[U-Boot] [PATCH v4 12/15] bootstage: Replace show_boot_progress/error() with bootstage_...()
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v4: - Adjust bootstage.h header to fix build warnings (bisect problem)
arch/arm/lib/bootm.c | 2 +- arch/avr32/lib/bootm.c | 2 +- arch/m68k/lib/bootm.c | 2 +- arch/microblaze/lib/bootm.c | 2 +- arch/mips/lib/bootm.c | 2 +- arch/mips/lib/bootm_qemu_mips.c | 2 +- arch/nds32/lib/bootm.c | 2 +- arch/powerpc/lib/board.c | 2 +- arch/powerpc/lib/bootm.c | 2 +- arch/sparc/lib/board.c | 2 +- arch/x86/lib/board.c | 19 +++---- board/hermes/hermes.c | 2 +- board/matrix_vision/common/mv_common.c | 2 +- board/scb9328/scb9328.c | 6 -- common/cmd_bootm.c | 92 ++++++++++++++++---------------- common/cmd_ide.c | 46 ++++++++-------- common/cmd_nand.c | 34 ++++++------ common/cmd_net.c | 16 +++--- common/env_common.c | 2 +- common/image.c | 52 +++++++++--------- include/bootstage.h | 30 ++++++++++- net/eth.c | 6 +- post/post.c | 4 +- 23 files changed, 175 insertions(+), 156 deletions(-)
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 249ac1b..f114cd6 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -113,7 +113,7 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) printf ("Using machid 0x%x from environment\n", machid); }
- show_boot_progress(BOOTSTAGE_ID_RUN_OS); + bootstage_mark(BOOTSTAGE_ID_RUN_OS);
#ifdef CONFIG_OF_LIBFDT if (images->ft_len) diff --git a/arch/avr32/lib/bootm.c b/arch/avr32/lib/bootm.c index f180737..74ebeca 100644 --- a/arch/avr32/lib/bootm.c +++ b/arch/avr32/lib/bootm.c @@ -192,7 +192,7 @@ int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *ima
theKernel = (void *)images->ep;
params = params_start = (struct tag *)gd->bd->bi_boot_params; params = setup_start_tag(params); diff --git a/arch/m68k/lib/bootm.c b/arch/m68k/lib/bootm.c index 233782b..d506d0c 100644 --- a/arch/m68k/lib/bootm.c +++ b/arch/m68k/lib/bootm.c @@ -104,7 +104,7 @@ int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *ima debug("## Transferring control to Linux (at address %08lx) ...\n", (ulong) kernel);
/* * Linux Kernel Parameters (passing board info data): diff --git a/arch/microblaze/lib/bootm.c b/arch/microblaze/lib/bootm.c index 24b9e09..95cee50 100644 --- a/arch/microblaze/lib/bootm.c +++ b/arch/microblaze/lib/bootm.c @@ -59,7 +59,7 @@ int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *ima if (ret) return 1;
if (!of_flat_tree && argc > 3) of_flat_tree = (char *)simple_strtoul(argv[3], NULL, 16); diff --git a/arch/mips/lib/bootm.c b/arch/mips/lib/bootm.c index 5b7e74f..9930abf 100644 --- a/arch/mips/lib/bootm.c +++ b/arch/mips/lib/bootm.c @@ -56,7 +56,7 @@ int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *ima /* find kernel entry point */ theKernel = (void (*)(int, char **, char **, int *))images->ep;
#ifdef DEBUG printf ("## Transferring control to Linux (at address %08lx) ...\n", diff --git a/arch/mips/lib/bootm_qemu_mips.c b/arch/mips/lib/bootm_qemu_mips.c index 47f5310..bb6442a 100644 --- a/arch/mips/lib/bootm_qemu_mips.c +++ b/arch/mips/lib/bootm_qemu_mips.c @@ -39,7 +39,7 @@ int do_bootm_linux(int flag, int argc, char * const argv[], bootm_headers_t *ima /* find kernel entry point */ theKernel = (void (*)(int, char **, char **, int *))images->ep;
debug ("## Transferring control to Linux (at address %08lx) ...\n", (ulong) theKernel); diff --git a/arch/nds32/lib/bootm.c b/arch/nds32/lib/bootm.c index 5ae90fb..03f58bf 100644 --- a/arch/nds32/lib/bootm.c +++ b/arch/nds32/lib/bootm.c @@ -69,7 +69,7 @@ int do_bootm_linux(int flag, int argc, char *argv[], bootm_headers_t *images) printf("Using machid 0x%x from environment\n", machid); }
debug("## Transferring control to Linux (at address %08lx) ...\n", (ulong)theKernel); diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index 837c82d..fc63b2c 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -1065,7 +1065,7 @@ void board_init_r(gd_t *id, ulong dest_addr) void hang(void) { puts("### ERROR ### Please RESET the board ###\n"); - show_boot_error(BOOTSTAGE_ID_NEED_RESET); + bootstage_error(BOOTSTAGE_ID_NEED_RESET); for (;;) ; } diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index 37f162a..53dc4df 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -69,7 +69,7 @@ static void boot_jump_linux(bootm_headers_t *images) debug ("## Transferring control to Linux (at address %08lx) ...\n", (ulong)kernel);
#if defined(CONFIG_SYS_INIT_RAM_LOCK) && !defined(CONFIG_E500) unlock_ram_in_cache(); diff --git a/arch/sparc/lib/board.c b/arch/sparc/lib/board.c index 770136b..c0d2608 100644 --- a/arch/sparc/lib/board.c +++ b/arch/sparc/lib/board.c @@ -426,7 +426,7 @@ void hang(void) { puts("### ERROR ### Please RESET the board ###\n"); #ifdef CONFIG_SHOW_BOOT_PROGRESS - show_boot_error(BOOTSTAGE_ID_NEED_RESET); + bootstage_error(BOOTSTAGE_ID_NEED_RESET); #endif for (;;) ; } diff --git a/arch/x86/lib/board.c b/arch/x86/lib/board.c index 1f677cc..4c117a3 100644 --- a/arch/x86/lib/board.c +++ b/arch/x86/lib/board.c @@ -280,7 +280,7 @@ void board_init_r(gd_t *id, ulong dest_addr) static gd_t gd_data; init_fnc_t **init_fnc_ptr;
- show_boot_progress(BOOTSTAGE_ID_BOARD_INIT_R); + bootstage_mark(BOOTSTAGE_ID_BOARD_INIT_R);
/* Global data pointer is now writable */ gd = &gd_data; @@ -291,7 +291,7 @@ void board_init_r(gd_t *id, ulong dest_addr)
gd->bd = &bd_data; memset(gd->bd, 0, sizeof(bd_t)); - show_boot_progress(BOOTSTAGE_ID_BOARD_GLOBAL_DATA); + bootstage_mark(BOOTSTAGE_ID_BOARD_GLOBAL_DATA);
gd->baudrate = CONFIG_BAUDRATE;
@@ -302,7 +302,7 @@ void board_init_r(gd_t *id, ulong dest_addr) if ((*init_fnc_ptr)() != 0) hang(); } - show_boot_progress(BOOTSTAGE_ID_BOARD_INIT_SEQ); + bootstage_mark(BOOTSTAGE_ID_BOARD_INIT_SEQ);
#ifdef CONFIG_SERIAL_MULTI serial_initialize(); @@ -312,15 +312,14 @@ void board_init_r(gd_t *id, ulong dest_addr) /* configure available FLASH banks */ size = flash_init(); display_flash_config(size); - show_boot_progress(BOOTSTAGE_ID_BOARD_FLASH); + bootstage_mark(BOOTSTAGE_ID_BOARD_FLASH); #endif
- show_boot_progress(BOOTSTAGE_ID_BOARD_FLASH_37); + bootstage_mark(BOOTSTAGE_ID_BOARD_FLASH_37);
/* initialize environment */ env_relocate(); - show_boot_progress(BOOTSTAGE_ID_BOARD_ENV); - + bootstage_mark(BOOTSTAGE_ID_BOARD_ENV);
