[PATCH v3] gitlab: x86: Add a coreboot test
Coreboot supports U-Boot as a payload and this recently got a bit of a facelist. Add a test for this.
For now this uses a binary build of coreboot (v4.15). Future work could potentially build it from source, but we need to figure out the toolchain problems first, since coreboot uses its own toolchain. It turns out that this is tricky, because coreboot fails to build with a vanilla gcc.
This needs some changes to the hooks scripts as well. An example build is at https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/359687
Changes in v3: - Drop RFC tag
Changes in v2: - Drop the local CI changes; we need the real ones applied first anyway
.gitlab-ci.yml | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 4c44c01e7bf..75ad67fab03 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -52,6 +52,16 @@ stages: genimage --inputpath . --config board/sifive/unleashed/genimage_spi-nor.cfg; cp images/spi-nor.img ${UBOOT_TRAVIS_BUILD_DIR}/; fi + - if [[ "${TEST_PY_BD}" == "coreboot" ]]; then + wget -O - + "https://drive.google.com/uc?id=1x6nrtWIyIRPLS2cQBwYTnT2TbOI8UjmM&export=..." | + xz -dc >${UBOOT_TRAVIS_BUILD_DIR}/coreboot.rom; + wget -O - + "https://drive.google.com/uc?id=149Cz-5SZXHNKpi9xg6R_5XITWohu348y&export=..." > + cbfstool; + chmod a+x cbfstool; + ./cbfstool ${UBOOT_TRAVIS_BUILD_DIR}/coreboot.rom add-flat-binary -f ${UBOOT_TRAVIS_BUILD_DIR}/u-boot.bin -n fallback/payload -c LZMA -l 0x1110000 -e 0x1110000; + fi - virtualenv -p /usr/bin/python3 /tmp/venv - . /tmp/venv/bin/activate - pip install -r test/py/requirements.txt @@ -61,6 +71,10 @@ stages: ./test/py/test.py -ra --bd ${TEST_PY_BD} ${TEST_PY_ID} ${TEST_PY_TEST_SPEC:+"-k ${TEST_PY_TEST_SPEC}"} --build-dir "$UBOOT_TRAVIS_BUILD_DIR" + # It seems that the files in /tmp go away, so copy out what we need + - if [[ "${TEST_PY_BD}" == "coreboot" ]]; then + cp -v /tmp/coreboot/*.{html,css} .; + fi
build all 32bit ARM platforms: stage: world build @@ -387,3 +401,15 @@ xtfpga test.py: TEST_PY_TEST_SPEC: "not sleep" TEST_PY_ID: "--id qemu" <<: *buildman_and_testpy_dfn + +coreboot test.py: + variables: + TEST_PY_BD: "coreboot" + TEST_PY_TEST_SPEC: "not sleep" + TEST_PY_ID: "--id qemu" + artifacts: + paths: + - "*.html" + - "*.css" + expire_in: 1 week + <<: *buildman_and_testpy_dfn
Changes in v3:
- Drop RFC tag
Changes in v2:
We need to do similar in Azure. Due to the nature of what hosts are available, GitLab ends up being a subset of Azure in terms of whats tested (we can't easily do Windows/macOS host tools in GitLab).
Hi Tom,
Changes in v3:
- Drop RFC tag
Changes in v2:
Oops I forgot to add that, will do.
