[U-Boot] [PATCH v4 2/2] socfpga: Adding System Manager driver
Adding the generated pin mux configuration by Preloader Generator tool
Signed-off-by: Chin Liang See clsee@altera.com Reviewed-by: Pavel Machek pavel@denx.de Cc: Wolfgang Denk wd@denx.de CC: Pavel Machek pavel@denx.de Cc: Dinh Nguyen dinguyen@altera.com --- Changes for v2: - Fixed the word wrap issue within patch Changes for v3: - Fixed the long subject of the patch Changes for v4: - Added change log for each revision change
board/altera/socfpga_cyclone5/pinmux_config.c | 214 +++++++++++++++++++++++++ board/altera/socfpga_cyclone5/pinmux_config.h | 54 +++++++ 2 files changed, 268 insertions(+) create mode 100644 board/altera/socfpga_cyclone5/pinmux_config.c create mode 100644 board/altera/socfpga_cyclone5/pinmux_config.h
diff --git a/board/altera/socfpga_cyclone5/pinmux_config.c b/board/altera/socfpga_cyclone5/pinmux_config.c new file mode 100644 index 0000000..8b09005 --- /dev/null +++ b/board/altera/socfpga_cyclone5/pinmux_config.c @@ -0,0 +1,214 @@ +/* This file is generated by Preloader Generator */ + +#include "pinmux_config.h" + +/* pin mux configuration data */ +unsigned long sys_mgr_init_table[CONFIG_HPS_PINMUX_NUM] = { + 0, /* EMACIO0 - Unused */ + 2, /* EMACIO1 - USB */ + 2, /* EMACIO2 - USB */ + 2, /* EMACIO3 - USB */ + 2, /* EMACIO4 - USB */ + 2, /* EMACIO5 - USB */ + 2, /* EMACIO6 - USB */ + 2, /* EMACIO7 - USB */ + 2, /* EMACIO8 - USB */ + 0, /* EMACIO9 - Unused */ + 2, /* EMACIO10 - USB */ + 2, /* EMACIO11 - USB */ + 2, /* EMACIO12 - USB */ + 2, /* EMACIO13 - USB */ + 0, /* EMACIO14 - N/A */ + 0, /* EMACIO15 - N/A */ + 0, /* EMACIO16 - N/A */ + 0, /* EMACIO17 - N/A */ + 0, /* EMACIO18 - N/A */ + 0, /* EMACIO19 - N/A */ + 3, /* FLASHIO0 - SDMMC */ + 3, /* FLASHIO1 - SDMMC */ + 3, /* FLASHIO2 - SDMMC */ + 3, /* FLASHIO3 - SDMMC */ + 0, /* FLASHIO4 - SDMMC */ + 0, /* FLASHIO5 - SDMMC */ + 0, /* FLASHIO6 - SDMMC */ + 0, /* FLASHIO7 - SDMMC */ + 0, /* FLASHIO8 - SDMMC */ + 3, /* FLASHIO9 - SDMMC */ + 3, /* FLASHIO10 - SDMMC */ + 3, /* FLASHIO11 - SDMMC */ + 3, /* GENERALIO0 - TRACE */ + 3, /* GENERALIO1 - TRACE */ + 3, /* GENERALIO2 - TRACE */ + 3, /* GENERALIO3 - TRACE */ + 3, /* GENERALIO4 - TRACE */ + 3, /* GENERALIO5 - TRACE */ + 3, /* GENERALIO6 - TRACE */ + 3, /* GENERALIO7 - TRACE */ + 3, /* GENERALIO8 - TRACE */ + 3, /* GENERALIO9 - SPIM0 */ + 3, /* GENERALIO10 - SPIM0 */ + 3, /* GENERALIO11 - SPIM0 */ + 3, /* GENERALIO12 - SPIM0 */ + 2, /* GENERALIO13 - CAN0 */ + 2, /* GENERALIO14 - CAN0 */ + 3, /* GENERALIO15 - I2C0 */ + 3, /* GENERALIO16 - I2C0 */ + 2, /* GENERALIO17 - UART0 */ + 2, /* GENERALIO18 - UART0 */ + 0, /* GENERALIO19 - N/A */ + 0, /* GENERALIO20 - N/A */ + 0, /* GENERALIO21 - N/A */ + 0, /* GENERALIO22 - N/A */ + 