[PATCH] efi: fix semihosting EFI payload booting
At the moment any naive attempt to boot an EFI payload that has just been loaded via "hostfs" (sandbox or semihosting) is met by a rather confusing error message: =========== VExpress64# load hostfs - $kernel_addr_r Image 52752896 bytes read in 8 ms (6.1 GiB/s) VExpress64# bootefi $kernel_addr_r No UEFI binary known at 0x80080000 =========== Actually explicitly providing the filesize: VExpress64# bootefi $kernel_addr_r:$filesize works around that problem, but the issue lies deeper: the call to efi_set_bootdev() (as done by the generic load code) bails out at some point, leaving the image_addr and image_size variables unset, which triggers this message. The problem seems to be that "-" is not understood by the code creating an UEFI device path. We could try to fix just that, but actually semihosting seems to have some explicit support in UEFI (at least it does in EDK II): there is a separate GUID for it, and hostfs is significantly different in some aspects to justify special handling.
Check for the device name being "hostfs" and create a specific UEFI device path for semihosting in this case. This uses the GUID used by EDK II for almost 15 years. This fixes the above load/bootefi sequence without requiring an explicit file size argument.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- lib/efi_loader/efi_device_path.c | 34 ++++++++++++++++++++++++++++++++ 1 file changed, 34 insertions(+)
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index e2e98a39be1..b6d2074dd70 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1079,6 +1079,35 @@ struct efi_device_path *efi_dp_from_uart(void) return buf; }
+#define SEMIHOSTING_GUID \ + EFI_GUID(0xc5b9c74a, 0x6d72, 0x4719, \ + 0x99, 0xab, 0xc5, 0x9f, 0x19, 0x90, 0x91, 0xeb) + +struct efi_device_path *efi_dp_from_semihosting(void) +{ + const struct efi_device_path_vendor smh_vendor = { + .dp = { + .type = DEVICE_PATH_TYPE_HARDWARE_DEVICE, + .sub_type = DEVICE_PATH_SUB_TYPE_VENDOR, + .length = sizeof(smh_vendor), + }, + .guid = SEMIHOSTING_GUID, + }; + void *buf, *pos; + size_t dpsize = sizeof(smh_vendor) + sizeof(END); + + buf = efi_alloc(dpsize); + if (!buf) + return NULL; + pos = buf; + memcpy(pos, &smh_vendor, sizeof(smh_vendor)); + pos += sizeof(smh_vendor); + + memcpy(pos, &END, sizeof(END)); + + return buf; +} + #ifdef CONFIG_NETDEVICES struct efi_device_path *efi_dp_from_eth(void) { @@ -1210,6 +1239,11 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, *device = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, (uintptr_t)image_addr, image_size); + } else if (!strcmp(dev, "hostfs")) { + efi_get_image_parameters(&image_addr, &image_size); + + if (device) + *device = efi_dp_from_semihosting(); } else { part = blk_get_device_part_str(dev, devnr, &desc, &fs_partition, 1);
Could you, please, indicate how to invoke QEMU with semihosting enabled. This information needs to be added to doc/usage/semihosting.rst.
Can there be multiple semihosting block devices?
- EFI_GUID(0xc5b9c74a, 0x6d72, 0x4719, \
Can semihosting be moved to the driver model?
Then we could create a generic catch all for device path nodes for all uclasses.
Best regards
Heinrich
- const struct efi_device_path_vendor smh_vendor = {
.dp = {
- void *buf, *pos;
- size_t dpsize = sizeof(smh_vendor) + sizeof(END);
- buf = efi_alloc(dpsize);
- if (!buf)
return NULL;
- pos = buf;
- memcpy(pos, &smh_vendor, sizeof(smh_vendor));
- pos += sizeof(smh_vendor);
- memcpy(pos, &END, sizeof(END));
- return buf;
- #ifdef CONFIG_NETDEVICES struct efi_device_path *efi_dp_from_eth(void) {
- } else if (!strcmp(dev, "hostfs")) {
if (device)
} else { part = blk_get_device_part_str(dev, devnr, &desc, &fs_partition, 1);*device = efi_dp_from_semihosting();
On Wed, 10 May 2023 17:58:06 +0200 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
It's already there: https://u-boot.readthedocs.io/en/latest/usage/semihosting.html#qemu
It's mostly just "-semihosting" on the QEMU side, but it's not enabled by default in the QEMU defconfig, because it *was* needed to be provided in sync with the QEMU option. It's a debug feature, so there is no good discovery mechanism, really. I think Sean made this work, with this autodetect via trap feature, so we might want to enable this option now, at least for the filesystem part.
Regardless I was doing those experiments with the FVP fastmodel, which is the most original semihosting provider, I think, and always enables semihosting.
There is no semihosting *block device*, it's a pure filesystem interface. And there is conceptually only one instance of that: it's basically a hook in the debugger (or emulation software) to provide some kind of syscall interface, triggered by a certain instruction ("brk" on AArch64). This allows some very limited access to the host filesystem - read files, write files, but no listing, for instance. It is super convenient to launch the model and load the kernel (or whatever) directly from your build machine's filesystem - especially if you do bisects or trial-and-error experiments.
