[PATCH] global: Remove dead code that starts with CONFIG_[0-9A]
This removes a number of spots of dead code based on symbols that start with CONFIG_[0-9] or CONFIG_A.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/powerpc/cpu/mpc83xx/pcie.c | 144 ---------------------- arch/powerpc/include/asm/processor.h | 4 - board/freescale/mpc8349emds/mpc8349emds.c | 2 - drivers/net/smc91111.h | 13 +- drivers/video/pxa_lcd.c | 68 +--------- include/configs/MPC8349EMDS.h | 3 - include/configs/MPC8349EMDS_SDRAM.h | 3 - include/configs/aspenite.h | 1 - include/configs/km/km-mpc8309.h | 1 - include/configs/km/km-mpc832x.h | 1 - include/configs/kmcoge5ne.h | 1 - include/configs/sniper.h | 10 -- include/configs/total_compute.h | 2 - include/configs/vexpress_common.h | 3 - 14 files changed, 3 insertions(+), 253 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/pcie.c b/arch/powerpc/cpu/mpc83xx/pcie.c index 84797c871c95..c386e4ed3fde 100644 --- a/arch/powerpc/cpu/mpc83xx/pcie.c +++ b/arch/powerpc/cpu/mpc83xx/pcie.c @@ -34,148 +34,6 @@ static struct { #endif };
-#ifdef CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES - -/* private structure for mpc83xx pcie hose */ -static struct mpc83xx_pcie_priv { - u8 index; -} pcie_priv[PCIE_MAX_BUSES] = { - { - /* pcie controller 1 */ - .index = 0, - }, - { - /* pcie controller 2 */ - .index = 1, - }, -}; - -static int mpc83xx_pcie_remap_cfg(struct pci_controller *hose, pci_dev_t dev) -{ - int bus = PCI_BUS(dev) - hose->first_busno; - immap_t *immr = (immap_t *)CONFIG_SYS_IMMR; - struct mpc83xx_pcie_priv *pcie_priv = hose->priv_data; - pex83xx_t *pex = &immr->pciexp[pcie_priv->index]; - struct pex_outbound_window *out_win = &pex->bridge.pex_outbound_win[0]; - u8 devfn = PCI_DEV(dev) << 3 | PCI_FUNC(dev); - u32 dev_base = bus << 24 | devfn << 16; - - if (hose->indirect_type == INDIRECT_TYPE_NO_PCIE_LINK) - return -1; - /* - * Workaround for the HW bug: for Type 0 configure transactions the - * PCI-E controller does not check the device number bits and just - * assumes that the device number bits are 0. - */ - if (devfn & 0xf8) - return -1; - - out_le32(&out_win->tarl, dev_base); - return 0; -} - -#define cfg_read(val, addr, type, op) \ - do { *val = op((type)(addr)); } while (0) -#define cfg_write(val, addr, type, op) \ - do { op((type *)(addr), (val)); } while (0) - -#define cfg_read_err(val) do { *val = -1; } while (0) -#define cfg_write_err(val) do { } while (0) - -#define PCIE_OP(rw, size, type, op) \ -static int pcie_##rw##_config_##size(struct pci_controller *hose, \ - pci_dev_t dev, int offset, \ - type val) \ -{ \ - int ret; \ - \ - ret = mpc83xx_pcie_remap_cfg(hose, dev); \ - if (ret) { \ - cfg_##rw##_err(val); \ - return ret; \ - } \ - cfg_##rw(val, (void *)hose->cfg_addr + offset, type, op); \ - return 0; \ -} - -PCIE_OP(read, byte, u8 *, in_8) -PCIE_OP(read, word, u16 *, in_le16) -PCIE_OP(read, dword, u32 *, in_le32) -PCIE_OP(write, byte, u8, out_8) -PCIE_OP(write, word, u16, out_le16) -PCIE_OP(write, dword, u32, out_le32) - -static void mpc83xx_pcie_register_hose(int bus, struct pci_region *reg, - u8 link) -{ - extern void disable_addr_trans(void); /* start.S */ - static struct pci_controller pcie_hose[PCIE_MAX_BUSES]; - struct pci_controller *hose = &pcie_hose[bus]; - int i; - - /* - * There are no spare BATs to remap all PCI-E windows for U-Boot, so - * disable translations. In general, this is not great solution, and - * that's why we don't register PCI-E hoses by