[PATCH u-boot-marvell] arm: mvebu: turris_omnia: Enable networking via ethernet switch
The Turris Omnia contains the Marvell 88E6176 ethernet switch. Add config options and device tree to enable the support.
Signed-off-by: Marek Mojík marek.mojik@nic.cz Signed-off-by: Marek Behún kabel@kernel.org --- Stefan, this patch depends on [v2] net: mv88e6xxx: fix missing SMI address initialization https://patchwork.ozlabs.org/project/uboot/patch/62eoapvurxkedw74vpzb55q3nuq... --- .../dts/armada-385-turris-omnia-u-boot.dtsi | 51 +++++++++++++++++++ configs/turris_omnia_defconfig | 2 + 2 files changed, 53 insertions(+)
diff --git a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi index 509d6ca69c..c63a331d69 100644 --- a/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi +++ b/arch/arm/dts/armada-385-turris-omnia-u-boot.dtsi @@ -35,6 +35,57 @@ }; };
+&mdio { + switch@10 { + mdio { + #address-cells = <1>; + #size-cells = <0>; + + sw_phy0: ethernet-phy@0 { + reg = <0x0>; + }; + + sw_phy1: ethernet-phy@1 { + reg = <0x1>; + }; + + sw_phy2: ethernet-phy@2 { + reg = <0x2>; + }; + + sw_phy3: ethernet-phy@3 { + reg = <0x3>; + }; + + sw_phy4: ethernet-phy@4 { + reg = <0x4>; + }; + }; + ports { + ports@0 { + phy-handle = <&sw_phy0>; + phy-mode = "internal"; + }; + ports@1 { + phy-handle = <&sw_phy1>; + phy-mode = "internal"; + }; + ports@2 { + phy-handle = <&sw_phy2>; + phy-mode = "internal"; + }; + ports@3 { + phy-handle = <&sw_phy3>; + phy-mode = "internal"; + }; + ports@4 { + phy-handle = <&sw_phy4>; + phy-mode = "internal"; + }; + }; + }; +}; + #ifdef CONFIG_ENV_IS_IN_SPI_FLASH &spi0 { flash@0 { diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 65d4a296e7..3aaee276ea 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -96,7 +96,9 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_MTD=y CONFIG_PHY_MARVELL=y CONFIG_PHY_FIXED=y +CONFIG_DM_DSA=y CONFIG_PHY_GIGE=y +CONFIG_MV88E6XXX=y CONFIG_MVNETA=y CONFIG_MII=y CONFIG_MVMDIO=y
Applied to u-boot-marvell/master
Thanks, Stefan
+&mdio {
- switch@10 {
mdio {
#size-cells = <0>;
reg = <0x0>;
reg = <0x1>;
reg = <0x2>;
reg = <0x3>;
reg = <0x4>;
ports {
ports@0 {
ports@1 {
ports@2 {
ports@3 {
ports@4 {
- #ifdef CONFIG_ENV_IS_IN_SPI_FLASH &spi0 { flash@0 {
Viele Grüße, Stefan Roese
Marek Behún
Stefan Roese