Mmh, I am not sure this is a thing, since there is no block device, it's a filesystem. Which is part of the problem, I believe, and probably also a good reason to treat it separately.
Need to digest that idea ....
Cheers, Andre
Best regards
Heinrich
.dp = {
- void *buf, *pos;
- if (!buf)
return NULL;
- pos = buf;
- return buf;
if (device)
This does not tell me which arguments I should pass to qemu-system-aarch64.
If it is missing in Ubuntu's QEMU, please, indicate how I can build a QEMU that allows testing. This information needs to go into semihosting.rst.
It seems FVP's are not open source (https://developer.arm.com/Tools%20and%20Software/Fixed%20Virtual%20Platforms).
We need some open source solution for testing the suggested changes.
Best regards
Heinrich
Cheers, Andre
Best regards
Heinrich
.dp = {
- void *buf, *pos;
- if (!buf)
return NULL;
- pos = buf;
- return buf;
if (device)
On Wed, 10 May 2023 23:19:33 +0200 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
I would say that's out of scope for this document, and is explained in doc/boards/emulation/qemu-arm.rst. A minimum working example is: $ qemu-system-aarch64 -M virt -cpu cortex-a57 -nographic -bios u-boot.bin
It's all there and it works on my 20.04 QEMU build out of the box. What I meant is that -semihosting is a QEMU command line *option*, and a very optional one, so to speak, as it's more an ARM low level debugger technology than anything else, and it was just adopted by QEMU. And until recently you had to make sure that you give that option to QEMU if you enable semihosting support in U-Boot, otherwise it would crash. For more details see Sean's FOSDEM talk: https://fosdem.org/2023/schedule/event/semihosting_uboot/
Sure, I just mentioned this because the models are just the reference implementation and natural habitat for semihosting: because it's enabled by default there, and it's an ancient ARM technology.
If you want to test it, just use your favourite QEMU command line (or the one I mention above) and add "-semihosting". Then load your EFI app: => load hostfs - $kernel_addr_r app.efi => bootefi $kernel_addr_r
Cheers, Andre
Best regards
Heinrich
Cheers, Andre
Best regards
Heinrich
.dp = {
- void *buf, *pos;
- if (!buf)
return NULL;
- pos = buf;
- return buf;
if (device)
Cheers, Andre
I have compiled qemu_arm64_defconfig with CONFIG_SERIAL_PROBE_ALL=y and invoked qemu-system-aarch64 (1:7.2+dfsg-5ubuntu2) on Ubuntu 23.10 with -semihosting.
qemu-system-aarch64 -semihosting \ -machine virt,gic-version=max -accel tcg,thread=multi \ -m 1G -smp cores=2 \ -bios denx/u-boot.bin -cpu cortex-a72 -nographic -gdb tcp::1234 \ -netdev user,id=eth0,tftp=tftp -device e1000,netdev=eth0,romfile= \ -drive if=none,file=arm64.img,format=raw,id=mydisk \ -drive if=pflash,format=raw,index=1,file=envstore.img \ -device virtio-rng-pci \ -device ich9-ahci,id=ahci -device ide-hd,drive=mydisk,bus=ahci.0
With and without your patch I get:
=> load hostfs - $kernel_addr_r foo ** No device specified ** Couldn't find partition hostfs - Can't set block device
Please, describe in sufficient detail how to use semihosting.
Best regards
Heinrich
Best regards
Heinrich
Cheers, Andre
Best regards
Heinrich
.dp = {
- void *buf, *pos;
- if (!buf)
return NULL;
- pos = buf;
- return buf;
if (device)
On Thu, 11 May 2023 08:22:30 +0200 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Cheers, Andre
Ah, sorry, I see that the semihosting QEMU doc section fails to mention that you need to enable CONFIG_SEMIHOSTING. That is just listed in the FVP section. I will send a patch later.
This should work then, if foo is a file in your local directory.
Hope that helps!
Cheers, Andre
Best regards
Heinrich
Best regards
Heinrich
Cheers, Andre
Best regards
Heinrich
.dp = {
- void *buf, *pos;
- if (!buf)
return NULL;
- pos = buf;
- return buf;
if (device)
On 5/10/23 16:13, Andre Przywara wrote: > At the moment any naive attempt to boot an EFI payload that has just > been loaded via "hostfs" (sandbox or semihosting) is met by a rather > confusing error message: > =========== > VExpress64# load hostfs - $kernel_addr_r Image > 52752896 bytes read in 8 ms (6.1 GiB/s) > VExpress64# bootefi $kernel_addr_r > No UEFI binary known at 0x80080000 > =========== > Actually explicitly providing the filesize: > VExpress64# bootefi $kernel_addr_r:$filesize > works around that problem, but the issue lies deeper: the call to > efi_set_bootdev() (as done by the generic load code) bails out at some > point, leaving the image_addr and image_size variables unset, which > triggers this message. The problem seems to be that "-" is not > understood by the code creating an UEFI device path. We could try to fix > just that, but actually semihosting seems to have some explicit support > in UEFI (at least it does in EDK II): there is a separate GUID for it, > and hostfs is significantly different in some aspects to justify special > handling. > > Check for the device name being "hostfs" and create a specific UEFI device > path for semihosting in this case. This uses the GUID used by EDK II for > almost 15 years. > This fixes the above load/bootefi sequence without requiring an explicit > file size argument. > > Signed-off-by: Andre Przywara andre.przywara@arm.com
Cheers, Andre
Hope that helps!
