[U-Boot] [PATCH 0/8] NXP LS1021A-TSN Board
This patchset adds initial support for the NXP LS1021A-TSN board, an evaluation platform built in partnership with VVDN/Argonboards for some IEEE 802.1 TSN features.
It features a cleaned-up U-boot board support taken from OpenIL, as well as an eTSEC migration to DM_ETH. I picked up Bin Meng's patch that converts the LS1021A-TWR (different board, same SoC): https://lists.denx.de/pipermail/u-boot/2018-May/330096.html verified it on the LS1021A-TSN board I am submitting, and made a few adjustments where necessary.
TODO items: - Make the eTSEC driver support fixed-link interfaces (necessary for the enet2 <-> sja1105 internal port) - Add driver for SJA1105 switch - Potentially migrate the eTSEC MDIO bus driver to DM_MDIO and expose the TBI PHY to mdio commands (useful for debugging), once https://lists.denx.de/pipermail/u-boot/2019-June/371563.html is merged.
Bin Meng (1): arm: ls1021atwr: Convert to use driver model TSEC driver
Jianchao Wang (1): Add support for the NXP LS1021A-TSN board
Vladimir Oltean (6): net: tsec: Refactor the readout of the tbi-handle property net: tsec: Fix offset of MDIO registers for DM_ETH net: tsec: Reverse Christmas tree notation net: tsec: Make errors visible net: tsec: Common handling of MAC station address for DM_ETH configs: ls1021atwr: Fix distro_bootcmd for QSPI boot
arch/arm/Kconfig | 14 + arch/arm/cpu/armv7/ls102xa/cpu.c | 2 +- arch/arm/cpu/armv7/ls102xa/fdt.c | 10 + arch/arm/dts/Makefile | 2 +- arch/arm/dts/ls1021a-tsn.dts | 77 ++++ arch/arm/dts/ls1021a-twr.dtsi | 32 ++ arch/arm/dts/ls1021a.dtsi | 28 +- board/freescale/ls1021atsn/Kconfig | 18 + board/freescale/ls1021atsn/MAINTAINERS | 8 + board/freescale/ls1021atsn/Makefile | 3 + board/freescale/ls1021atsn/README.rst | 96 +++++ board/freescale/ls1021atsn/ls1021atsn.c | 291 +++++++++++++++ board/freescale/ls1021atsn/ls102xa_pbi.cfg | 15 + board/freescale/ls1021atsn/ls102xa_rcw_sd.cfg | 8 + board/freescale/ls1021atwr/ls1021atwr.c | 2 +- configs/ls1021atsn_qspi_defconfig | 76 ++++ configs/ls1021atsn_sdcard_defconfig | 85 +++++ configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + drivers/net/tsec.c | 57 ++- include/configs/ls1021atsn.h | 346 ++++++++++++++++++ include/configs/ls1021atwr.h | 6 +- include/tsec.h | 4 +- 23 files changed, 1143 insertions(+), 39 deletions(-) create mode 100644 arch/arm/dts/ls1021a-tsn.dts create mode 100644 board/freescale/ls1021atsn/Kconfig create mode 100644 board/freescale/ls1021atsn/MAINTAINERS create mode 100644 board/freescale/ls1021atsn/Makefile create mode 100644 board/freescale/ls1021atsn/README.rst create mode 100644 board/freescale/ls1021atsn/ls1021atsn.c create mode 100644 board/freescale/ls1021atsn/ls102xa_pbi.cfg create mode 100644 board/freescale/ls1021atsn/ls102xa_rcw_sd.cfg create mode 100644 configs/ls1021atsn_qspi_defconfig create mode 100644 configs/ls1021atsn_sdcard_defconfig create mode 100644 include/configs/ls1021atsn.h
The point of this patch is to eliminate the use of the locally-defined "reg" variable (which interferes with next patch) and simplify the fallback to the default CONFIG_SYS_TBIPA_VALUE in case "tbi-handle" is missing.
Signed-off-by: Vladimir Oltean olteanv@gmail.com --- drivers/net/tsec.c | 15 +++++++-------- 1 file changed, 7 insertions(+), 8 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 06a9b4fb03ce..53eb5470f4c8 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -798,6 +798,7 @@ int tsec_probe(struct udevice *dev) struct eth_pdata *pdata = dev_get_platdata(dev); struct fsl_pq_mdio_info mdio_info; struct ofnode_phandle_args phandle_args; + u32 tbiaddr = CONFIG_SYS_TBIPA_VALUE; ofnode parent; const char *phy_mode; int ret; @@ -825,14 +826,12 @@ int tsec_probe(struct udevice *dev) return -ENOENT; }
- if (dev_read_phandle_with_args(dev, "tbi-handle", NULL, 0, 0, - &phandle_args)) { - priv->tbiaddr = CONFIG_SYS_TBIPA_VALUE; - } else { - int reg = ofnode_read_u32_default(phandle_args.node, "reg", - CONFIG_SYS_TBIPA_VALUE); - priv->tbiaddr = reg; - } + ret = dev_read_phandle_with_args(dev, "tbi-handle", NULL, 0, 0, + &phandle_args); + if (ret == 0) + ofnode_read_u32(phandle_args.node, "reg", &tbiaddr); + + priv->tbiaddr = tbiaddr;
phy_mode = dev_read_prop(dev, "phy-connection-type", NULL); if (phy_mode)
By convention, the eTSEC MDIO controller nodes are defined in DT at 0x2d24000 and 0x2d50000, but actually U-boot does not touch the interrupt portion of the register map (MDIO_IEVENTM, MDIO_IMASKM, MDIO_EMAPM).
That leaves only the MDIO bus registers (MDIO_MIIMCFG, MDIO_MIIMCOM, MDIO_MIIMADD, MDIO_MIIMADD, MDIO_MIIMCON, MDIO_MIIMSTAT) which start at the 0x520 offset.
So shift the DT-defined register map by the offset of MDIO_MIIMCFG when mapping the MDIO bus registers.
Signed-off-by: Vladimir Oltean olteanv@gmail.com --- drivers/net/tsec.c | 13 +++++++------ include/tsec.h | 4 +++- 2 files changed, 10 insertions(+), 7 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 53eb5470f4c8..576398676af7 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -801,6 +801,7 @@ int tsec_probe(struct udevice *dev) u32 tbiaddr = CONFIG_SYS_TBIPA_VALUE; ofnode parent; const char *phy_mode; + fdt_addr_t reg; int ret;
pdata->iobase = (phys_addr_t)dev_read_addr(dev); @@ -817,15 +818,15 @@ int tsec_probe(struct udevice *dev) }
parent = ofnode_get_parent(phandle_args.node); - if (ofnode_valid(parent)) { - int reg = ofnode_get_addr_index(parent, 0); - - priv->phyregs_sgmii = (struct tsec_mii_mng *)reg; - } else { - debug("No parent node for PHY?\n"); + if (!ofnode_valid(parent)) { + printf("No parent node for PHY?\n"); return -ENOENT; }
+ reg = ofnode_get_addr_index(parent, 0); + priv->phyregs_sgmii = (struct tsec_mii_mng *) + (reg + TSEC_MDIO_REGS_OFFSET); + ret = dev_read_phandle_with_args(dev, "tbi-handle", NULL, 0, 0, &phandle_args); if (ret == 0) diff --git a/include/tsec.h b/include/tsec.h index e90095121bdd..b17fa957df5b 100644 --- a/include/tsec.h +++ b/include/tsec.h @@ -17,6 +17,8 @@ #include <config.h> #include <phy.h>
+#define TSEC_MDIO_REGS_OFFSET 0x520 + #ifndef CONFIG_DM_ETH
#ifdef CONFIG_ARCH_LS1021A @@ -27,7 +29,7 @@ #define TSEC_MDIO_OFFSET 0x01000 #endif
-#define CONFIG_SYS_MDIO_BASE_ADDR (MDIO_BASE_ADDR + 0x520) +#define CONFIG_SYS_MDIO_BASE_ADDR (MDIO_BASE_ADDR + TSEC_MDIO_REGS_OFFSET)
#define TSEC_GET_REGS(num, offset) \ (struct tsec __iomem *)\
Hi Vladimir,
nits: U-Boot, not U-boot
Could you please create a TSEC MDIO DM driver based on this series that Alex has done?
http://patchwork.ozlabs.org/project/uboot/list/?series=111504?
Regards, Bin
Hi Bin,
On Sat, 13 Jul 2019 at 07:55, Bin Meng bmeng.cn@gmail.com wrote:
Hi Vladimir,
Yes I actually said in the cover letter that I want to do that, but it has to get merged first :)
Regards, Bin
Thanks, -Vladimir
Hi Vladimir,
On Sat, Jul 13, 2019 at 5:44 PM Vladimir Oltean olteanv@gmail.com wrote:
Hi Bin,
Hi Vladimir,
That's good to know :)
Regards, Bin
fdt_addr_t reg; int ret; pdata->iobase = (phys_addr_t)dev_read_addr(dev);
} else {
I'm surprised not to see a .dts change in this patch as well or some other consumer of this phyregs_sgmii member.
#define TSEC_GET_REGS(num, offset) \ (struct tsec __iomem *)\ -- 2.17.1
Hi Joe,
} else {
This surprises me as well, to be honest. Actually Bin Meng's patchset to convert the TSEC driver to DM never got completely merged. I suppose the LS1021A-TWR conversion was sort of mechanical and probably not tested on hardware, otherwise I can't explain. There is no DT patch because this portion of the code never worked. The DM version of the TSEC driver had no (upstream?) users.
Thanks, -Vladimir
Hi Vladimir,
On Tue, Jul 16, 2019 at 6:00 AM Vladimir Oltean olteanv@gmail.com wrote:
Hi Joe,
} else {
Actually I did test the LS1021A-TWR TSEC DM conversion patch when I submitted it before. I vaguely remember the reason why it was not merged was because DM ETH depended on DM PCI conversion and at that time, DM PCI conversion on LS1021A was not ready.
