[U-Boot] [PATCH v6 00/11] arm, davinci: add support for dm368 based cam_enc_4xx board
This is a repost of the cam_enc_4xx board support patches from http://lists.denx.de/pipermail/u-boot/2011-October/107651.html
changes for v6: - moved arch/arm/cpu/arm926ejs/davinci/spl_nand.c to drivers/mtd/nand/nand_spl_load.c as Scoot Wood suggested. compiled through CONFIG_SPL_NAND_LOAD define - make enable_vbus() weak with alias, as Igor Grinberg suggested.
Patches are checkpatch clean
"./MAKEALL -a arm --soc davinci" compiles clean with patch: http://patchwork.ozlabs.org/patch/122348/
Also needed patches:
[U-Boot] net, davinci_emac: fix compiler error http://patchwork.ozlabs.org/patch/122348/
arm, arm926: fix missing symbols in NAND_SPL mode http://patchwork.ozlabs.org/patch/104942/
arm, davinci: replace CONFIG_PRELOADER with CONFIG_SPL_BUILD http://patchwork.ozlabs.org/patch/106983/
[U-Boot,v2,2/3] arm, davinci: Add function lpsc_syncreset() http://patchwork.ozlabs.org/patch/119375/
Albert? Maybe this patchset has a chance to go now in mainline? It is pending now since Sat Jul 16 12:06:41 CEST 2011, see: http://lists.denx.de/pipermail/u-boot/2011-July/096302.html
Cc: Sandeep Paulraj s-paulraj@ti.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net
Heiko Schocher (11): usb, davinci: add enable_vbus() weak function arm, usb, davinci: make USBPHY_CTL register configurable net, davinci_emac: make clock divider in MDIO control register configurable spl: add option for adding post memory test to the SPL framework arm, davinci: add support for new spl framework spl, nand: add 4bit HW ecc oob first nand_read_page function arm, davinci: add header files for dm365 arm, davinci: add lowlevel function for dm365 soc arm926ejs, davinci: add cpuinfo for dm365 arm926ejs, davinci: add missing spi defines for dm365 arm, davinci: add cam_enc_4xx support
MAINTAINERS | 1 + Makefile | 8 +- README | 5 + arch/arm/cpu/arm926ejs/davinci/Makefile | 5 + arch/arm/cpu/arm926ejs/davinci/cpu.c | 27 ++- arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c | 439 +++++++++++++++++++ arch/arm/cpu/arm926ejs/davinci/spl.c | 63 +++ arch/arm/cpu/arm926ejs/start.S | 25 +- arch/arm/include/asm/arch-davinci/aintc_defs.h | 50 +++ arch/arm/include/asm/arch-davinci/dm365_lowlevel.h | 41 ++ arch/arm/include/asm/arch-davinci/hardware.h | 15 + arch/arm/include/asm/arch-davinci/pll_defs.h | 84 ++++ arch/arm/include/asm/arch-davinci/psc_defs.h | 86 ++++ arch/arm/include/asm/arch-davinci/syscfg_defs.h | 66 +++ board/ait/cam_enc_4xx/Makefile | 46 ++ board/ait/cam_enc_4xx/cam_enc_4xx.c | 446 +++++++++++++++++++ board/ait/cam_enc_4xx/config.mk | 15 + board/ait/cam_enc_4xx/u-boot-spl.lds | 73 ++++ board/ait/cam_enc_4xx/ublimage.cfg | 48 ++ boards.cfg | 1 + doc/README.SPL | 2 + doc/README.davinci.nand_spl | 141 ++++++ drivers/mtd/nand/Makefile | 3 + drivers/mtd/nand/nand_spl_load.c | 56 +++ drivers/mtd/nand/nand_spl_simple.c | 43 ++- drivers/net/davinci_emac.c | 9 +- drivers/usb/musb/davinci.c | 20 +- include/configs/cam_enc_4xx.h | 453 ++++++++++++++++++++ spl/Makefile | 1 + tools/ublimage.h | 2 +- 30 files changed, 2262 insertions(+), 12 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c create mode 100644 arch/arm/cpu/arm926ejs/davinci/spl.c create mode 100644 arch/arm/include/asm/arch-davinci/aintc_defs.h create mode 100644 arch/arm/include/asm/arch-davinci/dm365_lowlevel.h create mode 100644 arch/arm/include/asm/arch-davinci/pll_defs.h create mode 100644 arch/arm/include/asm/arch-davinci/psc_defs.h create mode 100644 arch/arm/include/asm/arch-davinci/syscfg_defs.h create mode 100644 board/ait/cam_enc_4xx/Makefile create mode 100644 board/ait/cam_enc_4xx/cam_enc_4xx.c create mode 100644 board/ait/cam_enc_4xx/config.mk create mode 100644 board/ait/cam_enc_4xx/u-boot-spl.lds create mode 100644 board/ait/cam_enc_4xx/ublimage.cfg create mode 100644 doc/README.davinci.nand_spl create mode 100644 drivers/mtd/nand/nand_spl_load.c create mode 100644 include/configs/cam_enc_4xx.h
Signed-off-by: Heiko Schocher hs@denx.de Cc: Remy Bohmer linux@bohmer.net Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Igor Grinberg grinberg@compulab.co.il
--- changes for v4: - patch is new since v4, as Igor Grinberg suggested. changes for v6: - make enable_vbus() weak with alias
drivers/usb/musb/davinci.c | 14 ++++++++++++-- 1 files changed, 12 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/musb/davinci.c b/drivers/usb/musb/davinci.c index f56f2df..c94a762 100644 --- a/drivers/usb/musb/davinci.c +++ b/drivers/usb/musb/davinci.c @@ -78,6 +78,17 @@ static void phy_off(void) writel(USBPHY_OSCPDWN | USBPHY_PHYPDWN, USBPHY_CTL_PADDR); }
+void __enable_vbus(void) +{ + /* + * nothing to do, vbus is handled through the cpu. + * Define this function in board code, if it is + * different on your board. + */ +} +void enable_vbus(void) + __attribute__((weak, alias("__enable_vbus"))); + /* * This function performs Davinci platform specific initialization for usb0. */ @@ -86,9 +97,8 @@ int musb_platform_init(void) u32 revision;
/* enable USB VBUS */ -#ifndef DAVINCI_DM365EVM enable_vbus(); -#endif + /* start the on-chip USB phy and its pll */ if (!phy_on()) return -1;
Define CONFIG_DV_USBPHY_CTL for setting the USB PHY control register.
Signed-off-by: Heiko Schocher hs@denx.de Acked-by: Remy Bohmer linux@bohmer.net cc: Sandeep Paulraj s-paulraj@ti.com cc: Remy Bohmer linux@bohmer.net --- drivers/usb/musb/davinci.c | 6 +++++- 1 files changed, 5 insertions(+), 1 deletions(-)
diff --git a/drivers/usb/musb/davinci.c b/drivers/usb/musb/davinci.c index c94a762..359c635 100644 --- a/drivers/usb/musb/davinci.c +++ b/drivers/usb/musb/davinci.c @@ -26,6 +26,10 @@ #include "davinci.h" #include <asm/arch/hardware.h>
+#if !defined(CONFIG_DV_USBPHY_CTL) +#define CONFIG_DV_USBPHY_CTL (USBPHY_SESNDEN | USBPHY_VBDTCTEN) +#endif + /* MUSB platform configuration */ struct musb_config musb_cfg = { .regs = (struct musb_regs *)MENTOR_USB0_BASE, @@ -50,7 +54,7 @@ static u8 phy_on(void) writel(USBPHY_PHY24MHZ | USBPHY_SESNDEN | USBPHY_VBDTCTEN, USBPHY_CTL_PADDR); #else - writel(USBPHY_SESNDEN | USBPHY_VBDTCTEN, USBPHY_CTL_PADDR); + writel(CONFIG_DV_USBPHY_CTL, USBPHY_CTL_PADDR); #endif timeout = musb_cfg.timeout;
Define CONFIG_SYS_EMAC_TI_CLKDIV for setting the clkdiv value in the MDIO control register.
Signed-off-by: Heiko Schocher hs@denx.de cc: Sandeep Paulraj s-paulraj@ti.com cc: Wolfgang Denk wd@denx.de --- drivers/net/davinci_emac.c | 9 +++++++-- 1 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/drivers/net/davinci_emac.c b/drivers/net/davinci_emac.c index a900480..fa31159 100644 --- a/drivers/net/davinci_emac.c +++ b/drivers/net/davinci_emac.c @@ -53,6 +53,11 @@ unsigned int emac_dbg = 0; #define emac_gigabit_enable(phy_addr) /* no gigabit to enable */ #endif
+#if !defined(CONFIG_SYS_EMAC_TI_CLKDIV) +#define CONFIG_SYS_EMAC_TI_CLKDIV ((EMAC_MDIO_BUS_FREQ / \ + EMAC_MDIO_CLOCK_FREQ) - 1) +#endif + static void davinci_eth_mdio_enable(void);
static int gen_init_phy(int phy_addr); @@ -131,7 +136,7 @@ static void davinci_eth_mdio_enable(void) { u_int32_t clkdiv;
- clkdiv = (EMAC_MDIO_BUS_FREQ / EMAC_MDIO_CLOCK_FREQ) - 1; + clkdiv = CONFIG_SYS_EMAC_TI_CLKDIV;
writel((clkdiv & 0xff) | MDIO_CONTROL_ENABLE | @@ -473,7 +478,7 @@ static int davinci_eth_open(struct eth_device *dev, bd_t *bis) #endif
/* Init MDIO & get link state */ - clkdiv = (EMAC_MDIO_BUS_FREQ / EMAC_MDIO_CLOCK_FREQ) - 1; + clkdiv = CONFIG_SYS_EMAC_TI_CLKDIV; writel((clkdiv & 0xff) | MDIO_CONTROL_ENABLE | MDIO_CONTROL_FAULT, &adap_mdio->CONTROL);
Signed-off-by: Heiko Schocher hs@denx.de Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Sandeep Paulraj s-paulraj@ti.com Cc: Sergei Shtylyov sshtylyov@mvista.com
--- changes for v4: - add comment from Sergei Shtylyov: - remove Leftmost open parent in dox/README.SPL
doc/README.SPL | 1 + spl/Makefile | 1 + 2 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/doc/README.SPL b/doc/README.SPL index b4500fc..b460e84 100644 --- a/doc/README.SPL +++ b/doc/README.SPL @@ -63,3 +63,4 @@ CONFIG_SPL_LIBGENERIC_SUPPORT (lib/libgeneric.o) CONFIG_SPL_POWER_SUPPORT (drivers/power/libpower.o) CONFIG_SPL_NAND_SUPPORT (drivers/mtd/nand/libnand.o) CONFIG_SPL_DMA_SUPPORT (drivers/dma/libdma.o) +CONFIG_SPL_POST_MEM_SUPPORT (post/drivers/memory.o) diff --git a/spl/Makefile b/spl/Makefile index ed1f770..fec005f 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -55,6 +55,7 @@ LIBS-$(CONFIG_SPL_LIBGENERIC_SUPPORT) += lib/libgeneric.o LIBS-$(CONFIG_SPL_POWER_SUPPORT) += drivers/power/libpower.o LIBS-$(CONFIG_SPL_NAND_SUPPORT) += drivers/mtd/nand/libnand.o LIBS-$(CONFIG_SPL_DMA_SUPPORT) += drivers/dma/libdma.o +LIBS-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/memory.o
ifeq ($(SOC),omap3) LIBS-y += $(CPUDIR)/omap-common/libomap-common.o
Signed-off-by: Heiko Schocher hs@denx.de Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Sandeep Paulraj s-paulraj@ti.com Cc: Scott Wood scottwood@freescale.com
--- change for v6: - moved arch/arm/cpu/arm926ejs/davinci/spl_nand.c to drivers/mtd/nand/nand_spl_load.c as Scoot Wood suggested. compiled through CONFIG_SPL_NAND_LOAD define
Makefile | 8 +++- arch/arm/cpu/arm926ejs/davinci/Makefile | 5 ++ arch/arm/cpu/arm926ejs/davinci/spl.c | 63 +++++++++++++++++++++++++++++++ arch/arm/cpu/arm926ejs/start.S | 25 ++++++++++++- doc/README.SPL | 1 + drivers/mtd/nand/Makefile | 3 + drivers/mtd/nand/nand_spl_load.c | 56 +++++++++++++++++++++++++++ 7 files changed, 158 insertions(+), 3 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/davinci/spl.c create mode 100644 drivers/mtd/nand/nand_spl_load.c
diff --git a/Makefile b/Makefile index 9ef33f9..46a6e78 100644 --- a/Makefile +++ b/Makefile @@ -415,9 +415,13 @@ $(obj)u-boot.sha1: $(obj)u-boot.bin $(obj)u-boot.dis: $(obj)u-boot $(OBJDUMP) -d $< > $@
-$(obj)u-boot.ubl: $(obj)u-boot-nand.bin +$(obj)u-boot.ubl: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin + $(OBJCOPY) ${OBJCFLAGS} --pad-to=$(PAD_TO) -O binary $(obj)spl/u-boot-spl $(obj)spl/u-boot-spl-pad.bin + cat $(obj)spl/u-boot-spl-pad.bin $(obj)u-boot.bin > $(obj)u-boot-ubl.bin $(obj)tools/mkimage -n $(UBL_CONFIG) -T ublimage \ - -e $(CONFIG_SYS_TEXT_BASE) -d $< $@ + -e $(CONFIG_SYS_TEXT_BASE) -d $(obj)u-boot-ubl.bin $(obj)u-boot.ubl + rm $(obj)u-boot-ubl.bin + rm $(obj)spl/u-boot-spl-pad.bin
ifeq ($(CONFIG_SANDBOX),y) GEN_UBOOT = \ diff --git a/arch/arm/cpu/arm926ejs/davinci/Makefile b/arch/arm/cpu/arm926ejs/davinci/Makefile index 0310957..98c7e55 100644 --- a/arch/arm/cpu/arm926ejs/davinci/Makefile +++ b/arch/arm/cpu/arm926ejs/davinci/Makefile @@ -35,6 +35,11 @@ COBJS-$(CONFIG_SOC_DM644X) += dm644x.o COBJS-$(CONFIG_SOC_DM646X) += dm646x.o COBJS-$(CONFIG_DRIVER_TI_EMAC) += lxt972.o dp83848.o et1011c.o ksz8873.o
+ifdef CONFIG_SPL_BUILD +COBJS-y += spl.o +COBJS-y += dm365_lowlevel.o +endif + SOBJS = reset.o
