[U-Boot] [PATCH 5/6] mips: ath79: Use AR933X_PLL_SWITCH_CLOCK_CONTROL_REG macro define
Add AR933X_PLL_SWITCH_CLOCK_CONTROL_REG define for ar933x chip.
Signed-off-by: Wills Wang wills.wang@live.com ---
arch/mips/mach-ath79/include/mach/ar71xx_regs.h | 1 + arch/mips/mach-ath79/reset.c | 2 +- 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h index dabcad0..7b48524 100644 --- a/arch/mips/mach-ath79/include/mach/ar71xx_regs.h +++ b/arch/mips/mach-ath79/include/mach/ar71xx_regs.h @@ -331,6 +331,7 @@ #define AR933X_PLL_CPU_CONFIG_REG 0x00 #define AR933X_PLL_CLK_CTRL_REG 0x08 #define AR933X_PLL_DITHER_FRAC_REG 0x10 +#define AR933X_PLL_SWITCH_CLOCK_CONTROL_REG 0x24
#define AR933X_PLL_CPU_CONFIG_NINT_SHIFT 10 #define AR933X_PLL_CPU_CONFIG_NINT_MASK 0x3f diff --git a/arch/mips/mach-ath79/reset.c b/arch/mips/mach-ath79/reset.c index a5ee141..073a179 100644 --- a/arch/mips/mach-ath79/reset.c +++ b/arch/mips/mach-ath79/reset.c @@ -89,7 +89,7 @@ static int eth_init_ar933x(void) mdelay(10);
/* Get Atheros S26 PHY out of reset. */ - clrsetbits_be32(pregs + AR934X_PLL_SWITCH_CLOCK_CONTROL_REG, + clrsetbits_be32(pregs + AR933X_PLL_SWITCH_CLOCK_CONTROL_REG, 0x1f, 0x10); mdelay(10);
Am 30.05.2016 um 16:54 schrieb Wills Wang:
applied to u-boot-mips, thanks!
Daniel Schwierzeck
Wills Wang
