[U-Boot] [PATCH V2 1/3 CORRECTED] Initial support for Marvell Orion5x SoC
** ATTENTION: this patch supersedes the previous '1/3' patch in the same series. The correction is the removal of Kirkwood-inherited device init code unused at the moment and partly inapplicable to Orion5x anyway. This correct patch has been run through checkpatch.pl again with the exact same result as its predecessor (6 false pos).
Sorry for the inconvenience.
This patch adds support for the Marvell Orion5x SoC. It has no use alone, and must be followed by a patch to add Orion5x support for serial, then support for the ED Mini V2, an Orion5x-based board from LaCie.
Signed-off-by: Albert Aribaud albert.aribaud@free.fr --- cpu/arm926ejs/orion5x/Makefile | 52 ++++++ cpu/arm926ejs/orion5x/cpu.c | 299 ++++++++++++++++++++++++++++++++ cpu/arm926ejs/orion5x/dram.c | 61 +++++++ cpu/arm926ejs/orion5x/mpp.c | 89 ++++++++++ cpu/arm926ejs/orion5x/timer.c | 175 +++++++++++++++++++ include/asm-arm/arch-orion5x/88f5182.h | 40 +++++ include/asm-arm/arch-orion5x/cpu.h | 208 ++++++++++++++++++++++ include/asm-arm/arch-orion5x/gpio.h | 52 ++++++ include/asm-arm/arch-orion5x/mpp.h | 122 +++++++++++++ include/asm-arm/arch-orion5x/orion5x.h | 67 +++++++ 10 files changed, 1165 insertions(+), 0 deletions(-) create mode 100644 cpu/arm926ejs/orion5x/Makefile create mode 100644 cpu/arm926ejs/orion5x/cpu.c create mode 100644 cpu/arm926ejs/orion5x/dram.c create mode 100644 cpu/arm926ejs/orion5x/mpp.c create mode 100644 cpu/arm926ejs/orion5x/timer.c create mode 100644 include/asm-arm/arch-orion5x/88f5182.h create mode 100644 include/asm-arm/arch-orion5x/cpu.h create mode 100644 include/asm-arm/arch-orion5x/gpio.h create mode 100644 include/asm-arm/arch-orion5x/mpp.h create mode 100644 include/asm-arm/arch-orion5x/orion5x.h
diff --git a/cpu/arm926ejs/orion5x/Makefile b/cpu/arm926ejs/orion5x/Makefile new file mode 100644 index 0000000..3343124 --- /dev/null +++ b/cpu/arm926ejs/orion5x/Makefile @@ -0,0 +1,52 @@ +# +# Copyright (C) 2009 Albert ARIBAUD albrt.aribaud@free.fr +# +# Based on original Kirkwood support which is +# (C) Copyright 2009 +# Marvell Semiconductor <www.marvell.com> +# Written-by: Prafulla Wadaskar prafulla@marvell.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, +# MA 02110-1301 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS-y = cpu.o +COBJS-y += dram.o +COBJS-y += mpp.o +COBJS-y += timer.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/cpu/arm926ejs/orion5x/cpu.c b/cpu/arm926ejs/orion5x/cpu.c new file mode 100644 index 0000000..f4644b1 --- /dev/null +++ b/cpu/arm926ejs/orion5x/cpu.c @@ -0,0 +1,299 @@ +/* + * Copyright (C) 2009 Albert ARIBAUD albert.aribaud@free.fr + * + * Based on original Kirkwood support which is + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/cache.h> +#include <u-boot/md5.h> +#include <asm/arch/orion5x.h> +#include <hush.h> + +#define BUFLEN 16 + +void reset_cpu(unsigned long ignored) +{ + struct orion5x_cpu_registers *cpureg = + (struct orion5x_cpu_registers *)ORION5X_CPU_REG_BASE; + + writel(readl(&cpureg->rstoutn_mask) | (1 << 2), + &cpureg->rstoutn_mask); + writel(readl(&cpureg->sys_soft_rst) | 1, + &cpureg->sys_soft_rst); + while (1) + ; +} + +/* + * Window Size + * Used with the Base register to set the address window size and location. + * Must be programmed from LSB to MSB as sequence of ones followed by + * sequence of zeros. The number of ones specifies the size of the window in + * 64 KByte granularity (e.g., a value of 0x00FF specifies 256 = 16 MByte). + * NOTE: A value of 0x0 specifies 64-KByte size. + */ +unsigned int orion5x_winctrl_calcsize(unsigned int sizeval) +{ + int i; + unsigned int j = 0; + u32 val = sizeval >> 1; + + for (i = 0; val > 0x10000; i++) { + j |= (1 << i); + val = val >> 1; + } + return 0x0000ffff & j; +} + +/* + * orion5x_config_adr_windows - Configure address Windows + * + * There are 8 address windows supported by Orion5x Soc to addess different + * devices. Each window can be configured for size, BAR and remap addr + * Below configuration is standard for most of the cases + * + * If remap function not used, remap_lo