[PATCH v10 0/4] Boot variables management for removable media
Major changes: 1.Rename and move bootorder and bootoption apis from cmd to lib for re-use between eficonfig and bootmgr 2.Fix incorrect return code of boot option update Correct the return code for out-of-memory and no boot option found 3.Changes for complying to EFI spec §3.5.1.1 'Removable Media Boot Behavior'. Boot variables can be automatically generated during a removable media is probed. At the same time, unused boot variables will be detected and removed. 4.The boot variables automatically generated for removable medias should be with short form of device path without device nodes. This is a requirement for the case that a removable media is plugged into a different port but is still able to work with the existing boot variables.
Raymond Mao (4): Move bootorder and bootoption apis to lib Fix incorrect return code of boot option update Boot var automatic management for removable medias Load option with short device path for boot vars
cmd/bootmenu.c | 4 +- cmd/eficonfig.c | 410 +---------------------------------- include/efi_config.h | 5 - include/efi_loader.h | 11 + lib/efi_loader/efi_bootmgr.c | 385 ++++++++++++++++++++++++++++++++ lib/efi_loader/efi_disk.c | 18 ++ lib/efi_loader/efi_helper.c | 25 +++ lib/efi_loader/efi_setup.c | 7 + 8 files changed, 455 insertions(+), 410 deletions(-)
Rename and move bootorder and bootoption apis from cmd to lib for re-use between eficonfig and bootmgr Fix 'unexpected indentation' when 'make htmldocs' after functions are moved
Signed-off-by: Raymond Mao raymond.mao@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes in v3 - Split the patch into moving and renaming functions and individual patches for each changed functionality Changes in v6 - Revert v3 changes in function efi_bootmgr_update_media_device_boot_option and efi_bootmgr_delete_invalid_boot_option Changes in v8 - Fix 'unexpected indentation' when 'make htmldocs'
cmd/bootmenu.c | 2 +- cmd/eficonfig.c | 408 +---------------------------------- include/efi_config.h | 5 - include/efi_loader.h | 11 + lib/efi_loader/efi_bootmgr.c | 375 ++++++++++++++++++++++++++++++++ lib/efi_loader/efi_helper.c | 25 +++ 6 files changed, 418 insertions(+), 408 deletions(-)
diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 6baeedc69f..01daddca7b 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -351,7 +351,7 @@ static struct bootmenu_data *bootmenu_create(int delay) * UEFI specification requires booting from removal media using * a architecture-specific default image name such as BOOTAA64.EFI. */ - efi_ret = eficonfig_generate_media_device_boot_option(); + efi_ret = efi_bootmgr_update_media_device_boot_option(); if (efi_ret != EFI_SUCCESS && efi_ret != EFI_NOT_FOUND) goto cleanup;
diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index 720f52b48b..82a80306f4 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -1134,43 +1134,6 @@ out: return ret; }
-/** - * eficonfig_get_unused_bootoption() - get unused "Boot####" index - * - * @buf: pointer to the buffer to store boot option variable name - * @buf_size: buffer size - * @index: pointer to store the index in the BootOrder variable - * Return: status code - */ -efi_status_t eficonfig_get_unused_bootoption(u16 *buf, efi_uintn_t buf_size, - unsigned int *index) -{ - u32 i; - efi_status_t ret; - efi_uintn_t size; - - if (buf_size < u16_strsize(u"Boot####")) - return EFI_BUFFER_TOO_SMALL; - - for (i = 0; i <= 0xFFFF; i++) { - size = 0; - efi_create_indexed_name(buf, buf_size, "Boot", i); - ret = efi_get_variable_int(buf, &efi_global_variable_guid, - NULL, &size, NULL, NULL); - if (ret == EFI_BUFFER_TOO_SMALL) - continue; - else - break; - } - - if (i > 0xFFFF) - return EFI_OUT_OF_RESOURCES; - - *index = i; - - return EFI_SUCCESS; -} - /** * eficonfig_set_boot_option() - set boot option * @@ -1208,46 +1171,6 @@ static efi_status_t eficonfig_set_boot_option(u16 *varname, struct efi_device_pa return ret; }
-/** - * eficonfig_append_bootorder() - append new boot option in BootOrder variable - * - * @index: "Boot####" index to append to BootOrder variable - * Return: status code - */ -efi_status_t eficonfig_append_bootorder(u16 index) -{ - u16 *bootorder; - efi_status_t ret; - u16 *new_bootorder = NULL; - efi_uintn_t last, size, new_size; - - /* append new boot option */ - bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); - last = size / sizeof(u16); - new_size = size + sizeof(u16); - new_bootorder = calloc(1, new_size); - if (!new_bootorder) { - ret = EFI_OUT_OF_RESOURCES; - goto out; - } - memcpy(new_bootorder, bootorder, size); - new_bootorder[last] = index; - - ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, - EFI_VARIABLE_NON_VOLATILE | - EFI_VARIABLE_BOOTSERVICE_ACCESS | - EFI_VARIABLE_RUNTIME_ACCESS, - new_size, new_bootorder, false); - if (ret != EFI_SUCCESS) - goto out; - -out: - free(bootorder); - free(new_bootorder); - - return ret; -} - /** * create_boot_option_entry() - create boot option entry * @@ -1619,7 +1542,7 @@ static efi_status_t eficonfig_process_add_boot_option(void *data) if (!bo) return EFI_OUT_OF_RESOURCES;
- ret = eficonfig_get_unused_bootoption(varname, sizeof(varname), &bo->boot_index); + ret = efi_bootmgr_get_unused_bootoption(varname, sizeof(varname), &bo->boot_index); if (ret != EFI_SUCCESS) return ret;
@@ -1627,7 +1550,7 @@ static efi_status_t eficonfig_process_add_boot_option(void *data) if (ret != EFI_SUCCESS) goto out;
- ret = eficonfig_append_bootorder((u16)bo->boot_index); + ret = efi_bootmgr_append_bootorder((u16)bo->boot_index); if (ret != EFI_SUCCESS) goto out;
@@ -1656,31 +1579,6 @@ static efi_status_t eficonfig_process_boot_selected(void *data) return EFI_SUCCESS; }
