[U-Boot] [RFC PATCH 0/2] ARMV7: OMAP4: Add support for twl6032
TWL6032 is a companion Power Management IC (PMIC) of OMAP4470. This chip is similar to TWL6030 but has slight difference in some registers e.g. for GPADC. In u-boot only TWL6030 is supported now, thus there is no ability to boot OMAP4470 with TWL6032 because u-boot hangs when attempts to get the battery voltage from GPADC using false ctrl register address. These patches add the detection of the TWL chip type and support for TWL6032 chip in the battery charger driver.
Oleg Kosheliev (2): ARMV7: OMAP4: Add struct for twl603x data ARMV7: OMAP4: Add twl6032 support
drivers/power/twl6030.c | 79 +++++++++++++++++++++++++++++++++++++++++------ include/twl6030.h | 38 +++++++++++++++++++++++ 2 files changed, 107 insertions(+), 10 deletions(-)
The data struct is used to support different PMIC chip types. It contains the chip type and the data (e.g. registers addresses, adc multiplier) which is different for twl6030 and twl6032. Replaced some hardcoded values with the structure vars.
Based on Balaji T K balajitk@ti.com patches for TI u-boot.
Signed-off-by: Oleg Kosheliev oleg.kosheliev@ti.com --- drivers/power/twl6030.c | 25 ++++++++++++++++++++----- include/twl6030.h | 18 ++++++++++++++++++ 2 files changed, 38 insertions(+), 5 deletions(-)
diff --git a/drivers/power/twl6030.c b/drivers/power/twl6030.c index d421e60..badcd4a 100644 --- a/drivers/power/twl6030.c +++ b/drivers/power/twl6030.c @@ -25,6 +25,17 @@
#include <twl6030.h>
+static struct twl6030_data *twl; + +static struct twl6030_data twl6030_info = { + .chip_type = chip_TWL6030, + .adc_rbase = GPCH0_LSB, + .adc_ctrl = CTRL_P2, + .adc_enable = CTRL_P2_SP2, + .vbat_mult = TWL6030_VBAT_MULT, + .vbat_shift = TWL6030_VBAT_SHIFT, +}; + static int twl6030_gpadc_read_channel(u8 channel_no) { u8 lsb = 0; @@ -32,12 +43,12 @@ static int twl6030_gpadc_read_channel(u8 channel_no) int ret = 0;
ret = twl6030_i2c_read_u8(TWL6030_CHIP_ADC, - GPCH0_LSB + channel_no * 2, &lsb); + twl->adc_rbase + channel_no * 2, &lsb); if (ret) return ret;
ret = twl6030_i2c_read_u8(TWL6030_CHIP_ADC, - GPCH0_MSB + channel_no * 2, &msb); + twl->adc_rbase + 1 + channel_no * 2, &msb); if (ret) return ret;
@@ -49,7 +60,8 @@ static int twl6030_gpadc_sw2_trigger(void) u8 val; int ret = 0;
- ret = twl6030_i2c_write_u8(TWL6030_CHIP_ADC, CTRL_P2, CTRL_P2_SP2); + ret = twl6030_i2c_write_u8(TWL6030_CHIP_ADC, + twl->adc_ctrl, twl->adc_enable); if (ret) return ret;
@@ -57,7 +69,8 @@ static int twl6030_gpadc_sw2_trigger(void) val = CTRL_P2_BUSY;