#ifdef CONFIG_CMD_NET /* IP Address */ @@ -334,7 +333,7 @@ void board_init_r(gd_t *id, ulong dest_addr) pci_init(); #endif
- show_boot_progress(BOOTSTAGE_ID_BOARD_PCI); + bootstage_mark(BOOTSTAGE_ID_BOARD_PCI);
stdio_init(); @@ -363,7 +362,7 @@ void board_init_r(gd_t *id, ulong dest_addr)
/* enable exceptions */ enable_interrupts(); - show_boot_progress(BOOTSTAGE_ID_BOARD_INTERRUPTS); + bootstage_mark(BOOTSTAGE_ID_BOARD_INTERRUPTS);
#ifdef CONFIG_STATUS_LED status_led_set(STATUS_LED_BOOT, STATUS_LED_BLINKING); @@ -432,7 +431,7 @@ void board_init_r(gd_t *id, ulong dest_addr) post_run(NULL, POST_RAM | post_bootmode_get(0)); #endif
- show_boot_progress(BOOTSTAGE_ID_BOARD_DONE); + bootstage_mark(BOOTSTAGE_ID_BOARD_DONE);
/* main_loop() can return to retry autoboot, if so just run it again. */ for (;;) diff --git a/board/hermes/hermes.c b/board/hermes/hermes.c index 38bab03..a3bf4bb 100644 --- a/board/hermes/hermes.c +++ b/board/hermes/hermes.c @@ -27,7 +27,7 @@
#ifdef CONFIG_SHOW_BOOT_PROGRESS # include <status_led.h> -# define SHOW_BOOT_PROGRESS(arg) show_boot_progress(arg) +# define SHOW_BOOT_PROGRESS(arg) bootstage_mark(arg) #else # define SHOW_BOOT_PROGRESS(arg) #endif diff --git a/board/matrix_vision/common/mv_common.c b/board/matrix_vision/common/mv_common.c index 7fde4ac..b9330f9 100644 --- a/board/matrix_vision/common/mv_common.c +++ b/board/matrix_vision/common/mv_common.c @@ -95,7 +95,7 @@ int mv_load_fpga(void)
result = fpga_load(0, fpga_data, data_size); if (!result) - show_boot_progress(BOOTSTAGE_ID_START); + bootstage_mark(BOOTSTAGE_ID_START);
return result; } diff --git a/board/scb9328/scb9328.c b/board/scb9328/scb9328.c index 076c046..1ec2044 100644 --- a/board/scb9328/scb9328.c +++ b/board/scb9328/scb9328.c @@ -23,12 +23,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#ifdef CONFIG_SHOW_BOOT_PROGRESS -# define SHOW_BOOT_PROGRESS(arg) show_boot_progress(arg) -#else -# define SHOW_BOOT_PROGRESS(arg) -#endif - int board_init (void) { gd->bd->bi_arch_number = MACH_TYPE_SCB9328; diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index 44a9ded..7e780fb 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -222,21 +222,21 @@ static int bootm_start(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[] if (fit_image_get_type(images.fit_hdr_os, images.fit_noffset_os, &images.os.type)) { puts("Can't get image type!\n"); - show_boot_error(BOOTSTAGE_ID_FIT_TYPE); + bootstage_error(BOOTSTAGE_ID_FIT_TYPE); return 1; }
if (fit_image_get_comp(images.fit_hdr_os, images.fit_noffset_os, &images.os.comp)) { puts("Can't get image compression!\n"); - show_boot_error(BOOTSTAGE_ID_FIT_COMPRESSION); + bootstage_error(BOOTSTAGE_ID_FIT_COMPRESSION); return 1; }
if (fit_image_get_os(images.fit_hdr_os, images.fit_noffset_os, &images.os.os)) { puts("Can't get image OS!\n"); - show_boot_error(BOOTSTAGE_ID_FIT_OS); + bootstage_error(BOOTSTAGE_ID_FIT_OS); return 1; }
@@ -245,7 +245,7 @@ static int bootm_start(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[] if (fit_image_get_load(images.fit_hdr_os, images.fit_noffset_os, &images.os.load)) { puts("Can't get image load address!\n"); - show_boot_error(BOOTSTAGE_ID_FIT_LOADADDR); + bootstage_error(BOOTSTAGE_ID_FIT_LOADADDR); return 1; } break; @@ -348,7 +348,7 @@ static int bootm_load_os(image_info_t os, ulong *load_end, int boot_progress) puts("GUNZIP: uncompress, out-of-mem or overwrite " "error - must RESET board to recover\n"); if (boot_progress) - show_boot_error(BOOTSTAGE_ID_DECOMP_IMAGE); + bootstage_error(BOOTSTAGE_ID_DECOMP_IMAGE); return BOOTM_ERR_RESET; }
@@ -370,7 +370,7 @@ static int bootm_load_os(image_info_t os, ulong *load_end, int boot_progress) printf("BUNZIP2: uncompress or overwrite error %d " "- must RESET board to recover\n", i); if (boot_progress) - show_boot_error(BOOTSTAGE_ID_DECOMP_IMAGE); + bootstage_error(BOOTSTAGE_ID_DECOMP_IMAGE); return BOOTM_ERR_RESET; }
@@ -389,7 +389,7 @@ static int bootm_load_os(image_info_t os, ulong *load_end, int boot_progress) if (ret != SZ_OK) { printf("LZMA: uncompress or overwrite error %d " "- must RESET board to recover\n", ret); - show_boot_error(BOOTSTAGE_ID_DECOMP_IMAGE); + bootstage_error(BOOTSTAGE_ID_DECOMP_IMAGE); return BOOTM_ERR_RESET; } *load_end = load + unc_len; @@ -407,7 +407,7 @@ static int bootm_load_os(image_info_t os, ulong *load_end, int boot_progress) printf("LZO: uncompress or overwrite error %d " "- must RESET board to recover\n", ret); if (boot_progress) - show_boot_error(BOOTSTAGE_ID_DECOMP_IMAGE); + bootstage_error(BOOTSTAGE_ID_DECOMP_IMAGE); return BOOTM_ERR_RESET; }
@@ -423,7 +423,7 @@ static int bootm_load_os(image_info_t os, ulong *load_end, int boot_progress)
puts("OK\n"); debug(" kernel loaded at 0x%08lx, end = 0x%08lx\n", load, *load_end); - show_boot_progress(BOOTSTAGE_ID_KERNEL_LOADED); + bootstage_mark(BOOTSTAGE_ID_KERNEL_LOADED);
if (!no_overlap && (load < blob_end) && (*load_end > blob_start)) { debug("images.os.start = 0x%lX, images.os.end = 0x%lx\n", @@ -648,14 +648,14 @@ int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) } else { puts("ERROR: new format image overwritten - " "must RESET the board to recover\n"); - show_boot_error(BOOTSTAGE_ID_OVERWRITTEN); + bootstage_error(BOOTSTAGE_ID_OVERWRITTEN); do_reset(cmdtp, flag, argc, argv); } } if (ret == BOOTM_ERR_UNIMPLEMENTED) { if (iflag) enable_interrupts(); - show_boot_error(BOOTSTAGE_ID_DECOMP_UNIMPL); + bootstage_error(BOOTSTAGE_ID_DECOMP_UNIMPL); return 1; } } @@ -670,7 +670,7 @@ int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
- show_boot_progress(BOOTSTAGE_ID_CHECK_BOOT_OS); + bootstage_mark(BOOTSTAGE_ID_CHECK_BOOT_OS);
#ifdef CONFIG_SILENT_CONSOLE if (images.os.os == IH_OS_LINUX) @@ -684,7 +684,7 @@ int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) enable_interrupts(); printf("ERROR: booting os '%s' (%d) is not supported\n", genimg_get_os_name(images.os.os), images.os.os); - show_boot_error(BOOTSTAGE_ID_CHECK_BOOT_OS); + bootstage_error(BOOTSTAGE_ID_CHECK_BOOT_OS); return 1; }
@@ -692,7 +692,7 @@ int do_bootm(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
boot_fn(0, argc, argv, &images);
- show_boot_error(BOOTSTAGE_ID_BOOT_OS_RETURNED); + bootstage_error(BOOTSTAGE_ID_BOOT_OS_RETURNED); #ifdef DEBUG puts("\n## Control returned to monitor - resetting...\n"); #endif @@ -734,34 +734,34 @@ static image_header_t *image_get_kernel(ulong img_addr, int verify)