-/** - * search_bootorder() - search the boot option index in BootOrder - * - * @bootorder: pointer to the BootOrder variable - * @num: number of BootOrder entry - * @target: target boot option index to search - * @index: pointer to store the index of BootOrder variable - * Return: true if exists, false otherwise - */ -static bool search_bootorder(u16 *bootorder, efi_uintn_t num, u32 target, u32 *index) -{ - u32 i; - - for (i = 0; i < num; i++) { - if (target == bootorder[i]) { - if (index) - *index = i; - - return true; - } - } - - return false; -} - /** * eficonfig_add_boot_selection_entry() - add boot option menu entry * @@ -1805,7 +1703,7 @@ static efi_status_t eficonfig_show_boot_selection(unsigned int *selected)
if (efi_varname_is_load_option(var_name16, &index)) { /* If the index is included in the BootOrder, skip it */ - if (search_bootorder(bootorder, num, index, NULL)) + if (efi_search_bootorder(bootorder, num, index, NULL)) continue;
ret = eficonfig_add_boot_selection_entry(efi_menu, index, selected); @@ -2202,7 +2100,7 @@ static efi_status_t eficonfig_create_change_boot_order_entry(struct efimenu *efi
ret = eficonfig_add_change_boot_order_entry(efi_menu, index, false); @@ -2304,50 +2202,6 @@ out: return ret; }
-/** - * delete_boot_option() - delete selected boot option - * - * @boot_index: boot option index to delete - * Return: status code - */ -static efi_status_t delete_boot_option(u16 boot_index) -{ - u16 *bootorder; - u16 varname[9]; - efi_status_t ret; - unsigned int index; - efi_uintn_t num, size; - - efi_create_indexed_name(varname, sizeof(varname), - "Boot", boot_index); - ret = efi_set_variable_int(varname, &efi_global_variable_guid, - 0, 0, NULL, false); - if (ret != EFI_SUCCESS) { - log_err("delete boot option(%ls) failed\n", varname); - return ret; - } - - /* update BootOrder if necessary */ - bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); - if (!bootorder) - return EFI_SUCCESS; - - num = size / sizeof(u16); - if (!search_bootorder(bootorder, num, boot_index, &index)) - return EFI_SUCCESS; - - memmove(&bootorder[index], &bootorder[index + 1], - (num - index - 1) * sizeof(u16)); - size -= sizeof(u16); - ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, - EFI_VARIABLE_NON_VOLATILE | - EFI_VARIABLE_BOOTSERVICE_ACCESS | - EFI_VARIABLE_RUNTIME_ACCESS, - size, bootorder, false); - - return ret; -} - /** * eficonfig_process_delete_boot_option() - handler to delete boot option * @@ -2362,7 +2216,7 @@ static efi_status_t eficonfig_process_delete_boot_option(void *data) while (1) { ret = eficonfig_show_boot_selection(&selected); if (ret == EFI_SUCCESS) - ret = delete_boot_option(selected); + ret = efi_bootmgr_delete_boot_option(selected);
if (ret != EFI_SUCCESS) break; @@ -2374,256 +2228,6 @@ static efi_status_t eficonfig_process_delete_boot_option(void *data) return ret; }
-/** - * eficonfig_enumerate_boot_option() - enumerate the possible bootable media - * - * @opt: pointer to the media boot option structure - * @volume_handles: pointer to the efi handles - * @count: number of efi handle - * Return: status code - */ -efi_status_t eficonfig_enumerate_boot_option(struct eficonfig_media_boot_option *opt, - efi_handle_t *volume_handles, efi_status_t count) -{ - u32 i; - struct efi_handler *handler; - efi_status_t ret = EFI_SUCCESS; - - for (i = 0; i < count; i++) { - u16 *p; - u16 dev_name[BOOTMENU_DEVICE_NAME_MAX]; - char *optional_data; - struct efi_load_option lo; - char buf[BOOTMENU_DEVICE_NAME_MAX]; - struct efi_device_path *device_path; - - ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); - if (ret != EFI_SUCCESS) - continue; - ret = efi_protocol_open(handler, (void **)&device_path, - efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); - if (ret != EFI_SUCCESS) - continue; - - ret = efi_disk_get_device_name(volume_handles[i], buf, BOOTMENU_DEVICE_NAME_MAX); - if (ret != EFI_SUCCESS) - continue; - - p = dev_name; - utf8_utf16_strncpy(&p, buf, strlen(buf)); - - lo.label = dev_name; - lo.attributes = LOAD_OPTION_ACTIVE; - lo.file_path = device_path; - lo.file_path_length = efi_dp_size(device_path) + sizeof(END); - /* - * Set the dedicated guid to optional_data, it is used to identify - * the boot option that automatically generated by the bootmenu. - * efi_serialize_load_option() expects optional_data is null-terminated - * utf8 string, so set the "1234567" string to allocate enough space - * to store guid, instead of realloc the load_option. - */ - lo.optional_data = "1234567"; - opt[i].size = efi_serialize_load_option(&lo, (u8 **)&opt[i].lo); - if (!opt[i].size) { - ret = EFI_OUT_OF_RESOURCES; - goto out; - } - /* set the guid */ - optional_data = (char *)opt[i].lo + (opt[i].size - u16_strsize(u"1234567")); - memcpy(optional_data, &efi_guid_bootmenu_auto_generated, sizeof(efi_guid_t)); - } - -out: - return ret; -} - -/** - * eficonfig_delete_invalid_boot_option() - delete non-existing boot option - * - * @opt: pointer to the media boot option structure - * @count: number of media boot option structure - * Return: status code - */ -efi_status_t eficonfig_delete_invalid_boot_option(struct eficonfig_media_boot_option *opt, - efi_status_t count) -{ - efi_uintn_t size; - void *load_option; - u32 i, list_size = 0; - struct efi_load_option lo; - u16 *var_name16 = NULL; - u16 varname[] = u"Boot####"; - efi_status_t ret = EFI_SUCCESS; - u16 *delete_index_list = NULL, *p; - efi_uintn_t buf_size; - - buf_size = 128; - var_name16 = malloc(buf_size); - if (!var_name16) - return EFI_OUT_OF_RESOURCES; - - var_name16[0] = 0; - for (;;) { - int index; - efi_guid_t guid; - efi_uintn_t tmp; - - ret = efi_next_variable_name(&buf_size, &var_name16, &guid); - if (ret == EFI_NOT_FOUND) { - /* - * EFI_NOT_FOUND indicates we retrieved all EFI variables. - * This should be treated as success. - */ - ret = EFI_SUCCESS; - break; - } - if (ret != EFI_SUCCESS) - goto out; - - if (!efi_varname_is_load_option(var_name16, &index)) - continue; - - efi_create_indexed_name(varname, sizeof(varname), "Boot", index); - load_option = efi_get_var(varname, &efi_global_variable_guid, &size); - if (!load_option) - continue; - - tmp = size; - ret = efi_deserialize_load_option(&lo, load_option, &size); - if (ret != EFI_SUCCESS) - goto next; - - if (size >= sizeof(efi_guid_bootmenu_auto_generated) && - !guidcmp(lo.optional_data, &efi_guid_bootmenu_auto_generated)) { - for (i = 0; i < count; i++) { - if (opt[i].size == tmp && - memcmp(opt[i].lo, load_option, tmp) == 0) { - opt[i].exist = true; - break; - } - } - - /* - * The entire list of variables must be retrieved by - * efi_get_next_variable_name_int() before deleting the invalid - * boot option, just save the index here. - */ - if (i == count) { - p = realloc(delete_index_list, sizeof(u32) * - (list_size + 1)); - if (!p) { - ret = EFI_OUT_OF_RESOURCES; - goto out; - } - delete_index_list = p; - delete_index_list[list_size++] = index; - } - } -next: - free(load_option); - } - - /* delete all invalid boot options */ - for (i = 0; i < list_size; i++) { - ret = delete_boot_option(delete_index_list[i]); - if (ret != EFI_SUCCESS) - goto out; - } - -out: - free(var_name16); - free(delete_index_list); - - return ret; -} - -/** - * eficonfig_generate_media_device_boot_option() - generate the media device boot option - * - * This function enumerates all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL - * and generate the bootmenu entries. - * This function also provide the BOOT#### variable maintenance for - * the media device entries. - * - Automatically create the BOOT#### variable for the newly detected device, - * this BOOT#### variable is distinguished by the special GUID - * stored in the EFI_LOAD_OPTION.optional_data - * - If the device is not attached to the system, the associated BOOT#### variable - * is automatically deleted. - * - * Return: status code - */ -efi_status_t eficonfig_generate_media_device_boot_option(void) -{ - u32 i; - efi_status_t ret; - efi_uintn_t count; - efi_handle_t *volume_handles = NULL; - struct eficonfig_media_boot_option *opt = NULL; - - ret = efi_locate_handle_buffer_int(BY_PROTOCOL, &efi_simple_file_system_protocol_guid, - NULL, &count, (efi_handle_t **)&volume_handles); - if (ret != EFI_SUCCESS) - return ret; - - opt = calloc(count, sizeof(struct eficonfig_media_boot_option)); - if (!opt) - goto out; - - /* enumerate all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL */ - ret = eficonfig_enumerate_boot_option(opt, volume_handles, count); - if (ret != EFI_SUCCESS) - goto out; - - /* - * System hardware configuration may vary depending on the user setup. - * The boot option is automatically added by the bootmenu. - * If the device is not attached to the system, the boot option needs - * to be deleted. - */ - ret = eficonfig_delete_invalid_boot_option(opt, count); - if (ret != EFI_SUCCESS) - goto out; - - /* add non-existent boot option */ - for (i = 0; i < count; i++) { - u32 boot_index; - u16 var_name[9]; - - if (!opt[i].exist) { - ret = eficonfig_get_unused_bootoption(var_name, sizeof(var_name), - &boot_index); - if (ret != EFI_SUCCESS) - goto out; - - ret = efi_set_variable_int(var_name, &efi_global_variable_guid, - EFI_VARIABLE_NON_VOLATILE | - EFI_VARIABLE_BOOTSERVICE_ACCESS | - EFI_VARIABLE_RUNTIME_ACCESS, - opt[i].size, opt[i].lo, false); - if (ret != EFI_SUCCESS) - goto out; - - ret = eficonfig_append_bootorder(boot_index); - if (ret != EFI_SUCCESS) { - efi_set_variable_int(var_name, &efi_global_variable_guid, - 0, 0, NULL, false); - goto out; - } - } - } - -out: - if (opt) { - for (i = 0; i < count; i++) - free(opt[i].lo); - } - free(opt); - efi_free_pool(volume_handles); - - return ret; -} - /** * eficonfig_init() - do required initialization for eficonfig command * @@ -2709,7 +2313,7 @@ static int do_eficonfig(struct cmd_tbl *cmdtp, int flag, int argc, char *const a if (ret != EFI_SUCCESS) return CMD_RET_FAILURE;
- ret = eficonfig_generate_media_device_boot_option(); + ret = efi_bootmgr_update_media_device_boot_option(); if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) return ret;
diff --git a/include/efi_config.h b/include/efi_config.h index 01ce9b2b06..d7c1601137 100644 --- a/include/efi_config.h +++ b/include/efi_config.h @@ -105,11 +105,6 @@ efi_status_t eficonfig_process_common(struct efimenu *efi_menu, void (*item_data_print)(void *), char *(*item_choice)(void *)); efi_status_t eficonfig_process_select_file(void *data); -efi_status_t eficonfig_get_unused_bootoption(u16 *buf, - efi_uintn_t buf_size, u32 *index); -efi_status_t eficonfig_append_bootorder(u16 index); -efi_status_t eficonfig_generate_media_device_boot_option(void); - efi_status_t eficonfig_append_menu_entry(struct efimenu *efi_menu, char *title, eficonfig_entry_func func, void *data); diff --git a/include/efi_loader.h b/include/efi_loader.h index 1542b4b625..31ca1f5d1d 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -516,6 +516,17 @@ extern struct list_head efi_register_notify_events; int efi_init_early(void); /* Initialize efi execution environment */ efi_status_t efi_init_obj_list(void); +/* Append new boot option in BootOrder variable */ +efi_status_t efi_bootmgr_append_bootorder(u16 index); +/* Get unused "Boot####" index */ +efi_status_t efi_bootmgr_get_unused_bootoption(u16 *buf, + efi_uintn_t buf_size, u32 *index); +/* Generate the media device boot option */ +efi_status_t efi_bootmgr_update_media_device_boot_option(void); +/* Delete selected boot option */ +efi_status_t efi_bootmgr_delete_boot_option(u16 boot_index); +/* search the boot option index in BootOrder */ +bool efi_search_bootorder(u16 *bootorder, efi_uintn_t num, u32 target, u32 *index); /* Set up console modes */ void efi_setup_console_size(void); /* Install device tree */ diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 4b24b41047..97d5b8dc2b 