must be set as base + * + * Reference Documentation: + * Mbus-L to Mbus Bridge Registers Configuration. + * (Sec 25.1 and 25.3 of Datasheet) + */ +int orion5x_config_adr_windows(void) +{ + struct orion5x_win_registers *winregs = + (struct orion5x_win_registers *)ORION5X_CPU_WIN_BASE; + + /* Window 0: PCIE MEM address space */ + writel(ORION5X_CPU_WIN_CTRL_DATA(ORION5X_DEFSZ_PCIE_MEM, + ORION5X_TARGET_PCIE, ORION5X_ATTR_PCIE_MEM, + ORION5X_WIN_ENABLE), &winregs[0].ctrl); + writel(ORION5X_DEFADR_PCIE_MEM, &winregs[0].base); + writel(ORION5X_DEFADR_PCIE_MEM_REMAP_LO, &winregs[0].remap_lo); + writel(ORION5X_DEFADR_PCIE_MEM_REMAP_HI, &winregs[0].remap_hi); + + /* Window 1: PCIE IO address space */ + writel(ORION5X_CPU_WIN_CTRL_DATA(ORION5X_DEFSZ_PCIE_IO, + ORION5X_TARGET_PCIE, ORION5X_ATTR_PCIE_IO, + ORION5X_WIN_ENABLE), &winregs[1].ctrl); + writel(ORION5X_DEFADR_PCIE_IO, &winregs[1].base); + writel(ORION5X_DEFADR_PCIE_IO_REMAP_LO, &winregs[1].remap_lo); + writel(ORION5X_DEFADR_PCIE_IO_REMAP_HI, &winregs[1].remap_hi); + + /* Window 2: PCI MEM address space */ + writel(ORION5X_CPU_WIN_CTRL_DATA(ORION5X_DEFSZ_PCI_MEM, + ORION5X_TARGET_PCI, ORION5X_ATTR_PCI_MEM, + ORION5X_WIN_ENABLE), &winregs[2].ctrl); + writel(ORION5X_DEFADR_PCI_MEM, &winregs[2].base); + + /* Window 3: PCI IO address space */ + writel(ORION5X_CPU_WIN_CTRL_DATA(ORION5X_DEFSZ_PCI_IO, + ORION5X_TARGET_PCI, ORION5X_ATTR_PCI_IO, + ORION5X_WIN_ENABLE), &winregs[3].ctrl); + writel(ORION5X_DEFADR_PCI_IO, &winregs[3].base); + + /* Window 4: DEV_CS0 address space */ + writel(ORION5X_CPU_WIN_CTRL_DATA(ORION5X_DEFSZ_DEV_CS0, + ORION5X_TARGET_DEVICE, ORION5X_ATTR_DEV_CS0, + ORION5X_WIN_ENABLE), &winregs[4].ctrl); + writel(ORION5X_DEFADR_DEV_CS0, &winregs[4].base); + + /* Window 5: DEV_CS1 address space */ + writel(ORION5X_CPU_WIN_CTRL_DATA(ORION5X_DEFSZ_DEV_CS1, + ORION5X_TARGET_DEVICE, ORION5X_ATTR_DEV_CS1, + ORION5X_WIN_ENABLE), &winregs[5].ctrl); + writel(ORION5X_DEFADR_DEV_CS1, &winregs[5].base); + + /* Window 6: DEV_CS2 address space */ + writel(ORION5X_CPU_WIN_CTRL_DATA(ORION5X_DEFSZ_DEV_CS2, + ORION5X_TARGET_DEVICE, ORION5X_ATTR_DEV_CS2, + ORION5X_WIN_ENABLE), &winregs[6].ctrl); + writel(ORION5X_DEFADR_DEV_CS2, &winregs[6].base); + + /* Window 7: BOOT Memory address space */ + writel(ORION5X_CPU_WIN_CTRL_DATA(ORION5X_DEFSZ_BOOTROM, + ORION5X_TARGET_DEVICE, ORION5X_ATTR_BOOTROM, + ORION5X_WIN_ENABLE), &winregs[7].ctrl); + writel(ORION5X_DEFADR_BOOTROM, &winregs[7].base); + + return 0; +} + +/* + * orion5x_config_gpio - GPIO configuration + */ +void orion5x_config_gpio(u32 gpp_oe_val, u32 gpp_oe) +{ + struct orion5x_gpio_registers *gpioreg = + (struct orion5x_gpio_registers *)ORION5X_GPIO_BASE; + + /* Init GPIOS to default values as per board requirement */ + writel(gpp_oe_val, &gpioreg->dout); + writel(gpp_oe, &gpioreg->oe); +} + +/* + * orion5x_config_mpp - Multi-Purpose Pins Functionality configuration + * + * Each MPP can be configured to different functionality through + * MPP control register, ref (sec 6.1 of Orion5x h/w specification) + * + * There are maximum 20 Multi-Pourpose Pins on Orion5x + * Each MPP functionality can be configured by a 4bit value + * in the MPP control registers, the value and associated functionality + * depends upon used SoC variant + */ +int orion5x_config_mpp(u32 mpp0_7, u32 mpp8_15, u32 mpp16_23) +{ + u32 *mppreg = (u32 *) ORION5X_MPP_BASE; + + /* program mpp registers */ + writel(mpp0_7, &mppreg[0]); + writel(mpp8_15, &mppreg[1]); + writel(mpp16_23, &mppreg[2]); + return 0; +} + +/* + * Orion5x identification is done through PCIE space. + */ +#define PCIE_DEV_ID_OFF (ORION5X_REG_PCIE_BASE + 0x0000) +#define PCIE_DEV_REV_OFF (ORION5X_REG_PCIE_BASE + 0x0008) +u32 orion5x_device_id(void) +{ + return readl(PCIE_DEV_ID_OFF) >> 16; +} + +u32 orion5x_device_rev(void) +{ + return readl(PCIE_DEV_REV_OFF) & 0xff; +} + +#if defined(CONFIG_DISPLAY_CPUINFO) + +int print_cpuinfo(void) +{ + char dev_str[] = "0x0000"; + char rev_str[] = "0x00"; + char *dev_name = NULL; + char *rev_name = NULL; + + u32 dev = orion5x_device_id(); + u32 rev = orion5x_device_rev(); + + if (dev == MV88F5181_DEV_ID) { + dev_name = "MV88F5181"; + if (rev == MV88F5181_REV_B1) + rev_name = "B1"; + else if (rev == MV88F5181L_REV_A1) { + dev_name = "MV88F5181L"; + rev_name = "A1"; + } else if (rev == MV88F5181L_REV_A0) { + dev_name = "MV88F5181L"; + rev_name = "A0"; + } + } else if (dev == MV88F5182_DEV_ID) { + dev_name = "MV88F5182"; + if (rev == MV88F5182_REV_A2) + rev_name = "A2"; + } else if (dev == MV88F5281_DEV_ID) { + dev_name = "MV88F5281"; + if (rev == MV88F5281_REV_D2) + rev_name = "D2"; + else if (rev == MV88F5281_REV_D1) + rev_name = "D1"; + else if (rev == MV88F5281_REV_D0) + rev_name = "D0"; + } else if (dev == MV88F6183_DEV_ID) { + dev_name = "MV88F6183"; + if (rev == MV88F6183_REV_B0) + rev_name = "B0"; + } + if (dev_name == NULL) { + sprintf(dev_str, "0x%04x", dev); + dev_name = dev_str; + } + if (rev_name == NULL) { + sprintf(rev_str, "0x%02x", rev); + rev_name = rev_str; + } + + printf("SoC: Orion5x %s-%s\n", dev_name, rev_name); + + return 0; +} +#endif /* CONFIG_DISPLAY_CPUINFO */ + +#ifdef CONFIG_ARCH_CPU_INIT +int arch_cpu_init(void) +{ + struct orion5x_cpu_registers *cpureg = + (struct orion5x_cpu_registers *)ORION5X_CPU_REG_BASE; + + /* Linux expects` the internal registers to be at 0xf1000000 */ + writel(ORION5X_REGS_PHY_BASE, ORION5X_OFFSET_REG); + + /* Enable and invalidate L2 cache in write through mode */ + invalidate_l2_cache(); + + orion5x_config_adr_windows(); + + return 0; +} +#endif /* CONFIG_ARCH_CPU_INIT */ + +/* + * SOC specific misc init + */ +#if defined(CONFIG_ARCH_MISC_INIT) +int arch_misc_init(void) +{ + u32 temp; + + /*CPU streaming & write allocate */ + temp = readfr_extra_feature_reg(); + temp &= ~(1 << 28); /* disable wr alloc */ + writefr_extra_feature_reg(temp); + + temp = readfr_extra_feature_reg(); + temp &= ~(1 << 29); /* streaming disabled */ + writefr_extra_feature_reg(temp); + + /* L2Cache settings */ + temp = readfr_extra_feature_reg(); + /* Disable L2C pre fetch - Set bit 24 */ + temp |= (1 << 24); + /* enable L2C - Set bit 22 */ + temp |= (1 << 22); + writefr_extra_feature_reg(temp); + + icache_enable(); + /* Change reset vector to address 0x0 */ + temp = get_cr(); + set_cr(temp & ~CR_V); + + return 0; +} +#endif /* CONFIG_ARCH_MISC_INIT */ diff --git a/cpu/arm926ejs/orion5x/dram.c b/cpu/arm926ejs/orion5x/dram.c new file mode 100644 index 0000000..ba6dd91 --- /dev/null +++ b/cpu/arm926ejs/orion5x/dram.c @@ -0,0 +1,61 @@ +/* + * Copyright (C) 2009 Albert ARIBAUD albert.aribaud@free.fr + * + * Based on original Kirkwood support which is + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <config.h> +#include <asm/arch/orion5x.h> + +#define ORION5X_REG_CPUCS_WIN_BAR(x) (ORION5X_REGISTER(0x1500) + (x * 0x08)) +#define ORION5X_REG_CPUCS_WIN_SZ(x) (ORION5X_REGISTER(0x1504) + (x * 0x08)) +/* + * orion5x_sdram_bar - reads SDRAM Base Address Register + */ +u32 orion5x_sdram_bar(enum memory_bank bank) +{ + u32 result = 0; + u32 enable = 0x01 & readl(ORION5X_REG_CPUCS_WIN_SZ(bank)); + + if ((!enable) || (bank > BANK3)) + return 0; + + result = readl(ORION5X_REG_CPUCS_WIN_BAR(bank)); + return result; +} + +/* + * orion5x_sdram_bs - reads SDRAM Bank size + */ +u32 orion5x_sdram_bs(enum memory_bank bank) +{ + u32 result = 0; + u32 enable = 0x01 & readl(ORION5X_REG_CPUCS_WIN_SZ(bank)); + + if ((!enable) || (bank > BANK3)) + return 0; + result = 0xff000000 & readl(ORION5X_REG_CPUCS_WIN_SZ(bank)); + result += 0x01000000; + return result; +} diff --git a/cpu/arm926ejs/orion5x/mpp.c b/cpu/arm926ejs/orion5x/mpp.c new file mode 100644 index 0000000..f341747 --- /dev/null +++ b/cpu/arm926ejs/orion5x/mpp.c @@ -0,0 +1,89 @@ +/* + * Copyright (C) 2009 Albert ARIBAUD albert.aribaud@free.fr + * + * Based on original Kirkwood support + * + * arch/arm/mach-orion5x/mpp.c + * + * MPP functions for Marvell Kirorion5xood SoCs + * Referenced from Linux kernel source + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +#include <common.h> +#include <asm/arch/orion5x.h> +#include <asm/arch/mpp.h> + +static u32 orion5x_variant(void) +{ + switch (orion5x_device_id()) { + case MV88F5181_DEV_ID: + return 0; + case MV88F5182_DEV_ID: + return MPP_F5182_MASK; + case