[U-Boot] [v1] ls1028a: hdp: Add support for HDP firmware loading
This patch adds a command to load the HDP firmware and supporting libraries.
Signed-off-by: Oliver Brown oliver.brown@nxp.com Signed-off-by: Alison Wang alison.wang@nxp.com Signed-off-by: Wen He wen.he_1@nxp.com --- configs/ls1028aqds_tfa_defconfig | 2 + configs/ls1028ardb_tfa_defconfig | 2 + drivers/video/Kconfig | 9 + drivers/video/Makefile | 1 + drivers/video/imx/Makefile | 8 + drivers/video/imx/hdp/API_General.c | 473 ++++++++++++++++++++++++ drivers/video/imx/hdp/API_General.h | 275 ++++++++++++++ drivers/video/imx/hdp/Makefile | 6 + drivers/video/imx/hdp/address.h | 78 ++++ drivers/video/imx/hdp/apb_cfg.h | 155 ++++++++ drivers/video/imx/hdp/externs.h | 54 +++ drivers/video/imx/hdp/general_handler.h | 132 +++++++ drivers/video/imx/hdp/opcodes.h | 85 +++++ drivers/video/imx/hdp/test_base_sw.c | 216 +++++++++++ drivers/video/imx/hdp/util.h | 256 +++++++++++++ drivers/video/imx/hdp_load.c | 58 +++ 16 files changed, 1810 insertions(+) create mode 100644 drivers/video/imx/Makefile create mode 100644 drivers/video/imx/hdp/API_General.c create mode 100644 drivers/video/imx/hdp/API_General.h create mode 100644 drivers/video/imx/hdp/Makefile create mode 100644 drivers/video/imx/hdp/address.h create mode 100644 drivers/video/imx/hdp/apb_cfg.h create mode 100644 drivers/video/imx/hdp/externs.h create mode 100644 drivers/video/imx/hdp/general_handler.h create mode 100644 drivers/video/imx/hdp/opcodes.h create mode 100644 drivers/video/imx/hdp/test_base_sw.c create mode 100644 drivers/video/imx/hdp/util.h create mode 100644 drivers/video/imx/hdp_load.c
diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index 2a592a0a73..758fca5d63 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -59,3 +59,5 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_VIDEO=y +CONFIG_VIDEO_IMX_HDP_LOAD=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index 7ab61ecb6a..cd256ec1c1 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -62,3 +62,5 @@ CONFIG_EFI_LOADER_BOUNCE_BUFFER=y CONFIG_WDT_SP805=y CONFIG_WDT=y CONFIG_CMD_WDT=y +CONFIG_VIDEO=y +CONFIG_VIDEO_IMX_HDP_LOAD=y diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 2eac4b6381..184efa116a 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -554,6 +554,15 @@ config VIDEO_IPUV3 This enables framebuffer driver for i.MX processors working on the IPUv3(Image Processing Unit) internal graphic processor.
+config VIDEO_IMX_HDP_LOAD + bool "i.MX8 HDMI/DP firmware loading" + default y + depends on VIDEO + help + Support for HDMI/DP firmware loading for i.MX8QM and LS1028A + processors. The firmware is copied from system memory to the + HDMI/DP IRAM and DRAM memory. + config CFB_CONSOLE bool "Enable colour frame buffer console" depends on VIDEO diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 671f037c35..b33d03b416 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -65,3 +65,4 @@ obj-$(CONFIG_VIDEO_VESA) += vesa.o
obj-y += bridge/ obj-y += sunxi/ +obj-y += imx/ diff --git a/drivers/video/imx/Makefile b/drivers/video/imx/Makefile new file mode 100644 index 0000000000..1bf44939e9 --- /dev/null +++ b/drivers/video/imx/Makefile @@ -0,0 +1,8 @@ +# +# Copyright 2018-2019 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# + +UBOOTINCLUDE += -I$(srctree)/drivers/video/imx/hdp +obj-$(CONFIG_VIDEO_IMX_HDP_LOAD) += hdp_load.o hdp/ diff --git a/drivers/video/imx/hdp/API_General.c b/drivers/video/imx/hdp/API_General.c new file mode 100644 index 0000000000..bf6ffa076f --- /dev/null +++ b/drivers/video/imx/hdp/API_General.c @@ -0,0 +1,473 @@ +/****************************************************************************** + * + * Copyright (C) 2016-2017 Cadence Design Systems, Inc. + * All rights reserved worldwide. + * + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: BSD-3-Clause + * + ****************************************************************************** + * + * API_General.c + * + ****************************************************************************** + */ + +#include "API_General.h" +#include "util.h" +#ifndef __UBOOT__ +#include <string.h> +#endif +#include "address.h" +#include "apb_cfg.h" +#include "opcodes.h" +#include "general_handler.h" +#include "externs.h" +#ifndef __UBOOT__ +#include <stdio.h> +#endif + +extern state_struct state; + +void cdn_api_init(void) +{ + memset(&state, 0, sizeof(state_struct)); +} + +CDN_API_STATUS hdp_rx_loadfirmware(unsigned char *imem, int imemsize, + unsigned char *dmem, int dmemsize) +{ + int i; + + for (i = 0; i < imemsize; i += 4) + if (hdp_rx_apb_write(ADDR_IMEM + i, + (unsigned int)imem[i] << 0 | + (unsigned int)imem[i + 1] << 8 | + (unsigned int)imem[i + 2] << 16 | + (unsigned int)imem[i + 3] << 24)) + return CDN_ERR; + for (i = 0; i < dmemsize; i += 4) + if (hdp_rx_apb_write(ADDR_DMEM + i, + (unsigned int)dmem[i] << 0 | + (unsigned int)dmem[i + 1] << 8 | + (unsigned int)dmem[i + 2] << 16 | + (unsigned int)dmem[i + 3] << 24)) + return CDN_ERR; + return CDN_OK; +} + +CDN_API_STATUS cdn_api_loadfirmware(unsigned char *imem, int imemsize, + unsigned char *dmem, int dmemsize) +{ + int i; + + for (i = 0; i < imemsize; i += 4) + if (cdn_apb_write(ADDR_IMEM + i, + (unsigned int)imem[i] << 0 | + (unsigned int)imem[i + 1] << 8 | + (unsigned int)imem[i + 2] << 16 | + (unsigned int)imem[i + 3] << 24)) + return CDN_ERR; + for (i = 0; i < dmemsize; i += 4) + if (cdn_apb_write(ADDR_DMEM + i, + (unsigned int)dmem[i] << 0 | + (unsigned int)dmem[i + 1] << 8 | + (unsigned int)dmem[i + 2] << 16 | + (unsigned int)dmem[i + 3] << 24)) + return CDN_ERR; + return CDN_OK; +} + +CDN_API_STATUS cdn_api_general_test_echo(unsigned int val, + CDN_BUS_TYPE bus_type) +{ + CDN_API_STATUS ret; + + if (!state.running) { + if (!internal_apb_available()) + return CDN_BSY; + state.bus_type = bus_type; + state.rxenable = 1; + internal_tx_mkfullmsg(MB_MODULE_ID_GENERAL, GENERAL_TEST_ECHO, + 1, 4, val); + return CDN_STARTED; + } + if (state.txenable && !internal_mbox_tx_process().txend) + return CDN_BSY; + if (state.rxenable && !internal_mbox_rx_process().rxend) + return CDN_BSY; + ret = internal_test_rx_head(MB_MODULE_ID_GENERAL, GENERAL_TEST_ECHO); + if (ret != CDN_OK) { + state.running = 0; + return ret; + } + state.running = 0; + if (val != internal_betoi(state.rxbuffer + INTERNAL_CMD_HEAD_SIZE, 4)) + return CDN_ERR; + return CDN_OK; +} + +CDN_API_STATUS cdn_api_general_test_echo_blocking(unsigned int val, + CDN_BUS_TYPE bus_type) +{ + internal_block_function(cdn_api_general_test_echo(val, bus_type)); +} + +CDN_API_STATUS cdn_api_general_test_echo_ext(u8 const *msg, u8 *resp, + u16 num_bytes, + CDN_BUS_TYPE bus_type) +{ + CDN_API_STATUS ret; + + if (!msg || !resp) + return CDN_ERR; + + if ((num_bytes > GENERAL_TEST_ECHO_MAX_PAYLOAD) || + (num_bytes < GENERAL_TEST_ECHO_MIN_PAYLOAD)) + return CDN_ERR; + + if (!state.running) { + if (!internal_apb_available()) + return CDN_BSY; + + state.bus_type = bus_type; + state.rxenable = 1; + + internal_tx_mkfullmsg(MB_MODULE_ID_GENERAL, GENERAL_TEST_ECHO, + 1, -num_bytes, msg); + + return CDN_STARTED; + } + + if (state.txenable && !internal_mbox_tx_process().txend) + return CDN_BSY; + + if (state.rxenable && !internal_mbox_rx_process().rxend) + return CDN_BSY; + + ret = internal_test_rx_head(MB_MODULE_ID_GENERAL, GENERAL_TEST_ECHO); + + if (ret != CDN_OK) { + state.running = 0; + return ret; + } + + state.running = 0; + + memcpy(resp, state.rxbuffer + INTERNAL_CMD_HEAD_SIZE, num_bytes); + + if (memcmp(msg, resp, num_bytes) != 0) + return CDN_ERR; + + return CDN_OK; +} + +CDN_API_STATUS cdn_api_general_test_echo_ext_blocking(u8 const *msg, + u8 *resp, + u16 num_bytes, + CDN_BUS_TYPE bus_type) +{ + internal_block_function(cdn_api_general_test_echo_ext + (msg, resp, num_bytes, bus_type)); +} + +CDN_API_STATUS cdn_api_general_getcurversion(unsigned short *ver, + unsigned short *verlib) +{ + unsigned int vh, vl, vlh, vll; + + if (cdn_apb_read(VER_L << 2, &vl)) + return CDN_ERR; + if (cdn_apb_read(VER_H << 2, &vh)) + return CDN_ERR; + if (cdn_apb_read(VER_LIB_L_ADDR << 2, &vll)) + return CDN_ERR; + if (cdn_apb_read(VER_LIB_H_ADDR << 2, &vlh)) + return CDN_ERR; + *ver = F_VER_MSB_RD(vh) << 8 | F_VER_LSB_RD(vl); + *verlib = F_SW_LIB_VER_H_RD(vlh) << 8 | F_SW_LIB_VER_L_RD(vll); + return CDN_OK; +} + +CDN_API_STATUS cdn_api_get_event(uint32_t *events) +{ + u32 evt[4] = { 0 }; + + if (!events) { + printf("events pointer is NULL!\n"); + return CDN_ERR; + } + + if (cdn_apb_read(SW_EVENTS0 << 2, &evt[0]) || + cdn_apb_read(SW_EVENTS1 << 2, &evt[1]) || + cdn_apb_read(SW_EVENTS2 << 2, &evt[2]) || + cdn_apb_read(SW_EVENTS3 << 2, &evt[3])) { + printf("Failed to read events registers.\n"); + return CDN_ERR; + } + + *events = (evt[0] & 0xFF) + | ((evt[1] & 0xFF) << 8) + | ((evt[2] & 0xFF) << 16) + | ((evt[3] & 0xFF) << 24); + + return CDN_OK; +} + +CDN_API_STATUS cdn_api_get_debug_reg_val(uint16_t *val) +{ + u32 dbg[2] = { 0 }; + + if (!val) { + printf("val pointer is NULL!\n"); + return CDN_ERR; + } + + if (cdn_apb_read(SW_DEBUG_L << 2, &dbg[0]) || + cdn_apb_read(SW_DEBUG_H << 2, &dbg[1])) { + printf("Failed to read debug registers.\n"); + return CDN_ERR; + } + + *val = (u16)((dbg[0] & 0xFF) | ((dbg[1] & 0xFF) << 8)); + + return CDN_OK; +} + +CDN_API_STATUS cdn_api_checkalive(void) +{ + static unsigned int alive; + unsigned int newalive; + + if (cdn_apb_read(KEEP_ALIVE << 2, &newalive)) + return CDN_ERR; + if (alive == newalive) + return CDN_BSY; + alive = newalive; + return CDN_OK; +} + +CDN_API_STATUS cdn_api_checkalive_blocking(void) +{ + internal_block_function(cdn_api_checkalive()); +} + +CDN_API_STATUS cdn_api_maincontrol(unsigned char mode, unsigned char *resp) +{ + if (!state.running) { + if (!internal_apb_available()) + return CDN_BSY; + state.bus_type = CDN_BUS_TYPE_APB; + state.rxenable = 1; + internal_tx_mkfullmsg(MB_MODULE_ID_GENERAL, + GENERAL_MAIN_CONTROL, 1, 1, mode); + return CDN_STARTED; + } + INTERNAL_PROCESS_MESSAGES; + internal_opcode_ok_or_return(MB_MODULE_ID_GENERAL, + GENERAL_MAIN_CONTROL_RESP); + internal_readmsg(1, 1, resp); + return CDN_OK; +} + +CDN_API_STATUS cdn_api_maincontrol_blocking(unsigned char mode, + unsigned char *resp) +{ + internal_block_function(cdn_api_maincontrol(mode, resp)); +} + +CDN_API_STATUS cdn_api_apbconf(u8 dpcd_bus_sel, u8 dpcd_bus_lock, + u8 hdcp_bus_sel, u8 hdcp_bus_lock, + u8 capb_bus_sel, u8 capb_bus_lock, + u8 *dpcd_resp, u8 *hdcp_resp, + u8 *capb_resp) +{ + u8 resp; + u8 set = 0; + + if (!state.running) { + if (!internal_apb_available()) + return CDN_BSY; + + state.bus_type = CDN_BUS_TYPE_APB; + state.rxenable = 1; + + set |= (dpcd_bus_sel) + ? (1 << GENERAL_BUS_SETTINGS_DPCD_BUS_BIT) + : 0; + set |= (dpcd_bus_lock) + ? (1 << GENERAL_BUS_SETTINGS_DPCD_BUS_LOCK_BIT) + : 0; + set |= (hdcp_bus_sel) + ? (1 << GENERAL_BUS_SETTINGS_HDCP_BUS_BIT) + : 0; + set |= (hdcp_bus_lock) + ? (1 << GENERAL_BUS_SETTINGS_HDCP_BUS_LOCK_BIT) + : 0; + set |= (capb_bus_sel) + ? (1 << GENERAL_BUS_SETTINGS_CAPB_OWNER_BIT) + : 0; + set |= (capb_bus_lock) + ? (1 << GENERAL_BUS_SETTINGS_CAPB_OWNER_LOCK_BIT) + : 0; + + internal_tx_mkfullmsg(MB_MODULE_ID_GENERAL, + GENERAL_BUS_SETTINGS, 1, 1, set); + + return CDN_STARTED; + } + + INTERNAL_PROCESS_MESSAGES; + internal_opcode_ok_or_return(MB_MODULE_ID_GENERAL, + GENERAL_BUS_SETTINGS_RESP); + + /* Read one one-byte response */ + internal_readmsg(1, 1, &resp); + + *dpcd_resp = + (resp & (1 << GENERAL_BUS_SETTINGS_RESP_DPCD_BUS_BIT)) ? 1 : 0; + *hdcp_resp = + (resp & (1 << GENERAL_BUS_SETTINGS_RESP_HDCP_BUS_BIT)) ? 1 : 0; + *capb_resp = + (resp & (1 << GENERAL_BUS_SETTINGS_RESP_CAPB_OWNER_BIT)) ? 1 : 0; + + return CDN_OK; +} + +CDN_API_STATUS cdn_api_apbconf_blocking(u8 dpcd_bus_sel, + u8 dpcd_bus_lock, + u8 hdcp_bus_sel, + u8 hdcp_bus_lock, + u8 capb_bus_sel, + u8 capb_bus_lock, + u8 *dpcd_resp, + u8 *hdcp_resp, + u8 *capb_resp) +{ + internal_block_function(cdn_api_apbconf(dpcd_bus_sel, dpcd_bus_lock, + hdcp_bus_sel, hdcp_bus_lock, + capb_bus_sel, capb_bus_lock, + dpcd_resp, hdcp_resp, + capb_resp)); +} + +CDN_API_STATUS cdn_api_setclock(unsigned char mhz) +{ + return cdn_apb_write(SW_CLK_H << 2, mhz); +} + +CDN_API_STATUS cdn_api_general_read_register(unsigned int addr, + GENERAL_READ_REGISTER_RESPONSE + *resp) +{ + CDN_API_STATUS ret; + + if (!state.running) { + if (!internal_apb_available()) + return CDN_BSY; + internal_tx_mkfullmsg(MB_MODULE_ID_GENERAL, + GENERAL_READ_REGISTER, 1, 4, addr); + state.bus_type = CDN_BUS_TYPE_APB; + state.rxenable = 1; + return CDN_STARTED; + } + INTERNAL_PROCESS_MESSAGES; + ret = internal_test_rx_head(MB_MODULE_ID_GENERAL, + GENERAL_READ_REGISTER_RESP); + if (ret != CDN_OK) + return ret; + internal_readmsg(2, 4, &resp->addr, 4, &resp->val); + return CDN_OK; +} + +CDN_API_STATUS +cdn_api_general_read_register_blocking(unsigned int addr, + GENERAL_READ_REGISTER_RESPONSE *resp) +{ + internal_block_function(cdn_api_general_read_register(addr, resp)); +} + +CDN_API_STATUS cdn_api_general_write_register(unsigned int addr, + unsigned int val) +{ + if (!state.running) { + if (!internal_apb_available()) + return CDN_BSY; + internal_tx_mkfullmsg(MB_MODULE_ID_GENERAL, + GENERAL_WRITE_REGISTER, 2, 4, addr, 4, + val); + state.bus_type = CDN_BUS_TYPE_APB; + return CDN_STARTED; + } + INTERNAL_PROCESS_MESSAGES; + return CDN_OK; +} + +CDN_API_STATUS cdn_api_general_write_register_blocking(unsigned int addr, + unsigned int val) +{ + internal_block_function(cdn_api_general_write_register(addr, val)); +} + +CDN_API_STATUS cdn_api_general_write_field(unsigned int addr, + unsigned