[U-Boot] [PATCH 1/2] usbarmory: switch to using kernel zImage
Switch to using zImage instead of uImage.
Signed-off-by: Andrej Rosano andrej@inversepath.com --- include/configs/usbarmory.h | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 8568663..c0e093f 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -69,17 +69,19 @@ #define CONFIG_CMD_FUSE #define CONFIG_FSL_IIM
-/* Linux boot */ +/* U-Boot memory offsets */ #define CONFIG_LOADADDR 0x72000000 #define CONFIG_SYS_TEXT_BASE 0x77800000 #define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* Linux boot */ #define CONFIG_HOSTNAME usbarmory #define CONFIG_BOOTCOMMAND \ "run distro_bootcmd; " \ "setenv bootargs console=${console} ${bootargs_default}; " \ - "ext2load mmc 0:1 ${kernel_addr_r} /boot/uImage; " \ + "ext2load mmc 0:1 ${kernel_addr_r} /boot/zImage; " \ "ext2load mmc 0:1 ${fdt_addr_r} /boot/${fdtfile}; " \ - "bootm ${kernel_addr_r} - ${fdt_addr_r}" + "bootz ${kernel_addr_r} - ${fdt_addr_r}"
#define BOOT_TARGET_DEVICES(func) func(MMC, mmc, 0)
Define a default board_run_command() function. This function contains the commands needed to boot the board when CLI is disabled (CONFIG_CMDLINE=n).
Signed-off-by: Andrej Rosano andrej@inversepath.com --- board/inversepath/usbarmory/usbarmory.c | 31 +++++++++++++++++++++++++++++++ include/configs/usbarmory.h | 11 +++++++---- 2 files changed, 38 insertions(+), 4 deletions(-)
diff --git a/board/inversepath/usbarmory/usbarmory.c b/board/inversepath/usbarmory/usbarmory.c index a809039..a11e3b3 100644 --- a/board/inversepath/usbarmory/usbarmory.c +++ b/board/inversepath/usbarmory/usbarmory.c @@ -415,3 +415,34 @@ int checkboard(void) puts("Board: Inverse Path USB armory MkI\n"); return 0; } + +#ifndef CONFIG_CMDLINE +static char *ext2_argv[] = { + "ext2load", + "mmc", + "0:1", + USBARMORY_FIT_ADDR, + USBARMORY_FIT_PATH +}; + +static char *bootm_argv[] = { + "bootm", + USBARMORY_FIT_ADDR +}; + +int board_run_command(const char *cmdline) +{ + printf("%s %s %s %s %s\n", ext2_argv[0], ext2_argv[1], ext2_argv[2], + ext2_argv[3], ext2_argv[4]); + + if (do_ext2load(NULL, 0, 5, ext2_argv) != 0) { + udelay(5*1000*1000); + return 1; + } + + printf("%s %s\n", bootm_argv[0], bootm_argv[1]); + do_bootm(NULL, 0, 2, bootm_argv); + + return 1; +} +#endif diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index c0e093f..5484204 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -17,16 +17,13 @@ #define CONFIG_SYS_FSL_CLK #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MXC_GPIO +#define CONFIG_SYS_NO_FLASH
#include <asm/arch/imx-regs.h>
#include <config_distro_defaults.h>
-/* U-Boot commands */ - /* U-Boot environment */ -#define CONFIG_ENV_OVERWRITE -#define CONFIG_SYS_NO_FLASH #define CONFIG_ENV_OFFSET (6 * 64 * 1024) #define CONFIG_ENV_SIZE (8 * 1024) #define CONFIG_ENV_IS_IN_MMC @@ -101,6 +98,12 @@ "console=ttymxc0,115200\0" \ BOOTENV
+#ifndef CONFIG_CMDLINE +#define CONFIG_BOOTARGS "console=ttymxc0,115200 root=/dev/mmcblk0p1 rootwait rw" +#define USBARMORY_FIT_PATH "/boot/usbarmory.itb" +#define USBARMORY_FIT_ADDR "0x70800000" +#endif + /* Physical Memory Map */ #define CONFIG_NR_DRAM_BANKS 1 #define PHYS_SDRAM CSD0_BASE_ADDR
Hallo Andrej,
- "ext2load",
- "mmc",
- "0:1",
- USBARMORY_FIT_ADDR,
- USBARMORY_FIT_PATH
- "bootm",
- printf("%s %s %s %s %s\n", ext2_argv[0], ext2_argv[1], ext2_argv[2],
- if (do_ext2load(NULL, 0, 5, ext2_argv) != 0) {
return 1;
- printf("%s %s\n", bootm_argv[0], bootm_argv[1]);
- do_bootm(NULL, 0, 2, bootm_argv);
- return 1;
I ten to NACK this. You can do exactly the same with a U-Boot script, and if you want to have this as default, you can change your default environment. This is just a wrapper around the hush shell.
Best regards, Stefano Babic
Hi Stefano,
On Mon, Jun 20, 2016 at 05:46:52PM +0200, Stefano Babic wrote:
Hallo Andrej,
- "ext2load",
- "mmc",
- "0:1",
- "bootm",
return 1;
- return 1;
The intention of the patch is to boot the kernel while having the CLI disabled (CONFIG_CMDLINE=n). The U-Boot script needs the CLI to be enabled AFAIK.
It is better having the CLI disabled when using the Verified Boot, otherwise there are chances to bypass the FIT image verification (e.g. using md/mw commands in case are available):
https://github.com/inversepath/usbarmory/blob/master/software/secure_boot/u-...
Andrej
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
-- Andrej Rosano Inverse Path Srl andrej@inversepath.com http://www.inversepath.com
0x01939B21 5BB8 574E 68E8 D841 E18F D5E9 CEAD E0CF 0193 9B21
Hi Andrej,
Why is it not enough to disable the CONSOLE ? I mean, if there is no user interface (and this is done in a lot of ways, for example setting stdin / stdout), there is no ways to bypass it because the interface is not availabel. Or is there some other security issues I am not aware of ?
On 27 June 2016 at 03:38, Stefano Babic sbabic@denx.de wrote:
Hi Andrej,
It is an extra level of security - providing a very simple command execution instead of the general CLI. That is actually the original purpose of board_run_command(). E.g. for Chrome OS we had an option to either run the normal CLI or a simple (secure) one. Also see cli_process_fdt() which provides for a 'bootsecure' mode, controlled from the FDT.
Hi Simon,
Hi Andrej,
I see, thanks for explanation. My fear is that the process diverges and boards start to embed U-Boot scripts inside the code, letting them not very maintainable. But I have understood the issue and I put this patch for merging in my queue.
Andrej Rosano
Stefano Babic
