[U-Boot] [PATCH 0/3] Add generic ioremap / iounmap defines
I ran Buildman for the whole series, and I did not see any regression.
01: Merge branch 'master' of git://git.denx.de/u-boot-uniphier openrisc: + openrisc-generic arc: + tb100 axs101 axs103 blackfin: + bf533-stamp cm-bf527 arm: + socfpga_is1 powerpc: + P1022DS_36BIT_NAND T2080QDS_SPIFLASH T1042RDB_PI_SPIFLASH P1010RDB-PA_36BIT_NAND P1010RDB-PB_SDCARD T1042D4RDB_NAND T4240RDB_SDCARD P1010RDB-PB_36BIT_NAND P1022DS_36BIT_SDCARD P1010RDB-PB_36BIT_SDCARD P1022DS_NAND T4160QDS_NAND T1042RDB_PI_NAND T2080RDB_NAND P1022DS_SDCARD T1042RDB_PI_SDCARD T2081QDS_NAND T4160QDS_SDCARD T2080QDS_SDCARD T4240QDS_SDCARD P1010RDB-PA_SPIFLASH T1040RDB_SDCARD B4860QDS_NAND P1010RDB-PA_36BIT_SDCARD T1040D4RDB_SDCARD T1040D4RDB_SPIFLASH T2080QDS_NAND T1040D4RDB_NAND P1010RDB-PB_SPIFLASH P1010RDB-PA_NAND T1040RDB_SPIFLASH kmcoge4 T2081QDS_SDCARD T2081QDS_SPIFLASH T4240QDS_NAND B4420QDS_NAND T1040RDB_NAND P1010RDB-PA_SDCARD T2080RDB_SPIFLASH P1010RDB-PB_NAND T1042D4RDB_SPIFLASH P1022DS_SPIFLASH T1042D4RDB_SDCARD kmlion1 P1022DS_36BIT_SPIFLASH P1010RDB-PB_36BIT_SPIFLASH T2080RDB_SDCARD P1010RDB-PA_36BIT_SPIFLASH [snip lots of error messages we have in the mainline] 02: types.h: move and redefine resource_size_t 03: arm, nds32, sh: remove useless ioremap()/iounmap() defines 04: linux/io.h: add generic ioremap()/iounmap() defines
Masahiro Yamada (3): types.h: move and redefine resource_size_t arm, nds32, sh: remove useless ioremap()/iounmap() defines linux/io.h: add generic ioremap()/iounmap() defines
arch/arm/include/asm/io.h | 34 ---------------------------------- arch/arm/include/asm/types.h | 1 - arch/nds32/include/asm/io.h | 34 ---------------------------------- arch/sh/include/asm/io.h | 33 --------------------------------- include/linux/io.h | 16 ++++++++++++++++ include/linux/types.h | 4 ++++ 6 files changed, 20 insertions(+), 102 deletions(-)
Currently, this is only defined in arch/arm/include/asm/types.h, so move it to include/linux/types.h to make it available for all architectures.
I defined it with phys_addr_t as Linux does. I needed to surround the define with #ifdef __KERNEL__ ... #endif to avoid build errors in tools building. (Host tools should not include <linux/types.h> in the first place, but this is already messy in U-Boot...)
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/include/asm/types.h | 1 - include/linux/types.h | 4 ++++ 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/types.h b/arch/arm/include/asm/types.h index d108915..9af7353 100644 --- a/arch/arm/include/asm/types.h +++ b/arch/arm/include/asm/types.h @@ -71,5 +71,4 @@ typedef u32 dma_addr_t;
#endif /* __KERNEL__ */
-typedef unsigned long resource_size_t; #endif diff --git a/include/linux/types.h b/include/linux/types.h index 6f75be4..416fa66 100644 --- a/include/linux/types.h +++ b/include/linux/types.h @@ -124,6 +124,10 @@ typedef __UINT64_TYPE__ u_int64_t; typedef __INT64_TYPE__ int64_t; #endif
+#ifdef __KERNEL__ +typedef phys_addr_t resource_size_t; +#endif + /* * Below are truly Linux-specific types that should never collide with * any application/library that wants linux/types.h.
These defines are valid only when iomem_valid_addr is defined, but I do not see such defines anywhere. Remove.