default. - */ - disable_addr_trans(); - - for (i = 0; i < 2; i++, reg++) { - if (reg->size == 0) - break; - - hose->regions[i] = *reg; - hose->region_count++; - } - - i = hose->region_count++; - hose->regions[i].bus_start = 0; - hose->regions[i].phys_start = 0; - hose->regions[i].size = gd->ram_size; - hose->regions[i].flags = PCI_REGION_MEM | PCI_REGION_SYS_MEMORY; - - i = hose->region_count++; - hose->regions[i].bus_start = CONFIG_SYS_IMMR; - hose->regions[i].phys_start = CONFIG_SYS_IMMR; - hose->regions[i].size = 0x100000; - hose->regions[i].flags = PCI_REGION_MEM | PCI_REGION_SYS_MEMORY; - - hose->first_busno = pci_last_busno() + 1; - hose->last_busno = 0xff; - - hose->cfg_addr = (unsigned int *)mpc83xx_pcie_cfg_space[bus].base; - - hose->priv_data = &pcie_priv[bus]; - - pci_set_ops(hose, - pcie_read_config_byte, - pcie_read_config_word, - pcie_read_config_dword, - pcie_write_config_byte, - pcie_write_config_word, - pcie_write_config_dword); - - if (!link) - hose->indirect_type = INDIRECT_TYPE_NO_PCIE_LINK; - - pci_register_hose(hose); - -#ifdef CONFIG_PCI_SCAN_SHOW - printf("PCI: Bus Dev VenId DevId Class Int\n"); -#endif - /* - * Hose scan. - */ - hose->last_busno = pci_hose_scan(hose); -} - -#else - -static void mpc83xx_pcie_register_hose(int bus, struct pci_region *reg, - u8 link) {} - -#endif /* CONFIG_83XX_GENERIC_PCIE_REGISTER_HOSES */ - int get_pcie_clk(int index) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; @@ -340,8 +198,6 @@ static void mpc83xx_pcie_init_bus(int bus, struct pci_region *reg) printf("link\n"); else printf("No link\n"); - - mpc83xx_pcie_register_hose(bus, reg, reg16 >= PCI_LTSSM_L0); }
/* diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index e03ab21f59d5..b6944d88ebe6 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -46,11 +46,7 @@ #define MSR_RI (1<<1) /* Recoverable Exception */ #define MSR_LE (1<<0) /* Little Endian */
-#ifdef CONFIG_APUS_FAST_EXCEPT -#define MSR_ MSR_ME|MSR_IP|MSR_RI -#else #define MSR_ MSR_ME|MSR_RI -#endif #ifndef CONFIG_E500 #define MSR_KERNEL MSR_|MSR_IR|MSR_DR #else diff --git a/board/freescale/mpc8349emds/mpc8349emds.c b/board/freescale/mpc8349emds/mpc8349emds.c index 5f38639afd42..c4c7f528b58e 100644 --- a/board/freescale/mpc8349emds/mpc8349emds.c +++ b/board/freescale/mpc8349emds/mpc8349emds.c @@ -50,8 +50,6 @@ int board_early_init_f (void) return 0; }
-#define ns2clk(ns) (ns / (1000000000 / CONFIG_8349_CLKIN) + 1) - int dram_init(void) { volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; diff --git a/drivers/net/smc91111.h b/drivers/net/smc91111.h index 4c3acba35a9d..db324c17d679 100644 --- a/drivers/net/smc91111.h +++ b/drivers/net/smc91111.h @@ -251,18 +251,14 @@ struct smc91111_priv{ * We have only 16 Bit PCMCIA access on Socket 0 */
-#ifdef CONFIG_ADNPESC1 -#define SMC_inw(a,r) (*((volatile word *)((a)->iobase+((r)<<1)))) -#elif CONFIG_ARM64 +#if CONFIG_ARM64 #define SMC_inw(a, r) (*((volatile word*)((a)->iobase+((dword)(r))))) #else #define SMC_inw(a, r) (*((volatile word*)((a)->iobase+(r)))) #endif #define SMC_inb(a,r) (((r)&1) ? SMC_inw((a),(r)&~1)>>8 : SMC_inw((a),(r)&0xFF))
