[U-Boot] [PATCH 1/5] bcm63158: add initial support
This add the initial support of the broadcom bcm63158 SoC family, only the cpu, dram and uart are supported.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/arm/Kconfig | 6 ++++ arch/arm/dts/bcm63158.dtsi | 85 ++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 91 insertions(+) create mode 100644 arch/arm/dts/bcm63158.dtsi
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f0edb10..4316de0 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -528,6 +528,12 @@ config ARCH_BCM283X imply CMD_DM imply FAT_WRITE
+config ARCH_BCM63158 + bool "Broadcom BCM63158 family" + select DM + select OF_CONTROL + imply CMD_DM + config ARCH_BCM6858 bool "Broadcom BCM6858 family" select DM diff --git a/arch/arm/dts/bcm63158.dtsi b/arch/arm/dts/bcm63158.dtsi new file mode 100644 index 0000000..be68205 --- /dev/null +++ b/arch/arm/dts/bcm63158.dtsi @@ -0,0 +1,85 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Philippe Reynes philippe.reynes@softathome.com + */ + +#include "skeleton64.dtsi" + +/ { + compatible = "brcm,bcm63158"; + #address-cells = <2>; + #size-cells = <2>; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + u-boot,dm-pre-reloc; + + cpu0: cpu@0 { + compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + reg = <0x0 0x0>; + next-level-cache = <&l2>; + u-boot,dm-pre-reloc; + }; + + cpu1: cpu@1 { + compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + reg = <0x0 0x1>; + next-level-cache = <&l2>; + u-boot,dm-pre-reloc; + }; + + cpu2: cpu@2 { + compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + reg = <0x0 0x2>; + next-level-cache = <&l2>; + u-boot,dm-pre-reloc; + }; + + cpu3: cpu@3 { + compatible = "arm,cortex-a53", "arm,armv8"; + device_type = "cpu"; + reg = <0x0 0x3>; + next-level-cache = <&l2>; + u-boot,dm-pre-reloc; + }; + + l2: l2-cache0 { + compatible = "cache"; + u-boot,dm-pre-reloc; + }; + }; + + clocks { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + u-boot,dm-pre-reloc; + + periph_osc: periph-osc { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <0xbebc200>; + u-boot,dm-pre-reloc; + }; + }; + + ubus { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + u-boot,dm-pre-reloc; + + uart0: serial@ff812000 { + compatible = "arm,pl011", "arm,primecell"; + reg = <0x0 0xff812000 0x0 0x1000>; + clock = <50000000>; + + status = "disabled"; + }; + }; +};
This add the initial support of the broadcom reference board bcm963158 with a bcm63158 SoC.
This board has 1 GB of ram, 512 MB of flash (nand), 2 usb port, 1 uart, 4 ethernet ports (LAN), 1 ethernet port (WAN).
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/arm/Kconfig | 1 + arch/arm/dts/bcm963158.dts | 31 ++++++++++++++++++ board/broadcom/bcm963158/Kconfig | 17 ++++++++++ board/broadcom/bcm963158/MAINTAINERS | 6 ++++ board/broadcom/bcm963158/Makefile | 3 ++ board/broadcom/bcm963158/bcm963158.c | 61 ++++++++++++++++++++++++++++++++++++ configs/bcm963158_ram_defconfig | 40 +++++++++++++++++++++++ include/configs/broadcom_bcm963158.h | 37 ++++++++++++++++++++++ 8 files changed, 196 insertions(+) create mode 100644 arch/arm/dts/bcm963158.dts create mode 100644 board/broadcom/bcm963158/Kconfig create mode 100644 board/broadcom/bcm963158/MAINTAINERS create mode 100644 board/broadcom/bcm963158/Makefile create mode 100644 board/broadcom/bcm963158/bcm963158.c create mode 100644 configs/bcm963158_ram_defconfig create mode 100644 include/configs/broadcom_bcm963158.