Regards, Bin
Hi Bin,
On Tue, 16 Jul 2019 at 04:19, Bin Meng bmeng.cn@gmail.com wrote:
Hi Vladimir,
Hi Joe,
} else {
But did you actually test with traffic? There's no way this could have worked back then - with improper MDIO bus register mapping, it would have said "Waiting for PHY auto-negotiation to complete" ad infinitum.
Regards, Bin
Thanks, -Vladimir
Hi Vladimir,
On Tue, Jul 16, 2019 at 6:02 PM Vladimir Oltean olteanv@gmail.com wrote:
Hi Bin,
Hi Vladimir,
Hi Joe,
} else {
I really don't remember now. But I think I should have tested it before submitting any patches :)
Regards, Bin
This is a cosmetic patch that reorders variable definitions in the inverse order of their line length, where possible.
Signed-off-by: Vladimir Oltean olteanv@gmail.com --- drivers/net/tsec.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 576398676af7..ce19ff9228fd 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -259,8 +259,8 @@ static int tsec_send(struct udevice *dev, void *packet, int length) { struct tsec_private *priv = (struct tsec_private *)dev->priv; struct tsec __iomem *regs = priv->regs; - u16 status; int result = 0; + u16 status; int i;
/* Find an empty buffer descriptor */ @@ -708,9 +708,9 @@ static int init_phy(struct tsec_private *priv) */ static int tsec_initialize(bd_t *bis, struct tsec_info_struct *tsec_info) { + struct tsec_private *priv; struct eth_device *dev; int i; - struct tsec_private *priv;
dev = (struct eth_device *)malloc(sizeof(*dev));
@@ -794,14 +794,14 @@ int tsec_standard_init(bd_t *bis) #else /* CONFIG_DM_ETH */ int tsec_probe(struct udevice *dev) { - struct tsec_private *priv = dev_get_priv(dev); struct eth_pdata *pdata = dev_get_platdata(dev); - struct fsl_pq_mdio_info mdio_info; + struct tsec_private *priv = dev_get_priv(dev); struct ofnode_phandle_args phandle_args; u32 tbiaddr = CONFIG_SYS_TBIPA_VALUE; - ofnode parent; + struct fsl_pq_mdio_info mdio_info; const char *phy_mode; fdt_addr_t reg; + ofnode parent; int ret;
I've never heard of anyone optimizing for this before, but sure.
This replaces debug() calls with printf() so that it is immediately obvious from the console that something is wrong.
Signed-off-by: Vladimir Oltean olteanv@gmail.com --- drivers/net/tsec.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index ce19ff9228fd..1e20fe4cd246 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -268,7 +268,7 @@ static int tsec_send(struct udevice *dev, void *packet, int length) in_be16(&priv->txbd[priv->tx_idx].status) & TXBD_READY; i++) { if (i >= TOUT_LOOP) { - debug("%s: tsec: tx buffers full\n", dev->name); + printf("%s: tsec: tx buffers full\n", dev->name); return result; } } @@ -287,7 +287,7 @@ static int tsec_send(struct udevice *dev, void *packet, int length) in_be16(&priv->txbd[priv->tx_idx].status) & TXBD_READY; i++) { if (i >= TOUT_LOOP) { - debug("%s: tsec: tx error\n", dev->name); + printf("%s: tsec: tx error\n", dev->name); return result; } } @@ -809,7 +809,7 @@ int tsec_probe(struct udevice *dev)
if (dev_read_phandle_with_args(dev, "phy-handle", NULL, 0, 0, &phandle_args)) { - debug("phy-handle does not exist under tsec %s\n", dev->name); + printf("phy-handle does not exist under tsec %s\n", dev->name); return -ENOENT; } else { int reg = ofnode_read_u32_default(phandle_args.node, "reg", 0); @@ -838,7 +838,7 @@ int tsec_probe(struct udevice *dev) if (phy_mode) pdata->phy_interface = phy_get_interface_by_name(phy_mode); if (pdata->phy_interface == -1) { - debug("Invalid PHY interface '%s'\n", phy_mode); + printf("Invalid PHY interface '%s'\n", phy_mode); return -EINVAL; } priv->interface = pdata->phy_interface;
In tsec_init, the MAC address is retrieved from 2 different structures depending on whether DM_ETH is enabled or not.
But since the field name is the same inside both structures, we can conditionally define the structure of the correct type and simplify the assignments.
Signed-off-by: Vladimir Oltean olteanv@gmail.com --- drivers/net/tsec.c | 11 ++--------- 1 file changed, 2 insertions(+), 9 deletions(-)
diff --git a/drivers/net/tsec.c b/drivers/net/tsec.c index 1e20fe4cd246..f6278817330d 100644 --- a/drivers/net/tsec.c +++ b/drivers/net/tsec.c @@ -560,6 +560,8 @@ static int tsec_init(struct udevice *dev) struct tsec_private *priv = (struct tsec_private *)dev->priv; #ifdef CONFIG_DM_ETH struct eth_pdata *pdata = dev_get_platdata(dev); +#else + struct eth_device *pdata = dev; #endif struct tsec __iomem *regs = priv->regs; u32 tempval; @@ -580,21 +582,12 @@ static int tsec_init(struct udevice *dev) * order (BE), MACnADDR1 is set to 0xCDAB7856 and * MACnADDR2 is set to 0x34120000. */ -#ifndef CONFIG_DM_ETH - tempval = (dev->enetaddr[5] << 24) | (dev->enetaddr[4] << 16) | - (dev->enetaddr[3] << 8) | dev->enetaddr[2]; -#else tempval = (pdata->enetaddr[5] << 24) | (pdata->enetaddr[4] << 16) | (pdata->enetaddr[3] << 8) | pdata->enetaddr[2]; -#endif
out_be32(®s->macstnaddr1, tempval);
-#ifndef CONFIG_DM_ETH - tempval = (dev->enetaddr[1] << 24) | (dev->enetaddr[0] << 16); -#else tempval = (pdata->enetaddr[1] << 24) | (pdata->enetaddr[0] << 16); -#endif
out_be32(®s->macstnaddr2, tempval);
Now that we have added driver model support to the TSEC driver, convert ls1021atwr board to use it.
This depends on previous DM series for ls1021atwr: http://patchwork.ozlabs.org/patch/561855/
Signed-off-by: Bin Meng bmeng.cn@gmail.com
[Vladimir] Made the following changes: - Added 'status = "disabled";' for all Ethernet ports in ls1021a.dtsi - Fixed the confusion between the SGMII/TBI PCS for enet0 and enet1 - a mistake ported over from Linux. Each SGMII PCS lies on the private MDIO bus of the interface (and the RGMII enet2 has no SGMII PCS).
Signed-off-by: Vladimir Oltean olteanv@gmail.com --- arch/arm/cpu/armv7/ls102xa/cpu.c | 2 +- arch/arm/cpu/armv7/ls102xa/fdt.c | 10 ++++++++ arch/arm/dts/ls1021a-twr.dtsi | 32 +++++++++++++++++++++++++ arch/arm/dts/ls1021a.dtsi | 28 ++++++++++++++++++++-- board/freescale/ls1021atwr/ls1021atwr.c | 2 +- configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + include/configs/ls1021atwr.h | 4 ++++ 8 files changed, 76 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/cpu.c b/arch/arm/cpu/armv7/ls102xa/cpu.c index ecf9e869855e..9ccfe1042ce5 100644 --- a/arch/arm/cpu/armv7/ls102xa/cpu.c +++ b/arch/arm/cpu/armv7/ls102xa/cpu.c @@ -296,7 +296,7 @@ int cpu_mmc_init(bd_t *bis)
int cpu_eth_init(bd_t *bis) { -#ifdef CONFIG_TSEC_ENET +#if defined(CONFIG_TSEC_ENET) && !defined(CONFIG_DM_ETH) tsec_standard_init(bis); #endif
diff --git a/arch/arm/cpu/armv7/ls102xa/fdt.c b/arch/arm/cpu/armv7/ls102xa/fdt.c index 8bf9c42b2260..90cf7958f257 100644 --- a/arch/arm/cpu/armv7/ls102xa/fdt.c +++ b/arch/arm/cpu/armv7/ls102xa/fdt.c @@ -16,12 +16,17 @@ #include <tsec.h> #include <asm/arch/immap_ls102xa.h> #include <fsl_sec.h> +#include <dm.h>
DECLARE_GLOBAL_DATA_PTR;
void ft_fixup_enet_phy_connect_type(void *fdt) { +#ifndef CONFIG_DM_ETH struct eth_device *dev; +#else + struct udevice *dev; +#endif struct tsec_private *priv; const char *enet_path, *phy_path; char enet[16]; @@ -29,7 +34,12 @@ void ft_fixup_enet_phy_connect_type(void *fdt) int phy_node; int i = 0; uint32_t ph; +#ifndef CONFIG_DM_ETH char *name[3] = { "eTSEC1", "eTSEC2", "eTSEC3" }; +#else + char *name[3] = { "ethernet@2d10000", "ethernet@2d50000", + "ethernet@2d90000" }; +#endif
for (; i < ARRAY_SIZE(name); i++) { dev = eth_get_dev_by_name(name[i]); diff --git a/arch/arm/dts/ls1021a-twr.dtsi b/arch/arm/dts/ls1021a-twr.dtsi index 5d3275ced913..27c96f95400a 100644 --- a/arch/arm/dts/ls1021a-twr.dtsi +++ b/arch/arm/dts/ls1021a-twr.dtsi @@ -51,6 +51,26 @@ }; };
