[U-Boot] [PATCH 1/2] arm: smdkc100: remove config.mk file
Since config.mk is deprecated, remove this file, and move CONFIG_SYS_TEXT_BASE define to config file.
Signed-off-by: Minkyu Kang mk7.kang@samsung.com Cc: Wolfgang Denk wd@denx.de --- board/samsung/smdkc100/config.mk | 16 ---------------- include/configs/smdkc100.h | 3 +++ 2 files changed, 3 insertions(+), 16 deletions(-) delete mode 100644 board/samsung/smdkc100/config.mk
diff --git a/board/samsung/smdkc100/config.mk b/board/samsung/smdkc100/config.mk deleted file mode 100644 index 3a08bb1..0000000 --- a/board/samsung/smdkc100/config.mk +++ /dev/null @@ -1,16 +0,0 @@ -# -# Copyright (C) 2008 # Samsung Elecgtronics -# Kyungmin Park kyungmin.park@samsung.com -# - -# On S5PC100 we use the 128 MiB OneDRAM bank at -# -# 0x30000000 to 0x35000000 (80MiB) -# 0x38000000 to 0x40000000 (128MiB) -# -# On S5PC110 we use the 128 MiB OneDRAM bank at -# -# 0x30000000 to 0x35000000 (80MiB) -# 0x40000000 to 0x48000000 (128MiB) -# -CONFIG_SYS_TEXT_BASE = 0x34800000 diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index fb640db..fa9e345 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -50,6 +50,9 @@ /* DRAM Base */ #define CONFIG_SYS_SDRAM_BASE 0x30000000
+/* Text Base */ +#define CONFIG_SYS_TEXT_BASE 0x34800000 + #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_CMDLINE_TAG #define CONFIG_INITRD_TAG
Signed-off-by: Minkyu Kang mk7.kang@samsung.com Cc: Wolfgang Denk wd@denx.de --- changes for v2: rebased.
diff --git a/board/samsung/smdkc100/config.mk b/board/samsung/smdkc100/config.mk deleted file mode 100644 index 3a08bb1..0000000 --- a/board/samsung/smdkc100/config.mk +++ /dev/null @@ -1,16 +0,0 @@ -# -# Copyright (C) 2008 # Samsung Elecgtronics -# Kyungmin Park kyungmin.park@samsung.com -# - -# On S5PC100 we use the 128 MiB OneDRAM bank at -# -# 0x30000000 to 0x35000000 (80MiB) -# 0x38000000 to 0x40000000 (128MiB) -# -# On S5PC110 we use the 128 MiB OneDRAM bank at -# -# 0x30000000 to 0x35000000 (80MiB) -# 0x40000000 to 0x48000000 (128MiB) -# -CONFIG_SYS_TEXT_BASE = 0x34800000 diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index a572e62..507a5d3 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -34,6 +34,9 @@ /* DRAM Base */ #define CONFIG_SYS_SDRAM_BASE 0x30000000
applied to u-boot-samsung.
Minkyu Kang.
Minkyu Kang
