[U-Boot-Users] Adding support to M5282Lite
Hi all, I want port U-Boot to M5282Lite board.
To it create a new target in U-Boot Makefile and create the directory boards/m5282lite and include/configs/M5282LITE.h based on M5282EVB.
Also added the SDRAM init code to initdram().
These is my main defines:
TEXT_BASE = 0xFFE00000 #define CFG_LOAD_ADDR 0x20000 #define CFG_FLASH_BASE 0xffe00000 #define CFG_MONITOR_BASE (CFG_INT_FLASH_BASE + 0x400)
Using the m68k-bdm-elf-gdb I am trying to start u-boot:
(gdb) target bdm /dev/bdmcf0 Detected V2 core GDB target bdm connected to /dev/bdmcf0 Coldfire debug module version is 0 (5206(e)/5272/5282) (gdb) symbol u-boot Reading symbols from u-boot...done. (gdb) load u-boot Loading section .text, size 0xcd0a lma 0xffe00000 Loading section .rodata, size 0x37b1 lma 0xffe0cd0a Loading section .reloc, size 0xc3c lma 0xffe10500 Loading section .data, size 0xae8 lma 0xffe1113c Loading section .got.plt, size 0xc lma 0xffe11c24 Loading section .u_boot_cmd, size 0x378 lma 0xffe11c30 Start address 0xffe00000, load size 73571 Transfer rate: 98094 bits/sec, 500 bytes/write. (gdb) b cpu_init_f Breakpoint 1 at 0xffe04638: file cpu_init.c, line 178. (gdb) c Continuing. ^ C [New process 42000]
Program received signal SIGTSTP, Stopped (user). [Switching to process 42000] 0xffe0808a in do_bootm (cmdtp=0xffffffff, flag=-1, argc=-1, argv=0xffffffff) at cmd_bootm.c:345 345 printf (" Uncompressing %s ... ", name); (gdb)
But it never goes to cpu_init_f ...
Am I doing some misconfiguration or some wrong step?
Cheers,
Alan
Alan Carvalho de Assis
