[U-Boot] [PATCH v3 0/2] ARM: am335x: Support chiliSOM and chiliBoard
These patches add support for chiliSOM (http://grinn-global.com/chilisom/), and chiliBoard (which uses chiliSOM as it's base).
chiliSOM consists of processor (TI AM335x), RAM memory (up to 512M DDR3) and flash (NAND). The idea is that every board vendor can use chiliSOM as it's base for designed board. Hence, we need a way to reuse common code between those board.
chiliBoard is a development kit (and reference platform for chiliSOM), that mainly shows possibilities and use cases of chiliSOM.
Patches were developed and tested on 2017.01.
Changes v2 -> v3: * Removed USB gadget and SPL ETH references in chiliBoard code, which removed a lot of unused lines in eth initialization (suggested by Tom) * Removed SPI FLASH and SPL USB from defconfig
Changes v1 -> v2: * chiliSOM was moved from arch/arm/mach-chilisom/chilisom.c to arch/arm/mach-omap2/chilisom.c (suggested by Tom) * CONFIG_CHILISOM -> CONFIG_AM33XX_CHILISOM (suggested by Tom) * converted include/configs/chiliboard.h header to SPDX license identifier (suggested by Tom) * removed USB gadget, CMD_DFU options from chiliboard_defconfig
Marcin Niestroj (2): ARM: am335x: Add support for chiliSOM board/chiliboard: Add support for chiliBoard
arch/arm/Kconfig | 1 + arch/arm/include/asm/arch-am33xx/chilisom.h | 15 ++ arch/arm/mach-omap2/am33xx/Kconfig | 10 ++ arch/arm/mach-omap2/am33xx/Makefile | 2 + arch/arm/mach-omap2/am33xx/chilisom.c | 185 ++++++++++++++++++++++++ board/grinn/chiliboard/Kconfig | 15 ++ board/grinn/chiliboard/MAINTAINERS | 8 ++ board/grinn/chiliboard/Makefile | 6 + board/grinn/chiliboard/README | 31 ++++ board/grinn/chiliboard/board.c | 206 ++++++++++++++++++++++++++ configs/chiliboard_defconfig | 45 ++++++ include/configs/chiliboard.h | 214 ++++++++++++++++++++++++++++ 12 files changed, 738 insertions(+) create mode 100644 arch/arm/include/asm/arch-am33xx/chilisom.h create mode 100644 arch/arm/mach-omap2/am33xx/chilisom.c create mode 100644 board/grinn/chiliboard/Kconfig create mode 100644 board/grinn/chiliboard/MAINTAINERS create mode 100644 board/grinn/chiliboard/Makefile create mode 100644 board/grinn/chiliboard/README create mode 100644 board/grinn/chiliboard/board.c create mode 100644 configs/chiliboard_defconfig create mode 100644 include/configs/chiliboard.h
chiliSOM is a System On Module (http://http://grinn-global.com/chilisom/). It can't exists on its own, but will be used as part of other boards.
Hardware specification: * TI AM335x processor * 128M, 256M or 512M DDR3 memory * up to 256M NAND
We place source inside arch/arm/mach-omap2/ directory and make it possible to reuse initialization code (i.e. DDR, NAND init) for all boards that use it.