+&enet0 { + tbi-handle = <&tbi0>; + phy-handle = <&sgmii_phy2>; + phy-connection-type = "sgmii"; + status = "okay"; +}; + +&enet1 { + tbi-handle = <&tbi1>; + phy-handle = <&sgmii_phy0>; + phy-connection-type = "sgmii"; + status = "okay"; +}; + +&enet2 { + phy-handle = <&rgmii_phy1>; + phy-connection-type = "rgmii-id"; + status = "okay"; +}; + &i2c0 { status = "okay"; }; @@ -84,12 +104,24 @@ sgmii_phy0: ethernet-phy@0 { reg = <0x0>; }; + rgmii_phy1: ethernet-phy@1 { reg = <0x1>; }; + sgmii_phy2: ethernet-phy@2 { reg = <0x2>; }; + + /* SGMII PCS for enet0 */ + tbi0: tbi-phy@1f { + reg = <0x1f>; + device_type = "tbi-phy"; + }; +}; + +&mdio1 { + /* SGMII PCS for enet1 */ tbi1: tbi-phy@1f { reg = <0x1f>; device_type = "tbi-phy"; diff --git a/arch/arm/dts/ls1021a.dtsi b/arch/arm/dts/ls1021a.dtsi index 8a0f473e25ca..c274a302d358 100644 --- a/arch/arm/dts/ls1021a.dtsi +++ b/arch/arm/dts/ls1021a.dtsi @@ -350,14 +350,38 @@ <&platform_clk 1>; };
+ enet0: ethernet@2d10000 { + compatible = "fsl,tsec"; + reg = <0x2d10000 0x1000>; + status = "disabled"; + }; + + enet1: ethernet@2d50000 { + compatible = "fsl,tsec"; + reg = <0x2d50000 0x1000>; + status = "disabled"; + }; + + enet2: ethernet@2d90000 { + compatible = "fsl,tsec"; + reg = <0x2d90000 0x1000>; + status = "disabled"; + }; + mdio0: mdio@2d24000 { - compatible = "gianfar"; - device_type = "mdio"; + compatible = "fsl,tsec-mdio"; #address-cells = <1>; #size-cells = <0>; reg = <0x2d24000 0x4000>; };
+ mdio1: mdio@2d64000 { + compatible = "fsl,tsec-mdio"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x2d64000 0x4000>; + }; + usb@8600000 { compatible = "fsl-usb2-dr-v2.5", "fsl-usb2-dr"; reg = <0x8600000 0x1000>; diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 01ba1bc96213..a4ff0b7bc7eb 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -248,7 +248,7 @@ int board_mmc_init(bd_t *bis)
int board_eth_init(bd_t *bis) { -#ifdef CONFIG_TSEC_ENET +#if defined(CONFIG_TSEC_ENET) && !defined(CONFIG_DM_ETH) struct fsl_pq_mdio_info mdio_info; struct tsec_info_struct tsec_info[4]; int num = 0; diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index 9d8c2024c04e..3c9cf9a8c909 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -40,6 +40,7 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_DM_ETH=y CONFIG_TSEC_ENET=y CONFIG_PCI=y CONFIG_DM_PCI=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index b9cfdb6fd69e..762af87b0dd3 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -42,6 +42,7 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y +CONFIG_DM_ETH=y CONFIG_TSEC_ENET=y CONFIG_PCI=y CONFIG_DM_PCI=y diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index de0c9c7f26af..c967be3a6fce 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -260,6 +260,7 @@ */
#ifdef CONFIG_TSEC_ENET +#ifndef CONFIG_DM_ETH #define CONFIG_MII_DEFAULT_TSEC 1 #define CONFIG_TSEC1 1 #define CONFIG_TSEC1_NAME "eTSEC1" @@ -287,6 +288,9 @@ #define CONFIG_HAS_ETH0 #define CONFIG_HAS_ETH1 #define CONFIG_HAS_ETH2 +#else +#define CONFIG_ETHPRIME "ethernet@2d10000" +#endif #endif
/* PCIe */
Generally looks good, but a few nits below...
Please use positive logic where convenient. I.e. #ifdef CONFIG_DM_ETH and swap cases.
+#else
Use positive logic.
+#else
+&enet0 {
status = "okay";
+&enet1 {
status = "okay";
+&enet2 {
status = "okay";
tbi0: tbi-phy@1f {
reg = <0x1f>;
+&mdio1 {
#size-cells = <0>;
Use positive logic
/* PCIe */
2.17.1
Hi Joe,
To be honest I don't know why keep compatibility with non-DM ETH at all for the TWR board. On the LS1021A-TSN I'm not doing that. Bin, is there any particular reason? If not, I'll just completely remove your #ifdef's for v2.
+#else
Use positive logic.
+#else
+&enet0 {
status = "okay";
+&enet1 {
status = "okay";
+&enet2 {
status = "okay";
tbi0: tbi-phy@1f {
reg = <0x1f>;
+&mdio1 {
#size-cells = <0>;
Use positive logic
/* PCIe */
2.17.1
Thanks, -Vladimir
Hi Vladimir,
On Sat, Jul 13, 2019 at 5:39 PM Vladimir Oltean olteanv@gmail.com wrote:
Hi Joe,
I remember at that time there were some PowerPC 83xx/85xx boards that were not converted to DM but still used TSEC driver. If this is not a concern now, I am all for it to remove the non-DM TSEC support.
Regards, Bin
On Sun, 14 Jul 2019 at 04:55, Bin Meng bmeng.cn@gmail.com wrote:
Hi Vladimir,
Hi Joe,
For the TSEC driver code, sure, there are still non-DM users out there and we're still keeping them for now. I was talking about the board code for LS1021A-TWR when I replied to Joe.
Regards, Bin
Thanks, -Vladimir
Hi Vladimir,
Hi Joe,
For LS1021A-TWR board codes, I agree there is no need to keep non-DM stuff.
Regards, Bin
Due to a typo, "run qspi_bootcmd" and "env exists secureboot" got concatenated instead of being separated by a semicolon.
Signed-off-by: Vladimir Oltean olteanv@gmail.com --- include/configs/ls1021atwr.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index c967be3a6fce..5dbbf158c6b1 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -448,7 +448,7 @@
#undef CONFIG_BOOTCOMMAND #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) -#define CONFIG_BOOTCOMMAND "run distro_bootcmd; run qspi_bootcmd" \ +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; run qspi_bootcmd; " \ "env exists secureboot && esbc_halt" #elif defined(CONFIG_SD_BOOT) #define CONFIG_BOOTCOMMAND "run distro_bootcmd; run sd_bootcmd; " \
The LS1021A-TSN is a development board built by VVDN/Argonboards in partnership with NXP.
It features the LS1021A SoC and the first-generation SJA1105T Ethernet switch for prototyping implementations of a subset of IEEE 802.1 TSN standards.
Supported boot media: microSD card (via SPL), QSPI flash.
Rev. A of the board uses a Spansion S25FL512S_256K serial flash, which is 64 MB in size and has an erase sector size of 256KB (therefore, flashing the RCW would erase part of U-boot).
Rev. B and C of the board use a Spansion S25FL256S1 serial flash, which is only 32 MB in size but has an erase sector size of 64KB (therefore the RCW image can be flashed without erasing U-boot).
To avoid the problems above, the U-boot base address has been selected at 0x100000 (the start of the 5th 256KB erase sector), which works for all board revisions. Actually 0x40000 would have been enough, but 0x100000 is common for all Layerscape devices.
eTSEC3 is connecting directly to SJA1105 via an RGMII fixed-link, but SJA1105 is currently not supported by uboot. Therefore, eTSEC3 is disabled.
Signed-off-by: Xiaoliang Yang xiaoliang.yang@nxp.com Signed-off-by: Mingkai Hu mingkai.hu@nxp.com Signed-off-by: Jianchao Wang jianchao.wang@nxp.com Signed-off-by: Changming Huang jerry.huang@nxp.com
[Vladimir] Code taken from https://github.com/openil/u-boot (which itself is mostly copied from ls1021a-iot) and adapted with the following changes:
- Add a008850 errata workaround - Converted eTSEC, MMC to DM to avoid all build warnings - Plugged in distro boot feature, including support for extlinux.conf - Added defconfig for QSPI boot - Added the board/freescale/ls1021atsn/README.rst for initial setup
Signed-off-by: Vladimir Oltean olteanv@gmail.com --- arch/arm/Kconfig | 14 + arch/arm/dts/Makefile | 2 +- arch/arm/dts/ls1021a-tsn.dts | 77 ++++ board/freescale/ls1021atsn/Kconfig | 18 + board/freescale/ls1021atsn/MAINTAINERS | 8 + board/freescale/ls1021atsn/Makefile | 3 + board/freescale/ls1021atsn/README.rst | 96 +++++ board/freescale/ls1021atsn/ls1021atsn.c | 291 +++++++++++++++ board/freescale/ls1021atsn/ls102xa_pbi.cfg | 15 + board/freescale/ls1021atsn/ls102xa_rcw_sd.cfg | 8 + configs/ls1021atsn_qspi_defconfig | 76 ++++ configs/ls1021atsn_sdcard_defconfig | 85 +++++ include/configs/ls1021atsn.h | 346 ++++++++++++++++++ 13 files changed, 1038 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/ls1021a-tsn.dts create mode 100644 board/freescale/ls1021atsn/Kconfig create mode 100644 board/freescale/ls1021atsn/MAINTAINERS create mode 100644 board/freescale/ls1021atsn/Makefile create mode 100644 board/freescale/ls1021atsn/README.rst create mode 100644 board/freescale/ls1021atsn/ls1021atsn.c create mode 100644 board/freescale/ls1021atsn/ls102xa_pbi.cfg create mode 100644 board/freescale/ls1021atsn/ls102xa_rcw_sd.cfg create mode 100644 configs/ls1021atsn_qspi_defconfig create mode 100644 configs/ls1021atsn_sdcard_defconfig create mode 100644 include/configs/ls1021atsn.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 01ff57cf1bec..5edac7ea2bd5 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1327,6 +1327,19 @@ config TARGET_LS1021ATWR select SUPPORT_SPL imply SCSI