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -347,3 +347,378 @@ efi_status_t efi_bootmgr_load(efi_handle_t *handle, void **load_options) error: return ret; } + +/** + * efi_bootmgr_enumerate_boot_option() - enumerate the possible bootable media + * + * @opt: pointer to the media boot option structure + * @volume_handles: pointer to the efi handles + * @count: number of efi handle + * Return: status code + */ +static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boot_option *opt, + efi_handle_t *volume_handles, + efi_status_t count) +{ + u32 i; + struct efi_handler *handler; + efi_status_t ret = EFI_SUCCESS; + + for (i = 0; i < count; i++) { + u16 *p; + u16 dev_name[BOOTMENU_DEVICE_NAME_MAX]; + char *optional_data; + struct efi_load_option lo; + char buf[BOOTMENU_DEVICE_NAME_MAX]; + struct efi_device_path *device_path; + + ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); + if (ret != EFI_SUCCESS) + continue; + ret = efi_protocol_open(handler, (void **)&device_path, + efi_root, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); + if (ret != EFI_SUCCESS) + continue; + + ret = efi_disk_get_device_name(volume_handles[i], buf, BOOTMENU_DEVICE_NAME_MAX); + if (ret != EFI_SUCCESS) + continue; + + p = dev_name; + utf8_utf16_strncpy(&p, buf, strlen(buf)); + + lo.label = dev_name; + lo.attributes = LOAD_OPTION_ACTIVE; + lo.file_path = device_path; + lo.file_path_length = efi_dp_size(device_path) + sizeof(END); + /* + * Set the dedicated guid to optional_data, it is used to identify + * the boot option that automatically generated by the bootmenu. + * efi_serialize_load_option() expects optional_data is null-terminated + * utf8 string, so set the "1234567" string to allocate enough space + * to store guid, instead of realloc the load_option. + */ + lo.optional_data = "1234567"; + opt[i].size = efi_serialize_load_option(&lo, (u8 **)&opt[i].lo); + if (!opt[i].size) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + /* set the guid */ + optional_data = (char *)opt[i].lo + (opt[i].size - u16_strsize(u"1234567")); + memcpy(optional_data, &efi_guid_bootmenu_auto_generated, sizeof(efi_guid_t)); + } + +out: + return ret; +} + +/** + * efi_bootmgr_delete_invalid_boot_option() - delete non-existing boot option + * + * @opt: pointer to the media boot option structure + * @count: number of media boot option structure + * Return: status code + */ +static efi_status_t efi_bootmgr_delete_invalid_boot_option(struct eficonfig_media_boot_option *opt, + efi_status_t count) +{ + efi_uintn_t size; + void *load_option; + u32 i, list_size = 0; + struct efi_load_option lo; + u16 *var_name16 = NULL; + u16 varname[] = u"Boot####"; + efi_status_t ret = EFI_SUCCESS; + u16 *delete_index_list = NULL, *p; + efi_uintn_t buf_size; + + buf_size = 128; + var_name16 = malloc(buf_size); + if (!var_name16) + return EFI_OUT_OF_RESOURCES; + + var_name16[0] = 0; + for (;;) { + int index; + efi_guid_t guid; + efi_uintn_t tmp; + + ret = efi_next_variable_name(&buf_size, &var_name16, &guid); + if (ret == EFI_NOT_FOUND) { + /* + * EFI_NOT_FOUND indicates we retrieved all EFI variables. + * This should be treated as success. + */ + ret = EFI_SUCCESS; + break; + } + + if (ret != EFI_SUCCESS) + goto out; + + if (!efi_varname_is_load_option(var_name16, &index)) + continue; + + efi_create_indexed_name(varname, sizeof(varname), "Boot", index); + load_option = efi_get_var(varname, &efi_global_variable_guid, &size); + if (!load_option) + continue; + + tmp = size; + ret = efi_deserialize_load_option(&lo, load_option, &size); + if (ret != EFI_SUCCESS) + goto next; + + if (size >= sizeof(efi_guid_bootmenu_auto_generated) && + !guidcmp(lo.optional_data, &efi_guid_bootmenu_auto_generated)) { + for (i = 0; i < count; i++) { + if (opt[i].size == tmp && + memcmp(opt[i].lo, load_option, tmp) == 0) { + opt[i].exist = true; + break; + } + } + + /* + * The entire list of variables must be retrieved by + * efi_get_next_variable_name_int() before deleting the invalid + * boot option, just save the index here. + */ + if (i == count) { + p = realloc(delete_index_list, sizeof(u32) * + (list_size + 1)); + if (!p) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + delete_index_list = p; + delete_index_list[list_size++] = index; + } + } +next: + free(load_option); + } + + /* delete all invalid boot options */ + for (i = 0; i < list_size; i++) { + ret = efi_bootmgr_delete_boot_option(delete_index_list[i]); + if (ret != EFI_SUCCESS) + goto out; + } + +out: + free(var_name16); + free(delete_index_list); + + return ret; +} + +/** + * efi_bootmgr_get_unused_bootoption() - get unused "Boot####" index + * + * @buf: pointer to the buffer to store boot option variable name + * @buf_size: buffer size + * @index: pointer to store the index in the BootOrder variable + * Return: status code + */ +efi_status_t efi_bootmgr_get_unused_bootoption(u16 *buf, efi_uintn_t buf_size, + unsigned int *index) +{ + u32 i; + efi_status_t ret; + efi_uintn_t size; + + if (buf_size < u16_strsize(u"Boot####")) + return EFI_BUFFER_TOO_SMALL; + + for (i = 0; i <= 0xFFFF; i++) { + size = 0; + efi_create_indexed_name(buf, buf_size, "Boot", i); + ret = efi_get_variable_int(buf, &efi_global_variable_guid, + NULL, &size, NULL, NULL); + if (ret == EFI_BUFFER_TOO_SMALL) + continue; + else + break; + } + + if (i > 0xFFFF) + return EFI_OUT_OF_RESOURCES; + + *index = i; + + return EFI_SUCCESS; +} + +/** + * efi_bootmgr_append_bootorder() - append new boot option in BootOrder variable + * + * @index: "Boot####" index to append to BootOrder variable + * Return: status code + */ +efi_status_t efi_bootmgr_append_bootorder(u16 index) +{ + u16 *bootorder; + efi_status_t ret; + u16 *new_bootorder = NULL; + efi_uintn_t last, size, new_size; + + /* append new boot option */ + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + last = size / sizeof(u16); + new_size = size + sizeof(u16); + new_bootorder = calloc(1, new_size); + if (!new_bootorder) { + ret = EFI_OUT_OF_RESOURCES; + goto out; + } + memcpy(new_bootorder, bootorder, size); + new_bootorder[last] = index; + + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + new_size, new_bootorder, false); + if (ret != EFI_SUCCESS) + goto out; + +out: + free(bootorder); + free(new_bootorder); + + return ret; +} + +/** + * efi_bootmgr_delete_boot_option() - delete selected boot option + * + * @boot_index: boot option index to delete + * Return: status code + */ +efi_status_t efi_bootmgr_delete_boot_option(u16 boot_index) +{ + u16 *bootorder; + u16 varname[9]; + efi_status_t ret; + unsigned int index; + efi_uintn_t num, size; + + efi_create_indexed_name(varname, sizeof(varname), + "Boot", boot_index); + ret = efi_set_variable_int(varname, &efi_global_variable_guid, + 0, 0, NULL, false); + if (ret != EFI_SUCCESS) { + log_err("delete boot option(%ls) failed\n", varname); + return ret; + } + + /* update BootOrder if necessary */ + bootorder = efi_get_var(u"BootOrder", &efi_global_variable_guid, &size); + if (!bootorder) + return EFI_SUCCESS; + + num = size / sizeof(u16); + if (!efi_search_bootorder(bootorder, num, boot_index, &index)) + return EFI_SUCCESS; + + memmove(&bootorder[index], &bootorder[index + 1], + (num - index - 1) * sizeof(u16)); + size -= sizeof(u16); + ret = efi_set_variable_int(u"BootOrder", &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + size, bootorder, false); + + return ret; +} + +/** + * efi_bootmgr_update_media_device_boot_option() - generate the media device boot option + * + * This function enumerates all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL + * and generate the bootmenu entries. + * This function also provide the BOOT#### variable maintenance for + * the media device entries. + * - Automatically create the BOOT#### variable for the newly detected device, + * this BOOT#### variable is distinguished by the special GUID + * stored in the EFI_LOAD_OPTION.optional_data + * - If the device is not attached to the system, the associated BOOT#### variable + * is automatically deleted. + * + * Return: status code + */ +efi_status_t efi_bootmgr_update_media_device_boot_option(void) +{ + u32 i; + efi_status_t ret; + efi_uintn_t count; + efi_handle_t *volume_handles = NULL; + struct eficonfig_media_boot_option *opt = NULL; + + ret = efi_locate_handle_buffer_int(BY_PROTOCOL, + &efi_simple_file_system_protocol_guid, + NULL, &count, + (efi_handle_t **)&volume_handles); + if (ret != EFI_SUCCESS) + return ret; + + opt = calloc(count, sizeof(struct eficonfig_media_boot_option)); + if (!opt) + goto out; + + /* enumerate all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL */ + ret = efi_bootmgr_enumerate_boot_option(opt, volume_handles, count); + if (ret != EFI_SUCCESS) + goto out; + + /* + * System hardware configuration may vary depending on the user setup. + * The boot option is automatically added by the bootmenu. + * If the device is not attached to the system, the boot option needs + * to be deleted. + */ + ret = efi_bootmgr_delete_invalid_boot_option(opt, count); + if (ret != EFI_SUCCESS) + goto out; + + /* add non-existent boot option */ + for (i = 0; i < count; i++) { + u32 boot_index; + u16 var_name[9]; + + if (!opt[i].exist) { + ret = efi_bootmgr_get_unused_bootoption(var_name, sizeof(var_name), + &boot_index); + if (ret != EFI_SUCCESS) + goto out; + + ret = efi_set_variable_int(var_name, &efi_global_variable_guid, + EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS | + EFI_VARIABLE_RUNTIME_ACCESS, + opt[i].size, opt[i].lo, false); + if (ret != EFI_SUCCESS) + goto out; + + ret = efi_bootmgr_append_bootorder(boot_index); + if (ret != EFI_SUCCESS) { + efi_set_variable_int(var_name, &efi_global_variable_guid, + 0, 0, NULL, false); + goto out; + } + } + } + +out: + if (opt) { + for (i = 0; i < count; i++) + free(opt[i].lo); + } + free(opt); + efi_free_pool(volume_handles); + + return ret; +} diff --git a/lib/efi_loader/efi_helper.c b/lib/efi_loader/efi_helper.c index 1f4ab2b419..cdfd16ea77 100644 --- a/lib/efi_loader/efi_helper.c +++ b/lib/efi_loader/efi_helper.c @@ -257,3 +257,28 @@ efi_status_t efi_next_variable_name(efi_uintn_t *size, u16 **buf, efi_guid_t *gu
return ret; } + +/** + * efi_search_bootorder() - search the boot option index in BootOrder + * + * @bootorder: pointer to the BootOrder variable + * @num: number of BootOrder entry + * @target: target boot option index to search + * @index: pointer to store the index of BootOrder variable + * Return: true if exists, false otherwise + */ +bool efi_search_bootorder(u16 *bootorder, efi_uintn_t num, u32 target, u32 *index) +{ + u32 i; + + for (i = 0; i < num; i++) { + if (target == bootorder[i]) { + if (index) + *index = i; + + return true; + } + } + + return false; +}
Signed-off-by: Raymond Mao raymond.mao@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes in v7 - new patch file created
cmd/bootmenu.c | 2 +- cmd/eficonfig.c | 2 +- lib/efi_loader/efi_bootmgr.c | 8 ++++++-- 3 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/cmd/bootmenu.c b/cmd/bootmenu.c index 01daddca7b..987b16889f 100644 --- a/cmd/bootmenu.c +++ b/cmd/bootmenu.c @@ -352,7 +352,7 @@ static struct bootmenu_data *bootmenu_create(int delay) * a architecture-specific default image name such as BOOTAA64.EFI. */ efi_ret = efi_bootmgr_update_media_device_boot_option(); - if (efi_ret != EFI_SUCCESS && efi_ret != EFI_NOT_FOUND) + if (efi_ret != EFI_SUCCESS) goto cleanup;
ret = prepare_uefi_bootorder_entry(menu, &iter, &i); diff --git a/cmd/eficonfig.c b/cmd/eficonfig.c index 82a80306f4..e6e8a0a488 100644 --- a/cmd/eficonfig.c +++ b/cmd/eficonfig.c @@ -2314,7 +2314,7 @@ static int do_eficonfig(struct cmd_tbl *cmdtp, int flag, int argc, char *const a return CMD_RET_FAILURE;
