[U-Boot-Users] [PATCH] Fix a bunch of compiler warnings for gcc 4.0
* Fix a bunch of compiler warnings for gcc 4.0
Signed-off-by: Matthew McClintock msm@freescale.com
--- commit 7376eb87aaa601f728f9b8e5e9cd2711a67f529e tree e7fd7c42b85dccbeb3ab29710d165ef37ea0ac5d parent 88c8f4921fc47fb0eb2384b16586f1bd7f275be7 author Matthew McClintock msm@freescale.com Wed, 11 Oct 2006 15:13:01 -0500 committer Matthew McClintock msm@freescale.com Wed, 11 Oct 2006 15:13:01 -0500
board/cds/mpc8541cds/mpc8541cds.c | 4 +--- board/cds/mpc8548cds/mpc8548cds.c | 2 -- board/cds/mpc8555cds/mpc8555cds.c | 2 -- board/mpc8540ads/mpc8540ads.c | 3 --- board/mpc8560ads/mpc8560ads.c | 2 -- board/pm854/pm854.c | 2 -- board/pm856/pm856.c | 2 -- board/stxgp3/stxgp3.c | 2 -- board/tqm85xx/tqm85xx.c | 2 -- common/cmd_bootm.c | 2 +- common/ft_build.c | 10 +++++----- cpu/mpc85xx/pci.c | 5 +++++ include/ft_build.h | 2 ++ include/pci.h | 3 +++ 14 files changed, 17 insertions(+), 26 deletions(-)
diff --git a/board/cds/mpc8541cds/mpc8541cds.c b/board/cds/mpc8541cds/mpc8541cds.c index c2b3009..a42904c 100644 --- a/board/cds/mpc8541cds/mpc8541cds.c +++ b/board/cds/mpc8541cds/mpc8541cds.c @@ -497,8 +497,6 @@ void pci_init_board(void) { #ifdef CONFIG_PCI - extern void pci_mpc85xx_init(struct pci_controller **hose); - - pci_mpc85xx_init(&hose); + pci_mpc85xx_init(hose); #endif } diff --git a/board/cds/mpc8548cds/mpc8548cds.c b/board/cds/mpc8548cds/mpc8548cds.c index 6eedb4a..ab5835d 100644 --- a/board/cds/mpc8548cds/mpc8548cds.c +++ b/board/cds/mpc8548cds/mpc8548cds.c @@ -322,8 +322,6 @@ void pci_init_board(void) { #ifdef CONFIG_PCI - extern void pci_mpc85xx_init(struct pci_controller **hose); - pci_mpc85xx_init(&hose); #endif } diff --git a/board/cds/mpc8555cds/mpc8555cds.c b/board/cds/mpc8555cds/mpc8555cds.c index 012181c..d980ea6 100644 --- a/board/cds/mpc8555cds/mpc8555cds.c +++ b/board/cds/mpc8555cds/mpc8555cds.c @@ -497,8 +497,6 @@ void pci_init_board(void) { #ifdef CONFIG_PCI - extern void pci_mpc85xx_init(struct pci_controller *hose); - pci_mpc85xx_init(hose); #endif } diff --git a/board/mpc8540ads/mpc8540ads.c b/board/mpc8540ads/mpc8540ads.c index fbcb397..914e51a 100644 --- a/board/mpc8540ads/mpc8540ads.c +++ b/board/mpc8540ads/mpc8540ads.c @@ -33,7 +33,6 @@ #include <spd.h>
#if defined(CONFIG_OF_FLAT_TREE) #include <ft_build.h> -extern void ft_cpu_setup(void *blob, bd_t *bd); #endif
@@ -327,8 +326,6 @@ void pci_init_board(void) { #ifdef CONFIG_PCI - extern void pci_mpc85xx_init(struct pci_controller *hose); - pci_mpc85xx_init(&hose); #endif /* CONFIG_PCI */ } diff --git a/board/mpc8560ads/mpc8560ads.c b/board/mpc8560ads/mpc8560ads.c index f9d75e8..c1572a3 100644 --- a/board/mpc8560ads/mpc8560ads.c +++ b/board/mpc8560ads/mpc8560ads.c @@ -539,8 +539,6 @@ void pci_init_board(void) { #ifdef CONFIG_PCI - extern void pci_mpc85xx_init(struct pci_controller *hose); - pci_mpc85xx_init(&hose); #endif /* CONFIG_PCI */ } diff --git a/board/pm854/pm854.c b/board/pm854/pm854.c index 94c492f..6ead1d0 100644 --- a/board/pm854/pm854.c +++ b/board/pm854/pm854.c @@ -289,8 +289,6 @@ void pci_init_board(void) { #ifdef CONFIG_PCI - extern void pci_mpc85xx_init(struct pci_controller *hose); - pci_mpc85xx_init(&hose); #endif /* CONFIG_PCI */ } diff --git a/board/pm856/pm856.c b/board/pm856/pm856.c index 5044708..a100754 100644 --- a/board/pm856/pm856.c +++ b/board/pm856/pm856.c @@ -442,8 +442,6 @@ void pci_init_board(void) { #ifdef CONFIG_PCI - extern void pci_mpc85xx_init(struct pci_controller *hose); - pci_mpc85xx_init(&hose); #endif /* CONFIG_PCI */ } diff --git a/board/stxgp3/stxgp3.c b/board/stxgp3/stxgp3.c index 2b3949c..a58c043 100644 --- a/board/stxgp3/stxgp3.c +++ b/board/stxgp3/stxgp3.c @@ -375,8 +375,6 @@ void pci_init_board(void) { #ifdef CONFIG_PCI - extern void pci_mpc85xx_init(struct pci_controller *hose); - pci_mpc85xx_init(&hose); #endif /* CONFIG_PCI */ } diff --git a/board/tqm85xx/tqm85xx.c b/board/tqm85xx/tqm85xx.c index befe8b7..9f03ec5 100644 --- a/board/tqm85xx/tqm85xx.c +++ b/board/tqm85xx/tqm85xx.c @@ -408,8 +408,6 @@ #endif /* CONFIG_PCI */ void pci_init_board (void) { #ifdef CONFIG_PCI - extern void pci_mpc85xx_init (struct pci_controller *hose); - pci_mpc85xx_init (&hose); #endif /* CONFIG_PCI */ } diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 04bce76..b785b9e 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -623,7 +623,7 @@ #ifdef CONFIG_OF_FLAT_TREE /* Look for a '-' which indicates to ignore the ramdisk argument */ if (argc >= 3 && strcmp(argv[2], "-") == 0) { debug ("Skipping initrd\n"); - data = 0; + len = data = 0; } else #endif diff --git a/common/ft_build.c b/common/ft_build.c index b5937e3..c6a018d 100644 --- a/common/ft_build.c +++ b/common/ft_build.c @@ -87,9 +87,9 @@ static int lookup_string(struct ft_cxt *
p = cxt->p; while (p < cxt->p_end) { - if (strcmp(p, name) == 0) + if (strcmp((char *)p, name) == 0) return p - cxt->p; - p += strlen(p) + 1; + p += strlen((char *)p) + 1; }
return -1; @@ -143,9 +143,9 @@ void ft_init_cxt(struct ft_cxt *cxt, voi cxt->p_rsvmap += SIZE_OF_RSVMAP_ENTRY; }
- cxt->p_start = (char*)bph + bph->off_dt_struct; - cxt->p_end = (char *)bph + bph->totalsize; - cxt->p = (char *)bph + bph->off_dt_strings; + cxt->p_start = (u8 *)bph + bph->off_dt_struct; + cxt->p_end = (u8 *)bph + bph->totalsize; + cxt->p = (u8 *)bph + bph->off_dt_strings; }
/* add a reserver physical area to the rsvmap */ diff --git a/cpu/mpc85xx/pci.c b/cpu/mpc85xx/pci.c index cfb7dcd..84f839a 100644 --- a/cpu/mpc85xx/pci.c +++ b/cpu/mpc85xx/pci.c @@ -29,6 +29,9 @@ #include <common.h> #include <asm/cpm_85xx.h> #include <pci.h>
+#if defined(CONFIG_OF_FLAT_TREE) +#include <ft_build.h> +#endif
#if defined(CONFIG_PCI)
@@ -42,7 +45,9 @@ pci_mpc85xx_init(struct pci_controller *
volatile immap_t *immap = (immap_t *)CFG_CCSRBAR; volatile ccsr_pcix_t *pcix = &immap->im_pcix; +#ifdef CONFIG_MPC85XX_PCI2 volatile ccsr_pcix_t *pcix2 = &immap->im_pcix2; +#endif volatile ccsr_gur_t *gur = &immap->im_gur; struct pci_controller * hose;
diff --git a/include/ft_build.h b/include/ft_build.h index f515687..89c689c 100644 --- a/include/ft_build.h +++ b/include/ft_build.h @@ -64,6 +64,8 @@ void *ft_get_prop(void *bphp, const char
#ifdef CONFIG_OF_BOARD_SETUP void ft_board_setup(void *blob, bd_t *bd); +void ft_cpu_setup(void *blob, bd_t *bd); +void ft_pci_setup(void *blob, bd_t *bd); #endif
#endif diff --git a/include/pci.h b/include/pci.h index e0e8783..cc216e1 100644 --- a/include/pci.h +++ b/include/pci.h @@ -501,4 +501,7 @@ #ifdef CONFIG_MPC824X extern void pci_mpc824x_init (struct pci_controller *hose); #endif
+#ifdef CONFIG_MPC85xx +extern void pci_mpc85xx_init (struct pci_controller *hose); +#endif #endif /* _PCI_H */
Please note this patch is already in my or Jon's git tree.
On Wed, 2006-10-18 at 11:54 -0500, Matthew McClintock wrote:
- Fix a bunch of compiler warnings for gcc 4.0
data = 0;
} elselen = data = 0;
p += strlen(p) + 1;
return -1;
- cxt->p_start = (u8 *)bph + bph->off_dt_struct;
- cxt->p_end = (u8 *)bph + bph->totalsize;
- cxt->p = (u8 *)bph + bph->off_dt_strings;
Using Tomcat but need to do more? Need to support web services, security? Get stuff done quickly with pre-integrated technology to make your job easier Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&da... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Matthew McClintock
