[U-Boot] [RESEND 1/2] stm32: stm32f4: move flash driver to mtd driver location
Same flash driver can be used by other stm32 families like stm32f7. Better place for this driver would be mtd driver location.
Signed-off-by: Vikas Manocha vikas.manocha@st.com --- arch/arm/include/asm/arch-stm32f4/stm32.h | 31 ++++++------------- arch/arm/mach-stm32/stm32f4/Makefile | 2 +- arch/arm/mach-stm32/stm32f4/clock.c | 10 +------ drivers/mtd/Makefile | 1 + .../stm32f4/flash.c => drivers/mtd/stm32_flash.c | 35 +++++++++++----------- drivers/mtd/stm32_flash.h | 27 +++++++++++++++++ include/configs/stm32f429-discovery.h | 1 + include/flash.h | 2 +- 8 files changed, 59 insertions(+), 50 deletions(-) rename arch/arm/mach-stm32/stm32f4/flash.c => drivers/mtd/stm32_flash.c (82%) create mode 100644 drivers/mtd/stm32_flash.h
diff --git a/arch/arm/include/asm/arch-stm32f4/stm32.h b/arch/arm/include/asm/arch-stm32f4/stm32.h index 7d6331b..6cc1966 100644 --- a/arch/arm/include/asm/arch-stm32f4/stm32.h +++ b/arch/arm/include/asm/arch-stm32f4/stm32.h @@ -82,16 +82,6 @@ struct stm32_pwr_regs { u32 csr; };
-struct stm32_flash_regs { - u32 acr; - u32 key; - u32 optkeyr; - u32 sr; - u32 cr; - u32 optcr; - u32 optcr1; -}; - /* * Registers access macros */ @@ -104,18 +94,6 @@ struct stm32_flash_regs { #define STM32_PWR_BASE (STM32_APB1PERIPH_BASE + 0x7000) #define STM32_PWR ((struct stm32_pwr_regs *)STM32_PWR_BASE)
-#define STM32_FLASH_BASE (STM32_AHB1PERIPH_BASE + 0x3C00) -#define STM32_FLASH ((struct stm32_flash_regs *)STM32_FLASH_BASE) - -#define STM32_FLASH_SR_BSY (1 << 16) - -#define STM32_FLASH_CR_PG (1 << 0) -#define STM32_FLASH_CR_SER (1 << 1) -#define STM32_FLASH_CR_STRT (1 << 16) -#define STM32_FLASH_CR_LOCK (1 << 31) -#define STM32_FLASH_CR_SNB_OFFSET 3 -#define STM32_FLASH_CR_SNB_MASK (15 << STM32_FLASH_CR_SNB_OFFSET) - /* * Peripheral base addresses */ @@ -124,6 +102,14 @@ struct stm32_flash_regs { #define STM32_USART3_BASE (STM32_APB1PERIPH_BASE + 0x4800) #define STM32_USART6_BASE (STM32_APB2PERIPH_BASE + 0x1400)
+#define FLASH_CNTL_BASE (STM32_AHB1PERIPH_BASE + 0x3C00) + +static const u32 sect_sz_kb[CONFIG_SYS_MAX_FLASH_SECT] = { + [0 ... 3] = 16 * 1024, + [4] = 64 * 1024, + [5 ... 11] = 128 * 1024 +}; + enum clock { CLOCK_CORE, CLOCK_AHB, @@ -133,5 +119,6 @@ enum clock {
int configure_clocks(void); unsigned long clock_get(enum clock clck); +void stm32_flash_latency_cfg(int latency);
#endif /* _MACH_STM32_H_ */ diff --git a/arch/arm/mach-stm32/stm32f4/Makefile b/arch/arm/mach-stm32/stm32f4/Makefile index 42d01db..020e783 100644 --- a/arch/arm/mach-stm32/stm32f4/Makefile +++ b/arch/arm/mach-stm32/stm32f4/Makefile @@ -8,4 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += soc.o clock.o timer.o flash.o +obj-y += soc.o clock.o timer.o diff --git a/arch/arm/mach-stm32/stm32f4/clock.c b/arch/arm/mach-stm32/stm32f4/clock.c index 631f36a..15fcadb 100644 --- a/arch/arm/mach-stm32/stm32f4/clock.c +++ b/arch/arm/mach-stm32/stm32f4/clock.c @@ -66,11 +66,6 @@ #define PWR_CR_VOS_SCALE_MODE_2 (PWR_CR_VOS1) #define PWR_CR_VOS_SCALE_MODE_3 (PWR_CR_VOS0)
