[U-Boot-Users] [PATCH] support nand based environment
The attached file, env_nand.c, allows storing U-Boot environment data in NAND flash. It is compiled based on CFG_ENV_IS_IN_NAND.
You need make the following changes to be able to use it: 1. nand_rw() and nand_erase() in cmd_nand.c need to be made public. 2. env_common.c needs add CFG_ENV_IS_IN_NAND for compile condition. 3. env_nand.o needs to be added to obj list
I currently use U-Boot1.02 which is not up-to-date. I guess sending this new file makes merging easier.
Regards, Jian
In message BA2832125C3C994384FCC051CDFC73690F4731@dlee2k05.ent.ti.com you wrote:
- nand_rw() and nand_erase() in cmd_nand.c need to be made public.
- env_common.c needs add CFG_ENV_IS_IN_NAND for compile condition.
- env_nand.o needs to be added to obj list
On contrary. Please play by the rules, and send a patch.
Zhang, Jian
