[U-Boot] [PATCH 1/2] armv8: ls1043a: remove redundant code in board files
gd->env_addr will be initialized in env_init() in common/env_nowhere.c if CONFIG_ENV_IS_NOWHERE is defined. So no need to do it again.
Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- board/freescale/ls1043aqds/ls1043aqds.c | 4 ---- board/freescale/ls1043ardb/ls1043ardb.c | 5 ----- 2 files changed, 9 deletions(-)
diff --git a/board/freescale/ls1043aqds/ls1043aqds.c b/board/freescale/ls1043aqds/ls1043aqds.c index fba6b88..a59b8f4 100644 --- a/board/freescale/ls1043aqds/ls1043aqds.c +++ b/board/freescale/ls1043aqds/ls1043aqds.c @@ -325,10 +325,6 @@ int board_init(void) #ifdef CONFIG_LAYERSCAPE_NS_ACCESS enable_layerscape_ns_access(); #endif - -#ifdef CONFIG_ENV_IS_NOWHERE - gd->env_addr = (ulong)&default_environment[0]; -#endif return 0; }
diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index ec5fdbf..f1d4c39 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -19,7 +19,6 @@ #include <fsl_csu.h> #include <fsl_esdhc.h> #include <fsl_ifc.h> -#include <environment.h> #include <fsl_sec.h> #include "cpld.h" #ifdef CONFIG_U_QE @@ -95,10 +94,6 @@ int board_init(void) init_final_memctl_regs(); #endif
-#ifdef CONFIG_ENV_IS_NOWHERE - gd->env_addr = (ulong)&default_environment[0]; -#endif - #ifdef CONFIG_LAYERSCAPE_NS_ACCESS enable_layerscape_ns_access(); #endif
Using u16 for cfg_rcw_src and u8 for sd1refclk_sel is enough.
Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- board/freescale/ls1043ardb/ls1043ardb.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/freescale/ls1043ardb/ls1043ardb.c b/board/freescale/ls1043ardb/ls1043ardb.c index f1d4c39..2685dac 100644 --- a/board/freescale/ls1043ardb/ls1043ardb.c +++ b/board/freescale/ls1043ardb/ls1043ardb.c @@ -30,12 +30,12 @@ DECLARE_GLOBAL_DATA_PTR;
int checkboard(void) { - static const char *freq[3] = {"100.00MHZ", "156.25MHZ"}; + static const char *freq[2] = {"100.00MHZ", "156.25MHZ"}; #ifndef CONFIG_SD_BOOT u8 cfg_rcw_src1, cfg_rcw_src2; - u32 cfg_rcw_src; + u16 cfg_rcw_src; #endif - u32 sd1refclk_sel; + u8 sd1refclk_sel;
printf("Board: LS1043ARDB, boot from ");
Applied to u-boot-fsl-qoriq master, awaiting upstream.
Thanks.
York
Thanks.
York
Gong Qianyu
York Sun