MV88F5281_DEV_ID: + return MPP_F5281_MASK; + case MV88F6183_DEV_ID: + return 0; + default: + debug("MPP setup: unknown Orion5x variant\n"); + return 0; + } +} + +#define MPP_CTRL(i) (ORION5X_MPP_BASE + (i*4)) +#define MPP_NR_REGS (1 + MPP_MAX/8) + +void orion5x_mpp_conf(u32 *mpp_list) +{ + u32 mpp_ctrl[MPP_NR_REGS]; + unsigned int variant_mask; + int i; + + variant_mask = orion5x_variant(); + if (!variant_mask) + return; + + debug("initial MPP regs:"); + + for (i = 0; i < MPP_NR_REGS; i++) { + mpp_ctrl[i] = readl(MPP_CTRL(i)); + debug(" %08x", mpp_ctrl[i]); + } + debug("\n"); + + + while (*mpp_list) { + unsigned int num = MPP_NUM(*mpp_list); + unsigned int sel = MPP_SEL(*mpp_list); + int shift; + + if (num > MPP_MAX) { + debug("orion5x_mpp_conf: invalid MPP " + "number (%u)\n", num); + continue; + } + if (!(*mpp_list & variant_mask)) { + debug("orion5x_mpp_conf: requested MPP%u config " + "unavailable on this hardware\n", num); + continue; + } + + shift = (num & 7) << 2; + mpp_ctrl[num / 8] &= ~(0xf << shift); + mpp_ctrl[num / 8] |= sel << shift; + + mpp_list++; + } + + debug(" final MPP regs:"); + for (i = 0; i < MPP_NR_REGS; i++) { + writel(mpp_ctrl[i], MPP_CTRL(i)); + debug(" %08x", mpp_ctrl[i]); + } + debug("\n"); + +} diff --git a/cpu/arm926ejs/orion5x/timer.c b/cpu/arm926ejs/orion5x/timer.c new file mode 100644 index 0000000..9944916 --- /dev/null +++ b/cpu/arm926ejs/orion5x/timer.c @@ -0,0 +1,175 @@ +/* + * Copyright (C) 2009 Albert ARIBAUD albert.aribaud@free.fr + * + * Based on original Kirkwood support which is + * Copyright (C) Marvell International Ltd. and its affiliates + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#include <common.h> +#include <asm/arch/orion5x.h> + +#define UBOOT_CNTR 0 /* counter to use for uboot timer */ + +/* Timer reload and current value registers */ +struct orion5x_tmr_val { + u32 reload; /* Timer reload reg */ + u32 val; /* Timer value reg */ +}; + +/* Timer registers */ +struct orion5x_tmr_registers { + u32 ctrl; /* Timer control reg */ + u32 pad[3]; + struct orion5x_tmr_val tmr[2]; + u32 wdt_reload; + u32 wdt_val; +}; + +struct orion5x_tmr_registers *orion5x_tmr_regs = + (struct orion5x_tmr_registers *)ORION5X_TIMER_BASE; + +/* + * ARM Timers Registers Map + */ +#define CNTMR_CTRL_REG (&orion5x_tmr_regs->ctrl) +#define CNTMR_RELOAD_REG(tmrnum) (&orion5x_tmr_regs->tmr[tmrnum].reload) +#define CNTMR_VAL_REG(tmrnum) (&orion5x_tmr_regs->tmr[tmrnum].val) + +/* + * ARM Timers Control Register + * CPU_TIMERS_CTRL_REG (CTCR) + */ +#define CTCR_ARM_TIMER_EN_OFFS(cntr) (cntr * 2) +#define CTCR_ARM_TIMER_EN_MASK(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS) +#define CTCR_ARM_TIMER_EN(cntr) (1 << CTCR_ARM_TIMER_EN_OFFS(cntr)) +#define CTCR_ARM_TIMER_DIS(cntr) (0 << CTCR_ARM_TIMER_EN_OFFS(cntr)) + +#define CTCR_ARM_TIMER_AUTO_OFFS(cntr) ((cntr * 2) + 1) +#define CTCR_ARM_TIMER_AUTO_MASK(cntr) (1 << 1) +#define CTCR_ARM_TIMER_AUTO_EN(cntr) (1 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) +#define CTCR_ARM_TIMER_AUTO_DIS(cntr) (0 << CTCR_ARM_TIMER_AUTO_OFFS(cntr)) + +/* + * ARM Timer\Watchdog Reload Register + * CNTMR_RELOAD_REG (TRR) + */ +#define TRG_ARM_TIMER_REL_OFFS 0 +#define TRG_ARM_TIMER_REL_MASK 0xffffffff + +/* + * ARM Timer\Watchdog Register + * CNTMR_VAL_REG (TVRG) + */ +#define TVR_ARM_TIMER_OFFS 0 +#define TVR_ARM_TIMER_MASK 0xffffffff +#define TVR_ARM_TIMER_MAX 0xffffffff +#define TIMER_LOAD_VAL 0xffffffff + +#define READ_TIMER \ + (readl(CNTMR_VAL_REG(UBOOT_CNTR)) / (CONFIG_SYS_TCLK / 1000)) + +static ulong timestamp; +static ulong lastdec; + +void reset_timer_masked(void) +{ + /* reset time */ + lastdec = READ_TIMER; + timestamp = 0; +} + +ulong get_timer_masked(void) +{ + ulong now = READ_TIMER; + + if (lastdec >= now) { + /* normal mode */ + timestamp += lastdec - now; + } else { + /* we have an overflow ... */ + timestamp += lastdec + + (TIMER_LOAD_VAL / (CONFIG_SYS_TCLK / 1000)) - now; + } + lastdec = now; + + return timestamp; +} + +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +void set_timer(ulong t) +{ + timestamp = t; +} + +#define UBOOT_CNTR_VAL readl(CNTMR_VAL_REG(UBOOT_CNTR)) + +void