ret = efi_bootmgr_update_media_device_boot_option(); - if (ret != EFI_SUCCESS && ret != EFI_NOT_FOUND) + if (ret != EFI_SUCCESS) return ret;
while (1) { diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 97d5b8dc2b..28e800499c 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -663,11 +663,13 @@ efi_status_t efi_bootmgr_update_media_device_boot_option(void) NULL, &count, (efi_handle_t **)&volume_handles); if (ret != EFI_SUCCESS) - return ret; + goto out;
opt = calloc(count, sizeof(struct eficonfig_media_boot_option)); - if (!opt) + if (!opt) { + ret = EFI_OUT_OF_RESOURCES; goto out; + }
/* enumerate all devices supporting EFI_SIMPLE_FILE_SYSTEM_PROTOCOL */ ret = efi_bootmgr_enumerate_boot_option(opt, volume_handles, count); @@ -720,5 +722,7 @@ out: free(opt); efi_free_pool(volume_handles);
+ if (ret == EFI_NOT_FOUND) + return EFI_SUCCESS; return ret; }
Please note that currently the function 'efi_disk_remove' has no ability to distinguish below two scenarios a) Unplugging of a removable media under U-Boot b) U-Boot exiting and booting an OS Thus currently the boot variables management is not added into 'efi_disk_remove' to avoid boot options being added/erased repeatedly under scenario b) during power cycles See TODO comments under function 'efi_disk_remove' for more details
Signed-off-by: Raymond Mao raymond.mao@linaro.org --- Changes in v3 - Split the patch into moving and renaming functions and individual patches for each changed functionality Changes in v5 - Move function call of efi_bootmgr_update_media_device_boot_option() from efi_init_variables() to efi_init_obj_list() Changes in v6 - Revert unrelated changes Changes in v7 - adapt the return code of function efi_bootmgr_update_media_device_boot_option() Changes in v8 - add a note in the commit message for future reference Changes in v9 - amend the note text in the commit message - add a TODO comment in 'efi_disk_remove' Changes in v10 - fix typo and build failures with 'CONFIG_CMD_BOOTEFI_BOOTMGR=n'
lib/efi_loader/efi_disk.c | 18 ++++++++++++++++++ lib/efi_loader/efi_setup.c | 7 +++++++ 2 files changed, 25 insertions(+)
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index d2256713a8..911a4adfb1 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -687,6 +687,13 @@ int efi_disk_probe(void *ctx, struct event *event) return -1; }
+ /* only do the boot option management when UEFI sub-system is initialized */ + if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR) && efi_obj_list_initialized == EFI_SUCCESS) { + ret = efi_bootmgr_update_media_device_boot_option(); + if (ret != EFI_SUCCESS) + return -1; + } + return 0; }
@@ -773,6 +780,17 @@ int efi_disk_remove(void *ctx, struct event *event) return efi_disk_delete_part(dev); else return 0; + + /* + * TODO A flag to distinguish below 2 different scenarios of this + * function call is needed: + * a) Unplugging of a removable media under U-Boot + * b) U-Boot exiting and booting an OS + * In case of scenario a), efi_bootmgr_update_media_device_boot_option() + * needs to be invoked here to update the boot options and remove the + * unnecessary ones. + */ + }
/** diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index 58d4e13402..69c8b27730 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -245,6 +245,13 @@ efi_status_t efi_init_obj_list(void) if (ret != EFI_SUCCESS) goto out;
+ if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR)) { + /* update boot option after variable service initialized */ + ret = efi_bootmgr_update_media_device_boot_option(); + if (ret != EFI_SUCCESS) + goto out; + } + /* Define supported languages */ ret = efi_init_platform_lang(); if (ret != EFI_SUCCESS)
Changes in v3
Changes in v5
Changes in v6
Changes in v7
Changes in v8
Changes in v9
Changes in v10
- /* only do the boot option management when UEFI sub-system is initialized */
- if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR) && efi_obj_list_initialized == EFI_SUCCESS) {
return -1;
- return 0; }
* unnecessary ones.
As in future we want to integrate more EFI drivers with the driver model such a status should be in a global variable. It will have to be set in ExitBootServices() before invoking dm_remove_devices_flags().
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
- if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR)) {
goto out;
- /* Define supported languages */ ret = efi_init_platform_lang(); if (ret != EFI_SUCCESS)
Changes in v3
Changes in v7
Changes in v9
Changes in v10
diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c index d2256713a8..911a4adfb1 100644 --- a/lib/efi_loader/efi_disk.c +++ b/lib/efi_loader/efi_disk.c @@ -687,6 +687,13 @@ int efi_disk_probe(void *ctx, struct event *event) return -1; } + /* only do the boot option management when UEFI sub-system is initialized */ + if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR) && efi_obj_list_initialized == EFI_SUCCESS) { + ret = efi_bootmgr_update_media_device_boot_option(); + if (ret != EFI_SUCCESS) + return -1; + }
return 0; } @@ -773,6 +780,17 @@ int efi_disk_remove(void *ctx, struct event *event) return efi_disk_delete_part(dev); else return 0;
} /** diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index 58d4e13402..69c8b27730 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -245,6 +245,13 @@ efi_status_t efi_init_obj_list(void) if (ret != EFI_SUCCESS) goto out; + if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR)) { + /* update boot option after variable service initialized */ + ret = efi_bootmgr_update_media_device_boot_option(); + if (ret != EFI_SUCCESS) + goto out; + }
This patch leads to a test failure in
test/py/tests/test_efi_secboot/test_signed.py::TestEfiSignedImage::test_efi_signed_image_auth2
No EFI system partition Failed to persist EFI variables
Please, run 'make tests' before resubmitting.