if (!image_check_magic(hdr)) { puts("Bad Magic Number\n"); - show_boot_error(BOOTSTAGE_ID_CHECK_MAGIC); + bootstage_error(BOOTSTAGE_ID_CHECK_MAGIC); return NULL; } - show_boot_progress(BOOTSTAGE_ID_CHECK_HEADER); + bootstage_mark(BOOTSTAGE_ID_CHECK_HEADER);
if (!image_check_hcrc(hdr)) { puts("Bad Header Checksum\n"); - show_boot_error(BOOTSTAGE_ID_CHECK_HEADER); + bootstage_error(BOOTSTAGE_ID_CHECK_HEADER); return NULL; }
- show_boot_progress(BOOTSTAGE_ID_CHECK_CHECKSUM); + bootstage_mark(BOOTSTAGE_ID_CHECK_CHECKSUM); image_print_contents(hdr);
if (verify) { puts(" Verifying Checksum ... "); if (!image_check_dcrc(hdr)) { printf("Bad Data CRC\n"); - show_boot_error(BOOTSTAGE_ID_CHECK_CHECKSUM); + bootstage_error(BOOTSTAGE_ID_CHECK_CHECKSUM); return NULL; } puts("OK\n"); } - show_boot_progress(BOOTSTAGE_ID_CHECK_ARCH); + bootstage_mark(BOOTSTAGE_ID_CHECK_ARCH);
if (!image_check_target_arch(hdr)) { printf("Unsupported Architecture 0x%x\n", image_get_arch(hdr)); - show_boot_error(BOOTSTAGE_ID_CHECK_ARCH); + bootstage_error(BOOTSTAGE_ID_CHECK_ARCH); return NULL; } return hdr; @@ -789,28 +789,28 @@ static int fit_check_kernel(const void *fit, int os_noffset, int verify) puts(" Verifying Hash Integrity ... "); if (!fit_image_check_hashes(fit, os_noffset)) { puts("Bad Data Hash\n"); - show_boot_error(BOOTSTAGE_ID_FIT_CHECK_HASH); + bootstage_error(BOOTSTAGE_ID_FIT_CHECK_HASH); return 0; } puts("OK\n"); } - show_boot_progress(BOOTSTAGE_ID_FIT_CHECK_ARCH); + bootstage_mark(BOOTSTAGE_ID_FIT_CHECK_ARCH);
if (!fit_image_check_target_arch(fit, os_noffset)) { puts("Unsupported Architecture\n"); - show_boot_error(BOOTSTAGE_ID_FIT_CHECK_ARCH); + bootstage_error(BOOTSTAGE_ID_FIT_CHECK_ARCH); return 0; }
- show_boot_progress(BOOTSTAGE_ID_FIT_CHECK_KERNEL); + bootstage_mark(BOOTSTAGE_ID_FIT_CHECK_KERNEL); if (!fit_image_check_type(fit, os_noffset, IH_TYPE_KERNEL) && !fit_image_check_type(fit, os_noffset, IH_TYPE_KERNEL_NOLOAD)) { puts("Not a kernel image\n"); - show_boot_error(BOOTSTAGE_ID_FIT_CHECK_KERNEL); + bootstage_error(BOOTSTAGE_ID_FIT_CHECK_KERNEL); return 0; }
- show_boot_progress(BOOTSTAGE_ID_FIT_CHECKED); + bootstage_mark(BOOTSTAGE_ID_FIT_CHECKED); return 1; } #endif /* CONFIG_FIT */ @@ -863,7 +863,7 @@ static void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, debug("* kernel: cmdline image address = 0x%08lx\n", img_addr); }
- show_boot_progress(BOOTSTAGE_ID_CHECK_MAGIC); + bootstage_mark(BOOTSTAGE_ID_CHECK_MAGIC);
/* copy from dataflash if needed */ img_addr = genimg_get_image(img_addr); @@ -877,7 +877,7 @@ static void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, hdr = image_get_kernel(img_addr, images->verify); if (!hdr) return NULL; - show_boot_progress(BOOTSTAGE_ID_CHECK_IMAGETYPE); + bootstage_mark(BOOTSTAGE_ID_CHECK_IMAGETYPE);
/* get os_data and os_len */ switch (image_get_type(hdr)) { @@ -896,7 +896,7 @@ static void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, default: printf("Wrong Image Type for %s command\n", cmdtp->name); - show_boot_error(BOOTSTAGE_ID_CHECK_IMAGETYPE); + bootstage_error(BOOTSTAGE_ID_CHECK_IMAGETYPE); return NULL; }
@@ -911,7 +911,7 @@ static void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, images->legacy_hdr_os = hdr;
images->legacy_hdr_valid = 1; - show_boot_progress(BOOTSTAGE_ID_DECOMP_IMAGE); + bootstage_mark(BOOTSTAGE_ID_DECOMP_IMAGE); break; #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: @@ -921,10 +921,10 @@ static void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc,
if (!fit_check_format(fit_hdr)) { puts("Bad FIT kernel image format!\n"); - show_boot_error(BOOTSTAGE_ID_FIT_FORMAT); + bootstage_error(BOOTSTAGE_ID_FIT_FORMAT); return NULL; } - show_boot_progress(BOOTSTAGE_ID_FIT_FORMAT); + bootstage_mark(BOOTSTAGE_ID_FIT_FORMAT);
if (!fit_uname_kernel) { /* @@ -933,11 +933,11 @@ static void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, * fit_conf_get_node() will try to find default config * node */ - show_boot_progress(BOOTSTAGE_ID_FIT_NO_UNIT_NAME); + bootstage_mark(BOOTSTAGE_ID_FIT_NO_UNIT_NAME); cfg_noffset = fit_conf_get_node(fit_hdr, fit_uname_config); if (cfg_noffset < 0) { - show_boot_error(BOOTSTAGE_ID_FIT_NO_UNIT_NAME); + bootstage_error(BOOTSTAGE_ID_FIT_NO_UNIT_NAME); return NULL; } /* save configuration uname provided in the first @@ -948,7 +948,7 @@ static void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, NULL); printf(" Using '%s' configuration\n", images->fit_uname_cfg); - show_boot_progress(BOOTSTAGE_ID_FIT_CONFIG); + bootstage_mark(BOOTSTAGE_ID_FIT_CONFIG);
os_noffset = fit_conf_get_kernel_node(fit_hdr, cfg_noffset); @@ -956,28 +956,28 @@ static void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, NULL); } else { /* get kernel component image node offset */ - show_boot_progress(BOOTSTAGE_ID_FIT_UNIT_NAME); + bootstage_mark(BOOTSTAGE_ID_FIT_UNIT_NAME); os_noffset = fit_image_get_node(fit_hdr, fit_uname_kernel); } if (os_noffset < 0) { - show_boot_error(BOOTSTAGE_ID_FIT_CONFIG); + bootstage_error(BOOTSTAGE_ID_FIT_CONFIG); return NULL; }
printf(" Trying '%s' kernel subimage\n", fit_uname_kernel);
- show_boot_progress(BOOTSTAGE_ID_FIT_CHECK_SUBIMAGE); + bootstage_mark(BOOTSTAGE_ID_FIT_CHECK_SUBIMAGE); if (!fit_check_kernel(fit_hdr, os_noffset, images->verify)) return NULL;
/* get kernel image data address and length */ if (fit_image_get_data(fit_hdr, os_noffset, &data, &len)) { puts("Could not find kernel subimage data!\n"); - show_boot_error(BOOTSTAGE_ID_FIT_KERNEL_INFO_ERR); + bootstage_error(BOOTSTAGE_ID_FIT_KERNEL_INFO_ERR); return NULL; } - show_boot_progress(BOOTSTAGE_ID_FIT_KERNEL_INFO); + bootstage_mark(BOOTSTAGE_ID_FIT_KERNEL_INFO);
*os_len = len; *os_data = (ulong)data; @@ -988,7 +988,7 @@ static void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, #endif default: printf("Wrong Image Format for %s command\n", cmdtp->name); - show_boot_error(BOOTSTAGE_ID_FIT_KERNEL_INFO); + bootstage_error(BOOTSTAGE_ID_FIT_KERNEL_INFO); return NULL; }
@@ -1339,7 +1339,7 @@ static int do_bootm_netbsd(int flag, int argc, char * const argv[], "(at address %08lx) ...\n", (ulong)loader);