+config TARGET_LS1021ATSN + bool "Support ls1021atsn" + select ARCH_LS1021A + select ARCH_SUPPORT_PSCI + select BOARD_EARLY_INIT_F + select BOARD_LATE_INIT + select CPU_V7A + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT + select LS1_DEEP_SLEEP + select SUPPORT_SPL + imply SCSI + config TARGET_LS1021AIOT bool "Support ls1021aiot" select ARCH_LS1021A @@ -1693,6 +1706,7 @@ source "board/freescale/ls1028a/Kconfig" source "board/freescale/ls1021aqds/Kconfig" source "board/freescale/ls1043aqds/Kconfig" source "board/freescale/ls1021atwr/Kconfig" +source "board/freescale/ls1021atsn/Kconfig" source "board/freescale/ls1021aiot/Kconfig" source "board/freescale/ls1046aqds/Kconfig" source "board/freescale/ls1043ardb/Kconfig" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 528fb909d5b0..28590b0c5530 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -325,7 +325,7 @@ dtb-$(CONFIG_TARGET_STV0991) += stv0991.dtb dtb-$(CONFIG_ARCH_LS1021A) += ls1021a-qds-duart.dtb \ ls1021a-qds-lpuart.dtb \ ls1021a-twr-duart.dtb ls1021a-twr-lpuart.dtb \ - ls1021a-iot-duart.dtb + ls1021a-iot-duart.dtb ls1021a-tsn.dtb dtb-$(CONFIG_FSL_LSCH3) += fsl-ls2080a-qds.dtb \ fsl-ls2080a-rdb.dtb \ fsl-ls2081a-rdb.dtb \ diff --git a/arch/arm/dts/ls1021a-tsn.dts b/arch/arm/dts/ls1021a-tsn.dts new file mode 100644 index 000000000000..f633074099dc --- /dev/null +++ b/arch/arm/dts/ls1021a-tsn.dts @@ -0,0 +1,77 @@ +// SPDX-License-Identifier: GPL-2.0 +/* Copyright 2016-2018 NXP Semiconductors + * Copyright 2019 Vladimir Oltean olteanv@gmail.com + */ + +/dts-v1/; +#include "ls1021a.dtsi" + +/ { + model = "NXP LS1021A-TSN Board"; + + aliases { + enet0-sgmii-phy = &sgmii_phy2; + enet1-sgmii-phy = &sgmii_phy1; + spi0 = &qspi; + spi1 = &dspi1; + }; +}; + +&enet0 { + tbi-handle = <&tbi0>; + phy-handle = <&sgmii_phy2>; + phy-mode = "sgmii"; + status = "okay"; +}; + +&enet1 { + tbi-handle = <&tbi1>; + phy-handle = <&sgmii_phy1>; + phy-mode = "sgmii"; + status = "okay"; +}; + +&i2c0 { + status = "okay"; +}; + +&mdio0 { + /* AR8031 */ + sgmii_phy1: ethernet-phy@1 { + reg = <0x1>; + }; + + /* AR8031 */ + sgmii_phy2: ethernet-phy@2 { + reg = <0x2>; + }; + + /* SGMII PCS for enet0 */ + tbi0: tbi-phy@1f { + reg = <0x1f>; + device_type = "tbi-phy"; + }; +}; + +&mdio1 { + /* SGMII PCS for enet1 */ + tbi1: tbi-phy@1f { + reg = <0x1f>; + device_type = "tbi-phy"; + }; +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + flash@0 { + compatible = "spi-flash"; + spi-max-frequency = <20000000>; + reg = <0>; + }; +}; + +&uart0 { + status = "okay"; +}; diff --git a/board/freescale/ls1021atsn/Kconfig b/board/freescale/ls1021atsn/Kconfig new file mode 100644 index 000000000000..d999fa469002 --- /dev/null +++ b/board/freescale/ls1021atsn/Kconfig @@ -0,0 +1,18 @@ +# SPDX-License-Identifier: GPL-2.0 +if TARGET_LS1021ATSN + +config SYS_BOARD + default "ls1021atsn" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "ls102xa" + +config SYS_CONFIG_NAME + default "ls1021atsn" + +source "board/freescale/common/Kconfig" + +endif diff --git a/board/freescale/ls1021atsn/MAINTAINERS b/board/freescale/ls1021atsn/MAINTAINERS new file mode 100644 index 000000000000..560bb615d2fe --- /dev/null +++ b/board/freescale/ls1021atsn/MAINTAINERS @@ -0,0 +1,8 @@ +NXP LS1021A-TSN Board +M: Vladimir Oltean olteanv@gmail.com +S: Maintained +F: arch/arm/dts/ls1021a-tsn.dts +F: board/freescale/ls1021atsn/ +F: include/configs/ls1021atsn.h +F: configs/ls1021atsn_qspi_defconfig +F: configs/ls1021atsn_sdcard_defconfig diff --git a/board/freescale/ls1021atsn/Makefile b/board/freescale/ls1021atsn/Makefile new file mode 100644 index 000000000000..b4808f05e8e0 --- /dev/null +++ b/board/freescale/ls1021atsn/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 +obj-y += ls1021atsn.o +obj-$(CONFIG_ARMV7_PSCI) += ../ls1021atwr/psci.o diff --git a/board/freescale/ls1021atsn/README.rst b/board/freescale/ls1021atsn/README.rst new file mode 100644 index 000000000000..e986f460c4d4 --- /dev/null +++ b/board/freescale/ls1021atsn/README.rst @@ -0,0 +1,96 @@ +.. SPDX-License-Identifier: GPL-2.0 + +LS1021A-TSN Board Overview +========================== + + - 1GB DDR3 at 800 MHz + - Spansion/Cypress 64 MB (Rev. A) / 32 MB (Rev. B and C) QSPI NOR flash + - Ethernet + - 2 SGMII 10/100/1G Ethernet ports (Atheros AR8031) + - One SJA1105T switch with 4 Ethernet ports (Broadcom BCM5464R) + - One internal RGMII port connected to the switch + - SDHC + - microSDHC/SDXC connector + - Other I/O + - One Serial port + - Arduino and expansion headers + - mPCIE slot + - SATA port + - USB3.0 port + +LS1021A Memory map +================== + +The addresses in brackets are physical addresses. + +============== ============== ============================== ======= +Start Address End Address Description Size +============== ============== ============================== ======= +0x00_0000_0000 0x00_000F_FFFF Secure Boot ROM 1MB +0x00_0100_0000 0x00_0FFF_FFFF CCSRBAR 240MB +0x00_1000_0000 0x00_1000_FFFF OCRAM0 64KB +0x00_1001_0000 0x00_1001_FFFF OCRAM1 64KB +0x00_2000_0000 0x00_20FF_FFFF DCSR 16MB +0x00_4000_0000 0x00_5FFF_FFFF QSPI 512MB +0x00_6000_0000 0x00_67FF_FFFF IFC - NOR Flash 128MB +0x00_8000_0000 0x00_FFFF_FFFF DRAM1 2GB +============== ============== ============================== ======= + +Compiling and flashing +====================== + +The LS1021A-TSN board comes along with a microSD card with OpenIL U-boot. +That will be used to update the internal QSPI flash, as well as + +To compile and flash an SD card image:: + + make ls1021atsn_sdcard_defconfig && make -j 8 && sudo cp u-boot-with-spl-pbl.bin /srv/tftpboot/ + => tftp 0x82000000 u-boot-with-spl-pbl.bin && mmc rescan && mmc erase 8 0x1100 && mmc write 0x82000000 8 0x1100 + +For the QSPI flash, first obtain the Reset Configuration Word binary for +bootimg from the QSPI flash from the rcw project +(https://source.codeaurora.org/external/qoriq/qoriq-components/rcw):: + + make -j 8 && sudo cp ls1021atsn/SSR_PNS_30/rcw_1200_qspiboot.bin.swapped /srv/tftpboot/ + +The above RCW binary takes care of swapping the QSPI AMBA memory, so that the +U-boot binary does not need to be swapped when flashing it. + +To compile and flash a U-boot image for QSPI:: + + make ls1021atsn_qspi_defconfig && make -j 8 && sudo cp u-boot.bin /srv/tftpboot/ + +Then optionally create a custom uboot-env.txt file (although the default +environment already supports distro boot) and convert it to binary format:: + + mkenvimage -s 2M -o /srv/tftpboot/uboot-env.bin uboot-env.txt + +To program the QSPI flash with the images:: + + => tftp 0x82000000 rcw_1000_qspiboot.bin.swapped && sf probe && sf erase 0x0 +${filesize} && sf write 0x82000000 0x0 ${filesize} + => tftp 0x82000000 u-boot.bin && sf probe && sf erase 0x100000 +${filesize} && sf write 0x82000000 0x100000 ${filesize} + => tftp 0x82000000 uboot-env.bin && sf probe && sf erase 0x400000 +${filesize} && sf write 0x82000000 0x400000 ${filesize} + +The boards contain an AT24 I2C EEPROM that is supposed to hold the MAC +addresses of the Ethernet interfaces, however the EEPROM comes blank out of +the factory, and the MAC addresses are printed on a label on the bottom of +the boards. + +To write the MAC addresses to the EEPROM, the