[U-Boot] m68k: 3 boards are broken
Hi Alison, Angelo
I found 3 m68k boards are broken: eb_cpu5282_defconfig eb_cpu5282_internal_defconfig M53017EVB_defconfig
LD u-boot common/built-in.o: In function `reserve_video': /home/yamada/workspace/u-boot/common/board_f.c:501: undefined reference to `video_setmem' make: *** [u-boot] Error 1
Can you figure it out, please?
Dear Masahiro,
On 27/03/2015 08:05, Masahiro Yamada wrote:
Hi Alison, Angelo
Fixed the first 2 boards, there is no reserve_video needed for m68k. The third (M53017EVB) is a relocation issue.
arch/m68k/cpu/mcf532x/start.o: In function `_start': /home/angelo/sysam/u-boot/arch/m68k/cpu/mcf532x/start.S:159:(.text+0x462): relocation truncated to fit: R_68K_PC16 against symbol `board_init_f' defined in .text.board_init_f section in common/built-in.o Makefile:1094: set di istruzioni per l'obiettivo "u-boot" non riuscito make: *** [u-boot] Errore 1
For some reason this board have a different text section in the linker script, and this cause the error. Also board.c in m68k/lib is no more built-in.
SECTIONS { /* Read-only sections, merged into text segment: */ .text : { arch/m68k/cpu/mcf532x/start.o (.text*) arch/m68k/cpu/mcf532x/built-in.o (.text*) arch/m68k/lib/built-in.o (.text*)
. = DEFINED(env_offset) ? env_offset : .; common/env_embedded.o (.text*)
*(.text*) } _etext = .;
Studying on this last issue. Hope to post the full patch later.
Regards Angelo
Hi Alison, Angelo
about M53017EVB_defconfig, i moved embedded env in 3rd sector (should be third as Spansion layout) exactly as M52277 do with similar os same flash.
Alison, feel free to change / block this if doesn't suit the board needs.
Regards, Angelo Dureghello
Angelo Dureghello
Masahiro Yamada