ifndef CONFIG_SKIP_LOWLEVEL_INIT diff --git a/arch/arm/cpu/arm926ejs/davinci/spl.c b/arch/arm/cpu/arm926ejs/davinci/spl.c new file mode 100644 index 0000000..d9b9398 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/davinci/spl.c @@ -0,0 +1,63 @@ +/* + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/u-boot.h> +#include <asm/utils.h> +#include <nand.h> +#include <asm/arch/dm365_lowlevel.h> +#include <ns16550.h> + +void puts(const char *str) +{ + while (*str) + putc(*str++); +} + +void putc(char c) +{ + if (c == '\n') + NS16550_putc((NS16550_t)(CONFIG_SYS_NS16550_COM1), '\r'); + + NS16550_putc((NS16550_t)(CONFIG_SYS_NS16550_COM1), c); +} + +inline void hang(void) +{ + puts("### ERROR ### Please RESET the board ###\n"); + for (;;) + ; +} + +void board_init_f(ulong dummy) +{ + dm36x_lowlevel_init(0); + relocate_code(CONFIG_SPL_STACK, NULL, CONFIG_SPL_TEXT_BASE); +} + +void board_init_r(gd_t *id, ulong dummy) +{ + + nand_init(); + puts("Nand boot...\n"); + nand_boot(); +} diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 86a0dc2..339c5ed 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -126,7 +126,15 @@ _fiq:
.globl _TEXT_BASE _TEXT_BASE: +#ifdef CONFIG_NAND_SPL /* deprecated, use instead CONFIG_SPL_BUILD */ .word CONFIG_SYS_TEXT_BASE +#else +#ifdef CONFIG_SPL_BUILD + .word CONFIG_SPL_TEXT_BASE +#else + .word CONFIG_SYS_TEXT_BASE +#endif +#endif
/* * These are defined in the board-specific linker script. @@ -192,7 +200,15 @@ reset:
/* Set stackpointer in internal RAM to call board_init_f */ call_board_init_f: +#ifdef CONFIG_NAND_SPL /* deprecated, use instead CONFIG_SPL_BUILD */ + ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#else +#ifdef CONFIG_SPL_BUILD + ldr sp, =(CONFIG_SPL_STACK) +#else ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#endif +#endif bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ ldr r0,=0x00000000 bl board_init_f @@ -217,6 +233,7 @@ stack_setup: mov sp, r4
adr r0, _start + sub r9, r6, r0 /* r9 <- relocation offset */ cmp r0, r6 beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy loop */ @@ -271,12 +288,17 @@ fixnext: #endif
clear_bss: -#ifndef CONFIG_SPL_BUILD +#ifdef CONFIG_SPL_BUILD + /* No relocation for SPL */ + ldr r0, =__bss_start + ldr r1, =__bss_end__ +#else ldr r0, _bss_start_ofs ldr r1, _bss_end_ofs mov r4, r6 /* reloc addr */ add r0, r0, r4 add r1, r1, r4 +#endif mov r2, #0x00000000 /* clear */
clbss_l:str r2, [r0] /* clear loop... */ @@ -284,6 +306,7 @@ clbss_l:str r2, [r0] /* clear loop... */ cmp r0, r1 bne clbss_l
+#ifndef CONFIG_SPL_BUILD bl coloured_LED_init bl red_led_on #endif diff --git a/doc/README.SPL b/doc/README.SPL index b460e84..89d24a7 100644 --- a/doc/README.SPL +++ b/doc/README.SPL @@ -64,3 +64,4 @@ CONFIG_SPL_POWER_SUPPORT (drivers/power/libpower.o) CONFIG_SPL_NAND_SUPPORT (drivers/mtd/nand/libnand.o) CONFIG_SPL_DMA_SUPPORT (drivers/dma/libdma.o) CONFIG_SPL_POST_MEM_SUPPORT (post/drivers/memory.o) +CONFIG_SPL_NAND_LOAD (drivers/mtd/nand/nand_spl_load.o) diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 1eeba5c..28bd350 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -30,6 +30,9 @@ ifdef CONFIG_SPL_BUILD ifdef CONFIG_SPL_NAND_SIMPLE COBJS-y += nand_spl_simple.o endif +ifdef CONFIG_SPL_NAND_LOAD +COBJS-y += nand_spl_load.o +endif else COBJS-y += nand.o COBJS-y += nand_bbt.o diff --git a/drivers/mtd/nand/nand_spl_load.c b/drivers/mtd/nand/nand_spl_load.c new file mode 100644 index 0000000..ae8d5ac --- /dev/null +++ b/drivers/mtd/nand/nand_spl_load.c @@ -0,0 +1,56 @@ +/* + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <nand.h> + +/* + * The main entry for NAND booting. It's necessary that SDRAM is already + * configured and available since this code loads the main U-Boot image + * from NAND into SDRAM and starts it from there. + */ +void nand_boot(void) +{ + int ret; + __attribute__((noreturn)) void (*uboot)(void); + + /* + * Load U-Boot image from NAND into RAM + */ + ret = nand_spl_load_image(CONFIG_SYS_NAND_U_BOOT_OFFS, + CONFIG_SYS_NAND_U_BOOT_SIZE, + (void *)CONFIG_SYS_NAND_U_BOOT_DST); + +#ifdef CONFIG_NAND_ENV_DST + ret = nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, + (void *)CONFIG_NAND_ENV_DST); + +#ifdef CONFIG_ENV_OFFSET_REDUND + ret = nand_spl_load_image(CONFIG_ENV_OFFSET_REDUND, CONFIG_ENV_SIZE, + (void *)CONFIG_NAND_ENV_DST + CONFIG_ENV_SIZE); +#endif +#endif + + /* + * Jump to U-Boot image + */ + uboot = (void *)CONFIG_SYS_NAND_U_BOOT_START; + (*uboot)(); +}
- puts("### ERROR ### Please RESET the board ###\n");
- for (;;)
Why is this inline?
- .word CONFIG_SPL_TEXT_BASE
+#else
- .word CONFIG_SYS_TEXT_BASE
+#endif +#endif
- These are defined in the board-specific linker script.
- ldr sp, =(CONFIG_SYS_INIT_SP_ADDR)
- ldr sp, =(CONFIG_SPL_STACK)
Why does CONFIG_NAND_SPL need its own ifdef, if it's going to produce the same code as any other !CONFIG_SPL_BUILD build?
If your concerned with making it obvious what happens with the legacy NAND SPL, Just have a comment after #ifdef CONFIG_SPL_BUILD that says: /* not set with legacy CONFIG_NAND_SPL */
Space, not tab, to match the rest of the file.
- The main entry for NAND booting. It's necessary that SDRAM is already
- configured and available since this code loads the main U-Boot image
- from NAND into SDRAM and starts it from there.
- int ret;
- __attribute__((noreturn)) void (*uboot)(void);
- ret = nand_spl_load_image(CONFIG_SYS_NAND_U_BOOT_OFFS,
The indent/alignment of continuation lines here looks odd...
-Scott
Signed-off-by: Heiko Schocher hs@denx.de Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Sandeep Paulraj s-paulraj@ti.com Cc: Scott Wood scottwood@freescale.com Cc: Tom Rini trini@ti.com
changes for v7: - add comments from Scott Wood: - removed unnecessary inline - add only a comment after #ifdef CONFIG_SPL_BUILD that says: /* not set with legacy CONFIG_NAND_SPL */ - replaced tab with space in drivers/mtd/nand/Makefile - changed indent/alignment in drivers/mtd/nand/nand_spl_load.c
Makefile | 8 +++- arch/arm/cpu/arm926ejs/davinci/Makefile | 5 ++ arch/arm/cpu/arm926ejs/davinci/spl.c | 63 +++++++++++++++++++++++++++++++ arch/arm/cpu/arm926ejs/start.S | 19 +++++++++- doc/README.SPL | 1 + drivers/mtd/nand/Makefile | 3 + drivers/mtd/nand/nand_spl_load.c | 56 +++++++++++++++++++++++++++ 7 files changed, 152 insertions(+), 3 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/davinci/spl.c create mode 100644 drivers/mtd/nand/nand_spl_load.c
ifndef CONFIG_SKIP_LOWLEVEL_INIT diff --git a/arch/arm/cpu/arm926ejs/davinci/spl.c b/arch/arm/cpu/arm926ejs/davinci/spl.c new file mode 100644 index 0000000..db69be8 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/davinci/spl.c @@ -0,0 +1,63 @@ +/* + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <asm/u-boot.h> +#include <asm/utils.h> +#include <nand.h> +#include <asm/arch/dm365_lowlevel.h> +#include <ns16550.h> + +void puts(const char *str) +{ + while (*str) + putc(*str++); +} + +void putc(char c) +{ + if (c == '\n') + NS16550_putc((NS16550_t)(CONFIG_SYS_NS16550_COM1), '\r'); + + NS16550_putc((NS16550_t)(CONFIG_SYS_NS16550_COM1), c); +} + +void hang(void) +{ + puts("### ERROR ### Please RESET the board ###\n"); + for (;;) + ; +} + +void board_init_f(ulong dummy) +{ + dm36x_lowlevel_init(0); + relocate_code(CONFIG_SPL_STACK, NULL, CONFIG_SPL_TEXT_BASE); +} + +void board_init_r(gd_t *id, ulong dummy) +{ + + nand_init(); + puts("Nand boot...\n"); + nand_boot(); +} diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 86a0dc2..5ffc653 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -126,7 +126,12 @@ _fiq:
.globl _TEXT_BASE _TEXT_BASE: +#ifdef CONFIG_SPL_BUILD + /* not set with legacy CONFIG_NAND_SPL */ + .word CONFIG_SPL_TEXT_BASE +#else .word CONFIG_SYS_TEXT_BASE +#endif
/* * These are defined in the board-specific linker script. @@ -192,7 +197,12 @@ reset:
/* Set stackpointer in internal RAM to call board_init_f */ call_board_init_f: +#ifdef CONFIG_SPL_BUILD + /* not set with legacy CONFIG_NAND_SPL */ + ldr sp, =(CONFIG_SPL_STACK) +#else ldr sp, =(CONFIG_SYS_INIT_SP_ADDR) +#endif bic sp, sp, #7 /* 8-byte alignment for ABI compliance */ ldr r0,=0x00000000 bl board_init_f @@ -217,6 +227,7 @@ stack_setup: mov sp, r4
adr r0, _start + sub r9, r6, r0 /* r9 <- relocation offset */ cmp r0, r6 beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy loop */ @@ -271,12 +282,17 @@ fixnext: #endif
clbss_l:str r2, [r0] /* clear loop... */ @@ -284,6 +300,7 @@ clbss_l:str r2, [r0] /* clear loop... */ cmp r0, r1 bne clbss_l
+#ifndef CONFIG_SPL_BUILD bl coloured_LED_init bl red_led_on #endif diff --git a/doc/README.SPL b/doc/README.SPL index b460e84..89d24a7 100644 --- a/doc/README.SPL +++ b/doc/README.SPL @@ -64,3 +64,4 @@ CONFIG_SPL_POWER_SUPPORT (drivers/power/libpower.o) CONFIG_SPL_NAND_SUPPORT (drivers/mtd/nand/libnand.o) CONFIG_SPL_DMA_SUPPORT (drivers/dma/libdma.o) CONFIG_SPL_POST_MEM_SUPPORT (post/drivers/memory.o) +CONFIG_SPL_NAND_LOAD (drivers/mtd/nand/nand_spl_load.o) diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 1eeba5c..e80da62 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -30,6 +30,9 @@ ifdef CONFIG_SPL_BUILD ifdef CONFIG_SPL_NAND_SIMPLE COBJS-y += nand_spl_simple.o endif +ifdef CONFIG_SPL_NAND_LOAD +COBJS-y += nand_spl_load.o +endif else COBJS-y += nand.o COBJS-y += nand_bbt.o diff --git a/drivers/mtd/nand/nand_spl_load.c b/drivers/mtd/nand/nand_spl_load.c new file mode 100644 index 0000000..d7f6f10 --- /dev/null +++ b/drivers/mtd/nand/nand_spl_load.c @@ -0,0 +1,56 @@ +/* + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <nand.h> + +/* + * The main entry for NAND booting. It's necessary that SDRAM is already + * configured and available since this code loads the main U-Boot image + * from NAND into SDRAM and starts it from there. + */ +void nand_boot(void) +{ + int ret; + __attribute__((noreturn)) void (*uboot)(void); + + /* + * Load U-Boot image from NAND into RAM + */ + ret = nand_spl_load_image(CONFIG_SYS_NAND_U_BOOT_OFFS, + CONFIG_SYS_NAND_U_BOOT_SIZE, + (void *)CONFIG_SYS_NAND_U_BOOT_DST); + +#ifdef CONFIG_NAND_ENV_DST + ret = nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, + (void *)CONFIG_NAND_ENV_DST); + +#ifdef CONFIG_ENV_OFFSET_REDUND + ret = nand_spl_load_image(CONFIG_ENV_OFFSET_REDUND, CONFIG_ENV_SIZE, + (void *)CONFIG_NAND_ENV_DST + CONFIG_ENV_SIZE); +#endif +#endif + + /* + * Jump to U-Boot image + */ + uboot = (void *)CONFIG_SYS_NAND_U_BOOT_START; + (*uboot)(); +}
similiar to commit dc7cd8e59ba077f3b4c1a4557c9cd86a31b9ab1f, only adapted for the new spl framework.
Signed-off-by: Heiko Schocher hs@denx.de Acked-by: Tom Rini trini@ti.com Acked-by: Scott Wood scottwood@freescale.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Sandeep Paulraj s-paulraj@ti.com
--- changes for v2: - add comment from Scott Wood: as BSS is cleared, no need for intializing vars with 0 remove this.
changes for v3: - add comment from Scoot Wood and Tom Rini - rename CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST to CONFIG_SYS_NAND_HW_ECC_OOBFIRST - add dokumentation in README
changes for v4: - added Acked-by: Tom Rini trini@ti.com
changes for v5: - added Acked-by: Scott Wood scottwood@freescale.com
README | 5 ++++ drivers/mtd/nand/nand_spl_simple.c | 43 +++++++++++++++++++++++++++++++++++- 2 files changed, 47 insertions(+), 1 deletions(-)
diff --git a/README b/README index 62ef0a7..f4366e6 100644 --- a/README +++ b/README @@ -3261,6 +3261,11 @@ Low Level (hardware related) configuration options: that is executed before the actual U-Boot. E.g. when compiling a NAND SPL.