udelay(unsigned long usec) +{ + uint current; + ulong delayticks; + + current = readl(CNTMR_VAL_REG(UBOOT_CNTR)); + delayticks = (usec * (CONFIG_SYS_TCLK / 1000000)); + + if (current < delayticks) { + delayticks -= current; + while (readl(CNTMR_VAL_REG(UBOOT_CNTR)) < current) + ; + while ((TIMER_LOAD_VAL - delayticks) < UBOOT_CNTR_VAL) + ; + } else { + while (UBOOT_CNTR_VAL > (current - delayticks)) + ; + } +} + +/* + * init the counter + */ +int timer_init(void) +{ + unsigned int cntmrctrl; + + /* load value into timer */ + writel(TIMER_LOAD_VAL, CNTMR_RELOAD_REG(UBOOT_CNTR)); + writel(TIMER_LOAD_VAL, CNTMR_VAL_REG(UBOOT_CNTR)); + + /* enable timer in auto reload mode */ + cntmrctrl = readl(CNTMR_CTRL_REG); + cntmrctrl |= CTCR_ARM_TIMER_EN(UBOOT_CNTR); + cntmrctrl |= CTCR_ARM_TIMER_AUTO_EN(UBOOT_CNTR); + writel(cntmrctrl, CNTMR_CTRL_REG); + + /* init the timestamp and lastdec value */ + reset_timer_masked(); + + return 0; +} diff --git a/include/asm-arm/arch-orion5x/88f5182.h b/include/asm-arm/arch-orion5x/88f5182.h new file mode 100644 index 0000000..b16b23f --- /dev/null +++ b/include/asm-arm/arch-orion5x/88f5182.h @@ -0,0 +1,40 @@ +/* + * Copyright (C) 2009 Albert ARIBAUD albert.aribaud@free.fr + * + * Based on original Kirkwood 88F6182 support which is + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * Header file for Feroceon CPU core 88F5182 SOC. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _CONFIG_88F5182_H +#define _CONFIG_88F5182_H + +/* SOC specific definations */ +#define F88F5182_REGS_PHYS_BASE 0xf1000000 +#define ORION5X_REGS_PHY_BASE F88F5182_REGS_PHYS_BASE + +/* TCLK Core Clock defination */ +#define CONFIG_SYS_TCLK 166000000 /* 166MHz */ + +#endif /* _CONFIG_88F5182_H */ diff --git a/include/asm-arm/arch-orion5x/cpu.h b/include/asm-arm/arch-orion5x/cpu.h new file mode 100644 index 0000000..303361d --- /dev/null +++ b/include/asm-arm/arch-orion5x/cpu.h @@ -0,0 +1,208 @@ +/* + * Copyright (C) 2009 Albert ARIBAUD albert.aribaud@free.fr + * + * Based on original Kirorion5x_ood support which is + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _ORION5X_CPU_H +#define _ORION5X_CPU_H + +#include <asm/system.h> + +#ifndef __ASSEMBLY__ + +#define ORION5X_CPU_WIN_CTRL_DATA(size, target, attr, en) (en | (target << 4) \ + | (attr << 8) | (orion5x_winctrl_calcsize(size) << 16)) + +#define ORION5XGBE_PORT_SERIAL_CONTROL1_REG(_x) \ + ((_x ? ORION5X_EGIGA0_BASE : ORION5X_EGIGA1_BASE) + 0x44c) + +enum memory_bank { + BANK0, + BANK1, + BANK2, + BANK3 +}; + +enum orion5x_cpu_winen { + ORION5X_WIN_DISABLE, + ORION5X_WIN_ENABLE +}; + +enum orion5x_cpu_target { + ORION5X_TARGET_DRAM = 0, + ORION5X_TARGET_DEVICE = 1, + ORION5X_TARGET_PCI = 3, + ORION5X_TARGET_PCIE = 4, + ORION5X_TARGET_SASRAM = 9 +}; + +enum orion5x_cpu_attrib { + ORION5X_ATTR_DRAM_CS0 = 0x0e, + ORION5X_ATTR_DRAM_CS1 = 0x0d, + ORION5X_ATTR_DRAM_CS2 = 0x0b, + ORION5X_ATTR_DRAM_CS3 = 0x07, + ORION5X_ATTR_PCI_MEM = 0x59, + ORION5X_ATTR_PCI_IO = 0x51, + ORION5X_ATTR_PCIE_MEM = 0x59, + ORION5X_ATTR_PCIE_IO = 0x51, + ORION5X_ATTR_SASRAM = 0x00, + ORION5X_ATTR_DEV_CS0 = 0x1e, + ORION5X_ATTR_DEV_CS1 = 0x1d, + ORION5X_ATTR_DEV_CS2 = 0x1b, + ORION5X_ATTR_BOOTROM = 0x0f +}; + +/* + * Default Device Address MAP BAR values + */ +#define ORION5X_DEFADR_PCIE_MEM 0x90000000 +#define ORION5X_DEFADR_PCIE_MEM_REMAP_LO 0x90000000 +#define ORION5X_DEFADR_PCIE_MEM_REMAP_HI 0 +#define ORION5X_DEFSZ_PCIE_MEM (128*1024*1024) + +#define ORION5X_DEFADR_PCIE_IO 0xf0000000 +#define ORION5X_DEFADR_PCIE_IO_REMAP_LO 0x90000000 +#define ORION5X_DEFADR_PCIE_IO_REMAP_HI 0 +#define ORION5X_DEFSZ_PCIE_IO (64*1024) + +#define ORION5X_DEFADR_PCI_MEM 0x98000000 +#define ORION5X_DEFSZ_PCI_MEM (128*1024*1024) + +#define ORION5X_DEFADR_PCI_IO 0xf0100000 +#define ORION5X_DEFSZ_PCI_IO (64*1024) + +#define ORION5X_DEFADR_DEV_CS0 0xfa000000 +#define ORION5X_DEFSZ_DEV_CS0 (2*1024*1024) + +#define ORION5X_DEFADR_DEV_CS1 0xf8000000 +#define ORION5X_DEFSZ_DEV_CS1 (32*1024*1024) + +#define ORION5X_DEFADR_DEV_CS2 0xfa800000 +#define ORION5X_DEFSZ_DEV_CS2 (1*1024*1024) + +#define ORION5X_DEFADR_BOOTROM 0xFFF80000 +#define