Best regards
Heinrich
Hi Heinrich,
I run 'make tests' with the patches locally but no errors observed from 'test_signed.py', below are few lines from the output console: ``` test/py/tests/test_efi_secboot/test_signed.py ssssssss
[ 90%] ```
Regards, Raymond
Changes in v3
Changes in v5
Changes in v6
Changes in v7
Changes in v8
Changes in v9
Changes in v10
initialized */
return -1;
}return 0;
the
* unnecessary ones.
goto out;
Best regards
Heinrich
Hi Raymond,
On Tue, 18 Jul 2023 at 05:23, Raymond Mao raymond.mao@linaro.org wrote:
Hi Heinrich,
test/py/tests/test_efi_secboot/test_signed.py ssssssss [ 90%]
I think the test cases are just skipped, not executed.
I guess that some required packages are missing on the host machine, such as sbsigntool, efitools and libguestfs-tools. build-sandbox/test-log.html will help to analyze why the tests are skipped.
The following document describes prerequisites to run python tests. https://u-boot.readthedocs.io/en/latest/develop/py_testing.html
'make tests' runs many test cases and takes time. './test/py/test.py --bd sandbox --build -k efi_secboot' will run only the efi_secboot test and it will be useful for debugging purposes.
Thanks, Masahisa Kojima
Regards, Raymond
Changes in v3
Changes in v5
Changes in v6
Changes in v7
Changes in v8
Changes in v9
Changes in v10
initialized */
return -1;
}return 0;
the
* unnecessary ones.
goto out;
Best regards
Heinrich
On 18.07.23 11:03, Masahisa Kojima wrote:
Hi Raymond,
Hi Heinrich,
To get more output describing why tests are skipped or fail use
export PYTEST_ADDOPTS="-ra"
https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/16948 shows the errors with the suggested patch.
Best regards
Heinrich
Regards, Raymond
Changes in v3
Changes in v5
Changes in v6
Changes in v7
Changes in v8
Changes in v9
Changes in v10
initialized */
return -1;
}return 0;
the
* unnecessary ones.
goto out;
Best regards
Heinrich
Hi Heinrich,
I checkouted the 'origin/removable_medias' branch from the 'EFI U-Boot Custodian Tree'. Run the secureboot test suite on the sandbox locally by './test/py/test.py --bd sandbox --build -k efi_secboot'. But there are no errors observed for 'test_signed.py'. Below is the output logs: ``` ./test/py/test.py --bd sandbox --build -k efi_secboot +make O=/home/raymond/upstream/U-Boot-custodian/u-boot-efi/build-sandbox -s sandbox_defconfig +make O=/home/raymond/upstream/U-Boot-custodian/u-boot-efi/build-sandbox -s -j2 =========================================================================================== test session starts =========================================================================================== platform linux -- Python 3.10.9, pytest-6.2.5, py-1.10.0, pluggy-0.13.0 rootdir: /home/raymond/upstream/U-Boot-custodian/u-boot-efi/test/py, configfile: pytest.ini plugins: xdist-2.5.0, forked-1.6.0 collected 1147 items / 1128 deselected / 19 selected
test/py/tests/test_efi_secboot/test_authvar.py .....
[ 26%] test/py/tests/test_efi_secboot/test_signed.py ........
[ 68%] test/py/tests/test_efi_secboot/test_signed_intca.py ...
[ 84%] test/py/tests/test_efi_secboot/test_unsigned.py ...
[100%]
============================================================================= 19 passed, 1128 deselected in 78.28s (0:01:18) ============================================================================== ``` Is it a pipeline issue? I didn't find a button to retrigger the failed jobs. Do I have the permissions?
The HEAD of my testing workspace is on: ``` commit c88c134c29934654a696aef61ba63ff2c9a8481e (HEAD -> removable_medias, origin/removable_medias) Author: Raymond Mao raymond.mao@linaro.org Date: Mon Jun 19 14:23:00 2023 -0700
Boot var automatic management for removable medias ``` Same as the one for pipeline: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/16948
Thanks! Regards, Raymond
Hi Raymond,
wrote:
Hi Heinrich,
[ 90%]
skipped.
Best regards
Heinrich
Regards, Raymond
Changes in v3
Changes in v5
Changes in v6
Changes in v7
Changes in v8
Changes in v9
Changes in v10
*event)
return -1; }
initialized */
return -1;
}return 0;
*event)
this
remove
the
* unnecessary ones.
model
in
goto out;
Best regards
Heinrich
Hi Raymond, Heinrich, Ilias,
On Wed, 19 Jul 2023 at 07:11, Raymond Mao raymond.mao@linaro.org wrote:
Hi Heinrich,
./test/py/test.py --bd sandbox --build -k efi_secboot +make O=/home/raymond/upstream/U-Boot-custodian/u-boot-efi/build-sandbox -s sandbox_defconfig +make O=/home/raymond/upstream/U-Boot-custodian/u-boot-efi/build-sandbox -s -j2 =========================================================================================== test session starts =========================================================================================== platform linux -- Python 3.10.9, pytest-6.2.5, py-1.10.0, pluggy-0.13.0 rootdir: /home/raymond/upstream/U-Boot-custodian/u-boot-efi/test/py, configfile: pytest.ini plugins: xdist-2.5.0, forked-1.6.0 collected 1147 items / 1128 deselected / 19 selected test/py/tests/test_efi_secboot/test_authvar.py ..... [ 26%] test/py/tests/test_efi_secboot/test_signed.py ........ [ 68%] test/py/tests/test_efi_secboot/test_signed_intca.py ... [ 84%] test/py/tests/test_efi_secboot/test_unsigned.py ... [100%] ============================================================================= 19 passed, 1128 deselected in 78.28s (0:01:18) ==============================================================================
commit c88c134c29934654a696aef61ba63ff2c9a8481e (HEAD -> removable_medias, origin/removable_medias) Author: Raymond Mao <raymond.mao@linaro.org> Date: Mon Jun 19 14:23:00 2023 -0700 Boot var automatic management for removable medias
I could reproduce the error on efi_secboot tests and find the cause.
The efi_secboot tests expect that BootOrder is not defined. WIth this "Boot var automatic management for removable medias" patch, BootOrder is added when the disk is detected. In my testing, the BootOrder variable has two entries and the test ends up with an unexpected failure since efibootmgr falls back to BootOrder when loading from BootNext failed.