Signed-off-by: Marcin Niestroj m.niestroj@grinn-global.com Reviewed-by: Tom Rini trini@konsulko.com --- Changes v2 -> v3: none
Changes v1 -> v2 (suggested by Tom): * chiliSOM was moved from arch/arm/mach-chilisom/chilisom.c to arch/arm/mach-omap2/chilisom.c * CONFIG_CHILISOM -> CONFIG_AM33XX_CHILISOM
arch/arm/include/asm/arch-am33xx/chilisom.h | 15 +++ arch/arm/mach-omap2/am33xx/Kconfig | 4 + arch/arm/mach-omap2/am33xx/Makefile | 2 + arch/arm/mach-omap2/am33xx/chilisom.c | 185 ++++++++++++++++++++++++++++ 4 files changed, 206 insertions(+) create mode 100644 arch/arm/include/asm/arch-am33xx/chilisom.h create mode 100644 arch/arm/mach-omap2/am33xx/chilisom.c
diff --git a/arch/arm/include/asm/arch-am33xx/chilisom.h b/arch/arm/include/asm/arch-am33xx/chilisom.h new file mode 100644 index 0000000000..bd0016e441 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/chilisom.h @@ -0,0 +1,15 @@ +/* + * Copyright (C) 2017 Grinn + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __ARCH_ARM_MACH_CHILISOM_SOM_H__ +#define __ARCH_ARM_MACH_CHILISOM_SOM_H__ + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT +void chilisom_enable_pin_mux(void); +void chilisom_spl_board_init(void); +#endif + +#endif diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 56c44062c4..b1a0f0f356 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -1,5 +1,9 @@ if AM33XX
+config AM33XX_CHILISOM + bool + select SUPPORT_SPL + choice prompt "AM33xx board select" optional diff --git a/arch/arm/mach-omap2/am33xx/Makefile b/arch/arm/mach-omap2/am33xx/Makefile index 6fda4825fc..05cc8a11c5 100644 --- a/arch/arm/mach-omap2/am33xx/Makefile +++ b/arch/arm/mach-omap2/am33xx/Makefile @@ -20,3 +20,5 @@ obj-y += board.o obj-y += mux.o
obj-$(CONFIG_CLOCK_SYNTHESIZER) += clk_synthesizer.o + +obj-$(CONFIG_AM33XX_CHILISOM) += chilisom.o diff --git a/arch/arm/mach-omap2/am33xx/chilisom.c b/arch/arm/mach-omap2/am33xx/chilisom.c new file mode 100644 index 0000000000..a594f6cf37 --- /dev/null +++ b/arch/arm/mach-omap2/am33xx/chilisom.c @@ -0,0 +1,185 @@ +/* + * Copyright (C) 2011, Texas Instruments, Incorporated - http://www.ti.com/ + * Copyright (C) 2017, Grinn - http://grinn-global.com/ + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/clock.h> +#include <asm/arch/clk_synthesizer.h> +#include <asm/arch/cpu.h> +#include <asm/arch/ddr_defs.h> +#include <asm/arch/hardware.h> +#include <asm/arch/omap.h> +#include <asm/arch/mem.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/emif.h> +#include <asm/io.h> +#include <errno.h> +#include <i2c.h> +#include <power/tps65217.h> +#include <spl.h> + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + +static struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; + +static struct module_pin_mux i2c0_pin_mux[] = { + {OFFSET(i2c0_sda), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C_DATA */ + {OFFSET(i2c0_scl), (MODE(0) | RXACTIVE | + PULLUDEN | SLEWCTRL)}, /* I2C_SCLK */ + {-1}, +}; + +static struct module_pin_mux nand_pin_mux[] = { + {OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD0 */ + {OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD1 */ + {OFFSET(gpmc_ad2), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD2 */ + {OFFSET(gpmc_ad3), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD3 */ + {OFFSET(gpmc_ad4), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD4 */ + {OFFSET(gpmc_ad5), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD5 */ + {OFFSET(gpmc_ad6), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD6 */ + {OFFSET(gpmc_ad7), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD7 */ + {OFFSET(gpmc_wait0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* NAND WAIT */ + {OFFSET(gpmc_wpn), (MODE(7) | PULLUP_EN | RXACTIVE)}, /* NAND_WPN */ + {OFFSET(gpmc_csn0), (MODE(0) | PULLUDEN)}, /* NAND_CS0 */ + {OFFSET(gpmc_advn_ale), (MODE(0) | PULLUDEN)}, /* NAND_ADV_ALE */ + {OFFSET(gpmc_oen_ren), (MODE(0) | PULLUDEN)}, /* NAND_OE */ + {OFFSET(gpmc_wen), (MODE(0) | PULLUDEN)}, /* NAND_WEN */ + {OFFSET(gpmc_be0n_cle), (MODE(0) | PULLUDEN)}, /* NAND_BE_CLE */ + {-1}, +}; + +static void enable_i2c0_pin_mux(void) +{ + configure_module_pin_mux(i2c0_pin_mux); +} + +void chilisom_enable_pin_mux(void) +{ + /* chilisom pin mux */ + configure_module_pin_mux(nand_pin_mux); +} + +static const struct ddr_data ddr3_chilisom_data = { + .datardsratio0 = MT41K256M16HA125E_RD_DQS, + .datawdsratio0 = MT41K256M16HA125E_WR_DQS, + .datafwsratio0 = MT41K256M16HA125E_PHY_FIFO_WE, + .datawrsratio0 = MT41K256M16HA125E_PHY_WR_DATA, +}; + +static const struct cmd_control ddr3_chilisom_cmd_ctrl_data = { + .cmd0csratio = MT41K256M16HA125E_RATIO, + .cmd0iclkout = MT41K256M16HA125E_INVERT_CLKOUT, + + .cmd1csratio = MT41K256M16HA125E_RATIO, + .cmd1iclkout = MT41K256M16HA125E_INVERT_CLKOUT, + + .cmd2csratio = MT41K256M16HA125E_RATIO, + .cmd2iclkout = MT41K256M16HA125E_INVERT_CLKOUT, +}; + +static struct emif_regs ddr3_chilisom_emif_reg_data = { + .sdram_config = MT41K256M16HA125E_EMIF_SDCFG, + .ref_ctrl = MT41K256M16HA125E_EMIF_SDREF, + .sdram_tim1 = MT41K256M16HA125E_EMIF_TIM1, + .sdram_tim2 = MT41K256M16HA125E_EMIF_TIM2, + .sdram_tim3 = MT41K256M16HA125E_EMIF_TIM3, + .ocp_config = 0x00141414, + .zq_config = MT41K256M16HA125E_ZQ_CFG, + .emif_ddr_phy_ctlr_1 = MT41K256M16HA125E_EMIF_READ_LATENCY, +}; + +void chilisom_spl_board_init(void) +{ + int mpu_vdd; + int usb_cur_lim; + + enable_i2c0_pin_mux(); + + /* Get the frequency */ + dpll_mpu_opp100.m = am335x_get_efuse_mpu_max_freq(cdev); + + + if (i2c_probe(TPS65217_CHIP_PM)) + return; + + /* + * Increase USB current limit to 1300mA or 1800mA and set + * the MPU voltage controller as needed. + */ + if (dpll_mpu_opp100.m == MPUPLL_M_1000) { + usb_cur_lim = TPS65217_USB_INPUT_CUR_LIMIT_1800MA; + mpu_vdd = TPS65217_DCDC_VOLT_SEL_1325MV; + } else { + usb_cur_lim = TPS65217_USB_INPUT_CUR_LIMIT_1300MA; + mpu_vdd = TPS65217_DCDC_VOLT_SEL_1275MV; + } + + if (tps65217_reg_write(TPS65217_PROT_LEVEL_NONE, + TPS65217_POWER_PATH, + usb_cur_lim, + TPS65217_USB_INPUT_CUR_LIMIT_MASK)) + puts("tps65217_reg_write failure\n"); + + /* Set DCDC3 (CORE) voltage to 1.125V */ + if (tps65217_voltage_update(TPS65217_DEFDCDC3, + TPS65217_DCDC_VOLT_SEL_1125MV)) { + puts("tps65217_voltage_update failure\n"); + return; + } + /* Set CORE Frequencies to OPP100 */ + do_setup_dpll(&dpll_core_regs, &dpll_core_opp100); + + /* Set DCDC2 (MPU) voltage */ + if (tps65217_voltage_update(TPS65217_DEFDCDC2, mpu_vdd)) { + puts("tps65217_voltage_update failure\n"); + return; + } + + /* Set LDO3 to 1.8V and LDO4 to 3.3V */ + if (tps65217_reg_write(TPS65217_PROT_LEVEL_2, + TPS65217_DEFLS1, + TPS65217_LDO_VOLTAGE_OUT_1_8, + TPS65217_LDO_MASK)) + puts("tps65217_reg_write failure\n"); + + if (tps65217_reg_write(TPS65217_PROT_LEVEL_2, + TPS65217_DEFLS2, + TPS65217_LDO_VOLTAGE_OUT_3_3, + TPS65217_LDO_MASK)) + puts("tps65217_reg_write failure\n"); + + /* Set MPU Frequency to what we detected now that voltages are set */ + do_setup_dpll(&dpll_mpu_regs, &dpll_mpu_opp100); +} + +#define OSC (V_OSCK/1000000) +const struct dpll_params dpll_ddr_chilisom = { + 400, OSC-1, 1, -1, -1, -1, -1}; + +const struct dpll_params *get_dpll_ddr_params(void) +{ + return &dpll_ddr_chilisom; +} + +const struct ctrl_ioregs ioregs_chilisom = { + .cm0ioctl = MT41K256M16HA125E_IOCTRL_VALUE, + .cm1ioctl = MT41K256M16HA125E_IOCTRL_VALUE, + .cm2ioctl = MT41K256M16HA125E_IOCTRL_VALUE, + .dt0ioctl = MT41K256M16HA125E_IOCTRL_VALUE, + .dt1ioctl = MT41K256M16HA125E_IOCTRL_VALUE, +}; + +void sdram_init(void) +{ + config_ddr(400, &ioregs_chilisom, + &ddr3_chilisom_data, + &ddr3_chilisom_cmd_ctrl_data, + &ddr3_chilisom_emif_reg_data, 0); +} + +#endif /* CONFIG_SKIP_LOWLEVEL_INIT */
chiliBoard is a development board which uses chiliSOM as its base.
Hardware specification: * chiliSOM (TI AM335x, DRAM, NAND) * Ethernet PHY (id 0) * USB host (usb1) * MicroSD slot (mmc0)
Signed-off-by: Marcin Niestroj m.niestroj@grinn-global.com --- Changes v2 -> v3: * Removed USB gadget and SPL ETH references in chiliBoard code, which removed a lot of unused lines in eth initialization (suggested by Tom) * Removed SPI FLASH and SPL USB from defconfig
Changes v1 -> v2: * converted include/configs/chiliboard.h header to SPDX license identifier (suggested by Tom) * removed USB gadget, CMD_DFU options from chiliboard_defconfig
arch/arm/Kconfig | 1 + arch/arm/mach-omap2/am33xx/Kconfig | 6 ++ board/grinn/chiliboard/Kconfig | 15 +++ board/grinn/chiliboard/MAINTAINERS | 8 ++ board/grinn/chiliboard/Makefile | 6 ++ board/grinn/chiliboard/README | 31 ++++++ board/grinn/chiliboard/board.c | 206 +++++++++++++++++++++++++++++++++++ configs/chiliboard_defconfig | 45 ++++++++ include/configs/chiliboard.h | 214 +++++++++++++++++++++++++++++++++++++ 9 files changed, 532 insertions(+) create mode 100644 board/grinn/chiliboard/Kconfig create mode 100644 board/grinn/chiliboard/MAINTAINERS create mode 100644 board/grinn/chiliboard/Makefile create mode 100644 board/grinn/chiliboard/README create mode 100644 board/grinn/chiliboard/board.c create mode 100644 configs/chiliboard_defconfig create mode 100644 include/configs/chiliboard.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 2554a2cd14..3421f273b5 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1046,6 +1046,7 @@ source "board/freescale/mx53loco/Kconfig" source "board/freescale/mx53smd/Kconfig" source "board/freescale/s32v234evb/Kconfig" source "board/freescale/vf610twr/Kconfig" +source "board/grinn/chiliboard/Kconfig" source "board/gumstix/pepper/Kconfig" source "board/h2200/Kconfig" source "board/hisilicon/hikey/Kconfig" diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index b1a0f0f356..57e1a93211 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -59,6 +59,12 @@ config TARGET_BAV335X
For more information, visit: http://birdland.com/oem