-#define FLASH_ACR_WS(n) n -#define FLASH_ACR_PRFTEN (1 << 8) -#define FLASH_ACR_ICEN (1 << 9) -#define FLASH_ACR_DCEN (1 << 10) - /* * RCC GPIO specific definitions */ @@ -181,10 +176,7 @@ int configure_clocks(void) while (!(readl(&STM32_RCC->cr) & RCC_CR_PLLRDY)) ;
- /* 5 wait states, Prefetch enabled, D-Cache enabled, I-Cache enabled */ - writel(FLASH_ACR_WS(5) | FLASH_ACR_PRFTEN | FLASH_ACR_ICEN - | FLASH_ACR_DCEN, &STM32_FLASH->acr); - + stm32_flash_latency_cfg(5); clrbits_le32(&STM32_RCC->cfgr, (RCC_CFGR_SW0 | RCC_CFGR_SW1)); setbits_le32(&STM32_RCC->cfgr, RCC_CFGR_SW_PLL);
diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index 7f018a4..703700a 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -20,3 +20,4 @@ obj-$(CONFIG_FTSMC020) += ftsmc020.o obj-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o obj-$(CONFIG_MW_EEPROM) += mw_eeprom.o obj-$(CONFIG_ST_SMI) += st_smi.o +obj-$(CONFIG_STM32_FLASH) += stm32_flash.o diff --git a/arch/arm/mach-stm32/stm32f4/flash.c b/drivers/mtd/stm32_flash.c similarity index 82% rename from arch/arm/mach-stm32/stm32f4/flash.c rename to drivers/mtd/stm32_flash.c index a379f47..71f4854 100644 --- a/arch/arm/mach-stm32/stm32f4/flash.c +++ b/drivers/mtd/stm32_flash.c @@ -8,19 +8,20 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/stm32.h> - -#define STM32_FLASH_KEY1 0x45670123 -#define STM32_FLASH_KEY2 0xCDEF89AB +#include "stm32_flash.h"
flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS];
-const u32 sect_sz_kb[CONFIG_SYS_MAX_FLASH_SECT] = { - [0 ... 3] = 16 * 1024, - [4] = 64 * 1024, - [5 ... 11] = 128 * 1024 -}; +#define STM32_FLASH ((struct stm32_flash_regs *)FLASH_CNTL_BASE) + +void stm32_flash_latency_cfg(int latency) +{ + /* 5 wait states, Prefetch enabled, D-Cache enabled, I-Cache enabled */ + writel(FLASH_ACR_WS(5) | FLASH_ACR_PRFTEN | FLASH_ACR_ICEN + | FLASH_ACR_DCEN, &STM32_FLASH->acr); +}
-static void stm32f4_flash_lock(u8 lock) +static void stm32_flash_lock(u8 lock) { if (lock) { setbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_LOCK); @@ -36,7 +37,7 @@ unsigned long flash_init(void) u8 i, j;
for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { - flash_info[i].flash_id = FLASH_STM32F4; + flash_info[i].flash_id = FLASH_STM32; flash_info[i].sector_count = CONFIG_SYS_MAX_FLASH_SECT; flash_info[i].start[0] = CONFIG_SYS_FLASH_BASE + (i << 20); flash_info[i].size = sect_sz_kb[0]; @@ -58,8 +59,8 @@ void flash_print_info(flash_info_t *info) if (info->flash_id == FLASH_UNKNOWN) { printf("missing or unknown FLASH type\n"); return; - } else if (info->flash_id == FLASH_STM32F4) { - printf("STM32F4 Embedded Flash\n"); + } else if (info->flash_id == FLASH_STM32) { + printf("stm32 Embedded Flash\n"); }
