[PATCH 1/2] tee: optee: don't fail probe because of optee-rng
Fixes optee-rng driver bind sequence in optee driver to print a warning message but not report an error status when a optee-rng service driver fails to be bound as the optee driver itself is still fully functional.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/tee/optee/core.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/tee/optee/core.c b/drivers/tee/optee/core.c index 9240277579..604fd1414f 100644 --- a/drivers/tee/optee/core.c +++ b/drivers/tee/optee/core.c @@ -834,7 +834,7 @@ static int optee_probe(struct udevice *dev) */ ret = device_bind_driver(dev, "optee-rng", "optee-rng", NULL); if (ret) - return ret; + dev_warn(dev, "ftpm_tee failed to bind: %d\n", ret); }
Makes OP-TEE to enumerate also services depending on tee-supplicant support in U-Boot. This change allows OP-TEE services like fTPM TA to be discovered and get a TPM device registered in U-Boot.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- drivers/tee/optee/core.c | 32 +++++++++++++++++++++++--------- 1 file changed, 23 insertions(+), 9 deletions(-)
diff --git a/drivers/tee/optee/core.c b/drivers/tee/optee/core.c index 604fd1414f..b21031d7d8 100644 --- a/drivers/tee/optee/core.c +++ b/drivers/tee/optee/core.c @@ -102,13 +102,14 @@ static int bind_service_list(struct udevice *dev, struct tee_shm *service_list, return 0; }
-static int __enum_services(struct udevice *dev, struct tee_shm *shm, size_t *shm_size, u32 tee_sess) +static int __enum_services(struct udevice *dev, struct tee_shm *shm, size_t *shm_size, u32 tee_sess, + unsigned int pta_cmd) { struct tee_invoke_arg arg = { }; struct tee_param param = { }; int ret = 0;
- arg.func = PTA_CMD_GET_DEVICES; + arg.func = pta_cmd; arg.session = tee_sess;
/* Fill invoke cmd params */ @@ -118,7 +119,7 @@ static int __enum_services(struct udevice *dev, struct tee_shm *shm, size_t *shm
ret = tee_invoke_func(dev, &arg, 1, ¶m); if (ret || (arg.ret && arg.ret != TEE_ERROR_SHORT_BUFFER)) { - dev_err(dev, "PTA_CMD_GET_DEVICES invoke function err: 0x%x\n", arg.ret); + dev_err(dev, "Enumeration command 0x%x failed: 0x%x\n", pta_cmd, arg.ret); return -EINVAL; }
@@ -127,12 +128,13 @@ static int __enum_services(struct udevice *dev, struct tee_shm *shm, size_t *shm return 0; }
-static int enum_services(struct udevice *dev, struct tee_shm **shm, size_t *count, u32 tee_sess) +static int enum_services(struct udevice *dev, struct tee_shm **shm, size_t *count, u32 tee_sess, + unsigned int pta_cmd) { size_t shm_size = 0; int ret;
- ret = __enum_services(dev, NULL, &shm_size, tee_sess); + ret = __enum_services(dev, NULL, &shm_size, tee_sess, pta_cmd); if (ret) return ret;
@@ -142,7 +144,7 @@ static int enum_services(struct udevice *dev, struct tee_shm **shm, size_t *coun return ret; }
- ret = __enum_services(dev, *shm, &shm_size, tee_sess); + ret = __enum_services(dev, *shm, &shm_size, tee_sess, pta_cmd); if (!ret) *count = shm_size / sizeof(struct tee_optee_ta_uuid);
@@ -174,20 +176,32 @@ static int bind_service_drivers(struct udevice *dev) struct tee_shm *service_list = NULL; size_t service_count; u32 tee_sess; - int ret; + int ret, ret2;
ret = open_enum_session(dev, &tee_sess); if (ret) return ret;
- ret = enum_services(dev, &service_list, &service_count, tee_sess); + ret = enum_services(dev, &service_list, &service_count, tee_sess, + PTA_CMD_GET_DEVICES); if (!ret) ret = bind_service_list(dev, service_list, service_count);
tee_shm_free(service_list); + + ret2 = enum_services(dev, &service_list, &service_count, tee_sess, + PTA_CMD_GET_DEVICES_SUPP); + if (!ret2) + ret2 = bind_service_list(dev, service_list, service_count); + + tee_shm_free(service_list); + tee_close_session(dev, tee_sess);
- return ret; + if (ret) + return ret; + + return ret2; }
return -EINVAL; }dev_err(dev, "Enumeration command 0x%x failed: 0x%x\n", pta_cmd, arg.ret);
- ret = __enum_services(dev, NULL, &shm_size, tee_sess, pta_cmd); if (ret) return ret;
- ret = __enum_services(dev, *shm, &shm_size, tee_sess, pta_cmd); if (!ret) *count = shm_size / sizeof(struct tee_optee_ta_uuid);
- int ret;
int ret, ret2;
if (!ret2)
- return ret;
- if (ret)
return ret;
- return ret2;
All looks good, mind sending a v2 converting this to a ternary operator?
with or without Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Regards /Ilias
2.25.1
On Wed, Dec 7, 2022 at 4:30 PM Etienne Carriere etienne.carriere@linaro.org wrote:
Reviewed-by: Jens Wiklander jens.wiklander@linaro.org
Thanks, Jens
arg.func = pta_cmd; arg.session = tee_sess; /* Fill invoke cmd params */
int ret;
int ret, ret2; ret = open_enum_session(dev, &tee_sess); if (ret) return ret;
PTA_CMD_GET_DEVICES); if (!ret) ret = bind_service_list(dev, service_list, service_count); tee_shm_free(service_list);
if (!ret2)
return ret;
if (ret)
return ret;
return ret2;
2.25.1
{ struct tee_invoke_arg arg = { }; struct tee_param param = { }; int ret = 0;unsigned int pta_cmd)
{ size_t shm_size = 0; int ret;unsigned int pta_cmd)
- int ret;
int ret, ret2;
can you move part of duplicate code in enum_services() function ? => variables service_list and service_count => call to bind_service_list() => call to tee_shm_free(service_list);
then the call is more simple :
static int bind_service_drivers(struct udevice *dev) u32 tee_sess; int ret, ret2;
ret = enum_services(dev, tee_sess, PTA_CMD_GET_DEVICES); ret2 = enum_services(dev, tee_sess, PTA_CMD_GET_DEVICES_SUPP);
return ret2;
- ret2 = enum_services(dev, &service_list, &service_count, tee_sess,
- if (!ret2)
- tee_shm_free(service_list);
- tee_close_session(dev, tee_sess);
- return ret;
if (ret)
return ret;
return ret2; }
with or without
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
return ret;
-- 2.25.1
Thanks, Jens
return ret;
dev_warn(dev, "ftpm_tee failed to bind: %d\n", ret); } return 0;
-- 2.25.1
return ret;
Thanks Patrick
Etienne Carriere
Ilias Apalodimas
Jens Wiklander
Patrick DELAUNAY