+config TARGET_CHILIBOARD + bool "Grinn chiliBoard" + select AM33XX_CHILISOM + select DM + select DM_SERIAL + config TARGET_CM_T335 bool "Support cm_t335" select DM diff --git a/board/grinn/chiliboard/Kconfig b/board/grinn/chiliboard/Kconfig new file mode 100644 index 0000000000..20056e81a1 --- /dev/null +++ b/board/grinn/chiliboard/Kconfig @@ -0,0 +1,15 @@ +if TARGET_CHILIBOARD + +config SYS_BOARD + default "chiliboard" + +config SYS_VENDOR + default "grinn" + +config SYS_CONFIG_NAME + default "chiliboard" + +config SYS_SOC + default "am33xx" + +endif diff --git a/board/grinn/chiliboard/MAINTAINERS b/board/grinn/chiliboard/MAINTAINERS new file mode 100644 index 0000000000..5eaccb2791 --- /dev/null +++ b/board/grinn/chiliboard/MAINTAINERS @@ -0,0 +1,8 @@ +CHILIBOARD +M: Marcin Niestroj m.niestroj@grinn-global.com +S: Maintained +F: arch/arm/include/asm/arch-am33xx/chilisom.h +F: arch/arm/mach-omap2/am33xx/chilisom.c +F: board/grinn/chiliboard/ +F: include/configs/chiliboard.h +F: configs/chiliboard_defconfig diff --git a/board/grinn/chiliboard/Makefile b/board/grinn/chiliboard/Makefile new file mode 100644 index 0000000000..865968d1a7 --- /dev/null +++ b/board/grinn/chiliboard/Makefile @@ -0,0 +1,6 @@ +# (C) Copyright 2017 Grinn +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y := board.o diff --git a/board/grinn/chiliboard/README b/board/grinn/chiliboard/README new file mode 100644 index 0000000000..cea4c1d42e --- /dev/null +++ b/board/grinn/chiliboard/README @@ -0,0 +1,31 @@ +How to use U-Boot on Grinn's chiliBoard +-------------------------------------- + +- Build U-Boot for chiliBoard: + +$ make mrproper +$ make chiliboard_defconfig +$ make + +This will generate the SPL image called MLO and the u-boot.img. + +- Flash the SPL image into the micro SD card: + +sudo dd if=MLO of=/dev/mmcblk0 bs=128k; sync + +- Flash the u-boot.img image into the micro SD card: + +sudo dd if=u-boot.img of=/dev/mmcblk0 bs=128k seek=3; sync + +- Jumper settings: + +S2: 1 1 1 0 1 0 + +where 0 means bottom position and 1 means top position (from the +switch label numbers reference). + +- Insert the micro SD card in the board. + +- Connect USB cable between chiliBoard and the PC for the power and console. + +- U-Boot messages should come up. diff --git a/board/grinn/chiliboard/board.c b/board/grinn/chiliboard/board.c new file mode 100644 index 0000000000..e3f82b0a80 --- /dev/null +++ b/board/grinn/chiliboard/board.c @@ -0,0 +1,206 @@ +/* + * Copyright (C) 2011, Texas Instruments, Incorporated - http://www.ti.com/ + * Copyright (C) 2017, Grinn - http://grinn-global.com/ + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/chilisom.h> +#include <asm/arch/cpu.h> +#include <asm/arch/hardware.h> +#include <asm/arch/omap.h> +#include <asm/arch/mem.h> +#include <asm/arch/mmc_host_def.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/emif.h> +#include <asm/io.h> +#include <cpsw.h> +#include <environment.h> +#include <errno.h> +#include <miiphy.h> +#include <serial.h> +#include <spl.h> +#include <watchdog.h> + +DECLARE_GLOBAL_DATA_PTR; + +static __maybe_unused struct ctrl_dev *cdev = + (struct ctrl_dev *)CTRL_DEVICE_BASE; + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT +static struct module_pin_mux uart0_pin_mux[] = { + {OFFSET(uart0_rxd), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* UART0_RXD */ + {OFFSET(uart0_txd), (MODE(0) | PULLUDEN)}, /* UART0_TXD */ + {-1}, +}; + +static struct module_pin_mux mmc0_pin_mux[] = { + {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ + {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ + {OFFSET(mmc0_dat1), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT1 */ + {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */ + {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */ + {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */ + {-1}, +}; + +static struct module_pin_mux rmii1_pin_mux[] = { + {OFFSET(mii1_crs), MODE(1) | RXACTIVE}, /* RMII1_CRS */ + {OFFSET(mii1_rxerr), MODE(1) | RXACTIVE}, /* RMII1_RXERR */ + {OFFSET(mii1_txen), MODE(1)}, /* RMII1_TXEN */ + {OFFSET(mii1_txd1), MODE(1)}, /* RMII1_TXD1 */ + {OFFSET(mii1_txd0), MODE(1)}, /* RMII1_TXD0 */ + {OFFSET(mii1_rxd1), MODE(1) | RXACTIVE}, /* RMII1_RXD1 */ + {OFFSET(mii1_rxd0), MODE(1) | RXACTIVE}, /* RMII1_RXD0 */ + {OFFSET(mdio_data), MODE(0) | RXACTIVE | PULLUP_EN}, /* MDIO_DATA */ + {OFFSET(mdio_clk), MODE(0) | PULLUP_EN}, /* MDIO_CLK */ + {OFFSET(rmii1_refclk), MODE(0) | RXACTIVE}, /* RMII1_REFCLK */ + {-1}, +}; + +static void enable_board_pin_mux(void) +{ + chilisom_enable_pin_mux(); + + /* chiliboard pinmux */ + configure_module_pin_mux(rmii1_pin_mux); + configure_module_pin_mux(mmc0_pin_mux); +} +#endif /* CONFIG_SKIP_LOWLEVEL_INIT */ + +#ifndef CONFIG_DM_SERIAL +struct serial_device *default_serial_console(void) +{ + return &eserial1_device; +} +#endif + +#ifndef CONFIG_SKIP_LOWLEVEL_INIT +void set_uart_mux_conf(void) +{ + configure_module_pin_mux(uart0_pin_mux); +} + +void set_mux_conf_regs(void) +{ + enable_board_pin_mux(); +} + +void am33xx_spl_board_init(void) +{ + chilisom_spl_board_init(); +} +#endif + +/* + * Basic board specific setup. Pinmux has been handled already. + */ +int board_init(void) +{ +#if defined(CONFIG_HW_WATCHDOG) + hw_watchdog_init(); +#endif + + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; + gpmc_init(); + + return 0; +} + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ +#if !defined(CONFIG_SPL_BUILD) + uint8_t mac_addr[6]; + uint32_t mac_hi, mac_lo; + + /* try reading mac address from efuse */ + mac_lo = readl(&cdev->macid0l); + mac_hi = readl(&cdev->macid0h); + mac_addr[0] = mac_hi & 0xFF; + mac_addr[1] = (mac_hi & 0xFF00) >> 8; + mac_addr[2] = (mac_hi & 0xFF0000) >> 16; + mac_addr[3] = (mac_hi & 0xFF000000) >> 24; + mac_addr[4] = mac_lo & 0xFF; + mac_addr[5] = (mac_lo & 0xFF00) >> 8; + + if (!getenv("ethaddr")) { + printf("<ethaddr> not set. Validating first E-fuse MAC\n"); + + if (is_valid_ethaddr(mac_addr)) + eth_setenv_enetaddr("ethaddr", mac_addr); + } + + mac_lo = readl(&cdev->macid1l); + mac_hi = readl(&cdev->macid1h); + mac_addr[0] = mac_hi & 0xFF; + mac_addr[1] = (mac_hi & 0xFF00) >> 8; + mac_addr[2] = (mac_hi & 0xFF0000) >> 16; + mac_addr[3] = (mac_hi & 0xFF000000) >> 24; + mac_addr[4] = mac_lo & 0xFF; + mac_addr[5] = (mac_lo & 0xFF00) >> 8; + + if (!getenv("eth1addr")) { + if (is_valid_ethaddr(mac_addr)) + eth_setenv_enetaddr("eth1addr", mac_addr); + } +#endif + + return 0; +} +#endif + +#if !defined(CONFIG_DM_ETH) && defined(CONFIG_DRIVER_TI_CPSW) && \ + !defined(CONFIG_SPL_BUILD) +static void cpsw_control(int enabled) +{ + /* VTP can be added here */ + + return; +} + +static struct cpsw_slave_data cpsw_slaves[] = { + { + .slave_reg_ofs = 0x208, + .sliver_reg_ofs = 0xd80, + .phy_addr = 0, + } +}; + +static struct cpsw_platform_data cpsw_data = { + .mdio_base = CPSW_MDIO_BASE, + .cpsw_base = CPSW_BASE, + .mdio_div = 0xff, + .channels = 8, + .cpdma_reg_ofs = 0x800, + .slaves = 1, + .slave_data = cpsw_slaves, + .ale_reg_ofs = 