0, /* GENERALIO23 - N/A */ + 0, /* GENERALIO24 - N/A */ + 0, /* GENERALIO25 - N/A */ + 0, /* GENERALIO26 - N/A */ + 0, /* GENERALIO27 - N/A */ + 0, /* GENERALIO28 - N/A */ + 0, /* GENERALIO29 - N/A */ + 0, /* GENERALIO30 - N/A */ + 0, /* GENERALIO31 - N/A */ + 2, /* MIXED1IO0 - EMAC */ + 2, /* MIXED1IO1 - EMAC */ + 2, /* MIXED1IO2 - EMAC */ + 2, /* MIXED1IO3 - EMAC */ + 2, /* MIXED1IO4 - EMAC */ + 2, /* MIXED1IO5 - EMAC */ + 2, /* MIXED1IO6 - EMAC */ + 2, /* MIXED1IO7 - EMAC */ + 2, /* MIXED1IO8 - EMAC */ + 2, /* MIXED1IO9 - EMAC */ + 2, /* MIXED1IO10 - EMAC */ + 2, /* MIXED1IO11 - EMAC */ + 2, /* MIXED1IO12 - EMAC */ + 2, /* MIXED1IO13 - EMAC */ + 0, /* MIXED1IO14 - Unused */ + 3, /* MIXED1IO15 - QSPI */ + 3, /* MIXED1IO16 - QSPI */ + 3, /* MIXED1IO17 - QSPI */ + 3, /* MIXED1IO18 - QSPI */ + 3, /* MIXED1IO19 - QSPI */ + 3, /* MIXED1IO20 - QSPI */ + 0, /* MIXED1IO21 - GPIO */ + 0, /* MIXED2IO0 - N/A */ + 0, /* MIXED2IO1 - N/A */ + 0, /* MIXED2IO2 - N/A */ + 0, /* MIXED2IO3 - N/A */ + 0, /* MIXED2IO4 - N/A */ + 0, /* MIXED2IO5 - N/A */ + 0, /* MIXED2IO6 - N/A */ + 0, /* MIXED2IO7 - N/A */ + 0, /* GPLINMUX48 */ + 0, /* GPLINMUX49 */ + 0, /* GPLINMUX50 */ + 0, /* GPLINMUX51 */ + 0, /* GPLINMUX52 */ + 0, /* GPLINMUX53 */ + 0, /* GPLINMUX54 */ + 0, /* GPLINMUX55 */ + 0, /* GPLINMUX56 */ + 0, /* GPLINMUX57 */ + 0, /* GPLINMUX58 */ + 0, /* GPLINMUX59 */ + 0, /* GPLINMUX60 */ + 0, /* GPLINMUX61 */ + 0, /* GPLINMUX62 */ + 0, /* GPLINMUX63 */ + 0, /* GPLINMUX64 */ + 0, /* GPLINMUX65 */ + 0, /* GPLINMUX66 */ + 0, /* GPLINMUX67 */ + 0, /* GPLINMUX68 */ + 0, /* GPLINMUX69 */ + 0, /* GPLINMUX70 */ + 1, /* GPLMUX0 */ + 1, /* GPLMUX1 */ + 1, /* GPLMUX2 */ + 1, /* GPLMUX3 */ + 1, /* GPLMUX4 */ + 1, /* GPLMUX5 */ + 1, /* GPLMUX6 */ + 1, /* GPLMUX7 */ + 1, /* GPLMUX8 */ + 1, /* GPLMUX9 */ + 1, /* GPLMUX10 */ + 1, /* GPLMUX11 */ + 1, /* GPLMUX12 */ + 1, /* GPLMUX13 */ + 1, /* GPLMUX14 */ + 1, /* GPLMUX15 */ + 1, /* GPLMUX16 */ + 1, /* GPLMUX17 */ + 1, /* GPLMUX18 */ + 1, /* GPLMUX19 */ + 1, /* GPLMUX20 */ + 1, /* GPLMUX21 */ + 1, /* GPLMUX22 */ + 1, /* GPLMUX23 */ + 1, /* GPLMUX24 */ + 1, /* GPLMUX25 */ + 1, /* GPLMUX26 */ + 1, /* GPLMUX27 */ + 1, /* GPLMUX28 */ + 1, /* GPLMUX29 */ + 1, /* GPLMUX30 */ + 1, /* GPLMUX31 */ + 1, /* GPLMUX32 */ + 1, /* GPLMUX33 */ + 1, /* GPLMUX34 */ + 1, /* GPLMUX35 */ + 1, /* GPLMUX36 */ + 1, /* GPLMUX37 */ + 1, /* GPLMUX38 */ + 1, /* GPLMUX39 */ + 1, /* GPLMUX40 */ + 1, /* GPLMUX41 */ + 1, /* GPLMUX42 */ + 1, /* GPLMUX43 */ + 1, /* GPLMUX44 */ + 1, /* GPLMUX45 */ + 1, /* GPLMUX46 */ + 1, /* GPLMUX47 */ + 1, /* GPLMUX48 */ + 1, /* GPLMUX49 */ + 1, /* GPLMUX50 */ + 1, /* GPLMUX51 */ + 1, /* GPLMUX52 */ + 1, /* GPLMUX53 */ + 1, /* GPLMUX54 */ + 1, /* GPLMUX55 */ + 1, /* GPLMUX56 */ + 1, /* GPLMUX57 */ + 1, /* GPLMUX58 */ + 1, /* GPLMUX59 */ + 1, /* GPLMUX60 */ + 1, /* GPLMUX61 */ + 1, /* GPLMUX62 */ + 1, /* GPLMUX63 */ + 1, /* GPLMUX64 */ + 1, /* GPLMUX65 */ + 1, /* GPLMUX66 */ + 1, /* GPLMUX67 */ + 1, /* GPLMUX68 */ + 1, /* GPLMUX69 */ + 1, /* GPLMUX70 */ + 0, /* NANDUSEFPGA */ + 0, /* UART0USEFPGA */ + 0, /* RGMII1USEFPGA */ + 0, /* SPIS0USEFPGA */ + 0, /* CAN0USEFPGA */ + 0, /* I2C0USEFPGA */ + 0, /* SDMMCUSEFPGA */ + 0, /* QSPIUSEFPGA */ + 0, /* SPIS1USEFPGA */ + 0, /* RGMII0USEFPGA */ + 0, /* UART1USEFPGA */ + 0, /* CAN1USEFPGA */ + 0, /* USB1USEFPGA */ + 0, /* I2C3USEFPGA */ + 0, /* I2C2USEFPGA */ + 0, /* I2C1USEFPGA */ + 0, /* SPIM1USEFPGA */ + 0, /* USB0USEFPGA */ + 0 /* SPIM0USEFPGA */ +}; diff --git a/board/altera/socfpga_cyclone5/pinmux_config.h b/board/altera/socfpga_cyclone5/pinmux_config.h new file mode 100644 index 0000000..f278f2b --- /dev/null +++ b/board/altera/socfpga_cyclone5/pinmux_config.h @@ -0,0 +1,54 @@ +/* This file is generated by Preloader Generator */ + +#ifndef _PRELOADER_PINMUX_CONFIG_H_ +#define _PRELOADER_PINMUX_CONFIG_H_ + +/* + * State of enabling for which IP connected out through the muxing. + * Value 1 mean the IP connection is muxed out + */ +#define CONFIG_HPS_EMAC0 (0) +#define CONFIG_HPS_EMAC1 (1) +#define CONFIG_HPS_USB0 (0) +#define CONFIG_HPS_USB1 (1) +#define CONFIG_HPS_NAND (0) +#define CONFIG_HPS_SDMMC (1) +#define CONFIG_HPS_QSPI (1) +#define CONFIG_HPS_UART0 (1) +#define CONFIG_HPS_UART1 (0) +#define CONFIG_HPS_TRACE (1) +#define CONFIG_HPS_I2C0 (1) +#define CONFIG_HPS_I2C1 (0) +#define CONFIG_HPS_I2C2 (0) +#define CONFIG_HPS_I2C3 (0) +#define CONFIG_HPS_SPIM0 (1) +#define CONFIG_HPS_SPIM1 (0) +#define CONFIG_HPS_SPIS0 (0) +#define CONFIG_HPS_SPIS1 (0) +#define CONFIG_HPS_CAN0 (1) +#define CONFIG_HPS_CAN1 (0) + +/* IP attribute value (which affected by pin muxing configuration) */ +#define CONFIG_HPS_SDMMC_BUSWIDTH (4) + +/* 1 if the pins are connected out */ +#define CONFIG_HPS_QSPI_CS0 (1) +#define CONFIG_HPS_QSPI_CS1 (0) +#define CONFIG_HPS_QSPI_CS2 (0) +#define CONFIG_HPS_QSPI_CS3 (0) + +/* UART */ +/* 1 means the pin is mux out or available */ +#define CONFIG_HPS_UART0_TX (1) +#define CONFIG_HPS_UART0_RX (1) +#define CONFIG_HPS_UART0_CTS (0) +#define CONFIG_HPS_UART0_RTS (0) +#define CONFIG_HPS_UART1_TX (0) +#define CONFIG_HPS_UART1_RX (0) +#define CONFIG_HPS_UART1_CTS (0) +#define CONFIG_HPS_UART1_RTS (0) + +/* Pin mux data */ +#define CONFIG_HPS_PINMUX_NUM (207) + +#endif /* _PRELOADER_PINMUX_CONFIG_H_ */
Dear Chin Liang See,
In addition to the license issue, please chose a descriptive subject. It is not really helpful when all patches of a series have the same subject line.
Dear Wolfgang,
Sure, I can fix this.
Thanks Chin Liang
Chin Liang See