arch/arm/include/asm/io.h | 34 ---------------------------------- arch/nds32/include/asm/io.h | 34 ---------------------------------- arch/sh/include/asm/io.h | 33 --------------------------------- 3 files changed, 101 deletions(-)
diff --git a/arch/arm/include/asm/io.h b/arch/arm/include/asm/io.h index 9d185a6..6121f1d 100644 --- a/arch/arm/include/asm/io.h +++ b/arch/arm/include/asm/io.h @@ -292,40 +292,6 @@ static inline void __raw_readsl(unsigned long addr, void *data, int longlen) #define readsb(a, d, s) __raw_readsb((unsigned long)a, d, s)
/* - * ioremap and friends. - * - * ioremap takes a PCI memory address, as specified in - * linux/Documentation/IO-mapping.txt. If you want a - * physical address, use __ioremap instead. - */ -extern void * __ioremap(unsigned long offset, size_t size, unsigned long flags); -extern void __iounmap(void *addr); - -/* - * Generic ioremap support. - * - * Define: - * iomem_valid_addr(off,size) - * iomem_to_phys(off) - */ -#ifdef iomem_valid_addr -#define __arch_ioremap(off,sz,nocache) \ - ({ \ - unsigned long _off = (off), _size = (sz); \ - void *_ret = (void *)0; \ - if (iomem_valid_addr(_off, _size)) \ - _ret = __ioremap(iomem_to_phys(_off),_size,nocache); \ - _ret; \ - }) - -#define __arch_iounmap __iounmap -#endif - -#define ioremap(off,sz) __arch_ioremap((off),(sz),0) -#define ioremap_nocache(off,sz) __arch_ioremap((off),(sz),1) -#define iounmap(_addr) __arch_iounmap(_addr) - -/* * DMA-consistent mapping functions. These allocate/free a region of * uncached, unwrite-buffered mapped memory space for use with DMA * devices. This is the "generic" version. The PCI specific version diff --git a/arch/nds32/include/asm/io.h b/arch/nds32/include/asm/io.h index 04708e9..b2c4d0e 100644 --- a/arch/nds32/include/asm/io.h +++ b/arch/nds32/include/asm/io.h @@ -344,40 +344,6 @@ static inline void writesl(unsigned int *addr, const void * data, int longlen) #define insl_p(port, to, len) insl(port, to, len)
/* - * ioremap and friends. - * - * ioremap takes a PCI memory address, as specified in - * linux/Documentation/IO-mapping.txt. If you want a - * physical address, use __ioremap instead. - */ -extern void *__ioremap(unsigned long offset, size_t size, unsigned long flags); -extern void __iounmap(void *addr); - -/* - * Generic ioremap support. - * - * Define: - * iomem_valid_addr(off,size) - * iomem_to_phys(off) - */ -#ifdef iomem_valid_addr -#define __arch_ioremap(off, sz, nocache) \ -({ \ - unsigned long _off = (off), _size = (sz); \ - void *_ret = (void *)0; \ - if (iomem_valid_addr(_off, _size)) \ - _ret = __ioremap(iomem_to_phys(_off), _size, 0); \ - _ret; \ -}) - -#define __arch_iounmap __iounmap -#endif - -#define ioremap(off, sz) __arch_ioremap((off), (sz), 0) -#define ioremap_nocache(off, sz) __arch_ioremap((off), (sz), 1) -#define iounmap(_addr) __arch_iounmap(_addr) - -/* * DMA-consistent mapping functions. These allocate/free a region of * uncached, unwrite-buffered mapped memory space for use with DMA * devices. This is the "generic" version. The PCI specific version diff --git a/arch/sh/include/asm/io.h b/arch/sh/include/asm/io.h index 0a00db3..5dc27be 100644 --- a/arch/sh/include/asm/io.h +++ b/arch/sh/include/asm/io.h @@ -128,39 +128,6 @@ extern void __raw_readsl(unsigned int addr, void *data, int longlen); #define in_8(port) inb(port) #define in_le16(port) inw(port) #define in_le32(port) inl(port) -/* - * ioremap and friends. - * - * ioremap takes a PCI memory address, as specified in - * linux/Documentation/IO-mapping.txt. If you want a - * physical address, use __ioremap instead. - */ -extern void *__ioremap(unsigned long offset, size_t size, unsigned long flags); -extern void __iounmap(void *addr); - -/* - * Generic ioremap support. - * - * Define: - * iomem_valid_addr(off,size) - * iomem_to_phys(off) - */ -#ifdef iomem_valid_addr -#define __arch_ioremap(off, sz, nocache) \ -({ \ - unsigned long _off = (off), _size = (sz); \ - void *_ret = (void *)0; \ - if (iomem_valid_addr(_off, _size)) \ - _ret = __ioremap(iomem_to_phys(_off), _size, 0); \ - _ret; \ -}) - -#define __arch_iounmap __iounmap -#endif - -#define ioremap(off, sz) __arch_ioremap((off), (sz), 0) -#define ioremap_nocache(off, sz) __arch_ioremap((off), (sz), 1) -#define iounmap(_addr) __arch_iounmap(_addr)
For most of architectures in U-Boot, virtual address is straight mapped to physical address. So, it makes sense to have generic defines of ioremap and friends in <linux/io.h>.
All of them are just empty and will disappear at compile time, but they will be helpful to implement drivers which are counterparts of Linux ones.
I notice MIPS already has its own implementation, so I surrounded the defines with #ifndef CONFIG_MIPS ... #endif. I guess Sandbox will need its own implementation as well.
include/linux/io.h | 16 ++++++++++++++++ 1 file changed, 16 insertions(+)
diff --git a/include/linux/io.h b/include/linux/io.h index 1b36a22..ca23caa 100644 --- a/include/linux/io.h +++ b/include/linux/io.h @@ -5,6 +5,22 @@ #ifndef _LINUX_IO_H #define _LINUX_IO_H
+#include <linux/compiler.h> +#include <linux/types.h> #include <asm/io.h>
+#ifndef CONFIG_MIPS +static inline void __iomem *ioremap(resource_size_t offset, + resource_size_t size) +{ + return (void __iomem *)(unsigned long)offset; +} + +static inline void iounmap(void __iomem *addr) +{ +} + +#define devm_ioremap(dev, offset, size) ioremap(offset, size) +#endif + #endif /* _LINUX_IO_H */
Am 27.06.2016 um 10:32 schrieb Masahiro Yamada:
how about introducing a Kconfig symbol like CONFIG_HAVE_ARCH_IOREMAP which MIPS and Sandbox can select?
Hi Daniel,
2016-06-27 18:57 GMT+09:00 Daniel Schwierzeck daniel.schwierzeck@gmail.com:
Good idea!
I will do so in v2.
Daniel Schwierzeck
Masahiro Yamada