-#ifdef CONFIG_ADNPESC1 -#define SMC_outw(a,d,r) (*((volatile word *)((a)->iobase+((r)<<1))) = d) -#elif CONFIG_ARM64 +#if CONFIG_ARM64 #define SMC_outw(a, d, r) \ (*((volatile word*)((a)->iobase+((dword)(r)))) = d) #else @@ -439,11 +435,6 @@ struct smc91111_priv{ #define RPC_LED_RX (0x07) /* LED = RX packet occurred */ #if defined(CONFIG_DK1C20) || defined(CONFIG_DK1S10) /* buggy schematic: LEDa -> yellow, LEDb --> green */ -#define RPC_DEFAULT ( RPC_SPEED | RPC_DPLX | RPC_ANEG \ - | (RPC_LED_TX_RX << RPC_LSXA_SHFT) \ - | (RPC_LED_100_10 << RPC_LSXB_SHFT) ) -#elif defined(CONFIG_ADNPESC1) -/* SSV ADNP/ESC1 has only one LED: LEDa -> Rx/Tx indicator */ #define RPC_DEFAULT ( RPC_SPEED | RPC_DPLX | RPC_ANEG \ | (RPC_LED_TX_RX << RPC_LSXA_SHFT) \ | (RPC_LED_100_10 << RPC_LSXB_SHFT) ) diff --git a/drivers/video/pxa_lcd.c b/drivers/video/pxa_lcd.c index 67f5266164fa..21ade8d93c4a 100644 --- a/drivers/video/pxa_lcd.c +++ b/drivers/video/pxa_lcd.c @@ -199,72 +199,6 @@ vidinfo_t panel_info = {
-#ifdef CONFIG_ACX517AKN - -# define LCD_BPP LCD_COLOR8 - -/* you have to set lccr0 and lccr3 (including pcd) */ -# define REG_LCCR0 0x003008f9 -# define REG_LCCR3 0x03700006 - -vidinfo_t panel_info = { - .vl_col = 320, - .vl_row = 320, - .vl_width = 320, - .vl_height = 320, - .vl_clkp = CONFIG_SYS_HIGH, - .vl_oep = CONFIG_SYS_LOW, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_HIGH, - .vl_bpix = LCD_BPP, - .vl_lbw = 0, - .vl_splt = 1, - .vl_clor = 1, - .vl_tft = 1, - .vl_hpw = 0x04, - .vl_blw = 0x1c, - .vl_elw = 0x08, - .vl_vpw = 0x01, - .vl_bfw = 0x07, - .vl_efw = 0x08, -}; -#endif /* CONFIG_ACX517AKN */ - -#ifdef CONFIG_ACX544AKN - -# define LCD_BPP LCD_COLOR16 - -/* you have to set lccr0 and lccr3 (including pcd) */ -# define REG_LCCR0 0x003008f9 -# define REG_LCCR3 0x04700007 /* 16bpp */ - -vidinfo_t panel_info = { - .vl_col = 320, - .vl_row = 320, - .vl_width = 320, - .vl_height = 320, - .vl_clkp = CONFIG_SYS_LOW, - .vl_oep = CONFIG_SYS_LOW, - .vl_hsp = CONFIG_SYS_LOW, - .vl_vsp = CONFIG_SYS_LOW, - .vl_dp = CONFIG_SYS_LOW, - .vl_bpix = LCD_BPP, - .vl_lbw = 0, - .vl_splt = 0, - .vl_clor = 1, - .vl_tft = 1, - .vl_hpw = 0x05, - .vl_blw = 0x13, - .vl_elw = 0x08, - .vl_vpw = 0x02, - .vl_bfw = 0x07, - .vl_efw = 0x05, -}; -#endif /* CONFIG_ACX544AKN */ - -/*----------------------------------------------------------------------*/ - #ifdef CONFIG_LQ038J7DH53
# define LCD_BPP LCD_COLOR8 @@ -295,7 +229,7 @@ vidinfo_t panel_info = { .vl_bfw = 0x04, .vl_efw = 0x01, }; -#endif /* CONFIG_ACX517AKN */ +#endif /* CONFIG_LQ038J7DH53 */
diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 959de73cf0c6..d5af4e8166aa 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -210,9 +210,6 @@
#if defined(CONFIG_PCI)
-#define CONFIG_83XX_PCI_STREAMING - - #if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xFIXME #define PCI_ENET0_MEMADDR 0xFIXME diff --git a/include/configs/MPC8349EMDS_SDRAM.h b/include/configs/MPC8349EMDS_SDRAM.h index 072c6a000f86..ac12b22e64e2 100644 --- a/include/configs/MPC8349EMDS_SDRAM.h +++ b/include/configs/MPC8349EMDS_SDRAM.h @@ -265,9 +265,6 @@
-#define CONFIG_83XX_PCI_STREAMING - - #if !defined(CONFIG_PCI_PNP) #define PCI_ENET0_IOADDR 0xFIXME #define PCI_ENET0_MEMADDR 0xFIXME diff --git a/include/configs/aspenite.h b/include/configs/aspenite.h index 88e1bf177534..45d6b629dbdf 100644 --- a/include/configs/aspenite.h +++ b/include/configs/aspenite.h @@ -14,7 +14,6 @@ */ #define CONFIG_SHEEVA_88SV331xV5 1 /* CPU Core subversion */ #define CONFIG_ARMADA100 1 /* SOC Family Name */ -#define CONFIG_ARMADA168 1 /* SOC Used on this Board */ #define CONFIG_SKIP_LOWLEVEL_INIT /* disable board lowlevel_init */
/* diff --git a/include/configs/km/km-mpc8309.h b/include/configs/km/km-mpc8309.h index 8ed32b27f692..ff97c6cc791a 100644 --- a/include/configs/km/km-mpc8309.h +++ b/include/configs/km/km-mpc8309.h @@ -8,7 +8,6 @@ /* * System Clock Setup */ -#define CONFIG_83XX_CLKIN 66000000 #define CONFIG_SYS_CLK_FREQ 66000000 #define CONFIG_83XX_PCICLK 66000000
