[U-Boot] [PATCH] rpi: link to another model number info source
This source has been blessed by Dom Cobley at the RPi Foundation, so seems like the best source to refer to. It's a superset of and consistent with the other sources.
Cc: Lubomir Rintel lkundrak@v3.sk Cc: Eric Anholt eric@anholt.net Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- This patch is in reponse to Lubomir Rintel's "rpi: fix up Model B entries", although doesn't actually depend on it for context. --- board/raspberrypi/rpi/rpi.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index b344362514fe..89d78cc6c407 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -78,6 +78,11 @@ struct msg_get_clock_rate { * http://raspberryalphaomega.org.uk/2013/02/06/automatic-raspberry-pi-board-re... * http://www.raspberrypi.org/forums/viewtopic.php?f=63&t=32733 * http://git.drogon.net/?p=wiringPi;a=blob;f=wiringPi/wiringPi.c;h=503151f6101... + * + * In http://lists.denx.de/pipermail/u-boot/2016-January/243752.html + * ("[U-Boot] [PATCH] rpi: fix up Model B entries") Dom Cobley at the RPi + * Foundation stated that the following source was accurate: + * https://github.com/AndrewFromMelbourne/raspberry_pi_revision */ struct rpi_model { const char *name;
Stephen Warren