+- CONFIG_SYS_NAND_HW_ECC_OOBFIRST + define this, if you want to read first the oob data + and then the data. This is used for example on + davinci plattforms. + - CONFIG_USE_ARCH_MEMCPY CONFIG_USE_ARCH_MEMSET If these options are used a optimized version of memcpy/memset will diff --git a/drivers/mtd/nand/nand_spl_simple.c b/drivers/mtd/nand/nand_spl_simple.c index 71491d4..e5003e6 100644 --- a/drivers/mtd/nand/nand_spl_simple.c +++ b/drivers/mtd/nand/nand_spl_simple.c @@ -140,6 +140,47 @@ static int nand_is_bad_block(int block) return 0; }
+#if defined(CONFIG_SYS_NAND_HW_ECC_OOBFIRST) +static int nand_read_page(int block, int page, uchar *dst) +{ + struct nand_chip *this = mtd.priv; + u_char *ecc_calc; + u_char *ecc_code; + u_char *oob_data; + int i; + int eccsize = CONFIG_SYS_NAND_ECCSIZE; + int eccbytes = CONFIG_SYS_NAND_ECCBYTES; + int eccsteps = CONFIG_SYS_NAND_ECCSTEPS; + uint8_t *p = dst; + int stat; + + /* + * No malloc available for now, just use some temporary locations + * in SDRAM + */ + ecc_calc = (u_char *)(CONFIG_SYS_SDRAM_BASE + 0x10000); + ecc_code = ecc_calc + 0x100; + oob_data = ecc_calc + 0x200; + + nand_command(block, page, 0, NAND_CMD_READOOB); + this->read_buf(&mtd, oob_data, CONFIG_SYS_NAND_OOBSIZE); + nand_command(block, page, 0, NAND_CMD_READ0); + + /* Pick the ECC bytes out of the oob data */ + for (i = 0; i < CONFIG_SYS_NAND_ECCTOTAL; i++) + ecc_code[i] = oob_data[nand_ecc_pos[i]]; + + + for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize) { + this->ecc.hwctl(&mtd, NAND_ECC_READ); + this->read_buf(&mtd, p, eccsize); + this->ecc.calculate(&mtd, p, &ecc_calc[i]); + stat = this->ecc.correct(&mtd, p, &ecc_code[i], &ecc_calc[i]); + } + + return 0; +} +#else static int nand_read_page(int block, int page, void *dst) { struct nand_chip *this = mtd.priv; @@ -186,6 +227,7 @@ static int nand_read_page(int block, int page, void *dst)
return 0; } +#endif
int nand_spl_load_image(uint32_t offs, unsigned int size, void *dst) { @@ -230,7 +272,6 @@ void nand_init(void) mtd.priv = &nand_chip; nand_chip.IO_ADDR_R = nand_chip.IO_ADDR_W = (void __iomem *)CONFIG_SYS_NAND_BASE; - nand_chip.options = 0; board_nand_init(&nand_chip);
if (nand_chip.select_chip)
Signed-off-by: Heiko Schocher hs@denx.de Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Sandeep Paulraj s-paulraj@ti.com Cc: Christian Riesch christian.riesch@omicron.at
--- changes for v2: - rebase to TOT - add defines for timer 3 and 4 - delete "struct dv_timer_regs" as it is now "davinci_timer"
changes for v5: - add comment from Christian Riesch: use lpsc_on() and lpsc_syncreset(), remove dm365_lpc_transition() patches http://patchwork.ozlabs.org/patch/114942/ http://patchwork.ozlabs.org/patch/119375/ needed for this.
arch/arm/include/asm/arch-davinci/aintc_defs.h | 50 +++++++++++++ arch/arm/include/asm/arch-davinci/hardware.h | 13 ++++ arch/arm/include/asm/arch-davinci/pll_defs.h | 79 +++++++++++++++++++++ arch/arm/include/asm/arch-davinci/psc_defs.h | 86 +++++++++++++++++++++++ arch/arm/include/asm/arch-davinci/syscfg_defs.h | 66 +++++++++++++++++ 5 files changed, 294 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-davinci/aintc_defs.h create mode 100644 arch/arm/include/asm/arch-davinci/pll_defs.h create mode 100644 arch/arm/include/asm/arch-davinci/psc_defs.h create mode 100644 arch/arm/include/asm/arch-davinci/syscfg_defs.h
diff --git a/arch/arm/include/asm/arch-davinci/aintc_defs.h b/arch/arm/include/asm/arch-davinci/aintc_defs.h new file mode 100644 index 0000000..8f37053 --- /dev/null +++ b/arch/arm/include/asm/arch-davinci/aintc_defs.h @@ -0,0 +1,50 @@ +/* + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _DV_AINTC_DEFS_H_ +#define _DV_AINTC_DEFS_H_ + +struct dv_aintc_regs { + unsigned int fiq0; /* 0x00 */ + unsigned int fiq1; /* 0x04 */ + unsigned int irq0; /* 0x08 */ + unsigned int irq1; /* 0x0c */ + unsigned int fiqentry; /* 0x10 */ + unsigned int irqentry; /* 0x14 */ + unsigned int eint0; /* 0x18 */ + unsigned int eint1; /* 0x1c */ + unsigned int intctl; /* 0x20 */ + unsigned int eabase; /* 0x24 */ + unsigned char rsvd0[8]; /* 0x28 */ + unsigned int intpri0; /* 0x30 */ + unsigned int intpri1; /* 0x34 */ + unsigned int intpri2; /* 0x38 */ + unsigned int intpri3; /* 0x3c */ + unsigned int intpri4; /* 0x40 */ + unsigned int intpri5; /* 0x44 */ + unsigned int intpri6; /* 0x48 */ + unsigned int intpri7; /* 0x4c */ +}; + +#define dv_aintc_regs ((struct dv_aintc_regs *)DAVINCI_ARM_INTC_BASE) + +#endif /* _DV_AINTC_DEFS_H_ */ diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index 9699892..77c4d62 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -56,6 +56,7 @@ typedef volatile unsigned int * dv_reg_p; #define DAVINCI_DMA_3PTC1_BASE (0x01c10400) #define DAVINCI_UART0_BASE (0x01c20000) #define DAVINCI_UART1_BASE (0x01c20400) +#define DAVINCI_TIMER3_BASE (0x01c20800) #define DAVINCI_I2C_BASE (0x01c21000) #define DAVINCI_TIMER0_BASE (0x01c21400) #define DAVINCI_TIMER1_BASE (0x01c21800) @@ -63,6 +64,7 @@ typedef volatile unsigned int * dv_reg_p; #define DAVINCI_PWM0_BASE (0x01c22000) #define DAVINCI_PWM1_BASE (0x01c22400) #define DAVINCI_PWM2_BASE (0x01c22800) +#define DAVINCI_TIMER4_BASE (0x01c23800) #define DAVINCI_SYSTEM_MODULE_BASE (0x01c40000) #define DAVINCI_PLL_CNTRL0_BASE (0x01c40800) #define DAVINCI_PLL_CNTRL1_BASE (0x01c40c00) @@ -108,6 +110,7 @@ typedef volatile unsigned int * dv_reg_p; #define DAVINCI_MMC_SD1_BASE 0x01d00000 #define DAVINCI_ASYNC_EMIF_CNTRL_BASE 0x01d10000 #define DAVINCI_MMC_SD0_BASE 0x01d11000 +#define DAVINCI_DDR_EMIF_CTRL_BASE 0x20000000
#elif defined(CONFIG_SOC_DM646X) #define DAVINCI_ASYNC_EMIF_CNTRL_BASE 0x20008000 @@ -543,4 +546,14 @@ static inline int get_async3_src(void)
#endif /* CONFIG_SOC_DA8XX */
+#if defined(CONFIG_SOC_DM365) +#include <asm/arch/aintc_defs.h> +#include <asm/arch/ddr2_defs.h> +#include <asm/arch/emif_defs.h> +#include <asm/arch/gpio.h> +#include <asm/arch/pll_defs.h> +#include <asm/arch/psc_defs.h> +#include <asm/arch/syscfg_defs.h> +#include <asm/arch/timer_defs.h> +#endif #endif /* __ASM_ARCH_HARDWARE_H */ diff --git a/arch/arm/include/asm/arch-davinci/pll_defs.h b/arch/arm/include/asm/arch-davinci/pll_defs.h new file mode 100644 index 0000000..5d37616 --- /dev/null +++ b/arch/arm/include/asm/arch-davinci/pll_defs.h @@ -0,0 +1,79 @@ +/* + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _DV_PLL_DEFS_H_ +#define _DV_PLL_DEFS_H_ + +struct dv_pll_regs { + unsigned int pid; /* 0x00 */ + unsigned char rsvd0[224]; /* 0x04 */ + unsigned int rstype; /* 0xe4 */ + unsigned char rsvd1[24]; /* 0xe8 */ + unsigned int pllctl; /* 0x100 */ + unsigned char rsvd2[4]; /* 0x104 */ + unsigned int secctl; /* 0x108 */ + unsigned int rv; /* 0x10c */ + unsigned int pllm; /* 0x110 */ + unsigned int prediv; /* 0x114 */ + unsigned int plldiv1; /* 0x118 */ + unsigned int plldiv2; /* 0x11c */ + unsigned int plldiv3; /* 0x120 */ + unsigned int oscdiv1; /* 0x124 */ + unsigned int postdiv; /* 0x128 */ + unsigned int bpdiv; /* 0x12c */ + unsigned char rsvd5[8]; /* 0x130 */ + unsigned int pllcmd; /* 0x138 */ + unsigned int pllstat; /* 0x13c */ + unsigned int alnctl; /* 0x140 */ + unsigned int dchange; /* 0x144 */ + unsigned int cken; /* 0x148 */ + unsigned int ckstat; /* 0x14c */ + unsigned int systat; /* 0x150 */ + unsigned char rsvd6[12]; /* 0x154 */ + unsigned int plldiv4; /* 0x160 */ + unsigned int plldiv5; /* 0x164 */ + unsigned int plldiv6; /* 0x168 */ + unsigned int plldiv7; /* 0x16C */ + unsigned int plldiv8; /* 0x170 */ + unsigned int plldiv9; /* 0x174 */ +}; + +#define PLLCTL_PLLEN (1 << 0) +#define PLLCTL_PLLPWRDN (1 << 1) +#define PLLCTL_PLLRST (1 << 3) +#define PLLCTL_PLLENSRC (1 << 5) +#define PLLCTL_RES_9 (1 << 8) + +#define PLLSECCTL_TINITZ (1 << 16) +#define PLLSECCTL_TENABLE (1 << 17) +#define PLLSECCTL_TENABLEDIV (1 << 18) +#define PLLSECCTL_STOPMODE (1 << 22) + +#define PLLCMD_GOSET (1 << 0) + +#define PLL0_LOCK 0x07000000 +#define PLL1_LOCK 0x07000000 + +#define dv_pll0_regs ((struct dv_pll_regs *)DAVINCI_PLL_CNTRL0_BASE) +#define dv_pll1_regs ((struct dv_pll_regs *)DAVINCI_PLL_CNTRL1_BASE) + +#endif /* _DV_PLL_DEFS_H_ */ diff --git a/arch/arm/include/asm/arch-davinci/psc_defs.h b/arch/arm/include/asm/arch-davinci/psc_defs.h new file mode 100644 index 0000000..084b015 --- /dev/null +++ b/arch/arm/include/asm/arch-davinci/psc_defs.h @@ -0,0 +1,86 @@ +/* + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _DV_PSC_DEFS_H_ +#define _DV_PSC_DEFS_H_ + +/* + * Power/Sleep Ctrl Register structure + * See sprufb3.pdf, Chapter 7 + */ +struct dv_psc_regs { + unsigned int pid; /* 0x000 */ + unsigned char rsvd0[16]; /* 0x004 */ + unsigned char rsvd1[4]; /* 0x014 */ + unsigned int inteval; /* 0x018 */ + unsigned char rsvd2[36]; /* 0x01C */ + unsigned int merrpr0; /* 0x040 */ + unsigned int merrpr1; /* 0x044 */ + unsigned char rsvd3[8]; /* 0x048 */ + unsigned int merrcr0; /* 0x050 */ + unsigned int merrcr1; /* 0x054 */ + unsigned char rsvd4[8]; /* 0x058 */ + unsigned int perrpr; /* 0x060 */ + unsigned char rsvd5[4]; /* 0x064 */ + unsigned int perrcr; /* 0x068 */ + unsigned char rsvd6[4]; /* 0x06C */ + unsigned int epcpr; /* 0x070 */ + unsigned char rsvd7[4]; /* 0x074 */ + unsigned int epccr; /* 0x078 */ + unsigned char rsvd8[144]; /* 0x07C */ + unsigned char rsvd9[20]; /* 0x10C */ + unsigned int ptcmd; /* 0x120 */ + unsigned char rsvd10[4]; /* 0x124 */ + unsigned int ptstat; /* 0x128 */ + unsigned char rsvd11[212]; /* 0x12C */ + unsigned int pdstat0; /* 0x200 */ + unsigned int pdstat1; /* 0x204 */ + unsigned char rsvd12[248]; /* 0x208 */ + unsigned int pdctl0; /* 0x300 */ + unsigned int pdctl1; /* 0x304 */ + unsigned char rsvd13[536]; /* 0x308 */ + unsigned int mckout0; /* 0x520 */ + unsigned int mckout1; /* 0x524 */ + unsigned char rsvd14[728]; /* 0x528 */ + unsigned int mdstat[52]; /* 0x800 */ + unsigned char rsvd15[304]; /* 0x8D0 */ + unsigned int mdctl[52]; /* 0xA00 */ +}; + +/* PSC constants */ +#define EMURSTIE_MASK (0x00000200) + +#define PD0 (0) + +#define PSC_ENABLE (0x3) +#define PSC_DISABLE (0x2) +#define PSC_SYNCRESET (0x1) +#define PSC_SWRSTDISABLE (0x0) + +#define PSC_GOSTAT (1 << 0) +#define PSC_MD_STATE_MSK (0x1f) + +#define PSC_CMD_GO (1 << 0) + +#define dv_psc_regs ((struct dv_psc_regs *)DAVINCI_PWR_SLEEP_CNTRL_BASE) + +#endif /* _DV_PSC_DEFS_H_ */ diff --git a/arch/arm/include/asm/arch-davinci/syscfg_defs.h b/arch/arm/include/asm/arch-davinci/syscfg_defs.h new file mode 100644 index 0000000..05af020 --- /dev/null +++ b/arch/arm/include/asm/arch-davinci/syscfg_defs.h @@ -0,0 +1,66 @@ +/* + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _DV_SYSCFG_DEFS_H_ +#define _DV_SYSCFG_DEFS_H_ + +#ifndef CONFIG_SOC_DA8XX +/* System Control Module register structure for DM365 */ +struct dv_sys_module_regs { + unsigned int pinmux[5]; /* 0x00 */ + unsigned int bootcfg; /* 0x14 */ + unsigned int arm_intmux; /* 0x18 */ + unsigned int edma_evtmux; /* 0x1C */ + unsigned int ddr_slew; /* 0x20 */ + unsigned int clkout; /* 0x24 */ + unsigned int device_id; /* 0x28 */ + unsigned int vdac_config; /* 0x2C */ + unsigned int timer64_ctl; /* 0x30 */ + unsigned int usbbphy_ctl; /* 0x34 */ + unsigned int misc; /* 0x38 */ + unsigned int mstpri[2]; /* 0x3C */ + unsigned int vpss_clkctl; /* 0x44 */ + unsigned int peri_clkctl; /* 0x48 */ + unsigned int deepsleep; /* 0x4C */ + unsigned int dft_enable; /* 0x50 */ + unsigned int debounce[8]; /* 0x54 */ + unsigned int vtpiocr; /* 0x74 */ + unsigned int pupdctl0; /* 0x78 */ + unsigned int pupdctl1; /* 0x7C */ + unsigned int hdimcopbt; /* 0x80 */ + unsigned int pll0_config; /* 0x84 */ + unsigned int pll1_config; /* 0x88 */ +}; + +#define VPTIO_RDY (1 << 15) +#define VPTIO_IOPWRDN (1 << 14) +#define VPTIO_CLRZ (1 << 13) +#define VPTIO_LOCK (1 << 7) +#define VPTIO_PWRDN (1 << 6) + +#define VPSS_CLK_CTL_VPSS_CLKMD (1 << 7) + +#define dv_sys_module_regs \ + ((struct dv_sys_module_regs *)DAVINCI_SYSTEM_MODULE_BASE) + +#endif /* !CONFIG_SOC_DA8XX */ +#endif /* _DV_SYSCFG_DEFS_H_ */
used for booting (for example) from NAND using spl code.