ORION5X_DEFSZ_BOOTROM (512*1024) + +/* + * PCIE registers are used for SoC device ID and revision + */ +#define PCIE_DEV_ID_OFF (ORION5X_REG_PCIE_BASE + 0x0000) +#define PCIE_DEV_REV_OFF (ORION5X_REG_PCIE_BASE + 0x0008) + +/* Orion-1 (88F5181) and Orion-VoIP (88F5181L) */ +#define MV88F5181_DEV_ID 0x5181 +#define MV88F5181_REV_B1 3 +#define MV88F5181L_REV_A0 8 +#define MV88F5181L_REV_A1 9 +/* Orion-NAS (88F5182) */ +#define MV88F5182_DEV_ID 0x5182 +#define MV88F5182_REV_A2 2 +/* Orion-2 (88F5281) */ +#define MV88F5281_DEV_ID 0x5281 +#define MV88F5281_REV_D0 4 +#define MV88F5281_REV_D1 5 +#define MV88F5281_REV_D2 6 +/* Orion-1-90 (88F6183) */ +#define MV88F6183_DEV_ID 0x6183 +#define MV88F6183_REV_B0 3 + +/* + * read feroceon core extra feature register + * using co-proc instruction + */ +static inline unsigned int readfr_extra_feature_reg(void) +{ + unsigned int val; + asm volatile ("mrc p15, 1, %0, c15, c1, 0 @ readfr exfr":"=r" + (val)::"cc"); + return val; +} + +/* + * write feroceon core extra feature register + * using co-proc instruction + */ +static inline void writefr_extra_feature_reg(unsigned int val) +{ + asm volatile ("mcr p15, 1, %0, c15, c1, 0 @ writefr exfr"::"r" + (val):"cc"); + isb(); +} + +/* + * AHB to Mbus Bridge Registers + * Source: 88F5182 User Manual, Appendix A, section A.4 + * Note: only windows 0 and 1 have remap capability. + */ +struct orion5x_win_registers { + u32 ctrl; + u32 base; + u32 remap_lo; + u32 remap_hi; +}; + +/* + * CPU control and status Registers + * Source: 88F5182 User Manual, Appendix A, section A.4 + */ +struct orion5x_cpu_registers { + u32 config; /*0x20100 */ + u32 ctrl_stat; /*0x20104 */ + u32 rstoutn_mask; /* 0x20108 */ + u32 sys_soft_rst; /* 0x2010C */ + u32 ahb_mbus_cause_irq; /* 0x20110 */ + u32 ahb_mbus_mask_irq; /* 0x20114 */ +}; + +/* + * GPIO Registers + * Source: 88F5182 User Manual, Appendix A, section A.17 + */ +struct orion5x_gpio_registers { + u32 dout; + u32 oe; + u32 blink_en; + u32 din_pol; + u32 din; + u32 int_cause; + u32 int_mask; + u32 int_level_mask; +}; + +/* + * functions + */ +void reset_cpu(unsigned long ignored); +u32 orion5x_device_id(void); +u32 orion5x_device_rev(void); +unsigned int orion5x_sdram_bar(enum memory_bank bank); +unsigned int orion5x_sdram_bs(enum memory_bank bank); +int orion5x_config_adr_windows(void); +void orion5x_config_gpio(unsigned int gpp_oe_val, unsigned int gpp_oe); +int orion5x_config_mpp(unsigned int mpp0_7, unsigned int mpp8_15, + unsigned int mpp16_23); +unsigned int orion5x_winctrl_calcsize(unsigned int sizeval); +#endif /* __ASSEMBLY__ */ +#endif /* _ORION5X_CPU_H */ diff --git a/include/asm-arm/arch-orion5x/gpio.h b/include/asm-arm/arch-orion5x/gpio.h new file mode 100644 index 0000000..58592ad --- /dev/null +++ b/include/asm-arm/arch-orion5x/gpio.h @@ -0,0 +1,52 @@ +/* + * Copyright (C) 2009 Albert ARIBAUD albert.aribaud@free.fr + * + * Based on arch/asm-arm/mach-kirkwood/include/mach/gpio.h + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +/* + * Based on (mostly copied from) plat-orion based Linux 2.6 kernel driver. + * Removed kernel level irq handling. Took some macros from kernel to + * allow build. + * + * Dieter Kiermaier dk-arm-linux@gmx.de + */ + +#ifndef __ORION5X_GPIO_H +#define __ORION5X_GPIO_H + +/* got from kernel include/linux/bitops.h */ +#define BITS_PER_BYTE 8 +#define BITS_TO_LONGS(nr) DIV_ROUND_UP(nr, BITS_PER_BYTE * sizeof(long)) + +#define GPIO_MAX 26 +#define GPIO_OUT(pin) (ORION5X_GPIO0_BASE + 0x00) +#define GPIO_IO_CONF(pin) (ORION5X_GPIO0_BASE + 0x04) +#define GPIO_BLINK_EN(pin) (ORION5X_GPIO0_BASE + 0x08) +#define GPIO_IN_POL(pin) (ORION5X_GPIO0_BASE + 0x0c) +#define GPIO_DATA_IN(pin) (ORION5X_GPIO0_BASE + 0x10) +#define GPIO_EDGE_CAUSE(pin) (ORION5X_GPIO0_BASE + 0x14) +#define GPIO_EDGE_MASK(pin) (ORION5X_GPIO0_BASE + 0x18) +#define GPIO_LEVEL_MASK(pin) (ORION5X_GPIO0_BASE + 0x1c) + +/* + * Orion5x-specific GPIO API + */ + +void orion5x_gpio_set_valid(unsigned pin, int mode); +int orion5x_gpio_is_valid(unsigned pin, int mode); +int orion5x_gpio_direction_input(unsigned pin); +int orion5x_gpio_direction_output(unsigned