Cheers, Andre
Now I am able to debug the code.
I wonder if the file system should be exposed as EFI simple file system so that EFI applications can access it, e.g. for GRUB to load initrd and the kernel.
If we don't want to expose it, this change will be enough:
diff --git a/lib/efi_loader/efi_device_path.c b/lib/efi_loader/efi_device_path.c index e2e98a39be..058bdc1ee5 100644 --- a/lib/efi_loader/efi_device_path.c +++ b/lib/efi_loader/efi_device_path.c @@ -1203,7 +1203,7 @@ efi_status_t efi_dp_from_name(const char *dev, const char *devnr, } else if (!strcmp(dev, "Uart")) { if (device) *device = efi_dp_from_uart(); - } else if (!strcmp(dev, "Mem")) { + } else if (!strcmp(dev, "Mem") || !strcmp(dev, "hostfs") ) { efi_get_image_parameters(&image_addr, &image_size);
if (device)
Best regards
Heinrich
Hi Andre, Heinrich,
Apologies for being late to the party.
> On 5/10/23 16:13, Andre Przywara wrote: >> At the moment any naive attempt to boot an EFI payload that has just >> been loaded via "hostfs" (sandbox or semihosting) is met by a rather >> confusing error message: >> =========== >> VExpress64# load hostfs - $kernel_addr_r Image >> 52752896 bytes read in 8 ms (6.1 GiB/s) >> VExpress64# bootefi $kernel_addr_r >> No UEFI binary known at 0x80080000 >> =========== >> Actually explicitly providing the filesize: >> VExpress64# bootefi $kernel_addr_r:$filesize >> works around that problem, but the issue lies deeper: the call to >> efi_set_bootdev() (as done by the generic load code) bails out at some >> point, leaving the image_addr and image_size variables unset, which >> triggers this message. The problem seems to be that "-" is not >> understood by the code creating an UEFI device path. We could try to fix >> just that, but actually semihosting seems to have some explicit support >> in UEFI (at least it does in EDK II): there is a separate GUID for it, >> and hostfs is significantly different in some aspects to justify special >> handling. >> >> Check for the device name being "hostfs" and create a specific UEFI device >> path for semihosting in this case. This uses the GUID used by EDK II for >> almost 15 years. >> This fixes the above load/bootefi sequence without requiring an explicit >> file size argument. >> >> Signed-off-by: Andre Przywara andre.przywara@arm.com > > Could you, please, indicate how to invoke QEMU with semihosting enabled. > This information needs to be added to doc/usage/semihosting.rst.
Cheers, Andre
Hope that helps!
Cheers, Andre
} else if (!strcmp(dev, "Mem") || !strcmp(dev, "hostfs") ) { efi_get_image_parameters(&image_addr, &image_size); if (device)
I think it's a question of use cases here. Andre do you think that making the host filesystem accessible through EFI and the simple file system protocol is important or needed for the low level debugging semihosting is designed to enable? If the answer there is no, then I think I prefer Heinrichs patch
Thanks /Ilias
Best regards
Heinrich
On Thu, 11 May 2023 17:23:13 +0200 Heinrich Schuchardt xypron.glpk@gmx.de wrote:
Hi Heinrich, Ilias,
Yes, this would be the ultimate goal. There is no file listing functionality in semihosting, which is a bummer, but it should still work if you know the file name. On top of the EDK-II shell or grub being able to load an image, this would also allow to easily specify an initrd via the kernel command line. This works with EDK-II's semihosting support.
But I see that this requires more work, IIUC we need to support hostfs explicitly via the EFI_SIMPLE_FILE_SYSTEM_PROTOCOL. At the moment this seems to assume that there is some underlying block device, so this might need some refactoring.
As it stands right now, your much simpler patch seems to provide the same functionality as mine, so I wonder if we should take this as a kind of quick fix, to allow starting EFI apps loaded via hostfs (including sandbox, btw).
Eventually, when introducing proper filesystem protocol support, this patch probably would need to come back.
So I leave this up to you, but am fine with your simpler patch.
Cheers, Andre
Best regards
Heinrich
Cheers, Andre
GRUB only consumes the block IO protocol so it would not benefit.
Linux consumes the simple file system protocol but passing file names via the command line has been deprecated by the EFI maintainer.
Best regards
Heinrich
Andre Przywara
Ilias Apalodimas
