[PATCH] efi_loader: adjust config options for capsule updates
EFI_IGNORE_OSINDICATIONS is used to ignore OsIndications if setvariable at runtime is not supported and allow the platform to perform capsule updates on disk. With the recent changes boards can conditionally enable setvariable at runtime using EFI_RT_VOLATILE_STORE.
So let's make the options depend on each other and clarify their functionality. When EFI_RT_VOLATILE_STORE, setvariable at runtime is supported and EFI_IGNORE_OSINDICATIONS, which also breaks the EFI spec, is not needed anymore.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- lib/efi_loader/Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index 430bb7f0f7dc..c84064de1366 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -220,6 +220,8 @@ config EFI_CAPSULE_ON_DISK config EFI_IGNORE_OSINDICATIONS bool "Ignore OsIndications for CapsuleUpdate on-disk" depends on EFI_CAPSULE_ON_DISK + depends on !EFI_RT_VOLATILE_STORE + default y help There are boards where U-Boot does not support SetVariable at runtime. Select this option if you want to use the capsule-on-disk feature
Ilias Apalodimas ilias.apalodimas@linaro.org writes:
Hi Ilias,
Is there a corresponding effort to update fwupdmgr to set OSIndications (and set it correctly so the change persists a reboot)?
Otherwise, fwupdmgr provided capsules will now get ignored for boards that enable setvariable at runtime.
Jon
- depends on !EFI_RT_VOLATILE_STORE
- default y help There are boards where U-Boot does not support SetVariable at runtime. Select this option if you want to use the capsule-on-disk feature
-- 2.45.2
Hi Jon,
Hi Ilias,
We are not trying to fix anything atm, we probably will in the future.
That goes beyond fwupd, EFI variable changes will be ignored in general unless you sync the file manually -- e.g. dd if=/sys/firmware/efi/efivars/VarToFile-b2ac5fc9-92b7-4acd-aeac-11e818c3130c of=/boot/efi/ubootefi.var skip=4 bs=1 after every variable change. Unless you do that, enabling EFI_RT_VOLATILE_STORE makes little sense (and that's why it's not enabled by default). So, I prefer making EFI_IGNORE_OSINDICATIONS, which was a hack, mutually exclusive and start going in the right direction.
Regards /Ilias
Jon
-- 2.45.2
Hi Jon,
Hi Ilias,
I agree with the principle. My concern is that we want to encourage people to move to setvariable at runtime, but until LVFS is updated, people who care about LVFS will be deincentivized.
Jon
Regards /Ilias
Jon
-- 2.45.2
EFI_RT_VOLATILE_STORE does not imply that the OS that you are running supports writing variables to ubootefi.var or eMMC.
How about
default y if !EFI_RT_VOLATILE_STORE
Best regards
Heinrich
Hi Heinrich,
How about
Sure, that works for me. I'll send a v2
Cheers
Best regards
Heinrich
Ilias Apalodimas
Jon Humphreys