/* * NetBSD Stage-2 Loader Parameters: @@ -1397,7 +1397,7 @@ static int do_bootm_rtems(int flag, int argc, char * const argv[], printf("## Transferring control to RTEMS (at address %08lx) ...\n", (ulong)entry_point);
/* * RTEMS Parameters: @@ -1430,7 +1430,7 @@ static int do_bootm_ose(int flag, int argc, char * const argv[], printf("## Transferring control to OSE (at address %08lx) ...\n", (ulong)entry_point);
/* * OSE Parameters: @@ -1511,7 +1511,7 @@ static int do_bootm_integrity(int flag, int argc, char * const argv[], printf("## Transferring control to INTEGRITY (at address %08lx) ...\n", (ulong)entry_point);
/* * INTEGRITY Parameters: diff --git a/common/cmd_ide.c b/common/cmd_ide.c index 46fa7d4..b1aa50f 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -345,7 +345,7 @@ int do_diskboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) const void *fit_hdr = NULL; #endif
- show_boot_progress(BOOTSTAGE_ID_IDE_START); + bootstage_mark(BOOTSTAGE_ID_IDE_START); switch (argc) { case 1: addr = CONFIG_SYS_LOAD_ADDR; @@ -360,41 +360,41 @@ int do_diskboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) boot_device = argv[2]; break; default: - show_boot_error(BOOTSTAGE_ID_IDE_ADDR); + bootstage_error(BOOTSTAGE_ID_IDE_ADDR); return cmd_usage(cmdtp); } - show_boot_progress(BOOTSTAGE_ID_IDE_ADDR); + bootstage_mark(BOOTSTAGE_ID_IDE_ADDR);
if (!boot_device) { puts("\n** No boot device **\n"); - show_boot_error(BOOTSTAGE_ID_IDE_BOOT_DEVICE); + bootstage_error(BOOTSTAGE_ID_IDE_BOOT_DEVICE); return 1; } - show_boot_progress(BOOTSTAGE_ID_IDE_BOOT_DEVICE); + bootstage_mark(BOOTSTAGE_ID_IDE_BOOT_DEVICE);
dev = simple_strtoul(boot_device, &ep, 16);
if (ide_dev_desc[dev].type == DEV_TYPE_UNKNOWN) { printf("\n** Device %d not available\n", dev); - show_boot_error(BOOTSTAGE_ID_IDE_TYPE); + bootstage_error(BOOTSTAGE_ID_IDE_TYPE); return 1; } - show_boot_progress(BOOTSTAGE_ID_IDE_TYPE); + bootstage_mark(BOOTSTAGE_ID_IDE_TYPE);
if (*ep) { if (*ep != ':') { puts("\n** Invalid boot device, use `dev[:part]' **\n"); - show_boot_error(BOOTSTAGE_ID_IDE_PART); + bootstage_error(BOOTSTAGE_ID_IDE_PART); return 1; } part = simple_strtoul(++ep, NULL, 16); } - show_boot_progress(BOOTSTAGE_ID_IDE_PART); + bootstage_mark(BOOTSTAGE_ID_IDE_PART); if (get_partition_info(&ide_dev_desc[dev], part, &info)) { - show_boot_error(BOOTSTAGE_ID_IDE_PART_INFO); + bootstage_error(BOOTSTAGE_ID_IDE_PART_INFO); return 1; } - show_boot_progress(BOOTSTAGE_ID_IDE_PART_INFO); + bootstage_mark(BOOTSTAGE_ID_IDE_PART_INFO); if ((strncmp((char *)info.type, BOOT_PART_TYPE, sizeof(info.type)) != 0) && (strncmp((char *)info.type, BOOT_PART_COMP, sizeof(info.type)) != 0) @@ -402,10 +402,10 @@ int do_diskboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) printf("\n** Invalid partition type "%.32s"" " (expect "" BOOT_PART_TYPE "")\n", info.type); - show_boot_error(BOOTSTAGE_ID_IDE_PART_TYPE); + bootstage_error(BOOTSTAGE_ID_IDE_PART_TYPE); return 1; } - show_boot_progress(BOOTSTAGE_ID_IDE_PART_TYPE); + bootstage_mark(BOOTSTAGE_ID_IDE_PART_TYPE);
printf("\nLoading from IDE device %d, partition %d: " "Name: %.32s Type: %.32s\n", dev, part, info.name, info.type); @@ -416,23 +416,23 @@ int do_diskboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) if (ide_dev_desc[dev]. block_read(dev, info.start, 1, (ulong *) addr) != 1) { printf("** Read error on %d:%d\n", dev, part); - show_boot_error(BOOTSTAGE_ID_IDE_PART_READ); + bootstage_error(BOOTSTAGE_ID_IDE_PART_READ); return 1; } - show_boot_progress(BOOTSTAGE_ID_IDE_PART_READ); + bootstage_mark(BOOTSTAGE_ID_IDE_PART_READ);
switch (genimg_get_format((void *) addr)) { case IMAGE_FORMAT_LEGACY: hdr = (image_header_t *) addr;
- show_boot_progress(BOOTSTAGE_ID_IDE_FORMAT); + bootstage_mark(BOOTSTAGE_ID_IDE_FORMAT);
if (!image_check_hcrc(hdr)) { puts("\n** Bad Header Checksum **\n"); - show_boot_error(BOOTSTAGE_ID_IDE_CHECKSUM); + bootstage_error(BOOTSTAGE_ID_IDE_CHECKSUM); return 1; } - show_boot_progress(BOOTSTAGE_ID_IDE_CHECKSUM); + bootstage_mark(BOOTSTAGE_ID_IDE_CHECKSUM);
@@ -447,7 +447,7 @@ int do_diskboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) break; #endif default: - show_boot_error(BOOTSTAGE_ID_IDE_FORMAT); + bootstage_error(BOOTSTAGE_ID_IDE_FORMAT); puts("** Unknown image type\n"); return 1; } @@ -459,20 +459,20 @@ int do_diskboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) if (ide_dev_desc[dev].block_read(dev, info.start + 1, cnt, (ulong *)(addr + info.blksz)) != cnt) { printf("** Read error on %d:%d\n", dev, part); - show_boot_error(BOOTSTAGE_ID_IDE_READ); + bootstage_error(BOOTSTAGE_ID_IDE_READ); return 1; } - show_boot_progress(BOOTSTAGE_ID_IDE_READ); + bootstage_mark(BOOTSTAGE_ID_IDE_READ);
#if defined(CONFIG_FIT) /* This cannot be done earlier, we need complete FIT image in RAM first */ if (genimg_get_format((void *) addr) == IMAGE_FORMAT_FIT) { if (!fit_check_format(fit_hdr)) { - show_boot_error(BOOTSTAGE_ID_IDE_FIT_READ); + bootstage_error(BOOTSTAGE_ID_IDE_FIT_READ); puts("** Bad FIT image format\n"); return 1; } - show_boot_progress(BOOTSTAGE_ID_IDE_FIT_READ_OK); + bootstage_mark(BOOTSTAGE_ID_IDE_FIT_READ_OK); fit_print_contents(fit_hdr); } #endif diff --git a/common/cmd_nand.c b/common/cmd_nand.c index 1cfa247..52d721e 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -787,7 +787,7 @@ static int nand_load_image(cmd_tbl_t *cmdtp, nand_info_t *nand, if (s != NULL && (strcmp(s, ".jffs2") && strcmp(s, ".e") && strcmp(s, ".i"))) { printf("Unknown nand load suffix '%s'\n", s); - show_boot_error(BOOTSTAGE_ID_NAND_SUFFIX); + bootstage_error(BOOTSTAGE_ID_NAND_SUFFIX); return 1; }
@@ -797,16 +797,16 @@ static int nand_load_image(cmd_tbl_t *cmdtp, nand_info_t *nand, r = nand_read_skip_bad(nand, offset, &cnt, (u_char *) addr); if (r) { puts("** Read error\n"); - show_boot_error(BOOTSTAGE_ID_NAND_HDR_READ); + bootstage_error(BOOTSTAGE_ID_NAND_HDR_READ); return 1; } - show_boot_progress(BOOTSTAGE_ID_NAND_HDR_READ); + bootstage_mark(BOOTSTAGE_ID_NAND_HDR_READ);
switch (genimg_get_format ((void *)addr)) { case IMAGE_FORMAT_LEGACY: hdr = (image_header_t *)addr;
- show_boot_progress(BOOTSTAGE_ID_NAND_TYPE); + bootstage_mark(BOOTSTAGE_ID_NAND_TYPE); image_print_contents (hdr);