0xd00, + .ale_entries = 1024, + .host_port_reg_ofs = 0x108, + .hw_stats_reg_ofs = 0x900, + .bd_ram_ofs = 0x2000, + .mac_control = (1 << 5), + .control = cpsw_control, + .host_port_num = 0, + .version = CPSW_CTRL_VERSION_2, +}; + +int board_eth_init(bd_t *bis) +{ + int rv, n = 0; + + writel(RMII_MODE_ENABLE | RMII_CHIPCKL_ENABLE, &cdev->miisel); + cpsw_slaves[0].phy_if = PHY_INTERFACE_MODE_RMII; + + rv = cpsw_register(&cpsw_data); + if (rv < 0) + printf("Error %d registering CPSW switch\n", rv); + else + n += rv; + + return n; +} +#endif diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig new file mode 100644 index 0000000000..4e94214204 --- /dev/null +++ b/configs/chiliboard_defconfig @@ -0,0 +1,45 @@ +CONFIG_ARM=y +CONFIG_AM33XX=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_POWER_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_TARGET_CHILIBOARD=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_FIT=y +CONFIG_BOOTDELAY=1 +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL=y +CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_ASKENV=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_GPIO=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_DM_GPIO=y +CONFIG_MMC_OMAP_HS=y +CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y +CONFIG_USB_STORAGE=y +CONFIG_OF_LIBFDT=y diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h new file mode 100644 index 0000000000..04ee3a1d3c --- /dev/null +++ b/include/configs/chiliboard.h @@ -0,0 +1,214 @@ +/* + * Copyright (C) 2017 Grinn - http://grinn-global.com/ + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_CHILIBOARD_H +#define __CONFIG_CHILIBOARD_H + +#define CONFIG_NAND + +#include <configs/ti_am335x_common.h> + +#define CONFIG_CONS_INDEX 1 + +#ifndef CONFIG_SPL_BUILD +# define CONFIG_TIMESTAMP +# define CONFIG_LZO +#endif + +/* Clock Defines */ +#define V_OSCK 24000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK) + +#define NANDARGS \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \ + "nandargs=setenv bootargs console=${console} ${optargs} " \ + "${mtdparts} " \ + "root=${nandroot} " \ + "rootfstype=${nandrootfstype}\0" \ + "nandroot=ubi0:rootfs rw ubi.mtd=NAND.file-system\0" \ + "nandrootfstype=ubifs rootwait=1\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${fdt_addr} NAND.u-boot-spl-os; " \ + "nand read ${loadaddr} NAND.kernel; " \ + "bootz ${loadaddr} - ${fdt_addr}\0" + +#define CONFIG_BOOTCOMMAND \ + "run mmcboot; " \ + "run nandboot; " \ + "run netboot" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "fdt_addr=0x87800000\0" \ + "boot_fdt=try\0" \ + "console=ttyO0,115200n8\0" \ + "image=zImage\0" \ + "fdt_file=am335x-chiliboard.dtb\0" \ + "ip_dyn=yes\0" \ + "optargs=\0" \ + "loadbootscript=" \ + "load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "loadimage=load mmc ${mmcdev}:${mmcpart} ${loadaddr} " \ + "${boot_dir}/${image}\0" \ + "loadfdt=load mmc ${mmcdev}:${mmcpart} ${fdt_addr} " \ + "${boot_dir}/${fdt_file}\0" \ + "mmcdev=0\0" \ + "mmcpart=1\0" \ + "mmcroot=/dev/mmcblk0p2 rootwait rw\0" \ + "mmcargs=setenv bootargs console=${console},${baudrate} ${optargs} " \ + "${mtdparts} " \ + "root=${mmcroot}\0" \ + "mmcloados=run mmcargs; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if run loadfdt; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + "mmcboot=mmc dev ${mmcdev}; " \ + "if mmc