[U-Boot] [PATCH] Revert "AT91:mmc:fix multiple read/write error"
This reverts commit c310fc840472a36e4b9d2505830e9dc8d458d63c.
The Atmel custodian had apparently rejected this patch's approach in another thread, so this patch reverts it for now.
Signed-off-by: Andy Fleming afleming@freescale.com --- I have pushed this up to my repository, and will submit a pull request if Reinhard agrees
drivers/mmc/atmel_mci.h | 9 +-------- drivers/mmc/gen_atmel_mci.c | 4 ---- 2 files changed, 1 insertions(+), 12 deletions(-)
diff --git a/drivers/mmc/atmel_mci.h b/drivers/mmc/atmel_mci.h index 3095d22..90ab6a8 100644 --- a/drivers/mmc/atmel_mci.h +++ b/drivers/mmc/atmel_mci.h @@ -36,7 +36,7 @@ typedef struct atmel_mci { u32 sdcr; /* 0x0c */ u32 argr; /* 0x10 */ u32 cmdr; /* 0x14 */ - u32 blkr; /* 0x18 */ + u32 _18; /* 0x18 */ u32 _1c; /* 0x1c */ u32 rspr; /* 0x20 */ u32 rspr1; /* 0x24 */ @@ -67,7 +67,6 @@ typedef struct atmel_mci { #define MMCI_SDCR 0x000c #define MMCI_ARGR 0x0010 #define MMCI_CMDR 0x0014 -#define MMCI_BLKR 0x0018 #define MMCI_RSPR 0x0020 #define MMCI_RSPR1 0x0024 #define MMCI_RSPR2 0x0028 @@ -141,12 +140,6 @@ typedef struct atmel_mci { #define MMCI_TRTYP_OFFSET 19 #define MMCI_TRTYP_SIZE 2
-/* Bitfields in BLKR */ -#define MMCI_BCNT_OFFSET 0 -#define MMCI_BCNT_SIZE 16 -#define MMCI_BLKLEN_OFFSET 16 -#define MMCI_BLKLEN_SIZE 16 - /* Bitfields in RSPRx */ #define MMCI_RSP_OFFSET 0 #define MMCI_RSP_SIZE 32 diff --git a/drivers/mmc/gen_atmel_mci.c b/drivers/mmc/gen_atmel_mci.c index d217574..f346b24 100644 --- a/drivers/mmc/gen_atmel_mci.c +++ b/drivers/mmc/gen_atmel_mci.c @@ -183,10 +183,6 @@ mci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) /* Figure out the transfer arguments */ cmdr = mci_encode_cmd(cmd, data, &error_flags);
- if (data) - writel(MMCI_BF(BCNT, data->blocks) | - MMCI_BF(BLKLEN, mmc->read_bl_len), &mci->blkr); - /* Send the command */ writel(cmd->cmdarg, &mci->argr); writel(cmdr, &mci->cmdr);
Dear Andy,
[U-Boot] [Question]AT91: MMC read and multiple read failed
Agreed, Thank you! Best Regards, Reinhard
PS: is your clock OK ? Your mail is dated from last Friday :)
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Reinhard Meyer Sent: 2011年8月3日 4:19 To: Andy Fleming Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH] Revert "AT91:mmc:fix multiple read/write error"
Dear Reinhard, Andy
[U-Boot] [Question]AT91: MMC read and multiple read failed I remember CC the patch to you: From: elen.song [mailto:elen.song@atmel.com] Sent: 2011年7月12日 18:17 To: u-boot@emk-elektronik.de Cc: u-boot@lists.denx.de; Song, Elen Subject: [PATCH] AT91:mmc:fix multiple read/write error
Anyway,is there any problem with the patch? And for support mmc on other boards later,should I send the email to you or Andy?
I have pushed this up to my repository, and will submit a pull request if >Reinhard agrees
Thank you! Best Regards, Elen
_______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Andy Fleming
Reinhard Meyer
Song, Elen