cnt = image_get_image_size (hdr); @@ -820,29 +820,29 @@ static int nand_load_image(cmd_tbl_t *cmdtp, nand_info_t *nand, break; #endif default: - show_boot_error(BOOTSTAGE_ID_NAND_TYPE); + bootstage_error(BOOTSTAGE_ID_NAND_TYPE); puts ("** Unknown image type\n"); return 1; } - show_boot_progress(BOOTSTAGE_ID_NAND_TYPE); + bootstage_mark(BOOTSTAGE_ID_NAND_TYPE);
r = nand_read_skip_bad(nand, offset, &cnt, (u_char *) addr); if (r) { puts("** Read error\n"); - show_boot_error(BOOTSTAGE_ID_NAND_READ); + bootstage_error(BOOTSTAGE_ID_NAND_READ); return 1; } - show_boot_progress(BOOTSTAGE_ID_NAND_READ); + bootstage_mark(BOOTSTAGE_ID_NAND_READ);
#if defined(CONFIG_FIT) /* This cannot be done earlier, we need complete FIT image in RAM first */ if (genimg_get_format ((void *)addr) == IMAGE_FORMAT_FIT) { if (!fit_check_format (fit_hdr)) { - show_boot_error(BOOTSTAGE_ID_NAND_FIT_READ); + bootstage_error(BOOTSTAGE_ID_NAND_FIT_READ); puts ("** Bad FIT image format\n"); return 1; } - show_boot_progress(BOOTSTAGE_ID_NAND_FIT_READ_OK); + bootstage_mark(BOOTSTAGE_ID_NAND_FIT_READ_OK); fit_print_contents (fit_hdr); } #endif @@ -884,7 +884,7 @@ int do_nandboot(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) } #endif
- show_boot_progress(BOOTSTAGE_ID_NAND_PART); + bootstage_mark(BOOTSTAGE_ID_NAND_PART); switch (argc) { case 1: addr = CONFIG_SYS_LOAD_ADDR; @@ -907,26 +907,26 @@ int do_nandboot(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) #if defined(CONFIG_CMD_MTDPARTS) usage: #endif - show_boot_error(BOOTSTAGE_ID_NAND_SUFFIX); + bootstage_error(BOOTSTAGE_ID_NAND_SUFFIX); return cmd_usage(cmdtp); }
- show_boot_progress(BOOTSTAGE_ID_NAND_SUFFIX); + bootstage_mark(BOOTSTAGE_ID_NAND_SUFFIX); if (!boot_device) { puts("\n** No boot device **\n"); - show_boot_error(BOOTSTAGE_ID_NAND_BOOT_DEVICE); + bootstage_error(BOOTSTAGE_ID_NAND_BOOT_DEVICE); return 1; } - show_boot_progress(BOOTSTAGE_ID_NAND_BOOT_DEVICE); + bootstage_mark(BOOTSTAGE_ID_NAND_BOOT_DEVICE);
idx = simple_strtoul(boot_device, NULL, 16);
if (idx < 0 || idx >= CONFIG_SYS_MAX_NAND_DEVICE || !nand_info[idx].name) { printf("\n** Device %d not available\n", idx); - show_boot_error(BOOTSTAGE_ID_NAND_AVAILABLE); + bootstage_error(BOOTSTAGE_ID_NAND_AVAILABLE); return 1; } - show_boot_progress(BOOTSTAGE_ID_NAND_AVAILABLE); + bootstage_mark(BOOTSTAGE_ID_NAND_AVAILABLE);
return nand_load_image(cmdtp, &nand_info[idx], offset, addr, argv[0]); } diff --git a/common/cmd_net.c b/common/cmd_net.c index ea3df8f..78b7113 100644 --- a/common/cmd_net.c +++ b/common/cmd_net.c @@ -230,36 +230,36 @@ static int netboot_common(enum proto_t proto, cmd_tbl_t *cmdtp, int argc, break; #endif default: - show_boot_error(BOOTSTAGE_ID_NET_START); + bootstage_error(BOOTSTAGE_ID_NET_START); return cmd_usage(cmdtp); }
- show_boot_progress(BOOTSTAGE_ID_NET_START); + bootstage_mark(BOOTSTAGE_ID_NET_START); if ((size = NetLoop(proto)) < 0) { - show_boot_error(BOOTSTAGE_ID_NET_NETLOOP_OK); + bootstage_error(BOOTSTAGE_ID_NET_NETLOOP_OK); return 1; }
- show_boot_progress(BOOTSTAGE_ID_NET_NETLOOP_OK); + bootstage_mark(BOOTSTAGE_ID_NET_NETLOOP_OK); /* NetLoop ok, update environment */ netboot_update_env();
/* done if no file was loaded (no errors though) */ if (size == 0) { - show_boot_error(BOOTSTAGE_ID_NET_LOADED); + bootstage_error(BOOTSTAGE_ID_NET_LOADED); return 0; }
/* flush cache */ flush_cache(load_addr, size);
- show_boot_progress(BOOTSTAGE_ID_NET_LOADED); + bootstage_mark(BOOTSTAGE_ID_NET_LOADED); rcode = bootm_maybe_autostart(cmdtp, argv[0]);
if (rcode < 0) - show_boot_error(BOOTSTAGE_ID_NET_DONE_ERR); + bootstage_error(BOOTSTAGE_ID_NET_DONE_ERR); else - show_boot_progress(BOOTSTAGE_ID_NET_DONE); + bootstage_mark(BOOTSTAGE_ID_NET_DONE); return rcode; }
diff --git a/common/env_common.c b/common/env_common.c index 41e2f26..c33d22d 100644 --- a/common/env_common.c +++ b/common/env_common.c @@ -228,7 +228,7 @@ void env_relocate(void) #if defined(CONFIG_ENV_IS_NOWHERE) /* Environment not changable */ set_default_env(NULL); #else - show_boot_error(BOOTSTAGE_ID_NET_CHECKSUM); + bootstage_error(BOOTSTAGE_ID_NET_CHECKSUM); set_default_env("!bad CRC"); #endif } else { diff --git a/common/image.c b/common/image.c index 8b097bf..ff2bb68 100644 --- a/common/image.c +++ b/common/image.c @@ -373,37 +373,37 @@ static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch,
if (!image_check_magic(rd_hdr)) { puts("Bad Magic Number\n"); - show_boot_error(BOOTSTAGE_ID_RD_MAGIC); + bootstage_error(BOOTSTAGE_ID_RD_MAGIC); return NULL; }
if (!image_check_hcrc(rd_hdr)) { puts("Bad Header Checksum\n"); - show_boot_error(BOOTSTAGE_ID_RD_HDR_CHECKSUM); + bootstage_error(BOOTSTAGE_ID_RD_HDR_CHECKSUM); return NULL; }
- show_boot_progress(BOOTSTAGE_ID_RD_MAGIC); + bootstage_mark(BOOTSTAGE_ID_RD_MAGIC); image_print_contents(rd_hdr);
if (verify) { puts(" Verifying Checksum ... "); if (!image_check_dcrc(rd_hdr)) { puts("Bad Data CRC\n"); - show_boot_error(BOOTSTAGE_ID_RD_CHECKSUM); + bootstage_error(BOOTSTAGE_ID_RD_CHECKSUM); return NULL; } puts("OK\n"); }
- show_boot_progress(BOOTSTAGE_ID_RD_HDR_CHECKSUM); + bootstage_mark(BOOTSTAGE_ID_RD_HDR_CHECKSUM);
if (!image_check_os(rd_hdr, IH_OS_LINUX) || !image_check_arch(rd_hdr, arch) || !image_check_type(rd_hdr, IH_TYPE_RAMDISK)) { printf("No Linux %s Ramdisk Image\n", genimg_get_arch_name(arch)); - show_boot_error(BOOTSTAGE_ID_RAMDISK); + bootstage_error(BOOTSTAGE_ID_RAMDISK); return NULL; }
@@ -895,7 +895,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, printf("## Loading init Ramdisk from Legacy " "Image at %08lx ...\n", rd_addr);
- show_boot_progress(BOOTSTAGE_ID_CHECK_RAMDISK); + bootstage_mark(BOOTSTAGE_ID_CHECK_RAMDISK); rd_hdr = image_get_ramdisk(rd_addr, arch, images->verify);
@@ -912,14 +912,14 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, printf("## Loading init Ramdisk from FIT " "Image at %08lx ...\n", rd_addr);
- show_boot_progress(BOOTSTAGE_ID_FIT_RD_FORMAT); + bootstage_mark(BOOTSTAGE_ID_FIT_RD_FORMAT); if (!fit_check_format(fit_hdr)) { puts("Bad FIT ramdisk image format!\n"); - show_boot_error( + bootstage_error( BOOTSTAGE_ID_FIT_RD_FORMAT); return 1; } - show_boot_progress(BOOTSTAGE_ID_FIT_RD_FORMAT_OK); + bootstage_mark(BOOTSTAGE_ID_FIT_RD_FORMAT_OK);
