[U-Boot-Users] Unable to mount root fs
Hello,
Does anyone have a suggestion about this error? I got the same error in the following cases:
no initrd image in flash ( command : bootm 0x40000) multifile containing both kernel and initrd ( command : bootm 0x40000) compressed kernel uImage at 0x4000 and compressed initrd image at 0x120000 ( command : bootm 0x40000 0x120000) compressed kernel uImage at 0x4000 and uncompressed initrd image at 0x120000 ( command : bootm 0x40000 0x120000)
Starting kernel ...
Linux version 2.4.19-rmk7-pxa2 (root@localhost.localdomain) (gcc version 3.2.1) #1 Wed May 19 14:58:50 EEST 2004 CPU: XScale-PXA255 revision 6 Machine: Biosafe Memory clock: 99.53MHz (*27) Run Mode clock: 199.07MHz (*2) Turbo Mode clock: 199.07MHz (*1.0, inactive) On node 0 totalpages: 16384 zone(0): 16384 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: console=ttyS0,19200 root=/dev/ram Calibrating delay loop... 198.65 BogoMIPS Memory: 64MB = 64MB total Memory: 63988KB available (576K code, 190K data, 36K init) Dentry cache hash table entries: 8192 (order: 4, 65536 bytes) Inode cache hash table entries: 4096 (order: 3, 32768 bytes) Mount-cache hash table entries: 1024 (order: 1, 8192 bytes) Buffer-cache hash table entries: 4096 (order: 2, 16384 bytes) Page-cache hash table entries: 16384 (order: 4, 65536 bytes) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Starting kswapd pty: 256 Unix98 ptys configured Serial driver version 5.05c (2001-07-08) with no serial options enabled ttyS00 at 0x0000 (irq = 15) is a PXA UART ttyS01 at 0x0000 (irq = 14) is a PXA UART ttyS02 at 0x0000 (irq = 13) is a PXA UART NetWinder Floating Point Emulator V0.95 (c) 1998-1999 Rebel.com Kernel panic: VFS: Unable to mount root fs on 01:00
It looks like that you haven't compiled initrd support in your kernel. Make sure that you have Initrd support turned on as well as the support for the filesystem that your initial ramdisk contains.
Petre Pircalabu
Sharad Gupta