char startbit, + unsigned char bitsno, + unsigned int val) +{ + if (!state.running) { + if (!internal_apb_available()) + return CDN_BSY; + internal_tx_mkfullmsg(MB_MODULE_ID_GENERAL, GENERAL_WRITE_FIELD, + 4, 4, addr, 1, startbit, 1, bitsno, 4, + val); + state.bus_type = CDN_BUS_TYPE_APB; + return CDN_STARTED; + } + INTERNAL_PROCESS_MESSAGES; + return CDN_OK; +} + +CDN_API_STATUS cdn_api_general_write_field_blocking(unsigned int addr, + unsigned char startbit, + unsigned char bitsno, + unsigned int val) +{ + internal_block_function(cdn_api_general_write_field + (addr, startbit, bitsno, val)); +} + +CDN_API_STATUS cdn_api_general_phy_test_access(uint8_t *resp) +{ + CDN_API_STATUS ret; + + *resp = 0; + + if (!state.running) { + if (!internal_apb_available()) + return CDN_BSY; + + internal_tx_mkfullmsg(MB_MODULE_ID_GENERAL, GENERAL_TEST_ACCESS, + 0); + state.bus_type = CDN_BUS_TYPE_APB; + state.rxenable = 1; + + return CDN_STARTED; + } + + INTERNAL_PROCESS_MESSAGES; + + ret = internal_test_rx_head(MB_MODULE_ID_GENERAL, GENERAL_TEST_ACCESS); + + if (ret != CDN_OK) + return ret; + + internal_readmsg(1, 1, resp); + + return CDN_OK; +} + +CDN_API_STATUS cdn_api_general_phy_test_access_blocking(uint8_t *resp) +{ + internal_block_function(cdn_api_general_phy_test_access(resp)); +} diff --git a/drivers/video/imx/hdp/API_General.h b/drivers/video/imx/hdp/API_General.h new file mode 100644 index 0000000000..c66bb9d080 --- /dev/null +++ b/drivers/video/imx/hdp/API_General.h @@ -0,0 +1,275 @@ +/****************************************************************************** + * + * Copyright (C) 2016-2017 Cadence Design Systems, Inc. + * All rights reserved worldwide. + * + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: BSD-3-Clause + * + ****************************************************************************** + * + * API_General.h + * + ****************************************************************************** + */ + +#ifndef API_GENERAL_H_ +#define API_GENERAL_H_ + +#ifndef __UBOOT__ +#include <stdint.h> +#else +#include <common.h> +#endif + +#define GENERAL_TEST_ECHO_MAX_PAYLOAD 100 +#define GENERAL_TEST_ECHO_MIN_PAYLOAD 1 + +/** + * \addtogroup GENERAL_API + * { + */ +/** status code returned by API calls */ +typedef enum { + /** operation succedded */ + CDN_OK = 0, + /** CEC operation succedded */ + CDN_CEC_ERR_NONE = 0, + /** mailbox is currently sending or receiving data */ + CDN_BSY, + /** message set up and ready to be sent, no data sent yet */ + CDN_STARTED, + /** error encountered while reading/writing APB */ + CDN_ERR, + /** reply returned with bad opcode */ + CDN_BAD_OPCODE, + /** reply returned with bad module */ + CDN_BAD_MODULE, + /** reply not supported mode */ + CDN_ERROR_NOT_SUPPORTED, + /** Invalid argument passed to CEC API function */ + CDN_CEC_ERR_INVALID_ARG, + /** + * TX Buffer for CEC Messages is full. This is applicable only + * when TX Buffers for CEC Messages are implemented in the HW. + */ + CDN_CEC_ERR_TX_BUFF_FULL, + /** No Messages in the RX Buffers are present. */ + CDN_CEC_ERR_RX_BUFF_EMPTY, + /** Timeout during TX operation */ + CDN_CEC_ERR_TX_TIMEOUT, + /** Timeout during RX operation */ + CDN_CEC_ERR_RX_TIMEOUT, + /** Data transmision fail. */ + CDN_CEC_ERR_TX_FAILED, + /** Data reception fail. */ + CDN_CEC_ERR_RX_FAILED, + /** Operation aborted. */ + CDN_CEC_ERR_ABORT, + /** All Logical Addresses are in use. */ + CDN_CEC_ERR_ALL_LA_IN_USE, +} CDN_API_STATUS; + +typedef enum { + CDN_BUS_TYPE_APB = 0, + CDN_BUS_TYPE_SAPB = 1 +} CDN_BUS_TYPE; + +/** + * GENERAL_Read_Register response struct + */ +typedef struct { + unsigned int addr; + unsigned int val; +} GENERAL_READ_REGISTER_RESPONSE; + +/** + * \brief set up API, must be called before any other API call + */ +void cdn_api_init(void); + +/** + * \brief Loads firmware + * + * \param iMem - pointer to instruction memory + * \param imemSize - size of instruction memory buffer + * \param dMem - pointer to data memory + * \param dmemSize - size of data memory buffer + * \return 0 if success, 1 if apb error encountered, 2 if CPU + * isn't alive after loading firmware + * + * This function does not require initialisation by #CDN_API_Init + */ + +CDN_API_STATUS cdn_api_loadfirmware(unsigned char *imem, + int imemsize, + unsigned char *dmem, int dmemsize); +/** + * \brief debug echo command for APB + * \param val - value to echo + * \return status + * + * will return #CDN_ERROR if reply message doesn't match request + */ +CDN_API_STATUS cdn_api_general_test_echo(unsigned int val, + CDN_BUS_TYPE bus_type); + +/** + * \brief blocking version of #CDN_API_General_Test_Echo + */ +CDN_API_STATUS cdn_api_general_test_echo_blocking(unsigned int val, + CDN_BUS_TYPE bus_type); + +/** + * \brief Extended Echo test for mailbox. + * + * This test will send msg buffer to firmware's mailbox and + * receive it back to the resp buffer. Received data will be + * check against data sent and status will be returned as well + * as received data. + * + * \param msg - Pointer to a buffer to send. + * \param resp - Pointer to buffer for receiving msg payload back. + * \param num_bytes - Number of bytes to send and receive. + * \param bus_type Bus type. + * \return status + * + * will return #CDN_ERROR if reply message doesn't match request or if + * arguments are invalid. + */ +CDN_API_STATUS cdn_api_general_test_echo_ext(u8 const *msg, u8 *resp, + u16 num_bytes, + CDN_BUS_TYPE bus_type); + +/** + * \brief blocking version of #CDN_API_General_Test_Echo_Ext + */ +CDN_API_STATUS cdn_api_general_test_echo_ext_blocking(u8 const *msg, + u8 *resp, + u16 num_bytes, + CDN_BUS_TYPE bus_type); + +/** + * \brief get current version + * \param [out] ver - fw version + * \param [out] libver - lib version + * \return status + * + * this function does not require #CDN_API_Init + */ +CDN_API_STATUS cdn_api_general_getcurversion(unsigned short *ver, + unsigned short *verlib); + +/** + * \brief read event value + * \param [out] event - pointer to store 32-bit events value + * \return status + * + * this function does not require #CDN_API_Init + */ +CDN_API_STATUS cdn_api_get_event(uint32_t *events); + +/** + * \brief read debug register value + * \param [out] val - pointer to store 16-bit debug reg value + * \return status + * + * this function does not require #CDN_API_Init + */ +CDN_API_STATUS cdn_api_get_debug_reg_val(uint16_t *val); + +/** + * \brief check if KEEP_ALIVE register changed + * \return #CDN_BSY if KEEP_ALIVE not changed, #CDN_OK if changed and #CDN_ERR + * if error occurred while reading + */ +CDN_API_STATUS cdn_api_checkalive(void); + +/** + * \breif blocking version of #CDN_API_CheckAlive + * blocks until KEEP_ALIVE register changes or error occurs while reading + */ +CDN_API_STATUS