--- changes for v2: - fix bug for dm365 if setup A2CR register - rebase to TOT: - rename DM36x_DDR_* to DV_DDR_* - add support for new SPL framework
arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c | 439 ++++++++++++++++++++ arch/arm/include/asm/arch-davinci/dm365_lowlevel.h | 41 ++ 2 files changed, 480 insertions(+), 0 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c create mode 100644 arch/arm/include/asm/arch-davinci/dm365_lowlevel.h
diff --git a/arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c b/arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c new file mode 100644 index 0000000..3772e64 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c @@ -0,0 +1,439 @@ +/* + * SoC-specific lowlevel code for tms320dm365 and similar chips + * Actually used for booting from NAND with nand_spl. + * + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#include <common.h> +#include <nand.h> +#include <ns16550.h> +#include <post.h> +#include <asm/arch/dm365_lowlevel.h> +#include <asm/arch/hardware.h> + +void dm365_waitloop(unsigned long loopcnt) +{ + unsigned long i; + + for (i = 0; i < loopcnt; i++) + asm(" NOP"); +} + +int dm365_pll1_init(unsigned long pllmult, unsigned long prediv) +{ + unsigned int clksrc = 0x0; + + /* Power up the PLL */ + clrbits_le32(&dv_pll0_regs->pllctl, PLLCTL_PLLPWRDN); + + clrbits_le32(&dv_pll0_regs->pllctl, PLLCTL_RES_9); + setbits_le32(&dv_pll0_regs->pllctl, clksrc << 8); + + /* + * Set PLLENSRC '0', PLL Enable(PLLEN) selection is controlled + * through MMR + */ + clrbits_le32(&dv_pll0_regs->pllctl, PLLCTL_PLLENSRC); + + /* Set PLLEN=0 => PLL BYPASS MODE */ + clrbits_le32(&dv_pll0_regs->pllctl, PLLCTL_PLLEN); + + dm365_waitloop(150); + + /* PLLRST=1(reset assert) */ + setbits_le32(&dv_pll0_regs->pllctl, PLLCTL_PLLRST); + + dm365_waitloop(300); + + /*Bring PLL out of Reset*/ + clrbits_le32(&dv_pll0_regs->pllctl, PLLCTL_PLLRST); + + /* Program the Multiper and Pre-Divider for PLL1 */ + writel(pllmult, &dv_pll0_regs->pllm); + writel(prediv, &dv_pll0_regs->prediv); + + /* Assert TENABLE = 1, TENABLEDIV = 1, TINITZ = 1 */ + writel(PLLSECCTL_STOPMODE | PLLSECCTL_TENABLEDIV | PLLSECCTL_TENABLE | + PLLSECCTL_TINITZ, &dv_pll0_regs->secctl); + /* Assert TENABLE = 1, TENABLEDIV = 1, TINITZ = 0 */ + writel(PLLSECCTL_STOPMODE | PLLSECCTL_TENABLEDIV | PLLSECCTL_TENABLE, + &dv_pll0_regs->secctl); + /* Assert TENABLE = 0, TENABLEDIV = 0, TINITZ = 0 */ + writel(PLLSECCTL_STOPMODE, &dv_pll0_regs->secctl); + /* Assert TENABLE = 0, TENABLEDIV = 0, TINITZ = 1 */ + writel(PLLSECCTL_STOPMODE | PLLSECCTL_TINITZ, &dv_pll0_regs->secctl); + + /* Program the PostDiv for PLL1 */ + writel(0x8000, &dv_pll0_regs->postdiv); + + /* Post divider setting for PLL1 */ + writel(CONFIG_SYS_DM36x_PLL1_PLLDIV1, &dv_pll0_regs->plldiv1); + writel(CONFIG_SYS_DM36x_PLL1_PLLDIV2, &dv_pll0_regs->plldiv2); + writel(CONFIG_SYS_DM36x_PLL1_PLLDIV3, &dv_pll0_regs->plldiv3); + writel(CONFIG_SYS_DM36x_PLL1_PLLDIV4, &dv_pll0_regs->plldiv4); + writel(CONFIG_SYS_DM36x_PLL1_PLLDIV5, &dv_pll0_regs->plldiv5); + writel(CONFIG_SYS_DM36x_PLL1_PLLDIV6, &dv_pll0_regs->plldiv6); + writel(CONFIG_SYS_DM36x_PLL1_PLLDIV7, &dv_pll0_regs->plldiv7); + writel(CONFIG_SYS_DM36x_PLL1_PLLDIV8, &dv_pll0_regs->plldiv8); + writel(CONFIG_SYS_DM36x_PLL1_PLLDIV9, &dv_pll0_regs->plldiv9); + + dm365_waitloop(300); + + /* Set the GOSET bit */ + writel(PLLCMD_GOSET, &dv_pll0_regs->pllcmd); /* Go */ + + dm365_waitloop(300); + + /* Wait for PLL to LOCK */ + while (!((readl(&dv_sys_module_regs->pll0_config) & PLL0_LOCK) + == PLL0_LOCK)) + ; + + /* Enable the PLL Bit of PLLCTL*/ + setbits_le32(&dv_pll0_regs->pllctl, PLLCTL_PLLEN); + + return 0; +} + +int dm365_pll2_init(unsigned long pllm, unsigned long prediv) +{ + unsigned int clksrc = 0x0; + + /* Power up the PLL*/ + clrbits_le32(&dv_pll1_regs->pllctl, PLLCTL_PLLPWRDN); + + /* + * Select the Clock Mode as Onchip Oscilator or External Clock on + * MXI pin + * VDB has input on MXI pin + */ + clrbits_le32(&dv_pll1_regs->pllctl, PLLCTL_RES_9); + setbits_le32(&dv_pll1_regs->pllctl, clksrc << 8); + + /* + * Set PLLENSRC '0', PLL Enable(PLLEN) selection is controlled + * through MMR + */ + clrbits_le32(&dv_pll1_regs->pllctl, PLLCTL_PLLENSRC); + + /* Set PLLEN=0 => PLL BYPASS MODE */ + clrbits_le32(&dv_pll1_regs->pllctl, PLLCTL_PLLEN); + + dm365_waitloop(50); + + /* PLLRST=1(reset assert) */ + setbits_le32(&dv_pll1_regs->pllctl, PLLCTL_PLLRST); + + dm365_waitloop(300); + + /* Bring PLL out of Reset */ + clrbits_le32(&dv_pll1_regs->pllctl, PLLCTL_PLLRST); + + /* Program the Multiper and Pre-Divider for PLL2 */ + writel(pllm, &dv_pll1_regs->pllm); + writel(prediv, &dv_pll1_regs->prediv); + + writel(0x8000, &dv_pll1_regs->postdiv); + + /* Assert TENABLE = 1, TENABLEDIV = 1, TINITZ = 1 */ + writel(PLLSECCTL_STOPMODE | PLLSECCTL_TENABLEDIV | PLLSECCTL_TENABLE | + PLLSECCTL_TINITZ, &dv_pll1_regs->secctl); + /* Assert TENABLE = 1, TENABLEDIV = 1, TINITZ = 0 */ + writel(PLLSECCTL_STOPMODE | PLLSECCTL_TENABLEDIV | PLLSECCTL_TENABLE, + &dv_pll1_regs->secctl); + /* Assert TENABLE = 0, TENABLEDIV = 0, TINITZ = 0 */ + writel(PLLSECCTL_STOPMODE, &dv_pll1_regs->secctl); + /* Assert TENABLE = 0, TENABLEDIV = 0, TINITZ = 1 */ + writel(PLLSECCTL_STOPMODE | PLLSECCTL_TINITZ, &dv_pll1_regs->secctl); + + /* Post divider setting for PLL2 */ + writel(CONFIG_SYS_DM36x_PLL2_PLLDIV1, &dv_pll1_regs->plldiv1); + writel(CONFIG_SYS_DM36x_PLL2_PLLDIV2, &dv_pll1_regs->plldiv2); + writel(CONFIG_SYS_DM36x_PLL2_PLLDIV3, &dv_pll1_regs->plldiv3); + writel(CONFIG_SYS_DM36x_PLL2_PLLDIV4, &dv_pll1_regs->plldiv4); + writel(CONFIG_SYS_DM36x_PLL2_PLLDIV5, &dv_pll1_regs->plldiv5); + + /* GoCmd for PostDivider to take effect */ + writel(PLLCMD_GOSET, &dv_pll1_regs->pllcmd); + + dm365_waitloop(150); + + /* Wait for PLL to LOCK */ + while (!((readl(&dv_sys_module_regs->pll1_config) & PLL1_LOCK) + == PLL1_LOCK)) + ; + + dm365_waitloop(4100); + + /* Enable the PLL2 */ + setbits_le32(&dv_pll1_regs->pllctl, PLLCTL_PLLEN); + + /* do this after PLL's have been set up */ + writel(CONFIG_SYS_DM36x_PERI_CLK_CTRL, + &dv_sys_module_regs->peri_clkctl); + + return 0; +} + +int dm365_ddr_setup(void) +{ + lpsc_on(DAVINCI_LPSC_DDR_EMIF); + clrbits_le32(&dv_sys_module_regs->vtpiocr, + VPTIO_IOPWRDN | VPTIO_CLRZ | VPTIO_LOCK | VPTIO_PWRDN); + + /* Set bit CLRZ (bit 13) */ + setbits_le32(&dv_sys_module_regs->vtpiocr, VPTIO_CLRZ); + + /* Check VTP READY Status */ + while (!(readl(&dv_sys_module_regs->vtpiocr) & VPTIO_RDY)) + ; + + /* Set bit VTP_IOPWRDWN bit 14 for DDR input buffers) */ + setbits_le32(&dv_sys_module_regs->vtpiocr, VPTIO_IOPWRDN); + + /* Set bit LOCK(bit7) */ + setbits_le32(&dv_sys_module_regs->vtpiocr, VPTIO_LOCK); + + /* + * Powerdown VTP as it is locked (bit 6) + * Set bit VTP_IOPWRDWN bit 14 for DDR input buffers) + */ + setbits_le32(&dv_sys_module_regs->vtpiocr, + VPTIO_IOPWRDN | VPTIO_PWRDN); + + /* Wait for calibration to complete */ + dm365_waitloop(150); + + /* Set the DDR2 to synreset, then enable it again */ + lpsc_syncreset(DAVINCI_LPSC_DDR_EMIF); + lpsc_on(DAVINCI_LPSC_DDR_EMIF); + + writel(CONFIG_SYS_DM36x_DDR2_DDRPHYCR, &dv_ddr2_regs_ctrl->ddrphycr); + + /* Program SDRAM Bank Config Register */ + writel((CONFIG_SYS_DM36x_DDR2_SDBCR | DV_DDR_BOOTUNLOCK), + &dv_ddr2_regs_ctrl->sdbcr); + writel((CONFIG_SYS_DM36x_DDR2_SDBCR | DV_DDR_TIMUNLOCK), + &dv_ddr2_regs_ctrl->sdbcr); + + /* Program SDRAM Timing Control Register1 */ + writel(CONFIG_SYS_DM36x_DDR2_SDTIMR, &dv_ddr2_regs_ctrl->sdtimr); + /* Program SDRAM Timing Control Register2 */ + writel(CONFIG_SYS_DM36x_DDR2_SDTIMR2, &dv_ddr2_regs_ctrl->sdtimr2); + + writel(CONFIG_SYS_DM36x_DDR2_PBBPR, &dv_ddr2_regs_ctrl->pbbpr); + + writel(CONFIG_SYS_DM36x_DDR2_SDBCR, &dv_ddr2_regs_ctrl->sdbcr); + + /* Program SDRAM Refresh Control Register */ + writel(CONFIG_SYS_DM36x_DDR2_SDRCR, &dv_ddr2_regs_ctrl->sdrcr); + + lpsc_syncreset(DAVINCI_LPSC_DDR_EMIF); + lpsc_on(DAVINCI_LPSC_DDR_EMIF); + + return 0; +} + +void dm365_vpss_sync_reset(void) +{ + unsigned int PdNum = 0; + + /* VPSS_CLKMD 1:1 */ + setbits_le32(&dv_sys_module_regs->vpss_clkctl, + VPSS_CLK_CTL_VPSS_CLKMD); + + /* LPSC SyncReset DDR Clock Enable */ + writel(((readl(&dv_psc_regs->mdctl[47]) & ~PSC_MD_STATE_MSK) | + PSC_SYNCRESET), &dv_psc_regs->mdctl[47]); + + writel((1 << PdNum), &dv_psc_regs->ptcmd); + + while (!(((readl(&dv_psc_regs->ptstat) >> PdNum) & PSC_GOSTAT) == 0)) + ; + while (!((readl(&dv_psc_regs->mdstat[47]) & PSC_MD_STATE_MSK) == + PSC_SYNCRESET)) + ; +} + +void dm365_por_reset(void) +{ + if (readl(&dv_pll0_regs->rstype) & 3) + dm365_vpss_sync_reset(); +} + +void dm365_psc_init(void) +{ + unsigned char i = 0; + unsigned char lpsc_start; + unsigned char lpsc_end, lpscgroup, lpscmin, lpscmax; + unsigned int PdNum = 0; + + lpscmin = 0; + lpscmax = 2; + + for (lpscgroup = lpscmin; lpscgroup <= lpscmax; lpscgroup++) { + if (lpscgroup == 0) { + lpsc_start = 0; /* Enabling LPSC 3 to 28 SCR first */ + lpsc_end = 28; + } else if (lpscgroup == 1) { /* Skip locked LPSCs [29-37] */ + lpsc_start = 38; + lpsc_end = 47; + } else { + lpsc_start = 50; + lpsc_end = 51; + } + + /* NEXT=0x3, Enable LPSC's */ + for (i = lpsc_start; i <= lpsc_end; i++) + setbits_le32(&dv_psc_regs->mdctl[i], 0x3); + + /* + * Program goctl to start transition sequence for LPSCs + * CSL_PSC_0_REGS->PTCMD = (1<<PdNum); Kick off Power + * Domain 0 Modules + */ + writel((1 << PdNum), &dv_psc_regs->ptcmd); + + /* + * Wait for GOSTAT = NO TRANSITION from PSC for Powerdomain 0 + */ + while (!