[U-Boot] [PATCH] arm: socfpga: Do not call board_init_r() from board_init_f()
Instead of calling board_init_r() directly from board_init_f(), just return from board_init_f(). This will make the code continue executing in crt0.S _main(), from which the board_init_r() is called. This patch aligns the SoCFPGA SPL with the correct SPL design as well as reduces the stack utilisation slightly.
Signed-off-by: Marek Vasut marex@denx.de Cc: Dinh Nguyen dinguyen@opensource.altera.com --- arch/arm/mach-socfpga/spl.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/mach-socfpga/spl.c b/arch/arm/mach-socfpga/spl.c index 13ec24b..775a827 100644 --- a/arch/arm/mach-socfpga/spl.c +++ b/arch/arm/mach-socfpga/spl.c @@ -180,6 +180,4 @@ void board_init_f(ulong dummy)
/* Configure simple malloc base pointer into RAM. */ gd->malloc_base = CONFIG_SYS_TEXT_BASE + (1024 * 1024); - - board_init_r(NULL, 0); }
Applied, this is needed.
Best regards, Marek Vasut