printf(" Size: %ld MB in %d Sectors\n", @@ -91,7 +92,7 @@ int flash_erase(flash_info_t *info, int first, int last) if (bank == 0xFF) return -1;
- stm32f4_flash_lock(0); + stm32_flash_lock(0);
for (i = first; i <= last; i++) { while (readl(&STM32_FLASH->sr) & STM32_FLASH_SR_BSY) @@ -107,7 +108,7 @@ int flash_erase(flash_info_t *info, int first, int last) setbits_le32(&STM32_FLASH->cr, ((0x10 | i) << STM32_FLASH_CR_SNB_OFFSET)); } else { - stm32f4_flash_lock(1); + stm32_flash_lock(1); return -1; } setbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_SER); @@ -119,7 +120,7 @@ int flash_erase(flash_info_t *info, int first, int last) clrbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_SER); }
- stm32f4_flash_lock(1); + stm32_flash_lock(1); return 0; }
@@ -130,7 +131,7 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) while (readl(&STM32_FLASH->sr) & STM32_FLASH_SR_BSY) ;
setbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_PG); /* To make things simple use byte writes only */ @@ -140,7 +141,7 @@ int write_buff(flash_info_t *info, uchar *src, ulong addr, ulong cnt) ; } clrbits_le32(&STM32_FLASH->cr, STM32_FLASH_CR_PG); - stm32f4_flash_lock(1); + stm32_flash_lock(1);
return 0; } diff --git a/drivers/mtd/stm32_flash.h b/drivers/mtd/stm32_flash.h new file mode 100644 index 0000000..8cb81ef --- /dev/null +++ b/drivers/mtd/stm32_flash.h @@ -0,0 +1,27 @@ +struct stm32_flash_regs { + u32 acr; + u32 key; + u32 optkeyr; + u32 sr; + u32 cr; + u32 optcr; + u32 optcr1; +}; + +#define STM32_FLASH_KEY1 0x45670123 +#define STM32_FLASH_KEY2 0xCDEF89AB + +#define STM32_FLASH_SR_BSY (1 << 16) + +#define STM32_FLASH_CR_PG (1 << 0) +#define STM32_FLASH_CR_SER (1 << 1) +#define STM32_FLASH_CR_STRT (1 << 16) +#define STM32_FLASH_CR_LOCK (1 << 31) +#define STM32_FLASH_CR_SNB_OFFSET 3 +#define STM32_FLASH_CR_SNB_MASK (15 << STM32_FLASH_CR_SNB_OFFSET) + +/* Flash ACR: Access control register */ +#define FLASH_ACR_WS(n) n +#define FLASH_ACR_PRFTEN (1 << 8) +#define FLASH_ACR_ICEN (1 << 9) +#define FLASH_ACR_DCEN (1 << 10) diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index 85d492d..87901e8 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -49,6 +49,7 @@ #define CONFIG_GREEN_LED 109
#define CONFIG_STM32_GPIO +#define CONFIG_STM32_FLASH #define CONFIG_STM32_SERIAL
#define CONFIG_STM32_HSE_HZ 8000000 diff --git a/include/flash.h b/include/flash.h index f53ace7..c6321a0 100644 --- a/include/flash.h +++ b/include/flash.h @@ -465,7 +465,7 @@ extern flash_info_t *flash_get_info(ulong base); #define FLASH_S29GL064M 0x00F0 /* Spansion S29GL064M-R6 */ #define FLASH_S29GL128N 0x00F1 /* Spansion S29GL128N */
-#define FLASH_STM32F4 0x00F2 /* STM32F4 Embedded Flash */ +#define FLASH_STM32 0x00F2 /* STM32 Embedded Flash */ #define FLASH_STM32F1 0x00F3 /* STM32F1 Embedded Flash */
#define FLASH_UNKNOWN 0xFFFF /* unknown flash type */
This patch enables embedded flash for stm32f746 discovery board.
