[U-Boot] [PATCH] we don't went version control for .cmd files
commit 5acba11ad70ba7eeb8cc82e7dd77871f022964dd Author: Pavel Machek pavel@denx.de Date: Sat Mar 22 20:09:49 2014 +0100
.cmd files should not be version-controlled.
Signed-off-by: Pavel Machek pavel@denx.de
diff --git a/.gitignore b/.gitignore index a163728..77fb2c8 100644 --- a/.gitignore +++ b/.gitignore @@ -15,6 +15,7 @@ *.swp *.patch *.bin +*.cmd
# Build tree /build-*
Hi Pavel,
Which files do you need this patch for? Could you give me an example, please?
Best Regards Masahiro Yamada
Hi!
My build leaves files such as
./common/.fdt_support.o.cmd ./common/.console.o.cmd ./common/.main.o.cmd ./common/.cmd_load.o.cmd ./common/.flash.o.cmd ./common/.env_flags.o.cmd ./common/.cmd_source.o.cmd ./common/.built-in.o.cmd
. Git usage would be slightly nicer if those were ignored. My u-boot is based on v2013.01.01... hmm. I expected Altera to have slightly newer version. That may explain stuff.
Pavel
Hi Pavel,
On Mon, 24 Mar 2014 10:29:56 +0100 Pavel Machek pavel@denx.de wrote:
Hi!
.*.cmd files were introduced by Kbuild at v2014.04-rc1 and correctly ignored. v2013.01.01 you are using has nothing to do with Kbuild.
I guess you built at u-boot/master (.*.cmd files were generated) and then you checked out v2013.01.01.
And one more thing. Your patch is not applicable at all. Please do not post a patch based on such an old tag.
Not Acked by Masahiro Yamada
Hi!
Yes, I guess that's what happened.
Sorry for the noise, Pavel
Masahiro Yamada
Pavel Machek
