[U-Boot-Users] U-boot with IBM-PPC440GP - questions
Hi, there,
(please answer with copy to me, because I am not subscribed to the mailing list)
My company is starting to develop an IBM-PPC440GP based board, and, as it is a new processor for me, I am thinking on using the u-boot as the boot loader. I installed the source code and I generated the image for ebony (IBM-PPC440GP eval board), though I don't have it. I analysed the features the packet have, and it seems to have everything I need. However, I would like to ask some questions before deciding for it:
(1) - Did anyone use the U-boot with the IBM-440GP? If so, could you give me an idea of the boot time, both with the default configuration and with an optimized configuration?
(2) - The binary file (u-boot.bin) generated was too big for me (almost half Mbytes). Could it be smaller, how? Is it already compressed?
(3) - My board uses the LXT972 as the Ethernet transceiver (PHY). Does the boot loader support it?
(4) - I will use the Montavista Linux as operating system. Have anyone done that already? How hard is it to integrate the U-boot with it?
(5) - Will I have to publish the changes which are specific to my board, if I use the u-boot?
Thank you,
Helio Fujimoto.
This is a one-time exception. You ask here, so we reply here.
I did such measurements lately, but on a slower system (405EP at 133 MHz); in this application it was critical how long it takes until a certain Linux device driver starts running to empty some FIFOs. Without any modifications to the code the driver started running not more than 600 milliseconds after Power-on; the Linux kernel starts loading about 175 ms after power-on. Approx. 110ms of this time is spent for the PCI initialization; if you omit this, you can probably start the Linux kernel 65 ms after power-on.
The image is mostly empty. The size is determined by the link address in flash and the faxt that the reset vector is the last word in flash - there is a huge gap. The actual code is MUCH scmaller:
-> MAKEALL EBONY Configuring for EBONY board... text data bss dec hex filename 163772 24316 23948 212036 33c44 u-boot
As you can see, the real size is 212036 bytes = 207 kB.
Sure.
Zero effort.
If you distribute the board with your modified U-Boot, yes. U-Boot is covered by the GPL.
Helio Fujimoto