if (!fit_uname_ramdisk) { /* @@ -927,14 +927,14 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, * node first. If config unit node name is NULL * fit_conf_get_node() will try to find default config node */ - show_boot_progress( + bootstage_mark( BOOTSTAGE_ID_FIT_RD_NO_UNIT_NAME); cfg_noffset = fit_conf_get_node(fit_hdr, fit_uname_config); if (cfg_noffset < 0) { puts("Could not find configuration " "node\n"); - show_boot_error( + bootstage_error( BOOTSTAGE_ID_FIT_RD_NO_UNIT_NAME); return 1; } @@ -949,21 +949,21 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, rd_noffset, NULL); } else { /* get ramdisk component image node offset */ - show_boot_progress( + bootstage_mark( BOOTSTAGE_ID_FIT_RD_UNIT_NAME); rd_noffset = fit_image_get_node(fit_hdr, fit_uname_ramdisk); } if (rd_noffset < 0) { puts("Could not find subimage node\n"); - show_boot_error(BOOTSTAGE_ID_FIT_RD_SUBNODE); + bootstage_error(BOOTSTAGE_ID_FIT_RD_SUBNODE); return 1; }
printf(" Trying '%s' ramdisk subimage\n", fit_uname_ramdisk);
- show_boot_progress(BOOTSTAGE_ID_FIT_RD_CHECK); + bootstage_mark(BOOTSTAGE_ID_FIT_RD_CHECK); if (!fit_check_ramdisk(fit_hdr, rd_noffset, arch, images->verify)) return 1; @@ -972,10 +972,10 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, if (fit_image_get_data(fit_hdr, rd_noffset, &data, &size)) { puts("Could not find ramdisk subimage data!\n"); - show_boot_error(BOOTSTAGE_ID_FIT_RD_GET_DATA); + bootstage_error(BOOTSTAGE_ID_FIT_RD_GET_DATA); return 1; } - show_boot_progress(BOOTSTAGE_ID_FIT_RD_GET_DATA_OK); + bootstage_mark(BOOTSTAGE_ID_FIT_RD_GET_DATA_OK);
rd_data = (ulong)data; rd_len = size; @@ -983,10 +983,10 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, if (fit_image_get_load(fit_hdr, rd_noffset, &rd_load)) { puts("Can't get ramdisk subimage load " "address!\n"); - show_boot_error(BOOTSTAGE_ID_FIT_RD_LOAD); + bootstage_error(BOOTSTAGE_ID_FIT_RD_LOAD); return 1; } - show_boot_progress(BOOTSTAGE_ID_FIT_RD_LOAD); + bootstage_mark(BOOTSTAGE_ID_FIT_RD_LOAD);
images->fit_hdr_rd = fit_hdr; images->fit_uname_rd = fit_uname_ramdisk; @@ -1006,7 +1006,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, * Now check if we have a legacy mult-component image, * get second entry data start address and len. */ - show_boot_progress(BOOTSTAGE_ID_RAMDISK); + bootstage_mark(BOOTSTAGE_ID_RAMDISK); printf("## Loading init Ramdisk from multi component " "Legacy Image at %08lx ...\n", (ulong)images->legacy_hdr_os); @@ -1016,7 +1016,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, /* * no initrd image */ - show_boot_progress(BOOTSTAGE_ID_NO_RAMDISK); + bootstage_mark(BOOTSTAGE_ID_NO_RAMDISK); rd_len = rd_data = 0; }
@@ -1100,7 +1100,7 @@ int boot_ramdisk_high(struct lmb *lmb, ulong rd_data, ulong rd_len, puts("ramdisk - allocation error\n"); goto error; } - show_boot_progress(BOOTSTAGE_ID_COPY_RAMDISK); + bootstage_mark(BOOTSTAGE_ID_COPY_RAMDISK);
*initrd_end = *initrd_start + rd_len; printf(" Loading Ramdisk to %08lx, end %08lx ... ", @@ -3175,23 +3175,23 @@ static int fit_check_ramdisk(const void *fit, int rd_noffset, uint8_t arch, puts(" Verifying Hash Integrity ... "); if (!fit_image_check_hashes(fit, rd_noffset)) { puts("Bad Data Hash\n"); - show_boot_error(BOOTSTAGE_ID_FIT_RD_HASH); + bootstage_error(BOOTSTAGE_ID_FIT_RD_HASH); return 0; } puts("OK\n"); }
- show_boot_progress(BOOTSTAGE_ID_FIT_RD_CHECK_ALL); + bootstage_mark(BOOTSTAGE_ID_FIT_RD_CHECK_ALL); if (!fit_image_check_os(fit, rd_noffset, IH_OS_LINUX) || !fit_image_check_arch(fit, rd_noffset, arch) || !fit_image_check_type(fit, rd_noffset, IH_TYPE_RAMDISK)) { printf("No Linux %s Ramdisk Image\n", genimg_get_arch_name(arch)); - show_boot_error(BOOTSTAGE_ID_FIT_RD_CHECK_ALL); + bootstage_error(BOOTSTAGE_ID_FIT_RD_CHECK_ALL); return 0; }
- show_boot_progress(BOOTSTAGE_ID_FIT_RD_CHECK_ALL_OK); + bootstage_mark(BOOTSTAGE_ID_FIT_RD_CHECK_ALL_OK); return 1; } #endif /* USE_HOSTCC */ diff --git a/include/bootstage.h b/include/bootstage.h index 8f7fcd7..b56d953 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -178,9 +178,35 @@ enum bootstage_id { * has occurred. */ void show_boot_progress(int val); -static inline void show_boot_error(int val) + +#ifdef CONFIG_BOOTSTAGE +/* This is the full bootstage implementation */ + +/* + * Mark a time stamp for the current boot stage. + */ +ulong bootstage_mark(enum bootstage_id id); + +ulong bootstage_error(enum bootstage_id id); + +#else +/* + * This is a dummy implementation which just calls show_boot_progress(), + * and won't even do that unless CONFIG_SHOW_BOOT_PROGRESS is defined + */ + +static inline ulong bootstage_mark(enum bootstage_id id) +{ + show_boot_progress(id); + return 0; +} + +static inline ulong bootstage_error(enum bootstage_id id) { - show_boot_progress(-val); + show_boot_progress(-id); + return 0; }
+#endif /* CONFIG_BOOTSTAGE */ + #endif diff --git a/net/eth.c b/net/eth.c index 8fc84bc..9000fc7 100644 --- a/net/eth.c +++ b/net/eth.c @@ -230,7 +230,7 @@ int eth_initialize(bd_t *bis) eth_devices = NULL; eth_current = NULL;
- show_boot_progress(BOOTSTAGE_ID_NET_ETH_START); + bootstage_mark(BOOTSTAGE_ID_NET_ETH_START); #if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_init(); #endif @@ -260,12 +260,12 @@ int eth_initialize(bd_t *bis) #endif if (!eth_devices) { puts ("No ethernet found.\n"); - show_boot_error(BOOTSTAGE_ID_NET_ETH_START); + bootstage_error(BOOTSTAGE_ID_NET_ETH_START); } else { struct eth_device *dev = eth_devices; char *ethprime = getenv ("ethprime");
- show_boot_progress(BOOTSTAGE_ID_NET_ETH_INIT); + bootstage_mark(BOOTSTAGE_ID_NET_ETH_INIT); do { if (dev->index) puts (", "); diff --git a/post/post.c b/post/post.c index 9764e1d..7100d8b 100644 --- a/post/post.c +++ b/post/post.c @@ -158,7 +158,7 @@ void post_output_backlog(void) post_log("PASSED\n"); else { post_log("FAILED\n"); - show_boot_error(BOOTSTAGE_ID_POST_FAIL_R); + bootstage_error(BOOTSTAGE_ID_POST_FAIL_R); } } } @@ -295,7 +295,7 @@ static int post_run_single(struct post_test *test, } else { if ((*test->test)(flags) != 0) { post_log("FAILED\n"); - show_boot_error(BOOTSTAGE_ID_POST_FAIL_R); + bootstage_error(BOOTSTAGE_ID_POST_FAIL_R); show_post_progress(i, POST_AFTER, POST_FAILED); if (test_flags & POST_CRITICAL) gd->flags |= GD_FLG_POSTFAIL;
This defines the basics of a new boot time measurement feature. This allows logging of very accurate time measurements as the boot proceeds, by using an available microsecond counter.
