[PATCH] add kaslr-seed generation to extlinux.conf
add kaslrseed key word to extlinux.conf, which means generate kaslr-seed for linux
with this patch exlinux.conf boot item looks like
label l0 menu testing linux /boot/vmlinuz-5.15.16-arm initrd /boot/initramfs-5.15.16-arm.img fdtdir /boot/dtbs/5.15.16-arm/ kaslrseed append root=UUID=92ae1e50-eeeb-4c5b-8939-7e1cd6cfb059 ro
Signed-off-by: Zhang Ning zhangn1985@qq.com --- boot/pxe_utils.c | 69 +++++++++++++++++++++++++++++++++++++++++++++ include/pxe_utils.h | 2 ++ 2 files changed, 71 insertions(+)
diff --git a/boot/pxe_utils.c b/boot/pxe_utils.c index bb231b11a2..c7c422926e 100644 --- a/boot/pxe_utils.c +++ b/boot/pxe_utils.c @@ -20,6 +20,11 @@ #include <errno.h> #include <linux/list.h>
+#ifdef CONFIG_DM_RNG +#include <dm.h> +#include <rng.h> +#endif + #include <splash.h> #include <asm/io.h>
@@ -311,6 +316,61 @@ static int label_localboot(struct pxe_label *label) return run_command_list(localcmd, strlen(localcmd), 0); }
+/* + * label_boot_kaslrseed generate kaslrseed from hw rng + */ + +static void label_boot_kaslrseed(void) +{ +#ifdef CONFIG_DM_RNG + ulong fdt_addr; + struct fdt_header *working_fdt; + size_t n = 0x8; + struct udevice *dev; + u64 *buf; + int nodeoffset; + int err; + + /* Get the main fdt and map it */ + fdt_addr = hextoul(env_get("fdt_addr_r"), NULL); + working_fdt = map_sysmem(fdt_addr, 0); + err = fdt_check_header(working_fdt); + if (err) + return; + + if (uclass_get_device(UCLASS_RNG, 0, &dev) || !dev) { + printf("No RNG device\n"); + return; + } + + buf = malloc(n); + if (!buf) { + printf("Out of memory\n"); + return; + } + + if (dm_rng_read(dev, buf, n)) { + printf("Reading RNG failed\n"); + return; + } + + nodeoffset = fdt_find_or_add_subnode(working_fdt, 0, "chosen"); + if (nodeoffset < 0) { + printf("Reading chosen node failed\n"); + return; + } + + err = fdt_setprop(working_fdt, nodeoffset, "kaslr-seed", buf, sizeof(buf)); + if (err < 0) { + printf("Unable to set kaslr-seed on chosen node: %s\n", fdt_strerror(err)); + return; + } + + free(buf); +#endif + return; +} + /** * label_boot_fdtoverlay() - Loads fdt overlays specified in 'fdtoverlays' * @@ -631,6 +691,9 @@ static int label_boot(struct pxe_context *ctx, struct pxe_label *label) } }
+ if (label->kaslrseed) + label_boot_kaslrseed(); + #ifdef CONFIG_OF_LIBFDT_OVERLAY if (label->fdtoverlays) label_boot_fdtoverlay(ctx, label); @@ -710,6 +773,7 @@ enum token_type { T_ONTIMEOUT, T_IPAPPEND, T_BACKGROUND, + T_KASLRSEED, T_INVALID };
@@ -741,6 +805,7 @@ static const struct token keywords[] = { {"ontimeout", T_ONTIMEOUT,}, {"ipappend", T_IPAPPEND,}, {"background", T_BACKGROUND,}, + {"kaslrseed", T_KASLRSEED,}, {NULL, T_INVALID} };
@@ -1194,6 +1259,10 @@ static int parse_label(char **c, struct pxe_menu *cfg) err = parse_integer(c, &label->ipappend); break;
+ case T_KASLRSEED: + label->kaslrseed = 1; + break; + case T_EOL: break;
diff --git a/include/pxe_utils.h b/include/pxe_utils.h index dad2668818..4a73b2aace 100644 --- a/include/pxe_utils.h +++ b/include/pxe_utils.h @@ -33,6 +33,7 @@ * initrd - path to the initrd to use for this label. * attempted - 0 if we haven't tried to boot this label, 1 if we have. * localboot - 1 if this label specified 'localboot', 0 otherwise. + * kaslrseed - 1 if generate kaslrseed from hw_rng * list - lets these form a list, which a pxe_menu struct will hold. */ struct pxe_label { @@ -50,6 +51,7 @@ struct pxe_label { int attempted; int localboot; int localboot_val; + int kaslrseed; struct list_head list; };
Hi Zhang,
I am not too familiar with the extlinux stuff in U-Boot. Does that boot with efi or not? On the efi booting kaslr-seed is close to useless for linux. In fact we explicitly strip it when booting with EFI and and RNG hardware is available.
