[U-Boot] [PATCH 1/2] defconfigs: dra7xx_hs_evm: Add default OPTEE load address
Currently we let U-Boot find a spot at the end of DRAM at runtime, this forces us to build an OPTEE image based on the size of DRAM for an EVM. Add a default address that works across all current DRA7xx EVMs.
Signed-off-by: Andrew F. Davis afd@ti.com --- configs/dra7xx_hs_evm_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index e350d9f..b890a06 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -4,6 +4,9 @@ CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_TI_SECURE_DEVICE=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_DRA7XX_EVM=y +CONFIG_TI_SECURE_EMIF_REGION_START=0xbe000000 +CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 +CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_STACK_R_ADDR=0x82000000
Currently we let U-Boot find a spot at the end of DRAM at runtime, this forces us to build an OPTEE image based on the size of DRAM for an EVM. Add a default address that works across all current AM57xx EVMs.
Signed-off-by: Andrew F. Davis afd@ti.com --- configs/am57xx_hs_evm_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 2b1d695..c20c42e 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -3,6 +3,9 @@ CONFIG_OMAP54XX=y CONFIG_TI_SECURE_DEVICE=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_TARGET_AM57XX_EVM=y +CONFIG_TI_SECURE_EMIF_REGION_START=0xbe000000 +CONFIG_TI_SECURE_EMIF_TOTAL_REGION_SIZE=0x02000000 +CONFIG_TI_SECURE_EMIF_PROTECTED_REGION_SIZE=0x01c00000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_SPL_STACK_R_ADDR=0x82000000
Signed-off-by: Andrew F. Davis afd@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Andrew F. Davis