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 4316de0..455f06c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1532,6 +1532,7 @@ source "board/armltd/vexpress/Kconfig" source "board/armltd/vexpress64/Kconfig" source "board/broadcom/bcm23550_w1d/Kconfig" source "board/broadcom/bcm28155_ap/Kconfig" +source "board/broadcom/bcm963158/Kconfig" source "board/broadcom/bcm968580xref/Kconfig" source "board/broadcom/bcmcygnus/Kconfig" source "board/broadcom/bcmnsp/Kconfig" diff --git a/arch/arm/dts/bcm963158.dts b/arch/arm/dts/bcm963158.dts new file mode 100644 index 0000000..dc5afb5 --- /dev/null +++ b/arch/arm/dts/bcm963158.dts @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Philippe Reynes philippe.reynes@softathome.com + */ + +/dts-v1/; + +#include "bcm63158.dtsi" + +/ { + model = "Broadcom bcm963158"; + compatible = "broadcom,bcm963158", "brcm,bcm63158"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + memory { + device_type = "memory"; + reg = <0x0 0x0 0x0 0x40000000>; + }; +}; + +&uart0 { + u-boot,dm-pre-reloc; + status = "okay"; +}; diff --git a/board/broadcom/bcm963158/Kconfig b/board/broadcom/bcm963158/Kconfig new file mode 100644 index 0000000..41b6adb --- /dev/null +++ b/board/broadcom/bcm963158/Kconfig @@ -0,0 +1,17 @@ +if ARCH_BCM63158 + +config SYS_VENDOR + default "broadcom" + +config SYS_BOARD + default "bcm963158" + +config SYS_CONFIG_NAME + default "broadcom_bcm963158" + +endif + +config TARGET_BCM963158 + bool "Support Broadcom bcm963158" + depends on ARCH_BCM63158 + select ARM64 diff --git a/board/broadcom/bcm963158/MAINTAINERS b/board/broadcom/bcm963158/MAINTAINERS new file mode 100644 index 0000000..d28d971 --- /dev/null +++ b/board/broadcom/bcm963158/MAINTAINERS @@ -0,0 +1,6 @@ +BROADCOM BCM963158 +M: Philippe Reynes philippe.reynes@softathome.com +S: Maintained +F: board/broadcom/bcm963158/ +F: include/configs/broadcom_bcm963158.h +F: configs/bcm963158_ram_defconfig diff --git a/board/broadcom/bcm963158/Makefile b/board/broadcom/bcm963158/Makefile new file mode 100644 index 0000000..0a902c9 --- /dev/null +++ b/board/broadcom/bcm963158/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += bcm963158.o diff --git a/board/broadcom/bcm963158/bcm963158.c b/board/broadcom/bcm963158/bcm963158.c new file mode 100644 index 0000000..db82cd5 --- /dev/null +++ b/board/broadcom/bcm963158/bcm963158.c @@ -0,0 +1,61 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Philippe Reynes philippe.reynes@softathome.com + */ + +#include <common.h> +#include <fdtdec.h> +#include <linux/io.h> + +#ifdef CONFIG_ARM64 +#include <asm/armv8/mmu.h> + +static struct mm_region broadcom_bcm963158_mem_map[] = { + { + /* RAM */ + .virt = 0x00000000UL, + .phys = 0x00000000UL, + .size = 8UL * SZ_1G, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + /* SoC */ + .virt = 0x80000000UL, + .phys = 0x80000000UL, + .size = 0xff80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = broadcom_bcm963158_mem_map; +#endif + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ + if (fdtdec_setup_mem_size_base() != 0) + printf("fdtdec_setup_mem_size_base() has failed\n"); + + return 0; +} + +int dram_init_banksize(void) +{ + fdtdec_setup_memory_banksize(); + + return 0; +} + +int print_cpuinfo(void) +{ + return 0; +} diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig new file mode 100644 index 0000000..6e3b688 --- /dev/null +++ b/configs/bcm963158_ram_defconfig @@ -0,0 +1,40 @@ +CONFIG_ARM=y +# CONFIG_ARM64_SUPPORT_AARCH32 is not set +CONFIG_ARCH_BCM63158=y +CONFIG_SYS_TEXT_BASE=0x10000000 +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 +CONFIG_TARGET_BCM963158=y +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_TPL_SYS_MALLOC_F_LEN=0x400 +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_FIT_ENABLE_RSASSA_PSS_SUPPORT=y +CONFIG_FIT_VERBOSE=y +CONFIG_IMAGE_FORMAT_LEGACY=y +CONFIG_SUPPORT_RAW_INITRD=y +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTEFI_SELFTEST=y +# CONFIG_CMD_LZMADEC is not set +# CONFIG_CMD_UNZIP is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_CACHE=y +CONFIG_DOS_PARTITION=y +CONFIG_ISO_PARTITION=y +CONFIG_EFI_PARTITION=y +CONFIG_DEFAULT_DEVICE_TREE="bcm963158" +# CONFIG_NET is not set +CONFIG_BLK=y +CONFIG_CLK=y +# CONFIG_MMC is not set +CONFIG_SPECIFY_CONSOLE_INDEX=y +# CONFIG_SPL_SERIAL_PRESENT is not set +CONFIG_CONS_INDEX=0 +CONFIG_DM_SERIAL=y +CONFIG_SERIAL_SEARCH_ALL=y +CONFIG_PL01X_SERIAL=y +CONFIG_SYSRESET=y +CONFIG_REGEX=y +# CONFIG_GENERATE_SMBIOS_TABLE is not set diff --git a/include/configs/broadcom_bcm963158.h b/include/configs/broadcom_bcm963158.h new file mode 100644 index 0000000..5834e1e --- /dev/null +++ b/include/configs/broadcom_bcm963158.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Philippe Reynes philippe.reynes@softathome.com + */ + +#include <linux/sizes.h> + +/* + * common + */ + +/* UART */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ + 230400, 500000, 1500000 } +/* Memory usage */ +#define CONFIG_SYS_MAXARGS 24 +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) +#define CONFIG_SYS_BOOTM_LEN (16 * 1024 * 1024) + +/* + * 63158 + */ + +/* RAM */ +#define CONFIG_SYS_SDRAM_BASE 0x00000000 + +/* U-Boot */ +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_TEXT_BASE + SZ_16M) +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_TEXT_BASE + +#define CONFIG_SKIP_LOWLEVEL_INIT + +/* + * bcm963158 + */ + +#define CONFIG_ENV_SIZE (8 * 1024)
This IP is also used on some arm SoC, so we allow to use it on arm bcm63158 too.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- drivers/watchdog/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 9456abd..115fc45 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -88,7 +88,7 @@ config WDT_ASPEED
config WDT_BCM6345 bool "BCM6345 watchdog timer support" - depends on WDT && (ARCH_BMIPS || ARCH_BCM6858) + depends on WDT && (ARCH_BMIPS || ARCH_BCM6858 || ARCH_BCM63158) help Select this to enable watchdog timer for BCM6345 SoCs. The watchdog timer is stopped when initialized.
This commit add watchdog and sysreset watchdog in the bcm63158 device tree.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- arch/arm/dts/bcm63158.dtsi | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/arch/arm/dts/bcm63158.dtsi b/arch/arm/dts/bcm63158.dtsi index be68205..6a3fbc9 100644 --- a/arch/arm/dts/bcm63158.dtsi +++ b/arch/arm/dts/bcm63158.dtsi @@ -81,5 +81,22 @@
status = "disabled"; }; + + wdt1: watchdog@ff800480 { + compatible = "brcm,bcm6345-wdt"; + reg = <0x0 0xff800480 0x0 0x14>; + clocks = <&periph_osc>; + }; + + wdt2: watchdog@ff8004c0 { + compatible = "brcm,bcm6345-wdt"; + reg = <0x0 0xff8004c0 0x0 0x14>; + clocks = <&periph_osc>; + }; + + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdt1>; + }; }; };
Enable watchdog and reboot with watchdog in the configuration.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- configs/bcm963158_ram_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/bcm963158_ram_defconfig b/configs/bcm963158_ram_defconfig index 6e3b688..9083f1d 100644 --- a/configs/bcm963158_ram_defconfig +++ b/configs/bcm963158_ram_defconfig @@ -36,5 +36,7 @@ CONFIG_DM_SERIAL=y CONFIG_SERIAL_SEARCH_ALL=y CONFIG_PL01X_SERIAL=y CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y +CONFIG_WDT_BCM6345=y CONFIG_REGEX=y # CONFIG_GENERATE_SMBIOS_TABLE is not set
Philippe Reynes
