[U-Boot] [RFC] drivers: pci: imx: add imx_pcie_remove function
There is no dedicated reset signal wired up for the MX6QDL thus if the bootloader enables the link we need some special handling to get the core back into a state where it is safe to touch it for configuration.
While there has been some special handling in the Linux kernel to do this, it was removed in 4.11 thus we need to do it properly in the bootloader and therefore without this if you enable PCI in the bootloader you will hang while booting the 4.11 kernel.
This was tested on a Gateworks Ventana board.
TODO: what is the right arch specific place to hook the remove function?
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gw_ventana.c | 3 +++ drivers/pci/pcie_imx.c | 38 +++++++++++++++++++++++++++++++++ 2 files changed, 41 insertions(+)
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index f404497..6762a71 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -1163,6 +1163,9 @@ int ft_board_setup(void *blob, bd_t *bd) int i; char rev = 0;
+#if defined(CONFIG_CMD_PCI) + imx_pcie_remove(); +#endif /* determine board revision */ for (i = sizeof(ventana_info.model) - 1; i > 0; i--) { if (ventana_info.model[i] >= 'A') { diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index 732d59d..eab0a2b 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -42,6 +42,9 @@
/* PCIe Port Logic registers (memory-mapped) */ #define PL_OFFSET 0x700 +#define PCIE_PL_PFLR (PL_OFFSET + 0x08) +#define PCIE_PL_PFLR_LINK_STATE_MASK (0x3f << 16) +#define PCIE_PL_PFLR_FORCE_LINK (1 << 15) #define PCIE_PHY_DEBUG_R0 (PL_OFFSET + 0x28) #define PCIE_PHY_DEBUG_R1 (PL_OFFSET + 0x2c) #define PCIE_PHY_DEBUG_R1_LINK_UP (1 << 4) @@ -445,6 +448,36 @@ static int imx6_pcie_assert_core_reset(void) /* Power up PCIe PHY */ setbits_le32(&gpc_regs->cntr, PCIE_PHY_PUP_REQ); #else + /* + * If the bootloader already enabled the link we need some special + * handling to get the core back into a state where it is safe to + * touch it for configuration. As there is no dedicated reset signal + * wired up for MX6QDL, we need to manually force LTSSM into "detect" + * state before completely disabling LTSSM, which is a prerequisite + * for core configuration. + * + * If both LTSSM_ENABLE and REF_SSP_ENABLE are active we have a strong + * indication that the bootloader activated the link. + */ + if (is_mx6dq()) { + u32 val, gpr1, gpr12; + + gpr1 = readl(&iomuxc_regs->gpr[1]); + gpr12 = readl(&iomuxc_regs->gpr[12]); + if ((gpr1 & IOMUXC_GPR1_PCIE_REF_CLK_EN) && + (gpr12 & IOMUXC_GPR12_PCIE_CTL_2)) { + val = readl(MX6_DBI_ADDR + PCIE_PL_PFLR); + val &= ~PCIE_PL_PFLR_LINK_STATE_MASK; + val |= PCIE_PL_PFLR_FORCE_LINK; + + imx_pcie_fix_dabt_handler(true); + writel(val, MX6_DBI_ADDR + PCIE_PL_PFLR); + imx_pcie_fix_dabt_handler(false); + + gpr12 &= ~IOMUXC_GPR12_PCIE_CTL_2; + writel(val, &iomuxc_regs->gpr[12]); + } + } setbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_TEST_POWERDOWN); clrbits_le32(&iomuxc_regs->gpr[1], IOMUXC_GPR1_REF_SSP_EN); #endif @@ -652,6 +685,11 @@ void imx_pcie_init(void) } }
+void imx_pcie_remove(void) +{ + imx6_pcie_assert_core_reset(); +} + /* Probe function. */ void pci_init_board(void) {
Hi Tim,
Thanks for working on this!
[Adding Peter and Jagan on Cc]
Ideally the pcie_imx.c driver should be converted to driver model and then the .remove can be simply added, just like in Barebox.
Take a look at the following PCI drivers that have already been converted to the driver model to use as reference:
$ git grep U_BOOT_DRIVER drivers/pci/ drivers/pci/pci-uclass.c:U_BOOT_DRIVER(pci_bridge_drv) = { drivers/pci/pci-uclass.c:U_BOOT_DRIVER(pci_generic_drv) = { drivers/pci/pci_sandbox.c:U_BOOT_DRIVER(pci_sandbox) = { drivers/pci/pci_tegra.c:U_BOOT_DRIVER(pci_tegra) = { drivers/pci/pci_x86.c:U_BOOT_DRIVER(pci_x86) = { drivers/pci/pcie_dw_mvebu.c:U_BOOT_DRIVER(pcie_dw_mvebu) = { drivers/pci/pcie_layerscape.c:U_BOOT_DRIVER(pci_layerscape) = { drivers/pci/pcie_xilinx.c:U_BOOT_DRIVER(pcie_xilinx) = {
On Wed, May 10, 2017 at 11:10 AM, Fabio Estevam festevam@gmail.com wrote:
Hi Tim,
Fabio,
Unfortunately converting the IMX PCI driver to DM is a cleanup effort that I'm not permitted the time to do.