while (!((val & CTRL_P2_EOCP2) && (!(val & CTRL_P2_BUSY)))) { - ret = twl6030_i2c_read_u8(TWL6030_CHIP_ADC, CTRL_P2, &val); + ret = twl6030_i2c_read_u8(TWL6030_CHIP_ADC, + twl->adc_ctrl, &val); if (ret) return ret; udelay(1000); @@ -132,7 +145,7 @@ int twl6030_get_battery_voltage(void) printf("Failed to read battery voltage\n"); return ret; } - battery_volt = (battery_volt * 25 * 1000) >> (10 + 2); + battery_volt = (battery_volt * twl->vbat_mult) >> twl->vbat_shift; printf("Battery Voltage: %d mV\n", battery_volt);
return battery_volt; @@ -144,6 +157,8 @@ void twl6030_init_battery_charging(void) int battery_volt = 0; int ret = 0;
+ twl = &twl6030_info; + /* Enable VBAT measurement */ twl6030_i2c_write_u8(TWL6030_CHIP_PM, MISC1, VBAT_MEAS);
diff --git a/include/twl6030.h b/include/twl6030.h index 029b21f..c0db668 100644 --- a/include/twl6030.h +++ b/include/twl6030.h @@ -129,6 +129,24 @@ #define GPCH0_LSB 0x57 #define GPCH0_MSB 0x58
+#define TWL6030_VBAT_MULT 40 * 1000 + +#define TWL6030_VBAT_SHIFT (10 + 3) + +typedef enum { + chip_TWL6030, + chip_TWL603X_cnt +}t_TWL603X_chip_type; + +struct twl6030_data{ + t_TWL603X_chip_type chip_type; + u8 adc_rbase; + u8 adc_ctrl; + u8 adc_enable; + int vbat_mult; + int vbat_shift; +}; + /* Functions to read and write from TWL6030 */ static inline int twl6030_i2c_write_u8(u8 chip_no, u8 reg, u8 val) {
[snip]
+typedef enum {
- chip_TWL6030,
- chip_TWL603X_cnt
- t_TWL603X_chip_type chip_type;
No new typedefs.
Added chip type detection and twl6032 support in the battery control and charge functions.
Signed-off-by: Oleg Kosheliev oleg.kosheliev@ti.com --- drivers/power/twl6030.c | 56 ++++++++++++++++++++++++++++++++++++++++++----- include/twl6030.h | 20 +++++++++++++++++ 2 files changed, 70 insertions(+), 6 deletions(-)
diff --git a/drivers/power/twl6030.c b/drivers/power/twl6030.c index badcd4a..8d8f1b5 100644 --- a/drivers/power/twl6030.c +++ b/drivers/power/twl6030.c @@ -36,6 +36,15 @@ static struct twl6030_data twl6030_info = { .vbat_shift = TWL6030_VBAT_SHIFT, };
+static struct twl6030_data twl6032_info = { + .chip_type = chip_TWL6032, + .adc_rbase = TWL6032_GPCH0_LSB, + .adc_ctrl = TWL6032_CTRL_P1, + .adc_enable = CTRL_P1_SP1, + .vbat_mult = TWL6032_VBAT_MULT, + .vbat_shift = TWL6032_VBAT_SHIFT, +}; + static int twl6030_gpadc_read_channel(u8 channel_no) { u8 lsb = 0; @@ -131,6 +140,18 @@ int twl6030_get_battery_voltage(void) { int battery_volt = 0; int ret = 0; + u8 vbatch; + + if (twl->chip_type == chip_TWL6030) { + vbatch = TWL6030_GPADC_VBAT_CHNL; + } else { + ret = twl6030_i2c_write_u8(TWL6030_CHIP_ADC, + TWL6032_GPSELECT_ISB, + TWL6032_GPADC_VBAT_CHNL); + if (ret) + return ret; + vbatch = 0; + }
/* Start GPADC SW conversion */ ret = twl6030_gpadc_sw2_trigger(); @@ -140,7 +161,7 @@ int twl6030_get_battery_voltage(void) }