Signed-off-by: Vikas Manocha vikas.manocha@st.com --- arch/arm/include/asm/arch-stm32f7/stm32.h | 6 ++++++ include/configs/stm32f746-disco.h | 11 ++++------- 2 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/arch-stm32f7/stm32.h b/arch/arm/include/asm/arch-stm32f7/stm32.h index 713eb2e..68bdab0 100644 --- a/arch/arm/include/asm/arch-stm32f7/stm32.h +++ b/arch/arm/include/asm/arch-stm32f7/stm32.h @@ -50,6 +50,12 @@
#define SDRAM_FMC_BASE (AHB3_PERIPH_BASE + 0x4A0000140)
+static const u32 sect_sz_kb[CONFIG_SYS_MAX_FLASH_SECT] = { + [0 ... 3] = 32 * 1024, + [4] = 128 * 1024, + [5 ... 7] = 256 * 1024 +}; + enum clock { CLOCK_CORE, CLOCK_AHB, diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index e1b8bcb..807ab65 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -9,7 +9,7 @@ #define __CONFIG_H
#define CONFIG_SYS_THUMB_BUILD -#define CONFIG_SYS_NO_FLASH +/*#define CONFIG_SYS_NO_FLASH*/
#define CONFIG_OF_LIBFDT #define CONFIG_BOARD_EARLY_INIT_F @@ -33,17 +33,14 @@ #define CONFIG_SYS_LOAD_ADDR 0x20000000 #define CONFIG_LOADADDR 0x20000000
-#define CONFIG_SYS_MAX_FLASH_SECT 12 -#define CONFIG_SYS_MAX_FLASH_BANKS 2 +#define CONFIG_SYS_MAX_FLASH_SECT 8 +#define CONFIG_SYS_MAX_FLASH_BANKS 1
-#ifndef CONFIG_SYS_NO_FLASH -#define CONFIG_ENV_IS_IN_FLASH -#else #define CONFIG_ENV_IS_NOWHERE -#endif #define CONFIG_ENV_SIZE (8 << 10)
#define CONFIG_STM32_GPIO +#define CONFIG_STM32_FLASH #define CONFIG_STM32X7_SERIAL
#define CONFIG_SYS_CLK_FREQ 16*1000*1000 /* 180 MHz */
What kind of flash is it, parallel or serial NOR?
-- Jagan.
Hi Jagan ,
On Mar 9, 2016, at 6:53 PM, Jagan Teki jteki@openedev.com wrote:
On Thursday 10 March 2016 04:48 AM, Vikas Manocha wrote: Same flash driver can be used by other stm32 families like stm32f7. Better place for this driver would be mtd driver location.
It is embedded 256 bit NOR flash.
Cheers, Vikas
-- Jagan.
On 2016-03-09 23:18, Vikas MANOCHA wrote:
Hi Jagan ,
OK, I thought it's similar to SST25L.
Can't we detect this through cfi_flash framework?
-- Jagan.
Hi Jagan,
-----Original Message----- From: jteki@openedev.com [mailto:jteki@openedev.com] Sent: Wednesday, March 09, 2016 9:02 PM To: Vikas MANOCHA Cc: u-boot@lists.denx.de; Albert Aribaud; Antonio Borneo; Heiko Schocher; Kamil Lulko; Matt Porter; rev13@wp.pl; Scott Wood; Simon Glass; Stefan Roese; Thomas Chou; Vadzim Dambrouski Subject: Re: [RESEND 1/2] stm32: stm32f4: move flash driver to mtd driver location
Hi Jagan ,
No, it is not possible.
Cheers, Vikas
-- Jagan.
On Thursday 10 March 2016 11:11 PM, Vikas MANOCHA wrote:
Hi Jagan,
Hi Jagan ,
Sorry, please add some details why it couldn't?
-----Original Message----- From: Jagan Teki [mailto:jteki@openedev.com] Sent: Thursday, March 10, 2016 9:46 AM To: Vikas MANOCHA Cc: u-boot@lists.denx.de; Albert Aribaud; Antonio Borneo; Heiko Schocher; Kamil Lulko; Matt Porter; rev13@wp.pl; Scott Wood; Simon Glass; Stefan Roese; Thomas Chou; Vadzim Dambrouski Subject: Re: [RESEND 1/2] stm32: stm32f4: move flash driver to mtd driver location
Hi Jagan,
Hi Jagan ,
The embedded flash in stm32 is not cfi flash. Cfi tables to find the flash characteristics are not implemented.
Cheers, Vikas
Hi Jagan,
Hi Jagan ,
> On Thursday 10 March 2016 04:48 AM, Vikas Manocha wrote: > Same flash driver can be used by other stm32 families like stm32f7. > Better place for this driver would be mtd driver location.
OK, all your saying that this not quite exactly a cfi, different kind wrt sst32. true? then please convert this into MTD driver model format.
If needed take an example of existing MTD uclass driver.