(((readl(&dv_psc_regs->ptstat) >> PdNum) & PSC_GOSTAT) + == 0)) + ; + + /* Wait for MODSTAT = ENABLE from LPSC's */ + for (i = lpsc_start; i <= lpsc_end; i++) + while (!((readl(&dv_psc_regs->mdstat[i]) & + PSC_MD_STATE_MSK) == 0x3)) + ; + } +} + +static void dm365_emif_init(void) +{ + writel(CONFIG_SYS_DM36x_AWCCR, &davinci_emif_regs->awccr); + writel(CONFIG_SYS_DM36x_AB1CR, &davinci_emif_regs->ab1cr); + + setbits_le32(&davinci_emif_regs->nandfcr, 1); + + writel(CONFIG_SYS_DM36x_AB2CR, &davinci_emif_regs->ab2cr); + + return; +} + +void dm365_pinmux_ctl(unsigned long offset, unsigned long mask, + unsigned long value) +{ + clrbits_le32(&dv_sys_module_regs->pinmux[offset], mask); + setbits_le32(&dv_sys_module_regs->pinmux[offset], (mask & value)); +} + +__attribute__((weak)) +void board_gpio_init(void) +{ + return; +} + +#if defined(CONFIG_POST) +int post_log(char *format, ...) +{ + return 0; +} +#endif + +void dm36x_lowlevel_init(ulong bootflag) +{ + /* + * copied from arch/arm/cpu/arm926ejs/start.S + * + * flush v4 I/D caches + */ + asm("mov r0, #0"); + asm("mcr p15, 0, r0, c7, c7, 0"); /* flush v3/v4 cache */ + asm("mcr p15, 0, r0, c8, c7, 0"); /* flush v4 TLB */ + + /* + * disable MMU stuff and caches + */ + asm("mrc p15, 0, r0, c1, c0, 0"); + /* clear bits 13, 9:8 (--V- --RS) */ + asm("bic r0, r0, #0x00002300"); + /* clear bits 7, 2:0 (B--- -CAM) */ + asm("bic r0, r0, #0x00000087"); + /* set bit 2 (A) Align */ + asm("orr r0, r0, #0x00000002"); + /* set bit 12 (I) I-Cache */ + asm("orr r0, r0, #0x00001000"); + asm("mcr p15, 0, r0, c1, c0, 0"); + + /* Mask all interrupts */ + writel(0x04, &dv_aintc_regs->intctl); + writel(0x0, &dv_aintc_regs->eabase); + writel(0x0, &dv_aintc_regs->eint0); + writel(0x0, &dv_aintc_regs->eint1); + + /* Clear all interrupts */ + writel(0xffffffff, &dv_aintc_regs->fiq0); + writel(0xffffffff, &dv_aintc_regs->fiq1); + writel(0xffffffff, &dv_aintc_regs->irq0); + writel(0xffffffff, &dv_aintc_regs->irq1); + + /* System PSC setup - enable all */ + dm365_psc_init(); + + /* Setup Pinmux */ + dm365_pinmux_ctl(0, 0xFFFFFFFF, CONFIG_SYS_DM36x_PINMUX0); + dm365_pinmux_ctl(1, 0xFFFFFFFF, CONFIG_SYS_DM36x_PINMUX1); + dm365_pinmux_ctl(2, 0xFFFFFFFF, CONFIG_SYS_DM36x_PINMUX2); + dm365_pinmux_ctl(3, 0xFFFFFFFF, CONFIG_SYS_DM36x_PINMUX3); + dm365_pinmux_ctl(4, 0xFFFFFFFF, CONFIG_SYS_DM36x_PINMUX4); + + /* PLL setup */ + dm365_pll1_init(CONFIG_SYS_DM36x_PLL1_PLLM, + CONFIG_SYS_DM36x_PLL1_PREDIV); + dm365_pll2_init(CONFIG_SYS_DM36x_PLL2_PLLM, + CONFIG_SYS_DM36x_PLL2_PREDIV); + + /* GPIO setup */ + board_gpio_init(); + + NS16550_init((NS16550_t)(CONFIG_SYS_NS16550_COM1), + CONFIG_SYS_NS16550_CLK / 16 / CONFIG_BAUDRATE); + + /* + * Fix Power and Emulation Management Register + * see sprufh2.pdf page 38 Table 22 + */ + writel(0x0000e003, (CONFIG_SYS_NS16550_COM1 + 0x30)); + puts("ddr init\n"); + dm365_ddr_setup(); + + puts("emif init\n"); + dm365_emif_init(); + +#if defined(CONFIG_POST) + /* + * Do memory tests, calls arch_memory_failure_handle() + * if error detected. + */ + memory_post_test(0); +#endif +} diff --git a/arch/arm/include/asm/arch-davinci/dm365_lowlevel.h b/arch/arm/include/asm/arch-davinci/dm365_lowlevel.h new file mode 100644 index 0000000..4986e82 --- /dev/null +++ b/arch/arm/include/asm/arch-davinci/dm365_lowlevel.h @@ -0,0 +1,41 @@ +/* + * SoC-specific lowlevel code for tms320dm365 and similar chips + * + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ +#ifndef __DM365_LOWLEVEL_H +#define __DM365_LOWLEVEL_H + +#include <common.h> +#include <asm/arch/hardware.h> +#include <asm/io.h> + +void dm365_waitloop(unsigned long loopcnt); +int dm365_pll1_init(unsigned long pllmult, unsigned long prediv); +int dm365_pll2_init(unsigned long pllm, unsigned long prediv); +int dm365_ddr_setup(void); +void dm365_por_reset(void); +void dm365_psc_init(void); +void dm365_pinmux_ctl(unsigned long offset, unsigned long mask, + unsigned long value); +void dm36x_lowlevel_init(ulong bootflag); + +#endif /* #ifndef __DM365_LOWLEVEL_H */
--- Changes for v2: - rebase to TOT
arch/arm/cpu/arm926ejs/davinci/cpu.c | 27 ++++++++++++++++++++++++- arch/arm/include/asm/arch-davinci/pll_defs.h | 4 +++ 2 files changed, 29 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/davinci/cpu.c b/arch/arm/cpu/arm926ejs/davinci/cpu.c index 02819f6..9ea9785 100644 --- a/arch/arm/cpu/arm926ejs/davinci/cpu.c +++ b/arch/arm/cpu/arm926ejs/davinci/cpu.c @@ -146,13 +146,15 @@ static inline unsigned pll_prediv(volatile void *pllbase) return 8; else return pll_div(pllbase, PLLC_PREDIV); +#elif defined(CONFIG_SOC_DM365) + return pll_div(pllbase, PLLC_PREDIV); #endif return 1; }
static inline unsigned pll_postdiv(volatile void *pllbase) { -#ifdef CONFIG_SOC_DM355 +#if defined(CONFIG_SOC_DM355) || defined(CONFIG_SOC_DM365) return pll_div(pllbase, PLLC_POSTDIV); #elif defined(CONFIG_SOC_DM6446) if (pllbase == (volatile void *)DAVINCI_PLL_CNTRL0_BASE) @@ -171,9 +173,13 @@ static unsigned pll_sysclk_mhz(unsigned pll_addr, unsigned div) #endif
/* the PLL might be bypassed */ - if (REG(pllbase + PLLC_PLLCTL) & BIT(0)) { + if (readl(pllbase + PLLC_PLLCTL) & BIT(0)) { base /= pll_prediv(pllbase); +#if defined(CONFIG_SOC_DM365) + base *= 2 * (readl(pllbase + PLLC_PLLM) & 0x0ff); +#else base *= 1 + (REG(pllbase + PLLC_PLLM) & 0x0ff); +#endif base /= pll_postdiv(pllbase); } return DIV_ROUND_UP(base, 1000 * pll_div(pllbase, div)); @@ -184,8 +190,13 @@ int print_cpuinfo(void) /* REVISIT fetch and display CPU ID and revision information * too ... that will matter as more revisions appear. */ +#if defined(CONFIG_SOC_DM365) + printf("Cores: ARM %d MHz", + pll_sysclk_mhz(DAVINCI_PLL_CNTRL1_BASE, ARM_PLLDIV)); +#else printf("Cores: ARM %d MHz", pll_sysclk_mhz(DAVINCI_PLL_CNTRL0_BASE, ARM_PLLDIV)); +#endif
#ifdef DSP_PLLDIV printf(", DSP %d MHz", @@ -194,8 +205,13 @@ int print_cpuinfo(void)
printf("\nDDR: %d MHz\n", /* DDR PHY uses an x2 input clock */ +#if defined(CONFIG_SOC_DM365) + pll_sysclk_mhz(DAVINCI_PLL_CNTRL0_BASE, DDR_PLLDIV) + / 2); +#else pll_sysclk_mhz(DAVINCI_PLL_CNTRL1_BASE, DDR_PLLDIV) / 2); +#endif return 0; }
@@ -205,6 +221,13 @@ unsigned int davinci_arm_clk_get() return pll_sysclk_mhz(DAVINCI_PLL_CNTRL0_BASE, ARM_PLLDIV) * 1000000; } #endif + +#if defined(CONFIG_SOC_DM365) +unsigned int davinci_clk_get(unsigned int div) +{ + return pll_sysclk_mhz(DAVINCI_PLL_CNTRL0_BASE, div) * 1000000; +} +#endif #endif /* CONFIG_DISPLAY_CPUINFO */ #endif /* !CONFIG_SOC_DA8XX */
diff --git a/arch/arm/include/asm/arch-davinci/pll_defs.h b/arch/arm/include/asm/arch-davinci/pll_defs.h index 5d37616..606ed0b 100644 --- a/arch/arm/include/asm/arch-davinci/pll_defs.h +++ b/arch/arm/include/asm/arch-davinci/pll_defs.h @@ -76,4 +76,8 @@ struct dv_pll_regs { #define dv_pll0_regs ((struct dv_pll_regs *)DAVINCI_PLL_CNTRL0_BASE) #define dv_pll1_regs ((struct dv_pll_regs *)DAVINCI_PLL_CNTRL1_BASE)
+#define ARM_PLLDIV (offsetof(struct dv_pll_regs, plldiv2)) +#define DDR_PLLDIV (offsetof(struct dv_pll_regs, plldiv7)) + +unsigned int davinci_clk_get(unsigned int div); #endif /* _DV_PLL_DEFS_H_ */
Signed-off-by: Heiko Schocher hs@denx.de Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Sandeep Paulraj s-paulraj@ti.com --- arch/arm/include/asm/arch-davinci/hardware.h | 2 ++ arch/arm/include/asm/arch-davinci/pll_defs.h | 1 + 2 files changed, 3 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-davinci/hardware.h b/arch/arm/include/asm/arch-davinci/hardware.h index 77c4d62..707ff4d 100644 --- a/arch/arm/include/asm/arch-davinci/hardware.h +++ b/arch/arm/include/asm/arch-davinci/hardware.h @@ -111,6 +111,8 @@ typedef volatile unsigned int * dv_reg_p; #define DAVINCI_ASYNC_EMIF_CNTRL_BASE 0x01d10000 #define DAVINCI_MMC_SD0_BASE 0x01d11000 #define DAVINCI_DDR_EMIF_CTRL_BASE 0x20000000 +#define DAVINCI_SPI0_BASE 0x01c66000 +#define DAVINCI_SPI1_BASE 0x01c66800
#elif defined(CONFIG_SOC_DM646X) #define DAVINCI_ASYNC_EMIF_CNTRL_BASE 0x20008000 diff --git a/arch/arm/include/asm/arch-davinci/pll_defs.h b/arch/arm/include/asm/arch-davinci/pll_defs.h index 606ed0b..5c30953 100644 --- a/arch/arm/include/asm/arch-davinci/pll_defs.h +++ b/arch/arm/include/asm/arch-davinci/pll_defs.h @@ -78,6 +78,7 @@ struct dv_pll_regs {
#define ARM_PLLDIV (offsetof(struct dv_pll_regs, plldiv2)) #define DDR_PLLDIV (offsetof(struct dv_pll_regs, plldiv7)) +#define SPI_PLLDIV (offsetof(struct dv_pll_regs, plldiv4))
- DM368 SOC - booting with spl not with UBL from TI - before loading u-boot from NAND into RAM, test the RAM with the post memory test. If error is found, switch all LEDs on and halt system. - SPI Flash Dataflash Typ: M25PE80 - Ethernet DM9161BI - MMC - USB
Signed-off-by: Heiko Schocher hs@denx.de Cc: Sandeep Paulraj s-paulraj@ti.com Cc: Albert ARIBAUD albert.u.boot@aribaud.net Cc: Igor Grinberg grinberg@compulab.co.il
--- changes for v2: - rebase to TOT - adapted to new spl framework - add USB support - MDIO Clk only 1MHz - LED: set LED in spl code, and clear them after 1 second - add "bdinfo" command - add nandrbl board specific command for switching between rbl and uboot ecc calculation algorithm
changes for v3: - add CONFIG_SYS_NAND_HW_ECC_OOBFIRST
changes for v4: - add comments from Igor Grinberg - remove in board/ait/cam_enc_4xx/Makefile unnecessary targets clean, distcelan - use CONFIG_MACH_TYPE option - removed some unnecessary brackets - new patch: add a weak enable_vbus() in drivers/usb/musb/davinci.c - add a comment to an "#else" to make it clearer to which "#if" it belongs
- fix ALL to ALL-y in board config.mk, and add this only if CONFIG_SPL_BUILD is not set.