cdn_api_checkalive_blocking(void); + +/** + * \brief set cpu to standby or active + * \param [in] state - 1 for active, 0 for standby + * \return status + */ +CDN_API_STATUS cdn_api_maincontrol(unsigned char mode, unsigned char *resp); + +/** + * \breif blocking version of #CDN_API_MainControl + */ +CDN_API_STATUS cdn_api_maincontrol_blocking(unsigned char mode, + unsigned char *resp); + +/** + * \brief settings for APB + * + * Sends GENERAL_APB_CONF Command via regular Mailbox. + * @param dpcd_bus_sel Set DPCD to use selected bus (0 for APB or 1 for SAPB) + * @param dpcd_bus_lock Lock bus type. Aftern that bus type cannot be changed + * by using this function. + * @param hdcp_bus_sel Same meaning as for DPCD but for HDCP. + * @param hdcp_bus_lock Same meaning as for DPCD but for HDCP. + * @param capb_bus_sel Same meaning as for DPCD but for Cipher APB. + * @param capb_bus_lock Same meaning as for DPCD but for Cipher APB. + * @param dpcd_resp [out] Status of the operation. + * If set to zero then DPCD bus type was successfully changed. + * If not then error occurred, most likely due to locked DPCD bus. + * @param hdcp_resp [out] Same as for DPCD but for HDCP. + * @param capb_resp [out] Same as for DPCD but for Cipher APB. + * + * \return status + */ +CDN_API_STATUS cdn_api_apbconf(u8 dpcd_bus_sel, u8 dpcd_bus_lock, + u8 hdcp_bus_sel, u8 hdcp_bus_lock, + u8 capb_bus_sel, u8 capb_bus_lock, + u8 *dpcd_resp, u8 *hdcp_resp, + u8 *capb_resp); + +/** + * blocking version of #CDN_API_MainControl + */ +CDN_API_STATUS cdn_api_apbconf_blocking(u8 dpcd_bus_sel, + u8 dpcd_bus_lock, + u8 hdcp_bus_sel, + u8 hdcp_bus_lock, + u8 capb_bus_sel, + u8 capb_bus_lock, + u8 *dpcd_resp, + u8 *hdcp_resp, + u8 *capb_resp); + +/** + * \brief set the xtensa clk, write this api before turn on the cpu + */ +CDN_API_STATUS cdn_api_setclock(unsigned char mhz); + +CDN_API_STATUS cdn_api_general_read_register(unsigned int addr, + GENERAL_READ_REGISTER_RESPONSE + *resp); +CDN_API_STATUS +cdn_api_general_read_register_blocking(unsigned int addr, + GENERAL_READ_REGISTER_RESPONSE *resp); +CDN_API_STATUS cdn_api_general_write_register(unsigned int addr, + unsigned int val); +CDN_API_STATUS cdn_api_general_write_register_blocking(unsigned int addr, + unsigned int val); +CDN_API_STATUS cdn_api_general_write_field(unsigned int addr, + unsigned char startbit, + unsigned char bitsno, + unsigned int val); +CDN_API_STATUS cdn_api_general_write_field_blocking(unsigned int addr, + unsigned char startbit, + unsigned char bitsno, + unsigned int val); +CDN_API_STATUS cdn_api_general_phy_test_access(u8 *resp); +CDN_API_STATUS cdn_api_general_phy_test_access_blocking(u8 *resp); +CDN_API_STATUS hdp_rx_loadfirmware(unsigned char *imem, + int imemsize, + unsigned char *dmem, + int dmemsize); +#endif diff --git a/drivers/video/imx/hdp/Makefile b/drivers/video/imx/hdp/Makefile new file mode 100644 index 0000000000..034ba6c17e --- /dev/null +++ b/drivers/video/imx/hdp/Makefile @@ -0,0 +1,6 @@ +# +# Copyright 2019 NXP +# +# SPDX-License-Identifier: GPL-2.0+ +# +obj-$(CONFIG_VIDEO_IMX_HDP_LOAD) += API_General.o test_base_sw.o diff --git a/drivers/video/imx/hdp/address.h b/drivers/video/imx/hdp/address.h new file mode 100644 index 0000000000..396877e4f6 --- /dev/null +++ b/drivers/video/imx/hdp/address.h @@ -0,0 +1,78 @@ +/****************************************************************************** + * + * Copyright (C) 2016-2017 Cadence Design Systems, Inc. + * All rights reserved worldwide. + * + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: BSD-3-Clause + * + ****************************************************************************** + * + * address.h + * + ****************************************************************************** + */ + +#ifndef ADDRESS_H_ +# define ADDRESS_H_ + +# define ADDR_IMEM 0x10000 +# define ADDR_DMEM 0x20000 +# define ADDR_CIPHER 0x60000 +# define BASE_CIPHER 0x600 +# define ADDR_APB_CFG 0x00000 +# define BASE_APB_CFG 0x000 +# define ADDR_SOURCE_AIF_DECODER 0x30000 +# define BASE_SOURCE_AIF_DECODER 0x300 +# define ADDR_SOURCE_AIF_SMPL2PCKT 0x30080 +# define BASE_SOURCE_AIF_SMPL2PCKT 0x300 +# define ADDR_AIF_ENCODER 0x30000 +# define BASE_AIF_ENCODER 0x300 +# define ADDR_SOURCE_PIF 0x30800 +# define BASE_SOURCE_PIF 0x308 +# define ADDR_SINK_PIF 0x30800 +# define BASE_SINK_PIF 0x308 +# define ADDR_APB_CFG 0x00000 +# define BASE_APB_CFG 0x000 +# define ADDR_SOURCE_CSC 0x40000 +# define BASE_SOURCE_CSC 0x400 +# define ADDR_UCPU_CFG 0x00000 +# define BASE_UCPU_CFG 0x000 +# define ADDR_SOURCE_CAR 0x00900 +# define BASE_SOURCE_CAR 0x009 +# define ADDR_SINK_CAR 0x00900 +# define BASE_SINK_CAR 0x009 +# define ADDR_CLOCK_METERS 0x00A00 +# define BASE_CLOCK_METERS 0x00A +# define ADDR_SOURCE_VIF 0x00b00 +# define BASE_SOURCE_VIF 0x00b +# define ADDR_SINK_MHL_HD 0x01000 +# define ADDR_SINK_VIDEO_HD 0x01800 +# define BASE_SINK_MHL_HD 0x010 +# define ADDR_SINK_CORE 0x07800 +# define BASE_SINK_CORE 0x078 +# define ADDR_DPTX_PHY 0x02000 +# define BASE_DPTX_PHY 0x020 +# define ADDR_DPTX_HPD 0x02100 +# define BASE_DPTX_HPD 0x021 +# define ADDR_DPTX_FRAMER 0x02200 +# define BASE_DPTX_FRAMER 0x022 +# define ADDR_DPTX_STREAM 0x02200 +# define BASE_DPTX_STREAM 0x022 +# define ADDR_DPTX_GLBL 0x02300 +# define BASE_DPTX_GLBL 0x023 +# define ADDR_DPTX_HDCP 0x02400 +# define BASE_DPTX_HDCP 0x024 +# define ADDR_DP_AUX 0x02800 +# define BASE_DP_AUX 0x028 +# define ADDR_CRYPTO 0x05800 +# define BASE_CRYPTO 0x058 +# define ADDR_CIPHER 0x60000 +# define BASE_CIPHER 0x600 +# define ADDR_SOURCE_MHL_HD 0x01000 + +# define ADDR_AFE (0x20000 * 4) +# define ADDR_SOURCD_PHY (0x800) + +#endif diff --git a/drivers/video/imx/hdp/apb_cfg.h b/drivers/video/imx/hdp/apb_cfg.h new file mode 100644 index 0000000000..51b3dfea22 --- /dev/null +++ b/drivers/video/imx/hdp/apb_cfg.h @@ -0,0 +1,155 @@ +/****************************************************************************** + * + * Copyright (C) 2016-2017 Cadence Design Systems, Inc. + * All rights reserved worldwide. + * + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: BSD-3-Clause + * + ****************************************************************************** + * + * This file was auto-generated. Do not edit it manually. + * + ****************************************************************************** + * + * apb_cfg.h + * + ****************************************************************************** + */ + +#ifndef APB_CFG_H_ +#define APB_CFG_H_ + +/* register APB_CTRL */ +#define APB_CTRL 0 +#define F_APB_XT_RESET(x) (((x) & ((1 << 1) - 1)) << 0) +#define F_APB_XT_RESET_RD(x) (((x) & (((1 << 1) - 1) << 0)) >> 0) +#define F_APB_DRAM_PATH(x) (((x) & ((1 << 1) - 1)) << 1) +#define F_APB_DRAM_PATH_RD(x) (((x) & (((1 << 1) - 1) << 1)) >> 1) +#define F_APB_IRAM_PATH(x) (((x) & ((1 << 1) - 1)) << 2) +#define F_APB_IRAM_PATH_RD(x) (((x) & (((1 << 1) - 1) << 2)) >> 2) + +/* register XT_INT_CTRL */ +#define XT_INT_CTRL 1 +#define F_XT_INT_POLARITY(x) (((x) & ((1 << 2) - 1)) << 0) +#define F_XT_INT_POLARITY_RD(x) (((x) & (((1 << 2) - 1) << 0)) >> 0) + +/* register MAILBOX_FULL_ADDR */ +#define MAILBOX_FULL_ADDR 2 +#define F_MAILBOX_FULL(x) (((x) & ((1 << 1) - 1)) << 0) +#define F_MAILBOX_FULL_RD(x) (((x) & (((1 << 1) - 1) << 0)) >> 0) + +/* register MAILBOX_EMPTY_ADDR */ +#define MAILBOX_EMPTY_ADDR 3 +#define F_MAILBOX_EMPTY(x) (((x) & ((1 << 1) - 1)) << 0) +#define F_MAILBOX_EMPTY_RD(x) (((x) & (((1 << 1) - 1) << 0)) >> 0) + +/* register MAILBOX0_WR_DATA */ +#define MAILBOX0_WR_DATA 4 +#define F_MAILBOX0_WR_DATA(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_MAILBOX0_WR_DATA_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register MAILBOX0_RD_DATA */ +#define MAILBOX0_RD_DATA 5 +#define F_MAILBOX0_RD_DATA(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_MAILBOX0_RD_DATA_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register KEEP_ALIVE */ +#define KEEP_ALIVE 6 +#define F_KEEP_ALIVE_CNT(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_KEEP_ALIVE_CNT_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register VER_L */ +#define VER_L 7 +#define F_VER_LSB(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_VER_LSB_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register VER_H */ +#define VER_H 8 +#define F_VER_MSB(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_VER_MSB_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register VER_LIB_L_ADDR */ +#define VER_LIB_L_ADDR 9 +#define F_SW_LIB_VER_L(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_SW_LIB_VER_L_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register VER_LIB_H_ADDR */ +#define VER_LIB_H_ADDR 10 +#define F_SW_LIB_VER_H(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_SW_LIB_VER_H_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register SW_DEBUG_L */ +#define SW_DEBUG_L 11 +#define F_SW_DEBUG_7_0(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_SW_DEBUG_7_0_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register SW_DEBUG_H */ +#define SW_DEBUG_H 12 +#define F_SW_DEBUG_15_8(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_SW_DEBUG_15_8_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register MAILBOX_INT_MASK */ +#define MAILBOX_INT_MASK 13 +#define F_MAILBOX_INT_MASK(x) (((x) & ((1 << 2) - 1)) << 0) +#define F_MAILBOX_INT_MASK_RD(x) (((x) & (((1 << 2) - 1) << 0)) >> 0) + +/* register MAILBOX_INT_STATUS */ +#define MAILBOX_INT_STATUS 14 +#define F_MAILBOX_INT_STATUS(x) (((x) & ((1 << 2) - 1)) << 0) +#define F_MAILBOX_INT_STATUS_RD(x) (((x) & (((1 << 2) - 1) << 0)) >> 0) + +/* register SW_CLK_L */ +#define SW_CLK_L 15 +#define F_SW_CLOCK_VAL_L(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_SW_CLOCK_VAL_L_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register SW_CLK_H */ +#define SW_CLK_H 16 +#define F_SW_CLOCK_VAL_H(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_SW_CLOCK_VAL_H_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register SW_EVENTS0 */ +#define SW_EVENTS0 17 +#define F_SW_EVENTS7_0(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_SW_EVENTS7_0_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register SW_EVENTS1 */ +#define SW_EVENTS1 18 +#define F_SW_EVENTS15_8(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_SW_EVENTS15_8_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register SW_EVENTS2 */ +#define SW_EVENTS2 19 +#define F_SW_EVENTS23_16(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_SW_EVENTS23_16_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register SW_EVENTS3 */ +#define SW_EVENTS3 20 +#define F_SW_EVENTS31_24(x) (((x) & ((1 << 8) - 1)) << 0) +#define F_SW_EVENTS31_24_RD(x) (((x) & (((1 << 8) - 1) << 0)) >> 0) + +/* register XT_OCD_CTRL */ +#define XT_OCD_CTRL 24 +#define F_XT_DRESET(x) (((x) & ((1 << 1) - 1)) << 0) +#define F_XT_DRESET_RD(x) (((x) & (((1 << 1) - 1) << 0)) >> 0) +#define F_XT_OCDHALTONRESET(x) (((x) & ((1 << 1) - 1)) << 1) +#define F_XT_OCDHALTONRESET_RD(x) (((x) & (((1 << 1) - 1) << 1)) >> 1) + +/* register XT_OCD_CTRL_RO */ +#define XT_OCD_CTRL_RO 25 +#define F_XT_XOCDMODE(x) (((x) & ((1 << 1) - 1)) << 0) +#define F_XT_XOCDMODE_RD(x) (((x) & (((1 << 1) - 1) << 0)) >> 0) + +/* register APB_INT_MASK */ +#define APB_INT_MASK 27 +#define F_APB_INTR_MASK(x) (((x) & ((1 << 3) - 1)) << 0) +#define F_APB_INTR_MASK_RD(x) (((x) & (((1 << 3) - 1) << 0)) >> 0) + +/* register APB_STATUS_MASK */ +#define APB_STATUS_MASK 28 +#define F_APB_INTR_STATUS(x) (((x) & ((1 << 3) - 1)) << 0) +#define F_APB_INTR_STATUS_RD(x) (((x) & (((1 << 3) - 1) << 0)) >> 0) + +#endif /*APB_CFG*/ diff --git a/drivers/video/imx/hdp/externs.h b/drivers/video/imx/hdp/externs.h new file mode 100644 index 0000000000..109f2ed1c8 --- /dev/null +++ b/drivers/video/imx/hdp/externs.h @@ -0,0 +1,54 @@ +/****************************************************************************** + * + * Copyright (C) 2016-2017 Cadence Design Systems, Inc. + * All rights reserved worldwide. + * + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: BSD-3-Clause + * + ****************************************************************************** + * + * externs.h + * + ****************************************************************************** + */ + +#ifndef EXTERNS_H_ +#define EXTERNS_H_ + +#ifndef __UBOOT__ +#include <stdint.h> + +#else +#include <common.h> +#endif +/** + * \addtogroup UTILS + * { + */ +/** + * \brief read from apb + * \param addr - address to read + * \param value - pointer to store value + * \return non-zero value if error + */ +/*extern int cdn_bus_read(unsigned int addr, unsigned int* value);*/ + +/** + * \brief write to apb + * \param addr - address to write + * \param value - value to write + * \return non-zero if error + */ +/*extern int cdn_bus_write(unsigned int addr, unsigned int value);*/ + +u32 cdn_apb_read(u32 addr, u32 *value); +u32 cdn_sapb_read(u32 addr, u32 *value); +u32 cdn_apb_write(u32 addr, u32 value); +u32 cdn_sapb_write(u32 addr, u32 value); +u32 hdp_rx_apb_read(u32 addr, u32 *value); +u32 hdp_rx_sapb_read(u32 addr, u32 *value); +u32 hdp_rx_apb_write(u32 addr, u32 value); +u32 hdp_rx_sapb_write(u32 addr, u32 value); +#endif diff --git a/drivers/video/imx/hdp/general_handler.h b/drivers/video/imx/hdp/general_handler.h new file mode 100644 index 0000000000..3d176d9d9e --- /dev/null +++ b/drivers/video/imx/hdp/general_handler.h @@ -0,0 +1,132 @@ +/****************************************************************************** + * + * Copyright (C) 2016-2017 Cadence Design Systems, Inc. + * All rights reserved