[U-Boot] [PATCH v2] bcm281xx: add support for "USB OTG clock"
enable this clock with the following: clk_usb_otg_enable((void *)HSOTG_BASE_ADDR)
Signed-off-by: Steve Rae srae@broadcom.com ---
Changes in v2: removed unrelated changes as per Felipe Balbi balbi@ti.com
arch/arm/cpu/armv7/bcm281xx/Makefile | 1 + arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c | 16 +++++++++++++++ arch/arm/cpu/armv7/bcm281xx/clk-usb-otg.c | 32 +++++++++++++++++++++++++++++ arch/arm/cpu/armv7/kona-common/clk-stubs.c | 5 +++++ arch/arm/include/asm/arch-bcm281xx/sysmap.h | 2 ++ arch/arm/include/asm/kona-common/clk.h | 1 + 6 files changed, 57 insertions(+) create mode 100644 arch/arm/cpu/armv7/bcm281xx/clk-usb-otg.c
diff --git a/arch/arm/cpu/armv7/bcm281xx/Makefile b/arch/arm/cpu/armv7/bcm281xx/Makefile index bd867a2..f24aeb3 100644 --- a/arch/arm/cpu/armv7/bcm281xx/Makefile +++ b/arch/arm/cpu/armv7/bcm281xx/Makefile @@ -10,3 +10,4 @@ obj-y += clk-bcm281xx.o obj-y += clk-sdio.o obj-y += clk-bsc.o obj-$(CONFIG_BCM_SF2_ETH) += clk-eth.o +obj-y += clk-usb-otg.o diff --git a/arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c b/arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c index d16b99f..7e25255 100644 --- a/arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c +++ b/arch/arm/cpu/armv7/bcm281xx/clk-bcm281xx.c @@ -209,6 +209,10 @@ static struct peri_clk_data sdio4_sleep_data = { .gate = SW_ONLY_GATE(0x0360, 20, 4), };
+static struct bus_clk_data usb_otg_ahb_data = { + .gate = HW_SW_GATE_AUTO(0x0348, 16, 0, 1), +}; + static struct bus_clk_data sdio1_ahb_data = { .gate = HW_SW_GATE_AUTO(0x0358, 16, 0, 1), }; @@ -331,6 +335,17 @@ static struct ccu_clock esub_ccu_clk = { */
/* KPM bus clocks */ +static struct bus_clock usb_otg_ahb_clk = { + .clk = { + .name = "usb_otg_ahb_clk", + .parent = &kpm_ccu_clk.clk, + .ops = &bus_clk_ops, + .ccu_clk_mgr_base = KONA_MST_CLK_BASE_ADDR, + }, + .freq_tbl = master_ahb_freq_tbl, + .data = &usb_otg_ahb_data, +}; + static struct bus_clock sdio1_ahb_clk = { .clk = { .name = "sdio1_ahb_clk", @@ -541,6 +556,7 @@ struct clk_lookup arch_clk_tbl[] = { CLK_LK(bsc2), CLK_LK(bsc3), /* Bus clocks */ + CLK_LK(usb_otg_ahb), CLK_LK(sdio1_ahb), CLK_LK(sdio2_ahb), CLK_LK(sdio3_ahb), diff --git a/arch/arm/cpu/armv7/bcm281xx/clk-usb-otg.c b/arch/arm/cpu/armv7/bcm281xx/clk-usb-otg.c new file mode 100644 index 0000000..b7efd8e --- /dev/null +++ b/arch/arm/cpu/armv7/bcm281xx/clk-usb-otg.c @@ -0,0 +1,32 @@ +/* + * Copyright 2014 Broadcom Corporation. