[U-Boot] [PATCH v1 1/1] fastboot: Add support for flashing zImage
This patch adds support to flash zImage to the boot partition on eMMC. Usage: fastboot flash zImage <path_to_zImage>
Signed-off-by: Angela Stegmaier angelabaker@ti.com
Signed-off-by: Dileep Katta dileep.katta@linaro.org --- drivers/usb/gadget/f_fastboot.c | 152 ++++++++++++++++++++++++++++++++++++++++ 1 file changed, 152 insertions(+)
diff --git a/drivers/usb/gadget/f_fastboot.c b/drivers/usb/gadget/f_fastboot.c index 310175a..d3d16c0 100644 --- a/drivers/usb/gadget/f_fastboot.c +++ b/drivers/usb/gadget/f_fastboot.c @@ -23,6 +23,7 @@ #ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV #include <fb_mmc.h> #endif +#include <android_image.h>
#define FASTBOOT_VERSION "0.4"
@@ -492,6 +493,152 @@ static void cb_continue(struct usb_ep *ep, struct usb_request *req) }
#ifdef CONFIG_FASTBOOT_FLASH +static int fastboot_update_zimage(void); + +static u32 fastboot_get_boot_ptn(struct andr_img_hdr *hdr, char *response, + block_dev_desc_t *dev_desc) +{ + u32 hdr_sectors = 0; + u32 sector_size; + int status = 0; + strcpy(response, "OKAY"); + disk_partition_t info; + + status = get_partition_info_efi_by_name(dev_desc, "boot", &info); + if (status) { + strcpy(response, "FAILCannot find boot partition"); + goto out; + } + + /* Read the boot image header */ + sector_size = info.blksz; + hdr_sectors = (sizeof(struct andr_img_hdr)/sector_size) + 1; + status = dev_desc->block_read(dev_desc->dev, info.start, + hdr_sectors, (void *)hdr); + + if (status < 0) { + strcpy(response, "FAILCannot read hdr from boot partition"); + goto out; + } + if (android_image_check_header(hdr) != 0) { + printf("bad boot image magic\n"); + strcpy(response, "FAILBoot partition not initialized"); + goto out; + } + + return hdr_sectors; + +out: + strcpy(response, "INFO"); + fastboot_tx_write_str(response); + + return -1; +} + +#define CEIL(a, b) (((a) / (b)) + ((a % b) > 0 ? 1 : 0)) + +static int fastboot_update_zimage(void) +{ + struct andr_img_hdr *hdr = NULL; + u8 *ramdisk_buffer; + u32 ramdisk_sector_start, ramdisk_sectors; + u32 kernel_sector_start, kernel_sectors; + u32 hdr_sectors = 0; + u32 sectors_per_page = 0; + int ret = 0; + block_dev_desc_t *dev_desc; + disk_partition_t info; + char response[RESPONSE_LEN]; + u32 addr = CONFIG_USB_FASTBOOT_BUF_ADDR; + + strcpy(response, "OKAY"); + printf("Flashing zImage...%d bytes\n", download_bytes); + + dev_desc = get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV); + if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) { + sprintf(response + strlen(response), + "FAILInvalid mmc device"); + ret = -1; + goto out; + } + + addr += CEIL(download_bytes, 0x1000) * 0x1000; + hdr = (struct andr_img_hdr *)addr; + + hdr_sectors = fastboot_get_boot_ptn(hdr, response, dev_desc); + if (hdr_sectors <= 0) { + sprintf(response + strlen(response), + "FAILInvalid number of boot sectors %d", hdr_sectors); + ret = -1; + goto out; + } + ret = get_partition_info_efi_by_name(dev_desc, "boot", &info); + if (ret) { + strcpy(response, "FAILCannot find boot partition"); + ret = -1; + goto out; + } + + /* Extract ramdisk location and read it into local buffer */ + sectors_per_page = hdr->page_size / info.blksz; + ramdisk_sector_start = info.start + sectors_per_page; + ramdisk_sector_start += CEIL(hdr->kernel_size, hdr->page_size)* + sectors_per_page; + ramdisk_sectors = CEIL(hdr->ramdisk_size, hdr->page_size)* + sectors_per_page; + + ramdisk_buffer = (u8 *)hdr; + ramdisk_buffer += (hdr_sectors * info.blksz); + ret = dev_desc->block_read(dev_desc->dev, ramdisk_sector_start, + ramdisk_sectors, ramdisk_buffer); + if (ret < 0) { + sprintf(response, "FAILCannot read ramdisk from 'boot'"); + ret = -1; + goto out; + } + + /* Change the boot img hdr */ + hdr->kernel_size = download_bytes; + ret = dev_desc->block_write(dev_desc->dev, info.start, + hdr_sectors, (void *)hdr); + if (ret < 0) { + sprintf(response, "FAILCannot writeback boot img hdr"); + ret = -1; + goto out; + } + + /* Write the new downloaded kernel*/ + kernel_sector_start = info.start + sectors_per_page; + kernel_sectors = CEIL(hdr->kernel_size, hdr->page_size)* + sectors_per_page; + ret = dev_desc->block_write(dev_desc->dev, kernel_sector_start, + kernel_sectors, + (const void *)CONFIG_USB_FASTBOOT_BUF_ADDR); + if (ret < 0) { + sprintf(response, "FAILCannot write new kernel"); + ret = -1; + goto out; + } + + /* Write the saved Ramdisk back */ + ramdisk_sector_start = info.start + sectors_per_page; + ramdisk_sector_start += CEIL(hdr->kernel_size, hdr->page_size)* + sectors_per_page; + ret = dev_desc->block_write(dev_desc->dev, ramdisk_sector_start, + ramdisk_sectors, ramdisk_buffer); + if (ret < 0) { + sprintf(response, "FAILCannot write back original ramdisk"); + ret = -1; + goto out; + } + fastboot_tx_write_str(response); + return 0; + +out: + fastboot_tx_write_str(response); + return ret; +} + static void cb_flash(struct usb_ep *ep, struct usb_request *req) { char *cmd = req->buf; @@ -505,6 +652,11 @@ static void cb_flash(struct usb_ep *ep, struct usb_request *req) }
strcpy(response, "FAILno flash device defined"); + + if (!strcmp(cmd, "zImage") || !strcmp(cmd, "zimage")) { + fastboot_update_zimage(); + return; + } #ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV fb_mmc_flash_write(cmd, (void *)CONFIG_USB_FASTBOOT_BUF_ADDR, download_bytes, response);
So this replaces the kernel in an existing bootimage. What's wrong with "fastboot flash boot", "fastboot flash:raw boot <kernel>" or "fastboot boot <kernel>"? It is a bit fragile to be updating your kernel without updating the ramdisk. arm64 has no zImage, so this command is somewhat arm32 specific.
Fastboot is already plagued with a variety of implementations and behaviors. Some unification here would be good and just adding whatever various commands have been added to vendor u-boot's is not going to help. Adding to the combinations of things to test also bothers me.
Rob
u32 sector_size;
int status = 0;
if (status) {
goto out;
if (status < 0) {
goto out;
goto out;
return hdr_sectors;
+out:
return -1;
u8 *ramdisk_buffer;
int ret = 0;
ret = -1;
goto out;
ret = -1;
goto out;
if (ret) {
ret = -1;
goto out;
sectors_per_page;
sectors_per_page;
if (ret < 0) {
ret = -1;
goto out;
if (ret < 0) {
ret = -1;
goto out;
sectors_per_page;
kernel_sectors,
if (ret < 0) {
ret = -1;
goto out;
sectors_per_page;
if (ret < 0) {
ret = -1;
goto out;
+out:
return ret;
return;
#ifdef CONFIG_FASTBOOT_FLASH_MMC_DEV fb_mmc_flash_write(cmd, (void *)CONFIG_USB_FASTBOOT_BUF_ADDR, download_bytes, response); -- 1.8.3.2
+1. Just how much room do we have, or not have, to be compatible with existing tools but also abstract some of this out so that different boards can "I want a layout like this ..." (one set of kernel, device tree, initrd) and another "I want a layout like this ..." (two sets, for redundancy).
Hi Rob,
Rob
block_dev_desc_t
*dev_desc) +{
u32 sector_size;
int status = 0;
&info);
if (status) {
goto out;
if (status < 0) {
partition");
goto out;
initialized");
goto out;
return hdr_sectors;
+out:
return -1;
u8 *ramdisk_buffer;
int ret = 0;
ret = -1;
goto out;
dev_desc);
hdr_sectors);
ret = -1;
goto out;
&info);
if (ret) {
ret = -1;
goto out;
hdr->page_size)*
sectors_per_page;
sectors_per_page;
if (ret < 0) {
'boot'");
ret = -1;
goto out;
if (ret < 0) {
hdr");
ret = -1;
goto out;
sectors_per_page;
kernel_sectors,
(const void
if (ret < 0) {
ret = -1;
goto out;
hdr->page_size)*
sectors_per_page;
ramdisk_sectors,
ramdisk_buffer);
if (ret < 0) {
ramdisk");
ret = -1;
goto out;
+out:
return ret;
return;
1.8.3.2
Is this patch dropped or will there be any new revision?
Hi Lukasz,
On 4 March 2015 at 18:38, Lukasz Majewski l.majewski@samsung.com wrote:
Hi Rob,
Rob
block_dev_desc_t
*dev_desc) +{
u32 sector_size;
int status = 0;
&info);
if (status) {
goto out;
if (status < 0) {
partition");
goto out;
initialized");
goto out;
return hdr_sectors;
+out:
return -1;
u8 *ramdisk_buffer;
int ret = 0;
ret = -1;
goto out;
dev_desc);
hdr_sectors);
ret = -1;
goto out;
&info);
if (ret) {
ret = -1;
goto out;
hdr->page_size)*
sectors_per_page;
sectors_per_page;
if (ret < 0) {
'boot'");
ret = -1;
goto out;
if (ret < 0) {
hdr");
ret = -1;
goto out;
sectors_per_page;
kernel_sectors,
(const void
if (ret < 0) {
ret = -1;
goto out;
hdr->page_size)*
sectors_per_page;
ramdisk_sectors,
ramdisk_buffer);
if (ret < 0) {
ramdisk");
ret = -1;
goto out;
+out:
return ret;
return;
1.8.3.2
I am verifying existing flash commands with zImage, and if required there might be a new version for this patch.