Hi Jagan,
-----Original Message----- From: Jagan Teki [mailto:jteki@openedev.com] Sent: Thursday, March 10, 2016 9:58 AM To: Vikas MANOCHA Cc: u-boot@lists.denx.de; Albert Aribaud; Antonio Borneo; Heiko Schocher; Kamil Lulko; Matt Porter; rev13@wp.pl; Scott Wood; Simon Glass; Stefan Roese; Thomas Chou; Vadzim Dambrouski Subject: Re: [RESEND 1/2] stm32: stm32f4: move flash driver to mtd driver location
Hi Jagan,
Hi Jagan ,
wrote:
> >> On Thursday 10 March 2016 04:48 AM, Vikas Manocha wrote: >> Same flash driver can be used by other stm32 families like stm32f7. >> Better place for this driver would be mtd driver location. > > What kind of flash is it, parallel or serial NOR?
Yes, flash is embedded in the stm32 micro & details like data width etc are not relevant for the user. Sst32 ? , sorry but I am not aware of it and sst32L.
Can you please point me to it ?
Cheers, Vikas
On Thursday 10 March 2016 11:47 PM, Vikas MANOCHA wrote:
Hi Jagan,
Hi Jagan,
On 2016-03-09 23:18, Vikas MANOCHA wrote: > Hi Jagan , > >> On Mar 9, 2016, at 6:53 PM, Jagan Teki jteki@openedev.com
wrote:
>> >>> On Thursday 10 March 2016 04:48 AM, Vikas Manocha wrote: >>> Same flash driver can be used by other stm32 families like stm32f7. >>> Better place for this driver would be mtd driver location. >> >> What kind of flash is it, parallel or serial NOR? > > It is embedded 256 bit NOR flash.
The board your using with this driver has fdt and dm support?
If so, it is quite straight forward, take an example of this drivers/mtd/altera_qspi.c
- register with MTD_UCLASS - add your erase/write and read ops through mtd_ops
Hi Jagan,
-----Original Message----- From: Jagan Teki [mailto:jteki@openedev.com] Sent: Thursday, March 10, 2016 10:38 AM To: Vikas MANOCHA Cc: u-boot@lists.denx.de; Albert Aribaud; Antonio Borneo; Heiko Schocher; Kamil Lulko; Matt Porter; rev13@wp.pl; Scott Wood; Simon Glass; Stefan Roese; Thomas Chou; Vadzim Dambrouski Subject: Re: [RESEND 1/2] stm32: stm32f4: move flash driver to mtd driver location
Hi Jagan,
Hi Jagan,
> -----Original Message----- > From: jteki@openedev.com [mailto:jteki@openedev.com] > Sent: Wednesday, March 09, 2016 9:02 PM > To: Vikas MANOCHA > Cc: u-boot@lists.denx.de; Albert Aribaud; Antonio Borneo; Heiko > Schocher; Kamil Lulko; Matt Porter; rev13@wp.pl; Scott Wood; > Simon Glass; Stefan Roese; Thomas Chou; Vadzim Dambrouski > Subject: Re: [RESEND 1/2] stm32: stm32f4: move flash driver to > mtd driver location > > On 2016-03-09 23:18, Vikas MANOCHA wrote: >> Hi Jagan , >> >>> On Mar 9, 2016, at 6:53 PM, Jagan Teki jteki@openedev.com
wrote:
>>> >>>> On Thursday 10 March 2016 04:48 AM, Vikas Manocha wrote: >>>> Same flash driver can be used by other stm32 families like
stm32f7.
>>>> Better place for this driver would be mtd driver location. >>> >>> What kind of flash is it, parallel or serial NOR? >> >> It is embedded 256 bit NOR flash. > > OK, I thought it's similar to SST25L. > > Can't we detect this through cfi_flash framework?
Thanks for the pointer but what I am trying is to add (actually moving from stm32f4 area) the support for stm32 inbuilt flash memory e.g. to support flash operations required by flash commands like flinfo, erase, protect. I am not looking to add mtd support, I just saw one similar example here ("st_smi" in drivers/mtd) & thought of putting stm32 flash driver also here. The purpose is to make this driver available to other SOCs ( STM32s). Might be better place would be common area of arch/stm32...
Cheers, Vikas
participants (5)
Jagan Teki
jteki@openedev.com
Vikas MANOCHA
Vikas Manocha