following needs to be done once:: + + => mac id + => mac 0 00:1F:7B:xx:xx:xx + => mac 1 00:1F:7B:xx:xx:xx + => mac 2 00:1F:7B:xx:xx:xx + => mac save + +The switch ports do not have their own MAC address - they inherit it from the +master enet2 port. + +Known issues and limitations +============================ + +- The 4 SJA1105 switch ports are not functional in U-boot for now. +- Since the IFC pins are multiplexed with QSPI on LS1021A, currently there is + no way to talk to the CPLD for e.g. running the "qixis_reset" command, or + turning the fan on, etc. diff --git a/board/freescale/ls1021atsn/ls1021atsn.c b/board/freescale/ls1021atsn/ls1021atsn.c new file mode 100644 index 000000000000..84c2af142956 --- /dev/null +++ b/board/freescale/ls1021atsn/ls1021atsn.c @@ -0,0 +1,291 @@ +// SPDX-License-Identifier: GPL-2.0 +/* Copyright 2016-2019 NXP Semiconductors + */ +#include <common.h> +#include <i2c.h> +#include <asm/io.h> +#include <asm/arch/immap_ls102xa.h> +#include <asm/arch/clock.h> +#include <asm/arch/fsl_serdes.h> +#include <asm/arch-ls102xa/ls102xa_soc.h> +#include <asm/arch/ls102xa_devdis.h> +#include <asm/arch/ls102xa_soc.h> +#include <hwconfig.h> +#include <mmc.h> +#include <fsl_csu.h> +#include <fsl_esdhc.h> +#include <fsl_ifc.h> +#include <fsl_immap.h> +#include <netdev.h> +#include <spl.h> +#include "../common/sleep.h" +#ifdef CONFIG_U_QE +#include <fsl_qe.h> +#endif +#include <fsl_validate.h> + +DECLARE_GLOBAL_DATA_PTR; + +void cpld_show(void) +{ + struct ccsr_gur *dcfg = (struct ccsr_gur *)CONFIG_SYS_FSL_GUTS_ADDR; + u32 cpldrev; + int major; + int minor; + + cpldrev = in_be32(&dcfg->gpporcr1); + major = (cpldrev >> 28) & 0xf; + minor = (cpldrev >> 24) & 0xf; + + printf("CPLD: V%d.%d\n", major, minor); +} + +int checkboard(void) +{ + puts("Board: LS1021ATSN\n"); + cpld_show(); + return 0; +} + +void ddrmc_init(void) +{ + struct ccsr_ddr *ddr = (struct ccsr_ddr *)CONFIG_SYS_FSL_DDR_ADDR; + u32 temp_sdram_cfg, tmp; + + out_be32(&ddr->sdram_cfg, DDR_SDRAM_CFG); + + out_be32(&ddr->cs0_bnds, DDR_CS0_BNDS); + out_be32(&ddr->cs0_config, DDR_CS0_CONFIG); + + out_be32(&ddr->timing_cfg_0, DDR_TIMING_CFG_0); + out_be32(&ddr->timing_cfg_1, DDR_TIMING_CFG_1); + out_be32(&ddr->timing_cfg_2, DDR_TIMING_CFG_2); + out_be32(&ddr->timing_cfg_3, DDR_TIMING_CFG_3); + out_be32(&ddr->timing_cfg_4, DDR_TIMING_CFG_4); + out_be32(&ddr->timing_cfg_5, DDR_TIMING_CFG_5); + +#ifdef CONFIG_DEEP_SLEEP + if (is_warm_boot()) { + out_be32(&ddr->sdram_cfg_2, + DDR_SDRAM_CFG_2 & ~SDRAM_CFG2_D_INIT); + out_be32(&ddr->init_addr, CONFIG_SYS_SDRAM_BASE); + out_be32(&ddr->init_ext_addr, (1 << 31)); + + /* DRAM VRef will not be trained */ + out_be32(&ddr->ddr_cdr2, + DDR_DDR_CDR2 & ~DDR_CDR2_VREF_TRAIN_EN); + } else +#endif + { + out_be32(&ddr->sdram_cfg_2, DDR_SDRAM_CFG_2); + out_be32(&ddr->ddr_cdr2, DDR_DDR_CDR2); + } + + out_be32(&ddr->sdram_mode, DDR_SDRAM_MODE); + out_be32(&ddr->sdram_mode_2, DDR_SDRAM_MODE_2); + + out_be32(&ddr->sdram_interval, DDR_SDRAM_INTERVAL); + + out_be32(&ddr->ddr_wrlvl_cntl, DDR_DDR_WRLVL_CNTL); + + out_be32(&ddr->ddr_wrlvl_cntl_2, DDR_DDR_WRLVL_CNTL_2); + out_be32(&ddr->ddr_wrlvl_cntl_3, DDR_DDR_WRLVL_CNTL_3); + + out_be32(&ddr->ddr_cdr1, DDR_DDR_CDR1); + + out_be32(&ddr->sdram_clk_cntl, DDR_SDRAM_CLK_CNTL); + out_be32(&ddr->ddr_zq_cntl, DDR_DDR_ZQ_CNTL); + + out_be32(&ddr->cs0_config_2, DDR_CS0_CONFIG_2); + + /* DDR erratum A-009942 */ + tmp = in_be32(&ddr->debug[28]); + out_be32(&ddr->debug[28], tmp | 0x0070006f); + + udelay(1); + +#ifdef CONFIG_DEEP_SLEEP + if (is_warm_boot()) { + /* enter self-refresh */ + temp_sdram_cfg = in_be32(&ddr->sdram_cfg_2); + temp_sdram_cfg |= SDRAM_CFG2_FRC_SR; + out_be32(&ddr->sdram_cfg_2, temp_sdram_cfg); + + temp_sdram_cfg = (DDR_SDRAM_CFG_MEM_EN | SDRAM_CFG_BI); + } else +#endif + temp_sdram_cfg = (DDR_SDRAM_CFG_MEM_EN & ~SDRAM_CFG_BI); + + out_be32(&ddr->sdram_cfg, DDR_SDRAM_CFG | temp_sdram_cfg); + +#ifdef CONFIG_DEEP_SLEEP + if (is_warm_boot()) { + /* exit self-refresh */ + temp_sdram_cfg = in_be32(&ddr->sdram_cfg_2); + temp_sdram_cfg &= ~SDRAM_CFG2_FRC_SR; + out_be32(&ddr->sdram_cfg_2, temp_sdram_cfg); + } +#endif +} + +int dram_init(void) +{ +#if (!defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD)) + ddrmc_init(); +#endif + + erratum_a008850_post(); + + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, PHYS_SDRAM_SIZE); + +#if defined(CONFIG_DEEP_SLEEP) && !defined(CONFIG_SPL_BUILD) + fsl_dp_resume(); +#endif + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + return pci_eth_init(bis); +} + +int board_early_init_f(void) +{ + struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR; + +#ifdef CONFIG_TSEC_ENET + /* Clear BD & FR bits for big endian BD's and frame data (aka set + * correct eTSEC endianness). This is crucial in ensuring that it does + * not report Data Parity Errors in its RX/TX FIFOs when attempting to + * send traffic. + */ + clrbits_be32(&scfg->etsecdmamcr, SCFG_ETSECDMAMCR_LE_BD_FR); + /* EC3_GTX_CLK125 (of enet2) used for all RGMII interfaces */ + out_be32(&scfg->etsecmcr, SCFG_ETSECCMCR_GE2_CLK125); +#endif + +#ifdef CONFIG_FSL_IFC + init_early_memctl_regs(); +#endif + + arch_soc_init(); + +#if defined(CONFIG_DEEP_SLEEP) + if (is_warm_boot()) { + timer_init(); + dram_init(); + } +#endif + + return 0; +} + +#ifdef CONFIG_SPL_BUILD +void board_init_f(ulong dummy) +{ + void (*second_uboot)(void); + + /* Clear the BSS */ + memset(__bss_start, 0, __bss_end - __bss_start); + + get_clocks(); + +#if defined(CONFIG_DEEP_SLEEP) + if (is_warm_boot()) + fsl_dp_disable_console(); +#endif + + preloader_console_init(); + + dram_init(); + + /* Allow OCRAM access permission as R/W */ +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); + enable_layerscape_ns_access(); +#endif + + /* + * if it is woken up from deep sleep, then jump to second + * stage uboot and continue executing without recopying + * it from SD since it has already been reserved in memory + * in last boot. + */ + if (is_warm_boot()) { + second_uboot = (void (*)(void))CONFIG_SYS_TEXT_BASE; + second_uboot(); + } + + board_init_r(NULL, 0); +} +#endif + +int board_init(void) +{ +#ifndef CONFIG_SYS_FSL_NO_SERDES + fsl_serdes_init(); +#endif + ls102xa_smmu_stream_id_init(); + +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); +#endif + +#ifdef CONFIG_U_QE + u_qe_init(); +#endif + + return 0; +} + +#if defined(CONFIG_SPL_BUILD) +void spl_board_init(void) +{ + ls102xa_smmu_stream_id_init(); +} +#endif + +#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ +#ifdef CONFIG_CHAIN_OF_TRUST + fsl_setenv_chain_of_trust(); +#endif + + return 0; +} +#endif + +#if defined(CONFIG_MISC_INIT_R) +int misc_init_r(void) +{ +#ifdef CONFIG_FSL_DEVICE_DISABLE + device_disable(devdis_tbl, ARRAY_SIZE(devdis_tbl)); +#endif + +#ifdef CONFIG_FSL_CAAM + return sec_init(); +#endif +} +#endif + +#if defined(CONFIG_DEEP_SLEEP) +void board_sleep_prepare(void) +{ +#ifdef CONFIG_LAYERSCAPE_NS_ACCESS + enable_layerscape_ns_access(); +#endif +} +#endif + +int ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); + +#ifdef CONFIG_PCI + ft_pci_setup(blob, bd); +#endif + + return 0; +} diff --git a/board/freescale/ls1021atsn/ls102xa_pbi.cfg b/board/freescale/ls1021atsn/ls102xa_pbi.cfg new file mode 100644 index 000000000000..a8ba184c6684 --- /dev/null +++ b/board/freescale/ls1021atsn/ls102xa_pbi.cfg @@ -0,0 +1,15 @@ +#PBI commands + +09570200 ffffffff +09570158 00000300 +8940007c 21f47300 + +# Configure Scratch register +09ee0200 10000000 +# Configure alternate space +09570158 00001000 +# Flush PBL data +096100c0 000FFFFF + +09ea085c 00502880 +09ea0560 80800000 diff --git a/board/freescale/ls1021atsn/ls102xa_rcw_sd.cfg b/board/freescale/ls1021atsn/ls102xa_rcw_sd.cfg new file mode 100644 index 000000000000..67152dd2810e --- /dev/null +++ b/board/freescale/ls1021atsn/ls102xa_rcw_sd.cfg @@ -0,0 +1,8 @@ +# PBL preamble and RCW header +aa55aa55 01ee0100 + +# Disable IFC, enable QSPI and DSPI +0608000c 00000000 00000000 00000000 +30000000 08007900 60040a00 21046000 +00000000 00000000 00000000 20002000 +20024800 8804b340 00000000 00000000 diff --git a/configs/ls1021atsn_qspi_defconfig b/configs/ls1021atsn_qspi_defconfig new file mode 100644 index 000000000000..427881fe0c52 --- /dev/null +++ b/configs/ls1021atsn_qspi_defconfig @@ -0,0 +1,76 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1021ATSN=y +CONFIG_SYS_TEXT_BASE=0x40100000 +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-tsn" +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SYS_FSL_CLK=y +CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_FAT=y +CONFIG_FSL_ESDHC=y +CONFIG_CMD_SF=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_DM=y +CONFIG_FSL_CAAM=y +CONFIG_SPI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_NETDEVICES=y +CONFIG_DM_ETH=y +CONFIG_TSEC_ENET=y +CONFIG_MII=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_DATAFLASH=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y +CONFIG_PCI=y +CONFIG_CMD_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_CMD_MMC=y +CONFIG_DM_MMC=y +CONFIG_FSL_SPI_ALIGNED_TXFIFO=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_CMD_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_FSL=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_HAS_FSL_XHCI_USB=y +CONFIG_USB_STORAGE=y +CONFIG_CMD_EXT2=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_PHYLIB=y +CONFIG_PHY_GIGE=y +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_BROADCOM=y +CONFIG_PHY_FIXED=y +CONFIG_CMD_PING=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMDLINE_TAG=y +CONFIG_CMDLINE_EDITING=y +CONFIG_AUTO_COMPLETE=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_CMD_BOOTZ=y +CONFIG_SYS_LONGHELP=y +CONFIG_FIT=y +CONFIG_CMD_DM=y +CONFIG_AHCI=y +CONFIG_CMD_I2C=y +CONFIG_BLK=y +CONFIG_CMD_PART=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_FS_UUID=y +CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig new file mode 100644 index 000000000000..b74e01206817 --- /dev/null +++ b/configs/ls1021atsn_sdcard_defconfig @@ -0,0 +1,85 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1021ATSN=y +CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_SYS_TEXT_BASE=0x82000000 +CONFIG_DEFAULT_DEVICE_TREE="ls1021a-tsn" +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL=y +CONFIG_SPL_FRAMEWORK=y +CONFIG_SYS_FSL_CLK=y +CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" +CONFIG_SD_BOOT=y +CONFIG_BOOTDELAY=3 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0xe8 +CONFIG_HUSH_PARSER=y +CONFIG_CMD_GREPENV=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_FAT=y +CONFIG_CMD_MMC=y +CONFIG_FSL_ESDHC=y +CONFIG_CMD_SF=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_DM=y +CONFIG_FSL_CAAM=y +CONFIG_SPI=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_NETDEVICES=y +CONFIG_DM_ETH=y +CONFIG_TSEC_ENET=y +CONFIG_MII=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_DATAFLASH=y +CONFIG_FSL_DSPI=y +CONFIG_FSL_QSPI=y +CONFIG_PCI=y +CONFIG_CMD_PCI=y +CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_CMD_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_FSL=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_HAS_FSL_XHCI_USB=y +CONFIG_USB_STORAGE=y +CONFIG_CMD_EXT2=y +CONFIG_PCIE_LAYERSCAPE=y +CONFIG_PHYLIB=y +CONFIG_PHY_GIGE=y +CONFIG_PHY_ATHEROS=y +CONFIG_PHY_BROADCOM=y +CONFIG_PHY_FIXED=y +CONFIG_CMD_PING=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMDLINE_TAG=y +CONFIG_CMDLINE_EDITING=y +CONFIG_AUTO_COMPLETE=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_CMD_BOOTZ=y +CONFIG_SYS_LONGHELP=y +CONFIG_FIT=y +CONFIG_SPL_MMC_SUPPORT=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_I2C_SUPPORT=y +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_CMD_DM=y +CONFIG_AHCI=y +CONFIG_CMD_I2C=y +CONFIG_BLK=y +CONFIG_DM_MMC=y +CONFIG_CMD_PART=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_FS_UUID=y +CONFIG_DISTRO_DEFAULTS=y diff --git a/include/configs/ls1021atsn.h b/include/configs/ls1021atsn.h new file mode 100644 index 000000000000..c8ec414afd39 --- /dev/null +++ b/include/configs/ls1021atsn.h @@ -0,0 +1,346 @@ +/* SPDX-License-Identifier: GPL-2.0 + * Copyright 2016-2018 NXP Semiconductors + * Copyright 2019 Vladimir Oltean olteanv@gmail.com + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_ARMV7_SECURE_BASE OCRAM_BASE_S_ADDR + +#define CONFIG_SYS_FSL_CLK + +#define CONFIG_DEEP_SLEEP +#ifdef CONFIG_DEEP_SLEEP +#define CONFIG_SILENT_CONSOLE +#endif + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 16 * 1024 * 1024) + +#define CONFIG_SYS_INIT_RAM_ADDR OCRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE OCRAM_SIZE + +/* XHCI Support - enabled by default */ +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +#define CONFIG_SYS_CLK_FREQ 100000000 +#define CONFIG_DDR_CLK_FREQ 100000000 + +#define DDR_SDRAM_CFG 0x470c0008 +#define DDR_CS0_BNDS 0x008000bf +#define DDR_CS0_CONFIG 0x80014302 +#define DDR_TIMING_CFG_0 0x50550004 +#define DDR_TIMING_CFG_1 0xbcb38c56 +#define DDR_TIMING_CFG_2 0x0040d120 +#define DDR_TIMING_CFG_3 0x010e1000 +#define DDR_TIMING_CFG_4 0x00000001 +#define DDR_TIMING_CFG_5 0x03401400 +#define DDR_SDRAM_CFG_2 0x00401010 +#define DDR_SDRAM_MODE 0x00061c60 +#define DDR_SDRAM_MODE_2 0x00180000 +#define DDR_SDRAM_INTERVAL 0x18600618 +#define DDR_DDR_WRLVL_CNTL 0x8655f605 +#define DDR_DDR_WRLVL_CNTL_2 0x05060607 +#define DDR_DDR_WRLVL_CNTL_3 0x05050505 +#define DDR_DDR_CDR1 0x80040000 +#define DDR_DDR_CDR2 0x00000001 +#define DDR_SDRAM_CLK_CNTL 0x02000000 +#define DDR_DDR_ZQ_CNTL 0x89080600 +#define DDR_CS0_CONFIG_2 0 +#define DDR_SDRAM_CFG_MEM_EN 0x80000000 +#define SDRAM_CFG2_D_INIT 0x00000010 +#define DDR_CDR2_VREF_TRAIN_EN 0x00000080 +#define SDRAM_CFG2_FRC_SR 0x80000000 +#define SDRAM_CFG_BI 0x00000001 + +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_SYS_FSL_PBL_PBI \ + "board/freescale/ls1021atsn/ls102xa_pbi.cfg" +#endif + +#ifdef CONFIG_SD_BOOT +#ifdef CONFIG_SD_BOOT_QSPI +#define CONFIG_SYS_FSL_PBL_RCW \ + "board/freescale/ls1021atsn/ls102xa_rcw_sd_qspi.cfg" +#else +#define CONFIG_SYS_FSL_PBL_RCW \ + "board/freescale/ls1021atsn/ls102xa_rcw_sd_ifc.cfg" +#endif +#define CONFIG_SPL_LDSCRIPT "arch/$(ARCH)/cpu/u-boot-spl.lds" +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_WATCHDOG_SUPPORT +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0xe8 + +#ifdef CONFIG_SECURE_BOOT +#define CONFIG_U_BOOT_HDR_SIZE (16 << 10) +#endif /* ifdef CONFIG_SECURE_BOOT */ + +#define CONFIG_SPL_MAX_SIZE 0x1a000 +#define CONFIG_SPL_STACK 0x1001d000 +#define CONFIG_SPL_PAD_TO 0x1c000 + +#define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE + \ + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 +#define CONFIG_SPL_BSS_START_ADDR 0x80100000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 + +#ifdef CONFIG_U_BOOT_HDR_SIZE +/* + * HDR would be appended at end of image and copied to DDR along + * with U-Boot image. Here u-boot max. size is 512K. So if binary + * size increases then increase this size in case of secure boot as + * it uses raw u-boot image instead of fit image. + */ +#define CONFIG_SYS_MONITOR_LEN (0x80000 + CONFIG_U_BOOT_HDR_SIZE) +#else +#define CONFIG_SYS_MONITOR_LEN 0x80000 +#endif /* ifdef CONFIG_U_BOOT_HDR_SIZE */ +#endif + +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x80000000 +#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024) + +#define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_CHIP_SELECTS_PER_CTRL 4 + +#if !defined(CONFIG_SD_BOOT) && !defined(CONFIG_NAND_BOOT) && \ + !defined(CONFIG_QSPI_BOOT) +#define CONFIG_U_QE +#endif + +/* + * IFC Definitions + */ +#if !defined(CONFIG_QSPI_BOOT) && !defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_FSL_IFC +#endif + +/* CPLD */ +#define CONFIG_SYS_CPLD_BASE 0x7fb00000 +#define CPLD_BASE_PHYS CONFIG_SYS_CPLD_BASE + +#define CONFIG_SYS_FPGA_CSPR_EXT (0x0) +#define CONFIG_SYS_FPGA_CSPR (CSPR_PHYS_ADDR(CPLD_BASE_PHYS) | \ + CSPR_PORT_SIZE_8 | \ + CSPR_MSEL_GPCM | \ + CSPR_V) +#define CONFIG_SYS_FPGA_AMASK IFC_AMASK(64 * 1024) +#define CONFIG_SYS_FPGA_CSOR (CSOR_NOR_ADM_SHIFT(4) | \ + CSOR_NOR_NOR_MODE_AVD_NOR | \ + CSOR_NOR_TRHZ_80) + +/* CPLD Timing parameters for IFC GPCM */ +#define CONFIG_SYS_FPGA_FTIM0 (FTIM0_GPCM_TACSE(0xf) | \ + FTIM0_GPCM_TEADC(0xf) | \ + FTIM0_GPCM_TEAHC(0xf)) +#define CONFIG_SYS_FPGA_FTIM1 (FTIM1_GPCM_TACO(0xff) | \ + FTIM1_GPCM_TRAD(0x3f)) +#define CONFIG_SYS_FPGA_FTIM2 (FTIM2_GPCM_TCS(0xf) | \ + FTIM2_GPCM_TCH(0xf) | \ + FTIM2_GPCM_TWP(0xff)) +#define CONFIG_SYS_FPGA_FTIM3 0x0 +#define CONFIG_SYS_CSPR0_EXT CONFIG_SYS_FPGA_CSPR_EXT +#define CONFIG_SYS_CSPR0 CONFIG_SYS_FPGA_CSPR +#define CONFIG_SYS_AMASK0 CONFIG_SYS_FPGA_AMASK +#define CONFIG_SYS_CSOR0 CONFIG_SYS_FPGA_CSOR +#define CONFIG_SYS_CS0_FTIM0 CONFIG_SYS_FPGA_FTIM0 +#define CONFIG_SYS_CS0_FTIM1 CONFIG_SYS_FPGA_FTIM1 +#define CONFIG_SYS_CS0_FTIM2 CONFIG_SYS_FPGA_FTIM2 +#define CONFIG_SYS_CS0_FTIM3 CONFIG_SYS_FPGA_FTIM3 + +/* + * Serial Port + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_SERIAL +#ifndef CONFIG_DM_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#endif +#define CONFIG_SYS_NS16550_CLK get_serial_clock() + +#define CONFIG_BAUDRATE 115200 + +/* + * I2C + */ +#define CONFIG_SYS_I2C +#define CONFIG_SYS_I2C_MXC +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ +#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x51 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 + +/* SPI */ +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +/* QSPI */ +#define FSL_QSPI_FLASH_SIZE (1 << 24) +#define FSL_QSPI_FLASH_NUM 2 +/* DSPI */ +#endif + +#ifdef CONFIG_TSEC_ENET +#define CONFIG_ETHPRIME "ethernet@2d10000" +#endif + +/* PCIe */ +#define CONFIG_PCIE1 /* PCIE controller 1 */ +#define CONFIG_PCIE2 /* PCIE controller 2 */ +#define FSL_PCIE_COMPAT "fsl,ls1021a-pcie" +#ifdef CONFIG_PCI +#define CONFIG_PCI_SCAN_SHOW +#endif + +#define CONFIG_PEN_ADDR_BIG_ENDIAN +#define CONFIG_LAYERSCAPE_NS_ACCESS +#define CONFIG_SMP_PEN_ADDR 0x01ee0200 +#define COUNTER_FREQUENCY 12500000 + +#define CONFIG_HWCONFIG +#define HWCONFIG_BUFFER_SIZE 256 + +#define CONFIG_FSL_DEVICE_DISABLE + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(USB, usb, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "bootargs=root=/dev/ram0 rw console=ttyS0,115200\0" \ + "initrd_high=0xffffffff\0" \ + "fdt_high=0xffffffff\0" \ + "fdt_addr=0x64f00000\0" \ + "kernel_addr=0x61000000\0" \ + "kernelheader_addr=0x60800000\0" \ + "scriptaddr=0x80000000\0" \ + "scripthdraddr=0x80080000\0" \ + "fdtheader_addr_r=0x80100000\0" \ + "kernelheader_addr_r=0x80200000\0" \ + "kernel_addr_r=0x80008000\0" \ + "kernelheader_size=0x40000\0" \ + "fdt_addr_r=0x8f000000\0" \ + "ramdisk_addr_r=0xa0000000\0" \ + "load_addr=0x80008000\0" \ + "kernel_size=0x2800000\0" \ + "kernel_addr_sd=0x8000\0" \ + "kernel_size_sd=0x14000\0" \ + "kernelhdr_addr_sd=0x4000\0" \ + "kernelhdr_size_sd=0x10\0" \ + BOOTENV \ + "boot_scripts=ls1021atsn_boot.scr\0" \ + "boot_script_hdr=hdr_ls1021atsn_bs.out\0" \ + "scan_dev_for_boot_part=" \ + "part list ${devtype} ${devnum} devplist; " \ + "env exists devplist || setenv devplist 1; " \ + "for distro_bootpart in ${devplist}; do " \ + "if fstype ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "bootfstype; then " \ + "run scan_dev_for_boot; " \ + "fi; " \ + "done\0" \ + "scan_dev_for_boot=" \ + "echo Scanning ${devtype} " \ + "${devnum}:${distro_bootpart}...; " \ + "for prefix in ${boot_prefixes}; do " \ + "run scan_dev_for_scripts; " \ + "run scan_dev_for_extlinux; " \ + "done;" \ + "\0" \ + "boot_a_script=" \ + "load ${devtype} ${devnum}:${distro_bootpart} " \ + "${scriptaddr} ${prefix}${script}; " \ + "env exists secureboot && load ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "${scripthdraddr} ${prefix}${boot_script_hdr} " \ + "&& esbc_validate ${scripthdraddr};" \ + "source ${scriptaddr}\0" \ + "qspi_bootcmd=echo Trying load from qspi..;" \ + "sf probe && sf read $load_addr " \ + "$kernel_addr $kernel_size; env exists secureboot " \ + "&& sf read $kernelheader_addr_r $kernelheader_addr " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; " \ + "bootm $load_addr#$board\0" \ + "sd_bootcmd=echo Trying load from SD ..;" \ + "mmcinfo && mmc read $load_addr " \ + "$kernel_addr_sd $kernel_size_sd && " \ + "env exists secureboot && mmc read $kernelheader_addr_r " \ + "$kernelhdr_addr_sd $kernelhdr_size_sd " \ + " && esbc_validate ${kernelheader_addr_r};" \ + "bootm $load_addr#$board\0" + +#undef CONFIG_BOOTCOMMAND +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; run qspi_bootcmd; " \ + "env exists secureboot && esbc_halt" +#elif defined(CONFIG_SD_BOOT) +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; run sd_bootcmd; " \ + "env exists secureboot && esbc_halt;" +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_LOAD_ADDR 0x82000000 + +#define CONFIG_LS102XA_STREAM_ID + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE +#else +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif + +#define CONFIG_SYS_QE_FW_ADDR 0x67f40000 + +/* + * Environment + */ +#define CONFIG_ENV_OVERWRITE + +#if defined(CONFIG_SD_BOOT) +#define CONFIG_ENV_OFFSET 0x300000 +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE 0x20000 +#elif defined(CONFIG_QSPI_BOOT) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET 0x300000 +#define CONFIG_ENV_SECT_SIZE 0x40000 +#endif + +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS +#define CONFIG_MISC_INIT_R + +#include <asm/fsl_secure_boot.h> +#define CONFIG_SYS_BOOTM_LEN 0x8000000 /* 128 MB */ + +#endif
Hi Vladimir,
nits: U-Boot
ditto
ditto
select ARCH_LS1021A
select CPU_V7A
select SUPPORT_SPL
imply SCSI
- Copyright 2019 Vladimir Oltean olteanv@gmail.com
aliases {
spi0 = &qspi;
spi1 = &dspi1;
+&enet0 {
phy-mode = "sgmii";
status = "okay";
+&enet1 {
phy-mode = "sgmii";
status = "okay";
+&i2c0 {
status = "okay";
+&mdio0 {
/* AR8031 */
reg = <0x1>;
/* AR8031 */
reg = <0x2>;
tbi0: tbi-phy@1f {
reg = <0x1f>;
+&mdio1 {
tbi1: tbi-phy@1f {
reg = <0x1f>;
+&qspi {
bus-num = <0>;
status = "okay";
flash@0 {
reg = <0>;
+&uart0 {
status = "okay";
+config SYS_BOARD
+config SYS_VENDOR
default "freescale"
+config SYS_SOC
default "ls102xa"
- Ethernet
- SDHC
- Other I/O
- One Serial port
- mPCIE slot
- SATA port
- USB3.0 port
nits: U-Boot
- make ls1021atsn_sdcard_defconfig && make -j 8 && sudo cp u-boot-with-spl-pbl.bin /srv/tftpboot/
- => tftp 0x82000000 u-boot-with-spl-pbl.bin && mmc rescan && mmc erase 8 0x1100 && mmc write 0x82000000 8 0x1100
- make -j 8 && sudo cp ls1021atsn/SSR_PNS_30/rcw_1200_qspiboot.bin.swapped /srv/tftpboot/
nits: U-Boot
ditto
- make ls1021atsn_qspi_defconfig && make -j 8 && sudo cp u-boot.bin /srv/tftpboot/
- mkenvimage -s 2M -o /srv/tftpboot/uboot-env.bin uboot-env.txt
- => tftp 0x82000000 rcw_1000_qspiboot.bin.swapped && sf probe && sf erase 0x0 +${filesize} && sf write 0x82000000 0x0 ${filesize}
- => tftp 0x82000000 u-boot.bin && sf probe && sf erase 0x100000 +${filesize} && sf write 0x82000000 0x100000 ${filesize}
- => tftp 0x82000000 uboot-env.bin && sf probe && sf erase 0x400000 +${filesize} && sf write 0x82000000 0x400000 ${filesize}
- => mac id
- => mac 0 00:1F:7B:xx:xx:xx
- => mac 1 00:1F:7B:xx:xx:xx
- => mac 2 00:1F:7B:xx:xx:xx
- => mac save
nits: U-Boot
- no way to talk to the CPLD for e.g. running the "qixis_reset" command, or
- turning the fan on, etc.