To enable the feature, define CONFIG_BOOTSTAGE in your board config file. Also available is CONFIG_BOOTSTAGE_REPORT which will cause a report to be printed just before handing off to the OS.
Most IDs are not named at this stage. For that I would first like to renumber them all.
Timer summary in microseconds: Mark Elapsed Stage 0 0 reset 205,000 205,000 board_init_f 6,053,000 5,848,000 bootm_start 6,053,000 0 id=1 6,058,000 5,000 id=101 6,058,000 0 id=100 6,061,000 3,000 id=103 6,064,000 3,000 id=104 6,093,000 29,000 id=107 6,093,000 0 id=106 6,093,000 0 id=105 6,093,000 0 id=108 7,089,000 996,000 id=7 7,089,000 0 id=15 7,089,000 0 id=8 7,097,000 8,000 start_kernel
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v3: - Fix code style in bootstage_mark_name() - Make main bootstage commit title more explicit
Changes in v4: - Print times in unsigned format, and increase range - Remove guards around calls to show_boot_progress() - Sort by unsigned value to account for large time values
README | 25 ++++++++ common/Makefile | 1 + common/bootstage.c | 158 +++++++++++++++++++++++++++++++++++++++++++++++++++ include/bootstage.h | 43 ++++++++++++++ 4 files changed, 227 insertions(+), 0 deletions(-) create mode 100644 common/bootstage.c
diff --git a/README b/README index b6c9d0b..4c21924 100644 --- a/README +++ b/README @@ -2241,6 +2241,31 @@ The following options need to be configured: example, some LED's) on your board. At the moment, the following checkpoints are implemented:
+- Detailed boot stage timing + CONFIG_BOOTSTAGE + Define this option to get detailed timing of each stage + of the boot process. + + CONFIG_BOOTSTAGE_USER_COUNT + This is the number of available user bootstage records. + Each time you call bootstage_mark(BOOTSTAGE_ID_ALLOC, ...) + a new ID will be allocated from this stash. If you exceed + the limit, recording will stop. + + CONFIG_BOOTSTAGE_REPORT + Define this to print a report before boot, similar to this: + + Timer summary in microseconds: + Mark Elapsed Stage + 0 0 reset + 3,575,678 3,575,678 board_init_f start + 3,575,695 17 arch_cpu_init A9 + 3,575,777 82 arch_cpu_init done + 3,659,598 83,821 board_init_r start + 3,910,375 250,777 main_loop + 29,916,167 26,005,792 bootm_start + 30,361,327 445,160 start_kernel + Legacy uImage format:
Arg Where When diff --git a/common/Makefile b/common/Makefile index 2d9ae8c..038baf0 100644 --- a/common/Makefile +++ b/common/Makefile @@ -172,6 +172,7 @@ SPD := y endif COBJS-$(SPD) += ddr_spd.o COBJS-$(CONFIG_HWCONFIG) += hwconfig.o +COBJS-$(CONFIG_BOOTSTAGE) += bootstage.o COBJS-$(CONFIG_CONSOLE_MUX) += iomux.o COBJS-y += flash.o COBJS-$(CONFIG_CMD_KGDB) += kgdb.o kgdb_stubs.o diff --git a/common/bootstage.c b/common/bootstage.c new file mode 100644 index 0000000..d2bbe63 --- /dev/null +++ b/common/bootstage.c @@ -0,0 +1,158 @@ +/* + * Copyright (c) 2011, Google Inc. All rights reserved. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + + +/* + * This module records the progress of boot and arbitrary commands, and + * permits accurate timestamping of each. + * + * TBD: Pass timings to kernel in the FDT + */ + +#include <common.h> +#include <libfdt.h> + +DECLARE_GLOBAL_DATA_PTR; + +enum bootstage_flags { + BOOTSTAGEF_ERROR = 1 << 0, /* Error record */ + BOOTSTAGEF_ALLOC = 1 << 1, /* Allocate an id */ +}; + +struct bootstage_record { + ulong time_us; + const char *name; + int flags; /* see enum bootstage_flags */ + enum bootstage_id id; +}; + +static struct bootstage_record record[BOOTSTAGE_ID_COUNT] = { {1} }; +static int next_id = BOOTSTAGE_ID_USER; + +ulong bootstage_add_record(enum bootstage_id id, const char *name, + int flags) +{ + struct bootstage_record *rec; + ulong mark = timer_get_boot_us(); + + if (flags & BOOTSTAGEF_ALLOC) + id = next_id++; + + if (id < BOOTSTAGE_ID_COUNT) { + rec = &record[id]; + + /* Only record the first event for each */ + if (!rec->time_us) { + rec->time_us = mark; + rec->name = name; + rec->flags = flags; + rec->id = id; + } + } + + /* Tell the board about this progress */ + show_boot_progress(flags & BOOTSTAGEF_ERROR ? -id : id); + return mark; +} + + +ulong bootstage_mark(enum bootstage_id id) +{ + return bootstage_add_record(id, NULL, 0); +} + +ulong bootstage_error(enum bootstage_id id) +{ + return bootstage_add_record(id, NULL, BOOTSTAGEF_ERROR); +} + +ulong bootstage_mark_name(enum bootstage_id id, const char *name) +{ + int flags = 0; + + if (id == BOOTSTAGE_ID_ALLOC) + flags = BOOTSTAGEF_ALLOC; + return bootstage_add_record(id, name, flags); +} + +static void print_time(unsigned long us_time) +{ + char str[15], *s; + int grab = 3; + + /* We don't seem to have %'d in U-Boot */ + sprintf(str, "%12lu", us_time); + for (s = str + 3; *s; s += grab) { + if (s != str + 3) + putc(s[-1] != ' ' ? ',' : ' '); + printf("%.*s", grab, s); + grab = 3; + } +} + +static uint32_t print_time_record(enum bootstage_id id, + struct bootstage_record *rec, uint32_t prev) +{ + print_time(rec->time_us); + print_time(rec->time_us - prev); + if (rec->name) + printf(" %s\n", rec->name); + else if (id >= BOOTSTAGE_ID_USER) + printf(" user_%d\n", id - BOOTSTAGE_ID_USER); + else + printf(" id=%d\n", id); + return rec->time_us; +} + +static int h_compare_record(const void *r1, const void *r2) +{ + const struct bootstage_record *rec1 = r1, *rec2 = r2; + + return rec1->time_us > rec2->time_us ? 1 : -1; +} + +void bootstage_report(void) +{ + struct bootstage_record *rec = record; + int id; + uint32_t prev; + + puts("Timer summary in microseconds:\n"); + printf("%11s%11s %s\n", "Mark", "Elapsed", "Stage"); + + /* Fake the first record - we could get it from early boot */ + rec->name = "reset"; + rec->time_us = 0; + prev = print_time_record(BOOTSTAGE_ID_AWAKE, rec, 0); + + /* Sort records by increasing time */ + qsort(record, ARRAY_SIZE(record), sizeof(*rec), h_compare_record); + + for (id = 0; id < BOOTSTAGE_ID_COUNT; id++, rec++) { + if (rec->time_us != 0) + prev = print_time_record(rec->id, rec, prev); + } + if (next_id > BOOTSTAGE_ID_COUNT) + printf("(Overflowed internal boot id table by %d entries\n" + "- please increase CONFIG_BOOTSTAGE_USER_COUNT\n", + next_id - BOOTSTAGE_ID_COUNT); +} diff --git a/include/bootstage.h b/include/bootstage.h index b56d953..06ab2c8 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -26,6 +26,11 @@ #ifndef _BOOTSTAGE_H #define _BOOTSTAGE_H
