, 4) < 0) { + rc = -EIO; + goto out_release; + } + + /* create DID_VID register value, after swapping to little-endian */ + vendor = be32_to_cpu(vendor); + + if (vendor != TPM_TIS_I2C_DID_VID) { + rc = -ENODEV; + goto out_release; + } + + dev_info(dev, "1.2 TPM (device-id 0x%X)\n", vendor >> 16); + + /* + * A timeout query to TPM can be placed here. + * Standard timeout values are used so far + */ + + return 0; + +out_release: + release_locality(chip, 0, 1); + +out_err: + tpm_dev.addr = old_addr; + return rc; +} + +void tpm_vendor_cleanup(struct tpm_chip *chip) +{ + release_locality(chip, chip->vendor.locality, 1); +} diff --git a/drivers/tpm/tis_i2c.c b/drivers/tpm/tis_i2c.c new file mode 100644 index 0000000..e818fba --- /dev/null +++ b/drivers/tpm/tis_i2c.c @@ -0,0 +1,181 @@ +/* + * Copyright (c) 2012 The Chromium OS Authors. All rights reserved. + * Use of this source code is governed by a BSD-style license that can be + * found in the LICENSE file. + */ + +#include <config.h> +#include <common.h> +#include <fdtdec.h> +#include <i2c.h> +#include "slb9635_i2c/tpm.h" + +DECLARE_GLOBAL_DATA_PTR; + +/* TPM configuration */ +struct tpm { + int i2c_bus; + int slave_addr; + char inited; + int old_bus; +} tpm; + + +static int tpm_select(void) +{ + int ret; + + tpm.old_bus = i2c_get_bus_num(); + if (tpm.old_bus != tpm.i2c_bus) { + ret = i2c_set_bus_num(tpm.i2c_bus); + if (ret) { + debug("%s: Fail to set i2c bus %d\n", __func__, + tpm.i2c_bus); + return -1; + } + } + return 0; +} + +static int tpm_deselect(void) +{ + int ret; + + if (tpm.old_bus != i2c_get_bus_num()) { + ret = i2c_set_bus_num(tpm.old_bus); + if (ret) { + debug("%s: Fail to restore i2c bus %d\n", + __func__, tpm.old_bus); + return -1; + } + } + tpm.old_bus = -1; + return 0; +} + +/** + * Decode TPM configuration. + * + * @param dev Returns a configuration of TPM device + * @return 0 if ok, -1 on error + */ +static int tpm_decode_config(struct tpm *dev) +{ +#ifdef CONFIG_OF_CONTROL + const void *blob = gd->fdt_blob; + int node, parent; + int i2c_bus; + + node = fdtdec_next_compatible(blob, 0, COMPAT_INFINEON_SLB9635_TPM); + if (node < 0) { + debug("%s: Node not found\n", __func__); + return -1; + } + parent = fdt_parent_offset(blob, node); + if (parent < 0) { + debug("%s: Cannot find node parent\n", __func__); + return -1; + } + i2c_bus = i2c_get_bus_num_fdt(parent); + if (i2c_bus < 0) + return -1; + dev->i2c_bus = i2c_bus; + dev->slave_addr = fdtdec_get_addr(blob, node, "reg"); +#else + dev->i2c_bus = CONFIG_INFINEON_TPM_I2C_BUS; + dev->slave_addr = CONFIG_INFINEON_TPM_I2C_ADDR; +#endif + return 0; +} + +int tis_init(void) +{ + if (tpm.inited) + return 0; + + if (tpm_decode_config(&tpm)) + return -1; + + if (tpm_select()) + return -1; + + /* + * Probe TPM twice; the first probing might fail because TPM is asleep, + * and the probing can wake up TPM. + */ + if (i2c_probe(tpm.slave_addr) && i2c_probe(tpm.slave_addr)) { + debug("%s: fail to probe i2c addr 0x%x\n", __func__, + tpm.slave_addr); + return -1; + } + + tpm_deselect(); + + tpm.inited = 1; + + return 0; +} + +int tis_open(void) +{ + int rc; + + if (!tpm.inited) + return -1; + + if (tpm_select()) + return -1; + + rc = tpm_open(tpm.slave_addr); + + tpm_deselect(); + + return rc; +} + +int tis_close(void) +{ + if (!tpm.inited) + return -1; + + if (tpm_select()) + return -1; + + tpm_close(); + + tpm_deselect(); + + return 0; +} + +int tis_sendrecv(const uint8_t *sendbuf, size_t sbuf_size, + uint8_t *recvbuf, size_t *rbuf_len) +{ + int len; + uint8_t buf[4096]; + + if (!tpm.inited) + return -1; + + if (sizeof(buf) < sbuf_size) + return -1; + + memcpy(buf, sendbuf, sbuf_size); + + if (tpm_select()) + return -1; + + len = tpm_transmit(buf, sbuf_size); + + tpm_deselect(); + + if (len < 10) { + *rbuf_len = 0; + return -1; + } + + memcpy(recvbuf, buf, len); + *rbuf_len = len; + + return 0; +} diff --git a/include/fdtdec.h b/include/fdtdec.h index e7e3ff9..39fbdf1 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -90,6 +90,7 @@ enum fdt_compat_id { COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ COMPAT_MAXIM_98095_CODEC, /* MAX98095 Codec */ + COMPAT_INFINEON_SLB9635_TPM, /* Infineon SLB9635 TPM */
COMPAT_COUNT, }; diff --git a/lib/fdtdec.c b/lib/fdtdec.c index e17dd00..e93743c 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -63,6 +63,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686_pmic"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"), COMPAT(MAXIM_98095_CODEC, "maxim,max98095-codec"), + COMPAT(INFINEON_SLB9635_TPM, "infineon,slb9635-tpm"), };
const char *fdtdec_get_compatible(enum fdt_compat_id id)
This is used on some Exynos 5250 variants.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Move CONFIG change to exynos5-dt.h
include/configs/exynos5250-dt.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/include/configs/exynos5250-dt.h b/include/configs/exynos5250-dt.h index 2b9d6ac..7378487 100644 --- a/include/configs/exynos5250-dt.h +++ b/include/configs/exynos5250-dt.h @@ -129,6 +129,13 @@ #define CONFIG_USB_EHCI_EXYNOS #define CONFIG_USB_STORAGE
+/* TPM */ +#define CONFIG_TPM +#define CONFIG_CMD_TPM +#define CONFIG_INFINEON_TPM_I2C +#define CONFIG_INFINEON_TPM_I2C_BUS 3 +#define CONFIG_INFINEON_TPM_I2C_ADDR 0x20 + /* MMC SPL */ #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030