diff --git a/include/configs/km/km-mpc832x.h b/include/configs/km/km-mpc832x.h index 2955776c7535..537a9d554b06 100644 --- a/include/configs/km/km-mpc832x.h +++ b/include/configs/km/km-mpc832x.h @@ -6,7 +6,6 @@ /* * System Clock Setup */ -#define CONFIG_83XX_CLKIN 66000000 #define CONFIG_SYS_CLK_FREQ 66000000 #define CONFIG_83XX_PCICLK 66000000
diff --git a/include/configs/kmcoge5ne.h b/include/configs/kmcoge5ne.h index cdfb280aeeee..60fe4ae3839e 100644 --- a/include/configs/kmcoge5ne.h +++ b/include/configs/kmcoge5ne.h @@ -27,7 +27,6 @@ /* * System Clock Setup */ -#define CONFIG_83XX_CLKIN 66000000 #define CONFIG_SYS_CLK_FREQ 66000000 #define CONFIG_83XX_PCICLK 66000000
diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 844e2f1fff1d..25e0735022f7 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -11,16 +11,6 @@ #include <asm/arch/cpu.h> #include <asm/arch/omap.h>
-/* - * CPU - */ - -#define CONFIG_ARM_ARCH_CP15_ERRATA - -/* - * Board - */ - /* * Clocks */ diff --git a/include/configs/total_compute.h b/include/configs/total_compute.h index cc93f1930a1b..61ca86600611 100644 --- a/include/configs/total_compute.h +++ b/include/configs/total_compute.h @@ -34,9 +34,7 @@ #define PHYS_SDRAM_1_SIZE 0x80000000 - DRAM_SEC_SIZE #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
-#define CONFIG_ARM_PL180_MMCI_BASE 0x001c050000 #define CONFIG_SYS_MMC_MAX_BLK_COUNT 127 -#define CONFIG_ARM_PL180_MMCI_CLOCK_FREQ 12000000
#define CONFIG_EXTRA_ENV_SETTINGS \ "bootm_size=0x20000000\0" \ diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index b131480e5bc3..5d5ad923e5e1 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -56,7 +56,6 @@
/* Common peripherals relative to CS7. */ #define V2M_AACI (V2M_PA_CS7 + V2M_PERIPH_OFFSET(4)) -#define V2M_MMCI (V2M_PA_CS7 + V2M_PERIPH_OFFSET(5)) #define V2M_KMI0 (V2M_PA_CS7 + V2M_PERIPH_OFFSET(6)) #define V2M_KMI1 (V2M_PA_CS7 + V2M_PERIPH_OFFSET(7))
@@ -135,9 +134,7 @@ #define CONFIG_SYS_SERIAL0 V2M_UART0 #define CONFIG_SYS_SERIAL1 V2M_UART1
-#define CONFIG_ARM_PL180_MMCI_BASE V2M_MMCI #define CONFIG_SYS_MMC_MAX_BLK_COUNT 127 -#define CONFIG_ARM_PL180_MMCI_CLOCK_FREQ 6250000
/* BOOTP options */ #define CONFIG_BOOTP_BOOTFILESIZE
How did you find those symbols? I suppose the actual patch is just generated with unifdef or similar.
Shouldn't they also be removed from scripts/config_whitelist.txt ?
More generally, running
for x in $(cat scripts/config_whitelist.txt) ; do git grep -w -q $x -- . ':!scripts/config_whitelist.txt' || echo $x ; done
[I'm sure there's a more efficient way...] shows a few symbols that could be removed from that file, along with the places where they are set via a CONFIG_SYS_EXTRA_OPTIONS.
Rasmus
The entire list is at scripts/config_whitelist.txt and I just used `git grep -Ovim ...` and removed by hand.
I don't bother because there's so many conflicts and it's a generated by scripts/build-whitelist.sh
Yes, finishing the migration of CONFIG_SYS_EXTRA_OPTIONS is also on the list. I'm just running down the list looking for chunks of symbols that hopefully aren't in the categories of: - Abusing tests for CONFIG_SPL_BUILD to set/unset based on SPL build or not. - Sometimes a value, sometimes a function name. - Some other kind of game cpp lets you do, but that's not so easy to move to Kconfig.
Rasmus Villemoes