+/* The number of boot stage records available for the user */ +#ifndef CONFIG_BOOTSTAGE_USER_COUNT +#define CONFIG_BOOTSTAGE_USER_COUNT 20 +#endif + /* * A list of boot stages that we know about. Each of these indicates the * state that we are at, and the action that we are about to perform. For @@ -169,6 +174,33 @@ enum bootstage_id {
BOOTSTAGE_ID_NAND_FIT_READ = 150, BOOTSTAGE_ID_NAND_FIT_READ_OK, + + /* + * These boot stages are new, higher level, and not directly related + * to the old boot progress numbers. They are useful for recording + * rough boot timing information. + */ + BOOTSTAGE_ID_AWAKE, + BOOTSTAGE_ID_START_UBOOT_F, + BOOTSTAGE_ID_START_UBOOT_R, + BOOTSTAGE_ID_USB_START, + BOOTSTAGE_ID_ETH_START, + BOOTSTAGE_ID_BOOTP_START, + BOOTSTAGE_ID_BOOTP_STOP, + BOOTSTAGE_ID_BOOTM_START, + BOOTSTAGE_ID_BOOTM_HANDOFF, + BOOTSTAGE_ID_MAIN_LOOP, + BOOTSTAGE_KERNELREAD_START, + BOOTSTAGE_KERNELREAD_STOP, + + BOOTSTAGE_ID_CPU_AWAKE, + BOOTSTAGE_ID_MAIN_CPU_AWAKE, + BOOTSTAGE_ID_MAIN_CPU_READY, + + /* a few spare for the user, from here */ + BOOTSTAGE_ID_USER, + BOOTSTAGE_ID_COUNT = BOOTSTAGE_ID_USER + CONFIG_BOOTSTAGE_USER_COUNT, + BOOTSTAGE_ID_ALLOC, };
/* @@ -189,6 +221,11 @@ ulong bootstage_mark(enum bootstage_id id);
+ulong bootstage_mark_name(enum bootstage_id id, const char *name); + +/* Print a report about boot time */ +void bootstage_report(void); + #else /* * This is a dummy implementation which just calls show_boot_progress(), @@ -207,6 +244,12 @@ static inline ulong bootstage_error(enum bootstage_id id) return 0; }
+static inline ulong bootstage_mark_name(enum bootstage_id id, const char *name) +{ + return 0; +} + + #endif /* CONFIG_BOOTSTAGE */
#endif
Dear Simon Glass,
Changes in v3:
Changes in v4:
Applied, thanks.
Add calls to bootstage before and after relocation, and just before jumping to the OS.
The idea here is you can call bootstage_report() to get a report. Additionally, if you define CONFIG_BOOTSTAGE_REPORT then a report is printed automatically by U-Boot just before jumping to the kernel.
Signed-off-by: Simon Glass sjg@chromium.org --- Changes in v2: - Unify show_boot_progress() into this series
Changes in v3: - Update commit message to clarify the purpose of CONFIG_BOOTSTAGE_REPORT
Changes in v4: - Fix up ARM bootstage calls to use correct names
arch/arm/lib/board.c | 3 +++ arch/arm/lib/bootm.c | 4 ++++ 2 files changed, 7 insertions(+), 0 deletions(-)
diff --git a/arch/arm/lib/board.c b/arch/arm/lib/board.c index 500e216..b9b35de 100644 --- a/arch/arm/lib/board.c +++ b/arch/arm/lib/board.c @@ -266,6 +266,8 @@ void board_init_f(ulong bootflag) ulong reg; #endif
+ bootstage_mark_name(BOOTSTAGE_ID_START_UBOOT_F, "board_init_f"); + /* Pointer is writable since we allocated a register for it */ gd = (gd_t *) ((CONFIG_SYS_INIT_SP_ADDR) & ~0x07); /* compiler optimization barrier needed for GCC >= 3.4 */ @@ -455,6 +457,7 @@ void board_init_r(gd_t *id, ulong dest_addr) gd = id;
gd->flags |= GD_FLG_RELOC; /* tell others: relocation done */ + bootstage_mark_name(BOOTSTAGE_ID_START_UBOOT_R, "board_init_r");
monitor_flash_len = _end_ofs;
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index f114cd6..2961ab2 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -83,6 +83,10 @@ void arch_lmb_reserve(struct lmb *lmb) static void announce_and_cleanup(void) { printf("\nStarting kernel ...\n\n"); + bootstage_mark_name(BOOTSTAGE_ID_BOOTM_HANDOFF, "start_kernel"); +#ifdef CONFIG_BOOTSTAGE_REPORT + bootstage_report(); +#endif
#ifdef CONFIG_USB_DEVICE {
Dear Simon Glass,
Changes in v2:
Changes in v3:
Changes in v4:
Applied, thanks.
Dear Simon Glass,
Changes in v4:
Applied (with fixes), thanks.
Dear Simon Glass,
Changes in v4:
Actually not all bisect issues have been fixed. Commit 5dc8871 bootstage: Convert progress numbers 1-9 into enums breaks build with this error:
image.c: In function 'boot_get_ramdisk': image.c:898: error: 'BOOTSTAGE_ID_LOAD_RAMDISK' undeclared (first use in this function) image.c:898: error: (Each undeclared identifier is reported only once image.c:898: error: for each function it appears in.)
Also, the v4 12/15 commit breaks the ETX094 board when building with ELDK 4.2 due to grown code size:
Before (v2011.12-511-g5ff5539)
text data bss dec hex filename 17752 1026 2585 21363 5373 /work/wd/tmp-ppc/net/libnet.o
After (v2011.12-512-g77060e):
text data bss dec hex filename 17788 1026 2585 21399 5397 /work/wd/tmp-ppc/net/libnet.o
Yes, the increase is small, but the linker map for this board is carefully crafted ;-)
I think I can fix this, though.
Hi Wolfgang,
On Mon, Mar 19, 2012 at 1:34 AM, Wolfgang Denk wd@denx.de wrote:
Dear Simon Glass,
Changes in v4:
Yes you are right I'm afraid.
Oh dear. The problem is that for my toolchain both builds fails as the code is too large. It doesn't show up as a difference. I tried with ELDK 4.2 - the overflow seems to be only 12 bytes!
Can you fix it by adjusting the bootstage code or is something else required.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Wenn das dann in die Hose geht, nehme ich es auf meine Kappe. -- Rudi Völler, 15. Nov 2003