Regards,
Tim
On Wed, May 10, 2017 at 03:10:37PM -0300, Fabio Estevam wrote: Hi Tim,
Hi Tim,
[snip]
Thank you for working on this! Your patch worked for me, but I needed to add an "extern void imx_pcie_remove(void);" before calling the function, which probably means I'm missing something.
After applying this patch to u-boot, u-boot can initialize PCI and 4.11.0-next-20170510 will boot. Without your patch 4.11.0-next-20170510 do not boot if u-boot initialize the PCI bus.
Thanks a lot!
Here is the patch I'm using for our board:
diff --git a/board/ge/bx50v3/bx50v3.c b/board/ge/bx50v3/bx50v3.c index cb49b58..7e03082 100644 --- a/board/ge/bx50v3/bx50v3.c +++ b/board/ge/bx50v3/bx50v3.c @@ -829,6 +829,7 @@ static void remove_ethaddr_env_var(int index) setenv(env_var_name, NULL); }
+extern void imx_pcie_remove(void); int last_stage_init(void) { int i;
@@ -838,6 +839,8 @@ int last_stage_init(void) { remove_ethaddr_env_var(i); }
+ imx_pcie_remove(); + return 0; }
On Thu, May 11, 2017 at 6:01 AM, Peter Senna Tschudin peter.senna@collabora.com wrote:
The extern should be added into a header file.
Thanks a lot!
Stefano,
The patches that Tim/Peter posted solve a kernel hang with kernel 4.11 on mx6q when U-Boot has PCI support.
Could you please take a look and let us know if there is a more generic way to fix this issue, like fixing it for all mx6qdl boards that have PCI support?
I understand that ideally the imx6 pci driver should be converted to driver model and then we add the .remove hook, like Lucas did for Barebox: https://git.pengutronix.de/cgit/barebox/commit/?id=f1da98da2760c21487bbba8f7...
While the imx pci driver is not converted to device model, would you be willing to accept such per board patches for the time being?
Please advise.
Thanks
imx_pcie_remove();
if (is_mx6dq()) {
Thanks a lot!
Stefano,
The DM conversion should be pretty trivial IMO, no ?
Any volunteers? ;-)
Any volunteers? ;-)
Tim ? :)
Hi Fabio,
Thanks a lot!
Stefano,
Please advise.
Ok - let wait for Tim's answer, if he has enough time to work on this to move to DM. If not, it will be ok for now to fix it in this way, hoping to move soon to DM.
Regards, Stefano
On Thu, May 11, 2017 at 6:48 PM, Stefano Babic sbabic@denx.de wrote:
Hi Fabio,
Thanks a lot!
Stefano,
Please advise.
If none, have time to work, I'll work for dm conversion and have board to test the same.
Jagan.
On Thu, May 11, 2017 at 6:18 AM, Stefano Babic sbabic@denx.de wrote:
Hi Fabio,
Thanks a lot!
Stefano,
Please advise.
Regards, Stefano
Stefano,
I don't have enough time to work on the DM conversion currently but it sounds like this would be a welcomed 'fix' that we should get in sooner than later.
I know the include is missing from a header but I didn't bother as I though there would be a better arch-specific place to put the call to the remove. I don't think putting it in ft_board_setup made sense. Do you have any suggestions where it should go?
Tim
Date: Thu, 11 May 2017 07:02:52 -0700 From: Tim Harvey tharvey@gateworks.com To: Stefano Babic sbabic@denx.de Cc: Marek Vasut marex@denx.de, U-Boot-Denx u-boot@lists.denx.de, Peter Senna Tschudin peter.senna@collabora.com, Lucas Stach l.stach@pengutronix.de Subject: Re: [U-Boot] [RFC] drivers: pci: imx: add imx_pcie_remove function Message-ID: CAJ+vNU2MOp_1bsh5MusGauJPdASB7+KDPQGdg+YU4gfbtBSBhQ@mail.gmail.com Content-Type: text/plain; charset="UTF-8"
Hi Fabio,
needed to
function,
Thanks a lot!
Stefano,
Please advise.
Regards, Stefano
Stefano,
Tim
Tim,
this patch in addition to your original drivers/pci/pcie_imx.c changes works for me on a tbs2910 board. Since I did not touch board-specific code, this should also work for all affected boards.
Regards, Soeren
diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 40fe813..7ed9ca0 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -273,8 +273,13 @@ u32 get_ahb_clk(void) } #endif
+extern void imx_pcie_remove(void); + void arch_preboot_os(void) { +#if defined(CONFIG_PCIE_IMX) + imx_pcie_remove(); +#endif #if defined(CONFIG_CMD_SATA) sata_stop(); #if defined(CONFIG_MX6)
Hi Fabio,
needed to
function,
Thanks a lot!
Stefano,
Please advise.
Regards, Stefano
Stefano,
Tim
Tim,
Soeren,
Perfect, that's what I was looking for 'arch_preboot_os' seems like a good place for it!
I will put together a non-RFC patch.
Tim
participants (7)
Fabio Estevam
Jagan Teki
Soeren Moch
Stefano Babic
Tim Harvey