changes for v6: - add CONFIG_SPL_NAND_LOAD define
MAINTAINERS | 1 + board/ait/cam_enc_4xx/Makefile | 46 ++++ board/ait/cam_enc_4xx/cam_enc_4xx.c | 446 +++++++++++++++++++++++++++++++++ board/ait/cam_enc_4xx/config.mk | 15 ++ board/ait/cam_enc_4xx/u-boot-spl.lds | 73 ++++++ board/ait/cam_enc_4xx/ublimage.cfg | 48 ++++ boards.cfg | 1 + doc/README.davinci.nand_spl | 141 +++++++++++ include/configs/cam_enc_4xx.h | 453 ++++++++++++++++++++++++++++++++++ tools/ublimage.h | 2 +- 10 files changed, 1225 insertions(+), 1 deletions(-) create mode 100644 board/ait/cam_enc_4xx/Makefile create mode 100644 board/ait/cam_enc_4xx/cam_enc_4xx.c create mode 100644 board/ait/cam_enc_4xx/config.mk create mode 100644 board/ait/cam_enc_4xx/u-boot-spl.lds create mode 100644 board/ait/cam_enc_4xx/ublimage.cfg create mode 100644 doc/README.davinci.nand_spl create mode 100644 include/configs/cam_enc_4xx.h
diff --git a/MAINTAINERS b/MAINTAINERS index 576fea8..4dc72a0 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -421,6 +421,7 @@ Georg Schardt schardt@team-ctech.de
+ cam_enc_4xx davinci/ARM926EJS charon MPC5200 ids8247 MPC8247 jupiter MPC5200 diff --git a/board/ait/cam_enc_4xx/Makefile b/board/ait/cam_enc_4xx/Makefile new file mode 100644 index 0000000..2b22124 --- /dev/null +++ b/board/ait/cam_enc_4xx/Makefile @@ -0,0 +1,46 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := $(BOARD).o +SOBJS := + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS) $(SOBJS)) + +######################################################################### +# This is for $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/ait/cam_enc_4xx/cam_enc_4xx.c b/board/ait/cam_enc_4xx/cam_enc_4xx.c new file mode 100644 index 0000000..1351358 --- /dev/null +++ b/board/ait/cam_enc_4xx/cam_enc_4xx.c @@ -0,0 +1,446 @@ +/* + * Copyright (C) 2009 Texas Instruments Incorporated + * + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +#include <common.h> +#include <linux/mtd/nand.h> +#include <nand.h> +#include <miiphy.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/nand_defs.h> +#include <asm/arch/davinci_misc.h> +#ifdef CONFIG_DAVINCI_MMC +#include <mmc.h> +#include <asm/arch/sdmmc_defs.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +#ifndef CONFIG_SPL_BUILD +int dram_init(void) +{ + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size( + (void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_MAX_RAM_BANK_SIZE); + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = gd->ram_size; +} + +static struct davinci_timer *timer = + (struct davinci_timer *)DAVINCI_TIMER3_BASE; + +static unsigned long get_timer_val(void) +{ + unsigned long now = readl(&timer->tim34); + + return now; +} + +static void stop_timer(void) +{ + writel(0x0, &timer->tcr); + return; +} + +int checkboard(void) +{ + printf("Board: AIT CAM ENC 4XX\n"); + return 0; +} + +int board_init(void) +{ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + return 0; +} + +#ifdef CONFIG_DRIVER_TI_EMAC +int board_eth_init(bd_t *bis) +{ + davinci_emac_initialize(); + + return 0; +} +#endif + +#ifdef CONFIG_NAND_DAVINCI +static int +davinci_std_read_page_syndrome(struct mtd_info *mtd, struct nand_chip *chip, + uint8_t *buf, int page) +{ + struct nand_chip *this = mtd->priv; + int i, eccsize = chip->ecc.size; + int eccbytes = chip->ecc.bytes; + int eccsteps = chip->ecc.steps; + uint8_t *p = buf; + uint8_t *oob = chip->oob_poi; + + chip->cmdfunc(mtd, NAND_CMD_READOOB, 0x0, page & this->pagemask); + + chip->read_buf(mtd, oob, mtd->oobsize); + + chip->cmdfunc(mtd, NAND_CMD_READ0, 0x0, page & this->pagemask); + + + for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize) { + int stat; + + chip->ecc.hwctl(mtd, NAND_ECC_READ); + chip->read_buf(mtd, p, eccsize); + chip->ecc.hwctl(mtd, NAND_ECC_READSYN); + + if (chip->ecc.prepad) + oob += chip->ecc.prepad; + + stat = chip->ecc.correct(mtd, p, oob, NULL); + + if (stat == -1) + mtd->ecc_stats.failed++; + else + mtd->ecc_stats.corrected += stat; + + oob += eccbytes; + + if (chip->ecc.postpad) + oob += chip->ecc.postpad; + } + + /* Calculate remaining oob bytes */ + i = mtd->oobsize - (oob - chip->oob_poi); + if (i) + chip->read_buf(mtd, oob, i); + + return 0; +} + +static void davinci_std_write_page_syndrome(struct mtd_info *mtd, + struct nand_chip *chip, const uint8_t *buf) +{ + unsigned char davinci_ecc_buf[NAND_MAX_OOBSIZE]; + struct nand_chip *this = mtd->priv; + int i, eccsize = chip->ecc.size; + int eccbytes = chip->ecc.bytes; + int eccsteps = chip->ecc.steps; + int chunk = chip->ecc.bytes + chip->ecc.prepad + chip->ecc.postpad; + int offset = 0; + const uint8_t *p = buf; + uint8_t *oob = chip->oob_poi; + + for (i = 0; eccsteps; eccsteps--, i += eccbytes, p += eccsize) { + chip->ecc.hwctl(mtd, NAND_ECC_WRITE); + chip->write_buf(mtd, p, eccsize); + + /* Calculate ECC without prepad */ + chip->ecc.calculate(mtd, p, oob + chip->ecc.prepad); + + if (chip->ecc.prepad) { + offset = (chip->ecc.steps - eccsteps) * chunk; + memcpy(&davinci_ecc_buf[offset], oob, chip->ecc.prepad); + oob += chip->ecc.prepad; + } + + offset = ((chip->ecc.steps - eccsteps) * chunk) + + chip->ecc.prepad; + memcpy(&davinci_ecc_buf[offset], oob, eccbytes); + oob += eccbytes; + + if (chip->ecc.postpad) { + offset = ((chip->ecc.steps - eccsteps) * chunk) + + chip->ecc.prepad + eccbytes; + memcpy(&davinci_ecc_buf[offset], oob, + chip->ecc.postpad); + oob += chip->ecc.postpad; + } + } + + /* + * Write the sparebytes into the page once + * all eccsteps have been covered + */ + for (i = 0; i < mtd->oobsize; i++) + writeb(davinci_ecc_buf[i], this->IO_ADDR_W); + + /* Calculate remaining oob bytes */ + i = mtd->oobsize - (oob - chip->oob_poi); + if (i) + chip->write_buf(mtd, oob, i); +} + +static int davinci_std_write_oob_syndrome(struct mtd_info *mtd, + struct nand_chip *chip, int page) +{ + int pos, status = 0; + const uint8_t *bufpoi = chip->oob_poi; + + pos = mtd->writesize; + + chip->cmdfunc(mtd, NAND_CMD_SEQIN, pos, page); + + chip->write_buf(mtd, bufpoi, mtd->oobsize); + + chip->cmdfunc(mtd, NAND_CMD_PAGEPROG, -1, -1); + status = chip->waitfunc(mtd, chip); + + return status & NAND_STATUS_FAIL ? -1 : 0; +} + +static int davinci_std_read_oob_syndrome(struct mtd_info *mtd, + struct nand_chip *chip, int page, int sndcmd) +{ + struct nand_chip *this = mtd->priv; + uint8_t *buf = chip->oob_poi; + uint8_t *bufpoi = buf; + + chip->cmdfunc(mtd, NAND_CMD_READOOB, 0x0, page & this->pagemask); + + chip->read_buf(mtd, bufpoi, mtd->oobsize); + + return 1; +} + +static void nand_dm365evm_select_chip(struct mtd_info *mtd, int chip) +{ + struct nand_chip *this = mtd->priv; + unsigned long wbase = (unsigned long) this->IO_ADDR_W; + unsigned long rbase = (unsigned long) this->IO_ADDR_R; + + if (chip == 1) { + __set_bit(14, &wbase); + __set_bit(14, &rbase); + } else { + __clear_bit(14, &wbase); + __clear_bit(14, &rbase); + } + this->IO_ADDR_W = (void *)wbase; + this->IO_ADDR_R = (void *)rbase; +} + +int board_nand_init(struct nand_chip *nand) +{ + davinci_nand_init(nand); + nand->select_chip = nand_dm365evm_select_chip; + + return 0; +} + +struct nand_ecc_ctrl org_ecc; +static int notsaved = 1; + +static int nand_switch_hw_func(int mode) +{ + struct nand_chip *nand; + struct mtd_info *mtd; + + if (nand_curr_device < 0 || + nand_curr_device >= CONFIG_SYS_MAX_NAND_DEVICE || + !nand_info[nand_curr_device].name) { + printf("Error: Can't switch hw functions," \ + " no devices available\n"); + return -1; + } + + mtd = &nand_info[nand_curr_device]; + nand = mtd->priv; + + if (mode == 0) { + printf("switching to uboot hw functions.\n"); + memcpy(&nand->ecc, &org_ecc, sizeof(struct nand_ecc_ctrl)); + } else { + /* RBL */ + printf("switching to RBL hw functions.\n"); + if (notsaved == 1) { + memcpy(&org_ecc, &nand->ecc, + sizeof(struct nand_ecc_ctrl)); + notsaved = 0; + } + nand->ecc.mode = NAND_ECC_HW_SYNDROME; + nand->ecc.prepad = 6; + nand->ecc.read_page = davinci_std_read_page_syndrome; + nand->ecc.write_page = davinci_std_write_page_syndrome; + nand->ecc.read_oob = davinci_std_read_oob_syndrome; + nand->ecc.write_oob = davinci_std_write_oob_syndrome; + } + return mode; +} + +static int hwmode; + +static int do_switch_ecc(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + if (argc != 2) + goto usage; + if (strncmp(argv[1], "rbl", 2) == 0) + hwmode = nand_switch_hw_func(1); + else if (strncmp(argv[1], "uboot", 2) == 0) + hwmode = nand_switch_hw_func(0); + else + goto usage; + + return 0; + +usage: + printf("Usage: nandrbl %s\n", cmdtp->usage); + return 1; +} + +U_BOOT_CMD( + nandrbl, 2, 1, do_switch_ecc, + "switch between rbl/uboot NAND ECC calculation algorithm", + "[rbl/uboot] - Switch between rbl/uboot NAND ECC algorithm" +); + + +#endif /* #ifdef CONFIG_NAND_DAVINCI */ + +#ifdef CONFIG_DAVINCI_MMC +static struct davinci_mmc mmc_sd0 = { + .reg_base = (struct davinci_mmc_regs *)DAVINCI_MMC_SD0_BASE, + .input_clk = 121500000, + .host_caps = MMC_MODE_4BIT, + .voltages = MMC_VDD_32_33 | MMC_VDD_33_34, + .version = MMC_CTLR_VERSION_2, +}; + +int board_mmc_init(bd_t *bis) +{ + int err; + + /* Add slot-0 to mmc subsystem */ + err = davinci_mmc_init(bis, &mmc_sd0); + + return err; +} +#endif + +int board_late_init(void) +{ + struct davinci_gpio *gpio = davinci_gpio_bank45; + + /* 24MHz InputClock / 15 prediv -> 1.6 MHz timer running */ + while (get_timer_val() < 0x186a00) + ; + + /* 1 sec reached -> stop timer, clear all LED */ + stop_timer(); + clrbits_le32(&gpio->out_data, CONFIG_CAM_ENC_LED_MASK); + return 0; +} + +void reset_phy(void) +{ + char *name = "GENERIC @ 0x00"; + + /* reset the phy */ + miiphy_reset(name, 0x0); +} + +#else /* #ifndef CONFIG_SPL_BUILD */ +static void cam_enc_4xx_set_all_led(void) +{ + struct davinci_gpio *gpio = davinci_gpio_bank45; + + setbits_le32(&gpio->out_data, CONFIG_CAM_ENC_LED_MASK); +} + +/* + * TIMER 0 is used for tick + */ +static struct davinci_timer *timer = + (struct davinci_timer *)DAVINCI_TIMER3_BASE; + +#define TIMER_LOAD_VAL 0xffffffff +#define TIM_CLK_DIV 16 + +static int cam_enc_4xx_timer_init(void) +{ + /* We are using timer34 in unchained 32-bit mode, full speed */ + writel(0x0, &timer->tcr); + writel(0x0, &timer->tgcr); + writel(0x06 | ((TIM_CLK_DIV - 1) << 8), &timer->tgcr); + writel(0x0, &timer->tim34); + writel(TIMER_LOAD_VAL, &timer->prd34); + writel(2 << 22, &timer->tcr); + return 0; +} + +void board_gpio_init(void) +{ + struct davinci_gpio *gpio; + + cam_enc_4xx_set_all_led(); + cam_enc_4xx_timer_init(); + gpio = davinci_gpio_bank01; + clrbits_le32(&gpio->dir, ~0xfdfffffe); + /* clear LED D14 = GPIO25 */ + clrbits_le32(&gpio->out_data, 0x02000000); + gpio = davinci_gpio_bank23; + clrbits_le32(&gpio->dir, ~0x5ff0afef); + /* set GPIO61 to 1 -> intern UART0 as Console */ + setbits_le32(&gpio->out_data, 0x20000000); + /* + * PHY out of reset GIO 50 = 1 + * NAND WP off GIO 51 = 1 + */ + setbits_le32(&gpio->out_data, 0x000c0004); + gpio = davinci_gpio_bank45; + clrbits_le32(&gpio->dir, ~(0xdb2fffff) | CONFIG_CAM_ENC_LED_MASK); + /* + * clear LED: + * D17 = GPIO86 + * D11 = GPIO87 + * GPIO88 + * GPIO89 + * D13 = GPIO90 + * GPIO91 + */ + clrbits_le32(&gpio->out_data, CONFIG_CAM_ENC_LED_MASK); + gpio = davinci_gpio_bank67; + clrbits_le32(&gpio->dir, ~0x000007ff); +} + +/* + * functions for the post memory test. + */ +int arch_memory_test_prepare(u32 *vstart, u32 *size, phys_addr_t *phys_offset) +{ + *vstart = CONFIG_SYS_SDRAM_BASE; + *size = PHYS_SDRAM_1_SIZE; + *phys_offset = 0; + return 0; +} + +void arch_memory_failure_handle(void) +{ + cam_enc_4xx_set_all_led(); + puts("mem failure\n"); + while (1) + ; +} +#endif diff --git a/board/ait/cam_enc_4xx/config.mk b/board/ait/cam_enc_4xx/config.mk new file mode 100644 index 0000000..b1f9b6c --- /dev/null +++ b/board/ait/cam_enc_4xx/config.mk @@ -0,0 +1,15 @@ +# +# AIT cam_enc_4xx board +# cam_enc_4xx board has 1 bank of 256 MB DDR RAM +# Physical Address: 8000'0000 to 9000'0000 +# +# Linux Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) +# + +#Provide at least 16MB spacing between us and the Linux Kernel image +PAD_TO := 12320 +UBL_CONFIG = $(SRCTREE)/board/$(BOARDDIR)/ublimage.cfg +ifndef CONFIG_SPL_BUILD +ALL-y += $(obj)u-boot.ubl +endif diff --git a/board/ait/cam_enc_4xx/u-boot-spl.lds b/board/ait/cam_enc_4xx/u-boot-spl.lds new file mode 100644 index 0000000..6f6e065 --- /dev/null +++ b/board/ait/cam_enc_4xx/u-boot-spl.lds @@ -0,0 +1,73 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2008 + * Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE,\ + LENGTH = CONFIG_SPL_MAX_SIZE } + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + __start = .; + arch/arm/cpu/arm926ejs/start.o (.text) + *(.text*) + } >.sram + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(.rodata*)) } >.sram + + . = ALIGN(4); + .data : { *(SORT_BY_ALIGNMENT(.data*)) } >.sram + . = ALIGN(4); + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } >.sram + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } >.sram + + .bss : + { + . = ALIGN(4); + __bss_start = .; + *(.bss*) + . = ALIGN(4); + __bss_end__ = .; + } >.sram + + __image_copy_end = .; + _end = .; +} diff --git a/board/ait/cam_enc_4xx/ublimage.cfg b/board/ait/cam_enc_4xx/ublimage.cfg new file mode 100644 index 0000000..95182ca --- /dev/null +++ b/board/ait/cam_enc_4xx/ublimage.cfg @@ -0,0 +1,48 @@ +# +# (C Copyright 2011 +# Heiko Schocher DENX Software Engineering hs@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not write to the Free Software +# Foundation Inc. 51 Franklin Street Fifth Floor Boston, +# MA 02110-1301 USA +# +# Refer doc/README.ublimage for more details about how-to configure +# and create ublimage boot image +# +# The syntax is taken as close as possible with the kwbimage + +# UBL special mode : one of +# safe (the board has no nand neither onenand) +MODE safe + +# Entry point address for the user bootloader (absolute address) +# nand spl TEXT_BASE = 0x20 !! +ENTRY 0x00000020 + +# Number of pages (size of user bootloader in number of pages) +# @ nand spl 6 pages +PAGES 6 + +# Block number where user bootloader is present +# RBL starts always with block 1 +START_BLOCK 5 + +# Page number where user bootloader is present +# Page 0 is always UBL header +START_PAGE 0 + +LD_ADDR 0x20 diff --git a/boards.cfg b/boards.cfg index 604becf..d31e1b3 100644 --- a/boards.cfg +++ b/boards.cfg @@ -119,6 +119,7 @@ pm9263 arm arm926ejs pm9263 ronetix pm9g45 arm arm926ejs pm9g45 ronetix at91 pm9g45:AT91SAM9G45 da830evm arm arm926ejs da8xxevm davinci davinci da850evm arm arm926ejs da8xxevm davinci davinci +cam_enc_4xx arm arm926ejs cam_enc_4xx ait davinci cam_enc_4xx hawkboard arm arm926ejs da8xxevm davinci davinci hawkboard_nand arm arm926ejs da8xxevm davinci davinci hawkboard:NAND_U_BOOT hawkboard_uart arm arm926ejs da8xxevm davinci davinci hawkboard:UART_U_BOOT diff --git a/doc/README.davinci.nand_spl b/doc/README.davinci.nand_spl new file mode 100644 index 0000000..f46721a --- /dev/null +++ b/doc/README.davinci.nand_spl @@ -0,0 +1,141 @@ +With this approach, we don't need the UBL any more on DaVinci boards. +A "make boardname" will compile a u-boot.ubl, with UBL Header, which is +needed for the RBL to find the "UBL", which actually is a UBL-compatible +header, nand spl code and u-boot code. + + +As the RBL uses another read function as the "standard" u-boot, +we need a command, which switches between this two read/write +functions, so we can write the UBL header and the spl +code in a format, which the RBL can read. This is realize +(at the moment in board specific code) in the u-boot command +nandrbl + +nandrbl without arguments returns actual mode (rbl or uboot). +with nandrbl mode (mode = "rbl" or "uboot") you can switch +between the two NAND read/write modes. + + +To set up mkimage you need a config file for mkimage, example: +board/ait/cam_enc_4xx/ublimage.cfg + +For information about the configuration please see: +doc/README.ublimage + +Example for the cam_enc_4xx board: +On the cam_enc_4xx board we have a NAND flash with blocksize = 0x20000 and +pagesize = 0x800, so the u-boot.ubl image (which you get with: +"make cam_enc_4xx") looks like this: + +00000000 00 ed ac a1 20 00 00 00 06 00 00 00 05 00 00 00 |.... ...........| +00000010 00 00 00 00 20 00 00 00 ff ff ff ff ff ff ff ff |.... ...........| +00000020 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| +* +00000800 14 00 00 ea 14 f0 9f e5 10 f0 9f e5 0c f0 9f e5 |................| +00000810 08 f0 9f e5 04 f0 9f e5 00 f0 9f e5 04 f0 1f e5 |................| +00000820 00 01 00 00 78 56 34 12 78 56 34 12 78 56 34 12 |....xV4.xV4.xV4.| +[...] +* +00001fe0 00 00 00 00 00 00 00 00 ff ff ff ff ff ff ff ff |................| +00001ff0 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff |................| +* +00003800 14 00 00 ea 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 |................| +00003810 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 14 f0 9f e5 |................| +00003820 80 01 08 81 e0 01 08 81 40 02 08 81 a0 02 08 81 |........@.......| + +In the first "page" of the image, we have the UBL Header, needed for +the RBL to find the spl code. + +The spl code starts in the second "page" of the image, with a size +defined by: + +#define CONFIG_SYS_NROF_PAGES_NAND_SPL 6 + +After the spl code, there comes the "real" u-boot code +@ (6 + 1) * pagesize = 0x3800 + +------------------------------------------------------------------------ +Setting up spl code: + +/* + * RBL searches from Block n (n = 1..24) + * so we can define, how many UBL Headers + * we write before the real spl code + */ +#define CONFIG_SYS_NROF_UBL_HEADER 5 +#define CONFIG_SYS_NROF_PAGES_NAND_SPL 6 + +#define CONFIG_SYS_NAND_U_BOOT_OFFS ((CONFIG_SYS_NROF_UBL_HEADER * \ + CONFIG_SYS_NAND_BLOCK_SIZE) + \ + (CONFIG_SYS_NROF_PAGES_NAND_SPL) * \ + CONFIG_SYS_NAND_PAGE_SIZE) +------------------------------------------------------------------------ + +Burning into NAND: + +step 1: +The RBL searches from Block n ( n = 1..24) on page 0 for valid UBL +Headers, so you have to burn the UBL header page from the u-boot.ubl +image to the blocks, you want to have the UBL header. +!! Don;t forget to switch to rbl nand read/write functions with + "nandrbl rbl" + +step 2: +You need to setup in the ublimage.cfg, where the RBL can find the spl +code, and how big it is. + +!! RBL always starts reading from page 0 !! + +For the AIT board, we have: +PAGES 6 +START_BLOCK 5 + +So we need to copy the spl code to block 5 page 0 +!! Don;t forget to switch to rbl nand read/write functions with + "nandrbl rbl" + +step 3: +You need to copy the u-boot image to the block/page +where the spl code reads it (CONFIG_SYS_NAND_U_BOOT_OFFS) +!! Don;t forget to switch to rbl nand read/write functions with + "nandrbl uboot", which is default. + +On the cam_enc_4xx board it is: +#define CONFIG_SYS_NAND_U_BOOT_OFFS (0xc0000) + +-> this results in following NAND usage on the cam_enc_4xx board: + +addr + +20000 possible UBL Header +40000 possible UBL Header +60000 possible UBL Header +80000 possilbe UBL Header +a0000 spl code +c0000 u-boot code + +The above steps are executeed through the following environment vars: +(using 80000 as address for the UBL header) + +pagesz=800 +uboot=/tftpboot/cam_enc_4xx/u-boot.ubl +load=tftp 80000000 ${uboot} +writeheader nandrbl rbl;nand erase 80000 ${pagesz};nand write 80000000 80000 ${pagesz};nandrbl uboot +writenand_spl nandrbl rbl;nand erase a0000 3000;nand write 80000800 a0000 3000;nandrbl uboot +writeuboot nandrbl uboot;nand erase c0000 5d000;nand write 80003800 c0000 5d000 +update=run load writeheader writenand_spl writeuboot + +If you do a "run load update" u-boot, spl + ubl header +are magically updated ;-) + +Note: +- There seem to be a bug in the RBL code (at least on my HW), + In the UBL block, I can set the page to values != 0, so it + is possible to burn step 1 and step 2 in one step into the + flash, but the RBL ignores the page settings, so I have to + burn the UBL Header to a page 0 and the spl code to + a page 0 ... :-( +- If we make the nand read/write functions in the RBL equal to + the functions in u-boot (as I have no RBL code, it is only + possible in u-boot), we could burn the complete image in + one step ... that would be nice ... diff --git a/include/configs/cam_enc_4xx.h b/include/configs/cam_enc_4xx.h new file mode 100644 index 0000000..a21d448 --- /dev/null +++ b/include/configs/cam_enc_4xx.h @@ -0,0 +1,453 @@ +/* + * Copyright (C) 2009 Texas Instruments Incorporated + * + * Copyright (C) 2011 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_SYS_NO_FLASH /* that is, no *NOR* flash */ +#define CONFIG_SYS_CONSOLE_INFO_QUIET + +/* SoC Configuration */ +#define CONFIG_ARM926EJS /* arm926ejs CPU */ +#define CONFIG_SYS_TIMERBASE 0x01c21400 /* use timer 0 */ +#define CONFIG_SYS_HZ_CLOCK 24000000 /* timer0 freq */ +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SOC_DM365 + +#define CONFIG_MACH_TYPE MACH_TYPE_DAVINCI_DM365_EVM + +#define CONFIG_HOSTNAME cam_enc_4xx + +#define BOARD_LATE_INIT +#define CONFIG_CAM_ENC_LED_MASK 0x0fc00000 + +/* Memory Info */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 0x80000000 +#define PHYS_SDRAM_1_SIZE (256 << 20) /* 256 MiB */ +#define DDR_4BANKS /* 4-bank DDR2 (256MB) */ +#define CONFIG_MAX_RAM_BANK_SIZE (256 << 20) /* 256 MB */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +/* Serial Driver info: UART0 for console */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM1 0x01c20000 +#define CONFIG_SYS_NS16550_CLK CONFIG_SYS_HZ_CLOCK +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 + +/* Network Configuration */ +#define CONFIG_DRIVER_TI_EMAC +#define CONFIG_EMAC_MDIO_PHY_NUM 0 +#define CONFIG_SYS_EMAC_TI_CLKDIV 0xa9 /* 1MHz */ +#define CONFIG_MII +#define CONFIG_BOOTP_DEFAULT +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_NET_RETRY_COUNT 10 +#define CONFIG_NET_MULTI +#define CONFIG_CMD_MII +#define CONFIG_SYS_DCACHE_OFF +#define CONFIG_RESET_PHY_R + +/* I2C */ +#define CONFIG_HARD_I2C +#define CONFIG_DRIVER_DAVINCI_I2C +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 0x10 /* SMBus host address */ + +/* NAND: socketed, two chipselects, normally 2 GBytes */ +#define CONFIG_NAND_DAVINCI +#define CONFIG_SYS_NAND_CS 2 +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_SYS_NAND_4BIT_HW_ECC_OOBFIRST +#define CONFIG_SYS_NAND_PAGE_2K + +#define CONFIG_SYS_NAND_LARGEPAGE +#define CONFIG_SYS_NAND_BASE_LIST { 0x02000000, } +/* socket has two chipselects, nCE0 gated by address BIT(14) */ +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_MAX_CHIPS 1 + +/* SPI support */ +#define CONFIG_SPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_DAVINCI_SPI +#define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE +#define CONFIG_SYS_SPI_CLK davinci_clk_get(SPI_PLLDIV) +#define CONFIG_SF_DEFAULT_SPEED 3000000 +#define CONFIG_ENV_SPI_MAX_HZ CONFIG_SF_DEFAULT_SPEED +#define CONFIG_CMD_SF + +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_DAVINCI_MMC +#define CONFIG_MMC_MBLOCK + +/* U-Boot command configuration */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_BDI +#undef CONFIG_CMD_FLASH +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_SETGETDCR +#define CONFIG_CMD_ASKENV +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_PING +#define CONFIG_CMD_SAVES + +#ifdef CONFIG_MMC +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_MMC +#endif + +#ifdef CONFIG_NAND_DAVINCI +#define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_NAND +#define CONFIG_CMD_UBI +#define CONFIG_RBTREE +#endif + +#define CONFIG_CRC32_VERIFY +#define CONFIG_MX_CYCLIC + +/* U-Boot general configuration */ +#undef CONFIG_USE_IRQ /* No IRQ/FIQ in U-Boot */ +#define CONFIG_BOOTFILE "uImage" /* Boot file name */ +#define CONFIG_SYS_PROMPT "cam_enc_4xx> " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE /* Print buffer size */ \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_LONGHELP + +#ifdef CONFIG_NAND_DAVINCI +#define CONFIG_ENV_SIZE (256 << 10) /* 256 KiB */ +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x0 +#undef CONFIG_ENV_IS_IN_FLASH +#endif + +#if defined(CONFIG_MMC) && !defined(CONFIG_ENV_IS_IN_NAND) +#define CONFIG_CMD_ENV +#define CONFIG_ENV_SIZE (16 << 10) /* 16 KiB */ +#define CONFIG_ENV_OFFSET (51 << 9) /* Sector 51 */ +#define CONFIG_ENV_IS_IN_MMC +#undef CONFIG_ENV_IS_IN_FLASH +#endif + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_CMDLINE_EDITING +#define CONFIG_VERSION_VARIABLE +#define CONFIG_TIMESTAMP + +/* U-Boot memory configuration */ +#define CONFIG_STACKSIZE (256 << 10) /* 256 KiB */ +#define CONFIG_SYS_MALLOC_LEN (1 << 20) /* 1 MiB */ +#define CONFIG_SYS_MEMTEST_START 0x80000000 /* physical address */ +#define CONFIG_SYS_MEMTEST_END 0x81000000 /* test 16MB RAM */ + +/* Linux interfacing */ +#define CONFIG_CMDLINE_TAG +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_SYS_BARGSIZE 1024 /* bootarg Size */ +#define CONFIG_SYS_LOAD_ADDR 0x80700000 /* kernel address */ + +#define MTDIDS_DEFAULT "nand0=davinci_nand.0" + +#ifdef CONFIG_SYS_NAND_LARGEPAGE +/* Use same layout for 128K/256K blocks; allow some bad blocks */ +#define PART_BOOT "2m(bootloader)ro," +#endif + +#define PART_KERNEL "4m(kernel)," /* kernel + initramfs */ +#define PART_REST "-(filesystem)" + +#define MTDPARTS_DEFAULT \ + "mtdparts=davinci_nand.0:" PART_BOOT PART_KERNEL PART_REST + +#define CONFIG_SYS_NAND_PAGE_SIZE (0x800) +#define CONFIG_SYS_NAND_BLOCK_SIZE (0x20000) + +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SPL_NAND_SIMPLE +#define CONFIG_SPL_NAND_LOAD +#define CONFIG_SYS_NAND_HW_ECC_OOBFIRST +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_POST_MEM_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(BOARDDIR)/u-boot-spl.lds" +#define CONFIG_SPL_STACK (0x00010000 + 0x7f00) + +#define CONFIG_SPL_TEXT_BASE 0x0000020 /*CONFIG_SYS_SRAM_START*/ +#define CONFIG_SPL_MAX_SIZE 12320 + +#ifndef CONFIG_SPL_BUILD +#define CONFIG_SYS_TEXT_BASE 0x81080000 +#endif + +#define CONFIG_SYS_NAND_BASE 0x02000000 +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) + +#define CONFIG_SYS_NAND_ECCPOS { \ + 24, 25, 26, 27, 28, \ + 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, \ + 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, \ + 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, \ + 59, 60, 61, 62, 63 } +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 +#define CONFIG_SYS_NAND_ECCSIZE 0x200 +#define CONFIG_SYS_NAND_ECCBYTES 10 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_ECCSTEPS (CONFIG_SYS_NAND_PAGE_SIZE / \ + CONFIG_SYS_NAND_ECCSIZE) +#define CONFIG_SYS_NAND_ECCTOTAL (40) + +/* + * RBL searches from Block n (n = 1..24) + * so we can define, how many UBL Headers + * we can write before the real spl code + */ +#define CONFIG_SYS_NROF_UBL_HEADER 5 +#define CONFIG_SYS_NROF_PAGES_NAND_SPL 6 + +#define CONFIG_SYS_NAND_U_BOOT_DST 0x81080000 /* u-boot TEXT_BASE */ +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_NAND_U_BOOT_DST + +/* + * Post tests for memory testing + */ +#define CONFIG_POST CONFIG_SYS_POST_MEMORY +#define _POST_WORD_ADDR 0x0 + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_SYS_INIT_SP_ADDR CONFIG_SPL_STACK + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0xc0000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE 0x60000 + +/* + * U-Boot is a 3rd stage loader and if booting with spl, cpu setup is + * done in board_init_f from c code. + */ +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* for UBL header */ +#define CONFIG_SYS_UBL_BLOCK (CONFIG_SYS_NAND_PAGE_SIZE) + +#define CONFIG_SYS_DM36x_PLL1_PLLM 0x55 +#define CONFIG_SYS_DM36x_PLL1_PREDIV 0x8005 +#define CONFIG_SYS_DM36x_PLL2_PLLM 0x09 +#define CONFIG_SYS_DM36x_PLL2_PREDIV 0x8000 +#define CONFIG_SYS_DM36x_PERI_CLK_CTRL 0x243F04FC +#define CONFIG_SYS_DM36x_PLL1_PLLDIV1 0x801b +#define CONFIG_SYS_DM36x_PLL1_PLLDIV2 0x8001 +/* POST DIV 680/2 = 340Mhz -> MJCP and HDVICP bus interface clock */ +#define CONFIG_SYS_DM36x_PLL1_PLLDIV3 0x8001 +/* + * POST DIV 680/4 = 170Mhz -> EDMA/Peripheral CFG0(1/2 MJCP/HDVICP bus + * interface clk) + */ +#define CONFIG_SYS_DM36x_PLL1_PLLDIV4 0x8003 +/* POST DIV 680/2 = 340Mhz -> VPSS */ +#define CONFIG_SYS_DM36x_PLL1_PLLDIV5 0x8001 +/* POST DIV 680/9 = 75.6 Mhz -> VENC */ +#define CONFIG_SYS_DM36x_PLL1_PLLDIV6 0x8008 +/* + * POST DIV 680/1 = 680Mhz -> DDRx2(with internal divider of 2, clock boils + * down to 340 Mhz) + */ +#define CONFIG_SYS_DM36x_PLL1_PLLDIV7 0x8000 +/* POST DIV 680/7= 97Mhz-> MMC0/SD0 */ +#define CONFIG_SYS_DM36x_PLL1_PLLDIV8 0x8006 +/* POST DIV 680/28 = 24.3Mhz-> CLKOUT */ +#define CONFIG_SYS_DM36x_PLL1_PLLDIV9 0x801b + +#define CONFIG_SYS_DM36x_PLL2_PLLDIV1 0x8011 +/* POST DIV 432/1=432 Mhz -> ARM926/(HDVICP block) clk */ +#define CONFIG_SYS_DM36x_PLL2_PLLDIV2 0x8000 +#define CONFIG_SYS_DM36x_PLL2_PLLDIV3 0x8001 +/* POST DIV 432/21= 20.5714 Mhz->VOICE Codec clk */ +#define CONFIG_SYS_DM36x_PLL2_PLLDIV4 0x8014 +/* POST DIV 432/16=27 Mhz -> VENC(For SD modes, requires) */ +#define CONFIG_SYS_DM36x_PLL2_PLLDIV5 0x800f + +/* + * READ LATENCY 7 (CL + 2) + * CONFIG_PWRDNEN = 1 + * CONFIG_EXT_STRBEN = 1 + */ +#define CONFIG_SYS_DM36x_DDR2_DDRPHYCR (0 \ + | DV_DDR_PHY_EXT_STRBEN \ + | DV_DDR_PHY_PWRDNEN \ + | (7 << DV_DDR_PHY_RD_LATENCY_SHIFT)) + +/* + * T_RFC = (trfc/DDR_CLK) - 1 = (195 / 2.941) - 1 + * T_RP = (trp/DDR_CLK) - 1 = (12.5 / 2.941) - 1 + * T_RCD = (trcd/DDR_CLK) - 1 = (12.5 / 2.941) - 1 + * T_WR = (twr/DDR_CLK) - 1 = (15 / 2.941) - 1 + * T_RAS = (tras/DDR_CLK) - 1 = (45 / 2.941) - 1 + * T_RC = (trc/DDR_CLK) - 1 = (57.5 / 2.941) - 1 + * T_RRD = (trrd/DDR_CLK) - 1 = (7.5 / 2.941) - 1 + * T_WTR = (twtr/DDR_CLK) - 1 = (7.5 / 2.941) - 1 + */ +#define CONFIG_SYS_DM36x_DDR2_SDTIMR (0 \ + | (66 << DV_DDR_SDTMR1_RFC_SHIFT) \ + | (4 << DV_DDR_SDTMR1_RP_SHIFT) \ + | (4 << DV_DDR_SDTMR1_RCD_SHIFT) \ + | (5 << DV_DDR_SDTMR1_WR_SHIFT) \ + | (14 << DV_DDR_SDTMR1_RAS_SHIFT) \ + | (19 << DV_DDR_SDTMR1_RC_SHIFT) \ + | (2 << DV_DDR_SDTMR1_RRD_SHIFT) \ + | (2 << DV_DDR_SDTMR1_WTR_SHIFT)) + +/* + * T_RASMAX = (trasmax/refresh_rate) - 1 = (70K / 7812.6) - 1 + * T_XP = tCKE - 1 = 3 - 2 + * T_XSNR= ((trfc + 10)/DDR_CLK) - 1 = (205 / 2.941) - 1 + * T_XSRD = txsrd - 1 = 200 - 1 + * T_RTP = (trtp/DDR_CLK) - 1 = (7.5 / 2.941) - 1 + * T_CKE = tcke - 1 = 3 - 1 + */ +#define CONFIG_SYS_DM36x_DDR2_SDTIMR2 (0 \ + | (8 << DV_DDR_SDTMR2_RASMAX_SHIFT) \ + | (2 << DV_DDR_SDTMR2_XP_SHIFT) \ + | (69 << DV_DDR_SDTMR2_XSNR_SHIFT) \ + | (199 << DV_DDR_SDTMR2_XSRD_SHIFT) \ + | (2 << DV_DDR_SDTMR2_RTP_SHIFT) \ + | (2 << DV_DDR_SDTMR2_CKE_SHIFT)) + +/* PR_OLD_COUNT = 0xfe */ +#define CONFIG_SYS_DM36x_DDR2_PBBPR 0x000000FE +/* refresh rate = 0x768 */ +#define CONFIG_SYS_DM36x_DDR2_SDRCR 0x00000768 + +#define CONFIG_SYS_DM36x_DDR2_SDBCR (0 \ + | (2 << DV_DDR_SDCR_PAGESIZE_SHIFT) \ + | (3 << DV_DDR_SDCR_IBANK_SHIFT) \ + | (5 << DV_DDR_SDCR_CL_SHIFT) \ + | (1 << DV_DDR_SDCR_BUS_WIDTH_SHIFT) \ + | (1 << DV_DDR_SDCR_TIMUNLOCK_SHIFT) \ + | (1 << DV_DDR_SDCR_DDREN_SHIFT) \ + | (0 << DV_DDR_SDCR_DDRDRIVE0_SHIFT) \ + | (1 << DV_DDR_SDCR_DDR2EN_SHIFT) \ + | (1 << DV_DDR_SDCR_DDR_DDQS_SHIFT) \ + | (1 << DV_DDR_SDCR_BOOTUNLOCK_SHIFT)) + +#define CONFIG_SYS_DM36x_AWCCR 0xff +#define CONFIG_SYS_DM36x_AB1CR 0x40400204 +#define CONFIG_SYS_DM36x_AB2CR 0x04ca2650 + +/* All Video Inputs */ +#define CONFIG_SYS_DM36x_PINMUX0 0x00000000 +/* + * All Video Outputs, + * GPIO 86, 87 + 90 0x0000f030 + */ +#define CONFIG_SYS_DM36x_PINMUX1 0x00530002 +#define CONFIG_SYS_DM36x_PINMUX2 0x00001815 +/* + * SPI1, UART1, I2C, SD0, SD1, McBSP0, CLKOUTs + * GPIO 25 0x60000000 + */ +#define CONFIG_SYS_DM36x_PINMUX3 0x9b5affff +/* + * MMC/SD0 instead of MS, SPI0 + * GPIO 34 0x0000c000 + */ +#define CONFIG_SYS_DM36x_PINMUX4 0x00002655 + +/* + * Default environment settings + */ +#define xstr(s) str(s) +#define str(s) #s + +#define DVN4XX_UBOOT_ADDR_R_RAM 0x80000000 +/* (DVN4XX_UBOOT_ADDR_R_RAM + CONFIG_SYS_NAND_PAGE_SIZE) */ +#define DVN4XX_UBOOT_ADDR_R_NAND_SPL 0x80000800 +/* + * (DVN4XX_UBOOT_ADDR_R_NAND_SPL + (CONFIG_SYS_NROF_PAGES_NAND_SPL * \ + * CONFIG_SYS_NAND_PAGE_SIZE)) + */ +#define DVN4XX_UBOOT_ADDR_R_UBOOT 0x80003800 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "u_boot_addr_r=" xstr(DVN4XX_UBOOT_ADDR_R_RAM) "\0" \ + "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.ubl\0" \ + "load=tftp ${u_boot_addr_r} ${uboot}\0" \ + "pagesz=" xstr(CONFIG_SYS_NAND_PAGE_SIZE) "\0" \ + "writeheader=nandrbl rbl;nand erase 80000 ${pagesz};" \ + "nand write ${u_boot_addr_r} 80000 ${pagesz};" \ + "nandrbl uboot\0" \ + "writenand_spl=nandrbl rbl;nand erase a0000 3000;" \ + "nand write " xstr(DVN4XX_UBOOT_ADDR_R_NAND_SPL) \ + " a0000 3000;nandrbl uboot\0" \ + "writeuboot=nandrbl uboot;" \ + "nand erase " xstr(CONFIG_SYS_NAND_U_BOOT_OFFS) " " \ + xstr(CONFIG_SYS_NAND_U_BOOT_SIZE) \ + ";nand write " xstr(DVN4XX_UBOOT_ADDR_R_UBOOT) \ + " " xstr(CONFIG_SYS_NAND_U_BOOT_OFFS) " " \ + xstr(CONFIG_SYS_NAND_U_BOOT_SIZE) "\0" \ + "update=run load writenand_spl writeuboot\0" \ + "bootcmd=run bootcmd\0" \ + "rootpath=/opt/eldk-arm/arm\0" \ + "\0" + +/* USB Configuration */ +#define CONFIG_USB_DAVINCI +#define CONFIG_MUSB_HCD +#define CONFIG_DV_USBPHY_CTL (USBPHY_SESNDEN | USBPHY_VBDTCTEN | \ + USBPHY_PHY24MHZ) + +#define CONFIG_CMD_USB /* include support for usb cmd */ +#define CONFIG_USB_STORAGE /* MSC class support */ +#define CONFIG_CMD_STORAGE /* inclue support for usb-storage cmd */ +#define CONFIG_CMD_FAT /* inclue support for FAT/storage */ +#define CONFIG_DOS_PARTITION /* inclue support for FAT/storage */ + +#undef DAVINCI_DM365EVM +#define PINMUX4_USBDRVBUS_BITCLEAR 0x3000 +#define PINMUX4_USBDRVBUS_BITSET 0x2000 + +#endif /* __CONFIG_H */ diff --git a/tools/ublimage.h b/tools/ublimage.h index 93ec8ee..e440625 100644 --- a/tools/ublimage.h +++ b/tools/ublimage.h @@ -66,7 +66,7 @@ enum ublimage_fld_types { #define UBL_IMAGE_SIZE (0x00003800u)
/* one NAND block */ -#define UBL_BLOCK_SIZE 512 +#define UBL_BLOCK_SIZE 2048
/* from sprufg5a.pdf Table 109 */ struct ubl_header {
Heiko Schocher
Scott Wood
