[U-Boot] [PATCH 1/1] bootefi: allow return without EFI_BOOT_SERVICES.Exit
The Unified Extensible Firmware Interface Specification, version 2.7, defines in chapter 2.1.2 - UEFI Application that an EFI application may either directly return or call EFI_BOOT_SERVICES.Exit().
Unfortunately U-Boot makes the incorrect assumption that EFI_BOOT_SERVICES.Exit() is always called.
So the following application leads to a memory exception on the aarch64 architecture when returning:
EFI_STATUS efi_main( EFI_HANDLE handle, EFI_SYSTEM_TABlE systable) { return EFI_SUCCESS; }
With this patch the entry point is stored in the image handle.
The new wrapper function do_enter is used to call the EFI entry point.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/bootefi.c | 18 ++++++++++++++++-- include/efi_api.h | 4 ++++ 2 files changed, 20 insertions(+), 2 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index a0a5434967..fcb223e999 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -9,6 +9,7 @@ #include <common.h> #include <command.h> #include <dm.h> +#include <efi_api.h> #include <efi_loader.h> #include <errno.h> #include <libfdt.h> @@ -141,6 +142,18 @@ static void *copy_fdt(void *fdt) return new_fdt; }
+static asmlinkage ulong do_enter(void *image_handle, + struct efi_system_table *st) +{ + struct efi_loaded_image *handle = image_handle; + efi_status_t ret = EFI_LOAD_ERROR; + + if (handle->entry) + ret = handle->entry(image_handle, st); + st->boottime->exit(image_handle, ret, 0 , NULL); + return ret; +} + #ifdef CONFIG_ARM64 static unsigned long efi_run_in_el2(ulong (*entry)(void *image_handle, struct efi_system_table *st), void *image_handle, @@ -149,7 +162,7 @@ static unsigned long efi_run_in_el2(ulong (*entry)(void *image_handle, /* Enable caches again */ dcache_enable();
- return entry(image_handle, st); + return do_enter(image_handle, st); } #endif
@@ -237,6 +250,7 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt) efi_status_t status = loaded_image_info.exit_status; return status == EFI_SUCCESS ? 0 : -EINVAL; } + loaded_image_info.entry = entry;
#ifdef CONFIG_ARM64 /* On AArch64 we need to make sure we call our payload in < EL3 */ @@ -254,7 +268,7 @@ static unsigned long do_bootefi_exec(void *efi, void *fdt) } #endif
- return entry(&loaded_image_info, &systab); + return do_enter(&loaded_image_info, &systab); }
diff --git a/include/efi_api.h b/include/efi_api.h index 5c3836a51b..611c35c422 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -253,6 +253,10 @@ struct efi_loaded_image { efi_status_t exit_status; struct jmp_buf_data exit_jmp; #endif +#ifdef CONFIG_CMD_BOOTEFI + ulong (*entry)(void *image_handle, struct efi_system_table *st) + asmlinkage; +#endif };
#define DEVICE_PATH_GUID \
Please call it efi_do_enter instead :). Otherwise we might get into naming conflicts sooner or later.
- struct efi_loaded_image *handle = image_handle;
- efi_status_t ret = EFI_LOAD_ERROR;
- if (handle->entry)
- st->boottime->exit(image_handle, ret, 0 , NULL);
- return ret;
- #ifdef CONFIG_ARM64 static unsigned long efi_run_in_el2(ulong (*entry)(void *image_handle, struct efi_system_table *st), void *image_handle,
- return do_enter(image_handle, st); } #endif
- return do_enter(&loaded_image_info, &systab); }
- ulong (*entry)(void *image_handle, struct efi_system_table *st)
asmlinkage;
I don't understand why we need another field in the loaded image struct here. Can't we just pass entry as a parameter to do_enter()?
Alex
+#endif };
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index a0a5434967..fcb223e999 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -9,6 +9,7 @@ #include <common.h> #include <command.h> #include <dm.h> +#include <efi_api.h> #include <efi_loader.h> #include <errno.h> #include <libfdt.h> @@ -141,6 +142,18 @@ static void *copy_fdt(void *fdt) return new_fdt; } +static asmlinkage ulong do_enter(void *image_handle,
Sure.
- return ret;
- return do_enter(image_handle, st); } #endif @@ -237,6 +250,7 @@ static unsigned long do_bootefi_exec(void *efi,
- loaded_image_info.entry = entry; #ifdef CONFIG_ARM64 /* On AArch64 we need to make sure we call our payload in < EL3 */
- return do_enter(&loaded_image_info, &systab); } diff --git a/include/efi_api.h b/include/efi_api.h
asmlinkage;
I could not see how to pass 'entry' to do_enter() as parameter without changing assembly code routine armv8_switch_to_el2.
I would prefer not to touch that assembly code.
Furthermore I have no board which will call armv8_switch_to_el2. So I would not be able to test the any assembly code changes.
Using a separate static variable would not provide any advantage.
Best regards
Heinrich
Sure.
- return ret;
asmlinkage;
armv8_switch_to_el2 simply takes x0-x3 and passes it into the payload function (efi_run_in_el2 in our case). So we would have 4 parameters to pass.
However, efi_run_in_el2() already gets the entry pointer today:
static unsigned long efi_run_in_el2(ulong (*entry)(void *image_handle, struct efi_system_table *st), void *image_handle, struct efi_system_table *st)
So instead of calling
you would just change to that
return efi_do_enter(image_handle, st, entry);
and have the entry function pointer available in your function.
Alex
Alexander Graf
