[U-Boot] [PATCH] hwconfig: Fix handling of env_hwconfig, board_hwconfig, and cpu_hwconfig
The handling of env_hwconfig, board_hwconfig, and cpu_hwconfig got broken when we removed the boards defining dummy board_hwconfig & cpu_hwconfig values.
We fix this by handling the various strings in priority order. If hwconfig_parse returns NULL for a given string we check the next one in order (env_hwconfig, board_hwconfig, followed by cpu_hwconfig).
Signed-off-by: Kumar Gala galak@kernel.crashing.org --- common/hwconfig.c | 15 +++++++++------ 1 files changed, 9 insertions(+), 6 deletions(-)
diff --git a/common/hwconfig.c b/common/hwconfig.c index da8d3ed..193863a 100644 --- a/common/hwconfig.c +++ b/common/hwconfig.c @@ -75,7 +75,7 @@ const char board_hwconfig[] __attribute__((weak)) = "";
static const char *__hwconfig(const char *opt, size_t *arglen) { - const char *env_hwconfig = NULL; + const char *env_hwconfig = NULL, *ret; char buf[HWCONFIG_PRE_RELOC_BUF_SIZE];
if (gd->flags & GD_FLG_ENV_READY) { @@ -92,17 +92,20 @@ static const char *__hwconfig(const char *opt, size_t *arglen) env_hwconfig = buf; }
- if (env_hwconfig) - return hwconfig_parse(env_hwconfig, strlen(env_hwconfig), + if (env_hwconfig) { + ret = hwconfig_parse(env_hwconfig, strlen(env_hwconfig), opt, ";", ':', arglen); + if (ret) + return ret; + }
- return hwconfig_parse(board_hwconfig, strlen(board_hwconfig), + ret = hwconfig_parse(board_hwconfig, strlen(board_hwconfig), opt, ";", ':', arglen); + if (ret) + return ret;
return hwconfig_parse(cpu_hwconfig, strlen(cpu_hwconfig), opt, ";", ':', arglen); - - return NULL; }
I think the P1022DS is broken without this fix, but I can't get this patch to apply. Is there a pre-requisite patch that I'm missing?
-- Timur Tabi Linux kernel developer at Freescale
Try the latest HEAD of tree, Wolfgang pulled in the pre-req patch:
http://patchwork.ozlabs.org/patch/73656/
- k
Dear Kumar Gala,
In message 1291154307-21377-1-git-send-email-galak@kernel.crashing.org you wrote:
Applied, thanks.
Kumar Gala
Timur Tabi