The EFI stub ignores it and uses the EFI_RNG_PROTOCOL. Since you rely on an rng device to generate it the EFI_RNG_PROTOCOL will be installed.
- label_boot_kaslrseed generate kaslrseed from hw rng
- ulong fdt_addr;
- struct fdt_header *working_fdt;
- size_t n = 0x8;
- struct udevice *dev;
- u64 *buf;
- int nodeoffset;
- int err;
- /* Get the main fdt and map it */
- fdt_addr = hextoul(env_get("fdt_addr_r"), NULL);
- working_fdt = map_sysmem(fdt_addr, 0);
- err = fdt_check_header(working_fdt);
- if (err)
return;
- if (uclass_get_device(UCLASS_RNG, 0, &dev) || !dev) {
return;
- buf = malloc(n);
- if (!buf) {
return;
- if (dm_rng_read(dev, buf, n)) {
return;
- nodeoffset = fdt_find_or_add_subnode(working_fdt, 0, "chosen");
- if (nodeoffset < 0) {
return;
- err = fdt_setprop(working_fdt, nodeoffset, "kaslr-seed", buf, sizeof(buf));
- if (err < 0) {
return;
Almost all of the return cases fail to free the buffer. I'd write that a bit differently as well. Just allocate the buffer *after* you made sure the hardware and required nodes are there.
Regards /Ilias
- free(buf);
- return;
- label_boot_fdtoverlay() - Loads fdt overlays specified in 'fdtoverlays'
- T_KASLRSEED, T_INVALID
- {"kaslrseed", T_KASLRSEED,}, {NULL, T_INVALID}
case T_KASLRSEED:
break;
- case T_EOL: break;
- initrd - path to the initrd to use for this label.
- attempted - 0 if we haven't tried to boot this label, 1 if we have.
- localboot - 1 if this label specified 'localboot', 0 otherwise.
- kaslrseed - 1 if generate kaslrseed from hw_rng
- list - lets these form a list, which a pxe_menu struct will hold.
- int kaslrseed; struct list_head list;
-- 2.34.1
On Sat, Jan 29, 2022 at 03:04:48PM +0200, Ilias Apalodimas wrote:
Hi Zhang,
thank you for your review.
extlinux is same as bootm cmd in uboot cmdline, thus no relationship with EFI boot. I checked my old Uboot for khadas VIM, EFI_RNG_PROTOCOL is set, and kernel EFI_STUB is set, and I use extlinux.conf, kernel still complain no kalsr seed.
- ulong fdt_addr;
- size_t n = 0x8;
- u64 *buf;
- int nodeoffset;
- int err;
- if (err)
return;
return;
- buf = malloc(n);
- if (!buf) {
return;
return;
return;
- if (err < 0) {
return;
these code are copied from cmd/kalsrseed.c, I will add buff free in next version.
Regards /Ilias
- free(buf);
- return;
case T_KASLRSEED:
break;
-- 2.34.1
Ilias Apalodimas
ning
Zhang Ning