pin, int value); +int orion5x_gpio_get_value(unsigned pin); +void orion5x_gpio_set_value(unsigned pin, int value); +void orion5x_gpio_set_blink(unsigned pin, int blink); +void orion5x_gpio_set_unused(unsigned pin); + +#define GPIO_INPUT_OK (1 << 0) +#define GPIO_OUTPUT_OK (1 << 1) + +#endif diff --git a/include/asm-arm/arch-orion5x/mpp.h b/include/asm-arm/arch-orion5x/mpp.h new file mode 100644 index 0000000..31fade7 --- /dev/null +++ b/include/asm-arm/arch-orion5x/mpp.h @@ -0,0 +1,122 @@ +/* + * Copyright (C) 2009 Albert ARIBAUD albert.aribaud@free.fr + * + * Based on original Kirkwood support which is + * Copyright 2009: Marvell Technology Group Ltd. + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +#ifndef __ORION5X_MPP_H +#define __ORION5X_MPP_H + +#define MPP(_num, _sel, _in, _out, _F5182, _F5281) ( \ + /* MPP number */ ((_num) & 0xff) | \ + /* MPP select value */ (((_sel) & 0xf) << 8) | \ + /* may be input signal */ ((!!(_in)) << 12) | \ + /* may be output signal */ ((!!(_out)) << 13) | \ + /* available on F5182 */ ((!!(_F5182)) << 14) | \ + /* available on F5281 */ ((!!(_F5182)) << 15)) + +#define MPP_NUM(x) ((x) & 0xff) +#define MPP_SEL(x) (((x) >> 8) & 0xf) + + /* num sel i o 5182 5281 */ + +#define MPP_INPUT_MASK MPP(0, 0x0, 1, 0, 0, 0) +#define MPP_OUTPUT_MASK MPP(0, 0x0, 0, 1, 0, 0) + +#define MPP_F5182_MASK MPP(0, 0x0, 0, 0, 1, 0) +#define MPP_F5281_MASK MPP(0, 0x0, 0, 0, 0, 1) + +#define MPP0_PEX_RST_OUTn MPP(0, 0x0, 0, 1, 1, 1) +#define MPP0_PCI_REQ2n MPP(0, 0x2, 1, 0, 1, 1) +#define MPP0_GPIO MPP(0, 0x3, 1, 1, 1, 1) + +#define MPP1_GPIO MPP(1, 0x0, 1, 1, 1, 1) +#define MPP1_PCI_GNT2n MPP(1, 0x2, 0, 1, 1, 1) + +#define MPP2_GPIO MPP(2, 0x0, 1, 1, 1, 1) +#define MPP2_PCI_REQ3n MPP(2, 0x2, 1, 0, 1, 1) +#define MPP2_PMEn MPP(2, 0x3, 0, 1, 1, 1) + +#define MPP3_GPIO MPP(3, 0x0, 1, 1, 1, 1) +#define MPP3_PCI_GNT3nO MPP(3, 0x2, 0, 1, 1, 1) + +#define MPP4_GPIO MPP(4, 0x0, 1, 1, 1, 1) +#define MPP4_PCI_REQ4n MPP(4, 0x2, 1, 0, 1, 1) +#define MPP4_BOOT_NAND_FLASH_REn MPP(4, 0x4, 0, 0, 1, 1) +#define MPP4_SATA0_PRESENTn MPP(4, 0x5, 0, 1, 1, 0) + +#define MPP5_GPIO MPP(5, 0x0, 1, 1, 1, 1) +#define MPP5_PCI_GNT4n MPP(5, 0x2, 0, 1, 1, 1) +#define MPP5_BOOT_NAND_FLASH_WEn MPP(5, 0x4, 0, 0, 1, 1) +#define MPP5_SATA1_PRESENTn MPP(5, 0x5, 0, 1, 1, 0) + +#define MPP6_GPIO MPP(6, 0x0, 1, 1, 1, 1) +#define MPP6_PCI_REQ5n MPP(6, 0x2, 1, 0, 1, 1) +#define MPP6_NAND_FLASH_RE0n MPP(6, 0x4, 0, 0, 1, 1) +#define MPP6_SATA0_ACTn MPP(6, 0x5, 0, 1, 1, 0) + +#define MPP7_GPIO MPP(7, 0x0, 1, 1, 1, 1) +#define MPP7_PCI_GNT5n MPP(7, 0x2, 0, 1, 1, 1) +#define MPP7_NAND_FLASH_WE0n MPP(7, 0x4, 0, 0, 1, 1) +#define MPP7_SATA1_ACTn MPP(7, 0x5, 0, 1, 1, 0) + +#define MPP8_GPIO MPP(8, 0x0, 1, 1, 1, 1) +#define MPP8_GE_COL MPP(8, 0x1, 1, 0, 1, 1) + +#define MPP9_GPIO MPP(9, 0x0, 1, 1, 1, 1) +#define MPP9_GE_RXERR MPP(9, 0x1, 1, 0, 1, 1) + +#define MPP10_GPIO MPP(10, 0x0, 1, 1, 1, 1) +#define MPP10_GE_CRS MPP(10, 0x1, 1, 0, 1, 1) + +#define MPP11_GPIO MPP(11, 0x0, 1, 1, 1, 1) +#define MPP11_GE_TXERR MPP(11, 0x1, 0, 1, 1, 1) + +#define MPP12_GPIO MPP(12, 0x0, 1, 1, 1, 1) +#define MPP12_GE_TXD4 MPP(12, 0x1, 0, 1, 1, 1) +#define MPP12_NAND_FLASH_RE1n MPP(12, 0x4, 1, 1, 1, 1) +#define MPP12_SATA0_PRESENTn MPP(12, 0x5, 0, 1, 1, 0) + +#define MPP13_GPIO MPP(13, 0x0, 1, 1, 1, 1) +#define MPP13_GE_TXD5 MPP(13, 0x1, 0, 1, 1, 1) +#define MPP13_NAND_FLASH_WE1n MPP(13, 0x4, 0, 1, 1, 1) +#define MPP13_SATA1_PRESENTn MPP(13, 0x5, 0, 1, 1, 0) + +#define MPP14_GPIO MPP(14, 0x0, 1, 1, 1, 1) +#define MPP14_GE_TXD6 MPP(14, 0x1, 0, 1, 1, 1) +#define MPP14_NAND_FLASH_RE2n MPP(14, 0x4, 1, 1, 1, 1) +#define MPP14_SATA0_ACTn MPP(14, 0x5, 0, 1, 1, 0) + +#define MPP15_GPIO MPP(15, 0x0, 1, 1, 1, 1) +#define MPP15_GE_TXD7 MPP(15, 0x1, 0, 1, 1, 1) +#define MPP15_NAND_FLASH_WE2n MPP(15, 0x4, 0, 1, 1, 1) +#define MPP15_SATA1_ACTn MPP(15, 0x5, 0, 1, 1, 0) + +#define MPP16_UART1_RXD MPP(16, 0x0, 1, 0, 1, 1) +#define MPP16_GE_RXD4 MPP(16, 0x1, 1, 0, 1, 1) +#define MPP16_BOOT_NAND_FLASH_REn MPP(16, 0x4, 0, 0, 1, 1) +#define MPP16_GPIO MPP(16, 0x5, 1, 1, 1, 0) + +#define MPP17_UART1_TXD MPP(17, 0x0, 0, 1, 1, 1) +#define