rescan; then " \ + "echo SD/MMC found on device ${mmcdev};" \ + "if run loadimage; then " \ + "run mmcloados;" \ + "fi;" \ + "fi;\0" \ + "netargs=setenv bootargs console=${console},${baudrate} ${optargs} " \ + "${mtdparts} " \ + "root=/dev/nfs " \ + "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ + "netboot=echo Booting from net ...; " \ + "run netargs; " \ + "if test ${ip_dyn} = yes; then " \ + "setenv get_cmd dhcp; " \ + "else " \ + "setenv get_cmd tftp; " \ + "fi; " \ + "${get_cmd} ${image}; " \ + "if test ${boot_fdt} = yes || test ${boot_fdt} = try; then " \ + "if ${get_cmd} ${fdt_addr} ${fdt_file}; then " \ + "bootz ${loadaddr} - ${fdt_addr}; " \ + "else " \ + "if test ${boot_fdt} = try; then " \ + "bootz; " \ + "else " \ + "echo WARN: Cannot load the DT; " \ + "fi; " \ + "fi; " \ + "else " \ + "bootz; " \ + "fi;\0" \ + NANDARGS + +/* NS16550 Configuration */ +#define CONFIG_SYS_NS16550_COM1 0x44e09000 /* UART0 */ +#define CONFIG_SYS_NS16550_COM2 0x48022000 /* UART1 */ +#define CONFIG_SYS_NS16550_COM3 0x48024000 /* UART2 */ +#define CONFIG_SYS_NS16550_COM4 0x481a6000 /* UART3 */ +#define CONFIG_SYS_NS16550_COM5 0x481a8000 /* UART4 */ +#define CONFIG_SYS_NS16550_COM6 0x481aa000 /* UART5 */ +#define CONFIG_BAUDRATE 115200 + +/* PMIC support */ +#define CONFIG_POWER_TPS65217 + +/* SPL */ +/* Bootcount using the RTC block */ +#define CONFIG_BOOTCOUNT_LIMIT +#define CONFIG_BOOTCOUNT_AM33XX +#define CONFIG_SYS_BOOTCOUNT_BE + +#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/am33xx/u-boot-spl.lds" + +/* NAND: device related configs */ +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +/* NAND: driver related configs */ +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_NAND_OMAP_GPMC_PREFETCH +#define CONFIG_NAND_OMAP_ELM +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW +#define MTDIDS_DEFAULT "nand0=8000000.nand" +#define MTDPARTS_DEFAULT "mtdparts=8000000.nand:" \ + "128k(NAND.SPL)," \ + "128k(NAND.SPL.backup1)," \ + "128k(NAND.SPL.backup2)," \ + "128k(NAND.SPL.backup3)," \ + "256k(NAND.u-boot-spl-os)," \ + "1m(NAND.u-boot)," \ + "128k(NAND.u-boot-env)," \ + "128k(NAND.u-boot-env.backup1)," \ + "8m(NAND.kernel)," \ + "-(NAND.file-system)" +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 +/* NAND: SPL related configs */ +#ifdef CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_AM33XX_BCH +#endif + +/* USB configuration */ +#define CONFIG_USB_MUSB_DSPS +#define CONFIG_ARCH_MISC_INIT +#define CONFIG_USB_MUSB_PIO_ONLY +#define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT +#define CONFIG_AM335X_USB1 +#define CONFIG_AM335X_USB1_MODE MUSB_HOST + +/* + * Disable MMC DM for SPL build and can be re-enabled after adding + * DM support in SPL + */ +#ifdef CONFIG_SPL_BUILD +#undef CONFIG_DM_MMC +#undef CONFIG_TIMER +#undef CONFIG_DM_USB +#endif + +#if defined(CONFIG_ENV_IS_IN_NAND) +#define CONFIG_ENV_OFFSET 0x001c0000 +#define CONFIG_ENV_OFFSET_REDUND 0x001e0000 +#define CONFIG_ENV_SIZE SZ_128K +#define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE +#else +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_OFFSET SZ_128K +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE SZ_8K +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT +#endif + +/* Network. */ +#define CONFIG_PHYLIB +#define CONFIG_PHY_SMSC + +#endif /* ! __CONFIG_CHILIBOARD_H */
Marcin Niestroj