This should be static.
u32 cpldrev;
int major;
int minor;
cpld_show();
} else
udelay(1);
} else
+#endif +}
ddrmc_init();
fsl_dp_resume();
* send traffic.
arch_soc_init();
timer_init();
dram_init();
/* Clear the BSS */
get_clocks();
if (is_warm_boot())
dram_init();
* in last boot.
second_uboot();
+} +#endif
fsl_serdes_init();
+#ifdef CONFIG_U_QE
u_qe_init();
+} +#endif
+} +#endif
return sec_init();
+#endif +} +#endif
+#endif +} +#endif
+#ifdef CONFIG_PCI
[snip]
Regards, Bin
Hi Bin,
On Sat, 13 Jul 2019 at 08:05, Bin Meng bmeng.cn@gmail.com wrote:
Hi Vladimir,
nits: U-Boot
Why don't you add a rule to scripts/checkpatch.pl that warns on improper spelling of U-Boot? It would save a lot of time on both ends.
ditto
ditto
[snip]
nits: U-Boot
nits: U-Boot
ditto
- => mac id
- => mac save
nits: U-Boot
[snip]
Regards, Bin
Thanks, -Vladimir
Hi Vladimir,
On Mon, Jul 15, 2019 at 4:04 AM Vladimir Oltean olteanv@gmail.com wrote:
Hi Bin,
Hi Vladimir,
nits: U-Boot
Yep, I once tried to add some misspelled word list of U-Boot to spelling, but checkpatch would generate lots of false-positive warnings (like u-boot.bin) so I gave it up. It seems that we need add some special handling of U-Boot spelling in checkpatch? Do you have better idea?
ditto
ditto
[snip]
Regards, Bin
On Mon, 15 Jul 2019 at 05:18, Bin Meng bmeng.cn@gmail.com wrote:
Hi Vladimir,
Hi Bin,
Hi Vladimir,
nits: U-Boot
Ok, so I see that scripts/spelling.txt is case-insensitive, which doesn't work for what you want. I guess it just doesn't matter that much then? If it does matter to you, one way would be to add explicit checks in the checkpatch script itself.
ditto
ditto
[snip]
Regards, Bin
Thanks, -Vladimir
Hi Vladimir,
Hi Vladimir,
Hi Bin,
Hi Vladimir,
nits: U-Boot
Yes, it's case-insensitive, so it generates too many false-positive warnings and I believe that may annoy people :)
I did not want to do that as the checkpath script is synced up from Linux kernel upstream, and no U-Boot special handling should be applied.
Regards, Bin
select ARCH_LS1021A
select CPU_V7A
select SUPPORT_SPL
imply SCSI
aliases {
spi0 = &qspi;
spi1 = &dspi1;
+&enet0 {
phy-mode = "sgmii";
status = "okay";
+&enet1 {
phy-mode = "sgmii";
status = "okay";
+&i2c0 {
status = "okay";
+&mdio0 {
/* AR8031 */
reg = <0x1>;
/* AR8031 */
reg = <0x2>;
tbi0: tbi-phy@1f {
reg = <0x1f>;
+&mdio1 {
tbi1: tbi-phy@1f {
reg = <0x1f>;
+&qspi {
bus-num = <0>;
status = "okay";
flash@0 {
reg = <0>;
+&uart0 {
status = "okay";
+config SYS_BOARD
+config SYS_VENDOR
default "freescale"
+config SYS_SOC
default "ls102xa"
- Ethernet
- SDHC
- Other I/O
- One Serial port
- mPCIE slot
- SATA port
- USB3.0 port
- => mac id
- => mac save
u32 cpldrev;
int major;
int minor;
cpld_show();
} else
udelay(1);
} else
+#endif +}
ddrmc_init();
fsl_dp_resume();
Nit: Multi-line comment format. I'm curious why checkpatch.pl doesn't catch this sometimes.
* send traffic.
arch_soc_init();
timer_init();
dram_init();
/* Clear the BSS */
get_clocks();
if (is_warm_boot())
dram_init();
U-Boot
* in last boot.
second_uboot();
+} +#endif
fsl_serdes_init();
+#ifdef CONFIG_U_QE
u_qe_init();
+} +#endif
+} +#endif
return sec_init();
+#endif +} +#endif
+#endif +} +#endif
+#ifdef CONFIG_PCI
What is this file? Is it built by something?
- Copyright 2016-2018 NXP Semiconductors
- Size of malloc() pool
- HDR would be appended at end of image and copied to DDR along
- with U-Boot image. Here u-boot max. size is 512K. So if binary
U-Boot (second one).
- size increases then increase this size in case of secure boot as
- it uses raw u-boot image instead of fit image.
U-Boot
- IFC Definitions
CSPR_MSEL_GPCM | \
CSPR_V)
CSOR_NOR_TRHZ_80)
- Serial Port
- I2C
Where does this name come from? Is this not the first mac, i.e. would you get this without the explicit setting ethprime?
func(MMC, mmc, 0) \
func(USB, usb, 0) \
BOOTENV \
"fi; " \
"done\0" \
"done;" \
"\0" \
"boot_a_script=" \
- Miscellaneous configurable options
- Environment
2.17.1
Hi Joe,
select ARCH_LS1021A
select CPU_V7A
select SUPPORT_SPL
imply SCSI
aliases {
spi0 = &qspi;
spi1 = &dspi1;
+&enet0 {
phy-mode = "sgmii";
status = "okay";
+&enet1 {
phy-mode = "sgmii";
status = "okay";
+&i2c0 {
status = "okay";
+&mdio0 {
/* AR8031 */
reg = <0x1>;
/* AR8031 */
reg = <0x2>;
tbi0: tbi-phy@1f {
reg = <0x1f>;
+&mdio1 {
tbi1: tbi-phy@1f {
reg = <0x1f>;
+&qspi {
bus-num = <0>;
status = "okay";
flash@0 {
reg = <0>;
+&uart0 {
status = "okay";
+config SYS_BOARD
+config SYS_VENDOR
default "freescale"
+config SYS_SOC
default "ls102xa"
- Ethernet
- SDHC
- Other I/O
- One Serial port
- mPCIE slot
- SATA port
- USB3.0 port
- => mac id
- => mac save
u32 cpldrev;
int major;
int minor;
cpld_show();
} else
udelay(1);
} else
+#endif +}
ddrmc_init();
fsl_dp_resume();
What seems to be the problem with this? Do you prefer to see a first line with just " /* "?
* send traffic.
arch_soc_init();
timer_init();
dram_init();
/* Clear the BSS */
get_clocks();
if (is_warm_boot())
dram_init();
U-Boot
* in last boot.
second_uboot();
+} +#endif
fsl_serdes_init();
+#ifdef CONFIG_U_QE
u_qe_init();
+} +#endif
+} +#endif
return sec_init();
+#endif +} +#endif
+#endif +} +#endif
+#ifdef CONFIG_PCI
Yes, search for CONFIG_SYS_FSL_PBL_PBI in include/configs/ls1021atsn.h and in the main Makefile. So the boot ROM of the SoC searches for a 512-bit wide data structure starting with sector 8 of the MMC called RCW (Reset Configuration Word). This defines PLL frequencies, SerDes protocols, pinmuxing etc on the SoC. The RCW can also have a sequence of PBL (Pre-Boot Loader) commands appended to it - generally these are memory write operations that do stuff such as errata workarounds before the execution transfers to the boot loader. Actually I believe, but can't prove, that it is the PBL who copies the U-Boot SPL from MMC into an internal SRAM called OCRAM (on-chip RAM) before transferring the execution to it. I say I can't prove this because I would have expected to recognize this block copy command in the file you asked about. The takeaway is that for MMC-based booting, the RCW and PBI commands are packaged together in a file called u-boot-with-spl-pbl.bin. For QSPI-based booting that is not the case - the SPL and the OCRAM are not involved because the QSPI flash is memory-mapped so the CPU can execute the U-Boot image directly. In the case of booting from QSPI flash, the RCW and PBL commands are not packaged with the U-Boot image, but instead you're supposed to flash them separately. To be honest I don't know why it is like that - I'm not a big fan of keeping a relatively opaque hex dump of the RCW and PBL commands in U-Boot (let alone that the process is not the same for all boot sources).
U-Boot
- IFC Definitions
CSPR_MSEL_GPCM | \
CSPR_V)
CSOR_NOR_TRHZ_80)
- Serial Port
- I2C
I don't know, I didn't try not setting this. It is the first MAC, yes.
func(MMC, mmc, 0) \
func(USB, usb, 0) \
BOOTENV \
"fi; " \
"done\0" \
"done;" \
"\0" \
"boot_a_script=" \
- Environment
2.17.1
Thanks, -Vladimir
On Mon, Jul 15, 2019 at 4:57 PM Vladimir Oltean olteanv@gmail.com wrote:
Hi Joe,
Yes. See [1] and [2]. I tried to make the intent more clear at [2].
[1] - https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Docu... [2] - http://www.denx.de/wiki/U-Boot/CodingStyle
* send traffic.
arch_soc_init();
timer_init();
dram_init();
/* Clear the BSS */
get_clocks();
if (is_warm_boot())
dram_init();
U-Boot
* in last boot.
second_uboot();
+} +#endif
fsl_serdes_init();
+#ifdef CONFIG_U_QE
u_qe_init();
+} +#endif
+} +#endif
return sec_init();
+#endif +} +#endif
+#endif +} +#endif
+#ifdef CONFIG_PCI
Thanks for the explanation.
I would recommend trying it without setting this. It's usually only helpful of you need the second as default or something.
func(MMC, mmc, 0) \
func(USB, usb, 0) \
BOOTENV \
"fi; " \
"done\0" \
"done;" \
"\0" \
"boot_a_script=" \
- Environment
2.17.1
Thanks, -Vladimir _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Joe,
Oh, I wasn't aware that the coding style for the Linux net-next mailing list is the exception rather than the rule. Thanks for letting me know.
* send traffic.
arch_soc_init();
timer_init();
dram_init();
/* Clear the BSS */
get_clocks();
if (is_warm_boot())
dram_init();
U-Boot
* in last boot.
second_uboot();
+} +#endif
fsl_serdes_init();
+#ifdef CONFIG_U_QE
u_qe_init();
+} +#endif
+} +#endif
return sec_init();
+#endif +} +#endif
+#endif +} +#endif
+#ifdef CONFIG_PCI
func(MMC, mmc, 0) \
func(USB, usb, 0) \
BOOTENV \
"fi; " \
"done\0" \
"done;" \
"\0" \
"boot_a_script=" \
- Environment
2.17.1
Regards, -Vladimir
Bin Meng
Joe Hershberger
Vladimir Oltean
