[PATCH 0/2] imx93-11x11-evk: Convert to OF_UPSTREAM
patch 1 is to avoid build break when using upstream dts Patch 2 is moving to OF_UPSTREAM
This is a resend of V3 imx93: Conver to OF_UPSTREAM patch 5,6
Peng Fan (2): dt-bindings: imx93: sync clock header imx: imx93-11x11-evk: convert to OF_UPSTREAM
arch/arm/dts/Makefile | 1 - arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 118 +++++++++ arch/arm/dts/imx93-11x11-evk.dts | 322 ----------------------- arch/arm/dts/imx93-u-boot.dtsi | 15 ++ arch/arm/mach-imx/imx9/Kconfig | 1 + configs/imx93_11x11_evk_defconfig | 2 +- configs/imx93_11x11_evk_ld_defconfig | 2 +- include/dt-bindings/clock/imx93-clock.h | 3 +- 8 files changed, 138 insertions(+), 326 deletions(-) delete mode 100644 arch/arm/dts/imx93-11x11-evk.dts
Sync clock header with kernel 6.8
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/dt-bindings/clock/imx93-clock.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/dt-bindings/clock/imx93-clock.h b/include/dt-bindings/clock/imx93-clock.h index 35a1f62053a..787c9e74dc9 100644 --- a/include/dt-bindings/clock/imx93-clock.h +++ b/include/dt-bindings/clock/imx93-clock.h @@ -203,6 +203,7 @@ #define IMX93_CLK_ARM_PLL 198 #define IMX93_CLK_A55_SEL 199 #define IMX93_CLK_A55_CORE 200 -#define IMX93_CLK_END 201 +#define IMX93_CLK_PDM_IPG 201 +#define IMX93_CLK_END 202
#endif
Convert to OF_UPSTREAM for i.MX93 11x11 EVK.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/Makefile | 1 - arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 118 +++++++++ arch/arm/dts/imx93-11x11-evk.dts | 322 ----------------------- arch/arm/dts/imx93-u-boot.dtsi | 15 ++ arch/arm/mach-imx/imx9/Kconfig | 1 + configs/imx93_11x11_evk_defconfig | 2 +- configs/imx93_11x11_evk_ld_defconfig | 2 +- 7 files changed, 136 insertions(+), 325 deletions(-) delete mode 100644 arch/arm/dts/imx93-11x11-evk.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index dad869726dc..5c32daaebfe 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1041,7 +1041,6 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mq-librem5-r4.dtb
dtb-$(CONFIG_ARCH_IMX9) += \ - imx93-11x11-evk.dtb \ imx93-var-som-symphony.dtb \ imx93-phyboard-segin.dtb
diff --git a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi index a99ba99bfb4..408e601bc90 100644 --- a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi +++ b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi @@ -26,6 +26,111 @@ bootph-pre-ram; };
+&lpi2c2 { + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <400000>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&pinctrl_lpi2c2>; + pinctrl-1 = <&pinctrl_lpi2c2>; + status = "okay"; + + pmic@25 { + compatible = "nxp,pca9451a"; + reg = <0x25>; + interrupt-parent = <&pcal6524>; + interrupts = <11 IRQ_TYPE_LEVEL_LOW>; + + regulators { + buck1: BUCK1 { + regulator-name = "BUCK1"; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <2237500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck2: BUCK2 { + regulator-name = "BUCK2"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <2187500>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <3125>; + }; + + buck4: BUCK4{ + regulator-name = "BUCK4"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck5: BUCK5{ + regulator-name = "BUCK5"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + buck6: BUCK6 { + regulator-name = "BUCK6"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <3400000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1: LDO1 { + regulator-name = "LDO1"; + regulator-min-microvolt = <1600000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo4: LDO4 { + regulator-name = "LDO4"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo5: LDO5 { + regulator-name = "LDO5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; + + pcal6524: gpio@22 { + compatible = "nxp,pcal6524"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcal6524>; + reg = <0x22>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupt-parent = <&gpio3>; + interrupts = <27 IRQ_TYPE_LEVEL_LOW>; + }; + + adp5585gpio: gpio@34 { + compatible = "adp5585"; + reg = <0x34>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + &aips1 { bootph-pre-ram; bootph-all; @@ -44,6 +149,19 @@ &iomuxc { bootph-pre-ram; bootph-some-ram; + + pinctrl_lpi2c2: lpi2c2grp { + fsl,pins = < + MX93_PAD_I2C2_SCL__LPI2C2_SCL 0x40000b9e + MX93_PAD_I2C2_SDA__LPI2C2_SDA 0x40000b9e + >; + }; + + pinctrl_pcal6524: pcal6524grp { + fsl,pins = < + MX93_PAD_CCM_CLKO2__GPIO3_IO27 0x31e + >; + }; };
®_usdhc2_vmmc { diff --git a/arch/arm/dts/imx93-11x11-evk.dts b/arch/arm/dts/imx93-11x11-evk.dts deleted file mode 100644 index 4322cc3e11b..00000000000 --- a/arch/arm/dts/imx93-11x11-evk.dts +++ /dev/null @@ -1,322 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright 2022 NXP - */ - -/dts-v1/; - -#include "imx93.dtsi" - -/ { - model = "NXP i.MX93 11X11 EVK board"; - compatible = "fsl,imx93-11x11-evk", "fsl,imx93"; - - chosen { - stdout-path = &lpuart1; - }; - - reg_vref_1v8: regulator-adc-vref { - compatible = "regulator-fixed"; - regulator-name = "vref_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - reg_usdhc2_vmmc: regulator-usdhc2 { - compatible = "regulator-fixed"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_reg_usdhc2_vmmc>; - regulator-name = "VSD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio3 7 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; -}; - -&adc1 { - vref-supply = <®_vref_1v8>; - status = "okay"; -}; - -&mu1 { - status = "okay"; -}; - -&mu2 { - status = "okay"; -}; - -&eqos { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_eqos>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy1>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <5000000>; - - ethphy1: ethernet-phy@1 { - reg = <1>; - eee-broken-1000t; - }; - }; -}; - -&fec { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec>; - phy-mode = "rgmii-id"; - phy-handle = <ðphy2>; - fsl,magic-packet; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <5000000>; - - ethphy2: ethernet-phy@2 { - reg = <2>; - eee-broken-1000t; - }; - }; -}; - -&lpi2c2 { - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <400000>; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&pinctrl_lpi2c2>; - pinctrl-1 = <&pinctrl_lpi2c2>; - status = "okay"; - - pmic@25 { - compatible = "nxp,pca9451a"; - reg = <0x25>; - interrupt-parent = <&pcal6524>; - interrupts = <11 IRQ_TYPE_LEVEL_LOW>; - - regulators { - buck1: BUCK1 { - regulator-name = "BUCK1"; - regulator-min-microvolt = <650000>; - regulator-max-microvolt = <2237500>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck2: BUCK2 { - regulator-name = "BUCK2"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <2187500>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck4: BUCK4{ - regulator-name = "BUCK4"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - buck5: BUCK5{ - regulator-name = "BUCK5"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - buck6: BUCK6 { - regulator-name = "BUCK6"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1: LDO1 { - regulator-name = "LDO1"; - regulator-min-microvolt = <1600000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4: LDO4 { - regulator-name = "LDO4"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo5: LDO5 { - regulator-name = "LDO5"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; - - pcal6524: gpio@22 { - compatible = "nxp,pcal6524"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcal6524>; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - interrupt-parent = <&gpio3>; - interrupts = <27 IRQ_TYPE_LEVEL_LOW>; - }; - - adp5585gpio: gpio@34 { - compatible = "adp5585"; - reg = <0x34>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&lpuart1 { /* console */ - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - status = "okay"; -}; - -&usdhc1 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc1>; - pinctrl-1 = <&pinctrl_usdhc1>; - pinctrl-2 = <&pinctrl_usdhc1>; - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - cd-gpios = <&gpio3 00 GPIO_ACTIVE_LOW>; - vmmc-supply = <®_usdhc2_vmmc>; - bus-width = <4>; - status = "okay"; - no-sdio; - no-mmc; -}; - -&iomuxc { - pinctrl_lpi2c2: lpi2c2grp { - fsl,pins = < - MX93_PAD_I2C2_SCL__LPI2C2_SCL 0x40000b9e - MX93_PAD_I2C2_SDA__LPI2C2_SDA 0x40000b9e - >; - }; - - pinctrl_pcal6524: pcal6524grp { - fsl,pins = < - MX93_PAD_CCM_CLKO2__GPIO3_IO27 0x31e - >; - }; - - pinctrl_eqos: eqosgrp { - fsl,pins = < - MX93_PAD_ENET1_MDC__ENET_QOS_MDC 0x57e - MX93_PAD_ENET1_MDIO__ENET_QOS_MDIO 0x57e - MX93_PAD_ENET1_RD0__ENET_QOS_RGMII_RD0 0x57e - MX93_PAD_ENET1_RD1__ENET_QOS_RGMII_RD1 0x57e - MX93_PAD_ENET1_RD2__ENET_QOS_RGMII_RD2 0x57e - MX93_PAD_ENET1_RD3__ENET_QOS_RGMII_RD3 0x57e - MX93_PAD_ENET1_RXC__CCM_ENET_QOS_CLOCK_GENERATE_RX_CLK 0x5fe - MX93_PAD_ENET1_RX_CTL__ENET_QOS_RGMII_RX_CTL 0x57e - MX93_PAD_ENET1_TD0__ENET_QOS_RGMII_TD0 0x57e - MX93_PAD_ENET1_TD1__ENET_QOS_RGMII_TD1 0x57e - MX93_PAD_ENET1_TD2__ENET_QOS_RGMII_TD2 0x57e - MX93_PAD_ENET1_TD3__ENET_QOS_RGMII_TD3 0x57e - MX93_PAD_ENET1_TXC__CCM_ENET_QOS_CLOCK_GENERATE_TX_CLK 0x5fe - MX93_PAD_ENET1_TX_CTL__ENET_QOS_RGMII_TX_CTL 0x57e - >; - }; - - pinctrl_fec: fecgrp { - fsl,pins = < - MX93_PAD_ENET2_MDC__ENET1_MDC 0x57e - MX93_PAD_ENET2_MDIO__ENET1_MDIO 0x57e - MX93_PAD_ENET2_RD0__ENET1_RGMII_RD0 0x57e - MX93_PAD_ENET2_RD1__ENET1_RGMII_RD1 0x57e - MX93_PAD_ENET2_RD2__ENET1_RGMII_RD2 0x57e - MX93_PAD_ENET2_RD3__ENET1_RGMII_RD3 0x57e - MX93_PAD_ENET2_RXC__ENET1_RGMII_RXC 0x5fe - MX93_PAD_ENET2_RX_CTL__ENET1_RGMII_RX_CTL 0x57e - MX93_PAD_ENET2_TD0__ENET1_RGMII_TD0 0x57e - MX93_PAD_ENET2_TD1__ENET1_RGMII_TD1 0x57e - MX93_PAD_ENET2_TD2__ENET1_RGMII_TD2 0x57e - MX93_PAD_ENET2_TD3__ENET1_RGMII_TD3 0x57e - MX93_PAD_ENET2_TXC__ENET1_RGMII_TXC 0x5fe - MX93_PAD_ENET2_TX_CTL__ENET1_RGMII_TX_CTL 