[U-Boot] [feature request] make TAGS target
Hi
This looks at least as an inconsistency: the TAGS file is removed on "make distclean", but there is no "make TAGS" target. The easiest would be to remove removing TAGS, but better yet would be adding the target to build this file, taking into account the configured architecture, include/asm, for ARM also include/asm/arch, and maybe even cpu/..., lib_..., and board/ paths? Maybe one of u-boot Kbuild / Makefile gurus could implement this in their spare time?:-) I even can imagine, that some of us might want the "tags" file too, and I wouldn't mind adding this target too:-) Yes, kernel has these targets.
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Dear Guennadi,
There are "tags", "ctags", "etags" and "cscope" make targets.
What exactly is not working for you when you run "make tags", for example ?
On Tue, 12 Aug 2008, Wolfgang Denk wrote:
Dear Guennadi,
Ah, ok, so, it is called "etags", not "TAGS" as in Linux.
First, at least my emacs looks by default for a file called TAGS, not etags. Second, IMHO, it would be better to only tag files under respective include paths according to configuration, as in Linux. Currently include/ is tagged completely. Thirdly, I think, it should be possible to use either "find ... | xargs etags" or "rm -f TAGS; find ... -exec etags -a {} ;" to secure ourselves for the time we get too many files.