-- Best regards,
Lukasz Majewski
Samsung R&D Institute Poland (SRPOL) | Linux Platform Group
Regards, Dileep
Hi Dileep,
^^^^^ could you explain this acronym? My gut feeling is that this function name could be better. As fair as I can tell you return number of header sectors.
*response,
block_dev_desc_t
*dev_desc) +{
- u32 hdr_sectors = 0;
- u32 sector_size;
- int status = 0;
- strcpy(response, "OKAY");
- disk_partition_t info;
- status = get_partition_info_efi_by_name(dev_desc, "boot",
&info);
- if (status) {
goto out;
- /* Read the boot image header */
- sector_size = info.blksz;
- hdr_sectors = (sizeof(struct andr_img_hdr)/sector_size) + 1;
^^^ checkpatch.pl would complain about this line.
- status = dev_desc->block_read(dev_desc->dev, info.start,
- if (status < 0) {
partition");
goto out;
- if (android_image_check_header(hdr) != 0) {
^^^^^^ error()?
initialized");
goto out;
- return hdr_sectors;
+out:
- strcpy(response, "INFO");
- fastboot_tx_write_str(response);
- return -1;
Please use appropriate -Exxxxx error code in the whole file.
Maybe you could add this code to ./include/common.h file, so it would be reusable in the future?
- struct andr_img_hdr *hdr = NULL;
- u8 *ramdisk_buffer;
- u32 ramdisk_sector_start, ramdisk_sectors;
- u32 kernel_sector_start, kernel_sectors;
- u32 sectors_per_page = 0;
- int ret = 0;
- block_dev_desc_t *dev_desc;
- char response[RESPONSE_LEN];
^^^^^^^^^^^^ this is defined as (64 + 1) Isn't there any change that such unaligned buffer would cause cache flush/invalidation related bugs?
Please look into ALLOC_CACHE_ALIGN_BUFFER comment at ./include/common.h file
- u32 addr = CONFIG_USB_FASTBOOT_BUF_ADDR;
- printf("Flashing zImage...%d bytes\n", download_bytes);
- dev_desc = get_dev("mmc", CONFIG_FASTBOOT_FLASH_MMC_DEV);
- if (!dev_desc || dev_desc->type == DEV_TYPE_UNKNOWN) {
ret = -1;
goto out;
- addr += CEIL(download_bytes, 0x1000) * 0x1000;
^^^^^^ Please use define for this magic number. It would be more informative.
- hdr = (struct andr_img_hdr *)addr;
- hdr_sectors = fastboot_get_boot_ptn(hdr, response, dev_desc);
^^^ the comment the same as above.
- if (hdr_sectors <= 0) {
hdr_sectors);
ret = -1;
goto out;
- ret = get_partition_info_efi_by_name(dev_desc, "boot",
&info);
- if (ret) {
ret = -1;
goto out;
- /* Extract ramdisk location and read it into local buffer */
- sectors_per_page = hdr->page_size / info.blksz;
- ramdisk_sector_start = info.start + sectors_per_page;
- ramdisk_sector_start += CEIL(hdr->kernel_size,
hdr->page_size)*
sectors_per_page;
- ramdisk_sectors = CEIL(hdr->ramdisk_size, hdr->page_size)*
sectors_per_page;
- ramdisk_buffer = (u8 *)hdr;
- ramdisk_buffer += (hdr_sectors * info.blksz);
- ret = dev_desc->block_read(dev_desc->dev,
- if (ret < 0) {
'boot'");
ret = -1;
goto out;
- /* Change the boot img hdr */
- hdr->kernel_size = download_bytes;
- ret = dev_desc->block_write(dev_desc->dev, info.start,
- if (ret < 0) {
hdr");
ret = -1;
goto out;
- /* Write the new downloaded kernel*/
- kernel_sector_start = info.start + sectors_per_page;
- kernel_sectors = CEIL(hdr->kernel_size, hdr->page_size)*
sectors_per_page;
kernel_sectors,
(const void
- if (ret < 0) {
ret = -1;
goto out;
- /* Write the saved Ramdisk back */
hdr->page_size)*
sectors_per_page;
- if (ret < 0) {
ramdisk");
ret = -1;
goto out;
+out:
- return ret;
- if (!strcmp(cmd, "zImage") || !strcmp(cmd, "zimage")) {
Maybe you could use strcasecmp() function from ./lib/string.c?
return;
Dileep Katta
Lukasz Majewski
Rob Herring