/* measure Vbat voltage */ - battery_volt = twl6030_gpadc_read_channel(7); + battery_volt = twl6030_gpadc_read_channel(vbatch); if (battery_volt < 0) { printf("Failed to read battery voltage\n"); return ret; @@ -153,14 +174,37 @@ int twl6030_get_battery_voltage(void)
void twl6030_init_battery_charging(void) { - u8 stat1 = 0; + u8 val = 0; int battery_volt = 0; int ret = 0;
- twl = &twl6030_info; + ret = twl6030_i2c_read_u8(TWL6030_CHIP_USB, USB_PRODUCT_ID_LSB, &val); + if (ret) { + printf("twl6030_init_battery_charging(): " \ + "could not determine chip!\n"); + return; + } + if (val == 0x30) { + twl = &twl6030_info; + } else if (val == 0x32) { + twl = &twl6032_info; + } else { + printf("twl6030_init_battery_charging(): " \ + "unsupported chip type\n"); + return; + }
/* Enable VBAT measurement */ - twl6030_i2c_write_u8(TWL6030_CHIP_PM, MISC1, VBAT_MEAS); + if (twl->chip_type == chip_TWL6030) { + twl6030_i2c_write_u8(TWL6030_CHIP_PM, MISC1, VBAT_MEAS); + twl6030_i2c_write_u8(TWL6030_CHIP_ADC, + TWL6030_GPADC_CTRL, + GPADC_CTRL_SCALER_DIV4); + } else { + twl6030_i2c_write_u8(TWL6030_CHIP_ADC, + TWL6032_GPADC_CTRL2, + GPADC_CTRL2_CH18_SCALER_EN); + }
/* Enable GPADC module */ ret = twl6030_i2c_write_u8(TWL6030_CHIP_CHARGER, TOGGLE1, FGS | GPADCS); @@ -177,10 +221,10 @@ void twl6030_init_battery_charging(void) printf("Main battery voltage too low!\n");
/* Check for the presence of USB charger */ - twl6030_i2c_read_u8(TWL6030_CHIP_CHARGER, CONTROLLER_STAT1, &stat1); + twl6030_i2c_read_u8(TWL6030_CHIP_CHARGER, CONTROLLER_STAT1, &val);
/* check for battery presence indirectly via Fuel gauge */ - if ((stat1 & VBUS_DET) && (battery_volt < 3300)) + if ((val & VBUS_DET) && (battery_volt < 3300)) twl6030_start_usb_charging();
return; diff --git a/include/twl6030.h b/include/twl6030.h index c0db668..9fd2c8b 100644 --- a/include/twl6030.h +++ b/include/twl6030.h @@ -126,15 +126,35 @@ #define CTRL_P2_EOCP2 (1 << 1) #define CTRL_P2_BUSY (1 << 0)
+#define TWL6032_CTRL_P1 0x36 +#define CTRL_P1_SP1 (1 << 3) + #define GPCH0_LSB 0x57 #define GPCH0_MSB 0x58
+#define TWL6032_GPCH0_LSB 0x3b + +#define TWL6032_GPSELECT_ISB 0x35 + +#define USB_PRODUCT_ID_LSB 0x02 + +#define TWL6030_GPADC_VBAT_CHNL 0x07 +#define TWL6032_GPADC_VBAT_CHNL 0x12 + +#define TWL6030_GPADC_CTRL 0x2e +#define TWL6032_GPADC_CTRL2 0x2f +#define GPADC_CTRL2_CH18_SCALER_EN (1 << 2) +#define GPADC_CTRL_SCALER_DIV4 (1 << 3) + #define TWL6030_VBAT_MULT 40 * 1000 +#define TWL6032_VBAT_MULT 25 * 1000
#define TWL6030_VBAT_SHIFT (10 + 3) +#define TWL6032_VBAT_SHIFT (12 + 2)
typedef enum { chip_TWL6030, + chip_TWL6032, chip_TWL603X_cnt }t_TWL603X_chip_type;
[snip]
- ret = twl6030_i2c_read_u8(TWL6030_CHIP_USB, USB_PRODUCT_ID_LSB, &val);
- if (ret) {
return;
Please use puts() and don't split text strings, they can be longer than 80char wide.
[snip]
Same.
Oleg Kosheliev