worldwide. + * + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: BSD-3-Clause + * + ****************************************************************************** + * + * general_handler.h + * + ****************************************************************************** + */ + +#ifndef GENERAL_HANDLER_H +#define GENERAL_HANDLER_H + +/** + * \file + * \brief general handler, checks available messages, receives + * it from mailbox, handles requests and sends response + * to the host + */ +#define DP_TX_MAIL_HANDLER_REQUEST_BUFFER_LEN 256 + +/** + * \brief opcode defines host->controller + */ +#define GENERAL_MAIN_CONTROL 0x01 +#define GENERAL_TEST_ECHO 0x02 +#define GENERAL_BUS_SETTINGS 0x03 +#define GENERAL_TEST_ACCESS 0x04 + +#define GENERAL_WRITE_REGISTER 0x05 +#define GENERAL_WRITE_FIELD 0x06 +#define GENERAL_READ_REGISTER 0x07 +#define GENERAL_GET_HPD_STATE 0x11 + +#define GENERAL_TEST_TRNG_SIMPLE 0xF0 + +#define GENERAL_MAIN_CONTROL_SET_ACTIVE_BIT 0 +#define GENERAL_MAIN_CONTROL_SET_ALT_CIPHER_ADDR 1 +#define GENERAL_MAIN_CONTROL_SET_FAST_HDCP_DELAYS 2 + +#define GENERAL_BUS_SETTINGS_DPCD_BUS_BIT 0 +#define GENERAL_BUS_SETTINGS_DPCD_BUS_LOCK_BIT 1 +#define GENERAL_BUS_SETTINGS_HDCP_BUS_BIT 2 +#define GENERAL_BUS_SETTINGS_HDCP_BUS_LOCK_BIT 3 +#define GENERAL_BUS_SETTINGS_CAPB_OWNER_BIT 4 +#define GENERAL_BUS_SETTINGS_CAPB_OWNER_LOCK_BIT 5 + +/** + * \brief opcode defines controller->host + */ + +#define GENERAL_MAIN_CONTROL_RESP 0x01 +#define GENERAL_TEST_ECHO_RESP 0x02 +#define GENERAL_BUS_SETTINGS_RESP 0x03 + +#define GENERAL_READ_REGISTER_RESP 0x07 + +#define GENERAL_BUS_SETTINGS_RESP_DPCD_BUS_BIT 0 +#define GENERAL_BUS_SETTINGS_RESP_HDCP_BUS_BIT 1 +#define GENERAL_BUS_SETTINGS_RESP_CAPB_OWNER_BIT 2 + +#define GENERAL_BUS_SETTINGS_RESP_SUCCESS 0 +#define GENERAL_BUS_SETTINGS_RESP_LOCK_ERROR 1 + +typedef struct { + unsigned char dpcd_locked; + unsigned char hdcp_locked; + unsigned char capb_locked; + unsigned char active_mode; +} S_GENERAL_HANDLER_DATA; + +/** + * \brief event id sent to the host + */ +typedef enum { + EVENT_ID_DPTX_HPD = 0, + EVENT_ID_HDMI_TX_HPD = 0, + EVENT_ID_HDMI_RX_5V = 0, + + EVENT_ID_DPTX_TRAINING = 1, + EVENT_ID_HDMI_RX_SCDC_CHANGE = 1, + + EVENT_ID_RESERVE0 = 2, + EVENT_ID_RESERVE1 = 3, + + EVENT_ID_HDCPTX_STATUS = 4, + EVENT_ID_HDCPRX_STATUS = 4, + + EVENT_ID_HDCPTX_IS_KM_STORED = 5, + EVENT_ID_HDCPTX_STORE_KM = 6, + EVENT_ID_HDCPTX_IS_RECEIVER_ID_VALID = 7, + EVENT_ID_HDMITX_READ_REQUEST = 8, +} EVENT_ID; + +/** + * \brief convert bank id and register number to address and write to ptr + */ + +#define select_reg_old(bank, reg_no, ptr) \ +do { \ + ptr = 0; \ + if ((bank == 0x22) || (bank == 0x20) || (bank == 0x0b) || \ + (bank == 0x09) || (bank == 0x0A)) \ + ptr = (unsigned int *)(bank << 8 | reg_no); \ +} while (0) + +#define select_reg(bank, reg_no, ptr) \ + ptr = (unsigned int *)(bank << 8 | reg_no) + +#define select_reg4(pmsb, p2, p3, plsb, ptr) \ + ptr = (unsigned int *)((pmsb << 24) | (p2 << 16) | \ + (p3 << 8) | (plsb << 0)) + +#define EVENTS_DPTX_CNT 2 +#define EVENTS_HDCPTX_CNT 4 + +void general_handler_set_active_mode(void); +void general_handler_set_standby_mode(void); + +/** + * \brief request sending en event to the host + * \param [in] eventId + * \param [in] eventCode + */ + +#endif /* GENERAL_HANDLER_H */ diff --git a/drivers/video/imx/hdp/opcodes.h b/drivers/video/imx/hdp/opcodes.h new file mode 100644 index 0000000000..239e8b255b --- /dev/null +++ b/drivers/video/imx/hdp/opcodes.h @@ -0,0 +1,85 @@ +/****************************************************************************** + * + * Copyright (C) 2016-2017 Cadence Design Systems, Inc. + * All rights reserved worldwide. + * + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: BSD-3-Clause + * + ****************************************************************************** + * + * This file was auto-generated. Do not edit it manually. + * + ****************************************************************************** + * + * opcodes.h + * + ****************************************************************************** + */ + +#ifndef OPCODES_H_ +# define OPCODES_H_ + +# define DP_TX_MAIL_HANDLER_H +# define DP_TX_MAIL_HANDLER_REQUEST_BUFFER_LEN 256 +# define DPTX_SET_POWER_MNG 0x00 +# define DPTX_SET_HOST_CAPABILITIES 0x01 +# define DPTX_GET_EDID 0x02 +# define DPTX_READ_DPCD 0x03 +# define DPTX_WRITE_DPCD 0x04 +# define DPTX_ENABLE_EVENT 0x05 +# define DPTX_WRITE_REGISTER 0x06 +# define DPTX_READ_REGISTER 0x07 +# define DPTX_WRITE_FIELD 0x08 +# define DPTX_TRAINING_CONTROL 0x09 +# define DPTX_READ_EVENT 0x0A +# define DPTX_READ_LINK_STAT 0x0B +# define DPTX_SET_VIDEO 0x0C +# define DPTX_SET_AUDIO 0x0D +# define DPTX_GET_LAST_AUX_STAUS 0x0E +# define DPTX_SET_LINK_BREAK_POINT 0x0F +# define DPTX_FORCE_LANES 0x10 +# define DPTX_HPD_STATE 0x11 +# define DPTX_DBG_SET 0xF0 +# define DP_TX_OPCODE_READ_I2C_REQUEST 0xA5 +# define DP_TX_OPCODE_WRITE_I2C_REQUEST 0xA6 +# define DP_TX_OPCODE_MESSAGE_FILTER 0xA7 +# define DPTX_EDID_RESP 0x02 +# define DPTX_DPCD_READ_RESP 0x03 +# define DPTX_DPCD_WRITE_RESP 0x04 +# define DPTX_READ_EVENT_RESP 0x0A +# define DPTX_READ_REGISTER_RESP 0x07 +# define DP_TX_OPCODE_MESSAGE 0x10 +# define DP_TX_OPCODE_READ_I2C_RESPONSE 0x50 +# define DP_TX_OPCODE_WRITE_I2C_RESPONSE 0x60 +# define DP_TX_OPCODE_LOOPBACK_TEST 0xFE +# define DP_TX_OPCODE_BIT_TEST 0xFF +# define DP_TX_EVENT_ENABLE_HPD_BIT 0x00 +# define DP_TX_EVENT_ENABLE_TRAINING_BIT 0x01 +# define DP_TX_EVENT_CODE_HPD_HIGH 0x01 +# define DP_TX_EVENT_CODE_HPD_LOW 0x02 +# define DP_TX_EVENT_CODE_HPD_PULSE 0x04 +# define DP_TX_EVENT_CODE_HPD_STATE_HIGH 0x08 +# define DP_TX_EVENT_CODE_HPD_STATE_LOW 0x00 +# define DP_TX_EVENT_CODE_TRAINING_FULL_STARTED 0x01 +# define DP_TX_EVENT_CODE_TRAINING_FAST_STARTED 0x02 +# define DP_TX_EVENT_CODE_TRAINING_FINISHED_CR 0x04 +# define DP_TX_EVENT_CODE_TRAINING_FINISHED_EQ 0x08 +# define DP_TX_EVENT_CODE_TRAINING_FINISHED_FAST 0x10 +# define DP_TX_EVENT_CODE_TRAINING_FAILED_CR 0x20 +# define DP_TX_EVENT_CODE_TRAINING_FAILED_EQ 0x40 +# define DP_TX_EVENT_CODE_TRAINING_FAILED_FAST 0x80 +# define MB_MODULE_ID_DP_TX 0x01 +# define MB_MODULE_ID_DP_RX 0x02 +# define MB_MODULE_ID_HDMI_TX 0x03 +# define MB_MODULE_ID_HDMI_RX 0x04 +# define MB_MODULE_ID_MHL_TX 0x05 +# define MB_MODULE_ID_MHL_RX 0x06 +# define MB_MODULE_ID_HDCP_TX 0x07 +# define MB_MODULE_ID_HDCP_RX 0x08 +# define MB_MODULE_ID_HDCP_GENERAL 0x09 +# define MB_MODULE_ID_GENERAL 0x0A +# define MB_MODULE_ID 1 + +#endif diff --git a/drivers/video/imx/hdp/test_base_sw.c b/drivers/video/imx/hdp/test_base_sw.c new file mode 100644 index 0000000000..38a13e6532 --- /dev/null +++ b/drivers/video/imx/hdp/test_base_sw.c @@ -0,0 +1,216 @@ +/****************************************************************************** + * + * Copyright (C) 2016-2017 Cadence Design Systems, Inc. + * All rights reserved worldwide. + * + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: BSD-3-Clause + * + ****************************************************************************** + * + * test_base_sw.c + * + ****************************************************************************** + */ + +#ifndef __UBOOT__ +#include <stdlib.h> +#include <string.h> +#include <stdio.h> +#else +#include <common.h> +#include <asm/io.h> + +#ifdef CONFIG_ARCH_IMX8M +/* mscale */ +#define HDMI_BASE 0x32c00000 +#define HDMI_PHY_BASE 0x32c80000 +#define HDMI_SEC_BASE 0x32e40000 +#endif +#ifdef CONFIG_ARCH_IMX8 +/* QM */ +#define HDMI_BASE 0x56268000 +#define HDMI_SEC_BASE 0x56269000 +#define HDMI_OFFSET_ADDR 0x56261008 +#define HDMI_SEC_OFFSET_ADDR 0x5626100c + +#define HDMI_RX_BASE 0x58268000 +#define HDMI_RX_SEC_BASE 0x58269000 +#define HDMI_RX_OFFSET_ADDR 0x58261004 +#define HDMI_RX_SEC_OFFSET_ADDR 0x58261008 +#endif + +#ifdef CONFIG_ARCH_LS1028A +#define HDMI_BASE 0xf200000 +#endif +#endif + +#ifdef CONFIG_ARCH_IMX8M +int cdn_apb_read(unsigned int addr, unsigned int *value) +{ + unsigned int temp; + u64 tmp_addr = addr + HDMI_BASE; + + temp = __raw_readl(tmp_addr); + *value = temp; + return 0; +} + +int cdn_apb_write(unsigned int addr, unsigned int value) +{ + u64 tmp_addr = addr + HDMI_BASE; + + __raw_writel(value, tmp_addr); + return 0; +} + +int cdn_sapb_read(unsigned int addr, unsigned int *value) +{ + unsigned int temp; + u64 tmp_addr = addr + HDMI_SEC_BASE; + + temp = __raw_readl(tmp_addr); + *value = temp; + return 0; +} + +int cdn_sapb_write(unsigned int addr, unsigned int value) +{ + u64 tmp_addr = addr + HDMI_SEC_BASE; + + __raw_writel(value, tmp_addr); + return 0; +} + +void cdn_sleep(uint32_t ms) +{ + mdelay(ms); +} + +void cdn_usleep(uint32_t us) +{ + udelay(us); +} +#endif +#ifdef CONFIG_ARCH_IMX8 +int cdn_apb_read(unsigned int addr, unsigned int *value) +{ + unsigned int temp; + u64 tmp_addr = (addr & 0xfff) + HDMI_BASE; + + __raw_writel(addr >> 12, HDMI_OFFSET_ADDR); + + temp = __raw_readl(tmp_addr); + *value = temp; + return 0; +} + +int cdn_apb_write(unsigned int addr, unsigned int value) +{ + u64 tmp_addr = (addr & 0xfff) + HDMI_BASE; + + __raw_writel(addr >> 12, HDMI_OFFSET_ADDR); + __raw_writel(value, tmp_addr); + + return 0; +} + +int cdn_sapb_read(unsigned int addr, unsigned int *value) +{ + unsigned int temp; + u64 tmp_addr = (addr & 0xfff) + HDMI_SEC_BASE; + + __raw_writel(addr >> 12, HDMI_SEC_OFFSET_ADDR); + + temp = __raw_readl(tmp_addr); + *value = temp; + return 0; +} + +int cdn_sapb_write(unsigned int addr, unsigned int value) +{ + u64 tmp_addr = (addr & 0xfff) + HDMI_SEC_BASE; + + __raw_writel(addr >> 12, HDMI_SEC_OFFSET_ADDR); + __raw_writel(value, tmp_addr); + + return 0; +} + +int hdp_rx_apb_read(unsigned int addr, unsigned int *value) +{ + unsigned int temp; + u64 tmp_addr = (addr & 0xfff) + HDMI_RX_BASE; + + __raw_writel(addr >> 12, HDMI_RX_OFFSET_ADDR); + + temp = __raw_readl(tmp_addr); + + *value = temp; + return 0; +} + +int hdp_rx_apb_write(unsigned int addr, unsigned int value) +{ + u64 tmp_addr = (addr & 0xfff) + HDMI_RX_BASE; + + __raw_writel(addr >> 12, HDMI_RX_OFFSET_ADDR); + + __raw_writel(value, tmp_addr); + + return 0; +} + +int hdp_rx_sapb_read(unsigned int addr, unsigned int *value) +{ + unsigned int temp; + u64 tmp_addr = (addr & 0xfff) + HDMI_RX_SEC_BASE; + + __raw_writel(addr >> 12, HDMI_RX_SEC_OFFSET_ADDR); + + temp = __raw_readl(tmp_addr); + *value = temp; + return 0; +} + +int hdp_rx_sapb_write(unsigned int addr, unsigned int value) +{ + u64 tmp_addr = (addr & 0xfff) + HDMI_RX_SEC_BASE; + + __raw_writel(addr >> 12, HDMI_RX_SEC_OFFSET_ADDR); + __raw_writel(value, tmp_addr); + + return 0; +} + +void cdn_sleep(uint32_t ms) +{ + mdelay(ms); +} + +void cdn_usleep(uint32_t us) +{ + udelay(us); +} +#endif + +#ifdef CONFIG_ARCH_LS1028A +int cdn_apb_read(unsigned int addr, unsigned int *value) +{ + unsigned int temp; + u64 tmp_addr = addr + HDMI_BASE; + + temp = __raw_readl(tmp_addr); + *value = temp; + return 0; +} + +int cdn_apb_write(unsigned int addr, unsigned int value) +{ + u64 tmp_addr = addr + HDMI_BASE; + + __raw_writel(value, tmp_addr); + return 0; +} +#endif diff --git a/drivers/video/imx/hdp/util.h b/drivers/video/imx/hdp/util.h new file mode 100644 index 0000000000..2c81ddce5b --- /dev/null +++ b/drivers/video/imx/hdp/util.h @@ -0,0 +1,256 @@ +/****************************************************************************** + * + * Copyright (C) 2016-2017 Cadence Design Systems, Inc. + * All rights reserved worldwide. + * + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: BSD-3-Clause + * + ****************************************************************************** + * + * util.h + * + ****************************************************************************** + */ + +#ifndef UTIL_H_ +#define UTIL_H_ + +#include "API_General.h" +#ifndef __UBOOT__ +#include <stdarg.h> +#include <stdint.h> +#else +#include <common.h> +#endif +/** + * \addtogroup UTILS + * { + */ +#define INTERNAL_CMD_HEAD_SIZE 4 + +/** + * \brief expands to blocking function body + * \param x - function call + */ +#define internal_block_function(x) \ +do { \ + CDN_API_STATUS ret; \ + do { \ + ret = x; \ + } while (ret == CDN_BSY || ret == CDN_STARTED); \ + return ret; \ +} while (0) + +/** + * \brief write message and write response (if any), non-blocking way. + * Also sets state.running = 0 + */ +#define INTERNAL_PROCESS_MESSAGES \ +do { \ + if (state.txenable && !internal_mbox_tx_process().txend) \ + return CDN_BSY; \ + if (state.rxenable && !internal_mbox_rx_process().rxend) \ + return CDN_BSY; \ + state.running = 0; \ +} while (0) + +#define internal_opcode_ok_or_return(module, opcode) \ +do { \ + CDN_API_STATUS ret = internal_test_rx_head(module, opcode); \ + if (ret != CDN_OK) \ + return ret; \ +} while (0) + +#define internal_opcode_match_or_return() \ +do { \ + CDN_API_STATUS ret = internal_test_rx_head_match(); \ + if (ret != CDN_OK) \ + return ret; \ +} while (0) + +/* + * macro for simple tx only command, command format as in mkfullmsg + * (with count) + */ +#define internal_macro_command_tx(module, opcode, bustype, command...) \ +do { \ + if (!state.running) { \ + internal_tx_mkfullmsg(module, opcode, command); \ + state.bus_type = bustype; \ + return CDN_STARTED; \ + } \ + INTERNAL_PROCESS_MESSAGES; \ +} while (0) + +/* + * macro for command with response with matching opcode, command format as in + * mkfullmsg (with count) + */ +#define internal_macro_command_txrx(module, opcode, bustype, command...) \ +do { \ + if (!state.running) { \ + internal_tx_mkfullmsg(module, opcode, command); \ + state.bus_type = bustype; \ + state.rxenable = 1; \ + return