MPP17_GE_RXD5 MPP(17, 0x1, 1, 0, 1, 1) +#define MPP17_BOOT_NAND_FLASH_WEn MPP(17, 0x4, 0, 0, 1, 1) +#define MPP17_GPIO MPP(17, 0x5, 1, 1, 1, 0) + +#define MPP18_UART1_CTSn MPP(18, 0x0, 1, 0, 1, 1) +#define MPP18_GE_RXD6 MPP(18, 0x1, 1, 0, 1, 1) +#define MPP18_GPIO MPP(18, 0x5, 1, 1, 1, 0) + +#define MPP19_UART1_RTSn MPP(19, 0x0, 0, 1, 1, 1) +#define MPP19_GE_RXD7 MPP(19, 0x1, 1, 0, 1, 1) +#define MPP19_GPIO MPP(19, 0x5, 1, 1, 1, 0) + +#define MPP_MAX 19 + +void orion5x_mpp_conf(unsigned int *mpp_list); + +#endif diff --git a/include/asm-arm/arch-orion5x/orion5x.h b/include/asm-arm/arch-orion5x/orion5x.h new file mode 100644 index 0000000..850bca2 --- /dev/null +++ b/include/asm-arm/arch-orion5x/orion5x.h @@ -0,0 +1,67 @@ +/* + * Copyright (C) 2009 Albert ARIBAUD albert.aribaud@free.fr + * + * Based on original Kirkwood support which is + * (C) Copyright 2009 + * Marvell Semiconductor <www.marvell.com> + * Written-by: Prafulla Wadaskar prafulla@marvell.com + * + * Header file for Marvell's Orion SoC with Feroceon CPU core. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +#ifndef _ASM_ARCH_ORION5X_H +#define _ASM_ARCH_ORION5X_H + +#ifndef __ASSEMBLY__ +#include <asm/types.h> +#include <asm/io.h> +#endif /* __ASSEMBLY__ */ + +#if defined(CONFIG_FEROCEON) +#include <asm/arch/cpu.h> + +/* SOC specific definations */ +#define INTREG_BASE 0xd0000000 +#define ORION5X_REGISTER(x) (ORION5X_REGS_PHY_BASE + x) +#define ORION5X_OFFSET_REG (INTREG_BASE + 0x20080) + +/* Documented registers */ +#define ORION5X_TWSI_BASE (ORION5X_REGISTER(0x11000)) +#define ORION5X_UART0_BASE (ORION5X_REGISTER(0x12000)) +#define ORION5X_UART1_BASE (ORION5X_REGISTER(0x12100)) +#define ORION5X_MPP_BASE (ORION5X_REGISTER(0x10000)) +#define ORION5X_GPIO_BASE (ORION5X_REGISTER(0x10100)) +#define ORION5X_CPU_WIN_BASE (ORION5X_REGISTER(0x20000)) +#define ORION5X_CPU_REG_BASE (ORION5X_REGISTER(0x20100)) +#define ORION5X_TIMER_BASE (ORION5X_REGISTER(0x20300)) +#define ORION5X_REG_PCI_BASE (ORION5X_REGISTER(0x30000)) +#define ORION5X_REG_PCIE_BASE (ORION5X_REGISTER(0x40000)) +#define ORION5X_USB20_PORT0_BASE (ORION5X_REGISTER(0x50000)) +#define ORION5X_USB20_PORT1_BASE (ORION5X_REGISTER(0xA0000)) +#define ORION5X_EGIGA_BASE (ORION5X_REGISTER(0x72000)) + +#if defined(CONFIG_88F5182) +#include <asm/arch/88f5182.h> +#else +#error "SOC Name not defined" +#endif +#endif /* CONFIG_FEROCEON */ +#endif /* _ASM_ARCH_ORION5X_H */
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Albert Aribaud Sent: Sunday, November 15, 2009 1:27 PM To: U-Boot@lists.denx.de Subject: [U-Boot] [PATCH V2 1/3 CORRECTED] Initial support for Marvell Orion5x SoC
Please post this patch as v3 with above description as change log for v3
Regards.. Prafulla . . .
Hi Rafulla,
Seeing as I have also some fixes to do on patch V2 3/3, I'll report a whole V3 patchset with the description in the cover letter. Is that fine?
Amicalement,
-----Original Message----- From: Albert ARIBAUD [mailto:albert.aribaud@free.fr] Sent: Monday, November 16, 2009 2:52 PM To: Prafulla Wadaskar Cc: U-Boot@lists.denx.de Subject: Re: [U-Boot] [PATCH V2 1/3 CORRECTED] Initial support for Marvell Orion5x SoC
Hi Rafulla,
change log for v3
Seeing as I have also some fixes to do on patch V2 3/3, I'll report a whole V3 patch set with the description in the cover letter. Is that fine?
Change log is important to understand reviewers and other community friends to understand the history of the patch. In each patch you should maintain change log after line containing "---"
when patch will be applied, only commit log will be considered. So please segregate your information carefully.
Cover letter is optional, you better put enough information in the commit log relevant to patch
Amicalement,
Albert.
Dear Albert Aribaud,
In message 1258271818-27033-1-git-send-email-albert.aribaud@free.fr you wrote:
If this is a new patch version, you should write "V3" in the subject. And this "ATTENTION" has no place in the commit message. It belongs _below_ the "---" line. You are supposed to keep a history of changes between patch versions there.
Albert ARIBAUD
Albert Aribaud
Prafulla Wadaskar