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/errno.h> +#include <asm/arch/sysmap.h> +#include "clk-core.h" + +/* Enable appropriate clocks for the USB OTG port */ +int clk_usb_otg_enable(void *base) +{ + int ret; + char *ahbstr; + + switch ((u32) base) { + case HSOTG_BASE_ADDR: + ahbstr = "usb_otg_ahb_clk"; + break; + default: + printf("%s: base 0x%p not found\n", __func__, base); + return -EINVAL; + } + + ret = clk_get_and_enable(ahbstr); + if (ret) + return ret; + + return 0; +} diff --git a/arch/arm/cpu/armv7/kona-common/clk-stubs.c b/arch/arm/cpu/armv7/kona-common/clk-stubs.c index 338e0e4..fa10802 100644 --- a/arch/arm/cpu/armv7/kona-common/clk-stubs.c +++ b/arch/arm/cpu/armv7/kona-common/clk-stubs.c @@ -19,3 +19,8 @@ int __weak clk_bsc_enable(void *base, u32 rate, u32 *actual_ratep) { return 0; } + +int __weak clk_usb_otg_enable(void *base) +{ + return 0; +} diff --git a/arch/arm/include/asm/arch-bcm281xx/sysmap.h b/arch/arm/include/asm/arch-bcm281xx/sysmap.h index 350e7f6..93ebf34 100644 --- a/arch/arm/include/asm/arch-bcm281xx/sysmap.h +++ b/arch/arm/include/asm/arch-bcm281xx/sysmap.h @@ -13,6 +13,8 @@ #define ESUB_CLK_BASE_ADDR 0x38000000 #define ESW_CONTRL_BASE_ADDR 0x38200000 #define GPIO2_BASE_ADDR 0x35003000 +#define HSOTG_BASE_ADDR 0x3f120000 +#define HSOTG_CTRL_BASE_ADDR 0x3f130000 #define KONA_MST_CLK_BASE_ADDR 0x3f001000 #define KONA_SLV_CLK_BASE_ADDR 0x3e011000 #define PMU_BSC_BASE_ADDR 0x3500d000 diff --git a/arch/arm/include/asm/kona-common/clk.h b/arch/arm/include/asm/kona-common/clk.h index 2c7e829..a5e2fd9 100644 --- a/arch/arm/include/asm/kona-common/clk.h +++ b/arch/arm/include/asm/kona-common/clk.h @@ -25,5 +25,6 @@ int clk_set_parent(struct clk *clk, struct clk *parent); struct clk *clk_get_parent(struct clk *clk); int clk_sdio_enable(void *base, u32 rate, u32 *actual_ratep); int clk_bsc_enable(void *base); +int clk_usb_otg_enable(void *base);
#endif
Reviewed-by: Felipe Balbi balbi@ti.com
- .gate = HW_SW_GATE_AUTO(0x0348, 16, 0, 1),
- .clk = {
- .freq_tbl = master_ahb_freq_tbl,
- .data = &usb_otg_ahb_data,
- CLK_LK(usb_otg_ahb), CLK_LK(sdio1_ahb), CLK_LK(sdio2_ahb), CLK_LK(sdio3_ahb),
- Copyright 2014 Broadcom Corporation.
- int ret;
- char *ahbstr;
- switch ((u32) base) {
- case HSOTG_BASE_ADDR:
break;
- default:
return -EINVAL;
- ret = clk_get_and_enable(ahbstr);
- if (ret)
return ret;
#endif
1.8.5
Hi
.clk = {
int ret;
char *ahbstr;
break;
default:
return -EINVAL;
return clk_get..... ?
if (ret)
return ret;
What is usage of this file?
Why don't enable with the string?
Michael
*actual_ratep)
{ return 0; }
#endif
1.8.5
On 14-12-07 05:30 PM, Michael Trimarchi wrote:
Hi
- static struct bus_clk_data sdio1_ahb_data = { .gate = HW_SW_GATE_AUTO(0x0358, 16, 0, 1), };
.clk = {
- static struct bus_clock sdio1_ahb_clk = { .clk = { .name = "sdio1_ahb_clk",
int ret;
char *ahbstr;
break;
default:
return -EINVAL;
Thanks - see [v3]
if (ret)
return ret;
this "USB OTG clk" is enabled by the "fastboot initialization code" - which is in a parallel set of patches..... (I'm trying to not submit an overwhelming set of changes....) Thanks, Steve
Michael
*actual_ratep)
{ return 0; }
#endif
1.8.5
Felipe Balbi
Michael Trimarchi
Steve Rae