CDN_STARTED; \ + } \ + INTERNAL_PROCESS_MESSAGES; \ + internal_opcode_match_or_return(); \ +} while (0) + +typedef struct { + /** apb write status */ + enum tx_status_enum { + /** one or more bytes written */ + CDN_TX_WRITE = 0, + /** nothing to write */ + CDN_TX_NOTHING = 1, + /** mailbox full, 0 bytes written */ + CDN_TX_FULL = 2, + /** APB error while writing */ + CDN_TX_APB_ERROR = 3 + } tx_status:3; + /** apb read status */ + enum rx_status_enum { + /** 1 or more bytes read */ + CDN_RX_READ = 0, + /** mailbox empty, 0 bytes read */ + CDN_RX_EMPTY = 1, + /** apb error while reading */ + CDN_RX_APB_ERROR = 2 + } rx_status:2; + /** indicates end of currenly recived message */ + unsigned char rxend:1; + /** end of tx message reached */ + unsigned char txend:1; +} INTERNAL_MBOX_STATUS; + +/** + * \brief put val into dest in big endian format + * \param val - value to put + * \param dest - place to put value + * \param bytes - true size of val in bytes. for example if + * bytes = 2 val is treated as short int + */ +void internal_itobe(int val, volatile unsigned char *dest, int bytes); + +/** + * \brief read big endian value from src and return it + * \param src - source to read from + * \param bytes - size of read value + * \return result + */ +u32 internal_betoi(volatile u8 const *src, u8 bytes); + +/** + * \brief create message from size and value pairs; also sets + * state.running and state.txEnable + * \param dest - pointer to write message to + * \param valNo - number of values to write + * \param ... - pairs of size and value, each value is written + * after another. if size is positive value, value is + * written with #internal_itobe, if size is negative, + * value is treated as src pointer for memcpy + * + * example: + * + * unsigned short x = 0xAABB; + * + * internal_mkmsg(dest, 3, 1, 1, 2, 3, -2, &x); + * + * will write 01 00 03 AA BB to dest + */ +unsigned int internal_mkmsg(volatile unsigned char *dest, int valno, ...); +unsigned int internal_vmkmsg(volatile unsigned char *dest, int valno, + va_list vl); + +/** + * \brief setup message header in txBuffer, set txEnable = 1 + */ +void internal_mbox_tx_enable(unsigned char module, unsigned char opcode, + unsigned short length); + +/** + * \brief write from txBuffer to mailbox until full or end of message. + * + * when txEnable == 0 writes nothing + * when write reaches end of message set txEnable = 0 + */ + +/** + * \brief combination of #internal_mkmsg and #internal_mbox_tx_enable + * + * #internal_mkmsg dest and #internal_mbox_tx_enable length are determined + * automatically this function also sets state.txEnable = 1 and + * state.running + */ +void internal_tx_mkfullmsg(unsigned char module, unsigned char opcode, + int valno, ...); +void internal_vtx_mkfullmsg(unsigned char module, unsigned char opcode, + int valno, va_list vl); + +/** + * \brief read from state.txBuffer and store results in specified pointers + * \param valNo - numbero of values to read + * \param ... - pairs of size and ptr + * + * this function is similar to #internal_mkmsg - + * + * when size is positive read value using #internal_betoi + * when size is negative mempcy from txBuffer to ptr -size bytes + * when size is 0 write to ptr address of current position in rxbuffer + * when ptr is NULL ignore size bytes (if size is negative this + * will rewind buffer) + */ +void internal_readmsg(int valno, ...); +void internal_vreadmsg(int valno, va_list vl); + +INTERNAL_MBOX_STATUS internal_mbox_tx_process(void); +/** + * \brief read to rxBuffer from mailbox until empty or end of message + * + * when rxEnable == 0 reads nothing + * when end of message reached sets rxEnable = 0 + */ +INTERNAL_MBOX_STATUS internal_mbox_rx_process(void); + +/** + * \brief check if apb is available + * \return !(rxEnable && txEable) + */ +unsigned int internal_apb_available(void); + +/** + * \brief test if parameters match module and opcode in rxBuffer + * \return CDN_OK or CDN_BAD_OPCODE or CDN_BAD_MODULE + */ +CDN_API_STATUS internal_test_rx_head(unsigned char module, + unsigned char opcode); + +CDN_API_STATUS internal_test_rx_head_match(void); + +/** + * \brief print current fw and lib version + */ +void print_fw_ver(void); + +typedef struct { + unsigned char txbuffer[1024]; + unsigned char rxbuffer[1024]; + unsigned int txi; /* iterators */ + unsigned int rxi; + unsigned char txenable; /*data readt to send*/ + unsigned char rxenable; + unsigned char running; + CDN_BUS_TYPE bus_type; + unsigned int tmp; +} state_struct; + +extern state_struct state; +extern int cdn_bus_read(unsigned int addr, unsigned int *value); +extern int cdn_bus_write(unsigned int addr, unsigned int value); +unsigned short internal_get_msg_len(void); + +#endif diff --git a/drivers/video/imx/hdp_load.c b/drivers/video/imx/hdp_load.c new file mode 100644 index 0000000000..abfd9f4cd4 --- /dev/null +++ b/drivers/video/imx/hdp_load.c @@ -0,0 +1,58 @@ +/* + * Copyright 2018-2019 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <command.h> + +#include "API_General.h" + +DECLARE_GLOBAL_DATA_PTR; + +int do_hdp(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) +{ + if (argc < 2) + return 0; + + if (strncmp(argv[1], "load", 4) == 0) { + unsigned long address = 0; + unsigned long offset = 0x2000; + const int iram_size = 0x10000; + const int dram_size = 0x8000; + + if (argc > 2) { + address = simple_strtoul(argv[2], NULL, 0); + if (argc > 3) + offset = simple_strtoul(argv[3], NULL, 0); + } else { + printf("Missing address\n"); + } + + printf("Loading hdp firmware from 0x%016lx offset 0x%016lx\n", + address, offset); + cdn_api_loadfirmware((unsigned char *)(address + offset), + iram_size, + (unsigned char *)(address + offset + + iram_size), + dram_size); + printf("Loading hdp firmware Complete\n"); + /* do not turn off hdmi power or firmware load will be lost */ + } else { + printf("test error argc %d\n", argc); + } + + return 0; +} + +/***************************************************/ + +U_BOOT_CMD( + hdp, CONFIG_SYS_MAXARGS, 1, do_hdp, + "load hdmi firmware ", + "[<command>] ...\n" + "hdpload [address] [<offset>]\n" + " address - address where the binary image starts\n" + " <offset> - IRAM offset in the binary image (8192 default)\n" + );
Dear Anatolij Gustschin
-----Original Message----- From: Wen He Sent: Wednesday, May 15, 2019 3:32 PM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Jagdish Gediya jagdish.gediya@nxp.com; Alison Wang alison.wang@nxp.com; agust@denx.de; Oliver Brown oliver.brown@nxp.com; u-boot@lists.denx.de Cc: Wen He wen.he_1@nxp.com Subject: [v1] ls1028a: hdp: Add support for HDP firmware loading
Considering this is adding driver in drivers/video folder.
Can you please review it. Let me know if I need to delegate to you.
--pk
Prabhakar Kushwaha
Wen He
