[U-Boot] SPL building unwanted code
I have boards (omap3_logic and omap3_logic_somlv) which do not want USB enabled for SPL yet SPL is showing USB chunks being compiled into it.
I had to create a patch [1] which disables the USB host controller when in SPL, yet some of the framework is still present. There appears to be an option in the SPL menu for enabling/disabling "Support USB host drivers" and an option for "Support USB Gadget drivers" and for me, neither are selected. What I'd like to do is kill off all the USB code inside SPL to shrink the size.
When I look at the Makefile for the USB host, there doesn't appear to be any checks for whether or not we're in SPL.
There also appears to be an inconsistency in where to place the options for enabling something in SPL. In some cases, high-level options are listed in SPL/TPL menu, but in other instances, the options are listed under the "Device Drivers" menu. What I'd like to do is add a menu option for CONFIG_SPL_USB which lets people turn off all USB code when in SPL if they don't want any, then fix up the Makefiles to use the SPL/TPL macros to determine if we need to build or not.
My question is is...Where should the menu item for enabling CONFIG_SPL_USB be used, in the SPL/TPL menu or the USB menu?
adam
We're indeed not consistent enough here. Given how large common/spl/Kconfig is already today I suspect the right answer is that more things should be grouped closer to their non-SPL/TPL counterpart questions, with correct depends on lines. And options with names such that we can't use CONFIG_IS_ENABLED(FOO)/obj-$(CONFIG_$(SPL_TPL_)_FOO) need to be renamed as well. That should in turn lead to being able to correctly drop USB out of SPL for example.
Adam Ford
