[U-Boot] Please pull u-boot-x86
Hi Tom,
The following changes since commit 37b608a52dcb13312a4f7ccea199cd6bac76d298:
powerpc: remove icecube_5200, Lite5200, cpci5200, mecp5200, pf5200 (2015-01-23 16:56:09 -0500)
http://git.denx.de/u-boot-x86.git
for you to fetch changes up to e43ade3749ff10bc313f33bf23705465e4163896:
x86: config: chromebook_link: Enable environment (2015-01-24 06:13:46 -0700)
---------------------------------------------------------------- Bin Meng (5): x86: ahci: Make sure interface is not busy after enabling the port x86: Add missing DECLARE_GLOBAL_DATA_PTR for mtrr.c x86: Save mtrr support flag in global data x86: Test mtrr support flag before accessing mtrr msr x86: Fix various code format issues in start16.S
Sebastien Ronsse (1): x86: Fix out of bounds irq handlers access
Simon Glass (22): bios_emulator: Fix an #ifdef typo in the header file x86: Correct endianness isues in pci_rom x86: Support ROMs on other archs bios_emulator: Don't display error when emulator terminates bios_emulator: Add some VESA interface debugging x86: pci: Don't stop when we get a vendor/device mismatch x86: Add a VESA video driver x86: Drop the x86_fb driver x86: Access the VGA ROM when needed x86: video: Add support for CONFIG_CONSOLE_SCROLL_LINES x86: config: Always scroll the display by 5 lines, for speed x86: dts: Add compatible string for Intel ICH9 SPI controller net: Add a separate file for IP checksumming x86: Use ipchecksum from net/ x86: rtc: mc146818: Add helpers to read/write CMOS RAM x86: spi: Add device tree support Allow architecture-specific memory reservation x86: dts: Add SPI flash MRC details for chromebook_link x86: Implement a cache for Memory Reference Code parameters x86: config: Enable hook for saving MRC configuration x86: ivybridge: Drop the Kconfig MRC cache information x86: config: chromebook_link: Enable environment
Sjoerd Simons (1): pci: tegra: Fix port information parsing
arch/x86/cpu/coreboot/Makefile | 1 - arch/x86/cpu/coreboot/coreboot.c | 5 ++++ arch/x86/cpu/coreboot/ipchecksum.c | 55 ---------------------------------- arch/x86/cpu/coreboot/tables.c | 8 ++--- arch/x86/cpu/cpu.c | 7 +++++ arch/x86/cpu/ivybridge/Kconfig | 28 ----------------- arch/x86/cpu/ivybridge/Makefile | 1 + arch/x86/cpu/ivybridge/mrccache.c | 156 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/cpu/ivybridge/sdram.c | 253 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/x86/cpu/mtrr.c | 14 +++++++++ arch/x86/cpu/start16.S | 20 ++++++------- arch/x86/dts/chromebook_link.dts | 15 +++++++++- arch/x86/include/asm/arch-coreboot/ipchecksum.h | 37 ----------------------- arch/x86/include/asm/arch-ivybridge/mrccache.h | 51 +++++++++++++++++++++++++++++++ arch/x86/include/asm/global_data.h | 16 ++++++---- arch/x86/include/asm/mtrr.h | 5 +++- arch/x86/include/asm/u-boot-x86.h | 2 ++ arch/x86/lib/init_helpers.c | 4 ++- arch/x86/lib/interrupts.c | 2 +- common/board_f.c | 7 +++++ configs/chromebook_link_defconfig | 2 +- drivers/bios_emulator/atibios.c | 161 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------- drivers/bios_emulator/include/x86emu/debug.h | 2 +- drivers/bios_emulator/x86emu/ops.c | 2 +- drivers/block/ahci.c | 20 ++++++++++++- drivers/pci/pci_auto.c | 28 ++++++++++++++++- drivers/pci/pci_rom.c | 40 +++++++++++++++++-------- drivers/pci/pci_tegra.c | 5 ++-- drivers/rtc/mc146818.c | 121 ++++++++++++++++++++++++++++++++++++++++++++------------------------------ drivers/spi/ich.c | 7 +++++ drivers/video/Kconfig | 7 +++-- drivers/video/Makefile | 2 +- drivers/video/cfb_console.c | 26 ++++++++++------ drivers/video/vesa_fb.c | 64 +++++++++++++++++++++++++++++++++++++++ drivers/video/x86_fb.c | 38 ----------------------- include/configs/chromebook_link.h | 8 +++++ include/configs/x86-common.h | 2 ++ include/fdtdec.h | 1 + include/net.h | 30 +++++++++++++++++++ include/pci.h | 9 ++++++ include/pci_rom.h | 1 - include/rtc.h | 32 ++++++++++++++++++++ include/vbe.h | 9 ++++-- lib/fdtdec.c | 1 + net/Makefile | 1 + net/checksum.c | 60 +++++++++++++++++++++++++++++++++++++ 46 files changed, 1078 insertions(+), 288 deletions(-) delete mode 100644 arch/x86/cpu/coreboot/ipchecksum.c create mode 100644 arch/x86/cpu/ivybridge/mrccache.c delete mode 100644 arch/x86/include/asm/arch-coreboot/ipchecksum.h create mode 100644 arch/x86/include/asm/arch-ivybridge/mrccache.h create mode 100644 drivers/video/vesa_fb.c delete mode 100644 drivers/video/x86_fb.c create mode 100644 net/checksum.c
On Mon, Jan 26, 2015 at 12:51:40PM -0700, Simon Glass wrote:
Hi Tom,
