[U-Boot] some dead code and redundant files for nios?
another observation about header files, this time related to nios/nios2:
$ grep -r CONFIG_NIOS * arch/nios2/config.mk:PLATFORM_CPPFLAGS += -DCONFIG_NIOS2 -D__NIOS2__ arch/nios2/cpu/epcs.c:#endif /* CONFIG_NIOS_EPCS */ board/psyent/common/AMDLV065D.c:#if defined(CONFIG_NIOS) <-- ??? board/altera/common/AMDLV065D.c:#if defined(CONFIG_NIOS) <-- ??? common/cmd_bdinfo.c:#elif defined(CONFIG_NIOS2) examples/standalone/stubs.c:#elif defined(CONFIG_NIOS2) $
first, given that there is no "nios" architecture anymore, isn't that preprocessor test of:
in those two files always going to be false? the usage is:
#if defined(CONFIG_NIOS) #include <nios.h> #else #include <asm/io.h> #endif
and there *is* no nios.h file, anyway, so that pretty clearly looks like a removable test. more to the point, the same source file -- AMDLV065D.c -- is in two different directories, and they differ slightly:
$ diff board/{altera,psyent}/common/AMDLV065D.c 175c175 < writeb (b, dst); ---
writeb (dst, b);
that looks kind of weird, doesn't it? i haven't looked any more closely but for two source files with the same name to have that single, subtle difference just looks strange.
rday
On Fri, 1 Feb 2013, Robert P. J. Day wrote:
... the same source file -- AMDLV065D.c -- is in two different directories, and they differ slightly:
< writeb (b, dst);
writeb (dst, b);
i took a couple minutes with "git blame" to discover this:
$ git show 3d22d0b8 diff --git a/board/psyent/common/AMDLV065D.c b/board/psyent/common/AMDLV065D.c ... snip ... - *cmd = 0xaa; - *cmd = 0x55; - *cmd = 0xa0; - *dst = b; + writeb (cmd, 0xaa); + writeb (cmd, 0x55); + writeb (cmd, 0xa0); + writeb (dst, b); ... snip ...
while over in the (almost) identical file:
git show 9e486ab1 commit 9e486ab1c98ea7ab357520307fe5d5a0847cd1bb Author: Scott McNutt smcnutt@psyent.com Date: Tue Mar 30 20:26:15 2010 -0400
nios2: Fix AMDLV065D flash write bug in altera board common tree.
Signed-off-by: Scott McNutt smcnutt@psyent.com
diff --git a/board/altera/common/AMDLV065D.c b/board/altera/common/AMDLV065D.c index 72b0a9f..7a1b4d3 100644 --- a/board/altera/common/AMDLV065D.c +++ b/board/altera/common/AMDLV065D.c @@ -172,7 +172,7 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) writeb (0xaa, cmd); writeb (0x55, cmd); writeb (0xa0, cmd); - writeb (dst, b); + writeb (b, dst);
/* Verify write */ start = get_timer (0); $
i don't know what the above is doing, but it would certainly seem that if a flash write bug was being fixed in one of those files, it would be fixed in the other. beyond that, i cannot say.
rday
Robert P. J. Day