0x57e - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX93_PAD_UART1_RXD__LPUART1_RX 0x31e - MX93_PAD_UART1_TXD__LPUART1_TX 0x31e - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX93_PAD_SD1_CLK__USDHC1_CLK 0x15fe - MX93_PAD_SD1_CMD__USDHC1_CMD 0x13fe - MX93_PAD_SD1_DATA0__USDHC1_DATA0 0x13fe - MX93_PAD_SD1_DATA1__USDHC1_DATA1 0x13fe - MX93_PAD_SD1_DATA2__USDHC1_DATA2 0x13fe - MX93_PAD_SD1_DATA3__USDHC1_DATA3 0x13fe - MX93_PAD_SD1_DATA4__USDHC1_DATA4 0x13fe - MX93_PAD_SD1_DATA5__USDHC1_DATA5 0x13fe - MX93_PAD_SD1_DATA6__USDHC1_DATA6 0x13fe - MX93_PAD_SD1_DATA7__USDHC1_DATA7 0x13fe - MX93_PAD_SD1_STROBE__USDHC1_STROBE 0x15fe - >; - }; - - pinctrl_reg_usdhc2_vmmc: regusdhc2vmmcgrp { - fsl,pins = < - MX93_PAD_SD2_RESET_B__GPIO3_IO07 0x31e - >; - }; - - pinctrl_usdhc2_gpio: usdhc2gpiogrp { - fsl,pins = < - MX93_PAD_SD2_CD_B__GPIO3_IO00 0x31e - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX93_PAD_SD2_CLK__USDHC2_CLK 0x15fe - MX93_PAD_SD2_CMD__USDHC2_CMD 0x13fe - MX93_PAD_SD2_DATA0__USDHC2_DATA0 0x13fe - MX93_PAD_SD2_DATA1__USDHC2_DATA1 0x13fe - MX93_PAD_SD2_DATA2__USDHC2_DATA2 0x13fe - MX93_PAD_SD2_DATA3__USDHC2_DATA3 0x13fe - MX93_PAD_SD2_VSELECT__USDHC2_VSELECT 0x51e - >; - }; -}; diff --git a/arch/arm/dts/imx93-u-boot.dtsi b/arch/arm/dts/imx93-u-boot.dtsi index 40e17bbc5ae..289aba17584 100644 --- a/arch/arm/dts/imx93-u-boot.dtsi +++ b/arch/arm/dts/imx93-u-boot.dtsi @@ -86,3 +86,18 @@ }; }; }; + +&tmu { + compatible = "fsl,imx93-tmu"; + reg = <0x44482000 0x1000>; + clocks = <&clk IMX93_CLK_TMC_GATE>; + little-endian; + fsl,tmu-calibration = <0x0000000e 0x800000da + 0x00000029 0x800000e9 + 0x00000056 0x80000102 + 0x000000a2 0x8000012a + 0x00000116 0x80000166 + 0x00000195 0x800001a7 + 0x000001b2 0x800001b6>; + #thermal-sensor-cells = <1>; +}; diff --git a/arch/arm/mach-imx/imx9/Kconfig b/arch/arm/mach-imx/imx9/Kconfig index b79485f1f75..e892da80fe8 100644 --- a/arch/arm/mach-imx/imx9/Kconfig +++ b/arch/arm/mach-imx/imx9/Kconfig @@ -31,6 +31,7 @@ choice config TARGET_IMX93_11X11_EVK bool "imx93_11x11_evk" select IMX93 + imply OF_UPSTREAM
config TARGET_IMX93_VAR_SOM bool "imx93_var_som" diff --git a/configs/imx93_11x11_evk_defconfig b/configs/imx93_11x11_evk_defconfig index db2f2623d89..5ad770f91e1 100644 --- a/configs/imx93_11x11_evk_defconfig +++ b/configs/imx93_11x11_evk_defconfig @@ -10,7 +10,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x700000 CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx93-11x11-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-11x11-evk" CONFIG_SPL_TEXT_BASE=0x2049A000 CONFIG_TARGET_IMX93_11X11_EVK=y CONFIG_SYS_MONITOR_LEN=524288 diff --git a/configs/imx93_11x11_evk_ld_defconfig b/configs/imx93_11x11_evk_ld_defconfig index 822cad7e3fa..abda6d12662 100644 --- a/configs/imx93_11x11_evk_ld_defconfig +++ b/configs/imx93_11x11_evk_ld_defconfig @@ -10,7 +10,7 @@ CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x400000 CONFIG_IMX_CONFIG="arch/arm/mach-imx/imx9/imximage.cfg" CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx93-11x11-evk" +CONFIG_DEFAULT_DEVICE_TREE="freescale/imx93-11x11-evk" CONFIG_SPL_TEXT_BASE=0x2049A000 CONFIG_IMX9_LOW_DRIVE_MODE=y CONFIG_TARGET_IMX93_11X11_EVK=y
Applied all, thanks.
Fabio Estevam
Peng Fan (OSS)
