The following changes since commit ae52e75d23ce11f36b3eae758045da95a871f263:
Merge tag 'for-v2021.01-next' of https://gitlab.denx.de/u-boot/custodians/u-boot-i2c into next (2020-09-17 09:55:01 -0400)
git://git.denx.de/u-boot-usb.git next
for you to fetch changes up to 4fb50766433626f4d57e7491e638bc55d80badef:
usb: xhci-rcar: Add support for R8A774A1 SoC (2020-09-22 13:40:27 +0200)
---------------------------------------------------------------- Chance.Yang (1): usb: dwc2: Fix contorl OUT transfer issue
Chunfeng Yun (9): usb: xhci: add a member hci_version in xhci_ctrl struct usb: xhci: create one unified function to calculate TRB TD remainder usb: xhci: add quirks flag to support MediaTek xHCI 0.96 usb: xhci: convert to HCS_MAX_PORTS() usb: xhci: convert to TRB_TYPE() usb: xhci: convert to TRB_LEN() and TRB_INTR_TARGET() usb: xhci: convert to TRB_TX_TYPE() usb: xhci: use macros with parameter to fill ep_info2 usb: xhci: convert to readx_poll_sleep_timeout()
Lad Prabhakar (1): usb: xhci-rcar: Add support for R8A774A1 SoC
drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 16 +++++++++-- drivers/usb/host/xhci-mem.c | 18 ++++-------- drivers/usb/host/xhci-mtk.c | 1 + drivers/usb/host/xhci-rcar.c | 1 + drivers/usb/host/xhci-ring.c | 141 ++++++++++++++++++++++++++++++++++++++++++++---------------------------------------------- drivers/usb/host/xhci.c | 37 +++++++++++------------- include/usb/xhci.h | 18 ++++-------- 7 files changed, 111 insertions(+), 121 deletions(-)
NAK. Introduces a failure to build on: rpi_4 poplar odroid-c4 odroid-n2 khadas-vim libretech-ac libretech-cc khadas-vim2 libretech-s905d-pc libretech-s912-pc sei510 sei610 u200 khadas-vim3 khadas-vim3l odroid-go2 evb-px30 firefly-px30 roc-cc-rk3308 evb-rk3308 evb-rk3328 roc-cc-rk3328 rock-pi-e-rk3328 rock64-rk3328 such as: +(rpi_4) drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c: In function 'process_ep_out_intr': +(rpi_4) drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c:425:18: error: cast from pointer to integer of different size [-Werror=pointer-to-int-cast] +(rpi_4) 425 | u32 epsiz_reg = (u32)®->out_endp[ep_num].doeptsiz; +(rpi_4) | ^ +(rpi_4) In file included from drivers/usb/gadget/dwc2_udc_otg.c:42: +(rpi_4) arch/arm/include/asm/io.h:45:28: error: cast to pointer from integer of different size [-Werror=int-to-pointer-cast] +(rpi_4) 45 | #define __arch_getl(a) (*(volatile unsigned int *)(a)) +(rpi_4) | ^ +(rpi_4) arch/arm/include/asm/io.h:127:31: note: in expansion of macro '__arch_getl' +(rpi_4) 127 | #define readl(c) ({ u32 __v = __arch_getl(c); __iormb(); __v; }) +(rpi_4) | ^~~~~~~~~~~ +(rpi_4) drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c:447:15: note: in expansion of macro 'readl' +(rpi_4) 447 | ep_tsr = readl(epsiz_reg); +(rpi_4) | ^~~~~ +(rpi_4) cc1: all warnings being treated as errors +(rpi_4) make[2]: *** [drivers/usb/gadget/dwc2_udc_otg.o] Error 1 +(rpi_4) make[1]: *** [drivers/usb/gadget] Error 2 +(rpi_4) make: *** [sub-make] Error 2
Since you'll have to dig in here anyhow, there's also a typo in the commit message of: commit d033774655ee4dd7b3fc45bc5273b8c7a892a5b2 Author: Chance.Yang chance.yang@vatics.com Date: Tue Sep 22 16:48:42 2020 +0800
Thanks!
Interesting, this must be new.
It would be useful to CC the author of that patch. I will drop the patch for now and wait for a fixed one.
Hmm? 4fb507664336 has this fail to build.
... it is likely that the patch I flagged only because of the typo is also the patch that introduced breakage, in hindsight.
This is without the DWC2 patch.
The following changes since commit 26acc6395fee680cea72e51348bd59e206eb0464:
Merge branch '2020-09-30-assorted-network-improvements' into next (2020-10-01 09:46:10 -0400)
for you to fetch changes up to e15e817f3eb13dd4b58f465b009164ecd8b997cf:
usb: xhci-rcar: Add support for R8A774A1 SoC (2020-10-01 19:43:05 +0200)
---------------------------------------------------------------- Chunfeng Yun (9): usb: xhci: add a member hci_version in xhci_ctrl struct usb: xhci: create one unified function to calculate TRB TD remainder usb: xhci: add quirks flag to support MediaTek xHCI 0.96 usb: xhci: convert to HCS_MAX_PORTS() usb: xhci: convert to TRB_TYPE() usb: xhci: convert to TRB_LEN() and TRB_INTR_TARGET() usb: xhci: convert to TRB_TX_TYPE() usb: xhci: use macros with parameter to fill ep_info2 usb: xhci: convert to readx_poll_sleep_timeout()
drivers/usb/host/xhci-mem.c | 18 +++++--------- drivers/usb/host/xhci-mtk.c | 1 + drivers/usb/host/xhci-rcar.c | 1 + drivers/usb/host/xhci-ring.c | 141 +++++++++++++++++++++++++++++++++++++++++++++++++++----------------------------------------------------- drivers/usb/host/xhci.c | 37 ++++++++++++---------------- include/usb/xhci.h | 18 ++++---------- 6 files changed, 98 insertions(+), 118 deletions(-)
