[U-Boot] [PATCH v3 1/2] mtd: nand: Introduce CONFIG_SYS_NAND_BUSWIDTH_16BIT
Introduce CONFIG_SYS_NAND_BUSWIDTH_16BIT option so that other NAND controller drivers could use it when a 16-bit NAND is deployed.
drivers/mtd/nand/ndfc has CONFIG_SYS_NDFC_16BIT, so just rename it, so that other NAND drivers could reuse the same symbol.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v2: - None Changes since v1: - Improve README
README | 9 ++++++--- drivers/mtd/nand/ndfc.c | 4 ++-- 2 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/README b/README index d8cb394..bdd2c81 100644 --- a/README +++ b/README @@ -3713,9 +3713,12 @@ Low Level (hardware related) configuration options: - CONFIG_SYS_SRIOn_MEM_SIZE: Size of SRIO port 'n' memory region
-- CONFIG_SYS_NDFC_16 - Defined to tell the NDFC that the NAND chip is using a - 16 bit bus. +- CONFIG_SYS_NAND_BUSWIDTH_16BIT + Defined to tell the NAND controller that the NAND chip is using + a 16 bit bus. + Not all NAND drivers use this symbol. + Example of driver that uses it: + - drivers/mtd/nand/ndfc.c
- CONFIG_SYS_NDFC_EBC0_CFG Sets the EBC0_CFG register for the NDFC. If not defined diff --git a/drivers/mtd/nand/ndfc.c b/drivers/mtd/nand/ndfc.c index 6ebbb5e..213d2c9 100644 --- a/drivers/mtd/nand/ndfc.c +++ b/drivers/mtd/nand/ndfc.c @@ -156,7 +156,7 @@ static uint8_t ndfc_read_byte(struct mtd_info *mtd)
struct nand_chip *chip = mtd->priv;
-#ifdef CONFIG_SYS_NDFC_16BIT +#ifdef CONFIG_SYS_NAND_BUSWIDTH_16BIT return (uint8_t) readw(chip->IO_ADDR_R); #else return readb(chip->IO_ADDR_R); @@ -218,7 +218,7 @@ int board_nand_init(struct nand_chip *nand) nand->ecc.bytes = 3; nand->select_chip = ndfc_select_chip;
-#ifdef CONFIG_SYS_NDFC_16BIT +#ifdef CONFIG_SYS_NAND_BUSWIDTH_16BIT nand->options |= NAND_BUSWIDTH_16; #endif
Currently is_16bit_nand() is a per SoC function and it decides the bus nand width by reading some boot related registers.
This method works when NAND is the boot medium, but does not work if another boot medium is used. For example: booting from a SD card and then using NAND to store the environment variables, would lead to the following error:
NAND bus width 16 instead 8 bit No NAND device found!!! 0 MiB
Use CONFIG_SYS_NAND_BUSWIDTH_16BIT symbol to decide the bus width.
If it is defined in the board file, then consider 16-bit NAND bus-width, otherwise assume 8-bit NAND is used.
This also aligns with Documentation/devicetree/bindings/mtd/nand.txt, which states:
nand-bus-width : 8 or 16 bus width if not present 8
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Changes since v2: - Fix typo "if not present 82" Changes since v1: - Add an entry into README README | 3 ++- drivers/mtd/nand/mxc_nand.c | 37 +++---------------------------------- 2 files changed, 5 insertions(+), 35 deletions(-)
diff --git a/README b/README index bdd2c81..1a6a7a5 100644 --- a/README +++ b/README @@ -3717,8 +3717,9 @@ Low Level (hardware related) configuration options: Defined to tell the NAND controller that the NAND chip is using a 16 bit bus. Not all NAND drivers use this symbol. - Example of driver that uses it: + Example of drivers that use it: - drivers/mtd/nand/ndfc.c + - drivers/mtd/nand/mxc_nand.c
- CONFIG_SYS_NDFC_EBC0_CFG Sets the EBC0_CFG register for the NDFC. If not defined diff --git a/drivers/mtd/nand/mxc_nand.c b/drivers/mtd/nand/mxc_nand.c index d0ded48..bb475f2 100644 --- a/drivers/mtd/nand/mxc_nand.c +++ b/drivers/mtd/nand/mxc_nand.c @@ -98,45 +98,14 @@ static struct nand_ecclayout nand_hw_eccoob2k = { #endif #endif
-#ifdef CONFIG_MX27 static int is_16bit_nand(void) { - struct system_control_regs *sc_regs = - (struct system_control_regs *)IMX_SYSTEM_CTL_BASE; - - if (readl(&sc_regs->fmcr) & NF_16BIT_SEL) - return 1; - else - return 0; -} -#elif defined(CONFIG_MX31) -static int is_16bit_nand(void) -{ - struct clock_control_regs *sc_regs = - (struct clock_control_regs *)CCM_BASE; - - if (readl(&sc_regs->rcsr) & CCM_RCSR_NF16B) - return 1; - else - return 0; -} -#elif defined(CONFIG_MX25) || defined(CONFIG_MX35) -static int is_16bit_nand(void) -{ - struct ccm_regs *ccm = (struct ccm_regs *)IMX_CCM_BASE; - - if (readl(&ccm->rcsr) & CCM_RCSR_NF_16BIT_SEL) - return 1; - else - return 0; -} +#if defined(CONFIG_SYS_NAND_BUSWIDTH_16BIT) + return 1; #else -#warning "8/16 bit NAND autodetection not supported" -static int is_16bit_nand(void) -{ return 0; -} #endif +}
static uint32_t *mxc_nand_memcpy32(uint32_t *dest, uint32_t *source, size_t size) {
Hi Fabio,
Changes since v2:
Changes since v1:
return 1;
- else
return 1;
- else
return 1;
- else
- return 1;
static uint32_t *mxc_nand_memcpy32(uint32_t *dest, uint32_t *source, size_t size) { -- 1.7.9.5
For this series: Reviewed-by: Benoît Thébaudeau benoit.thebaudeau@advansee.com
I will integrate it as is at the beginning of the v8 of my series as planned, unless it is applied before. I hope to post my v8 before the end of the week.
Best regards, Benoît
Benoît Thébaudeau
Fabio Estevam