=== Loading from BootNext failed, falling back to BootOrder Loading Boot0000 'mmc 1:1' failed Loading Boot0001 'host 0:1' failed efi_bootmgr_load() returned: 14 efi_start_image() returned: 2 ===
I think we need to clear the BootOrder variable at the beginning of tests. I will resend this patch with efi_secboot pytest modification.
Hi Raymond,
Hi Heinrich,
Best regards
Heinrich
Regards, Raymond
On 6/19/23 23:23, Raymond Mao wrote: > Changes for complying to EFI spec §3.5.1.1 > 'Removable Media Boot Behavior'. > Boot variables can be automatically generated during a removable > media is probed. At the same time, unused boot variables will be > detected and removed. > > Please note that currently the function 'efi_disk_remove' has no > ability to distinguish below two scenarios > a) Unplugging of a removable media under U-Boot > b) U-Boot exiting and booting an OS > Thus currently the boot variables management is not added into > 'efi_disk_remove' to avoid boot options being added/erased > repeatedly under scenario b) during power cycles > See TODO comments under function 'efi_disk_remove' for more details > > Signed-off-by: Raymond Mao raymond.mao@linaro.org > --- > Changes in v3 > - Split the patch into moving and renaming functions and > individual patches for each changed functionality > Changes in v5 > - Move function call of efi_bootmgr_update_media_device_boot_option() > from efi_init_variables() to efi_init_obj_list() > Changes in v6 > - Revert unrelated changes > Changes in v7 > - adapt the return code of function > efi_bootmgr_update_media_device_boot_option() > Changes in v8 > - add a note in the commit message for future reference > Changes in v9 > - amend the note text in the commit message > - add a TODO comment in 'efi_disk_remove' > Changes in v10 > - fix typo and build failures with 'CONFIG_CMD_BOOTEFI_BOOTMGR=n' > > lib/efi_loader/efi_disk.c | 18 ++++++++++++++++++ > lib/efi_loader/efi_setup.c | 7 +++++++ > 2 files changed, 25 insertions(+) > > diff --git a/lib/efi_loader/efi_disk.c b/lib/efi_loader/efi_disk.c > index d2256713a8..911a4adfb1 100644 > --- a/lib/efi_loader/efi_disk.c > +++ b/lib/efi_loader/efi_disk.c > @@ -687,6 +687,13 @@ int efi_disk_probe(void *ctx, struct event *event) > return -1; > } > + /* only do the boot option management when UEFI sub-system is > initialized */ > + if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR) && > efi_obj_list_initialized == EFI_SUCCESS) { > + ret = efi_bootmgr_update_media_device_boot_option(); > + if (ret != EFI_SUCCESS) > + return -1; > + } > + > return 0; > } > @@ -773,6 +780,17 @@ int efi_disk_remove(void *ctx, struct event *event) > return efi_disk_delete_part(dev); > else > return 0; > + > + /* > + * TODO A flag to distinguish below 2 different scenarios of this > + * function call is needed: > + * a) Unplugging of a removable media under U-Boot > + * b) U-Boot exiting and booting an OS > + * In case of scenario a), > efi_bootmgr_update_media_device_boot_option() > + * needs to be invoked here to update the boot options and remove > the > + * unnecessary ones. > + */
> + > } > /** > diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c > index 58d4e13402..69c8b27730 100644 > --- a/lib/efi_loader/efi_setup.c > +++ b/lib/efi_loader/efi_setup.c > @@ -245,6 +245,13 @@ efi_status_t efi_init_obj_list(void) > if (ret != EFI_SUCCESS) > goto out; > + if (IS_ENABLED(CONFIG_CMD_BOOTEFI_BOOTMGR)) { > + /* update boot option after variable service initialized */ > + ret = efi_bootmgr_update_media_device_boot_option(); > + if (ret != EFI_SUCCESS) > + goto out; > + } > + > /* Define supported languages */ > ret = efi_init_platform_lang(); > if (ret != EFI_SUCCESS)
Best regards
Heinrich
Hi Masahisa,
Thanks for the hints. Found that I was missing 'guestfs-tools' for 'virt-make-fs'. Now I am able to reproduce the failure logs that Heinrich pointed out.
On Tue, 18 Jul 2023 at 05:03, Masahisa Kojima masahisa.kojima@linaro.org wrote:
Hi Raymond,
Hi Heinrich,
[ 90%]
Regards, Raymond
Changes in v3
Changes in v5
Changes in v6
Changes in v7
Changes in v8
Changes in v9
Changes in v10
*event)
return -1; }
initialized */
return -1;
}return 0;
*event)
this
remove
the
* unnecessary ones.
model
in
goto out;
Best regards
Heinrich
Signed-off-by: Raymond Mao raymond.mao@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes in v2 - Ignore EFI_NOT_FOUND returned from efi_bootmgr_update_media_device_boot_option which means no boot options scanned. Changes in v3 - Split the patch into moving and renaming functions and individual patches for each changed functionality Changes in v4 - Revert v2 change of introducing a bool parameter when updating the boot option. Use short-form of device path by default Changes in v5 - Add warning log when a short-form device path doesn't exist Changes in v6 - Revert v5 change and use original device path if short-form does not exist
lib/efi_loader/efi_bootmgr.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/lib/efi_loader/efi_bootmgr.c b/lib/efi_loader/efi_bootmgr.c index 28e800499c..398b0f89e2 100644 --- a/lib/efi_loader/efi_bootmgr.c +++ b/lib/efi_loader/efi_bootmgr.c @@ -371,6 +371,7 @@ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boo struct efi_load_option lo; char buf[BOOTMENU_DEVICE_NAME_MAX]; struct efi_device_path *device_path; + struct efi_device_path *short_dp;
ret = efi_search_protocol(volume_handles[i], &efi_guid_device_path, &handler); if (ret != EFI_SUCCESS) @@ -387,6 +388,11 @@ static efi_status_t efi_bootmgr_enumerate_boot_option(struct eficonfig_media_boo p = dev_name; utf8_utf16_strncpy(&p, buf, strlen(buf));
+ /* prefer to short form device path */ + short_dp = efi_dp_shorten(device_path); + if (short_dp) + device_path = short_dp; + lo.label = dev_name; lo.attributes = LOAD_OPTION_ACTIVE; lo.file_path = device_path;
Masahisa Kojima
Raymond Mao
